RTEMS  5.1
gtvar.h
1 /* $NetBSD: gtvar.h,v 1.7.4.1 2005/04/29 11:28:56 kent Exp $ */
2
3 /*
4  * Copyright (c) 2002 Allegro Networks, Inc., Wasabi Systems, Inc.
5  * All rights reserved.
6  *
7  * Redistribution and use in source and binary forms, with or without
8  * modification, are permitted provided that the following conditions
9  * are met:
10  * 1. Redistributions of source code must retain the above copyright
11  * notice, this list of conditions and the following disclaimer.
12  * 2. Redistributions in binary form must reproduce the above copyright
13  * notice, this list of conditions and the following disclaimer in the
14  * documentation and/or other materials provided with the distribution.
15  * 3. All advertising materials mentioning features or use of this software
16  * must display the following acknowledgement:
17  * This product includes software developed for the NetBSD Project by
18  * Allegro Networks, Inc., and Wasabi Systems, Inc.
19  * 4. The name of Allegro Networks, Inc. may not be used to endorse
20  * or promote products derived from this software without specific prior
21  * written permission.
22  * 5. The name of Wasabi Systems, Inc. may not be used to endorse
23  * or promote products derived from this software without specific prior
24  * written permission.
25  *
26  * THIS SOFTWARE IS PROVIDED BY ALLEGRO NETWORKS, INC. AND
27  * WASABI SYSTEMS, INC. ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES,
28  * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY
29  * AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
30  * IN NO EVENT SHALL EITHER ALLEGRO NETWORKS, INC. OR WASABI SYSTEMS, INC.
31  * BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
32  * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
33  * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
34  * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
35  * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
36  * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
37  * POSSIBILITY OF SUCH DAMAGE.
38  */
39
40 /*
41  * gtvar.h -- placeholder for GT system controller driver
42  */
43 #ifndef _DISCOVERY_DEV_GTVAR_H_
44 #define _DISCOVERY_DEV_GTVAR_H_
45
46 #include <sys/systm.h>
47
48 struct gt_softc {
49 #ifndef __rtems__
50  struct device gt_dev;
51  bus_dma_tag_t gt_dmat;
52  bus_space_tag_t gt_memt; /* the GT itself */
53  bus_space_tag_t gt_pci0_memt; /* PCI0 mem space */
54  bus_space_tag_t gt_pci0_iot; /* PCI0 i/o space */
55  boolean_t gt_pci0_host; /* We're host on PCI0 if TRUE */
56  bus_space_tag_t gt_pci1_memt; /* PCI1 mem space */
57  bus_space_tag_t gt_pci1_iot; /* PCI1 i/o space */
58  boolean_t gt_pci1_host; /* We're host on PCI1 if TRUE */
59
60  bus_space_handle_t gt_memh; /* to access the GT registers */
61 #else
62  unsigned gt_memh;
63 #endif
64  int gt_childmask; /* what children are present */
65 };
66
67 #define GT_CHILDOK(gt, ga, cd, pos, max) \
68  (((ga)->ga_unit) < (max) && \
69  !((gt)->gt_childmask & (1 << (((ga)->ga_unit) + (pos)))) && \
70  !strcmp((ga)->ga_name, (cd)->cd_name))
71
72 #define GT_MPSCOK(gt, ga, cd) GT_CHILDOK((gt), (ga), (cd), 0, 2)
