RTEMS  5.1
i8259.h
1
7 /* irq.h
8  *
9  * This include file describe the data structure and the functions implemented
10  * by RTEMS to control the i8259 chip.
11  *
12  * Copyright (C) 1999 valette@crf.canon.fr
13  *
14  * This code is heavilly inspired by the public specification of STREAM V2
15  * that can be found at :
16  *
17  * <http://www.chorus.com/Documentation/index.html> by following
18  * the STREAM API Specification Document link.
19  *
20  * The license and distribution terms for this file may be
21  * found in the file LICENSE in this distribution or at
22  * http://www.rtems.org/license/LICENSE.
23  */
24
25 #ifndef I8259_H
26 #define I8259_H
27
40 #if 1
41 #define ISA8259_M_ELCR 0x4d0
42 #define ISA8259_S_ELCR 0x4d1
43 #endif
44
45 #define ELCRS_INT15_LVL 0x80
46 #define ELCRS_INT14_LVL 0x40
47 #define ELCRS_INT13_LVL 0x20
48 #define ELCRS_INT12_LVL 0x10
49 #define ELCRS_INT11_LVL 0x08
50 #define ELCRS_INT10_LVL 0x04
51 #define ELCRS_INT9_LVL 0x02
52 #define ELCRS_INT8_LVL 0x01
53 #define ELCRM_INT7_LVL 0x80
54 #define ELCRM_INT6_LVL 0x40
55 #define ELCRM_INT5_LVL 0x20
56 #define ELCRM_INT4_LVL 0x10
57 #define ELCRM_INT3_LVL 0x8
58 #define ELCRM_INT2_LVL 0x4
59 #define ELCRM_INT1_LVL 0x2
60 #define ELCRM_INT0_LVL 0x1
61
69 #define PIC_MASTER_COMMAND_IO_PORT 0x20
70 #define PIC_SLAVE_COMMAND_IO_PORT 0xa0
71 #define PIC_MASTER_IMR_IO_PORT 0x21
72 #define PIC_SLAVE_IMR_IO_PORT 0xa1
73
74
81 #define PIC_EOSI 0x60
82 #define SLAVE_PIC_EOSI 0x62
83 #define PIC_EOI 0x20
84
85
87 #ifndef ASM
88
89 #ifdef __cplusplus
90 extern "C" {
91 #endif
92
93 /*
94  * rtems_irq_number Definitions
95  */
96 #if 0
97
103 #define BSP_ISA_IRQ_NUMBER (16)
104 #define BSP_ISA_IRQ_LOWEST_OFFSET (0)
105 #define BSP_ISA_IRQ_MAX_OFFSET (BSP_ISA_IRQ_LOWEST_OFFSET + BSP_ISA_IRQ_NUMBER - 1)
106
109 #ifndef qemu
110 #define BSP_PCI_IRQ_NUMBER (16)
111 #else
112 #define BSP_PCI_IRQ_NUMBER (0)
113 #endif
114 #define BSP_PCI_IRQ_LOWEST_OFFSET (BSP_ISA_IRQ_NUMBER)
115 #define BSP_PCI_IRQ_MAX_OFFSET (BSP_PCI_IRQ_LOWEST_OFFSET + BSP_PCI_IRQ_NUMBER - 1)
116
117 /*
118  * PowerPC exceptions handled as interrupt where an RTEMS managed interrupt
119  * handler might be connected
120  */
121 #define BSP_PROCESSOR_IRQ_NUMBER (1)
122 #define BSP_PROCESSOR_IRQ_LOWEST_OFFSET (BSP_PCI_IRQ_MAX_OFFSET + 1)
123 #define BSP_PROCESSOR_IRQ_MAX_OFFSET (BSP_PROCESSOR_IRQ_LOWEST_OFFSET + BSP_PROCESSOR_IRQ_NUMBER - 1)
124 /* Misc vectors for OPENPIC irqs (IPI, timers)
125  */
126 #ifndef qemu
127 #define BSP_MISC_IRQ_NUMBER (8)
128 #else
129 #define BSP_MISC_IRQ_NUMBER (0)
130 #endif
131
132 #define BSP_MISC_IRQ_LOWEST_OFFSET (BSP_PROCESSOR_IRQ_MAX_OFFSET + 1)
133 #define BSP_MISC_IRQ_MAX_OFFSET (BSP_MISC_IRQ_LOWEST_OFFSET + BSP_MISC_IRQ_NUMBER - 1)
134
140 #define BSP_IRQ_NUMBER (BSP_MISC_IRQ_MAX_OFFSET + 1)
141 #define BSP_LOWEST_OFFSET (BSP_ISA_IRQ_LOWEST_OFFSET)
142 #define BSP_MAX_OFFSET (BSP_MISC_IRQ_MAX_OFFSET)
143
151 #define BSP_ISA_PERIODIC_TIMER (0)
152 #define BSP_ISA_KEYBOARD (1)
153 #define BSP_ISA_UART_COM2_IRQ (3)
154 #define BSP_ISA_UART_COM1_IRQ (4)
