RTEMS  5.1
if_dcreg.h
1 /*
2  * Copyright (c) 1997, 1998, 1999
3  * Bill Paul <wpaul@ee.columbia.edu>. All rights reserved.
4  *
5  * Redistribution and use in source and binary forms, with or without
6  * modification, are permitted provided that the following conditions
7  * are met:
8  * 1. Redistributions of source code must retain the above copyright
9  * notice, this list of conditions and the following disclaimer.
10  * 2. Redistributions in binary form must reproduce the above copyright
11  * notice, this list of conditions and the following disclaimer in the
12  * documentation and/or other materials provided with the distribution.
13  * 3. All advertising materials mentioning features or use of this software
14  * must display the following acknowledgement:
15  * This product includes software developed by Bill Paul.
16  * 4. Neither the name of the author nor the names of any co-contributors
17  * may be used to endorse or promote products derived from this software
18  * without specific prior written permission.
19  *
20  * THIS SOFTWARE IS PROVIDED BY Bill Paul AND CONTRIBUTORS ``AS IS'' AND
21  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
22  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
23  * ARE DISCLAIMED. IN NO EVENT SHALL Bill Paul OR THE VOICES IN HIS HEAD
24  * BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
25  * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
26  * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
27  * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
28  * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
29  * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
30  * THE POSSIBILITY OF SUCH DAMAGE.
31  *
32  * $FreeBSD: src/sys/pci/if_dcreg.h,v 1.4.2.21 2003/02/12 22:19:34 mbr Exp $
33  */
34
35 /*
36  * 21143 and clone common register definitions.
37  */
38
39 #define DC_BUSCTL 0x00 /* bus control */
40 #define DC_TXSTART 0x08 /* tx start demand */
41 #define DC_RXSTART 0x10 /* rx start demand */
42 #define DC_RXADDR 0x18 /* rx descriptor list start addr */
43 #define DC_TXADDR 0x20 /* tx descriptor list start addr */
44 #define DC_ISR 0x28 /* interrupt status register */
45 #define DC_NETCFG 0x30 /* network config register */
46 #define DC_IMR 0x38 /* interrupt mask */
47 #define DC_FRAMESDISCARDED 0x40 /* # of discarded frames */
48 #define DC_SIO 0x48 /* MII and ROM/EEPROM access */
49 #define DC_ROM 0x50 /* ROM programming address */
50 #define DC_TIMER 0x58 /* general timer */
51 #define DC_10BTSTAT 0x60 /* SIA status */
52 #define DC_SIARESET 0x68 /* SIA connectivity */
53 #define DC_10BTCTRL 0x70 /* SIA transmit and receive */
54 #define DC_WATCHDOG 0x78 /* SIA and general purpose port */
55
56 /*
57  * There are two general 'types' of MX chips that we need to be
58  * concerned with. One is the original 98713, which has its internal
59  * NWAY support controlled via the MDIO bits in the serial I/O
60  * register. The other is everything else (from the 98713A on up),
61  * which has its internal NWAY controlled via CSR13, CSR14 and CSR15,
62  * just like the 21143. This type setting also governs which of the
63  * 'magic' numbers we write to CSR16. The PNIC II falls into the
64  * 98713A/98715/98715A/98725 category.
65  */
66 #define DC_TYPE_98713 0x1
67 #define DC_TYPE_98713A 0x2
68 #define DC_TYPE_987x5 0x3
69
70 /* Other type of supported chips. */
71 #define DC_TYPE_21143 0x4 /* Intel 21143 */
72 #define DC_TYPE_ASIX 0x5 /* ASIX AX88140A/AX88141 */
73 #define DC_TYPE_AL981 0x6 /* ADMtek AL981 Comet */
74 #define DC_TYPE_AN985 0x7 /* ADMtek AN985 Centaur */
75 #define DC_TYPE_DM9102 0x8 /* Davicom DM9102 */
76 #define DC_TYPE_PNICII 0x9 /* 82c115 PNIC II */
77 #define DC_TYPE_PNIC 0xA /* 82c168/82c169 PNIC I */
78 #define DC_TYPE_CONEXANT 0xC /* Conexant LANfinity RS7112 */
79
80 #define DC_IS_MACRONIX(x) \
81  (x->dc_type == DC_TYPE_98713 || \
82  x->dc_type == DC_TYPE_98713A || \
83  x->dc_type == DC_TYPE_987x5)
84
85 #define DC_IS_ADMTEK(x) \
86  (x->dc_type == DC_TYPE_AL981 || \
87  x->dc_type == DC_TYPE_AN985)
88
89 #define DC_IS_INTEL(x) (x->dc_type == DC_TYPE_21143)
90 #define DC_IS_ASIX(x) (x->dc_type == DC_TYPE_ASIX)
91 #define DC_IS_COMET(x) (x->dc_type == DC_TYPE_AL981)
92 #define DC_IS_CENTAUR(x) (x->dc_type == DC_TYPE_AN985)
93 #define DC_IS_DAVICOM(x) (x->dc_type == DC_TYPE_DM9102)
94 #define DC_IS_PNICII(x) (x->dc_type == DC_TYPE_PNICII)
95 #define DC_IS_PNIC(x) (x->dc_type == DC_TYPE_PNIC)
96 #define DC_IS_CONEXANT(x) (x->dc_type == DC_TYPE_CONEXANT)
97
98 /* MII/symbol mode port types */
99 #define DC_PMODE_MII 0x1
100 #define DC_PMODE_SYM 0x2
101 #define DC_PMODE_SIA 0x3
102
103 /*
104  * Bus control bits.
105  */
106 #define DC_BUSCTL_RESET 0x00000001
107 #define DC_BUSCTL_ARBITRATION 0x00000002
108 #define DC_BUSCTL_SKIPLEN 0x0000007C
109 #define DC_BUSCTL_BUF_BIGENDIAN 0x00000080
110 #define DC_BUSCTL_BURSTLEN 0x00003F00
111 #define DC_BUSCTL_CACHEALIGN 0x0000C000
112 #define DC_BUSCTL_TXPOLL 0x000E0000
113 #define DC_BUSCTL_DBO 0x00100000
114 #define DC_BUSCTL_MRME 0x00200000
115 #define DC_BUSCTL_MRLE 0x00800000
116 #define DC_BUSCTL_MWIE 0x01000000
117 #define DC_BUSCTL_ONNOW_ENB 0x04000000
118
119 #define DC_SKIPLEN_1LONG 0x00000004
120 #define DC_SKIPLEN_2LONG 0x00000008
121 #define DC_SKIPLEN_3LONG 0x00000010
122 #define DC_SKIPLEN_4LONG 0x00000020
123 #define DC_SKIPLEN_5LONG 0x00000040
124
125 #define DC_CACHEALIGN_NONE 0x00000000
126 #define DC_CACHEALIGN_8LONG 0x00004000
127 #define DC_CACHEALIGN_16LONG 0x00008000
128 #define DC_CACHEALIGN_32LONG 0x0000C000
129
130 #define DC_BURSTLEN_USECA 0x00000000
131 #define DC_BURSTLEN_1LONG 0x00000100
132 #define DC_BURSTLEN_2LONG 0x00000200
133 #define DC_BURSTLEN_4LONG 0x00000400
134 #define DC_BURSTLEN_8LONG 0x00000800
135 #define DC_BURSTLEN_16LONG 0x00001000
136 #define DC_BURSTLEN_32LONG 0x00002000
137
138 #define DC_TXPOLL_OFF 0x00000000
139 #define DC_TXPOLL_1 0x00020000
140 #define DC_TXPOLL_2 0x00040000
141 #define DC_TXPOLL_3 0x00060000
142 #define DC_TXPOLL_4 0x00080000
143 #define DC_TXPOLL_5 0x000A0000
144 #define DC_TXPOLL_6 0x000C0000
145 #define DC_TXPOLL_7 0x000E0000
146
147 /*
148  * Interrupt status bits.
