RTEMS  5.1
rtemscompat_defs.h
1 #ifndef RTEMS_COMPAT_DEFS_H
2 #define RTEMS_COMPAT_DEFS_H
3
4 /* Number of device instances the driver should support
5  * - may be limited to 1 depending on IRQ API
6  * (braindamaged PC586 and powerpc)
7  */
8 #define NETDRIVER_SLOTS 1
9
10 /* String name to print with error messages */
11 #define NETDRIVER "em"
12 /* Name snippet used to make global symbols unique to this driver */
13 #define NETDRIVER_PREFIX em
14
15 #define adapter em_softc
16 #define interface_data arpcom
17
18 /* Define according to endianness of the *ethernet*chip*
19  * (not the CPU - most probably are LE)
20  * This must be either NET_CHIP_LE or NET_CHIP_BE
21  */
22
23 #define NET_CHIP_LE
24 #undef NET_CHIP_BE
25
26 /* Define either NET_CHIP_MEM_IO or NET_CHIP_PORT_IO,
27  * depending whether the CPU sees it in memory address space
28  * or (e.g. x86) uses special I/O instructions.
29  */
30 #define NET_CHIP_MEM_IO
31 #undef NET_CHIP_PORT_IO
32
33 /* The name of the hijacked 'bus handle' field in the softc
34  * structure. We use this field to store the chip's base address.
35  */
36 #define NET_SOFTC_BHANDLE_FIELD osdep.mem_bus_space_handle
37
38 /* define the names of the 'if_XXXreg.h' and 'if_XXXvar.h' headers
39  * (only if present, i.e., if the BSDNET driver has no respective
40  * header, leave this undefined).
41  *
42  */
43 #define IF_REG_HEADER "../if_em/if_em.h"
44 #undef IF_VAR_HEADER
45
46 /* define if a pci device */
47 #define NETDRIVER_PCI <bsp/pci.h>
48
49 /* Macros to disable and enable interrupts, respectively.
50  * The 'disable' macro is expanded in the ISR, the 'enable'
51  * macro is expanded in the driver task.
52  * The global network semaphore usually provides mutex
53  * protection of the device registers.
54  * Special care must be taken when coding the 'disable' macro,
55  * however to MAKE SURE THERE ARE NO OTHER SIDE EFFECTS such
56  * as:
57  * - macro must not clear any status flags
58  * - macro must save/restore any context information
59  * (e.g., a address register pointer or a bank switch register)
60  *
61  * ARGUMENT: the macro arg is a pointer to the driver's 'softc' structure
62  */
63
64 #define NET_ENABLE_IRQS(sc) do { \
65  E1000_WRITE_REG(&sc->hw, IMS, (IMS_ENABLE_MASK)); \
66  } while (0)
67
68 #define NET_DISABLE_IRQS(sc) do { \
69  E1000_WRITE_REG(&sc->hw, IMC, 0xffffffff); \
70  } while (0)
71
72 #define KASSERT(a...) do {} while (0)
73
74 /* dmamap stuff; these are defined just to work with the current version
75  * of this driver and the implementation must be carefully checked if
76  * a newer version is merged.!
77  *
78  * The more cumbersome routines have been commented in the source, the
79  * simpler ones are defined to be NOOPs here so the source gets less
80  * cluttered...
81  *
82  * ASSUMPTIONS:
83  *
84  * -> dmamap_sync cannot sync caches; assume we have HW snooping
85  *
86  */
87
88 typedef unsigned bus_size_t;
89 typedef unsigned bus_addr_t;
90
91 typedef struct {
92  unsigned ds_addr;
93  unsigned ds_len;
95
96 #define bus_dma_tag_destroy(args...) do {} while(0)
97
98 #define bus_dmamap_destroy(args...) do {} while(0)
99
100 #define bus_dmamap_unload(args...) do {} while (0)
101
102 #ifdef __PPC__
103 #define bus_dmamap_sync(args...) do { __asm__ volatile("sync":::"memory"); } while (0)
104 #else
105 #define bus_dmamap_sync(args...) do {} while (0)
106 #endif
107
108 #define BUS_DMA_NOWAIT 0xdeadbeef /* unused */
109
110 #define em_adapter_list _bsd_em_adapter_list
111 #define em_arc_subsystem_valid _bsd_em_arc_subsystem_valid
112 #define em_check_downshift _bsd_em_check_downshift
113 #define em_check_for_link _bsd_em_check_for_link
114 #define em_check_mng_mode _bsd_em_check_mng_mode
115 #define em_check_phy_reset_block _bsd_em_check_phy_reset_block
116 #define em_check_polarity _bsd_em_check_polarity
117 #define em_cleanup_led _bsd_em_cleanup_led
118 #define em_clear_hw_cntrs _bsd_em_clear_hw_cntrs
119 #define em_clear_vfta _bsd_em_clear_vfta
120 #define em_commit_shadow_ram _bsd_em_commit_shadow_ram
121 #define em_config_collision_dist _bsd_em_config_collision_dist
