RTEMS  5.1
i82586var.h
1 /* $NetBSD: i82586var.h,v 1.15 2001/01/22 22:28:45 bjh21 Exp $ */
2
3 /*-
4  * Copyright (c) 1998 The NetBSD Foundation, Inc.
5  * All rights reserved.
6  *
7  * This code is derived from software contributed to The NetBSD Foundation
8  * by Paul Kranenburg and Charles M. Hannum.
9  *
10  * Redistribution and use in source and binary forms, with or without
11  * modification, are permitted provided that the following conditions
12  * are met:
13  * 1. Redistributions of source code must retain the above copyright
14  * notice, this list of conditions and the following disclaimer.
15  * 2. Redistributions in binary form must reproduce the above copyright
16  * notice, this list of conditions and the following disclaimer in the
17  * documentation and/or other materials provided with the distribution.
18  * 3. All advertising materials mentioning features or use of this software
19  * must display the following acknowledgement:
20  * This product includes software developed by the NetBSD
21  * Foundation, Inc. and its contributors.
22  * 4. Neither the name of The NetBSD Foundation nor the names of its
23  * contributors may be used to endorse or promote products derived
24  * from this software without specific prior written permission.
25  *
26  * THIS SOFTWARE IS PROVIDED BY THE NETBSD FOUNDATION, INC. AND CONTRIBUTORS
27  * ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
28  * TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
29  * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE FOUNDATION OR CONTRIBUTORS
30  * BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
31  * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
32  * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
33  * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
34  * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
35  * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
36  * POSSIBILITY OF SUCH DAMAGE.
37  */
38
39 /*-
40  * Copyright (c) 1992, 1993, University of Vermont and State
41  * Agricultural College.
42  * Copyright (c) 1992, 1993, Garrett A. Wollman.
43  *
44  * Portions:
45  * Copyright (c) 1994, 1995, Rafal K. Boni
46  * Copyright (c) 1990, 1991, William F. Jolitz
47  * Copyright (c) 1990, The Regents of the University of California
48  *
49  * All rights reserved.
50  *
51  * Redistribution and use in source and binary forms, with or without
52  * modification, are permitted provided that the following conditions
53  * are met:
54  * 1. Redistributions of source code must retain the above copyright
55  * notice, this list of conditions and the following disclaimer.
56  * 2. Redistributions in binary form must reproduce the above copyright
57  * notice, this list of conditions and the following disclaimer in the
58  * documentation and/or other materials provided with the distribution.
59  * 3. All advertising materials mentioning features or use of this software
60  * must display the following acknowledgement:
61  * This product includes software developed by the University of Vermont
62  * and State Agricultural College and Garrett A. Wollman, by William F.
63  * Jolitz, and by the University of California, Berkeley, Lawrence
64  * Berkeley Laboratory, and its contributors.
65  * 4. Neither the names of the Universities nor the names of the authors
66  * may be used to endorse or promote products derived from this software
67  * without specific prior written permission.
68  *
69  * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
70  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
71  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
72  * ARE DISCLAIMED. IN NO EVENT SHALL THE UNIVERSITY OR AUTHORS BE LIABLE
73  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
74  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
75  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
76  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
77  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
78  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
79  * SUCH DAMAGE.
80  */
81
82 /*
83  * Intel 82586 Ethernet chip
84  * Register, bit, and structure definitions.
85  *
86  * Original StarLAN driver written by Garrett Wollman with reference to the
87  * Clarkson Packet Driver code for this chip written by Russ Nelson and others.
88  *
89  * BPF support code taken from hpdev/if_le.c, supplied with tcpdump.
90  *
91  * 3C507 support is loosely based on code donated to NetBSD by Rafal Boni.
92  *
93  * Majorly cleaned up and 3C507 code merged by Charles Hannum.
94  *
95  * Converted to SUN ie driver by Charles D. Cranor,
96  * October 1994, January 1995.
97  * This sun version based on i386 version 1.30.
