RTEMS  5.1
if_wmreg.h
1 /* $NetBSD: if_wmreg.h,v 1.22 2007/04/29 20:35:21 bouyer Exp $ */
2
3 /*
4  * Copyright (c) 2001 Wasabi Systems, Inc.
5  * All rights reserved.
6  *
7  * Written by Jason R. Thorpe for Wasabi Systems, Inc.
8  * Some are added by Shuchen Kate Feng <feng1@bnl.gov>,
9  * NSLS, Brookhaven National Laboratory. All rights reserved.
10  * under the Deaprtment of Energy contract DE-AC02-98CH10886
11  *
12  * Redistribution and use in source and binary forms, with or without
13  * modification, are permitted provided that the following conditions
14  * are met:
15  * 1. Redistributions of source code must retain the above copyright
16  * notice, this list of conditions and the following disclaimer.
17  * 2. Redistributions in binary form must reproduce the above copyright
18  * notice, this list of conditions and the following disclaimer in the
19  * documentation and/or other materials provided with the distribution.
20  * 3. All advertising materials mentioning features or use of this software
21  * must display the following acknowledgement:
22  * This product includes software developed for the NetBSD Project by
23  * Wasabi Systems, Inc.
24  * 4. The name of Wasabi Systems, Inc. may not be used to endorse
25  * or promote products derived from this software without specific prior
26  * written permission.
27  *
28  * THIS SOFTWARE IS PROVIDED BY WASABI SYSTEMS, INC. ``AS IS'' AND
29  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
30  * TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
31  * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL WASABI SYSTEMS, INC
32  * BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
33  * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
34  * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
35  * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
36  * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
37  * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
38  * POSSIBILITY OF SUCH DAMAGE.
39  */
40
41 /*
42  * Register description for the Intel i82542 (``Wiseman''),
43  * i82543 (``Livengood''), and i82544 (``Cordova'') Gigabit
44  * Ethernet chips.
45  */
46
47 /*
48  * The wiseman supports 64-bit PCI addressing. This structure
49  * describes the address in descriptors.
50  */
51 typedef struct wiseman_addr {
52  uint32_t wa_low; /* low-order 32 bits */
53  uint32_t wa_high; /* high-order 32 bits */
54 } __attribute__((__packed__)) wiseman_addr_t;
55
56 /*
57  * The Wiseman receive descriptor.
58  *
59  * The receive descriptor ring must be aligned to a 4K boundary,
60  * and there must be an even multiple of 8 descriptors in the ring.
61  */
62 typedef volatile struct wiseman_rxdesc {
63  wiseman_addr_t wrx_addr; /* buffer address */
64
65  uint16_t wrx_len; /* buffer length */
66  uint16_t wrx_cksum; /* checksum (starting at PCSS) */
67
68  uint8_t wrx_status; /* Rx status */
69  uint8_t wrx_errors; /* Rx errors */
70  uint16_t wrx_special; /* special field (VLAN, etc.) */
71 } __attribute__((__packed__)) wiseman_rxdesc_t;
72
73 /* wrx_status bits */
74 #define WRX_ST_DD (1U << 0) /* descriptor done */
75 #define WRX_ST_EOP (1U << 1) /* end of packet */
76 #define WRX_ST_IXSM (1U << 2) /* ignore checksum indication */
77 #define WRX_ST_VP (1U << 3) /* VLAN packet */
78 #define WRX_ST_BPDU (1U << 4) /* ??? */
79 #define WRX_ST_TCPCS (1U << 5) /* TCP checksum performed */
80 #define WRX_ST_IPCS (1U << 6) /* IP checksum performed */
81 #define WRX_ST_PIF (1U << 7) /* passed in-exact filter */
82
83 /* wrx_error bits */
84 #define WRX_ER_CE (1U << 0) /* CRC error */
85 #define WRX_ER_SE (1U << 1) /* symbol error */
86 #define WRX_ER_SEQ (1U << 2) /* sequence error */
87 #define WRX_ER_ICE (1U << 3) /* ??? */
88 #define WRX_ER_CXE (1U << 4) /* carrier extension error */
89 #define WRX_ER_TCPE (1U << 5) /* TCP checksum error */
90 #define WRX_ER_IPE (1U << 6) /* IP checksum error */
91 #define WRX_ER_RXE (1U << 7) /* Rx data error */
92
93 /* wrx_special field for VLAN packets */
94 #define WRX_VLAN_ID(x) ((x) & 0x0fff) /* VLAN identifier */
95 #define WRX_VLAN_CFI (1U << 12) /* Canonical Form Indicator */
96 #define WRX_VLAN_PRI(x) (((x) >> 13) & 7)/* VLAN priority field */
97
98 /*
99  * The Wiseman transmit descriptor.
100  *
101  * The transmit descriptor ring must be aligned to a 4K boundary,
102  * and there must be an even multiple of 8 descriptors in the ring.
