RTEMS  5.1
i82586reg.h
1 /* $NetBSD: i82586reg.h,v 1.7 1998/02/28 01:07:45 pk Exp $ */
2
3 /*-
4  * Copyright (c) 1998 The NetBSD Foundation, Inc.
5  * All rights reserved.
6  *
7  * This code is derived from software contributed to The NetBSD Foundation
8  * by Paul Kranenburg.
9  *
10  * Redistribution and use in source and binary forms, with or without
11  * modification, are permitted provided that the following conditions
12  * are met:
13  * 1. Redistributions of source code must retain the above copyright
14  * notice, this list of conditions and the following disclaimer.
15  * 2. Redistributions in binary form must reproduce the above copyright
16  * notice, this list of conditions and the following disclaimer in the
17  * documentation and/or other materials provided with the distribution.
18  * 3. All advertising materials mentioning features or use of this software
19  * must display the following acknowledgement:
20  * This product includes software developed by the NetBSD
21  * Foundation, Inc. and its contributors.
22  * 4. Neither the name of The NetBSD Foundation nor the names of its
23  * contributors may be used to endorse or promote products derived
24  * from this software without specific prior written permission.
25  *
26  * THIS SOFTWARE IS PROVIDED BY THE NETBSD FOUNDATION, INC. AND CONTRIBUTORS
27  * ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
28  * TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
29  * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE FOUNDATION OR CONTRIBUTORS
30  * BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
31  * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
32  * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
33  * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
34  * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
35  * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
36  * POSSIBILITY OF SUCH DAMAGE.
37  */
38
39 /*-
40  * Copyright (c) 1992, University of Vermont and State Agricultural College.
41  * Copyright (c) 1992, Garrett A. Wollman.
42  * All rights reserved.
43  *
44  * Redistribution and use in source and binary forms, with or without
45  * modification, are permitted provided that the following conditions
46  * are met:
47  * 1. Redistributions of source code must retain the above copyright
48  * notice, this list of conditions and the following disclaimer.
49  * 2. Redistributions in binary form must reproduce the above copyright
50  * notice, this list of conditions and the following disclaimer in the
51  * documentation and/or other materials provided with the distribution.
52  * 3. All advertising materials mentioning features or use of this software
53  * must display the following acknowledgement:
54  * This product includes software developed by the University of
55  * Vermont and State Agricultural College and Garrett A. Wollman.
56  * 4. Neither the name of the University nor the name of the author
57  * may be used to endorse or promote products derived from this software
58  * without specific prior written permission.
59  *
60  * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
61  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
62  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
63  * ARE DISCLAIMED. IN NO EVENT SHALL THE UNIVERSITY OR AUTHOR BE LIABLE
64  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
65  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
66  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
67  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
68  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
69  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
70  * SUCH DAMAGE.
71  */
72
73 /*
74  * Intel 82586 Ethernet chip
75  * Register, bit, and structure definitions.
76  *
77  * Written by GAW with reference to the Clarkson Packet Driver code for this
78  * chip written by Russ Nelson and others.
79  */
80
81 /*
82  * NOTE, the structure definitions in here are for reference only.
83  * We use integer offsets exclusively to access the i82586 data structures.
84  */
85
86
87 #if 0
88 /*
89  * This is the master configuration block.
90  * It tells the hardware where all the rest of the stuff is.
91  */
92 struct __ie_sys_conf_ptr {
93  u_int16_t mbz; /* must be zero */
94  u_int8_t ie_bus_use; /* true if 8-bit only */
95  u_int8_t mbz2[5]; /* must be zero */
96  u_int32_t ie_iscp_ptr; /* 24-bit physaddr of ISCP */
97 };
98 #endif
99 #define IE_SCP_SZ 12
100 #define IE_SCP_BUS_USE(base) ((base) + 2)
101 #define IE_SCP_ISCP(base) ((base) + 8)
102
103 /*
104  * Note that this is wired in hardware; the SCP is always located here, no
105  * matter what.