149  */
150 #define DC_ISR_TX_OK 0x00000001
151 #define DC_ISR_TX_IDLE 0x00000002
152 #define DC_ISR_TX_NOBUF 0x00000004
153 #define DC_ISR_TX_JABBERTIMEO 0x00000008
154 #define DC_ISR_LINKGOOD 0x00000010
155 #define DC_ISR_TX_UNDERRUN 0x00000020
156 #define DC_ISR_RX_OK 0x00000040
157 #define DC_ISR_RX_NOBUF 0x00000080
158 #define DC_ISR_RX_READ 0x00000100
159 #define DC_ISR_RX_WATDOGTIMEO 0x00000200
160 #define DC_ISR_TX_EARLY 0x00000400
161 #define DC_ISR_TIMER_EXPIRED 0x00000800
162 #define DC_ISR_LINKFAIL 0x00001000
163 #define DC_ISR_BUS_ERR 0x00002000
164 #define DC_ISR_RX_EARLY 0x00004000
165 #define DC_ISR_ABNORMAL 0x00008000
166 #define DC_ISR_NORMAL 0x00010000
167 #define DC_ISR_RX_STATE 0x000E0000
168 #define DC_ISR_TX_STATE 0x00700000
169 #define DC_ISR_BUSERRTYPE 0x03800000
170 #define DC_ISR_100MBPSLINK 0x08000000
171 #define DC_ISR_MAGICKPACK 0x10000000
172
173 #define DC_RXSTATE_STOPPED 0x00000000 /* 000 - Stopped */
174 #define DC_RXSTATE_FETCH 0x00020000 /* 001 - Fetching descriptor */
175 #define DC_RXSTATE_ENDCHECK 0x00040000 /* 010 - check for rx end */
176 #define DC_RXSTATE_WAIT 0x00060000 /* 011 - waiting for packet */
177 #define DC_RXSTATE_SUSPEND 0x00080000 /* 100 - suspend rx */
178 #define DC_RXSTATE_CLOSE 0x000A0000 /* 101 - close tx desc */
179 #define DC_RXSTATE_FLUSH 0x000C0000 /* 110 - flush from FIFO */
180 #define DC_RXSTATE_DEQUEUE 0x000E0000 /* 111 - dequeue from FIFO */
181
182 #define DC_TXSTATE_RESET 0x00000000 /* 000 - reset */
183 #define DC_TXSTATE_FETCH 0x00100000 /* 001 - fetching descriptor */
184 #define DC_TXSTATE_WAITEND 0x00200000 /* 010 - wait for tx end */
185 #define DC_TXSTATE_READING 0x00300000 /* 011 - read and enqueue */
186 #define DC_TXSTATE_RSVD 0x00400000 /* 100 - reserved */
187 #define DC_TXSTATE_SETUP 0x00500000 /* 101 - setup packet */
188 #define DC_TXSTATE_SUSPEND 0x00600000 /* 110 - suspend tx */
189 #define DC_TXSTATE_CLOSE 0x00700000 /* 111 - close tx desc */
190
191 /*
192  * Network config bits.
193  */
194 #define DC_NETCFG_RX_HASHPERF 0x00000001
195 #define DC_NETCFG_RX_ON 0x00000002
196 #define DC_NETCFG_RX_HASHONLY 0x00000004
197 #define DC_NETCFG_RX_BADFRAMES 0x00000008
198 #define DC_NETCFG_RX_INVFILT 0x00000010
199 #define DC_NETCFG_BACKOFFCNT 0x00000020
200 #define DC_NETCFG_RX_PROMISC 0x00000040
201 #define DC_NETCFG_RX_ALLMULTI 0x00000080
202 #define DC_NETCFG_FULLDUPLEX 0x00000200
203 #define DC_NETCFG_LOOPBACK 0x00000C00
204 #define DC_NETCFG_FORCECOLL 0x00001000
205 #define DC_NETCFG_TX_ON 0x00002000
206 #define DC_NETCFG_TX_THRESH 0x0000C000
207 #define DC_NETCFG_TX_BACKOFF 0x00020000
208 #define DC_NETCFG_PORTSEL 0x00040000 /* 0 == 10, 1 == 100 */
209 #define DC_NETCFG_HEARTBEAT 0x00080000
210 #define DC_NETCFG_STORENFWD 0x00200000
211 #define DC_NETCFG_SPEEDSEL 0x00400000 /* 1 == 10, 0 == 100 */
212 #define DC_NETCFG_PCS 0x00800000
213 #define DC_NETCFG_SCRAMBLER 0x01000000
214 #define DC_NETCFG_NO_RXCRC 0x02000000
215 #define DC_NETCFG_RX_ALL 0x40000000
216 #define DC_NETCFG_CAPEFFECT 0x80000000
217
218 #define DC_OPMODE_NORM 0x00000000
219 #define DC_OPMODE_INTLOOP 0x00000400
220 #define DC_OPMODE_EXTLOOP 0x00000800
221
222 #if 0
223 #define DC_TXTHRESH_72BYTES 0x00000000
224 #define DC_TXTHRESH_96BYTES 0x00004000
225 #define DC_TXTHRESH_128BYTES 0x00008000
226 #define DC_TXTHRESH_160BYTES 0x0000C000
227 #endif
228
229 #define DC_TXTHRESH_MIN 0x00000000
230 #define DC_TXTHRESH_INC 0x00004000
231 #define DC_TXTHRESH_MAX 0x0000C000
232
233
234 /*
235  * Interrupt mask bits.