103  */
104 typedef struct wiseman_tx_fields {
105  uint8_t wtxu_status; /* Tx status */
106  uint8_t wtxu_options; /* options */
107  uint16_t wtxu_vlan; /* VLAN info */
108 } __attribute__((__packed__)) wiseman_txfields_t;
109 typedef volatile struct wiseman_txdesc {
110  wiseman_addr_t wtx_addr; /* buffer address */
111  uint32_t wtx_cmdlen; /* command and length */
112  wiseman_txfields_t wtx_fields; /* fields; see below */
113 } __attribute__((__packed__)) wiseman_txdesc_t;
114
115 /* Commands for wtx_cmdlen */
116 #define WTX_CMD_EOP (1U << 24) /* end of packet */
117 #define WTX_CMD_IFCS (1U << 25) /* insert FCS */
118 #define WTX_CMD_RS (1U << 27) /* report status */
119 #define WTX_CMD_RPS (1U << 28) /* report packet sent */
120 #define WTX_CMD_DEXT (1U << 29) /* descriptor extension */
121 #define WTX_CMD_VLE (1U << 30) /* VLAN enable */
122 #define WTX_CMD_IDE (1U << 31) /* interrupt delay enable */
123
124 /* Descriptor types (if DEXT is set) */
125 #define WTX_DTYP_C (0U << 20) /* context */
126 #define WTX_DTYP_D (1U << 20) /* data */
127
128 /* wtx_fields status bits */
129 #define WTX_ST_DD (1U << 0) /* descriptor done */
130 #define WTX_ST_EC (1U << 1) /* excessive collisions */
131 #define WTX_ST_LC (1U << 2) /* late collision */
132 #define WTX_ST_TU (1U << 3) /* transmit underrun */
133
134 /* wtx_fields option bits for IP/TCP/UDP checksum offload */
135 #define WTX_IXSM (1U << 0) /* IP checksum offload */
136 #define WTX_TXSM (1U << 1) /* TCP/UDP checksum offload */
137
138 /* Maximum payload per Tx descriptor */
139 #define WTX_MAX_LEN 4096
140
141 /*
142  * The Livengood TCP/IP context descriptor.
143  */
145  uint32_t tcpip_ipcs; /* IP checksum context */
146  uint32_t tcpip_tucs; /* TCP/UDP checksum context */
147  uint32_t tcpip_cmdlen;
148  uint32_t tcpip_seg; /* TCP segmentation context */
149 };
150
151 /* commands for context descriptors */
152 #define WTX_TCPIP_CMD_TCP (1U << 24) /* 1 = TCP, 0 = UDP */
153 #define WTX_TCPIP_CMD_IP (1U << 25) /* 1 = IPv4, 0 = IPv6 */
154 #define WTX_TCPIP_CMD_TSE (1U << 26) /* segmentation context valid */
155
156 #define WTX_TCPIP_IPCSS(x) ((x) << 0) /* checksum start */
157 #define WTX_TCPIP_IPCSO(x) ((x) << 8) /* checksum value offset */
158 #define WTX_TCPIP_IPCSE(x) ((x) << 16) /* checksum end */
159
160 #define WTX_TCPIP_TUCSS(x) ((x) << 0) /* checksum start */
161 #define WTX_TCPIP_TUCSO(x) ((x) << 8) /* checksum value offset */
162 #define WTX_TCPIP_TUCSE(x) ((x) << 16) /* checksum end */
163
164 #define WTX_TCPIP_SEG_STATUS(x) ((x) << 0)
165 #define WTX_TCPIP_SEG_HDRLEN(x) ((x) << 8)
166 #define WTX_TCPIP_SEG_MSS(x) ((x) << 16)
167
168 /*
169  * PCI config registers used by the Wiseman.
170  */
171 #define WM_PCI_MMBA PCI_MAPREG_START
172 /* registers for FLASH access on ICH8 */
173 #define WM_ICH8_FLASH 0x0014
174
175 /*
176  * Wiseman Control/Status Registers.
177  */
178 #define WMREG_CTRL 0x0000 /* Device Control Register */
179 #define CTRL_FD (1U << 0) /* full duplex */
180 #define CTRL_BEM (1U << 1) /* big-endian mode */
181 #define CTRL_PRIOR (1U << 2) /* 0 = receive, 1 = fair */
182 #define CTRL_LRST (1U << 3) /* link reset */
183 #define CTRL_ASDE (1U << 5) /* auto speed detect enable */
184 #define CTRL_SLU (1U << 6) /* set link up */
185 #define CTRL_ILOS (1U << 7) /* invert loss of signal */
186 #define CTRL_SPEED(x) ((x) << 8) /* speed (Livengood) */
187 #define CTRL_SPEED_10 CTRL_SPEED(0)
188 #define CTRL_SPEED_100 CTRL_SPEED(1)
189 #define CTRL_SPEED_1000 CTRL_SPEED(2)
190 #define CTRL_SPEED_MASK CTRL_SPEED(3)
191 #define CTRL_FRCSPD (1U << 11) /* force speed (Livengood) */
192 #define CTRL_FRCFDX (1U << 12) /* force full-duplex (Livengood) */
193 #define CTRL_D_UD_EN (1U << 13) /* Dock/Undock enable */
194 #define CTRL_D_UD_POL (1U << 14) /* Defined polarity of Dock/Undock indication in SDP[0] */
195 #define CTRL_F_PHY_R (1U << 15) /* Reset both PHY ports, through PHYRST_N pin */
