RTEMS  5.1
idtcpu.h
1
11 /*
12  * Based upon IDT provided code with the following release:
13  *
14  * This source code has been made available to you by IDT on an AS-IS
15  * basis. Anyone receiving this source is licensed under IDT copyrights
16  * to use it in any way he or she deems fit, including copying it,
17  * modifying it, compiling it, and redistributing it either with or
18  * without modifications. No license under IDT patents or patent
19  * applications is to be implied by the copyright license.
20  *
21  * Any user of this software should understand that IDT cannot provide
22  * technical support for this software and will not be responsible for
23  * any consequences resulting from the use of this software.
24  *
25  * Any person who transfers this source code or any derivative work must
26  * include the IDT copyright notice, this paragraph, and the preceeding
27  * two paragraphs in the transferred software.
28  *
29  * COPYRIGHT IDT CORPORATION 1996
30  * LICENSED MATERIAL - PROGRAM PROPERTY OF IDT
31  */
32
33 #ifndef _RTEMS_MIPS_IDTCPU_H
34 #define _RTEMS_MIPS_IDTCPU_H
35
44 /*
45  * 950313: Ketan added Register definition for XContext reg.
46  * added define for WAIT instruction.
47  * 950421: Ketan added Register definition for Config reg (R3081)
48  */
49
50 /*
51 ** memory configuration and mapping
52 */
53 #define K0BASE 0x80000000
54 #define K0SIZE 0x20000000
55 #define K1BASE 0xa0000000
56 #define K1SIZE 0x20000000
57 #define K2BASE 0xc0000000
58 #define K2SIZE 0x20000000
59 #if __mips == 3
60 #define KSBASE 0xe0000000
61 #define KSSIZE 0x20000000
62 #endif
63
64 #define KUBASE 0
65 #define KUSIZE 0x80000000
66
67 /*
68 ** Exception Vectors
69 */
70 #if __mips == 1
71 #define UT_VEC K0BASE /* utlbmiss vector */
72 #define DB_VEC (K0BASE+0x40) /* debug vector */
73 #define E_VEC (K0BASE+0x80) /* exception vector */
74 #elif __mips == 32
75 #define T_VEC (K0BASE+0x000) /* tlbmiss vector */
76 #define X_VEC (K0BASE+0x080) /* xtlbmiss vector */
77 #define C_VEC (K0BASE+0x100) /* cache error vector */
78 #define E_VEC (K0BASE+0x180) /* exception vector */
79 #elif __mips == 3
80 #define T_VEC (K0BASE+0x000) /* tlbmiss vector */
81 #define X_VEC (K0BASE+0x080) /* xtlbmiss vector */
82 #define C_VEC (K0BASE+0x100) /* cache error vector */
83 #define E_VEC (K0BASE+0x180) /* exception vector */
84 #else
85 #error "EXCEPTION VECTORS: unknown ISA level"
86 #endif
87 #define R_VEC (K1BASE+0x1fc00000) /* reset vector */
88
89 /*
90 ** Address conversion macros
91 */
92 #ifdef CLANGUAGE
93 #define CAST(as) (as)
94 #else
95 #define CAST(as)
96 #endif
97 #define K0_TO_K1(x) (CAST(unsigned)(x)|0xA0000000) /* kseg0 to kseg1 */
98 #define K1_TO_K0(x) (CAST(unsigned)(x)&0x9FFFFFFF) /* kseg1 to kseg0 */
99 #define K0_TO_PHYS(x) (CAST(unsigned)(x)&0x1FFFFFFF) /* kseg0 to physical */
100 #define K1_TO_PHYS(x) (CAST(unsigned)(x)&0x1FFFFFFF) /* kseg1 to physical */
101 #define PHYS_TO_K0(x) (CAST(unsigned)(x)|0x80000000) /* physical to kseg0 */
102 #define PHYS_TO_K1(x) (CAST(unsigned)(x)|0xA0000000) /* physical to kseg1 */
103
104 /*
105 ** Cache size constants
106 */
107 #define MINCACHE 0x200 /* 512 For 3041. */
108 #define MAXCACHE 0x40000 /* 256*1024 256k */
109
110 #if __mips == 32
111 /* R4000 configuration register definitions */
112 #define CFG_CM 0x80000000 /* Master-Checker mode */
113 #define CFG_ECMASK 0x70000000 /* System Clock Ratio */
