RTEMS  5.1
grtm.h
1 /* GRTM Telemetry (TM) driver interface
2  *
3  * COPYRIGHT (c) 2007.
4  * Cobham Gaisler AB.
5  *
6  * The license and distribution terms for this file may be
7  * found in the file LICENSE in this distribution or at
8  * http://www.rtems.org/license/LICENSE.
9  */
10
11 #ifndef __GRTM_H__
12 #define __GRTM_H__
13
14 #include <rtems.h>
15
16 #ifdef __cplusplus
17 extern "C" {
18 #endif
19
20 #define GRTM_IOC_UNUSED 0
21
22 /* Driver operation controlling commands */
23 #define GRTM_IOC_START 1
24 #define GRTM_IOC_STOP 2
25 #define GRTM_IOC_ISSTARTED 3
26 #define GRTM_IOC_SET_BLOCKING_MODE 4
27 #define GRTM_IOC_SET_TIMEOUT 5
28
29 /* Available only in STOPPED mode */
30 #define GRTM_IOC_SET_CONFIG 32
31
32 /* Available in both running and stopped mode */
33 #define GRTM_IOC_RECLAIM 64
34 #define GRTM_IOC_GET_CONFIG 65
35 #define GRTM_IOC_GET_HW_IMPL 66
36 #define GRTM_IOC_GET_HW_STATUS 67 /* Not implemented */
37 #define GRTM_IOC_GET_OCFREG 68
38 #define GRTM_IOC_GET_STATS 69
39 #define GRTM_IOC_CLR_STATS 70
40
41 /* Available only in RUNNING mode */
42 #define GRTM_IOC_SEND 96
43
44 /* Args to GRTC_IOC_SET_BLOCKING_MODE */
45 enum {
46  GRTM_BLKMODE_POLL = 0, /* Never block (polling mode) */
47  GRTM_BLKMODE_BLK = 1, /* Block until at least 1 byte can be read */
48 };
49
50 /* Reed Solomon Encoder implemented */
51 enum {
52  GRTM_RS_IMPL_NONE = 0,
53  GRTM_RS_IMPL_E16 = 1, /* E16 */
54  GRTM_RS_IMPL_E8 = 2, /* E8 */
55  GRTM_RS_IMPL_BOTH = 3 /* Both E8 and E16 */
56
57 };
58
59 struct grtm_ioc_hw {
60  char cs; /* Sub Carrier */
61  char sp; /* Split-Phase Level */
62  char ce;
63  char nrz;
64  char psr;
65  char te;
66  unsigned char rsdep;
67  unsigned char rs;
68  char aasm;
69  char fecf;
70  char ocf;
71  char evc;
72  char idle;
73  char fsh;
74  char mcg;
75  char iz;
76  char fhec;
77  char aos;
78  char cif;
79  char ocfb;
80
81  unsigned short blk_size; /* Block Size */
82  unsigned short fifo_size; /* FIFO Size */
83
84 };
85
86 /* Driver Mode */
87 enum {
88  GRTM_MODE_TM = 0, /* TM */
89  GRTM_MODE_AOS = 1 /* AOS */
90 };
91
92 /* Physical layer Options */
93 #define GRTM_IOC_PHY_SCF (1<<15) /* Sub Carrier Fall */
94 #define GRTM_IOC_PHY_SF (1<<31) /* Symbol Fall */
95
96 /* Coding Sub-layer Options */
97 #define GRTM_IOC_CODE_SC (1<<0) /* Enable Sub Carrier modulation */
98 #define GRTM_IOC_CODE_SP (1<<1) /* Enable Split-Phase (SP) level modulation */
99 #define GRTM_IOC_CODE_CE (1<<5) /* Enable Convolutional Encoding */