196 #define CTRL_EXT_LINK_EN (1U << 16) /* enable link status from external LINK_0 and LINK_1 pins */
197 #define CTRL_SWDPINS_SHIFT 18
198 #define CTRL_SWDPINS_MASK 0x0f
199 #define CTRL_SWDPIN(x) (1U << (CTRL_SWDPINS_SHIFT + (x)))
200 #define CTRL_SWDPIO_SHIFT 22
201 #define CTRL_SWDPIO_MASK 0x0f
202 #define CTRL_SWDPIO(x) (1U << (CTRL_SWDPIO_SHIFT + (x)))
203 #define CTRL_RST (1U << 26) /* device reset */
204 #define CTRL_RFCE (1U << 27) /* Rx flow control enable */
205 #define CTRL_TFCE (1U << 28) /* Tx flow control enable */
206 #define CTRL_VME (1U << 30) /* VLAN Mode Enable */
207 #define CTRL_PHY_RESET (1U << 31) /* PHY reset (Cordova) */
208
209 #define WMREG_CTRL_SHADOW 0x0004 /* Device Control Register (shadow) */
210
211 #define WMREG_STATUS 0x0008 /* Device Status Register */
212 #define STATUS_FD (1U << 0) /* full duplex */
213 #define STATUS_LU (1U << 1) /* link up */
214 #define STATUS_TCKOK (1U << 2) /* Tx clock running */
215 #define STATUS_RBCOK (1U << 3) /* Rx clock running */
216 #define STATUS_FUNCID_SHIFT 2 /* 82546 function ID */
217 #define STATUS_FUNCID_MASK 3 /* ... */
218 #define STATUS_TXOFF (1U << 4) /* Tx paused */
219 #define STATUS_TBIMODE (1U << 5) /* fiber mode (Livengood) */
220 #define STATUS_SPEED(x) ((x) << 6) /* speed indication */
221 #define STATUS_SPEED_10 STATUS_SPEED(0)
222 #define STATUS_SPEED_100 STATUS_SPEED(1)
223 #define STATUS_SPEED_1000 STATUS_SPEED(2)
224 #define STATUS_ASDV(x) ((x) << 8) /* auto speed det. val. (Livengood) */
225 #define STATUS_MTXCKOK (1U << 10) /* MTXD clock running */
226 #define STATUS_PCI66 (1U << 11) /* 66MHz bus (Livengood) */
227 #define STATUS_BUS64 (1U << 12) /* 64-bit bus (Livengood) */
228 #define STATUS_PCIX_MODE (1U << 13) /* PCIX mode (Cordova) */
229 #define STATUS_PCIXSPD(x) ((x) << 14) /* PCIX speed indication (Cordova) */
230 #define STATUS_PCIXSPD_50_66 STATUS_PCIXSPD(0)
231 #define STATUS_PCIXSPD_66_100 STATUS_PCIXSPD(1)
232 #define STATUS_PCIXSPD_100_133 STATUS_PCIXSPD(2)
233 #define STATUS_PCIXSPD_MASK STATUS_PCIXSPD(3)
234
235 #define WMREG_EECD 0x0010 /* EEPROM Control Register */
236 #define EECD_SK (1U << 0) /* clock */
237 #define EECD_CS (1U << 1) /* chip select */
238 #define EECD_DI (1U << 2) /* data in */
239 #define EECD_DO (1U << 3) /* data out */
240 #define EECD_FWE(x) ((x) << 4) /* flash write enable control */
241 #define EECD_FWE_DISABLED EECD_FWE(1)
242 #define EECD_FWE_ENABLED EECD_FWE(2)
243 #define EECD_EE_REQ (1U << 6) /* (shared) EEPROM request */
244 #define EECD_EE_GNT (1U << 7) /* (shared) EEPROM grant */
245 #define EECD_EE_PRES (1U << 8) /* EEPROM present */
246 #define EECD_EE_SIZE (1U << 9) /* EEPROM size
247  (0 = 64 word, 1 = 256 word) */
248 #define EECD_EE_AUTORD (1U << 9) /* auto read done */
249 #define EECD_EE_ABITS (1U << 10) /* EEPROM address bits
250  (based on type) */
251 #define EECD_EE_TYPE (1U << 13) /* EEPROM type
252  (0 = Microwire, 1 = SPI) */
253 #define EECD_SEC1VAL (1U << 22) /* Sector One Valid */
254
255 #define UWIRE_OPC_ERASE 0x04 /* MicroWire "erase" opcode */
256 #define UWIRE_OPC_WRITE 0x05 /* MicroWire "write" opcode */
257 #define UWIRE_OPC_READ 0x06 /* MicroWire "read" opcode */
258
259 #define SPI_OPC_WRITE 0x02 /* SPI "write" opcode */
260 #define SPI_OPC_READ 0x03 /* SPI "read" opcode */
261 #define SPI_OPC_A8 0x08 /* opcode bit 3 == address bit 8 */
262 #define SPI_OPC_WREN 0x06 /* SPI "set write enable" opcode */
263 #define SPI_OPC_WRDI 0x04 /* SPI "clear write enable" opcode */
264 #define SPI_OPC_RDSR 0x05 /* SPI "read status" opcode */
265 #define SPI_OPC_WRSR 0x01 /* SPI "write status" opcode */
266 #define SPI_MAX_RETRIES 5000 /* max wait of 5ms for RDY signal */
267
268 #define SPI_SR_RDY 0x01
269 #define SPI_SR_WEN 0x02
270 #define SPI_SR_BP0 0x04
271 #define SPI_SR_BP1 0x08
272 #define SPI_SR_WPEN 0x80
273
274 #define EEPROM_OFF_MACADDR 0x00 /* MAC address offset */
275 #define EEPROM_OFF_CFG1 0x0a /* config word 1 */
276 #define EEPROM_OFF_CFG2 0x0f /* config word 2 */