106  */
107 #define IE_SCP_ADDR 0xfffff4
108
109 #if 0
110 /*
111  * The tells the hardware where all the rest of the stuff is, too.
112  * FIXME: some of these should be re-commented after we figure out their
113  * REAL function.
114  */
115 struct __ie_int_sys_conf_ptr {
116  u_int8_t ie_busy; // zeroed after init
117  u_int8_t mbz;
118  u_int16_t ie_scb_offset; // 16-bit physaddr of next struct
119  caddr_t ie_base; // 24-bit physaddr for all 16-bit vars
120 };
121 #endif
122 #define IE_ISCP_SZ 8
123 #define IE_ISCP_BUSY(base) ((base) + 0)
124 #define IE_ISCP_SCB(base) ((base) + 2)
125 #define IE_ISCP_BASE(base) ((base) + 4)
126
127 #if 0
128 /*
129  * This FINALLY tells the hardware what to do and where to put it.
130  */
131 struct __ie_sys_ctl_block {
132  u_int16_t ie_status; // status word
133  u_int16_t ie_command; // command word
134  u_int16_t ie_command_list; // 16-pointer to command block list
135  u_int16_t ie_recv_list; // 16-pointer to receive frame list
136  u_int16_t ie_err_crc; // CRC errors
137  u_int16_t ie_err_align; // Alignment errors
138  u_int16_t ie_err_resource; // Resource errors
139  u_int16_t ie_err_overrun; // Overrun errors
140 };
141 #endif
142 #define IE_SCB_SZ 16
143 #define IE_SCB_STATUS(base) ((base) + 0)
144 #define IE_SCB_CMD(base) ((base) + 2)
145 #define IE_SCB_CMDLST(base) ((base) + 4)
146 #define IE_SCB_RCVLST(base) ((base) + 6)
147 #define IE_SCB_ERRCRC(base) ((base) + 8)
148 #define IE_SCB_ERRALN(base) ((base) + 10)
149 #define IE_SCB_ERRRES(base) ((base) + 12)
150 #define IE_SCB_ERROVR(base) ((base) + 14)
151
152 /* Command values */
153 #define IE_RUC_MASK 0x0070 /* mask for RU command */
154 #define IE_RUC_NOP 0 /* for completeness */
155 #define IE_RUC_START 0x0010 /* start receive unit command */
156 #define IE_RUC_RESUME 0x0020 /* resume a suspended receiver command */
157 #define IE_RUC_SUSPEND 0x0030 /* suspend receiver command */
158 #define IE_RUC_ABORT 0x0040 /* abort current receive operation */
159
160 #define IE_CUC_MASK 0x0700 /* mask for CU command */
161 #define IE_CUC_NOP 0 /* included for completeness */
162 #define IE_CUC_START 0x0100 /* do-command command */
163 #define IE_CUC_RESUME 0x0200 /* resume a suspended cmd list */
164 #define IE_CUC_SUSPEND 0x0300 /* suspend current command */
165 #define IE_CUC_ABORT 0x0400 /* abort current command */
166
167 #define IE_ACK_COMMAND 0xf000 /* mask for ACK command */
168 #define IE_ACK_CX 0x8000 /* ack IE_ST_CX */
169 #define IE_ACK_FR 0x4000 /* ack IE_ST_FR */
170 #define IE_ACK_CNA 0x2000 /* ack IE_ST_CNA */
171 #define IE_ACK_RNR 0x1000 /* ack IE_ST_RNR */
172
173 #define IE_ACTION_COMMAND(x) (((x) & IE_CUC_MASK) == IE_CUC_START)
174  /* is this command an action command? */
175
176 /* Status values */
177 #define IE_ST_WHENCE 0xf000 /* mask for cause of interrupt */
178 #define IE_ST_CX 0x8000 /* command with I bit completed */
179 #define IE_ST_FR 0x4000 /* frame received */
180 #define IE_ST_CNA 0x2000 /* all commands completed */
181 #define IE_ST_RNR 0x1000 /* receive not ready */
182
183 #define IE_CUS_MASK 0x0700 /* mask for command unit status */
184 #define IE_CUS_ACTIVE 0x0200 /* command unit is active */
185 #define IE_CUS_SUSPEND 0x0100 /* command unit is suspended */
186
187 #define IE_RUS_MASK 0x0070 /* mask for receiver unit status */
188 #define IE_RUS_SUSPEND 0x0010 /* receiver is suspended */
189 #define IE_RUS_NOSPACE 0x0020 /* receiver has no resources */
190 #define IE_RUS_READY 0x0040 /* receiver is ready */
191
192 #if 0
193 /*
194  * This is filled in partially by the chip, partially by us.