236  */
237 #define DC_IMR_TX_OK 0x00000001
238 #define DC_IMR_TX_IDLE 0x00000002
239 #define DC_IMR_TX_NOBUF 0x00000004
240 #define DC_IMR_TX_JABBERTIMEO 0x00000008
241 #define DC_IMR_LINKGOOD 0x00000010
242 #define DC_IMR_TX_UNDERRUN 0x00000020
243 #define DC_IMR_RX_OK 0x00000040
244 #define DC_IMR_RX_NOBUF 0x00000080
245 #define DC_IMR_RX_READ 0x00000100
246 #define DC_IMR_RX_WATDOGTIMEO 0x00000200
247 #define DC_IMR_TX_EARLY 0x00000400
248 #define DC_IMR_TIMER_EXPIRED 0x00000800
249 #define DC_IMR_LINKFAIL 0x00001000
250 #define DC_IMR_BUS_ERR 0x00002000
251 #define DC_IMR_RX_EARLY 0x00004000
252 #define DC_IMR_ABNORMAL 0x00008000
253 #define DC_IMR_NORMAL 0x00010000
254 #define DC_IMR_100MBPSLINK 0x08000000
255 #define DC_IMR_MAGICKPACK 0x10000000
256
257 #define DC_INTRS \
258  (DC_IMR_RX_OK|DC_IMR_TX_OK|DC_IMR_RX_NOBUF|DC_IMR_RX_WATDOGTIMEO|\
259  DC_IMR_TX_NOBUF|DC_IMR_TX_UNDERRUN|DC_IMR_BUS_ERR| \
260  DC_IMR_ABNORMAL|DC_IMR_NORMAL/*|DC_IMR_TX_EARLY*/)
261 /*
262  * Serial I/O (EEPROM/ROM) bits.
263  */
264 #define DC_SIO_EE_CS 0x00000001 /* EEPROM chip select */
265 #define DC_SIO_EE_CLK 0x00000002 /* EEPROM clock */
266 #define DC_SIO_EE_DATAIN 0x00000004 /* EEPROM data output */
267 #define DC_SIO_EE_DATAOUT 0x00000008 /* EEPROM data input */
268 #define DC_SIO_ROMDATA4 0x00000010
269 #define DC_SIO_ROMDATA5 0x00000020
270 #define DC_SIO_ROMDATA6 0x00000040
271 #define DC_SIO_ROMDATA7 0x00000080
272 #define DC_SIO_EESEL 0x00000800
273 #define DC_SIO_ROMSEL 0x00001000
274 #define DC_SIO_ROMCTL_WRITE 0x00002000
275 #define DC_SIO_ROMCTL_READ 0x00004000
276 #define DC_SIO_MII_CLK 0x00010000 /* MDIO clock */
277 #define DC_SIO_MII_DATAOUT 0x00020000 /* MDIO data out */
278 #define DC_SIO_MII_DIR 0x00040000 /* MDIO dir */
279 #define DC_SIO_MII_DATAIN 0x00080000 /* MDIO data in */
280
281 #define DC_EECMD_WRITE 0x140
282 #define DC_EECMD_READ 0x180
283 #define DC_EECMD_ERASE 0x1c0
284
285 #define DC_EE_NODEADDR_OFFSET 0x70
286 #define DC_EE_NODEADDR 10
287
288 /*
289  * General purpose timer register
290  */
291 #define DC_TIMER_VALUE 0x0000FFFF
292 #define DC_TIMER_CONTINUOUS 0x00010000
293
294 /*
295  * 10baseT status register
296  */
297 #define DC_TSTAT_MIIACT 0x00000001 /* MII port activity */
298 #define DC_TSTAT_LS100 0x00000002 /* link status of 100baseTX */
299 #define DC_TSTAT_LS10 0x00000004 /* link status of 10baseT */
300 #define DC_TSTAT_AUTOPOLARITY 0x00000008
301 #define DC_TSTAT_AUIACT 0x00000100 /* AUI activity */
302 #define DC_TSTAT_10BTACT 0x00000200 /* 10baseT activity */
303 #define DC_TSTAT_NSN 0x00000400 /* non-stable FLPs detected */
304 #define DC_TSTAT_REMFAULT 0x00000800
305 #define DC_TSTAT_ANEGSTAT 0x00007000
306 #define DC_TSTAT_LP_CAN_NWAY 0x00008000 /* link partner supports NWAY */
307 #define DC_TSTAT_LPCODEWORD 0xFFFF0000 /* link partner's code word */
308
309 #define DC_ASTAT_DISABLE 0x00000000
310 #define DC_ASTAT_TXDISABLE 0x00001000
311 #define DC_ASTAT_ABDETECT 0x00002000
312 #define DC_ASTAT_ACKDETECT 0x00003000
313 #define DC_ASTAT_CMPACKDETECT 0x00004000
314 #define DC_ASTAT_AUTONEGCMP 0x00005000
315 #define DC_ASTAT_LINKCHECK 0x00006000
316
317 /*
318  * PHY reset register
319  */
320 #define DC_SIA_RESET 0x00000001
321 #define DC_SIA_AUI 0x00000008 /* AUI or 10baseT */
322
323 /*
324  * 10baseT control register
325  */
326 #define DC_TCTL_ENCODER_ENB 0x00000001
327 #define DC_TCTL_LOOPBACK 0x00000002
328 #define DC_TCTL_DRIVER_ENB 0x00000004
329 #define DC_TCTL_LNKPULSE_ENB 0x00000008
330 #define DC_TCTL_HALFDUPLEX 0x00000040
331 #define DC_TCTL_AUTONEGENBL 0x00000080
332 #define DC_TCTL_RX_SQUELCH 0x00000100
333 #define DC_TCTL_COLL_SQUELCH 0x00000200
334 #define DC_TCTL_COLL_DETECT 0x00000400
335 #define DC_TCTL_SQE_ENB 0x00000800
336 #define DC_TCTL_LINKTEST 0x00001000
337 #define DC_TCTL_AUTOPOLARITY 0x00002000
338 #define DC_TCTL_SET_POL_PLUS 0x00004000
339 #define DC_TCTL_AUTOSENSE 0x00008000 /* 10bt/AUI autosense */
340 #define DC_TCTL_100BTXHALF 0x00010000
341 #define DC_TCTL_100BTXFULL 0x00020000
342 #define DC_TCTL_100BT4 0x00040000
343
344 /*
345  * Watchdog timer register
346  */
347 #define DC_WDOG_JABBERDIS 0x00000001
348 #define DC_WDOG_HOSTUNJAB 0x00000002
349 #define DC_WDOG_JABBERCLK 0x00000004
350 #define DC_WDOG_RXWDOGDIS 0x00000010
351 #define DC_WDOG_RXWDOGCLK 0x00000020
352 #define DC_WDOG_MUSTBEZERO 0x00000100
353 #define DC_WDOG_AUIBNC 0x00100000
354 #define DC_WDOG_ACTIVITY 0x00200000
355 #define DC_WDOG_RX_MATCH 0x00400000
356 #define DC_WDOG_LINK 0x00800000
357 #define DC_WDOG_CTLWREN 0x08000000
358
359 /*
360  * Size of a setup frame.
361  */
362 #define DC_SFRAME_LEN 192
363
364 /*
365  * 21x4x TX/RX list structure.