100 #define GRTM_IOC_CODE_NRZ (1<<6) /* Enable Non-Return-to-Zero mark encoding */
101 #define GRTM_IOC_CODE_PSR (1<<7) /* Enable Pseudo-Randomizer */
102 #define GRTM_IOC_CODE_RS8 (1<<11) /* Reed-solomon Encoder to use: 0=E16, 1=E8 */
103 #define GRTM_IOC_CODE_RS (1<<15) /* Enable Reed-Solomon Encoder */
104 #define GRTM_IOC_CODE_AASM (1<<16) /* Enable Alternative attached synchronization marker */
105 #define GRTM_IOC_CODE_ALL (GRTM_IOC_CODE_SC|GRTM_IOC_CODE_SP|GRTM_IOC_CODE_CE| \
106  GRTM_IOC_CODE_NRZ|GRTM_IOC_CODE_PSR|GRTM_IOC_CODE_RS8|\
107  GRTM_IOC_CODE_RS|GRTM_IOC_CODE_AASM)
108
109 enum {
110  GRTM_CERATE_00 = 0, /* Rate 1/2, no puncturing */
111  GRTM_CERATE_02 = 2, /* Rate 1/2, punctured */
112  GRTM_CERATE_04 = 4, /* Rate 2/3, punctured */
113  GRTM_CERATE_05 = 5, /* Rate 3/4, punctured */
114  GRTM_CERATE_06 = 6, /* Rate 5/6, punctured */
115  GRTM_CERATE_07 = 7, /* Rate 7/8, punctured */
116 };
117
118 /* Options for Generating all frames */
119 #define GRTM_IOC_ALL_FHEC 0x01 /* Enable Frame Header Error Control (Only AOS) */
120 #define GRTM_IOC_ALL_FECF 0x02 /* Enable Transfer Frame CRC */
121 #define GRTM_IOC_ALL_IZ 0x04 /* Enable Insert Zone */
122 #define GRTM_IOC_ALL_ALL (GRTM_IOC_ALL_FHEC|GRTM_IOC_ALL_FECF|GRTM_IOC_ALL_IZ)
123
124 /* Master Frame Generation Options */
125 #define GRTM_IOC_MF_OW 0x01 /* Over Write OCF bits 16 and 17 */
126 #define GRTM_IOC_MF_OCF 0x02 /* Enable Operation Control Field (OCF) for master channel */
127 #define GRTM_IOC_MF_FSH 0x04 /* Enable MC_FSH for master channel */
128 #define GRTM_IOC_MF_MC 0x08 /* Enable Master channel counter generation */
129 #define GRTM_IOC_MF_ALL (GRTM_IOC_MF_OW|GRTM_IOC_MF_OCF|GRTM_IOC_MF_FSH|GRTM_IOC_MF_MC)
130
131 /* Idle Frames Generation Options */
132 #define GRTM_IOC_IDLE_MC 0x01 /* Enable Master Channel (MC) counter generation (TM Only) */
133 #define GRTM_IOC_IDLE_VCC 0x02 /* Enable Virtual Channel counter cycle generation (AOS Only)*/
134 #define GRTM_IOC_IDLE_FSH 0x04 /* Enable Frame Secondary Header (FSH) for idle frames (TM Only) */
135 #define GRTM_IOC_IDLE_EVC 0x08 /* Enable Extended Virtual Channel Counter Generation */
136 #define GRTM_IOC_IDLE_OCF 0x10 /* Enable OCF/CLCW in idle frame */
137 #define GRTM_IOC_IDLE_EN 0x20 /* Enable Idle frame generation */
138 #define GRTM_IOC_IDLE_ALL (GRTM_IOC_IDLE_MC|GRTM_IOC_IDLE_VCC|GRTM_IOC_IDLE_FSH| \
139  GRTM_IOC_IDLE_EVC|GRTM_IOC_IDLE_OCF|GRTM_IOC_IDLE_EN)
140
141 /* Argument of GRTM_IOC_SET_CONFIG and GRTM_IOC_GET_CONFIG.
142  * Driver and Hardware configuration.