195  */
196 struct __ie_recv_frame_desc {
197  u_int16_t ie_fd_status; // status for this frame
198  u_int16_t ie_fd_last; // end of frame list flag
199  u_int16_t ie_fd_next; // 16-pointer to next RFD
200  u_int16_t ie_fd_buf_desc; // 16-pointer to list of buffer descs
201  struct __ie_en_addr dest; // destination ether
202  struct __ie_en_addr src; // source ether
203  u_int16_t ie_length; // 802 length/Ether type
204  u_short mbz; // must be zero
205 };
206 #endif
207 #define IE_RFRAME_SZ 24
208 #define IE_RFRAME_ADDR(base,i) ((base) + (i) * IE_RFRAME_SZ)
209 #define IE_RFRAME_STATUS(b,i) (IE_RFRAME_ADDR(b,i) + 0)
210 #define IE_RFRAME_LAST(b,i) (IE_RFRAME_ADDR(b,i) + 2)
211 #define IE_RFRAME_NEXT(b,i) (IE_RFRAME_ADDR(b,i) + 4)
212 #define IE_RFRAME_BUFDESC(b,i) (IE_RFRAME_ADDR(b,i) + 6)
213 #define IE_RFRAME_EDST(b,i) (IE_RFRAME_ADDR(b,i) + 8)
214 #define IE_RFRAME_ESRC(b,i) (IE_RFRAME_ADDR(b,i) + 14)
215 #define IE_RFRAME_ELEN(b,i) (IE_RFRAME_ADDR(b,i) + 20)
216
217 /* "last" bits */
218 #define IE_FD_EOL 0x8000 /* last rfd in list */
219 #define IE_FD_SUSP 0x4000 /* suspend RU after receipt */
220
221 /* status field bits */
222 #define IE_FD_COMPLETE 0x8000 /* frame is complete */
223 #define IE_FD_BUSY 0x4000 /* frame is busy */
224 #define IE_FD_OK 0x2000 /* frame is ok */
225 #define IE_FD_CRC 0x0800 /* CRC error */
226 #define IE_FD_ALGN 0x0400 /* Alignment error */
227 #define IE_FD_RNR 0x0200 /* receiver out of resources here */
228 #define IE_FD_OVR 0x0100 /* DMA overrun */
229 #define IE_FD_SHORT 0x0080 /* Short frame */
230 #define IE_FD_NOEOF 0x0040 /* no EOF (?) */
231 #define IE_FD_ERRMASK /* all error bits */ \
232  (IE_FD_CRC|IE_FD_ALGN|IE_FD_RNR|IE_FD_OVR|IE_FD_SHORT|IE_FD_NOEOF)
233 #define IE_FD_STATUSBITS \
234  "\20\20COMPLT\17BUSY\16OK\14CRC\13ALGN\12RNR\11OVR\10SHORT\7NOEOF"
235
236 #if 0
237 /*
238  * linked list of buffers...