366  */
367
368 struct dc_desc {
369  u_int32_t dc_status;
370  u_int32_t dc_ctl;
371  u_int32_t dc_ptr1;
372  u_int32_t dc_ptr2;
373 };
374
375 #define dc_data dc_ptr1
376 #define dc_next dc_ptr2
377
378 #define DC_RXSTAT_FIFOOFLOW 0x00000001
379 #define DC_RXSTAT_CRCERR 0x00000002
380 #define DC_RXSTAT_DRIBBLE 0x00000004
381 #define DC_RXSTAT_MIIERE 0x00000008
382 #define DC_RXSTAT_WATCHDOG 0x00000010
383 #define DC_RXSTAT_FRAMETYPE 0x00000020 /* 0 == IEEE 802.3 */
384 #define DC_RXSTAT_COLLSEEN 0x00000040
385 #define DC_RXSTAT_GIANT 0x00000080
386 #define DC_RXSTAT_LASTFRAG 0x00000100
387 #define DC_RXSTAT_FIRSTFRAG 0x00000200
388 #define DC_RXSTAT_MULTICAST 0x00000400
389 #define DC_RXSTAT_RUNT 0x00000800
390 #define DC_RXSTAT_RXTYPE 0x00003000
391 #define DC_RXSTAT_DE 0x00004000
392 #define DC_RXSTAT_RXERR 0x00008000
393 #define DC_RXSTAT_RXLEN 0x3FFF0000
394 #define DC_RXSTAT_OWN 0x80000000
395
396 #define DC_RXBYTES(x) ((x & DC_RXSTAT_RXLEN) >> 16)
397 #define DC_RXSTAT (DC_RXSTAT_FIRSTFRAG|DC_RXSTAT_LASTFRAG|DC_RXSTAT_OWN)
398
399 #define DC_RXCTL_BUFLEN1 0x00000FFF
400 #define DC_RXCTL_BUFLEN2 0x00FFF000
401 #define DC_RXCTL_RLINK 0x01000000
402 #define DC_RXCTL_RLAST 0x02000000
403
404 #define DC_TXSTAT_DEFER 0x00000001
405 #define DC_TXSTAT_UNDERRUN 0x00000002
406 #define DC_TXSTAT_LINKFAIL 0x00000003
407 #define DC_TXSTAT_COLLCNT 0x00000078
408 #define DC_TXSTAT_SQE 0x00000080
409 #define DC_TXSTAT_EXCESSCOLL 0x00000100
410 #define DC_TXSTAT_LATECOLL 0x00000200
411 #define DC_TXSTAT_NOCARRIER 0x00000400
412 #define DC_TXSTAT_CARRLOST 0x00000800
413 #define DC_TXSTAT_JABTIMEO 0x00004000
414 #define DC_TXSTAT_ERRSUM 0x00008000
415 #define DC_TXSTAT_OWN 0x80000000
416
417 #define DC_TXCTL_BUFLEN1 0x000007FF
418 #define DC_TXCTL_BUFLEN2 0x003FF800
419 #define DC_TXCTL_FILTTYPE0 0x00400000
420 #define DC_TXCTL_PAD 0x00800000
421 #define DC_TXCTL_TLINK 0x01000000
422 #define DC_TXCTL_TLAST 0x02000000
423 #define DC_TXCTL_NOCRC 0x04000000
424 #define DC_TXCTL_SETUP 0x08000000
425 #define DC_TXCTL_FILTTYPE1 0x10000000
426 #define DC_TXCTL_FIRSTFRAG 0x20000000
427 #define DC_TXCTL_LASTFRAG 0x40000000
428 #define DC_TXCTL_FINT 0x80000000
429
430 #define DC_FILTER_PERFECT 0x00000000
431 #define DC_FILTER_HASHPERF 0x00400000
432 #define DC_FILTER_INVERSE 0x10000000
433 #define DC_FILTER_HASHONLY 0x10400000
434
435 #define DC_MAXFRAGS 16
436 #ifdef DEVICE_POLLING
437 #define DC_RX_LIST_CNT 192
438 #else
439 #define DC_RX_LIST_CNT 64
440 #endif
441 #define DC_TX_LIST_CNT 256
442 #define DC_MIN_FRAMELEN 60
443 #define DC_RXLEN 1536
444
445 #define DC_INC(x, y) (x) = (x + 1) % y
446
447 struct dc_list_data {
448  struct dc_desc dc_rx_list[DC_RX_LIST_CNT];
449  struct dc_desc dc_tx_list[DC_TX_LIST_CNT];
450 };
451
453  struct mbuf *dc_rx_chain[DC_RX_LIST_CNT];
454  struct mbuf *dc_tx_chain[DC_TX_LIST_CNT];
455  u_int32_t dc_sbuf[DC_SFRAME_LEN/sizeof(u_int32_t)];
456  u_int8_t dc_pad[DC_MIN_FRAMELEN];
457  int dc_tx_prod;
458  int dc_tx_cons;
459  int dc_tx_cnt;
460  int dc_rx_prod;
461 };
462
463 struct dc_mediainfo {
464  int dc_media;
465  u_int8_t *dc_gp_ptr;
466  u_int8_t dc_gp_len;
467  u_int8_t *dc_reset_ptr;
468  u_int8_t dc_reset_len;
469  struct dc_mediainfo *dc_next;
470 };
471
472
473 struct dc_type {
474  u_int16_t dc_vid;
475  u_int16_t dc_did;
476  char *dc_name;
477  int dc_devsig;
478  int dc_bus;
479  int dc_dev;
480  int dc_fun;
481 };
482
483 struct dc_mii_frame {
484  u_int8_t mii_stdelim;
485  u_int8_t mii_opcode;
486  u_int8_t mii_phyaddr;
487  u_int8_t mii_regaddr;
488  u_int8_t mii_turnaround;
489  u_int16_t mii_data;
490 };
491
492 /*
493  * MII constants
494  */
495 #define DC_MII_STARTDELIM 0x01
496 #define DC_MII_READOP 0x02
497 #define DC_MII_WRITEOP 0x01
498 #define DC_MII_TURNAROUND 0x02
499
500
501 /*
502  * Registers specific to clone devices.
503  * This mainly relates to RX filter programming: not all 21x4x clones
504  * use the standard DEC filter programming mechanism.
505  */
506
507 /*
508  * ADMtek specific registers and constants for the AL981 and AN985.
509  * The AN985 doesn't use the magic PHY registers.
510  */
511 #define DC_AL_CR 0x88 /* command register */
512 #define DC_AL_PAR0 0xA4 /* station address */
513 #define DC_AL_PAR1 0xA8 /* station address */
514 #define DC_AL_MAR0 0xAC /* multicast hash filter */
515 #define DC_AL_MAR1 0xB0 /* multicast hash filter */
516 #define DC_AL_BMCR 0xB4 /* built in PHY control */
517 #define DC_AL_BMSR 0xB8 /* built in PHY status */
518 #define DC_AL_VENID 0xBC /* built in PHY ID0 */
519 #define DC_AL_DEVID 0xC0 /* built in PHY ID1 */
520 #define DC_AL_ANAR 0xC4 /* built in PHY autoneg advert */
521 #define DC_AL_LPAR 0xC8 /* bnilt in PHY link part. ability */
522 #define DC_AL_ANER 0xCC /* built in PHY autoneg expansion */
523
524 #define DC_AL_CR_ATUR 0x00000001 /* automatic TX underrun recovery */
525 #define DC_ADMTEK_PHYADDR 0x1
526 #define DC_AL_EE_NODEADDR 4
527 /* End of ADMtek specific registers */
528
529 /*
530  * ASIX specific registers.