277 #define EEPROM_OFF_SWDPIN 0x20 /* SWD Pins (Cordova) */
278
279 #define EEPROM_CFG1_LVDID (1U << 0)
280 #define EEPROM_CFG1_LSSID (1U << 1)
281 #define EEPROM_CFG1_PME_CLOCK (1U << 2)
282 #define EEPROM_CFG1_PM (1U << 3)
283 #define EEPROM_CFG1_ILOS (1U << 4)
284 #define EEPROM_CFG1_SWDPIO_SHIFT 5
285 #define EEPROM_CFG1_SWDPIO_MASK (0xf << EEPROM_CFG1_SWDPIO_SHIFT)
286 #define EEPROM_CFG1_IPS1 (1U << 8)
287 #define EEPROM_CFG1_LRST (1U << 9)
288 #define EEPROM_CFG1_FD (1U << 10)
289 #define EEPROM_CFG1_FRCSPD (1U << 11)
290 #define EEPROM_CFG1_IPS0 (1U << 12)
291 #define EEPROM_CFG1_64_32_BAR (1U << 13)
292
293 #define EEPROM_CFG2_CSR_RD_SPLIT (1U << 1)
294 #define EEPROM_CFG2_APM_EN (1U << 2)
295 #define EEPROM_CFG2_64_BIT (1U << 3)
296 #define EEPROM_CFG2_MAX_READ (1U << 4)
297 #define EEPROM_CFG2_DMCR_MAP (1U << 5)
298 #define EEPROM_CFG2_133_CAP (1U << 6)
299 #define EEPROM_CFG2_MSI_DIS (1U << 7)
300 #define EEPROM_CFG2_FLASH_DIS (1U << 8)
301 #define EEPROM_CFG2_FLASH_SIZE(x) (((x) & 3) >> 9)
302 #define EEPROM_CFG2_ANE (1U << 11)
303 #define EEPROM_CFG2_PAUSE(x) (((x) & 3) >> 12)
304 #define EEPROM_CFG2_ASDE (1U << 14)
305 #define EEPROM_CFG2_APM_PME (1U << 15)
306 #define EEPROM_CFG2_SWDPIO_SHIFT 4
307 #define EEPROM_CFG2_SWDPIO_MASK (0xf << EEPROM_CFG2_SWDPIO_SHIFT)
308
309 #define EEPROM_SWDPIN_MASK 0xdf
310 #define EEPROM_SWDPIN_SWDPIN_SHIFT 0
311 #define EEPROM_SWDPIN_SWDPIO_SHIFT 8
312
313 #define WMREG_EERD 0x0014 /* EEPROM read */
314 #define EERD_DONE 0x02 /* done bit */
315 #define EERD_START 0x01 /* First bit for telling part to start operation */
316 #define EERD_ADDR_SHIFT 2 /* Shift to the address bits */
317 #define EERD_DATA_SHIFT 16 /* Offset to data in EEPROM read/write registers */
318
319 #define WMREG_CTRL_EXT 0x0018 /* Extended Device Control Register */
320 #define CTRL_EXT_GPI_EN(x) (1U << (x)) /* gpin interrupt enable */
321 #define CTRL_EXT_SWDPINS_SHIFT 4
322 #define CTRL_EXT_SWDPINS_MASK 0x0d
323 #define CTRL_EXT_SWDPIN(x) (1U << (CTRL_EXT_SWDPINS_SHIFT + (x) - 4))
324 #define CTRL_EXT_SWDPIO_SHIFT 8
325 #define CTRL_EXT_SWDPIO_MASK 0x0d
326 #define CTRL_EXT_SWDPIO(x) (1U << (CTRL_EXT_SWDPIO_SHIFT + (x) - 4))
327 #define CTRL_EXT_ASDCHK (1U << 12) /* ASD check */
328 #define CTRL_EXT_EE_RST (1U << 13) /* EEPROM reset */
329 #define CTRL_EXT_IPS (1U << 14) /* invert power state bit 0 */
330 #define CTRL_EXT_SPD_BYPS (1U << 15) /* speed select bypass */
331 #define CTRL_EXT_IPS1 (1U << 16) /* invert power state bit 1 */
332 #define CTRL_EXT_RO_DIS (1U << 17) /* relaxed ordering disabled */
333 #define CTRL_EXT_LINK_MODE_MASK 0x00C00000
334 #define CTRL_EXT_LINK_MODE_GMII 0x00000000
335 #define CTRL_EXT_LINK_MODE_TBI 0x00C00000
336 #define CTRL_EXT_LINK_MODE_KMRN 0x00000000
337 #define CTRL_EXT_LINK_MODE_SERDES 0x00C00000
338
339
340 #define WMREG_MDIC 0x0020 /* MDI Control Register */
341 #define MDIC_DATA(x) ((x) & 0xffff)
342 #define MDIC_REGADD(x) ((x) << 16)
343 #define MDIC_PHYADD(x) ((x) << 21)
344 #define MDIC_OP_WRITE (1U << 26)
345 #define MDIC_OP_READ (2U << 26)
346 #define MDIC_READY (1U << 28)
347 #define MDIC_I (1U << 29) /* interrupt on MDI complete */
348 #define MDIC_E (1U << 30) /* MDI error */
349
350 #define WMREG_FCAL 0x0028 /* Flow Control Address Low */
351 #define FCAL_CONST 0x00c28001 /* Flow Control MAC addr low */
352
353 #define WMREG_FCAH 0x002c /* Flow Control Address High */
354 #define FCAH_CONST 0x00000100 /* Flow Control MAC addr high */
355
356 #define WMREG_FCT 0x0030 /* Flow Control Type */
357
358 #define WMREG_VET 0x0038 /* VLAN Ethertype */
359
360 #define WMREG_RAL_BASE 0x0040 /* Receive Address List */
361 #define WMREG_CORDOVA_RAL_BASE 0x5400
362 #define WMREG_RAL_LO(b, x) ((b) + ((x) << 3))
363 #define WMREG_RAL_HI(b, x) (WMREG_RAL_LO(b, x) + 4)
364  /*
365  * Receive Address List: The LO part is the low-order 32-bits
366  * of the MAC address. The HI part is the high-order 16-bits
367  * along with a few control bits.