114 #define CFG_ECBY2 0x00000000 /* divide by 2 */
115 #define CFG_ECBY3 0x10000000 /* divide by 3 */
116 #define CFG_ECBY4 0x20000000 /* divide by 4 */
117 #define CFG_EPMASK 0x0f000000 /* Transmit data pattern */
118 #define CFG_EPD 0x00000000 /* D */
119 #define CFG_EPDDX 0x01000000 /* DDX */
120 #define CFG_EPDDXX 0x02000000 /* DDXX */
121 #define CFG_EPDXDX 0x03000000 /* DXDX */
122 #define CFG_EPDDXXX 0x04000000 /* DDXXX */
123 #define CFG_EPDDXXXX 0x05000000 /* DDXXXX */
124 #define CFG_EPDXXDXX 0x06000000 /* DXXDXX */
125 #define CFG_EPDDXXXXX 0x07000000 /* DDXXXXX */
126 #define CFG_EPDXXXDXXX 0x08000000 /* DXXXDXXX */
127 #define CFG_SBMASK 0x00c00000 /* Secondary cache block size */
128 #define CFG_SBSHIFT 22
129 #define CFG_SB4 0x00000000 /* 4 words */
130 #define CFG_SB8 0x00400000 /* 8 words */
131 #define CFG_SB16 0x00800000 /* 16 words */
132 #define CFG_SB32 0x00c00000 /* 32 words */
133 #define CFG_SS 0x00200000 /* Split secondary cache */
134 #define CFG_SW 0x00100000 /* Secondary cache port width */
135 #define CFG_EWMASK 0x000c0000 /* System port width */
136 #define CFG_EWSHIFT 18
137 #define CFG_EW64 0x00000000 /* 64 bit */
138 #define CFG_EW32 0x00010000 /* 32 bit */
139 #define CFG_SC 0x00020000 /* Secondary cache absent */
140 #define CFG_SM 0x00010000 /* Dirty Shared mode disabled */
141 #define CFG_BE 0x00008000 /* Big Endian */
142 #define CFG_EM 0x00004000 /* ECC mode enable */
143 #define CFG_EB 0x00002000 /* Block ordering */
144 #define CFG_ICMASK 0x00000e00 /* Instruction cache size */
145 #define CFG_ICSHIFT 9
146 #define CFG_DCMASK 0x000001c0 /* Data cache size */
147 #define CFG_DCSHIFT 6
148 #define CFG_IB 0x00000020 /* Instruction cache block size */
149 #define CFG_DB 0x00000010 /* Data cache block size */
150 #define CFG_CU 0x00000008 /* Update on Store Conditional */
151 #define CFG_K0MASK 0x00000007 /* KSEG0 coherency algorithm */
152
153 /*
154  * R4000 primary cache mode
155  */
156 #define CFG_C_UNCACHED 2
157 #define CFG_C_NONCOHERENT 3
158 #define CFG_C_COHERENTXCL 4
159 #define CFG_C_COHERENTXCLW 5
160 #define CFG_C_COHERENTUPD 6
161
162 /*
163  * R4000 cache operations (should be in assembler...?)
164  */
165 #define Index_Invalidate_I 0x0 /* 0 0 */
166 #define Index_Writeback_Inv_D 0x1 /* 0 1 */
167 #define Index_Invalidate_SI 0x2 /* 0 2 */
168 #define Index_Writeback_Inv_SD 0x3 /* 0 3 */
169 #define Index_Load_Tag_I 0x4 /* 1 0 */
170 #define Index_Load_Tag_D 0x5 /* 1 1 */
171 #define Index_Load_Tag_SI 0x6 /* 1 2 */
172 #define Index_Load_Tag_SD 0x7 /* 1 3 */
173 #define Index_Store_Tag_I 0x8 /* 2 0 */
174 #define Index_Store_Tag_D 0x9 /* 2 1 */
175 #define Index_Store_Tag_SI 0xA /* 2 2 */
176 #define Index_Store_Tag_SD 0xB /* 2 3 */
177 #define Create_Dirty_Exc_D 0xD /* 3 1 */
178 #define Create_Dirty_Exc_SD 0xF /* 3 3 */
179 #define Hit_Invalidate_I 0x10 /* 4 0 */
180 #define Hit_Invalidate_D 0x11 /* 4 1 */
181 #define Hit_Invalidate_SI 0x12 /* 4 2 */
182 #define Hit_Invalidate_SD 0x13 /* 4 3 */
183 #define Hit_Writeback_Inv_D 0x15 /* 5 1 */
184 #define Hit_Writeback_Inv_SD 0x17 /* 5 3 */
185 #define Fill_I 0x14 /* 5 0 */
186 #define Hit_Writeback_D 0x19 /* 6 1 */
187 #define Hit_Writeback_SD 0x1B /* 6 3 */
188 #define Hit_Writeback_I 0x18 /* 6 0 */
189 #define Hit_Set_Virtual_SI 0x1E /* 7 2 */
190 #define Hit_Set_Virtual_SD 0x1F /* 7 3 */
191
192 /* Disabled by chris -- horrible overload of common word.