98  */
99
100 #ifndef I82586_DEBUG
101 #define I82586_DEBUG 0
102 #endif
103
104 /* Debug elements */
105 #define IED_RINT 0x01
106 #define IED_TINT 0x02
107 #define IED_RNR 0x04
108 #define IED_CNA 0x08
109 #define IED_READFRAME 0x10
110 #define IED_ENQ 0x20
111 #define IED_XMIT 0x40
112 #define IED_ALL 0x7f
113
114 #define B_PER_F 3 /* recv buffers per frame */
115 #define IE_RBUF_SIZE 256 /* size of each receive buffer;
116  MUST BE POWER OF TWO */
117 #define NTXBUF 2 /* number of transmit commands */
118 #define IE_TBUF_SIZE ETHER_MAX_LEN /* length of transmit buffer */
119
120 #define IE_MAXMCAST (IE_TBUF_SIZE/6)/* must fit in transmit buffer */
121
122
123 #define INTR_ENTER 0 /* intr hook called on ISR entry */
124 #define INTR_EXIT 1 /* intr hook called on ISR exit */
125 #define INTR_LOOP 2 /* intr hook called on ISR loop */
126 #define INTR_ACK 3 /* intr hook called on ie_ack */
127
128 #define CHIP_PROBE 0 /* reset called from chip probe */
129 #define CARD_RESET 1 /* reset called from card reset */
130
131 #if I82586_DEBUG
132 #define I82586_INTS_REQ 0
133 #define I82586_INTS_IN 1
134 #define I82586_INTS_LOOPS 2
135 #define I82586_INTS_OUT 3
136 #define I82586_RX_INT 4
137 #define I82586_RX_DROP 5
138 #define I82586_RX_ERR 6
139 #define I82586_RX_OK 7
140 #define I82586_RX_START 8
141 #define I82586_START_TX 9
142 #define I82586_TX_START 10
143 #define I82586_TX_INT 11
144 #define I82586_TX_REQ 12
145 #define I82586_TX_EVT 13
146 #define I82586_TX_EMIT 14
147 #define I82586_TX_BAD 15
148 #define I82586_TX_ACTIVE 16
149 #define I82586_TRACE_CNT 17
150
151 #define I82586_TRACE_FLOW (10000)
152 #endif
153
154 /*
155  * Ethernet status, per interface.
156  *
157  * The chip uses two types of pointers: 16 bit and 24 bit
158  * 24 bit pointers cover the board's memory.
159  * 16 bit pointers are offsets from the ISCP's `ie_base'
160  *
161  * The board's memory is represented by the bus handle `bh'. The MI
162  * i82586 driver deals exclusively with offsets relative to the
163  * board memory bus handle. The `ie_softc' fields below that are marked
164  * `MD' are in the domain of the front-end driver; they opaque to the
165  * MI driver part.
166  *
167  * The front-end is required to manage the SCP and ISCP structures. i.e.
168  * allocate room for them on the board's memory, and arrange to point the
169  * chip at the SCB stucture, the offset of which is passed to the MI
170  * driver in `sc_scb'.
171  *
172  * The following functions provide the glue necessary to deal with
173  * host and bus idiosyncracies:
174  *
175  * hwreset - board reset
176  * hwinit - board initialization
177  * chan_attn - get chip to look at prepared commands
178  * intrhook - board dependent interrupt processing
179  *
180  * All of the following shared-memory access function use an offset
181  * relative to the bus handle to indicate the shared memory location.
182  * The bus_{read/write}N function take or return offset into the
183  * shared memory in the host's byte-order.
184  *
185  * memcopyin - copy device memory: board to KVA
186  * memcopyout - copy device memory: KVA to board
187  * bus_read16 - read a 16-bit i82586 pointer
188  `offset' argument will be 16-bit aligned
189  * bus_write16 - write a 16-bit i82586 pointer
190  `offset' argument will be 16-bit aligned
191  * bus_write24 - write a 24-bit i82586 pointer
192  `offset' argument will be 32-bit aligned
193  * bus_barrier - perform a bus barrier operation, forcing
194  all outstanding reads/writes to complete
195  *
196  */
197
198 struct ie_softc {
199  struct arpcom arpcom;
200
201  /*
202  * For RTEMS we run the tx and rx handlers under a task due to the
203  * network semaphore stuff.
204  */
205
206  rtems_id intr_task;
207  rtems_id tx_task;
208
209  void *sc_iobase; /* (MD) KVA of base of 24 bit addr space */
210  void *sc_maddr; /* (MD) KVA of base of chip's RAM
211  (16bit addr space) */
212  u_int sc_msize; /* (MD) how much RAM we have/use */
213
214  /* Bus glue */
215  void (*hwreset) (struct ie_softc *, int);
216  void (*hwinit) (struct ie_softc *);
217  void (*chan_attn) (struct ie_softc *, int);
218  int (*intrhook) (struct ie_softc *, int where);
219
220  void (*memcopyin) (struct ie_softc *, void *, int, size_t);
221  void (*memcopyout) (struct ie_softc *, const void *,
222  int, size_t);
223  u_int16_t (*ie_bus_read16) (struct ie_softc *, int offset);
224  void (*ie_bus_write16) (struct ie_softc *, int offset,
225  u_int16_t value);
226  void (*ie_bus_write24) (struct ie_softc *, int offset,
227  int addr);
228  void (*ie_bus_barrier) (struct ie_softc *, int offset,
229  int length, int flags);
230
231  /* Media management */
232  int (*sc_mediachange) (struct ie_softc *);
233  /* card dependent media change */
234  void (*sc_mediastatus) (struct ie_softc *, struct ifmediareq *);
235  /* card dependent media status */
236
237  /*
238  * Offsets (relative to bus handle) of the i82586 SYSTEM structures.