531  */
532 #define DC_AX_FILTIDX 0x68 /* RX filter index */
533 #define DC_AX_FILTDATA 0x70 /* RX filter data */
534
535 /*
536  * Special ASIX-specific bits in the ASIX NETCFG register (CSR6).
537  */
538 #define DC_AX_NETCFG_RX_BROAD 0x00000100
539
540 /*
541  * RX Filter Index Register values
542  */
543 #define DC_AX_FILTIDX_PAR0 0x00000000
544 #define DC_AX_FILTIDX_PAR1 0x00000001
545 #define DC_AX_FILTIDX_MAR0 0x00000002
546 #define DC_AX_FILTIDX_MAR1 0x00000003
547 /* End of ASIX specific registers */
548
549 /*
550  * Macronix specific registers. The Macronix chips have a special
551  * register for reading the NWAY status, which we don't use, plus
552  * a magic packet register, which we need to tweak a bit per the
553  * Macronix application notes.
554  */
555 #define DC_MX_MAGICPACKET 0x80
556 #define DC_MX_NWAYSTAT 0xA0
557
558 /*
559  * Magic packet register
560  */
561 #define DC_MX_MPACK_DISABLE 0x00400000
562
563 /*
564  * NWAY status register.
565  */
566 #define DC_MX_NWAY_10BTHALF 0x08000000
567 #define DC_MX_NWAY_10BTFULL 0x10000000
568 #define DC_MX_NWAY_100BTHALF 0x20000000
569 #define DC_MX_NWAY_100BTFULL 0x40000000
570 #define DC_MX_NWAY_100BT4 0x80000000
571
572 /*
573  * These are magic values that must be written into CSR16
574  * (DC_MX_MAGICPACKET) in order to put the chip into proper
575  * operating mode. The magic numbers are documented in the
576  * Macronix 98715 application notes.
577  */
578 #define DC_MX_MAGIC_98713 0x0F370000
579 #define DC_MX_MAGIC_98713A 0x0B3C0000
580 #define DC_MX_MAGIC_98715 0x0B3C0000
581 #define DC_MX_MAGIC_98725 0x0B3C0000
582 /* End of Macronix specific registers */
583
584 /*
585  * PNIC 82c168/82c169 specific registers.
586  * The PNIC has its own special NWAY support, which doesn't work,
587  * and shortcut ways of reading the EEPROM and MII bus.
588  */
589 #define DC_PN_GPIO 0x60 /* general purpose pins control */
590 #define DC_PN_PWRUP_CFG 0x90 /* config register, set by EEPROM */
591 #define DC_PN_SIOCTL 0x98 /* serial EEPROM control register */
592 #define DC_PN_MII 0xA0 /* MII access register */
593 #define DC_PN_NWAY 0xB8 /* Internal NWAY register */
594
595 /* Serial I/O EEPROM register */
596 #define DC_PN_SIOCTL_DATA 0x0000003F
597 #define DC_PN_SIOCTL_OPCODE 0x00000300
598 #define DC_PN_SIOCTL_BUSY 0x80000000
599
600 #define DC_PN_EEOPCODE_ERASE 0x00000300
601 #define DC_PN_EEOPCODE_READ 0x00000600
602 #define DC_PN_EEOPCODE_WRITE 0x00000100
603
604 /*
605  * The first two general purpose pins control speed selection and
606  * 100Mbps loopback on the 82c168 chip. The control bits should always
607  * be set (to make the data pins outputs) and the speed selction and
608  * loopback bits set accordingly when changing media. Physically, this
609  * will set the state of a relay mounted on the card.
610  */
611 #define DC_PN_GPIO_DATA0 0x000000001
612 #define DC_PN_GPIO_DATA1 0x000000002
613 #define DC_PN_GPIO_DATA2 0x000000004
614 #define DC_PN_GPIO_DATA3 0x000000008
615 #define DC_PN_GPIO_CTL0 0x000000010
616 #define DC_PN_GPIO_CTL1 0x000000020
617 #define DC_PN_GPIO_CTL2 0x000000040
618 #define DC_PN_GPIO_CTL3 0x000000080
619 #define DC_PN_GPIO_SPEEDSEL DC_PN_GPIO_DATA0/* 1 == 100Mbps, 0 == 10Mbps */
620 #define DC_PN_GPIO_100TX_LOOP DC_PN_GPIO_DATA1/* 1 == normal, 0 == loop */
621 #define DC_PN_GPIO_BNC_ENB DC_PN_GPIO_DATA2
622 #define DC_PN_GPIO_100TX_LNK DC_PN_GPIO_DATA3
623 #define DC_PN_GPIO_SETBIT(sc, r) \
624  DC_SETBIT(sc, DC_PN_GPIO, ((r) | (r << 4)))
625 #define DC_PN_GPIO_CLRBIT(sc, r) \
626  { \
627  DC_SETBIT(sc, DC_PN_GPIO, ((r) << 4)); \
628  DC_CLRBIT(sc, DC_PN_GPIO, (r)); \
629  }
630
631 /* shortcut MII access register */
632 #define DC_PN_MII_DATA 0x0000FFFF
633 #define DC_PN_MII_RESERVER 0x00020000
634 #define DC_PN_MII_REGADDR 0x007C0000
635 #define DC_PN_MII_PHYADDR 0x0F800000
636 #define DC_PN_MII_OPCODE 0x30000000
637 #define DC_PN_MII_BUSY 0x80000000
638
639 #define DC_PN_MIIOPCODE_READ 0x60020000
640 #define DC_PN_MIIOPCODE_WRITE 0x50020000
641
642 /* Internal NWAY bits */
643 #define DC_PN_NWAY_RESET 0x00000001 /* reset */
644 #define DC_PN_NWAY_PDOWN 0x00000002 /* power down */
645 #define DC_PN_NWAY_BYPASS 0x00000004 /* bypass */
646 #define DC_PN_NWAY_AUILOWCUR 0x00000008 /* AUI low current */
647 #define DC_PN_NWAY_TPEXTEND 0x00000010 /* low squelch voltage */
648 #define DC_PN_NWAY_POLARITY 0x00000020 /* 0 == on, 1 == off */
649 #define DC_PN_NWAY_TP 0x00000040 /* 1 == tp, 0 == AUI */
650 #define DC_PN_NWAY_AUIVOLT 0x00000080 /* 1 == full, 0 == half */
651 #define DC_PN_NWAY_DUPLEX 0x00000100 /* LED, 1 == full, 0 == half */
652 #define DC_PN_NWAY_LINKTEST 0x00000200 /* 0 == on, 1 == off */
653 #define DC_PN_NWAY_AUTODETECT 0x00000400 /* 1 == off, 0 == on */
654 #define DC_PN_NWAY_SPEEDSEL 0x00000800 /* LED, 0 = 10, 1 == 100 */
655 #define DC_PN_NWAY_NWAY_ENB 0x00001000 /* 0 == off, 1 == on */
656 #define DC_PN_NWAY_CAP10HDX 0x00002000
657 #define DC_PN_NWAY_CAP10FDX 0x00004000
658 #define DC_PN_NWAY_CAP100FDX 0x00008000
659 #define DC_PN_NWAY_CAP100HDX 0x00010000
660 #define DC_PN_NWAY_CAP100T4 0x00020000
661 #define DC_PN_NWAY_ANEGRESTART 0x02000000 /* resets when aneg done */
662 #define DC_PN_NWAY_REMFAULT 0x04000000
663 #define DC_PN_NWAY_LPAR10HDX 0x08000000
664 #define DC_PN_NWAY_LPAR10FDX 0x10000000
665 #define DC_PN_NWAY_LPAR100FDX 0x20000000
666 #define DC_PN_NWAY_LPAR100HDX 0x40000000
667 #define DC_PN_NWAY_LPAR100T4 0x80000000
668
669 /* End of PNIC specific registers */
670
671 /*
672  * CONEXANT specific registers.