193 #ifndef WAIT
194 #define WAIT .word 0x42000020
195 #endif
196 */
197 /* Disabled by joel -- horrible overload of common word.
198 #ifndef wait
199 #define wait .word 0x42000020
200 #endif wait
201 */
202
203 #endif
204
205 #if __mips == 3
206 /* R4000 configuration register definitions */
207 #define CFG_CM 0x80000000 /* Master-Checker mode */
208 #define CFG_ECMASK 0x70000000 /* System Clock Ratio */
209 #define CFG_ECBY2 0x00000000 /* divide by 2 */
210 #define CFG_ECBY3 0x10000000 /* divide by 3 */
211 #define CFG_ECBY4 0x20000000 /* divide by 4 */
212 #define CFG_EPMASK 0x0f000000 /* Transmit data pattern */
213 #define CFG_EPD 0x00000000 /* D */
214 #define CFG_EPDDX 0x01000000 /* DDX */
215 #define CFG_EPDDXX 0x02000000 /* DDXX */
216 #define CFG_EPDXDX 0x03000000 /* DXDX */
217 #define CFG_EPDDXXX 0x04000000 /* DDXXX */
218 #define CFG_EPDDXXXX 0x05000000 /* DDXXXX */
219 #define CFG_EPDXXDXX 0x06000000 /* DXXDXX */
220 #define CFG_EPDDXXXXX 0x07000000 /* DDXXXXX */
221 #define CFG_EPDXXXDXXX 0x08000000 /* DXXXDXXX */
222 #define CFG_SBMASK 0x00c00000 /* Secondary cache block size */
223 #define CFG_SBSHIFT 22
224 #define CFG_SB4 0x00000000 /* 4 words */
225 #define CFG_SB8 0x00400000 /* 8 words */
226 #define CFG_SB16 0x00800000 /* 16 words */
227 #define CFG_SB32 0x00c00000 /* 32 words */
228 #define CFG_SS 0x00200000 /* Split secondary cache */
229 #define CFG_SW 0x00100000 /* Secondary cache port width */
230 #define CFG_EWMASK 0x000c0000 /* System port width */
231 #define CFG_EWSHIFT 18
232 #define CFG_EW64 0x00000000 /* 64 bit */
233 #define CFG_EW32 0x00010000 /* 32 bit */
234 #define CFG_SC 0x00020000 /* Secondary cache absent */
235 #define CFG_SM 0x00010000 /* Dirty Shared mode disabled */
236 #define CFG_BE 0x00008000 /* Big Endian */
237 #define CFG_EM 0x00004000 /* ECC mode enable */
238 #define CFG_EB 0x00002000 /* Block ordering */
239 #define CFG_ICMASK 0x00000e00 /* Instruction cache size */
240 #define CFG_ICSHIFT 9
241 #define CFG_DCMASK 0x000001c0 /* Data cache size */
242 #define CFG_DCSHIFT 6
243 #define CFG_IB 0x00000020 /* Instruction cache block size */
244 #define CFG_DB 0x00000010 /* Data cache block size */
245 #define CFG_CU 0x00000008 /* Update on Store Conditional */
246 #define CFG_K0MASK 0x00000007 /* KSEG0 coherency algorithm */
247
248 /*
249  * R4000 primary cache mode
250  */
251 #define CFG_C_UNCACHED 2
252 #define CFG_C_NONCOHERENT 3
253 #define CFG_C_COHERENTXCL 4
254 #define CFG_C_COHERENTXCLW 5
255 #define CFG_C_COHERENTUPD 6
256
257 /*
258  * R4000 cache operations (should be in assembler...?)