239  */
240 struct __ie_recv_buf_desc {
241  u_int16_t ie_rbd_status; // status for this buffer
242  u_int16_t ie_rbd_next; // 16-pointer to next RBD
243  caddr_t ie_rbd_buffer; // 24-pointer to buffer for this RBD
244  u_int16_t ie_rbd_length; // length of the buffer
245  u_int16_t mbz; // must be zero
246 };
247 #endif
248 #define IE_RBD_SZ 12
249 #define IE_RBD_ADDR(base,i) ((base) + (i) * IE_RBD_SZ)
250 #define IE_RBD_STATUS(b,i) (IE_RBD_ADDR(b,i) + 0)
251 #define IE_RBD_NEXT(b,i) (IE_RBD_ADDR(b,i) + 2)
252 #define IE_RBD_BUFADDR(b,i) (IE_RBD_ADDR(b,i) + 4)
253 #define IE_RBD_BUFLEN(b,i) (IE_RBD_ADDR(b,i) + 8)
254
255 /* RBD status fields */
256 #define IE_RBD_LAST 0x8000 /* last buffer */
257 #define IE_RBD_USED 0x4000 /* this buffer has data */
258 #define IE_RBD_CNTMASK 0x3fff /* byte count of buffer data */
259
260 /* RDB `End Of List' flag; encoded in `buffer length' field */
261 #define IE_RBD_EOL 0x8000 /* last buffer */
262
263
264 #if 0
265 /*
266  * All commands share this in common.
267  */
268 struct __ie_cmd_common {
269  u_int16_t ie_cmd_status; // status of this command
270  u_int16_t ie_cmd_cmd; // command word
271  u_int16_t ie_cmd_link; // link to next command
272 };
273 #endif
274 #define IE_CMD_COMMON_SZ 6
275 #define IE_CMD_COMMON_STATUS(base) ((base) + 0)
276 #define IE_CMD_COMMON_CMD(base) ((base) + 2)
277 #define IE_CMD_COMMON_LINK(base) ((base) + 4)
278
279 #define IE_STAT_COMPL 0x8000 /* command is completed */
280 #define IE_STAT_BUSY 0x4000 /* command is running now */
281 #define IE_STAT_OK 0x2000 /* command completed successfully */
282 #define IE_STAT_ABORT 0x1000 /* command was aborted */
283
284 #define IE_CMD_NOP 0x0000 /* NOP */
285 #define IE_CMD_IASETUP 0x0001 /* initial address setup */
286 #define IE_CMD_CONFIG 0x0002 /* configure command */
287 #define IE_CMD_MCAST 0x0003 /* multicast setup command */
288 #define IE_CMD_XMIT 0x0004 /* transmit command */
289 #define IE_CMD_TDR 0x0005 /* time-domain reflectometer command */
290 #define IE_CMD_DUMP 0x0006 /* dump command */
291 #define IE_CMD_DIAGNOSE 0x0007 /* diagnostics command */
292
293 #define IE_CMD_LAST 0x8000 /* this is the last command in the list */
294 #define IE_CMD_SUSPEND 0x4000 /* suspend CU after this command */
295 #define IE_CMD_INTR 0x2000 /* post an interrupt after completion */
296
297 /*
298  * No-op commands; just like COMMON but "indexable"
299  */
300 #define IE_CMD_NOP_SZ IE_CMD_COMMON_SZ
301 #define IE_CMD_NOP_ADDR(base,i) ((base) + (i) * IE_CMD_NOP_SZ)
302 #define IE_CMD_NOP_STATUS(b,i) (IE_CMD_NOP_ADDR(b,i) + 0)
303 #define IE_CMD_NOP_CMD(b,i) (IE_CMD_NOP_ADDR(b,i) + 2)
304 #define IE_CMD_NOP_LINK(b,i) (IE_CMD_NOP_ADDR(b,i) + 4)
305
306
307 #if 0
308 /*
309  * This is the command to transmit a frame.