368  */
369 #define RAL_AS(x) ((x) << 16) /* address select */
370 #define RAL_AS_DEST RAL_AS(0) /* (cordova?) */
371 #define RAL_AS_SOURCE RAL_AS(1) /* (cordova?) */
372 #define RAL_RDR1 (1U << 30) /* put packet in alt. rx ring */
373 #define RAL_AV (1U << 31) /* entry is valid */
374
375 #define WM_RAL_TABSIZE 16
376 #define WM_ICH8_RAL_TABSIZE 7
377
378 #define WMREG_ICR 0x00c0 /* Interrupt Cause Register */
379 #define ICR_TXDW (1U << 0) /* Tx desc written back */
380 #define ICR_TXQE (1U << 1) /* Tx queue empty */
381 #define ICR_LSC (1U << 2) /* link status change */
382 #define ICR_RXSEQ (1U << 3) /* receive sequence error */
383 #define ICR_RXDMT0 (1U << 4) /* Rx ring 0 nearly empty */
384 #define ICR_RXO (1U << 6) /* Rx overrun */
385 #define ICR_RXT0 (1U << 7) /* Rx ring 0 timer */
386 #define ICR_MDAC (1U << 9) /* MDIO access complete */
387 #define ICR_RXCFG (1U << 10) /* Receiving /C/ */
388 #define ICR_GPI(x) (1U << (x)) /* general purpose interrupts */
389 #define ICR_INT (1U << 31) /* device generated an interrupt */
390
391 #define WMREG_ITR 0x00c4 /* Interrupt Throttling Register */
392 #define ITR_IVAL_MASK 0xffff /* Interval mask */
393 #define ITR_IVAL_SHIFT 0 /* Interval shift */
394
395 #define WMREG_ICS 0x00c8 /* Interrupt Cause Set Register */
396  /* See ICR bits. */
397
398 #define WMREG_IMS 0x00d0 /* Interrupt Mask Set Register */
399  /* See ICR bits. */
400
401 #define WMREG_IMC 0x00d8 /* Interrupt Mask Clear Register */
402  /* See ICR bits. */
403
404 #define WMREG_RCTL 0x0100 /* Receive Control */
405 #define RCTL_EN (1U << 1) /* receiver enable */
406 #define RCTL_SBP (1U << 2) /* store bad packets */
407 #define RCTL_UPE (1U << 3) /* unicast promisc. enable */
408 #define RCTL_MPE (1U << 4) /* multicast promisc. enable */
409 #define RCTL_LPE (1U << 5) /* large packet enable */
410 #define RCTL_LBM(x) ((x) << 6) /* loopback mode */
411 #define RCTL_LBM_NONE RCTL_LBM(0)
412 #define RCTL_LBM_PHY RCTL_LBM(3)
413 #define RCTL_RDMTS(x) ((x) << 8) /* receive desc. min thresh size */
414 #define RCTL_RDMTS_1_2 RCTL_RDMTS(0)
415 #define RCTL_RDMTS_1_4 RCTL_RDMTS(1)
416 #define RCTL_RDMTS_1_8 RCTL_RDMTS(2)
417 #define RCTL_RDMTS_MASK RCTL_RDMTS(3)
418 #define RCTL_MO(x) ((x) << 12) /* multicast offset */
419 #define RCTL_BAM (1U << 15) /* broadcast accept mode */
420 #define RCTL_2k (0 << 16) /* 2k Rx buffers */
421 #define RCTL_1k (1 << 16) /* 1k Rx buffers */
422 #define RCTL_512 (2 << 16) /* 512 byte Rx buffers */
423 #define RCTL_256 (3 << 16) /* 256 byte Rx buffers */
424 #define RCTL_BSEX_16k (1 << 16) /* 16k Rx buffers (BSEX) */
425 #define RCTL_BSEX_8k (2 << 16) /* 8k Rx buffers (BSEX) */
426 #define RCTL_BSEX_4k (3 << 16) /* 4k Rx buffers (BSEX) */
427 #define RCTL_DPF (1U << 22) /* discard pause frames */
428 #define RCTL_PMCF (1U << 23) /* pass MAC control frames */
429 #define RCTL_BSEX (1U << 25) /* buffer size extension (Livengood) */
430 #define RCTL_SECRC (1U << 26) /* strip Ethernet CRC */
431
432 #define WMREG_OLD_RDTR0 0x0108 /* Receive Delay Timer (ring 0) */
433 #define WMREG_RDTR 0x2820
434 #define RDTR_FPD (1U << 31) /* flush partial descriptor */
435
436 #define WMREG_RADV 0x282c /* Receive Interrupt Absolute Delay Timer */
437
438 #define WMREG_OLD_RDBAL0 0x0110 /* Receive Descriptor Base Low (ring 0) */
439 #define WMREG_RDBAL 0x2800
440
441 #define WMREG_OLD_RDBAH0 0x0114 /* Receive Descriptor Base High (ring 0) */
442 #define WMREG_RDBAH 0x2804
443
444 #define WMREG_OLD_RDLEN0 0x0118 /* Receive Descriptor Length (ring 0) */
445 #define WMREG_RDLEN 0x2808
446
447 #define WMREG_OLD_RDH0 0x0120 /* Receive Descriptor Head (ring 0) */
448 #define WMREG_RDH 0x2810
449
450 #define WMREG_OLD_RDT0 0x0128 /* Receive Descriptor Tail (ring 0) */
451 #define WMREG_RDT 0x2818
452
453 #define WMREG_RXDCTL 0x2828 /* Receive Descriptor Control */
454 #define RXDCTL_PTHRESH(x) ((x) << 0) /* prefetch threshold */
455 #define RXDCTL_HTHRESH(x) ((x) << 8) /* host threshold */
456 #define RXDCTL_WTHRESH(x) ((x) << 16) /* write back threshold */