259  */
260 #define Index_Invalidate_I 0x0 /* 0 0 */
261 #define Index_Writeback_Inv_D 0x1 /* 0 1 */
262 #define Index_Invalidate_SI 0x2 /* 0 2 */
263 #define Index_Writeback_Inv_SD 0x3 /* 0 3 */
264 #define Index_Load_Tag_I 0x4 /* 1 0 */
265 #define Index_Load_Tag_D 0x5 /* 1 1 */
266 #define Index_Load_Tag_SI 0x6 /* 1 2 */
267 #define Index_Load_Tag_SD 0x7 /* 1 3 */
268 #define Index_Store_Tag_I 0x8 /* 2 0 */
269 #define Index_Store_Tag_D 0x9 /* 2 1 */
270 #define Index_Store_Tag_SI 0xA /* 2 2 */
271 #define Index_Store_Tag_SD 0xB /* 2 3 */
272 #define Create_Dirty_Exc_D 0xD /* 3 1 */
273 #define Create_Dirty_Exc_SD 0xF /* 3 3 */
274 #define Hit_Invalidate_I 0x10 /* 4 0 */
275 #define Hit_Invalidate_D 0x11 /* 4 1 */
276 #define Hit_Invalidate_SI 0x12 /* 4 2 */
277 #define Hit_Invalidate_SD 0x13 /* 4 3 */
278 #define Hit_Writeback_Inv_D 0x15 /* 5 1 */
279 #define Hit_Writeback_Inv_SD 0x17 /* 5 3 */
280 #define Fill_I 0x14 /* 5 0 */
281 #define Hit_Writeback_D 0x19 /* 6 1 */
282 #define Hit_Writeback_SD 0x1B /* 6 3 */
283 #define Hit_Writeback_I 0x18 /* 6 0 */
284 #define Hit_Set_Virtual_SI 0x1E /* 7 2 */
285 #define Hit_Set_Virtual_SD 0x1F /* 7 3 */
286
287 /* Disabled by chris -- horrible overload of common word.
288 #ifndef WAIT
289 #define WAIT .word 0x42000020
290 #endif
291 */
292 /* Disabled by joel -- horrible overload of common word.
293 #ifndef wait
294 #define wait .word 0x42000020
295 #endif wait
296 */
297
298 #endif
299
300 /*
301 ** TLB resource defines
302 */
303 #if __mips == 1
304 #define N_TLB_ENTRIES 64
305 #define TLB_PGSIZE 0x1000
306 #define RANDBASE 8
307 #define TLBLO_PFNMASK 0xfffff000
308 #define TLBLO_PFNSHIFT 12
309 #define TLBLO_N 0x800 /* non-cacheable */
310 #define TLBLO_D 0x400 /* writeable */
311 #define TLBLO_V 0x200 /* valid bit */
312 #define TLBLO_G 0x100 /* global access bit */
313
314 #define TLBHI_VPNMASK 0xfffff000
315 #define TLBHI_VPNSHIFT 12
316 #define TLBHI_PIDMASK 0xfc0
317 #define TLBHI_PIDSHIFT 6
318 #define TLBHI_NPID 64
319
320 #define TLBINX_PROBE 0x80000000
321 #define TLBINX_INXMASK 0x00003f00
322 #define TLBINX_INXSHIFT 8
323
324 #define TLBRAND_RANDMASK 0x00003f00
325 #define TLBRAND_RANDSHIFT 8
326
327 #define TLBCTXT_BASEMASK 0xffe00000
328 #define TLBCTXT_BASESHIFT 21
329
330 #define TLBCTXT_VPNMASK 0x001ffffc
331 #define TLBCTXT_VPNSHIFT 2
332 #endif
333 #if __mips == 3
334 #define N_TLB_ENTRIES 48
335
336 #define TLBHI_VPN2MASK 0xffffe000
337 #define TLBHI_PIDMASK 0x000000ff
338 #define TLBHI_NPID 256
339
340 #define TLBLO_PFNMASK 0x3fffffc0
341 #define TLBLO_PFNSHIFT 6
342 #define TLBLO_D 0x00000004 /* writeable */
343 #define TLBLO_V 0x00000002 /* valid bit */
344 #define TLBLO_G 0x00000001 /* global access bit */
345 #define TLBLO_CMASK 0x00000038 /* cache algorithm mask */
346 #define TLBLO_CSHIFT 3
347
348 #define TLBLO_UNCACHED (CFG_C_UNCACHED<<TLBLO_CSHIFT)
349 #define TLBLO_NONCOHERENT (CFG_C_NONCOHERENT<<TLBLO_CSHIFT)
350 #define TLBLO_COHERENTXCL (CFG_C_COHERENTXCL<<TLBLO_CSHIFT)
351 #define TLBLO_COHERENTXCLW (CFG_C_COHERENTXCLW<<TLBLO_CSHIFT)
352 #define TLBLO_COHERENTUPD (CFG_C_COHERENTUPD<<TLBLO_CSHIFT)
353
354 #define TLBINX_PROBE 0x80000000