155 #define BSP_ISA_RT_TIMER1 (8)
156 #define BSP_ISA_RT_TIMER3 (10)
157
165 #define BSP_PCI_IRQ0 (BSP_PCI_IRQ_LOWEST_OFFSET)
166 #if BSP_PCI_IRQ_NUMBER > 0
167 #define BSP_PCI_ISA_BRIDGE_IRQ (BSP_PCI_IRQ0)
168 #endif
169
172 #if defined(mvme2100)
173 #define BSP_DEC21143_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 1)
174 #define BSP_PMC_PCMIP_TYPE1_SLOT0_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 2)
175 #define BSP_PCMIP_TYPE1_SLOT1_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 3)
176 #define BSP_PCMIP_TYPE2_SLOT0_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 4)
177 #define BSP_PCMIP_TYPE2_SLOT1_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 5)
178 #define BSP_PCI_INTA_UNIVERSE_LINT0_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 7)
179 #define BSP_PCI_INTB_UNIVERSE_LINT1_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 8)
180 #define BSP_PCI_INTC_UNIVERSE_LINT2_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 9)
181 #define BSP_PCI_INTD_UNIVERSE_LINT3_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 10)
182 #define BSP_UART_COM1_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 13)
183 #define BSP_FRONT_PANEL_ABORT_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 14)
184 #define BSP_RTC_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 15)
185 #else
186 #define BSP_UART_COM1_IRQ BSP_ISA_UART_COM1_IRQ
187 #define BSP_UART_COM2_IRQ BSP_ISA_UART_COM2_IRQ
188 #endif
189
193 #define BSP_DECREMENTER (BSP_PROCESSOR_IRQ_LOWEST_OFFSET)
194 #endif
195
201 typedef unsigned short rtems_i8259_masks;
202 extern volatile rtems_i8259_masks i8259s_cache;
203
206 /*-------------------------------------------------------------------------+
207 | Function Prototypes.
208 +--------------------------------------------------------------------------*/
209 /*
210  * ------------------------ Intel 8259 (or emulation) Mngt Routines -------
211  */
212
218 void BSP_i8259s_init(void);
219
230 int BSP_irq_disable_at_i8259s (const rtems_irq_number irqLine);
231
238 int BSP_irq_enable_at_i8259s (const rtems_irq_number irqLine);
239
248 int BSP_irq_ack_at_i8259s (const rtems_irq_number irqLine);
249
253 int BSP_irq_enabled_at_i8259s (const rtems_irq_number irqLine);
254
255 int BSP_i8259s_int_process(void);
256
257 extern void BSP_rtems_irq_mng_init(unsigned cpuId);
258 extern void BSP_i8259s_init(void);
259
264 #ifdef __cplusplus
265 };
266 #endif
267
268 #endif
269 #endif
Type definition for RTEMS managed interrupts.
Definition: irq.h:88
int BSP_irq_enable_at_i8259s(const rtems_irq_number irqLine)
function to enable a particular irq at 8259 level.
Definition: i8259.c:91
int BSP_irq_enabled_at_i8259s(const rtems_irq_number irqLine)
function to check if a particular irq is enabled at 8259 level.
Definition: i8259.c:125
int BSP_irq_ack_at_i8259s(const rtems_irq_number irqLine)
function to acknowledge a particular irq at 8259 level.
Definition: i8259.c:143
int BSP_irq_disable_at_i8259s(const rtems_irq_number irqLine)
function to disable a particular irq at 8259 level.
Definition: i8259.c:49