457 #define RXDCTL_GRAN (1U << 24) /* 0 = cacheline, 1 = descriptor */
458
459 #define WMREG_OLD_RDTR1 0x0130 /* Receive Delay Timer (ring 1) */
460
461 #define WMREG_OLD_RDBA1_LO 0x0138 /* Receive Descriptor Base Low (ring 1) */
462
463 #define WMREG_OLD_RDBA1_HI 0x013c /* Receive Descriptor Base High (ring 1) */
464
465 #define WMREG_OLD_RDLEN1 0x0140 /* Receive Drscriptor Length (ring 1) */
466
467 #define WMREG_OLD_RDH1 0x0148
468
469 #define WMREG_OLD_RDT1 0x0150
470
471 #define WMREG_OLD_FCRTH 0x0160 /* Flow Control Rx Threshold Hi (OLD) */
472 #define WMREG_FCRTL 0x2160 /* Flow Control Rx Threshold Lo */
473 #define FCRTH_DFLT 0x00008000
474
475 #define WMREG_OLD_FCRTL 0x0168 /* Flow Control Rx Threshold Lo (OLD) */
476 #define WMREG_FCRTH 0x2168 /* Flow Control Rx Threhsold Hi */
477 #define FCRTL_DFLT 0x00004000
478 #define FCRTL_XONE 0x80000000 /* Enable XON frame transmission */
479
480 #define WMREG_FCTTV 0x0170 /* Flow Control Transmit Timer Value */
481 #define FCTTV_DFLT 0x00000600
482
483 #define WMREG_TXCW 0x0178 /* Transmit Configuration Word (TBI mode) */
484  /* See MII ANAR_X bits. */
485 #define TXCW_TxConfig (1U << 30) /* Tx Config */
486 #define TXCW_ANE (1U << 31) /* Autonegotiate */
487
488 #define WMREG_RXCW 0x0180 /* Receive Configuration Word (TBI mode) */
489  /* See MII ANLPAR_X bits. */
490 #define RXCW_NC (1U << 26) /* no carrier */
491 #define RXCW_IV (1U << 27) /* config invalid */
492 #define RXCW_CC (1U << 28) /* config change */
493 #define RXCW_C (1U << 29) /* /C/ reception */
494 #define RXCW_SYNCH (1U << 30) /* synchronized */
495 #define RXCW_ANC (1U << 31) /* autonegotiation complete */
496
497 #define WMREG_MTA 0x0200 /* Multicast Table Array */
498 #define WMREG_CORDOVA_MTA 0x5200
499
500 #define WMREG_TCTL 0x0400 /* Transmit Control Register */
501 #define TCTL_EN (1U << 1) /* transmitter enable */
502 #define TCTL_PSP (1U << 3) /* pad short packets */
503 #define TCTL_CT(x) (((x) & 0xff) << 4) /* 4:11 - collision threshold */
504 #define TCTL_COLD(x) (((x) & 0x3ff) << 12) /* 12:21 - collision distance */
505 #define TCTL_SWXOFF (1U << 22) /* software XOFF */
506 #define TCTL_RTLC (1U << 24) /* retransmit on late collision */
507 #define TCTL_NRTU (1U << 25) /* no retransmit on underrun */
508 #define TCTL_MULR (1U << 28) /* multiple request */
509
510 #define TX_COLLISION_THRESHOLD 15
511 #define TX_COLLISION_DISTANCE_HDX 512
512 #define TX_COLLISION_DISTANCE_FDX 64
513
514 #define WMREG_TCTL_EXT 0x0404 /* Transmit Control Register */
515 #define TCTL_EXT_BST_MASK 0x000003FF /* Backoff Slot Time */
516 #define TCTL_EXT_GCEX_MASK 0x000FFC00 /* Gigabit Carry Extend Padding */
517
518 #define DEFAULT_80003ES2LAN_TCTL_EXT_GCEX 0x00010000
519
520 #define WMREG_TQSA_LO 0x0408
521
522 #define WMREG_TQSA_HI 0x040c
523
524 #define WMREG_TIPG 0x0410 /* Transmit IPG Register */
525 #define TIPG_IPGT(x) (x) /* IPG transmit time */
526 #define TIPG_IPGR1(x) ((x) << 10) /* IPG receive time 1 */
527 #define TIPG_IPGR2(x) ((x) << 20) /* IPG receive time 2 */
528
529 #define TIPG_WM_DFLT (TIPG_IPGT(0x0a) | TIPG_IPGR1(0x02) | TIPG_IPGR2(0x0a))
530 #define TIPG_LG_DFLT (TIPG_IPGT(0x06) | TIPG_IPGR1(0x08) | TIPG_IPGR2(0x06))
531 #define TIPG_1000T_DFLT (TIPG_IPGT(0x08) | TIPG_IPGR1(0x08) | TIPG_IPGR2(0x06))
532 #define TIPG_1000T_80003_DFLT \
533  (TIPG_IPGT(0x08) | TIPG_IPGR1(0x02) | TIPG_IPGR2(0x07))
534 #define TIPG_10_100_80003_DFLT \
535  (TIPG_IPGT(0x09) | TIPG_IPGR1(0x02) | TIPG_IPGR2(0x07))
536
537 #define WMREG_TQC 0x0418
538
539 #define WMREG_EEWR 0x102c /* EEPROM write */
540
541 #define WMREG_RDFH 0x2410 /* Receive Data FIFO Head */
542
543 #define WMREG_RDFT 0x2418 /* Receive Data FIFO Tail */
544
545 #define WMREG_RDFHS 0x2420 /* Receive Data FIFO Head Saved */
546
547 #define WMREG_RDFTS 0x2428 /* Receive Data FIFO Tail Saved */
548
549 #define WMREG_TDFH 0x3410 /* Transmit Data FIFO Head */
550
551 #define WMREG_TDFT 0x3418 /* Transmit Data FIFO Tail */
552