122 #define em_config_dsp_after_link_change _bsd_em_config_dsp_after_link_change
123 #define em_config_fc_after_link_up _bsd_em_config_fc_after_link_up
124 #define em_dbg_config _bsd_em_dbg_config
125 #define em_detect_gig_phy _bsd_em_detect_gig_phy
126 #define em_disable_pciex_master _bsd_em_disable_pciex_master
127 #define em_display_debug_stats _bsd_em_display_debug_stats
128 #define em_driver_version _bsd_em_driver_version
129 #define em_enable_mng_pass_thru _bsd_em_enable_mng_pass_thru
130 #define em_enable_pciex_master _bsd_em_enable_pciex_master
131 #define em_enable_tx_pkt_filtering _bsd_em_enable_tx_pkt_filtering
132 #define em_force_mac_fc _bsd_em_force_mac_fc
133 #define em_get_auto_rd_done _bsd_em_get_auto_rd_done
134 #define em_get_bus_info _bsd_em_get_bus_info
135 #define em_get_cable_length _bsd_em_get_cable_length
136 #define em_get_hw_eeprom_semaphore _bsd_em_get_hw_eeprom_semaphore
137 #define em_get_phy_cfg_done _bsd_em_get_phy_cfg_done
138 #define em_get_speed_and_duplex _bsd_em_get_speed_and_duplex
139 #define em_hash_mc_addr _bsd_em_hash_mc_addr
140 #define em_hw_early_init _bsd_em_hw_early_init
141 #define em_id_led_init _bsd_em_id_led_init
142 #define em_init_eeprom_params _bsd_em_init_eeprom_params
143 #define em_init_hw _bsd_em_init_hw
144 #define em_init_rx_addrs _bsd_em_init_rx_addrs
145 #define em_io_read _bsd_em_io_read
146 #define em_io_write _bsd_em_io_write
147 #define em_is_onboard_nvm_eeprom _bsd_em_is_onboard_nvm_eeprom
148 #define em_led_off _bsd_em_led_off
149 #define em_led_on _bsd_em_led_on
150 #define em_mc_addr_list_update _bsd_em_mc_addr_list_update
151 #define em_mng_enable_host_if _bsd_em_mng_enable_host_if
152 #define em_mng_host_if_write _bsd_em_mng_host_if_write
153 #define em_mng_write_cmd_header _bsd_em_mng_write_cmd_header
154 #define em_mng_write_commit _bsd_em_mng_write_commit
155 #define em_mng_write_dhcp_info _bsd_em_mng_write_dhcp_info
156 #define em_mta_set _bsd_em_mta_set
157 #define em_pci_clear_mwi _bsd_em_pci_clear_mwi
158 #define em_pci_set_mwi _bsd_em_pci_set_mwi
159 #define em_phy_get_info _bsd_em_phy_get_info
160 #define em_phy_hw_reset _bsd_em_phy_hw_reset
161 #define em_phy_igp_get_info _bsd_em_phy_igp_get_info
162 #define em_phy_m88_get_info _bsd_em_phy_m88_get_info
163 #define em_phy_reset _bsd_em_phy_reset
164 #define em_phy_setup_autoneg _bsd_em_phy_setup_autoneg
165 #define em_poll_eerd_eewr_done _bsd_em_poll_eerd_eewr_done
166 #define em_put_hw_eeprom_semaphore _bsd_em_put_hw_eeprom_semaphore
167 #define em_rar_set _bsd_em_rar_set
168 #define em_read_eeprom _bsd_em_read_eeprom
169 #define em_read_eeprom_eerd _bsd_em_read_eeprom_eerd
170 #define em_read_mac_addr _bsd_em_read_mac_addr
171 #define em_read_part_num _bsd_em_read_part_num
172 #define em_read_pci_cfg _bsd_em_read_pci_cfg
173 #define em_read_phy_reg _bsd_em_read_phy_reg
174 #define em_read_reg_io _bsd_em_read_reg_io
175 #define em_reset_adaptive _bsd_em_reset_adaptive
176 #define em_reset_hw _bsd_em_reset_hw
177 #define em_set_d0_lplu_state _bsd_em_set_d0_lplu_state
178 #define em_set_d3_lplu_state _bsd_em_set_d3_lplu_state
179 #define em_set_mac_type _bsd_em_set_mac_type
180 #define em_set_media_type _bsd_em_set_media_type
181 #define em_set_pci_express_master_disable _bsd_em_set_pci_express_master_disable
182 #define em_setup_led _bsd_em_setup_led
183 #define em_setup_link _bsd_em_setup_link
184 #define em_tbi_adjust_stats _bsd_em_tbi_adjust_stats
185 #define em_update_adaptive _bsd_em_update_adaptive
186 #define em_update_eeprom_checksum _bsd_em_update_eeprom_checksum
187 #define em_validate_eeprom_checksum _bsd_em_validate_eeprom_checksum
188 #define em_validate_mdi_setting _bsd_em_validate_mdi_setting
189 #define em_wait_autoneg _bsd_em_wait_autoneg
190 #define em_write_eeprom _bsd_em_write_eeprom
191 #define em_write_eeprom_eewr _bsd_em_write_eeprom_eewr
192 #define em_write_pci_cfg _bsd_em_write_pci_cfg
193 #define em_write_phy_reg _bsd_em_write_phy_reg
194 #define em_write_reg_io _bsd_em_write_reg_io
195 #define em_write_vfta _bsd_em_write_vfta
196 #define the_em_devs _bsd_the_em_devs
197
198 #endif
Definition: rtemscompat_defs.h:91
