RTEMS  5.1
grspw_router.h
1 /*
2  * GRSPW ROUTER APB-Register Driver.
3  *
4  * COPYRIGHT (c) 2010-2017.
5  * Cobham Gaisler AB.
6  *
7  * The license and distribution terms for this file may be
8  * found in the file LICENSE in this distribution or at
9  * http://www.rtems.org/license/LICENSE.
10  */
11
12 #ifndef __GRSPW_ROUTER_H__
13 #define __GRSPW_ROUTER_H__
14
15 #ifdef __cplusplus
16 extern "C" {
17 #endif
18
19 /* Maximum number of ROUTER devices supported by driver */
20 #define ROUTER_MAX 2
21
22 #define ROUTER_ERR_OK 0
23 #define ROUTER_ERR_EINVAL -1
24 #define ROUTER_ERR_ERROR -2
25 #define ROUTER_ERR_TOOMANY -3
26 #define ROUTER_ERR_IMPLEMENTED -4
27
28 /* Hardware Information */
30  uint8_t nports_spw;
31  uint8_t nports_amba;
32  uint8_t nports_fifo;
33  int8_t srouting;
34  int8_t pnp_enable;
35  int8_t timers_avail;
36  int8_t pnp_avail;
37  uint8_t ver_major;
38  uint8_t ver_minor;
39  uint8_t ver_patch;
40  uint8_t iid;
41
42  /* Router capabilities */
43  uint8_t amba_port_fifo_size;
44  uint8_t spw_port_fifo_size;
45  uint8_t rmap_maxdlen;
46  int8_t aux_async;
47  int8_t aux_dist_int_support;
48  int8_t dual_port_support;
49  int8_t dist_int_support;
50  int8_t spwd_support;
51  uint8_t pktcnt_support;
52  uint8_t charcnt_support;
53 };
54
55 #define ROUTER_FLG_CFG 0x01
56 #define ROUTER_FLG_IID 0x02
57 #define ROUTER_FLG_IDIV 0x04
58 #define ROUTER_FLG_TPRES 0x08
59 #define ROUTER_FLG_TRLD 0x10
60 #define ROUTER_FLG_ALL 0x1f /* All Above Flags */
61
62 struct router_config {
63  uint32_t flags; /* Determine what configuration should be updated */
64
65  /* Router Configuration Register */
66  uint32_t config;
67
68  /* Set Instance ID */
69  uint8_t iid;
70
71  /* SpaceWire Link Initialization Clock Divisor */
72  uint8_t idiv;
73
74  /* Timer Prescaler */
75  uint32_t timer_prescaler;
76 };
77
78 /* Routing table address control */
80  uint32_t control[31];
81  uint32_t control_logical[224];
82 };
83
84 /* Routing table port mapping */
86  uint32_t pmap[31]; /* Port Setup for ports 1-31 */
87  uint32_t pmap_logical[224]; /* Port setup for locgical addresses 32-255 */
88 };
89
90 /* Routing table */
91 #define ROUTER_ROUTE_FLG_MAP 0x01
92 #define ROUTER_ROUTE_FLG_CTRL 0x02
93 #define ROUTER_ROUTE_FLG_ALL 0x3 /* All Above Flags */
95  uint32_t flags; /* Determine what configuration should be updated */
96
97  struct router_route_acontrol acontrol;
98  struct router_route_portmap portmap;
99 };
100
101 /* Set/Get Port Control/Status */
102 #define ROUTER_PORT_FLG_SET_CTRL 0x01
103 #define ROUTER_PORT_FLG_GET_CTRL 0x02
104 #define ROUTER_PORT_FLG_SET_STS 0x04