553 #define WMREG_TDFHS 0x3420 /* Transmit Data FIFO Head Saved */
554
555 #define WMREG_TDFTS 0x3428 /* Transmit Data FIFO Tail Saved */
556
557 #define WMREG_TDFPC 0x3430 /* Transmit Data FIFO Packet Count */
558
559 #define WMREG_OLD_TBDAL 0x0420 /* Transmit Descriptor Base Lo */
560 #define WMREG_TBDAL 0x3800
561
562 #define WMREG_OLD_TBDAH 0x0424 /* Transmit Descriptor Base Hi */
563 #define WMREG_TBDAH 0x3804
564
565 #define WMREG_OLD_TDLEN 0x0428 /* Transmit Descriptor Length */
566 #define WMREG_TDLEN 0x3808
567
568 #define WMREG_OLD_TDH 0x0430 /* Transmit Descriptor Head */
569 #define WMREG_TDH 0x3810
570
571 #define WMREG_OLD_TDT 0x0438 /* Transmit Descriptor Tail */
572 #define WMREG_TDT 0x3818
573
574 #define WMREG_OLD_TIDV 0x0440 /* Transmit Delay Interrupt Value */
575 #define WMREG_TIDV 0x3820
576
577 #define WMREG_TXDCTL 0x3828 /* Trandmit Descriptor Control */
578 #define TXDCTL_PTHRESH(x) ((x) << 0) /* prefetch threshold */
579 #define TXDCTL_HTHRESH(x) ((x) << 8) /* host threshold */
580 #define TXDCTL_WTHRESH(x) ((x) << 16) /* write back threshold */
581
582 #define WMREG_TADV 0x382c /* Transmit Absolute Interrupt Delay Timer */
583
584 #define WMREG_AIT 0x0458 /* Adaptive IFS Throttle */
585
586 #define WMREG_VFTA 0x0600
587
588 #define WM_MC_TABSIZE 128
589 #define WM_ICH8_MC_TABSIZE 32
590 #define WM_VLAN_TABSIZE 128
591
592 #define WMREG_PBA 0x1000 /* Packet Buffer Allocation */
593 #define PBA_BYTE_SHIFT 10 /* KB -> bytes */
594 #define PBA_ADDR_SHIFT 7 /* KB -> quadwords */
595 #define PBA_8K 0x0008
596 #define PBA_12K 0x000c
597 #define PBA_16K 0x0010 /* 16K, default Tx allocation */
598 #define PBA_22K 0x0016
599 #define PBA_24K 0x0018
600 #define PBA_30K 0x001e
601 #define PBA_32K 0x0020
602 #define PBA_40K 0x0028
603 #define PBA_48K 0x0030 /* 48K, default Rx allocation */
604
605 #define WMREG_PBS 0x1000 /* Packet Buffer Size (ICH8 only ?) */
606
607 #define WMREG_TXDMAC 0x3000 /* Transfer DMA Control */
608 #define TXDMAC_DPP (1U << 0) /* disable packet prefetch */
609
610 #define WMREG_TSPMT 0x3830 /* TCP Segmentation Pad and Minimum
611  Threshold (Cordova) */
612 #define TSPMT_TSMT(x) (x) /* TCP seg min transfer */
613 #define TSPMT_TSPBP(x) ((x) << 16) /* TCP seg pkt buf padding */
614
615 #define WMREG_RXCSUM 0x5000 /* Receive Checksum register */
616 #define RXCSUM_PCSS 0x000000ff /* Packet Checksum Start */
617 #define RXCSUM_IPOFL (1U << 8) /* IP checksum offload */
618 #define RXCSUM_TUOFL (1U << 9) /* TCP/UDP checksum offload */
619 #define RXCSUM_IPV6OFL (1U << 10) /* IPv6 checksum offload */
620
621 #define WMREG_RXERRC 0x400C /* receive error Count - R/clr */
622 #define WMREG_COLC 0x4028 /* collision Count - R/clr */
623 #define WMREG_XONRXC 0x4048 /* XON Rx Count - R/clr */
624 #define WMREG_XONTXC 0x404c /* XON Tx Count - R/clr */
625 #define WMREG_XOFFRXC 0x4050 /* XOFF Rx Count - R/clr */
626 #define WMREG_XOFFTXC 0x4054 /* XOFF Tx Count - R/clr */
627 #define WMREG_FCRUC 0x4058 /* Flow Control Rx Unsupported Count - R/clr */
628
629 #define WMREG_KUMCTRLSTA 0x0034 /* MAC-PHY interface - RW */
630 #define KUMCTRLSTA_MASK 0x0000FFFF
631 #define KUMCTRLSTA_OFFSET 0x001F0000
632 #define KUMCTRLSTA_OFFSET_SHIFT 16
633 #define KUMCTRLSTA_REN 0x00200000
634
635 #define KUMCTRLSTA_OFFSET_FIFO_CTRL 0x00000000
636 #define KUMCTRLSTA_OFFSET_CTRL 0x00000001
637 #define KUMCTRLSTA_OFFSET_INB_CTRL 0x00000002
638 #define KUMCTRLSTA_OFFSET_DIAG 0x00000003
639 #define KUMCTRLSTA_OFFSET_TIMEOUTS 0x00000004
640 #define KUMCTRLSTA_OFFSET_INB_PARAM 0x00000009
641 #define KUMCTRLSTA_OFFSET_HD_CTRL 0x00000010
642 #define KUMCTRLSTA_OFFSET_M2P_SERDES 0x0000001E
643 #define KUMCTRLSTA_OFFSET_M2P_MODES 0x0000001F
644
645 /* FIFO Control */
646 #define KUMCTRLSTA_FIFO_CTRL_RX_BYPASS 0x00000008
647 #define KUMCTRLSTA_FIFO_CTRL_TX_BYPASS 0x00000800
648
649 /* In-Band Control */
650 #define KUMCTRLSTA_INB_CTRL_LINK_TMOUT_DFLT 0x00000500
651 #define KUMCTRLSTA_INB_CTRL_DIS_PADDING 0x00000010
652
653 /* Half-Duplex Control */