73 #define GT_PCIOK(gt, ga, cd) GT_CHILDOK((gt), (ga), (cd), 2, 2)
74 #define GT_ETHEROK(gt, ga, cd) GT_CHILDOK((gt), (ga), (cd), 4, 3)
75 #define GT_OBIOOK(gt, ga, cd) GT_CHILDOK((gt), (ga), (cd), 7, 5)
76 #define GT_I2COK(gt, ga, cd) GT_CHILDOK((gt), (ga), (cd), 12, 1)
77
78 #define GT_CHILDFOUND(gt, ga, pos) \
79  ((void)(((gt)->gt_childmask |= (1 << (((ga)->ga_unit) + (pos))))))
80
81 #define GT_MPSCFOUND(gt, ga) GT_CHILDFOUND((gt), (ga), 0)
82 #define GT_PCIFOUND(gt, ga) GT_CHILDFOUND((gt), (ga), 2)
83 #define GT_ETHERFOUND(gt, ga) GT_CHILDFOUND((gt), (ga), 4)
84 #define GT_OBIOFOUND(gt, ga) GT_CHILDFOUND((gt), (ga), 7)
85 #define GT_I2CFOUND(gt, ga) GT_CHILDFOUND((gt), (ga), 12)
86
87 #ifndef __rtems__
89  const char *ga_name; /* class name of device */
90  bus_dma_tag_t ga_dmat; /* dma tag */
91  bus_space_tag_t ga_memt; /* GT bus space tag */
92  bus_space_handle_t ga_memh; /* GT bus space handle */
93  int ga_unit; /* instance of ga_name */
94 };
95
97  const char *oa_name; /* call name of device */
98  bus_space_tag_t oa_memt; /* bus space tag */
99  bus_addr_t oa_offset; /* offset (absolute) to device */
100  bus_size_t oa_size; /* size (strided) of device */
101  int oa_irq; /* irq */
102 };
103 #endif
104
105 #ifdef _KERNEL
106 #ifndef __rtems__
107 #include "locators.h"
108 #endif
109
110 #ifdef DEBUG
111 extern int gtpci_debug;
112 #endif
113
114 /*
115  * Locators for GT private devices, as specified to config.
116  */
117 #define GT_UNK_UNIT GTCF_UNIT_DEFAULT /* wcarded 'function' */
118
119 #define OBIO_UNK_OFFSET OBIOCF_OFFSET_DEFAULT /* wcarded 'offset' */
120
121 #define OBIO_UNK_SIZE OBIOCF_SIZE_DEFAULT /* wcarded 'size' */
122
123 #define OBIO_UNK_IRQ OBIOCF_IRQ_DEFAULT /* wcarded 'irq' */
124
125 void gt_attach_common(struct gt_softc *);
126 uint32_t gt_read_mpp(void);
127 int gt_cfprint(void *, const char *);
128
129 #ifndef __rtems__
130 /* int gt_bs_extent_init(struct discovery_bus_space *, char *); AKB */
131 int gt_mii_read(struct device *, struct device *, int, int);
132 void gt_mii_write(struct device *, struct device *, int, int, int);
133 int gtget_macaddr(struct gt_softc *,int, char *);
134
135 void gt_watchdog_service(void);
136 bus_addr_t gt_dma_phys_to_bus_mem(bus_dma_tag_t, bus_addr_t);
137 bus_addr_t gt_dma_bus_mem_to_phys(bus_dma_tag_t, bus_addr_t);
138
139 #define gt_read(gt,o) \
140  bus_space_read_4((gt)->gt_memt, (gt)->gt_memh, (o))
141 #define gt_write(gt,o,v) \
142  bus_space_write_4((gt)->gt_memt, (gt)->gt_memh, (o), (v))
143 #else
144 #endif
145
146 #if defined(__powerpc__)
147 static __inline volatile int
148 atomic_add(volatile int *p, int v)
149 {
150  int rv;
151  int rtmp;
152
153  __asm __volatile(
154  "1: lwarx %0,0,%3\n"
155  " add %1,%4,%0\n"
156  " stwcx. %1,0,%3\n"
157  " bne- 1b\n"
158  " sync"
159  : "=&r"(rv), "=&r"(rtmp), "=m"(*p)
160  : "r"(p), "r"(v), "m"(*p)
161  : "cc");
162
163  return rv;
164 }
165
166 #endif /* __powerpc__ */
167
168 #endif /* _KERNEL */
169
170 #endif /* _DISCOVERY_DEV_GTVAR_H_ */
unsigned p
Definition: tte.h:90
Definition: gtvar.h:96
Definition: rtemscompat1.h:15
Definition: gtvar.h:48
Definition: gtvar.h:88
unsigned v
Definition: tte.h:73