105 #define ROUTER_PORT_FLG_GET_STS 0x08
106 #define ROUTER_PORT_FLG_SET_CTRL2 0x10
107 #define ROUTER_PORT_FLG_GET_CTRL2 0x20
108 #define ROUTER_PORT_FLG_SET_TIMER 0x40
109 #define ROUTER_PORT_FLG_GET_TIMER 0x80
110 #define ROUTER_PORT_FLG_SET_PKTLEN 0x100
111 #define ROUTER_PORT_FLG_GET_PKTLEN 0x200
112 struct router_port {
113  uint32_t flag;
114  /* Port control */
115  uint32_t ctrl;
116  /* Port status */
117  uint32_t sts;
118  /* Port control 2 */
119  uint32_t ctrl2;
120  /* Timer Reload */
121  uint32_t timer_reload;
122  /* Maximum packet length */
123  uint32_t packet_length;
124 };
125
126 /* Register GRSPW Router driver to Driver Manager */
127 void router_register_drv(void);
128
129 extern void *router_open(unsigned int dev_no);
130 extern int router_close(void *d);
131 extern int router_print(void *d);
132 extern int router_hwinfo_get(void *d, struct router_hw_info *hwinfo);
133
134 /* Router general config */
135 extern int router_config_set(void *d, struct router_config *cfg);
136 extern int router_config_get(void *d, struct router_config *cfg);
137
138 /* Routing table config */
139 extern int router_routing_table_set(void *d,
140  struct router_routing_table *cfg);
141 extern int router_routing_table_get(void *d,
142  struct router_routing_table *cfg);
143
144 /*
145  * ROUTER PCTRL register fields
146  */
147 #define PCTRL_RD (0xff << PCTRL_RD_BIT)
148 #define PCTRL_ST (0x1 << PCTRL_ST_BIT)
149 #define PCTRL_SR (0x1 << PCTRL_SR_BIT)
150 #define PCTRL_AD (0x1 << PCTRL_AD_BIT)
151 #define PCTRL_LR (0x1 << PCTRL_LR_BIT)
152 #define PCTRL_PL (0x1 << PCTRL_PL_BIT)
153 #define PCTRL_TS (0x1 << PCTRL_TS_BIT)
154 #define PCTRL_IC (0x1 << PCTRL_IC_BIT)
155 #define PCTRL_ET (0x1 << PCTRL_ET_BIT)
156 #define PCTRL_NP (0x1 << PCTRL_NP_BIT)
157 #define PCTRL_PS (0x1 << PCTRL_PS_BIT)
158 #define PCTRL_BE (0x1 << PCTRL_BE_BIT)
159 #define PCTRL_DI (0x1 << PCTRL_DI_BIT)
160 #define PCTRL_TR (0x1 << PCTRL_TR_BIT)
161 #define PCTRL_PR (0x1 << PCTRL_PR_BIT)
162 #define PCTRL_TF (0x1 << PCTRL_TF_BIT)
163 #define PCTRL_RS (0x1 << PCTRL_RS_BIT)
164 #define PCTRL_TE (0x1 << PCTRL_TE_BIT)
165 #define PCTRL_CE (0x1 << PCTRL_CE_BIT)
166 #define PCTRL_AS (0x1 << PCTRL_AS_BIT)
167 #define PCTRL_LS (0x1 << PCTRL_LS_BIT)
168 #define PCTRL_LD (0x1 << PCTRL_LD_BIT)
169
170 #define PCTRL_RD_BIT 24
171 #define PCTRL_ST_BIT 21
172 #define PCTRL_SR_BIT 20
173 #define PCTRL_AD_BIT 19
174 #define PCTRL_LR_BIT 18
175 #define PCTRL_PL_BIT 17
176 #define PCTRL_TS_BIT 16
177 #define PCTRL_IC_BIT 15
178 #define PCTRL_ET_BIT 14
179 #define PCTRL_NP_BIT 13
180 #define PCTRL_PS_BIT 12
