RTEMS  5.1
if_fxpvar.h
1 /*
2  * Copyright (c) 1995, David Greenman
3  * All rights reserved.
4  *
5  * Redistribution and use in source and binary forms, with or without
6  * modification, are permitted provided that the following conditions
7  * are met:
8  * 1. Redistributions of source code must retain the above copyright
9  * notice unmodified, this list of conditions, and the following
10  * disclaimer.
11  * 2. Redistributions in binary form must reproduce the above copyright
12  * notice, this list of conditions and the following disclaimer in the
13  * documentation and/or other materials provided with the distribution.
14  *
15  * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
16  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18  * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
19  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
20  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
21  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
22  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
23  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
24  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
25  * SUCH DAMAGE.
26  *
27  * $FreeBSD: src/sys/dev/fxp/if_fxpvar.h,v 1.17.2.3 2001/06/08 20:36:58 jlemon Exp $
28  */
29
30 /*
31  * Misc. defintions for the Intel EtherExpress Pro/100B PCI Fast
32  * Ethernet driver
33  */
34
35 /*
36  * Number of transmit control blocks. This determines the number
37  * of transmit buffers that can be chained in the CB list.
38  * This must be a power of two.
39  */
40 #define FXP_NTXCB 128
41
42 /*
43  * Number of completed TX commands at which point an interrupt
44  * will be generated to garbage collect the attached buffers.
45  * Must be at least one less than FXP_NTXCB, and should be
46  * enough less so that the transmitter doesn't becomes idle
47  * during the buffer rundown (which would reduce performance).
48  */
49 #define FXP_CXINT_THRESH 120
50
51 /*
52  * TxCB list index mask. This is used to do list wrap-around.
53  */
54 #define FXP_TXCB_MASK (FXP_NTXCB - 1)
55
56 /*
57  * Number of receive frame area buffers. These are large so chose
58  * wisely.
59  */
60 #if 0
61 #define FXP_NRFABUFS 64
62 #else
63 #define FXP_NRFABUFS 16
64 #endif
65 /*
66  * Maximum number of seconds that the receiver can be idle before we
67  * assume it's dead and attempt to reset it by reprogramming the
68  * multicast filter. This is part of a work-around for a bug in the
69  * NIC. See fxp_stats_update().
70  */
71 #define FXP_MAX_RX_IDLE 15
72
73 #if __FreeBSD_version < 500000
74 #define FXP_LOCK(_sc)
75 #define FXP_UNLOCK(_sc)
76 #define mtx_init(a, b, c)
77 #define mtx_destroy(a)
78 struct mtx { int dummy; };
79 #else
80 #define FXP_LOCK(_sc) mtx_lock(&(_sc)->sc_mtx)
81 #define FXP_UNLOCK(_sc) mtx_unlock(&(_sc)->sc_mtx)
82 #endif
83
84 #ifdef __alpha__
85 #undef vtophys
86 #define vtophys(va) alpha_XXX_dmamap((vm_offset_t)(va))
87 #endif /* __alpha__ */
88
89 /*
90  * NOTE: Elements are ordered for optimal cacheline behavior, and NOT
91  * for functional grouping.
92  */
93 struct fxp_softc {
94  struct arpcom arpcom; /* per-interface network data */
95 #ifdef NOTUSED
96  struct resource *mem; /* resource descriptor for registers */
97  int rtp; /* register resource type */
98  int rgd; /* register descriptor in use */
99  struct resource *irq; /* resource descriptor for interrupt */
100 #endif
101  void *ih; /* interrupt handler cookie */
102  struct mtx sc_mtx;
103 #ifdef NOTUSED /* change for RTEMS */
104  bus_space_tag_t sc_st; /* bus space tag */
105  bus_space_handle_t sc_sh; /* bus space handle */
106 #else
107  unsigned char pci_bus; /* RTEMS PCI bus number */
108  unsigned char pci_dev; /* RTEMS PCI slot/device number */
109  unsigned char pci_fun; /* RTEMS PCI function number */
110  bool pci_regs_are_io; /* RTEMS dev regs are I/O mapped */