310  */
311 struct __ie_xmit_cmd {
312  struct __ie_cmd_common com; // common part
313 #define __ie_xmit_status com.ie_cmd_status
314
315  u_int16_t ie_xmit_desc; // pointer to buffer descriptor
316  struct __ie_en_addr ie_xmit_addr; // destination address
317  u_int16_t ie_xmit_length; // 802.3 length/Ether type field
318 };
319 #endif
320 #define IE_CMD_XMIT_SZ (IE_CMD_COMMON_SZ + 10)
321 #define IE_CMD_XMIT_ADDR(base,i) ((base) + (i) * IE_CMD_XMIT_SZ)
322 #define IE_CMD_XMIT_STATUS(b,i) \
323  (IE_CMD_XMIT_ADDR(b,i) + 0) /* == CMD_COMMON_STATUS */
324 #define IE_CMD_XMIT_CMD(b,i) \
325  (IE_CMD_XMIT_ADDR(b,i) + 2) /* == CMD_COMMON_CMD */
326 #define IE_CMD_XMIT_LINK(b,i) \
327  (IE_CMD_XMIT_ADDR(b,i) + 4) /* == CMD_COMMON_LINK */
328 #define IE_CMD_XMIT_DESC(b,i) \
329  (IE_CMD_XMIT_ADDR(b,i) + IE_CMD_COMMON_SZ + 0)
330 #define IE_CMD_XMIT_EADDR(b,i) \
331  (IE_CMD_XMIT_ADDR(b,i) + IE_CMD_COMMON_SZ + 2)
332 #define IE_CMD_XMIT_LEN(b,i) \
333  (IE_CMD_XMIT_ADDR(b,i) + IE_CMD_COMMON_SZ + 8)
334
335 #define IE_XS_MAXCOLL 0x000f /* number of collisions during transmit */
336 #define IE_XS_EXCMAX 0x0020 /* exceeded maximum number of collisions */
337 #define IE_XS_SQE 0x0040 /* SQE positive */
338 #define IE_XS_DEFERRED 0x0080 /* transmission deferred */
339 #define IE_XS_UNDERRUN 0x0100 /* DMA underrun */
340 #define IE_XS_LOSTCTS 0x0200 /* Lost CTS */
341 #define IE_XS_NOCARRIER 0x0400 /* No Carrier */
342 #define IE_XS_LATECOLL 0x0800 /* Late collision */
343
344 #if 0
345 /*
346  * This is a buffer descriptor for a frame to be transmitted.
347  */
348 struct __ie_xmit_buf {
349  u_int16_t ie_xmit_flags; // see below
350  u_int16_t ie_xmit_next; // 16-pointer to next desc
351  caddr_t ie_xmit_buf; // 24-pointer to the actual buffer
352 };
353 #endif
354 #define IE_XBD_SZ 8
355 #define IE_XBD_ADDR(base,i) ((base) + (i) * IE_XBD_SZ)
356 #define IE_XBD_FLAGS(b,i) (IE_XBD_ADDR(b,i) + 0)
357 #define IE_XBD_NEXT(b,i) (IE_XBD_ADDR(b,i) + 2)
358 #define IE_XBD_BUF(b,i) (IE_XBD_ADDR(b,i) + 4)
359
360 #define IE_TBD_EOL 0x8000 /* this TBD is the last one */
361 #define IE_TBD_CNTMASK 0x3fff /* The rest of the `flags' word
362  is actually the length. */
363
364
365 #if 0
366 /*
367  * Multicast setup command.
368  */
369 struct __ie_mcast_cmd {
370  struct __ie_cmd_common com; // common part
371 #define ie_mcast_status com.ie_cmd_status
372
373  // size (in bytes) of multicast addresses
374  u_short ie_mcast_bytes;
375  struct __ie_en_addr ie_mcast_addrs[IE_MAXMCAST + 1];// space for them
376 };
377 #endif
378 #define IE_CMD_MCAST_SZ (IE_CMD_COMMON_SZ + 2 /* + XXX */)
379 #define IE_CMD_MCAST_BYTES(base) ((base) + IE_CMD_COMMON_SZ + 0)
380 #define IE_CMD_MCAST_MADDR(base) ((base) + IE_CMD_COMMON_SZ + 2)
381
382 #if 0
383 /*
384  * Time Domain Reflectometer command.