143  *
144  * Pointer to:
145  */
147
148  /* Mode AOS or TM */
149  unsigned char mode; /* 0=TM, 1=AOS */
150
151  unsigned short frame_length; /* Length of every frame transmitted */
152  unsigned short limit; /* Number of data bytes fetched by DMA before transmission starts */
153  unsigned int as_marker; /* Attached Synchronization Marker */
154
155  /* Physical layer options */
156  unsigned short phy_subrate; /* Sub Carrier rate - sub carrier devision factor - 1 */
157  unsigned short phy_symbolrate; /* Symbol Rate division factor - 1 */
158  unsigned char phy_opts; /* Mask of GRTM_IOC_PHY_XXXX */
159
160  /* Coding sub-layer Options */
161  unsigned char code_rsdep; /* Coding sub-layer Reed-Solomon interleave depth (3-bit) */
162  unsigned char code_ce_rate; /* Convolutional encoding rate, select one of GRTM_CERATE_00 ... GRTM_CERATE_07 */
163  unsigned char code_csel; /* */
164  unsigned int code_opts; /* Mask of GRTM_IOC_CODE_XXXX */
165
166  /* All Frames Generation */
167  unsigned char all_izlen; /* FSH/IZ Length (5-bit) */
168  unsigned char all_opts; /* Mask of GRTM_IOC_ALL_XXXX */
169
170  /* Master Frame Generation */
171  unsigned char mf_opts; /* Mask of GRTM_IOC_MF_XXXX */
172
173  /* Idle frame Generation */
174  unsigned short idle_scid;
175  unsigned char idle_vcid;
176  unsigned char idle_opts; /* Mask of GRTM_IOC_IDLE_XXXX */
177
178  /* Interrupt options */
179  unsigned int enable_cnt; /* Number of frames in between Interrupt is generated, Zero disables interrupt */
180  int isr_desc_proc; /* Enable ISR to process descriptors */
181  int blocking; /* Blocking mode select (POLL,BLK..) */
182  rtems_interval timeout; /* Blocking mode timeout */
183 };
184
185 struct grtm_frame;
186
187 struct grtm_list {
188  struct grtm_frame *head; /* First Frame in list */
189  struct grtm_frame *tail; /* Last Frame in list */
190 };
191
192 #define GRTM_FLAGS_SENT 0x01
193 #define GRRM_FLAGS_ERR 0x02
194
195 #define GRTM_FLAGS_TRANSLATE (1<<31) /* Translate frame payload address from CPU address to remote bus (the bus GRTM is resident on) */
196 #define GRTM_FLAGS_TRANSLATE_AND_REMEMBER (1<<30) /* As GRTM_FLAGS_TRANSLATE, however if the translated payload address equals the payload address
197  * the GRTM_FLAGS_TRANSLATE_AND_REMEMBER bit is cleared and the GRTM_FLAGS_TRANSLATE bit is set */
198 #define GRTM_FLAGS_COPY_DATA (1<<29) /* Where available: Transfer Frame payload to target, may be used for SpaceWire, where the GRTM driver transfer
199  * the payload to a buffer on the SpaceWire target.
200  */
201
202 #define GRTM_FLAGS_TS (1<<14)
203 #define GRTM_FLAGS_VCE (1<<9)
204 #define GRTM_FLAGS_MCB (1<<8)
205 #define GRTM_FLAGS_FSHB (1<<7)
206 #define GRTM_FLAGS_OCFB (1<<6)
207 #define GRTM_FLAGS_FHECB (1<<5)
208 #define GRTM_FLAGS_IZB (1<<4)
209 #define GRTM_FLAGS_FECFB (1<<3)
210
211 #define GRTM_FLAGS_MASK (GRTM_FLAGS_TS|GRTM_FLAGS_VCE|GRTM_FLAGS_MCB|\
212  GRTM_FLAGS_FSHB|GRTM_FLAGS_OCFB|GRTM_FLAGS_FHECB|\
213  GRTM_FLAGS_IZB|GRTM_FLAGS_FECFB)
214
215 /* The GRTM software representation of a Frame */
216 struct grtm_frame {
217  /* Options and status */
218  unsigned int flags; /* bypass options, and sent/error status */
219
220  struct grtm_frame *next; /* Next packet in chain */
221
222  unsigned int *payload; /* The Headers and Payload, Frame data and header must be word aligned */
223 };
224
225 #define FRAME_SIZE(payloadlen) (sizeof(struct grtm_frame)+payloadlen)
226
228  unsigned long long frames_sent;
229  unsigned int err_underrun;
230  unsigned int err_tx;
231  unsigned int err_ahb;
232  unsigned int err_transfer_frame;
233 };
234
235 /* Register GRTM driver at driver manager */
236 void grtm_register_drv(void);
237
238 /* Register GRTM RMAP driver at driver manager */
239 void grtm_rmap_register_drv (void);
240
241 #ifdef __cplusplus
242 }
243 #endif
244
245 #endif /* __GRTM_H__ */
Watchdog_Interval rtems_interval
Used to manage and manipulate intervals specified by clock ticks.
Definition: types.h:127
Definition: grtm.h:187
Definition: grtm.h:216
Definition: grtm.h:146
Definition: grtm.h:59
Definition: grtm.h:227
