RTEMS  5.1
if_fxpreg.h
1 /*
2  * Copyright (c) 1995, David Greenman
3  * Copyright (c) 2001 Jonathan Lemon <jlemon@freebsd.org>
4  * All rights reserved.
5  *
6  * Redistribution and use in source and binary forms, with or without
7  * modification, are permitted provided that the following conditions
8  * are met:
9  * 1. Redistributions of source code must retain the above copyright
10  * notice unmodified, this list of conditions, and the following
11  * disclaimer.
12  * 2. Redistributions in binary form must reproduce the above copyright
13  * notice, this list of conditions and the following disclaimer in the
14  * documentation and/or other materials provided with the distribution.
15  *
16  * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
17  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
18  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
19  * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
20  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
21  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
22  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
23  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
24  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
25  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
26  * SUCH DAMAGE.
27  *
28  * $FreeBSD: src/sys/dev/fxp/if_fxpreg.h,v 1.23.2.4 2001/08/31 02:17:02 jlemon Exp $
29  */
30
31 #define FXP_VENDORID_INTEL 0x8086
32
33 #define FXP_PCI_MMBA 0x10
34 #define FXP_PCI_IOBA 0x14
35
36 /*
37  * Control/status registers.
38  */
39 #define FXP_CSR_SCB_RUSCUS 0 /* scb_rus/scb_cus (1 byte) */
40 #define FXP_CSR_SCB_STATACK 1 /* scb_statack (1 byte) */
41 #define FXP_CSR_SCB_COMMAND 2 /* scb_command (1 byte) */
42 #define FXP_CSR_SCB_INTRCNTL 3 /* scb_intrcntl (1 byte) */
43 #define FXP_CSR_SCB_GENERAL 4 /* scb_general (4 bytes) */
44 #define FXP_CSR_PORT 8 /* port (4 bytes) */
45 #define FXP_CSR_FLASHCONTROL 12 /* flash control (2 bytes) */
46 #define FXP_CSR_EEPROMCONTROL 14 /* eeprom control (2 bytes) */
47 #define FXP_CSR_MDICONTROL 16 /* mdi control (4 bytes) */
48 #define FXP_CSR_FLOWCONTROL 0x19 /* flow control (2 bytes) */
49 #define FXP_CSR_GENCONTROL 0x1C /* general control (1 byte) */
50
51 /*
52  * FOR REFERENCE ONLY, the old definition of FXP_CSR_SCB_RUSCUS:
53  *
54  * volatile u_int8_t :2,
55  * scb_rus:4,
56  * scb_cus:2;
57  */
58
59 #define FXP_PORT_SOFTWARE_RESET 0
60 #define FXP_PORT_SELFTEST 1
61 #define FXP_PORT_SELECTIVE_RESET 2
62 #define FXP_PORT_DUMP 3
63
64 #define FXP_SCB_RUS_IDLE 0
65 #define FXP_SCB_RUS_SUSPENDED 1
66 #define FXP_SCB_RUS_NORESOURCES 2
67 #define FXP_SCB_RUS_READY 4
68 #define FXP_SCB_RUS_SUSP_NORBDS 9
69 #define FXP_SCB_RUS_NORES_NORBDS 10
70 #define FXP_SCB_RUS_READY_NORBDS 12
71
72 #define FXP_SCB_CUS_IDLE 0
73 #define FXP_SCB_CUS_SUSPENDED 1
74 #define FXP_SCB_CUS_ACTIVE 2
75
76 #define FXP_SCB_INTR_DISABLE 0x01 /* Disable all interrupts */
77 #define FXP_SCB_INTR_SWI 0x02 /* Generate SWI */
78 #define FXP_SCB_INTMASK_FCP 0x04