385  */
386 struct __ie_tdr_cmd {
387  struct __ie_cmd_common com; // common part
388 #define ie_tdr_status com.ie_cmd_status
389  u_short ie_tdr_time; // error bits and time
390 };
391 #endif
392 #define IE_CMD_TDR_SZ (IE_CMD_COMMON_SZ + 2)
393 #define IE_CMD_TDR_TIME(base) ((base) + IE_CMD_COMMON_SZ + 0)
394
395 #define IE_TDR_SUCCESS 0x8000 /* TDR succeeded without error */
396 #define IE_TDR_XCVR 0x4000 /* detected a transceiver problem */
397 #define IE_TDR_OPEN 0x2000 /* detected an incorrect termination ("open") */
398 #define IE_TDR_SHORT 0x1000 /* TDR detected a short circuit */
399 #define IE_TDR_TIME 0x07ff /* mask for reflection time */
400
401 #if 0
402 /*
403  * Initial Address Setup command
404  */
405 struct __ie_iasetup_cmd {
406  struct __ie_cmd_common com;
407 #define ie_iasetup_status com.ie_cmd_status
408  struct __ie_en_addr ie_address;
409 };
410 #endif
411 #define IE_CMD_IAS_SZ (IE_CMD_COMMON_SZ + 6)
412 #define IE_CMD_IAS_EADDR(base) ((base) + IE_CMD_COMMON_SZ + 0)
413
414 #if 0
415 /*
416  * Configuration command
417  */
418 struct __ie_config_cmd {
419  struct __ie_cmd_common com; // common part
420 #define ie_config_status com.ie_cmd_status
421
422  u_int8_t ie_config_count; // byte count (0x0c)
423  u_int8_t ie_fifo; // fifo (8)
424  u_int8_t ie_save_bad; // save bad frames (0x40)
425  u_int8_t ie_addr_len; // address length (0x2e) (AL-LOC == 1)
426  u_int8_t ie_priority; // priority and backoff (0x0)
427  u_int8_t ie_ifs; // inter-frame spacing (0x60)
428  u_int8_t ie_slot_low; // slot time, LSB (0x0)
429  u_int8_t ie_slot_high; // slot time, MSN, and retries (0xf2)
430  u_int8_t ie_promisc; // 1 if promiscuous, else 0
431  u_int8_t ie_crs_cdt; // CSMA/CD parameters (0x0)
432  u_int8_t ie_min_len; // min frame length (0x40)
433  u_int8_t ie_junk; // stuff for 82596 (0xff)
434 };
435 #endif
436 #define IE_CMD_CFG_SZ (IE_CMD_COMMON_SZ + 12)
437 #define IE_CMD_CFG_CNT(base) ((base) + IE_CMD_COMMON_SZ + 0)
438 #define IE_CMD_CFG_FIFO(base) ((base) + IE_CMD_COMMON_SZ + 1)
439 #define IE_CMD_CFG_SAVEBAD(base) ((base) + IE_CMD_COMMON_SZ + 2)
440 #define IE_CMD_CFG_ADDRLEN(base) ((base) + IE_CMD_COMMON_SZ + 3)
441 #define IE_CMD_CFG_PRIORITY(base) ((base) + IE_CMD_COMMON_SZ + 4)
442 #define IE_CMD_CFG_IFS(base) ((base) + IE_CMD_COMMON_SZ + 5)
443 #define IE_CMD_CFG_SLOT_LOW(base) ((base) + IE_CMD_COMMON_SZ + 6)
444 #define IE_CMD_CFG_SLOT_HIGH(base) ((base) + IE_CMD_COMMON_SZ + 7)
445 #define IE_CMD_CFG_PROMISC(base) ((base) + IE_CMD_COMMON_SZ + 8)
446 #define IE_CMD_CFG_CRSCDT(base) ((base) + IE_CMD_COMMON_SZ + 9)
447 #define IE_CMD_CFG_MINLEN(base) ((base) + IE_CMD_COMMON_SZ + 10)
448 #define IE_CMD_CFG_JUNK(base) ((base) + IE_CMD_COMMON_SZ + 11)