673  */
674
675 #define DC_CONEXANT_PHYADDR 0x1
676 #define DC_CONEXANT_EE_NODEADDR 0x19A
677
678 /* End of CONEXANT specific registers */
679
680
681 struct dc_softc {
682  struct arpcom arpcom; /* interface info */
683  rtems_irq_connect_data irqInfo;
684  volatile u_int32_t membase;
685  rtems_id daemontid;
686 #if 0
687  bus_space_handle_t dc_bhandle; /* bus space handle */
688  bus_space_tag_t dc_btag; /* bus space tag */
689  void *dc_intrhand;
690  struct resource *dc_irq;
691  struct resource *dc_res;
692 #endif
693  struct dc_type *dc_info; /* adapter info */
694 /* device_t dc_miibus; */
695  u_int8_t dc_unit; /* interface number */
696  char *dc_name;
697  u_int8_t dc_type;
698  u_int8_t dc_pmode;
699  u_int8_t dc_link;
700  u_int8_t dc_cachesize;
701  int dc_romwidth;
702  int dc_pnic_rx_bug_save;
703  unsigned char *dc_pnic_rx_buf;
704  int dc_if_flags;
705  int dc_if_media;
706  u_int32_t dc_flags;
707  u_int32_t dc_txthresh;
708  u_int8_t *dc_srom;
709  struct dc_mediainfo *dc_mi;
710 /*
711  struct callout_handle dc_stat_ch;
712 */
713  struct dc_list_data *dc_ldata;
714  struct dc_chain_data dc_cdata;
715 #ifdef __alpha__
716  int dc_srm_media;
717 #endif
718 #ifdef DEVICE_POLLING
719  int rxcycles; /* ... when polling */
720 #endif
721  int suspended; /* 0 = normal 1 = suspended */
722
723  u_int32_t saved_maps[5]; /* pci data */
724  u_int32_t saved_biosaddr;
725  u_int8_t saved_intline;
726  u_int8_t saved_cachelnsz;
727  u_int8_t saved_lattimer;
728 };
729
730 #define DC_TX_POLL 0x00000001
731 #define DC_TX_COALESCE 0x00000002
732 #define DC_TX_ADMTEK_WAR 0x00000004
733 #define DC_TX_USE_TX_INTR 0x00000008
734 #define DC_RX_FILTER_TULIP 0x00000010
735 #define DC_TX_INTR_FIRSTFRAG 0x00000020
736 #define DC_PNIC_RX_BUG_WAR 0x00000040
737 #define DC_TX_FIXED_RING 0x00000080
738 #define DC_TX_STORENFWD 0x00000100
739 #define DC_REDUCED_MII_POLL 0x00000200
740 #define DC_TX_INTR_ALWAYS 0x00000400
741 #define DC_21143_NWAY 0x00000800
742 #define DC_128BIT_HASH 0x00001000
743 #define DC_64BIT_HASH 0x00002000
744 #define DC_TULIP_LEDS 0x00004000
745 #define DC_TX_ONE 0x00008000
746
747 /*
748  * register space access macros
749  */
750 #define _readl_(addr) (*(volatile unsigned int *)((void *)(addr)))
751 #define _writel_(b, addr) (*(volatile unsigned int *)((void *)(addr)) = (b))
752
753 #define CSR_READ_4(sc, reg) _readl_(((sc->membase)+(reg)))
754 #define CSR_WRITE_4(sc, reg, val) _writel_(val, ((sc->membase)+(reg)))
755
756
757
758
759
760
761 #define DC_TIMEOUT 1000
762 #define ETHER_ALIGN 2
763
764 /*
765  * General constants that are fun to know.
766  */
767
768 /*
769  * DEC PCI vendor ID
770  */
771 #define DC_VENDORID_DEC 0x1011
772
773 /*
774  * DEC/Intel 21143 PCI device ID
775  */
776 #define DC_DEVICEID_21143 0x0019
777
778 /*
779  * Macronix PCI vendor ID
780  */
781 #define DC_VENDORID_MX 0x10D9
782
783 /*
784  * Macronix PMAC device IDs.
785  */
786 #define DC_DEVICEID_98713 0x0512
787 #define DC_DEVICEID_987x5 0x0531
788 #define DC_DEVICEID_98727 0x0532
789 #define DC_DEVICEID_98732 0x0532
790
791 /* Macronix PCI revision codes. */
792 #define DC_REVISION_98713 0x00
793 #define DC_REVISION_98713A 0x10
794 #define DC_REVISION_98715 0x20
795 #define DC_REVISION_98715AEC_C 0x25
796 #define DC_REVISION_98725 0x30
797
798 /*
799  * Compex PCI vendor ID.
800  */
801 #define DC_VENDORID_CP 0x11F6
802
803 /*
804  * Compex PMAC PCI device IDs.
805  */
806 #define DC_DEVICEID_98713_CP 0x9881
807
808 /*
809  * Lite-On PNIC PCI vendor ID
810  */
811 #define DC_VENDORID_LO 0x11AD
812
813 /*
814  * 82c168/82c169 PNIC device IDs. Both chips have the same device
815  * ID but different revisions. Revision 0x10 is the 82c168, and
816  * 0x20 is the 82c169.
817  */
818 #define DC_DEVICEID_82C168 0x0002
819
820 #define DC_REVISION_82C168 0x10
821 #define DC_REVISION_82C169 0x20
822
823 /*
824  * Lite-On PNIC II device ID. Note: this is actually a Macronix 98715A
825  * with wake on lan/magic packet support.