79 #define FXP_SCB_INTMASK_ER 0x08
80 #define FXP_SCB_INTMASK_RNR 0x10
81 #define FXP_SCB_INTMASK_CNA 0x20
82 #define FXP_SCB_INTMASK_FR 0x40
83 #define FXP_SCB_INTMASK_CXTNO 0x80
84
85 #define FXP_SCB_STATACK_FCP 0x01 /* Flow Control Pause */
86 #define FXP_SCB_STATACK_ER 0x02 /* Early Receive */
87 #define FXP_SCB_STATACK_SWI 0x04
88 #define FXP_SCB_STATACK_MDI 0x08
89 #define FXP_SCB_STATACK_RNR 0x10
90 #define FXP_SCB_STATACK_CNA 0x20
91 #define FXP_SCB_STATACK_FR 0x40
92 #define FXP_SCB_STATACK_CXTNO 0x80
93
94 #define FXP_SCB_COMMAND_CU_NOP 0x00
95 #define FXP_SCB_COMMAND_CU_START 0x10
96 #define FXP_SCB_COMMAND_CU_RESUME 0x20
97 #define FXP_SCB_COMMAND_CU_DUMP_ADR 0x40
98 #define FXP_SCB_COMMAND_CU_DUMP 0x50
99 #define FXP_SCB_COMMAND_CU_BASE 0x60
100 #define FXP_SCB_COMMAND_CU_DUMPRESET 0x70
101
102 #define FXP_SCB_COMMAND_RU_NOP 0
103 #define FXP_SCB_COMMAND_RU_START 1
104 #define FXP_SCB_COMMAND_RU_RESUME 2
105 #define FXP_SCB_COMMAND_RU_ABORT 4
106 #define FXP_SCB_COMMAND_RU_LOADHDS 5
107 #define FXP_SCB_COMMAND_RU_BASE 6
108 #define FXP_SCB_COMMAND_RU_RBDRESUME 7
109
110 /*
111  * Command block definitions
112  */
113 struct fxp_cb_nop {
114  void *fill[2];
115  volatile u_int16_t cb_status;
116  volatile u_int16_t cb_command;
117  volatile u_int32_t link_addr;
118 };
119 struct fxp_cb_ias {
120  void *fill[2];
121  volatile u_int16_t cb_status;
122  volatile u_int16_t cb_command;
123  volatile u_int32_t link_addr;
124  volatile u_int8_t macaddr[6];
125 };
126 /* I hate bit-fields :-( */
128  void *fill[2];
129  volatile u_int16_t cb_status;
130  volatile u_int16_t cb_command;
131  volatile u_int32_t link_addr;
132  volatile u_int byte_count:6,
133  :2;
134  volatile u_int rx_fifo_limit:4,
135  tx_fifo_limit:3,
136  :1;
137  volatile u_int8_t adaptive_ifs;
138  volatile u_int mwi_enable:1, /* 8,9 */
139  type_enable:1, /* 8,9 */
140  read_align_en:1, /* 8,9 */
141  end_wr_on_cl:1, /* 8,9 */
142  :4;
143  volatile u_int rx_dma_bytecount:7,
144  :1;
145  volatile u_int tx_dma_bytecount:7,
146  dma_mbce:1;
147  volatile u_int late_scb:1, /* 7 */
148  direct_dma_dis:1, /* 8,9 */
149  tno_int_or_tco_en:1, /* 7,9 */
150  ci_int:1,
151  ext_txcb_dis:1, /* 8,9 */
152  ext_stats_dis:1, /* 8,9 */
153  keep_overrun_rx:1,
154  save_bf:1;
155  volatile u_int disc_short_rx:1,
156  underrun_retry:2,
157  :3,
158  two_frames:1, /* 8,9 */
159  dyn_tbd:1; /* 8,9 */
160  volatile u_int mediatype:1, /* 7 */
161  :6,
162  csma_dis:1; /* 8,9 */
163  volatile u_int tcp_udp_cksum:1, /* 9 */
164  :3,
165  vlan_tco:1, /* 8,9 */
166  link_wake_en:1, /* 8,9 */
167  arp_wake_en:1, /* 8 */
168  mc_wake_en:1; /* 8 */
169  volatile u_int :3,
170  nsai:1,
171  preamble_length:2,
172  loopback:2;
173  volatile u_int linear_priority:3, /* 7 */
174  :5;
175  volatile u_int linear_pri_mode:1, /* 7 */
176  :3,
177  interfrm_spacing:4;
178  volatile u_int :8;
179  volatile u_int :8;
180  volatile u_int promiscuous:1,
181  bcast_disable:1,
182  wait_after_win:1, /* 8,9 */
183  :1,
184  ignore_ul:1, /* 8,9 */
185  crc16_en:1, /* 9 */