181 #define PCTRL_BE_BIT 11
182 #define PCTRL_DI_BIT 10
183 #define PCTRL_TR_BIT 9
184 #define PCTRL_PR_BIT 8
185 #define PCTRL_TF_BIT 7
186 #define PCTRL_RS_BIT 6
187 #define PCTRL_TE_BIT 5
188 #define PCTRL_CE_BIT 3
189 #define PCTRL_AS_BIT 2
190 #define PCTRL_LS_BIT 1
191 #define PCTRL_LD_BIT 0
192
193 /*
194  * ROUTER PCTRL2 register fields
195  */
196 #define PCTRL2_SM (0xff << PCTRL2_SM_BIT)
197 #define PCTRL2_SV (0xff << PCTRL2_SV_BIT)
198 #define PCTRL2_OR (0x1 << PCTRL2_OR_BIT)
199 #define PCTRL2_UR (0x1 << PCTRL2_UR_BIT)
200 #define PCTRL2_AT (0x1 << PCTRL2_AT_BIT)
201 #define PCTRL2_AR (0x1 << PCTRL2_AR_BIT)
202 #define PCTRL2_IT (0x1 << PCTRL2_IT_BIT)
203 #define PCTRL2_IR (0x1 << PCTRL2_IR_BIT)
204 #define PCTRL2_SD (0x1f << PCTRL2_SD_BIT)
205 #define PCTRL2_SC (0x1f << PCTRL2_SC_BIT)
206
207 #define PCTRL2_SM_BIT 24
208 #define PCTRL2_SV_BIT 16
209 #define PCTRL2_OR_BIT 15
210 #define PCTRL2_UR_BIT 14
211 #define PCTRL2_AT_BIT 12
212 #define PCTRL2_AR_BIT 11
213 #define PCTRL2_IT_BIT 10
214 #define PCTRL2_IR_BIT 9
215 #define PCTRL2_SD_BIT 1
216 #define PCTRL2_SC_BIT 0
217
218 /* Router Set/Get Port configuration */
219 extern int router_port_ioc(void *d, int port, struct router_port *cfg);
220
221 /* Read-modify-write Port Control register */
222 extern int router_port_ctrl_rmw(void *d, int port, uint32_t *oldvalue, uint32_t bitmask, uint32_t value);
223 /* Read-modify-write Port Control2 register */
224 extern int router_port_ctrl2_rmw(void *d, int port, uint32_t *oldvalue, uint32_t bitmask, uint32_t value);
225 /* Read Port Control register */
226 extern int router_port_ctrl_get(void *d, int port, uint32_t *ctrl);
227 /* Read Port Control2 register */
228 extern int router_port_ctrl2_get(void *d, int port, uint32_t *ctrl2);
229 /* Write Port Control Register */
230 extern int router_port_ctrl_set(void *d, int port, uint32_t mask, uint32_t ctrl);
231 /* Write Port Control2 Register */
232 extern int router_port_ctrl2_set(void *d, int port, uint32_t mask, uint32_t ctrl2);
233 /* Set Timer Reload Value for a specific port */
234 extern int router_port_treload_set(void *d, int port, uint32_t reload);
235 /* Get Timer Reload Value for a specific port */
236 extern int router_port_treload_get(void *d, int port, uint32_t *reload);
237 /* Get Maximum packet length for a specific port */
238 extern int router_port_maxplen_get(void *d, int port, uint32_t *length);
239 /* Set Maximum packet length for a specific port */
240 extern int router_port_maxplen_set(void *d, int port, uint32_t length);
241
242 /*
243  * ROUTER PSTSCFG register fields
244  */