826  */
827 #define DC_DEVICEID_82C115 0xc115
828
829 /*
830  * Davicom vendor ID.
831  */
832 #define DC_VENDORID_DAVICOM 0x1282
833
834 /*
835  * Davicom device IDs.
836  */
837 #define DC_DEVICEID_DM9009 0x9009
838 #define DC_DEVICEID_DM9100 0x9100
839 #define DC_DEVICEID_DM9102 0x9102
840
841 /*
842  * The DM9102A has the same PCI device ID as the DM9102,
843  * but a higher revision code.
844  */
845 #define DC_REVISION_DM9102 0x10
846 #define DC_REVISION_DM9102A 0x30
847
848 /*
849  * ADMtek vendor ID.
850  */
851 #define DC_VENDORID_ADMTEK 0x1317
852
853 /*
854  * ADMtek device IDs.
855  */
856 #define DC_DEVICEID_AL981 0x0981
857 #define DC_DEVICEID_AN985 0x0985
858
859 /*
860  * ASIX vendor ID.
861  */
862 #define DC_VENDORID_ASIX 0x125B
863
864 /*
865  * ASIX device IDs.
866  */
867 #define DC_DEVICEID_AX88140A 0x1400
868
869 /*
870  * The ASIX AX88140 and ASIX AX88141 have the same vendor and
871  * device IDs but different revision values.
872  */
873 #define DC_REVISION_88140 0x00
874 #define DC_REVISION_88141 0x10
875
876 /*
877  * Accton vendor ID.
878  */
879 #define DC_VENDORID_ACCTON 0x1113
880
881 /*
882  * Accton device IDs.
883  */
884 #define DC_DEVICEID_EN1217 0x1217
885 #define DC_DEVICEID_EN2242 0x1216
886
887 /*
888  * Conexant vendor ID.
889  */
890 #define DC_VENDORID_CONEXANT 0x14f1
891
892 /*
893  * Conexant device IDs.
894  */
895 #define DC_DEVICEID_RS7112 0x1803
896
897 /*
898  * PCI low memory base and low I/O base register, and
899  * other PCI registers.
900  */
901
902 #define DC_PCI_CFID 0x00 /* Id */
903 #define DC_PCI_CFCS 0x04 /* Command and status */
904 #define DC_PCI_CFRV 0x08 /* Revision */
905 #define DC_PCI_CFLT 0x0C /* Latency timer */
906 #define DC_PCI_CFBIO 0x10 /* Base I/O address */
907 #define DC_PCI_CFBMA 0x14 /* Base memory address */
908 #define DC_PCI_CCIS 0x28 /* Card info struct */
909 #define DC_PCI_CSID 0x2C /* Subsystem ID */
910 #define DC_PCI_CBER 0x30 /* Expansion ROM base address */
911 #define DC_PCI_CCAP 0x34 /* Caps pointer - PD/TD chip only */
912 #define DC_PCI_CFIT 0x3C /* Interrupt */
913 #define DC_PCI_CFDD 0x40 /* Device and driver area */
914 #define DC_PCI_CWUA0 0x44 /* Wake-Up LAN addr 0 */
915 #define DC_PCI_CWUA1 0x48 /* Wake-Up LAN addr 1 */
916 #define DC_PCI_SOP0 0x4C /* SecureON passwd 0 */
917 #define DC_PCI_SOP1 0x50 /* SecureON passwd 1 */
918 #define DC_PCI_CWUC 0x54 /* Configuration Wake-Up cmd */
919 #define DC_PCI_CCID 0xDC /* Capability ID - PD/TD only */
920 #define DC_PCI_CPMC 0xE0 /* Pwrmgmt ctl & sts - PD/TD only */
921
922 /* PCI ID register */
923 #define DC_CFID_VENDOR 0x0000FFFF
924 #define DC_CFID_DEVICE 0xFFFF0000
925
926 /* PCI command/status register */
927 #define DC_CFCS_IOSPACE 0x00000001 /* I/O space enable */
928 #define DC_CFCS_MEMSPACE 0x00000002 /* memory space enable */
929 #define DC_CFCS_BUSMASTER 0x00000004 /* bus master enable */
930 #define DC_CFCS_MWI_ENB 0x00000010 /* mem write and inval enable */
931 #define DC_CFCS_PARITYERR_ENB 0x00000040 /* parity error enable */
932 #define DC_CFCS_SYSERR_ENB 0x00000100 /* system error enable */
933 #define DC_CFCS_NEWCAPS 0x00100000 /* new capabilities */
934 #define DC_CFCS_FAST_B2B 0x00800000 /* fast back-to-back capable */
935 #define DC_CFCS_DATAPARITY 0x01000000 /* Parity error report */
936 #define DC_CFCS_DEVSELTIM 0x06000000 /* devsel timing */
937 #define DC_CFCS_TGTABRT 0x10000000 /* received target abort */
938 #define DC_CFCS_MASTERABRT 0x20000000 /* received master abort */
939 #define DC_CFCS_SYSERR 0x40000000 /* asserted system error */
940 #define DC_CFCS_PARITYERR 0x80000000 /* asserted parity error */
941
942 /* PCI revision register */
943 #define DC_CFRV_STEPPING 0x0000000F
944 #define DC_CFRV_REVISION 0x000000F0
945 #define DC_CFRV_SUBCLASS 0x00FF0000
946 #define DC_CFRV_BASECLASS 0xFF000000
947
948 #define DC_21143_PB_REV 0x00000030
949 #define DC_21143_TB_REV 0x00000030
950 #define DC_21143_PC_REV 0x00000030
951 #define DC_21143_TC_REV 0x00000030
952 #define DC_21143_PD_REV 0x00000041
953 #define DC_21143_TD_REV 0x00000041
954
955 /* PCI latency timer register */
956 #define DC_CFLT_CACHELINESIZE 0x000000FF
957 #define DC_CFLT_LATENCYTIMER 0x0000FF00
958
959 /* PCI subsystem ID register */
960 #define DC_CSID_VENDOR 0x0000FFFF
961 #define DC_CSID_DEVICE 0xFFFF0000
962
963 /* PCI cababilities pointer */
964 #define DC_CCAP_OFFSET 0x000000FF
965
966 /* PCI interrupt config register */
967 #define DC_CFIT_INTLINE 0x000000FF
968 #define DC_CFIT_INTPIN 0x0000FF00
969 #define DC_CFIT_MIN_GNT 0x00FF0000
970 #define DC_CFIT_MAX_LAT 0xFF000000
971
972 /* PCI capability register */
973 #define DC_CCID_CAPID 0x000000FF
974 #define DC_CCID_NEXTPTR 0x0000FF00
975 #define DC_CCID_PM_VERS 0x00070000
976 #define DC_CCID_PME_CLK 0x00080000
977 #define DC_CCID_DVSPEC_INT 0x00200000
978 #define DC_CCID_STATE_D1 0x02000000
979 #define DC_CCID_STATE_D2 0x04000000
980 #define DC_CCID_PME_D0 0x08000000
981 #define DC_CCID_PME_D1 0x10000000
982 #define DC_CCID_PME_D2 0x20000000
983 #define DC_CCID_PME_D3HOT 0x40000000
984 #define DC_CCID_PME_D3COLD 0x80000000
985
986 /* PCI power management control/status register */
987 #define DC_CPMC_STATE 0x00000003
988 #define DC_CPMC_PME_ENB 0x00000100
989 #define DC_CPMC_PME_STS 0x00008000
990
991 #define DC_PSTATE_D0 0x0
992 #define DC_PSTATE_D1 0x1
993 #define DC_PSTATE_D2 0x2
994 #define DC_PSTATE_D3 0x3
995
996 /* Device specific region */
997 /* Configuration and driver area */
998 #define DC_CFDD_DRVUSE 0x0000FFFF
999 #define DC_CFDD_SNOOZE_MODE 0x40000000
1000 #define DC_CFDD_SLEEP_MODE 0x80000000
1001
1002 /* Configuration wake-up command register */
1003 #define DC_CWUC_MUST_BE_ZERO 0x00000001
1004 #define DC_CWUC_SECUREON_ENB 0x00000002
1005 #define DC_CWUC_FORCE_WUL 0x00000004
1006 #define DC_CWUC_BNC_ABILITY 0x00000008
1007 #define DC_CWUC_AUI_ABILITY 0x00000010
1008 #define DC_CWUC_TP10_ABILITY 0x00000020
1009 #define DC_CWUC_MII_ABILITY 0x00000040
1010 #define DC_CWUC_SYM_ABILITY 0x00000080
1011 #define DC_CWUC_LOCK 0x00000100
1012
1013 /*
1014  * SROM nonsense.
