RTEMS  5.1
if_gfevar.h
1 #ifndef IF_GFEVAR_H
2 #define IF_GFEVAR_H
3 /* $NetBSD: if_gfevar.h,v 1.4.10.1 2005/04/29 11:28:56 kent Exp $ */
4
5 /*
6  * Copyright (c) 2002 Allegro Networks, Inc., Wasabi Systems, Inc.
7  * All rights reserved.
8  *
9  * Redistribution and use in source and binary forms, with or without
10  * modification, are permitted provided that the following conditions
11  * are met:
12  * 1. Redistributions of source code must retain the above copyright
13  * notice, this list of conditions and the following disclaimer.
14  * 2. Redistributions in binary form must reproduce the above copyright
15  * notice, this list of conditions and the following disclaimer in the
16  * documentation and/or other materials provided with the distribution.
17  * 3. All advertising materials mentioning features or use of this software
18  * must display the following acknowledgement:
19  * This product includes software developed for the NetBSD Project by
20  * Allegro Networks, Inc., and Wasabi Systems, Inc.
21  * 4. The name of Allegro Networks, Inc. may not be used to endorse
22  * or promote products derived from this software without specific prior
23  * written permission.
24  * 5. The name of Wasabi Systems, Inc. may not be used to endorse
25  * or promote products derived from this software without specific prior
26  * written permission.
27  *
28  * THIS SOFTWARE IS PROVIDED BY ALLEGRO NETWORKS, INC. AND
29  * WASABI SYSTEMS, INC. ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES,
30  * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY
31  * AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
32  * IN NO EVENT SHALL EITHER ALLEGRO NETWORKS, INC. OR WASABI SYSTEMS, INC.
33  * BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
34  * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
35  * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
36  * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
37  * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
38  * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
39  * POSSIBILITY OF SUCH DAMAGE.
40  */
41
42 /* NOTE: GE_RXDESC_MAX * 16 <= GE_RXDESC_MEMSIZE */
43 /* NOTE: the driver needs 4*GE_RXDESC_MAX mbuf clusters (4 queues) */
44 #ifndef __rtems__
45 #define GE_RXDESC_MEMSIZE (1 * PAGE_SIZE)
46 #define GE_RXDESC_MAX 64
47 #define GE_RXBUF_SIZE 2048
48 #define GE_RXBUF_MEMSIZE (GE_RXDESC_MAX*GE_RXBUF_SIZE)
49 #else
50 #define GE_RXDESC_MEMSIZE (GE_RXDESC_MAX * sizeof(struct gt_eth_desc))
51 #define GE_RXDESC_MAX (sc->num_rxdesc)
52 #define GE_RXBUF_MEMSIZE 0
53 #endif
54
55 #define GE_RXBUF_NSEGS ((GE_RXBUF_MEMSIZE/PAGE_SIZE)+1)
56 #define GE_DMSEG_MAX (GE_RXBUF_NSEGS)
57
58 struct gfe_dmamem {
59  bus_dmamap_t gdm_map; /* dmamem'ed memory */
60 #ifdef __rtems__
61  void *gdm_unaligned_buf;
62 #endif
63  caddr_t gdm_kva; /* kva of tx memory */
64  int gdm_nsegs; /* # of segment in gdm_segs */
65  int gdm_maxsegs; /* maximum # of segments allowed */
66  size_t gdm_size; /* size of memory region */
67  bus_dma_segment_t gdm_segs[GE_DMSEG_MAX]; /* dma segment of tx memory */
68 };
69
70 /* With a 4096 page size, we get 256 descriptors per page.
71  */
72 #ifndef __rtems__
73 #define GE_TXDESC_MEMSIZE (1 * PAGE_SIZE)
74 #define GE_TXDESC_MAX (GE_TXDESC_MEMSIZE / 16)
75 #define GE_TXBUF_SIZE (4 * PAGE_SIZE)
76 #else
77 #define GE_TXDESC_MEMSIZE (sc->num_txdesc * sizeof(struct gt_eth_desc))
78 #define GE_TXDESC_MAX (sc->num_txdesc)
79 #endif
80
81 struct gfe_txqueue {
82  struct ifqueue txq_pendq; /* these are ready to go to the GT */
83  struct ifqueue txq_sentq;
84  struct gfe_dmamem txq_desc_mem; /* transmit descriptor memory */
85 #ifndef __rtems__
86  struct gfe_dmamem txq_buf_mem; /* transmit buffer memory */
87 #endif
88  unsigned int txq_lo; /* next to be given to GT */
89  unsigned int txq_fi; /* next to be returned to CPU */
90 #ifndef __rtems__
91  unsigned int txq_ei_gapcount; /* counter until next EI */
92 #endif
93  unsigned int txq_nactive; /* number of active descriptors */
94 #ifndef __rtems__
95  unsigned int txq_outptr; /* where to put next transmit packet */
96  unsigned int txq_inptr; /* start of 1st queued tx packet */
97 #endif
98  uint32_t txq_intrbits; /* bits to write to EIMR */
99  uint32_t txq_esdcmrbits; /* bits to write to ESDCMR */
100  uint32_t txq_epsrbits; /* bits to test with EPSR */
101  volatile struct gt_eth_desc *txq_descs; /* ptr to tx descriptors */
102  bus_addr_t txq_ectdp; /* offset to cur. tx desc ptr reg */
103  bus_addr_t txq_desc_busaddr; /* bus addr of tx descriptors */
104 #ifndef __rtems__
105  bus_addr_t txq_buf_busaddr; /* bus addr of tx buffers */
106 #endif
107 };
108
109 /* With a 4096 page size, we get 256 descriptors per page. We want 1024
110  * which will give us about 8ms of 64 byte packets (2ms for each priority
111  * queue).