355 #define TLBINX_INXMASK 0x0000003f
356
357 #define TLBRAND_RANDMASK 0x0000003f
358
359 #define TLBCTXT_BASEMASK 0xff800000
360 #define TLBCTXT_BASESHIFT 23
361
362 #define TLBCTXT_VPN2MASK 0x007ffff0
363 #define TLBCTXT_VPN2SHIFT 4
364
365 #define TLBPGMASK_MASK 0x01ffe000
366 #endif
367
368 #if __mips == 32
369 #define N_TLB_ENTRIES 16
370
371 #define TLBHI_VPN2MASK 0xffffe000
372 #define TLBHI_PIDMASK 0x000000ff
373 #define TLBHI_NPID 256
374
375 #define TLBLO_PFNMASK 0x3fffffc0
376 #define TLBLO_PFNSHIFT 6
377 #define TLBLO_D 0x00000004 /* writeable */
378 #define TLBLO_V 0x00000002 /* valid bit */
379 #define TLBLO_G 0x00000001 /* global access bit */
380 #define TLBLO_CMASK 0x00000038 /* cache algorithm mask */
381 #define TLBLO_CSHIFT 3
382
383 #define TLBLO_UNCACHED (CFG_C_UNCACHED<<TLBLO_CSHIFT)
384 #define TLBLO_NONCOHERENT (CFG_C_NONCOHERENT<<TLBLO_CSHIFT)
385 #define TLBLO_COHERENTXCL (CFG_C_COHERENTXCL<<TLBLO_CSHIFT)
386 #define TLBLO_COHERENTXCLW (CFG_C_COHERENTXCLW<<TLBLO_CSHIFT)
387 #define TLBLO_COHERENTUPD (CFG_C_COHERENTUPD<<TLBLO_CSHIFT)
388
389 #define TLBINX_PROBE 0x80000000
390 #define TLBINX_INXMASK 0x0000003f
391
392 #define TLBRAND_RANDMASK 0x0000003f
393
394 #define TLBCTXT_BASEMASK 0xff800000
395 #define TLBCTXT_BASESHIFT 23
396
397 #define TLBCTXT_VPN2MASK 0x007ffff0
398 #define TLBCTXT_VPN2SHIFT 4
399
400 #define TLBPGMASK_MASK 0x01ffe000
401 #endif
402
403 #if __mips == 1
404
405
406 /* definitions for Debug and Cache Invalidate control (DCIC) register bits */
407 #define DCIC_TR 0x80000000 /* Trap enable */
408 #define DCIC_UD 0x40000000 /* User debug enable */
409 #define DCIC_KD 0x20000000 /* Kernel debug enable */
410 #define DCIC_TE 0x10000000 /* Trace enable */
411 #define DCIC_DW 0x08000000 /* Enable data breakpoints on write */
412 #define DCIC_DR 0x04000000 /* Enable data breakpoints on read */
413 #define DCIC_DAE 0x02000000 /* Enable data addresss breakpoints */
414 #define DCIC_PCE 0x01000000 /* Enable instruction breakpoints */
415 #define DCIC_DE 0x00800000 /* Debug enable */
416 #define DCIC_DL 0x00008000 /* Data cache line invalidate */
417 #define DCIC_IL 0x00004000 /* Instruction cache line invalidate */
418 #define DCIC_D 0x00002000 /* Data cache invalidate enable */
419 #define DCIC_I 0x00001000 /* Instr. cache invalidate enable */
420 #define DCIC_T 0x00000020 /* Trace, set by CPU */
421 #define DCIC_W 0x00000010 /* Write reference, set by CPU */
422 #define DCIC_R 0x00000008 /* Read reference, set by CPU */
423 #define DCIC_DA 0x00000004 /* Data address, set by CPU */
424 #define DCIC_PC 0x00000002 /* Program counter, set by CPU */
425 #define DCIC_DB 0x00000001 /* Debug, set by CPU */
426
427
428
429
430 #define SR_CUMASK 0xf0000000 /* coproc usable bits */
431 #define SR_CU3 0x80000000 /* Coprocessor 3 usable */
432 #define SR_CU2 0x40000000 /* Coprocessor 2 usable */
433 #define SR_CU1 0x20000000 /* Coprocessor 1 usable */
434 #define SR_CU0 0x10000000 /* Coprocessor 0 usable */
435
436 #define SR_BEV 0x00400000 /* use boot exception vectors */
437
438 /* Cache control bits */
439 #define SR_TS 0x00200000 /* TLB shutdown */
440 #define SR_PE 0x00100000 /* cache parity error */