1015  */
1016
1017 #define DC_IB_CTLRCNT 0x13
1018 #define DC_IB_LEAF0_CNUM 0x1A
1019 #define DC_IB_LEAF0_OFFSET 0x1B
1020
1022  u_int16_t dc_conntype;
1023  u_int8_t dc_blkcnt;
1024  u_int8_t dc_rsvd;
1025  u_int16_t dc_infoblk;
1026 };
1027
1028 #define DC_CTYPE_10BT 0x0000
1029 #define DC_CTYPE_10BT_NWAY 0x0100
1030 #define DC_CTYPE_10BT_FDX 0x0204
1031 #define DC_CTYPE_10B2 0x0001
1032 #define DC_CTYPE_10B5 0x0002
1033 #define DC_CTYPE_100BT 0x0003
1034 #define DC_CTYPE_100BT_FDX 0x0205
1035 #define DC_CTYPE_100T4 0x0006
1036 #define DC_CTYPE_100FX 0x0007
1037 #define DC_CTYPE_100FX_FDX 0x0208
1038 #define DC_CTYPE_MII_10BT 0x0009
1039 #define DC_CTYPE_MII_10BT_FDX 0x020A
1040 #define DC_CTYPE_MII_100BT 0x000D
1041 #define DC_CTYPE_MII_100BT_FDX 0x020E
1042 #define DC_CTYPE_MII_100T4 0x000F
1043 #define DC_CTYPE_MII_100FX 0x0010
1044 #define DC_CTYPE_MII_100FX_FDX 0x0211
1045 #define DC_CTYPE_DYN_PUP_AUTOSENSE 0x0800
1046 #define DC_CTYPE_PUP_AUTOSENSE 0x8800
1047 #define DC_CTYPE_NOMEDIA 0xFFFF
1048
1049 #define DC_EBLOCK_SIA 0x0002
1050 #define DC_EBLOCK_MII 0x0003
1051 #define DC_EBLOCK_SYM 0x0004
1052 #define DC_EBLOCK_RESET 0x0005
1053 #define DC_EBLOCK_PHY_SHUTDOWN 0x0006
1054
1055 struct dc_leaf_hdr {
1056  u_int16_t dc_mtype;
1057  u_int8_t dc_mcnt;
1058  u_int8_t dc_rsvd;
1059 };
1060
1062  u_int8_t dc_len;
1063  u_int8_t dc_type;
1064 };
1065
1067  struct dc_eblock_hdr dc_sia_hdr;
1068  u_int8_t dc_sia_code;
1069  u_int8_t dc_sia_mediaspec[6]; /* CSR13, CSR14, CSR15 */
1070  u_int8_t dc_sia_gpio_ctl[2];
1071  u_int8_t dc_sia_gpio_dat[2];
1072 };
1073
1074 #define DC_SIA_CODE_10BT 0x00
1075 #define DC_SIA_CODE_10B2 0x01
1076 #define DC_SIA_CODE_10B5 0x02
1077 #define DC_SIA_CODE_10BT_FDX 0x04
1078 #define DC_SIA_CODE_EXT 0x40
1079
1080 /*
1081  * Note that the first word in the gpr and reset
1082  * sequences is always a control word.
1083  */
1085  struct dc_eblock_hdr dc_mii_hdr;
1086  u_int8_t dc_mii_phynum;
1087  u_int8_t dc_gpr_len;
1088 /* u_int16_t dc_gpr_dat[n]; */
1089 /* u_int8_t dc_reset_len; */
1090 /* u_int16_t dc_reset_dat[n]; */
1091 /* There are other fields after these, but we don't
1092  * care about them since they can be determined by looking
1093  * at the PHY.
1094  */
1095 };
1096
1098  struct dc_eblock_hdr dc_sym_hdr;
1099  u_int8_t dc_sym_code;
1100  u_int8_t dc_sym_gpio_ctl[2];
1101  u_int8_t dc_sym_gpio_dat[2];
1102  u_int8_t dc_sym_cmd[2];
1103 };
1104
1105 #define DC_SYM_CODE_100BT 0x03
1106 #define DC_SYM_CODE_100BT_FDX 0x05
1107 #define DC_SYM_CODE_100T4 0x06
1108 #define DC_SYM_CODE_100FX 0x07
1109 #define DC_SYM_CODE_100FX_FDX 0x08
1110
1112  struct dc_eblock_hdr dc_reset_hdr;
1113  u_int8_t dc_reset_len;
1114 /* u_int16_t dc_reset_dat[n]; */
1115 };
1116
1117 #ifdef __alpha__
1118 #undef vtophys
1119 #define vtophys(va) alpha_XXX_dmamap((vm_offset_t)va)
1120 #endif
Definition: if_dcreg.h:447
Definition: if_dcreg.h:1055
Definition: if_dcreg.h:681
Definition: if_dcreg.h:473
Definition: if_dcreg.h:463
Definition: if_dcreg.h:483
Definition: if_dcreg.h:1097
Definition: if_dcreg.h:1021
Definition: if_dcreg.h:1061
Definition: if_dcreg.h:1084
Definition: irq.h:45
Definition: if_dcreg.h:1111
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
Definition: if_dcreg.h:452
Definition: if_dcreg.h:368
Definition: if_dcreg.h:1066