186  :1,
187  crscdt:1;
188  volatile u_int fc_delay_lsb:8; /* 8,9 */
189  volatile u_int fc_delay_msb:8; /* 8,9 */
190  volatile u_int stripping:1,
191  padding:1,
192  rcv_crc_xfer:1,
193  long_rx_en:1, /* 8,9 */
194  pri_fc_thresh:3, /* 8,9 */
195  :1;
196  volatile u_int ia_wake_en:1, /* 8 */
197  magic_pkt_dis:1, /* 8,9,!9ER */
198  tx_fc_dis:1, /* 8,9 */
199  rx_fc_restop:1, /* 8,9 */
200  rx_fc_restart:1, /* 8,9 */
201  fc_filter:1, /* 8,9 */
202  force_fdx:1,
203  fdx_pin_en:1;
204  volatile u_int :5,
205  pri_fc_loc:1, /* 8,9 */
206  multi_ia:1,
207  :1;
208  volatile u_int :3,
209  mc_all:1,
210  :4;
211 };
212
213 #define MAXMCADDR 80
214 struct fxp_cb_mcs {
215  struct fxp_cb_tx *next;
216  struct mbuf *mb_head;
217  volatile u_int16_t cb_status;
218  volatile u_int16_t cb_command;
219  volatile u_int32_t link_addr;
220  volatile u_int16_t mc_cnt;
221  volatile u_int8_t mc_addr[MAXMCADDR][6];
222 };
223
224 /*
225  * Number of DMA segments in a TxCB. Note that this is carefully
226  * chosen to make the total struct size an even power of two. It's
227  * critical that no TxCB be split across a page boundry since
228  * no attempt is made to allocate physically contiguous memory.
229  *
230  */
231 #ifdef __alpha__ /* XXX - should be conditional on pointer size */
232 #define FXP_NTXSEG 28
233 #else
234 #define FXP_NTXSEG 29
235 #endif
236
237 struct fxp_tbd {
238  volatile u_int32_t tb_addr;
239  volatile u_int32_t tb_size;
240 };
241 struct fxp_cb_tx {
242  struct fxp_cb_tx *next;
243  struct mbuf *mb_head;
244  volatile u_int16_t cb_status;
245  volatile u_int16_t cb_command;
246  volatile u_int32_t link_addr;
247  volatile u_int32_t tbd_array_addr;
248  volatile u_int16_t byte_count;
249  volatile u_int8_t tx_threshold;
250  volatile u_int8_t tbd_number;
251  /*
252  * The following structure isn't actually part of the TxCB,
253  * unless the extended TxCB feature is being used. In this
254  * case, the first two elements of the structure below are
255  * fetched along with the TxCB.
256  */
257  volatile struct fxp_tbd tbd[FXP_NTXSEG];
258 };
259
260 /*
261  * Control Block (CB) definitions
262  */
263
264 /* status */
265 #define FXP_CB_STATUS_OK 0x2000
266 #define FXP_CB_STATUS_C 0x8000
267 /* commands */
268 #define FXP_CB_COMMAND_NOP 0x0
269 #define FXP_CB_COMMAND_IAS 0x1
270 #define FXP_CB_COMMAND_CONFIG 0x2
271 #define FXP_CB_COMMAND_MCAS 0x3
272 #define FXP_CB_COMMAND_XMIT 0x4
273 #define FXP_CB_COMMAND_RESRV 0x5
274 #define FXP_CB_COMMAND_DUMP 0x6
275 #define FXP_CB_COMMAND_DIAG 0x7
276 /* command flags */
277 #define FXP_CB_COMMAND_SF 0x0008 /* simple/flexible mode */
278 #define FXP_CB_COMMAND_I 0x2000 /* generate interrupt on completion */
279 #define FXP_CB_COMMAND_S 0x4000 /* suspend on completion */
280 #define FXP_CB_COMMAND_EL 0x8000 /* end of list */
281
282 /*
283  * RFA definitions
284  */
285
286 struct fxp_rfa {
287  volatile u_int16_t rfa_status;
288  volatile u_int16_t rfa_control;
289  volatile u_int8_t link_addr[4];
290  volatile u_int8_t rbd_addr[4];