441 #define SR_CM 0x00080000 /* cache miss */
442 #define SR_PZ 0x00040000 /* cache parity zero */
443 #define SR_SWC 0x00020000 /* swap cache */
444 #define SR_ISC 0x00010000 /* Isolate data cache */
445
446 /*
447 ** status register interrupt masks and bits
448 */
449
450 #define SR_IMASK 0x0000ff00 /* Interrupt mask */
451 #define SR_IMASK8 0x00000000 /* mask level 8 */
452 #define SR_IMASK7 0x00008000 /* mask level 7 */
453 #define SR_IMASK6 0x0000c000 /* mask level 6 */
454 #define SR_IMASK5 0x0000e000 /* mask level 5 */
455 #define SR_IMASK4 0x0000f000 /* mask level 4 */
456 #define SR_IMASK3 0x0000f800 /* mask level 3 */
457 #define SR_IMASK2 0x0000fc00 /* mask level 2 */
458 #define SR_IMASK1 0x0000fe00 /* mask level 1 */
459 #define SR_IMASK0 0x0000ff00 /* mask level 0 */
460
461 #define SR_IMASKSHIFT 8
462
463 #define SR_IBIT8 0x00008000 /* bit level 8 */
464 #define SR_IBIT7 0x00004000 /* bit level 7 */
465 #define SR_IBIT6 0x00002000 /* bit level 6 */
466 #define SR_IBIT5 0x00001000 /* bit level 5 */
467 #define SR_IBIT4 0x00000800 /* bit level 4 */
468 #define SR_IBIT3 0x00000400 /* bit level 3 */
469 #define SR_IBIT2 0x00000200 /* bit level 2 */
470 #define SR_IBIT1 0x00000100 /* bit level 1 */
471
472 #define SR_KUO 0x00000020 /* old kernel/user, 0 => k, 1 => u */
473 #define SR_IEO 0x00000010 /* old interrupt enable, 1 => enable */
474 #define SR_KUP 0x00000008 /* prev kernel/user, 0 => k, 1 => u */
475 #define SR_IEP 0x00000004 /* prev interrupt enable, 1 => enable */
476 #define SR_KUC 0x00000002 /* cur kernel/user, 0 => k, 1 => u */
477 #define SR_IEC 0x00000001 /* cur interrupt enable, 1 => enable */
478 #endif
479
480 #if __mips == 3
481 #define SR_CUMASK 0xf0000000 /* coproc usable bits */
482 #define SR_CU3 0x80000000 /* Coprocessor 3 usable */
483 #define SR_CU2 0x40000000 /* Coprocessor 2 usable */
484 #define SR_CU1 0x20000000 /* Coprocessor 1 usable */
485 #define SR_CU0 0x10000000 /* Coprocessor 0 usable */
486
487 #define SR_RP 0x08000000 /* Reduced power operation */
488 #define SR_FR 0x04000000 /* Additional floating point registers */
489 #define SR_RE 0x02000000 /* Reverse endian in user mode */
490
491 #define SR_BEV 0x00400000 /* Use boot exception vectors */
492 #define SR_TS 0x00200000 /* TLB shutdown */
493 #define SR_SR 0x00100000 /* Soft reset */
494 #define SR_CH 0x00040000 /* Cache hit */
495 #define SR_CE 0x00020000 /* Use cache ECC */
496 #define SR_DE 0x00010000 /* Disable cache exceptions */
497
498 /*
499 ** status register interrupt masks and bits
500 */
501
502 #define SR_IMASK 0x0000ff00 /* Interrupt mask */
503 #define SR_IMASK8 0x00000000 /* mask level 8 */
504 #define SR_IMASK7 0x00008000 /* mask level 7 */
505 #define SR_IMASK6 0x0000c000 /* mask level 6 */
506 #define SR_IMASK5 0x0000e000 /* mask level 5 */
507 #define SR_IMASK4 0x0000f000 /* mask level 4 */
508 #define SR_IMASK3 0x0000f800 /* mask level 3 */
509 #define SR_IMASK2 0x0000fc00 /* mask level 2 */
510 #define SR_IMASK1 0x0000fe00 /* mask level 1 */
511 #define SR_IMASK0 0x0000ff00 /* mask level 0 */
512
513 #define SR_IMASKSHIFT 8
514
515 #define SR_IBIT8 0x00008000 /* bit level 8 */
516 #define SR_IBIT7 0x00004000 /* bit level 7 */