654 #define KUMCTRLSTA_HD_CTRL_10_100_DEFAULT 0x00000004
655 #define KUMCTRLSTA_HD_CTRL_1000_DEFAULT 0x00000000
656
657 #define WMREG_MDPHYA 0x003C /* PHY address - RW */
658
659 #define WMREG_MANC2H 0x5860 /* Managment Control To Host - RW */
660
661 #define WMREG_SWSM 0x5b50 /* SW Semaphore */
662 #define SWSM_SMBI 0x00000001 /* Driver Semaphore bit */
663 #define SWSM_SWESMBI 0x00000002 /* FW Semaphore bit */
664 #define SWSM_WMNG 0x00000004 /* Wake MNG Clock */
665 #define SWSM_DRV_LOAD 0x00000008 /* Driver Loaded Bit */
666
667 #define WMREG_SW_FW_SYNC 0x5b5c /* software-firmware semaphore */
668 #define SWFW_EEP_SM 0x0001 /* eeprom access */
669 #define SWFW_PHY0_SM 0x0002 /* first ctrl phy access */
670 #define SWFW_PHY1_SM 0x0004 /* second ctrl phy access */
671 #define SWFW_MAC_CSR_SM 0x0008
672 #define SWFW_SOFT_SHIFT 0 /* software semaphores */
673 #define SWFW_FIRM_SHIFT 16 /* firmware semaphores */
674
675 #define WMREG_EXTCNFCTR 0x0f00 /* Extended Configuration Control */
676 #define EXTCNFCTR_PCIE_WRITE_ENABLE 0x00000001
677 #define EXTCNFCTR_PHY_WRITE_ENABLE 0x00000002
678 #define EXTCNFCTR_D_UD_ENABLE 0x00000004
679 #define EXTCNFCTR_D_UD_LATENCY 0x00000008
680 #define EXTCNFCTR_D_UD_OWNER 0x00000010
681 #define EXTCNFCTR_MDIO_SW_OWNERSHIP 0x00000020
682 #define EXTCNFCTR_MDIO_HW_OWNERSHIP 0x00000040
683 #define EXTCNFCTR_EXT_CNF_POINTER 0x0FFF0000
684 #define E1000_EXTCNF_CTRL_SWFLAG EXTCNFCTR_MDIO_SW_OWNERSHIP
685
686 /* ich8 flash control */
687 #define ICH_FLASH_COMMAND_TIMEOUT 5000 /* 5000 uSecs - adjusted */
688 #define ICH_FLASH_ERASE_TIMEOUT 3000000 /* Up to 3 seconds - worst case */
689 #define ICH_FLASH_CYCLE_REPEAT_COUNT 10 /* 10 cycles */
690 #define ICH_FLASH_SEG_SIZE_256 256
691 #define ICH_FLASH_SEG_SIZE_4K 4096
692 #define ICH_FLASH_SEG_SIZE_64K 65536
693
694 #define ICH_CYCLE_READ 0x0
695 #define ICH_CYCLE_RESERVED 0x1
696 #define ICH_CYCLE_WRITE 0x2
697 #define ICH_CYCLE_ERASE 0x3
698
699 #define ICH_FLASH_GFPREG 0x0000
700 #define ICH_FLASH_HSFSTS 0x0004 /* Flash Status Register */
701 #define HSFSTS_DONE 0x0001 /* Flash Cycle Done */
702 #define HSFSTS_ERR 0x0002 /* Flash Cycle Error */
703 #define HSFSTS_DAEL 0x0004 /* Direct Access error Log */
704 #define HSFSTS_ERSZ_MASK 0x0018 /* Block/Sector Erase Size */
705 #define HSFSTS_ERSZ_SHIFT 3
706 #define HSFSTS_FLINPRO 0x0020 /* flash SPI cycle in Progress */
707 #define HSFSTS_FLDVAL 0x4000 /* Flash Descriptor Valid */
708 #define HSFSTS_FLLK 0x8000 /* Flash Configuration Lock-Down */
709 #define ICH_FLASH_HSFCTL 0x0006 /* Flash control Register */
710 #define HSFCTL_GO 0x0001 /* Flash Cycle Go */
711 #define HSFCTL_CYCLE_MASK 0x0006 /* Flash Cycle */
712 #define HSFCTL_CYCLE_SHIFT 1
713 #define HSFCTL_BCOUNT_MASK 0x0300 /* Data Byte Count */
714 #define HSFCTL_BCOUNT_SHIFT 8
715 #define ICH_FLASH_FADDR 0x0008
716 #define ICH_FLASH_FDATA0 0x0010
717 #define ICH_FLASH_FRACC 0x0050
718 #define ICH_FLASH_FREG0 0x0054
719 #define ICH_FLASH_FREG1 0x0058
720 #define ICH_FLASH_FREG2 0x005C
721 #define ICH_FLASH_FREG3 0x0060
722 #define ICH_FLASH_FPR0 0x0074
723 #define ICH_FLASH_FPR1 0x0078
724 #define ICH_FLASH_SSFSTS 0x0090
725 #define ICH_FLASH_SSFCTL 0x0092
726 #define ICH_FLASH_PREOP 0x0094
727 #define ICH_FLASH_OPTYPE 0x0096
728 #define ICH_FLASH_OPMENU 0x0098
729
730 #define ICH_FLASH_REG_MAPSIZE 0x00A0
731 #define ICH_FLASH_SECTOR_SIZE 4096
732 #define ICH_GFPREG_BASE_MASK 0x1FFF
733 #define ICH_FLASH_LINEAR_ADDR_MASK 0x00FFFFFF
734
735 /* start of Kate Feng added */
736 #define WMREG_GPTC 0x4080 /* Good packets transmitted count */
737 #define WMREG_GPRC 0x4074 /* Good packets received count */
738 #define WMREG_CRCERRS 0x4000 /* CRC Error Count */
739 #define WMREG_RLEC 0x4040 /* Receive Length Error Count */
740 /* end of Kate Feng added */
Definition: if_wmreg.h:62
Definition: if_wmreg.h:104
Definition: if_wmreg.h:109
struct wiseman_addr __attribute__((__packed__)) wiseman_addr_t
The native record item.
Definition: recorddata.h:1175
Definition: if_wmreg.h:51
Definition: if_wmreg.h:144
