RTEMS  5.1
rtemscompat_defs.h
1 #ifndef RTEMS_COMPAT_DEFS_H
2 #define RTEMS_COMPAT_DEFS_H
3
4 #include <stdint.h>
5 #include <stddef.h>
6
7 /* Number of device instances the driver should support
8  * - may be limited to 1 depending on IRQ API
9  * (braindamaged PC586 and powerpc)
10  */
11 #define NETDRIVER_SLOTS 1
12 /* String name to print with error messages */
13 #define NETDRIVER "gfe"
14 /* Name snippet used to make global symbols unique to this driver */
15 #define NETDRIVER_PREFIX gfe
16
17 /* Define according to endianness of the *ethernet*chip*
18  * (not the CPU - most probably are LE)
19  * This must be either NET_CHIP_LE or NET_CHIP_BE
20  */
21
22 #define NET_CHIP_LE
23 #undef NET_CHIP_BE
24
25 /* Define either NET_CHIP_MEM_IO or NET_CHIP_PORT_IO,
26  * depending whether the CPU sees it in memory address space
27  * or (e.g. x86) uses special I/O instructions.
28  */
29 #define NET_CHIP_MEM_IO
30 #undef NET_CHIP_PORT_IO
31
32 /* The name of the hijacked 'bus handle' field in the softc
33  * structure. We use this field to store the chip's base address.
34  */
35 #define NET_SOFTC_BHANDLE_FIELD sc_memh
36
37 /* define the names of the 'if_XXXreg.h' and 'if_XXXvar.h' headers
38  * (only if present, i.e., if the BSDNET driver has no respective
39  * header, leave this undefined).
40  *
41  */
42 #undef IF_REG_HEADER
43 #define IF_VAR_HEADER "../if_gfe/if_gfevar.h"
44
45 /* define if a pci device */
46 /*
47 #define NETDRIVER_PCI <bsp/pci.h>
48 */
49 #undef NETDRIVER_PCI
50
51 /* Macros to disable and enable interrupts, respectively.
52  * The 'disable' macro is expanded in the ISR, the 'enable'
53  * macro is expanded in the driver task.
54  * The global network semaphore usually provides mutex
55  * protection of the device registers.
56  * Special care must be taken when coding the 'disable' macro,
57  * however to MAKE SURE THERE ARE NO OTHER SIDE EFFECTS such
58  * as:
59  * - macro must not clear any status flags
60  * - macro must save/restore any context information
61  * (e.g., a address register pointer or a bank switch register)
62  *
63  * ARGUMENT: the macro arg is a pointer to the driver's 'softc' structure
64  */
65
66 #define NET_DISABLE_IRQS(sc) GE_WRITE(sc, EIMR, 0)
67 #define NET_ENABLE_IRQS(sc) GE_WRITE(sc, EIMR, sc->sc_intrmask)
68
69 /* Driver may provide a macro/function to copy the hardware address
70  * from the device into 'softc.arpcom'.
71  * If this is undefined, the driver must to the copy itself.
72  * Preferrably, it should check soft.arpcom.ac_enaddr for all
73  * zeros and leave it alone if it is nonzero, i.e., write it
74  * to the hardware.
75 #define NET_READ_MAC_ADDR(sc)
76  */
77
78 typedef struct {
79  uint32_t ds_addr;
80  uint32_t ds_len;
82
83 #define dm_segs gdm_segs
84 #define dm_nsegs gdm_nsegs
85 typedef struct gfe_dmamem *bus_dmamap_t;
86
87 typedef uint32_t bus_addr_t;
88 typedef uint32_t bus_size_t;
89
90 typedef struct device blah;
91
92 #define BUS_DMA_NOCACHE 0xdeadbeef
93
94 #ifdef __PPC__
95 #define bus_dmamap_sync(args...) do { __asm__ volatile("sync":::"memory"); } while(0)
96 #else
97 #error "Dont' know how to sync memory on your CPU"
98 #endif
99
100 int ether_sprintf_r(const unsigned char *enaddr, char *buf, int len);
101
102 /* we have it although we're not ansi */
103 int snprintf(char *, size_t, const char *,...);
104
105 #include <string.h>
106
107 /* declare in every routine using ether_sprintf */
108 #define SPRINTFVARDECL char rtems_sprintf_local_buf[3*6] /* ethernet string */
109
110 #define ether_sprintf_macro(a) \
111  (snprintf(rtems_sprintf_local_buf, \
112  sizeof(rtems_sprintf_local_buf), \
113  "%02X:%02X:%02X:%02X:%02X:%02X", \
114  a[0],a[1],a[2],a[3],a[4],a[5]) ? \
115  rtems_sprintf_local_buf : 0 \
116  )
117
118
119 #define aprint_normal(args...) printf(args)
120 #define aprint_error(args...) fprintf(stderr,args)
121
122 #define delay(arg) DELAY(arg)
123
124 #define KASSERT(a...) do {} while (0)
125
126 #define gfe_assign_desc _bsd_gfe_assign_desc
127 #define gfe_attach _bsd_gfe_attach
128 #define gfe_dbg_config _bsd_gfe_dbg_config
129 #define gfe_dmamem_alloc _bsd_gfe_dmamem_alloc
130 #define gfe_dmamem_free _bsd_gfe_dmamem_free
131 #define gfe_hash_alloc _bsd_gfe_hash_alloc
132 #define gfe_hash_compute _bsd_gfe_hash_compute
133 #define gfe_hash_entry_op _bsd_gfe_hash_entry_op
134 #define gfe_hash_fill _bsd_gfe_hash_fill
135 #define gfe_ifioctl _bsd_gfe_ifioctl
136 #define gfe_ifstart _bsd_gfe_ifstart
137 #define gfe_ifwatchdog _bsd_gfe_ifwatchdog
138 #define gfe_init _bsd_gfe_init
139 #define gfe_intr _bsd_gfe_intr
140 #define gfe_mdio_access _bsd_gfe_mdio_access
141 #define gfe_mii_read _bsd_gfe_mii_read
142 #define gfe_mii_write _bsd_gfe_mii_write
143 #define gfe_probe _bsd_gfe_probe
144 #define gfe_rx_cleanup _bsd_gfe_rx_cleanup
145 #define gfe_rx_get _bsd_gfe_rx_get
146 #define gfe_rx_prime _bsd_gfe_rx_prime
147 #define gfe_rx_process _bsd_gfe_rx_process
148 #define gfe_rx_rxqalloc _bsd_gfe_rx_rxqalloc
149 #define gfe_rx_rxqinit _bsd_gfe_rx_rxqinit
150 #define gfe_rx_stop _bsd_gfe_rx_stop
151 #define gfe_tick _bsd_gfe_tick
152 #define gfe_tx_cleanup _bsd_gfe_tx_cleanup
153 #define gfe_tx_done _bsd_gfe_tx_done
154 #define gfe_tx_enqueue _bsd_gfe_tx_enqueue
155 #define gfe_tx_start _bsd_gfe_tx_start
156 #define gfe_tx_stop _bsd_gfe_tx_stop
157 #define gfe_tx_txqalloc _bsd_gfe_tx_txqalloc
158 #define gfe_whack _bsd_gfe_whack
159 #define the_gfe_devs _bsd_the_gfe_devs
160
161 #endif
Definition: rtemscompat1.h:15
Definition: if_gfevar.h:58
Definition: rtemscompat_defs.h:91