239  */
240  int scp; /* Offset to the SCP (set by front-end) */
241  int iscp; /* Offset to the ISCP (set by front-end) */
242  int scb; /* Offset to SCB (set by front-end) */
243
244  /*
245  * Offset and size of a block of board memory where the buffers
246  * are to be allocated from (initialized by front-end).
247  */
248  int buf_area; /* Start of descriptors and buffers */
249  int buf_area_sz; /* Size of above */
250
251  /*
252  * The buffers & descriptors (recv and xmit)
253  */
254  int rframes; /* Offset to `nrxbuf' frame descriptors */
255  int rbds; /* Offset to `nrxbuf' buffer descriptors */
256  int rbufs; /* Offset to `nrxbuf' receive buffers */
257 #define IE_RBUF_ADDR(sc, i) (sc->rbufs + ((i) * IE_RBUF_SIZE))
258  int rfhead, rftail;
259  int rbhead, rbtail;
260  int nframes; /* number of frames in use */
261  int nrxbuf; /* number of recv buffs in use */
262  int rnr_expect; /* XXX - expect a RCVR not ready interrupt */
263
264  int nop_cmds; /* Offset to NTXBUF no-op commands */
265  int xmit_cmds; /* Offset to NTXBUF transmit commands */
266  int xbds; /* Offset to NTXBUF buffer descriptors */
267  int xbufs; /* Offset to NTXBUF transmit buffers */
268 #define IE_XBUF_ADDR(sc, i) (sc->xbufs + ((i) * IE_TBUF_SIZE))
269
270  int xchead, xctail;
271  int xmit_busy;
272  int do_xmitnopchain; /* Controls use of xmit NOP chains */
273  int xmit_req;
274
275  /* Multicast addresses */
276  char *mcast_addrs; /* Current MC filter addresses */
277  int mcast_addrs_size; /* Current size of MC buffer */
278  int mcast_count; /* Current # of addrs in buffer */
279  int want_mcsetup; /* run mcsetup at next opportunity */
280
281  int promisc; /* are we in promisc mode? */
282  int async_cmd_inprogress; /* we didn't wait for 586 to accept
283  a command */
284
285 #if I82586_DEBUG
286 #define I82586_TRACE(s, e, d) \
287 do { rtems_interrupt_level level; rtems_interrupt_disable (level); \
288  (s)->trace_flow[(s)->trace_flow_in++] = (e); \
289  (s)->trace_flow[(s)->trace_flow_in++] = (unsigned int)(d); \
290  if ((s)->trace_flow_in >= I82586_TRACE_FLOW) { \
291  (s)->trace_flow_in = 0; \
292  (s)->trace_flow_wrap = 1; \
293  } \
294  rtems_interrupt_enable (level); \
295  } while (0)
296
297  int sc_debug;
298  unsigned int trace_flow[I82586_TRACE_FLOW * 2];
299  unsigned int trace_flow_wrap;
300 #endif
301  unsigned int trace_flow_in;
302 };
303
304 /* Exported functions */
305 rtems_isr i82586_intr (rtems_vector_number , void *);
306 int i82586_proberam (struct ie_softc *);
307 int i82586_attach (struct rtems_bsdnet_ifconfig *config, int attaching);
308
309 /* Shortcut macros to optional (driver uses default if unspecified) callbacks */
310 #define xIE_BUS_BARRIER(sc, offset, length, flags) \
311 do { \
312  if ((sc)->ie_bus_barrier) \
313  ((sc)->ie_bus_barrier)((sc), (offset), (length), (flags));\
314  else \
315  bus_space_barrier((sc)->bt, (sc)->bh, (offset), (length), \
316  (flags)); \
317 } while (0)
318
319 #define IE_BUS_BARRIER(sc, offset, length, flags)
Definition: deflate.c:115
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
ISR_Handler rtems_isr
Return type for interrupt handler.
Definition: intr.h:52
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
Definition: i82586var.h:198