291  volatile u_int16_t actual_size;
292  volatile u_int16_t size;
293 };
294 #define FXP_RFA_STATUS_RCOL 0x0001 /* receive collision */
295 #define FXP_RFA_STATUS_IAMATCH 0x0002 /* 0 = matches station address */
296 #define FXP_RFA_STATUS_S4 0x0010 /* receive error from PHY */
297 #define FXP_RFA_STATUS_TL 0x0020 /* type/length */
298 #define FXP_RFA_STATUS_FTS 0x0080 /* frame too short */
299 #define FXP_RFA_STATUS_OVERRUN 0x0100 /* DMA overrun */
300 #define FXP_RFA_STATUS_RNR 0x0200 /* no resources */
301 #define FXP_RFA_STATUS_ALIGN 0x0400 /* alignment error */
302 #define FXP_RFA_STATUS_CRC 0x0800 /* CRC error */
303 #define FXP_RFA_STATUS_OK 0x2000 /* packet received okay */
304 #define FXP_RFA_STATUS_C 0x8000 /* packet reception complete */
305 #define FXP_RFA_CONTROL_SF 0x08 /* simple/flexible memory mode */
306 #define FXP_RFA_CONTROL_H 0x10 /* header RFD */
307 #define FXP_RFA_CONTROL_S 0x4000 /* suspend after reception */
308 #define FXP_RFA_CONTROL_EL 0x8000 /* end of list */
309
310 /*
311  * Statistics dump area definitions
312  */
313 struct fxp_stats {
314  volatile u_int32_t tx_good;
315  volatile u_int32_t tx_maxcols;
316  volatile u_int32_t tx_latecols;
317  volatile u_int32_t tx_underruns;
318  volatile u_int32_t tx_lostcrs;
319  volatile u_int32_t tx_deffered;
320  volatile u_int32_t tx_single_collisions;
321  volatile u_int32_t tx_multiple_collisions;
322  volatile u_int32_t tx_total_collisions;
323  volatile u_int32_t rx_good;
324  volatile u_int32_t rx_crc_errors;
325  volatile u_int32_t rx_alignment_errors;
326  volatile u_int32_t rx_rnr_errors;
327  volatile u_int32_t rx_overrun_errors;
328  volatile u_int32_t rx_cdt_errors;
329  volatile u_int32_t rx_shortframes;
330  volatile u_int32_t completion_status;
331 };
332 #define FXP_STATS_DUMP_COMPLETE 0xa005
333 #define FXP_STATS_DR_COMPLETE 0xa007
334
335 /*
336  * Serial EEPROM control register bits
337  */
338 #define FXP_EEPROM_EESK 0x01 /* shift clock */
339 #define FXP_EEPROM_EECS 0x02 /* chip select */
340 #define FXP_EEPROM_EEDI 0x04 /* data in */
341 #define FXP_EEPROM_EEDO 0x08 /* data out */
342
343 /*
344  * Serial EEPROM opcodes, including start bit
345  */
346 #define FXP_EEPROM_OPC_ERASE 0x4
347 #define FXP_EEPROM_OPC_WRITE 0x5
348 #define FXP_EEPROM_OPC_READ 0x6
349
350 /*
351  * Management Data Interface opcodes
352  */
353 #define FXP_MDI_WRITE 0x1
354 #define FXP_MDI_READ 0x2
355
356 /*
357  * PHY device types
358  */
359 #define FXP_PHY_DEVICE_MASK 0x3f00
360 #define FXP_PHY_SERIAL_ONLY 0x8000
361 #define FXP_PHY_NONE 0
362 #define FXP_PHY_82553A 1
363 #define FXP_PHY_82553C 2
364 #define FXP_PHY_82503 3
365 #define FXP_PHY_DP83840 4
366 #define FXP_PHY_80C240 5
367 #define FXP_PHY_80C24 6
368 #define FXP_PHY_82555 7
369 #define FXP_PHY_DP83840A 10
370 #define FXP_PHY_82555B 11
Definition: if_fxpreg.h:119
Definition: if_fxpreg.h:214
Definition: if_fxpreg.h:127
Definition: if_fxpreg.h:313
Definition: if_fxpreg.h:237
Definition: if_fxpreg.h:113
Definition: if_fxpreg.h:286
Definition: if_fxpreg.h:241