517 #define SR_IBIT6 0x00002000 /* bit level 6 */
518 #define SR_IBIT5 0x00001000 /* bit level 5 */
519 #define SR_IBIT4 0x00000800 /* bit level 4 */
520 #define SR_IBIT3 0x00000400 /* bit level 3 */
521 #define SR_IBIT2 0x00000200 /* bit level 2 */
522 #define SR_IBIT1 0x00000100 /* bit level 1 */
523
524 #define SR_KSMASK 0x00000018 /* Kernel mode mask */
525 #define SR_KSUSER 0x00000010 /* User mode */
526 #define SR_KSSUPER 0x00000008 /* Supervisor mode */
527 #define SR_KSKERNEL 0x00000000 /* Kernel mode */
528 #define SR_ERL 0x00000004 /* Error level */
529 #define SR_EXL 0x00000002 /* Exception level */
530 #define SR_IE 0x00000001 /* Interrupts enabled */
531 #endif
532
533 #if __mips == 32
534 #define SR_CUMASK 0xf0000000 /* coproc usable bits */
535 #define SR_CU3 0x80000000 /* Coprocessor 3 usable */
536 #define SR_CU2 0x40000000 /* Coprocessor 2 usable */
537 #define SR_CU1 0x20000000 /* Coprocessor 1 usable */
538 #define SR_CU0 0x10000000 /* Coprocessor 0 usable */
539
540 #define SR_RP 0x08000000 /* Reduced power operation */
541 #define SR_FR 0x04000000 /* Additional floating point registers */
542 #define SR_RE 0x02000000 /* Reverse endian in user mode */
543
544 #define SR_BEV 0x00400000 /* Use boot exception vectors */
545 #define SR_TS 0x00200000 /* TLB shutdown */
546 #define SR_SR 0x00100000 /* Soft reset */
547 #define SR_CH 0x00040000 /* Cache hit */
548 #define SR_CE 0x00020000 /* Use cache ECC */
549 #define SR_DE 0x00010000 /* Disable cache exceptions */
550
551 /*
552 ** status register interrupt masks and bits
553 */
554
555 #define SR_IMASK 0x0000ff00 /* Interrupt mask */
556 #define SR_IMASK8 0x00000000 /* mask level 8 */
557 #define SR_IMASK7 0x00008000 /* mask level 7 */
558 #define SR_IMASK6 0x0000c000 /* mask level 6 */
559 #define SR_IMASK5 0x0000e000 /* mask level 5 */
560 #define SR_IMASK4 0x0000f000 /* mask level 4 */
561 #define SR_IMASK3 0x0000f800 /* mask level 3 */
562 #define SR_IMASK2 0x0000fc00 /* mask level 2 */
563 #define SR_IMASK1 0x0000fe00 /* mask level 1 */
564 #define SR_IMASK0 0x0000ff00 /* mask level 0 */
565
566 #define SR_IMASKSHIFT 8
567
568 #define SR_IBIT8 0x00008000 /* bit level 8 */
569 #define SR_IBIT7 0x00004000 /* bit level 7 */
570 #define SR_IBIT6 0x00002000 /* bit level 6 */
571 #define SR_IBIT5 0x00001000 /* bit level 5 */
572 #define SR_IBIT4 0x00000800 /* bit level 4 */
573 #define SR_IBIT3 0x00000400 /* bit level 3 */
574 #define SR_IBIT2 0x00000200 /* bit level 2 */
575 #define SR_IBIT1 0x00000100 /* bit level 1 */
576
577 #define SR_KSMASK 0x00000018 /* Kernel mode mask */
578 #define SR_KSUSER 0x00000010 /* User mode */
579 #define SR_KSSUPER 0x00000008 /* Supervisor mode */
580 #define SR_KSKERNEL 0x00000000 /* Kernel mode */
581 #define SR_ERL 0x00000004 /* Error level */
582 #define SR_EXL 0x00000002 /* Exception level */
583 #define SR_IE 0x00000001 /* Interrupts enabled */
584 #endif
585
586 /*
587  * Cause Register
588  */
589 #define CAUSE_BD 0x80000000 /* Branch delay slot */
590 #define CAUSE_BT 0x40000000 /* Branch Taken */
591 #define CAUSE_CEMASK 0x30000000 /* coprocessor error */
592 #define CAUSE_CESHIFT 28
593
594