112  */
113
114 #ifndef __rtems__
115 struct gfe_rxbuf {
116  uint8_t rb_data[GE_RXBUF_SIZE];
117 };
118 #endif
119
120 struct gfe_rxqueue {
121  struct gfe_dmamem rxq_desc_mem; /* receive descriptor memory */
122 #ifndef __rtems__
123  struct gfe_dmamem rxq_buf_mem; /* receive buffer memory */
124  struct mbuf *rxq_curpkt; /* mbuf for current packet */
125 #endif
126  volatile struct gt_eth_desc *rxq_descs;
127 #ifndef __rtems__
128  struct gfe_rxbuf *rxq_bufs;
129 #else
130  struct mbuf **rxq_bufs;
131 #endif
132  unsigned int rxq_fi; /* next to be returned to CPU */
133  unsigned int rxq_active; /* # of descriptors given to GT */
134  uint32_t rxq_intrbits; /* bits to write to EIMR */
135  bus_addr_t rxq_desc_busaddr; /* bus addr of rx descriptors */
136  uint32_t rxq_cmdsts; /* save cmdsts from first descriptor */
137  bus_size_t rxq_efrdp;
138  bus_size_t rxq_ecrdp;
139 };
140
141 enum gfe_txprio {
142  GE_TXPRIO_HI=1,
143  GE_TXPRIO_LO=0,
144  GE_TXPRIO_NONE=2
145 };
146 enum gfe_rxprio {
147  GE_RXPRIO_HI=3,
148  GE_RXPRIO_MEDHI=2,
149  GE_RXPRIO_MEDLO=1,
150  GE_RXPRIO_LO=0
151 };
152
153 #ifdef __rtems__
154 #define sc_ec arpcom
155 #define ec_if ac_if
156 #define sc_dev arpcom
157 #define dv_xname ac_if.if_name
158 #endif
159
160 struct gfe_softc {
161 #ifndef __rtems__
162  struct device sc_dev; /* must be first */
163  struct ethercom sc_ec; /* common ethernet glue */
164  struct callout sc_co; /* resource recovery */
165  mii_data_t sc_mii; /* mii interface */
166
167  /*
168  *
169  */
170  bus_space_tag_t sc_gt_memt;
171  bus_space_handle_t sc_gt_memh;
172  bus_space_handle_t sc_memh; /* subregion for ethernet */
173  bus_dma_tag_t sc_dmat;
174 #else
175  struct arpcom sc_ec;
176  unsigned sc_gt_memh;
177  unsigned sc_memh;
178  unsigned char irq_no;
179  rtems_id tid;
180  int sc_phyaddr;
181  int num_rxdesc, num_txdesc;
182 #endif
183  int sc_macno; /* which mac? 0, 1, or 2 */
184
185  unsigned int sc_tickflags;
186 #define GE_TICK_TX_IFSTART 0x0001
187 #define GE_TICK_RX_RESTART 0x0002
188  unsigned int sc_flags;
189 #define GE_ALLMULTI 0x0001
190 #define GE_PHYSTSCHG 0x0002
191 #define GE_RXACTIVE 0x0004
192 #define GE_NOFREE 0x0008 /* Don't free on disable */
193  uint32_t sc_pcr; /* current EPCR value */
194  uint32_t sc_pcxr; /* current EPCXR value */
195  uint32_t sc_intrmask; /* current EIMR value */
196  uint32_t sc_idlemask; /* suspended EIMR bits */
197  size_t sc_max_frame_length; /* maximum frame length */
198
199  /*
200  * Hash table related members
201  */
202  struct gfe_dmamem sc_hash_mem; /* dma'ble hash table */
203  uint64_t *sc_hashtable;
204  unsigned int sc_hashmask; /* 0x1ff or 0x1fff */
205
206  /*
207  * Transmit related members
208  */
209  struct gfe_txqueue sc_txq[2]; /* High & Low transmit queues */
210
211  /*
212  * Receive related members
213  */
214  struct gfe_rxqueue sc_rxq[4]; /* Hi/MedHi/MedLo/Lo receive queues */
215 };
216
217 #ifdef __rtems__
218 int
219 gfe_mii_read(int phy, void *arg, unsigned reg, uint32_t *pval);
220
221 int
222 gfe_mii_write(int phy, void *arg, unsigned reg, uint32_t value);
223 #endif
224
225 #endif
Definition: gtethreg.h:61
Definition: if_gfevar.h:81
Definition: rtemscompat1.h:15
Definition: if_gfevar.h:58
Definition: if_gfevar.h:160
Definition: if_gfevar.h:115
Definition: rtemscompat_defs.h:91
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
Definition: rtemsmain.c:734
Definition: if_gfevar.h:120