111  u_int32_t pci_regs_base; /* RTEMS i386 register base */
112  rtems_id daemonTid; /* Task ID of deamon */
113  rtems_vector_number irq_num;
114
115 #endif
116  struct mbuf *rfa_headm; /* first mbuf in receive frame area */
117  struct mbuf *rfa_tailm; /* last mbuf in receive frame area */
118  struct fxp_cb_tx *cbl_first; /* first active TxCB in list */
119  int tx_queued; /* # of active TxCB's */
120  int need_mcsetup; /* multicast filter needs programming */
121  struct fxp_cb_tx *cbl_last; /* last active TxCB in list */
122  struct fxp_stats *fxp_stats; /* Pointer to interface stats */
123  int rx_idle_secs; /* # of seconds RX has been idle */
124  enum {fxp_timeout_stopped,fxp_timeout_running,fxp_timeout_stop_rq}
125  stat_ch; /* status of status updater */
126  struct fxp_cb_tx *cbl_base; /* base of TxCB list */
127  struct fxp_cb_mcs *mcsp; /* Pointer to mcast setup descriptor */
128 #ifdef NOTUSED
129  struct ifmedia sc_media; /* media information */
130  device_t miibus;
131  device_t dev;
132 #endif
133  int eeprom_size; /* size of serial EEPROM */
134  int suspended; /* 0 = normal 1 = suspended (APM) */
135  int cu_resume_bug;
136  int chip;
137  int flags;
138  u_int32_t saved_maps[5]; /* pci data */
139  u_int32_t saved_biosaddr;
140  u_int8_t saved_intline;
141  u_int8_t saved_cachelnsz;
142  u_int8_t saved_lattimer;
143 };
144
145 #define FXP_CHIP_82557 1 /* 82557 chip type */
146
147 #define FXP_FLAG_MWI_ENABLE 0x0001 /* MWI enable */
148 #define FXP_FLAG_READ_ALIGN 0x0002 /* align read access with cacheline */
149 #define FXP_FLAG_WRITE_ALIGN 0x0004 /* end write on cacheline */
150 #define FXP_FLAG_EXT_TXCB 0x0008 /* enable use of extended TXCB */
151 #define FXP_FLAG_SERIAL_MEDIA 0x0010 /* 10Mbps serial interface */
152 #define FXP_FLAG_LONG_PKT_EN 0x0020 /* enable long packet reception */
153 #define FXP_FLAG_ALL_MCAST 0x0040 /* accept all multicast frames */
154 #define FXP_FLAG_CU_RESUME_BUG 0x0080 /* requires workaround for CU_RESUME */
155
156 /* Macros to ease CSR access. */
157 #if 0
158 #define CSR_READ_1(sc, reg) \
159  bus_space_read_1((sc)->sc_st, (sc)->sc_sh, (reg))
160 #define CSR_READ_2(sc, reg) \
161  bus_space_read_2((sc)->sc_st, (sc)->sc_sh, (reg))
162 #define CSR_READ_4(sc, reg) \
163  bus_space_read_4((sc)->sc_st, (sc)->sc_sh, (reg))
164 #define CSR_WRITE_1(sc, reg, val) \
165  bus_space_write_1((sc)->sc_st, (sc)->sc_sh, (reg), (val))
166 #define CSR_WRITE_2(sc, reg, val) \
167  bus_space_write_2((sc)->sc_st, (sc)->sc_sh, (reg), (val))
168 #define CSR_WRITE_4(sc, reg, val) \
169  bus_space_write_4((sc)->sc_st, (sc)->sc_sh, (reg), (val))
170 #else
171 #define CSR_READ_1(sc, reg) fxp_csr_read_1(sc,reg)
172 #define CSR_READ_2(sc, reg) fxp_csr_read_2(sc,reg)
173 #define CSR_READ_4(sc, reg) fxp_csr_read_4(sc,reg)
174
175 #define CSR_WRITE_1(sc, reg, val) \
176  do { \
177  if ((sc)->pci_regs_are_io) \
178  outport_byte((sc)->pci_regs_base+(reg),val); \
179  else \
180  *((volatile u_int8_t*)((sc)->pci_regs_base)+(reg)) = val; \
181  }while (0)
182
183 #define CSR_WRITE_2(sc, reg, val) \
184  do { \
185  if ((sc)->pci_regs_are_io) \
186  outport_word((sc)->pci_regs_base+(reg),val); \
187  else \
188  *((volatile u_int16_t*)((u_int8_t*)((sc)->pci_regs_base)+(reg))) = val; \
189  }while (0)
190
191 #define CSR_WRITE_4(sc, reg, val) \
192  do { \
193  if ((sc)->pci_regs_are_io) \
194  outport_long((sc)->pci_regs_base+(reg),val); \
195  else \
196  *((volatile u_int32_t*)((u_int8_t*)((sc)->pci_regs_base)+(reg))) = val; \
197  }while (0)
198
199 #endif
200
201 #define sc_if arpcom.ac_if
202
203 #define FXP_UNIT(_sc) (_sc)->arpcom.ac_if.if_unit
Definition: if_fxpreg.h:214
Definition: if_fxpreg.h:313
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
Definition: rtemscompat1.h:15
Definition: pci.h:75
Definition: if_fxpvar.h:93
Definition: pci.h:41
Definition: if_fxpvar.h:78
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
Definition: if_fxpreg.h:241