595 #define CAUSE_IPMASK 0x0000FF00 /* Pending interrupt mask */
596 #define CAUSE_IPSHIFT 8
597
598 #define CAUSE_EXCMASK 0x0000003C /* Cause code bits */
599 #define CAUSE_EXCSHIFT 2
600
601 #ifndef XDS
602 /*
603 ** Coprocessor 0 registers
604 */
605 #define C0_INX $0 /* tlb index */
606 #define C0_RAND $1 /* tlb random */
607 #if __mips == 1
608 #define C0_TLBLO $2 /* tlb entry low */
609 #endif
610 #if __mips == 3
611 #define C0_TLBLO0 $2 /* tlb entry low 0 */
612 #define C0_TLBLO1 $3 /* tlb entry low 1 */
613 #endif
614
615 #if __mips == 32
616 #define C0_TLBLO0 $2 /* tlb entry low 0 */
617 #define C0_TLBLO1 $3 /* tlb entry low 1 */
618 #endif
619
620
621 #define C0_CTXT $4 /* tlb context */
622
623 #if __mips == 3
624 #define C0_PAGEMASK $5 /* tlb page mask */
625 #define C0_WIRED $6 /* number of wired tlb entries */
626 #endif
627
628 #if __mips == 32
629 #define C0_PAGEMASK $5 /* tlb page mask */
630 #define C0_WIRED $6 /* number of wired tlb entries */
631 #endif
632
633 #if __mips == 1
634 #define C0_TAR $6
635 #endif
636
637 #define C0_BADVADDR $8 /* bad virtual address */
638
639 #if __mips == 3
640 #define C0_COUNT $9 /* cycle count */
641 #endif
642 #if __mips == 32
643 #define C0_COUNT $9 /* cycle count */
644 #endif
645
646 #define C0_TLBHI $10 /* tlb entry hi */
647
648 #if __mips == 3
649 #define C0_COMPARE $11 /* cyccle count comparator */
650 #endif
651
652 #if __mips == 32
653 #define C0_COMPARE $11 /* cyccle count comparator */
654 #endif
655
656 #define C0_SR $12 /* status register */
657 #define C0_CAUSE $13 /* exception cause */
658 #define C0_EPC $14 /* exception pc */
659 #define C0_PRID $15 /* revision identifier */
660
661 #if __mips == 1
662 #define C0_CONFIG $3 /* configuration register R3081*/
663 #endif
664
665 #if __mips == 3
666 #define C0_CONFIG $16 /* configuration register */
667 #define C0_LLADDR $17 /* linked load address */
668 #define C0_WATCHLO $18 /* watchpoint trap register */
669 #define C0_WATCHHI $19 /* watchpoint trap register */
670 #define C0_XCTXT $20 /* extended tlb context */
671 #define C0_ECC $26 /* secondary cache ECC control */
672 #define C0_CACHEERR $27 /* cache error status */
673 #define C0_TAGLO $28 /* cache tag lo */
674 #define C0_TAGHI $29 /* cache tag hi */
675 #define C0_ERRPC $30 /* cache error pc */
676 #endif
677
678 #if __mips == 32
679 #define C0_CONFIG $16 /* configuration register */
680 #define C0_LLADDR $17 /* linked load address */
681 #define C0_WATCHLO $18 /* watchpoint trap register */
682 #define C0_WATCHHI $19 /* watchpoint trap register */
683 #define C0_XCTXT $20 /* extended tlb context */
684 #define C0_ECC $26 /* secondary cache ECC control */
685 #define C0_CACHEERR $27 /* cache error status */
686 #define C0_TAGLO $28 /* cache tag lo */
687 #define C0_TAGHI $29 /* cache tag hi */
688 #define C0_ERRPC $30 /* cache error pc */
689 #endif
690
691
692 #define C1_REVISION $0
693 #define C1_STATUS $31
694
695 #endif /* XDS */
696
697 #ifdef R4650
698 #define IWATCH $18
699 #define DWATCH $19
700 #define IBASE $0
701 #define IBOUND $1
702 #define DBASE $2
703 #define DBOUND $3
704 #define CALG $17
705 #endif
706
708 #endif /* _RTEMS_MIPS_IDTCPU_H */
