RTEMS  5.1
if_em_osdep.h
1 /**************************************************************************
2
3 Copyright (c) 2001-2005, Intel Corporation
4 All rights reserved.
5
6 Redistribution and use in source and binary forms, with or without
7 modification, are permitted provided that the following conditions are met:
8
9  1. Redistributions of source code must retain the above copyright notice,
10  this list of conditions and the following disclaimer.
11
12  2. Redistributions in binary form must reproduce the above copyright
13  notice, this list of conditions and the following disclaimer in the
14  documentation and/or other materials provided with the distribution.
15
16  3. Neither the name of the Intel Corporation nor the names of its
17  contributors may be used to endorse or promote products derived from
18  this software without specific prior written permission.
19
20 THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
21 AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
22 IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
23 ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
24 LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
25 CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
26 SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
27 INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
28 CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
29 ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
30 POSSIBILITY OF SUCH DAMAGE.
31
32 ***************************************************************************/
33
34 /*$FreeBSD: /repoman/r/ncvs/src/sys/dev/em/if_em_osdep.h,v 1.14 2005/05/26 23:32:02 tackerman Exp $*/
35
36 #ifndef _RTEMS_OS_H_
37 #define _RTEMS_OS_H_
38
39 #include <rtems.h>
40 #include "../porting/rtemscompat.h"
41
42 #include <sys/types.h>
43 #include <sys/param.h>
44 #include <sys/systm.h>
45 #include <sys/mbuf.h>
46 #include <sys/protosw.h>
47 #include <sys/socket.h>
48 #include <sys/malloc.h>
49 #include <sys/kernel.h>
50 #include <bsp/pci.h>
51
52 /* Eventually, we should include this
53 #include <rtems/rtems-mii-ioctl.h>
54 */
55 #define IFM_LINK_OK IFM_FLAG0
56 #define IFM_ANEG_DIS IFM_FLAG1
57
58 #define ASSERT(x) if(!(x)) panic("EM: x")
59
60 /* The happy-fun DELAY macro is defined in /usr/src/sys/i386/include/clock.h */
61 #define usec_delay(x) DELAY(x)
62 #define msec_delay(x) DELAY(1000*(x))
63 /* TODO: Should we be paranoid about delaying in interrupt context? */
64 #define msec_delay_irq(x) DELAY(1000*(x))
65
66 #define MSGOUT(S, A, B) printf(S "\n", A, B)
67 #define DEBUGFUNC(F) DEBUGOUT(F);
68 #if DBG
69  #define DEBUGOUT(S) printf(S "\n")
70  #define DEBUGOUT1(S,A) printf(S "\n",A)
71  #define DEBUGOUT2(S,A,B) printf(S "\n",A,B)
72  #define DEBUGOUT3(S,A,B,C) printf(S "\n",A,B,C)
73  #define bootverbose (1)
74  #define DEBUGOUT7(S,A,B,C,D,E,F,G) printf(S "\n",A,B,C,D,E,F,G)
75 #else
76  #define DEBUGOUT(S)
77  #define DEBUGOUT1(S,A)
78  #define DEBUGOUT2(S,A,B)
79  #define DEBUGOUT3(S,A,B,C)
80  #define bootverbose (0)
81  #define DEBUGOUT7(S,A,B,C,D,E,F,G)
82 #endif
83
84 #define CMD_MEM_WRT_INVALIDATE 0x0010 /* BIT_4 */
85 #define PCI_COMMAND_REGISTER PCIR_COMMAND
86
87 struct em_osdep
88 {
89  unsigned mem_bus_space_handle;
90  device_t dev;
91 };
92
93 struct rtems_ifmedia {
94  int ifm_media;
95 };
96
97 #define E1000_WRITE_FLUSH(hw) E1000_READ_REG(hw, STATUS)
98
99 /* Read from an absolute offset in the adapter's memory space */
100 #define E1000_READ_OFFSET(hw, offset) \
101  bus_space_read_4( ((struct em_osdep *)(hw)->back)->mem_bus_space_tag, \
102  ((struct em_osdep *)(hw)->back)->mem_bus_space_handle, \
103  offset)
104
105 /* Write to an absolute offset in the adapter's memory space */
106 #define E1000_WRITE_OFFSET(hw, offset, value) \
107  bus_space_write_4( ((struct em_osdep *)(hw)->back)->mem_bus_space_tag, \
108  ((struct em_osdep *)(hw)->back)->mem_bus_space_handle, \
109  offset, \
110  value)
111
112 /* Convert a register name to its offset in the adapter's memory space */
113 #define E1000_REG_OFFSET(hw, reg) \
114  ((hw)->mac_type >= em_82543 ? E1000_##reg : E1000_82542_##reg)
115
116 #define E1000_READ_REG(hw, reg) \
117  E1000_READ_OFFSET(hw, E1000_REG_OFFSET(hw, reg))
118
119 #define E1000_WRITE_REG(hw, reg, value) \
120  E1000_WRITE_OFFSET(hw, E1000_REG_OFFSET(hw, reg), value)
121
122 #define E1000_READ_REG_ARRAY(hw, reg, index) \
123  E1000_READ_OFFSET(hw, E1000_REG_OFFSET(hw, reg) + ((index) << 2))
124
125 #define E1000_READ_REG_ARRAY_DWORD E1000_READ_REG_ARRAY
126
127 #define E1000_WRITE_REG_ARRAY(hw, reg, index, value) \
128  E1000_WRITE_OFFSET(hw, E1000_REG_OFFSET(hw, reg) + ((index) << 2), value)
129
130 #define E1000_WRITE_REG_ARRAY_BYTE(hw, reg, index, value) \
131  bus_space_write_1( ((struct em_osdep *)(hw)->back)->mem_bus_space_tag, \
132  ((struct em_osdep *)(hw)->back)->mem_bus_space_handle, \
133  E1000_REG_OFFSET(hw, reg) + (index), \
134  value)
135
136 #define E1000_WRITE_REG_ARRAY_WORD(hw, reg, index, value) \
137  bus_space_write_2( ((struct em_osdep *)(hw)->back)->mem_bus_space_tag, \
138  ((struct em_osdep *)(hw)->back)->mem_bus_space_handle, \
139  E1000_REG_OFFSET(hw, reg) + (index), \
140  value)
141
142 #define E1000_WRITE_REG_ARRAY_DWORD(hw, reg, index, value) \
143  E1000_WRITE_OFFSET(hw, E1000_REG_OFFSET(hw, reg) + ((index) << 2), value)
144
145 #endif /* _FREEBSD_OS_H_ */
146
Definition: rtemscompat1.h:15
Definition: if_em_osdep.h:87
Definition: if_em_osdep.h:93