245 #define PSTSCFG_EO (0x1 << PSTSCFG_EO_BIT)
246 #define PSTSCFG_EE (0x1 << PSTSCFG_EE_BIT)
247 #define PSTSCFG_PL (0x1 << PSTSCFG_PL_BIT)
248 #define PSTSCFG_TT (0x1 << PSTSCFG_TT_BIT)
249 #define PSTSCFG_PT (0x1 << PSTSCFG_PT_BIT)
250 #define PSTSCFG_HC (0x1 << PSTSCFG_HC_BIT)
251 #define PSTSCFG_PI (0x1 << PSTSCFG_PI_BIT)
252 #define PSTSCFG_CE (0x1 << PSTSCFG_CE_BIT)
253 #define PSTSCFG_EC (0xf << PSTSCFG_EC_BIT)
254 #define PSTSCFG_TS (0x1 << PSTSCFG_TS_BIT)
255 #define PSTSCFG_ME (0x1 << PSTSCFG_ME_BIT)
256 #define PSTSCFG_IP (0x1f << PSTSCFG_IP_BIT)
257 #define PSTSCFG_CP (0x1 << PSTSCFG_CP_BIT)
258 #define PSTSCFG_PC (0xf << PSTSCFG_PC_BIT)
259 #define PSTSCFG_WCLEAR (PSTSCFG_EO | PSTSCFG_EE | PSTSCFG_PL | \
260  PSTSCFG_TT | PSTSCFG_PT | PSTSCFG_HC | \
261  PSTSCFG_PI | PSTSCFG_CE | PSTSCFG_TS | \
262  PSTSCFG_ME | PSTSCFG_CP)
263 #define PSTSCFG_WCLEAR2 (PSTSCFG_CE | PSTSCFG_CP)
264
265 #define PSTSCFG_EO_BIT 31
266 #define PSTSCFG_EE_BIT 30
267 #define PSTSCFG_PL_BIT 29
268 #define PSTSCFG_TT_BIT 28
269 #define PSTSCFG_PT_BIT 27
270 #define PSTSCFG_HC_BIT 26
271 #define PSTSCFG_PI_BIT 25
272 #define PSTSCFG_CE_BIT 24
273 #define PSTSCFG_EC_BIT 20
274 #define PSTSCFG_TS_BIT 18
275 #define PSTSCFG_ME_BIT 17
276 #define PSTSCFG_IP_BIT 7
277 #define PSTSCFG_CP_BIT 4
278 #define PSTSCFG_PC_BIT 0
279
280 /*
281  * ROUTER PSTS register fields
282  */
283 #define PSTS_PT (0x3 << PSTS_PT_BIT)
284 #define PSTS_PL (0x1 << PSTS_PL_BIT)
285 #define PSTS_TT (0x1 << PSTS_TT_BIT)
286 #define PSTS_RS (0x1 << PSTS_RS_BIT)
287 #define PSTS_SR (0x1 << PSTS_SR_BIT)
288 #define PSTS_LR (0x1 << PSTS_LR_BIT)
289 #define PSTS_SP (0x1 << PSTS_SP_BIT)
290 #define PSTS_AC (0x1 << PSTS_AC_BIT)
291 #define PSTS_TS (0x1 << PSTS_TS_BIT)
292 #define PSTS_ME (0x1 << PSTS_ME_BIT)
293 #define PSTS_TF (0x1 << PSTS_TF_BIT)
294 #define PSTS_RE (0x1 << PSTS_RE_BIT)
295 #define PSTS_LS (0x7 << PSTS_LS_BIT)
296 #define PSTS_IP (0x1f << PSTS_IP_BIT)
297 #define PSTS_PR (0x1 << PSTS_PR_BIT)
298 #define PSTS_PB (0x1 << PSTS_PB_BIT)
299 #define PSTS_IA (0x1 << PSTS_IA_BIT)
300 #define PSTS_CE (0x1 << PSTS_CE_BIT)
301 #define PSTS_ER (0x1 << PSTS_ER_BIT)
302 #define PSTS_DE (0x1 << PSTS_DE_BIT)
303 #define PSTS_PE (0x1 << PSTS_PE_BIT)
304 #define PSTS_WCLEAR (PSTS_PL | PSTS_TT | PSTS_RS | PSTS_SR | \
305  PSTS_TS | PSTS_ME | PSTS_IA | PSTS_CE | \
306  PSTS_ER | PSTS_DE | PSTS_PE)
307
308 #define PSTS_PT_BIT 30
309 #define PSTS_PL_BIT 29
310 #define PSTS_TT_BIT 28
311 #define PSTS_RS_BIT 27
312 #define PSTS_SR_BIT 26
313 #define PSTS_LR_BIT 22
314 #define PSTS_SP_BIT 21
315 #define PSTS_AC_BIT 20
316 #define PSTS_TS_BIT 18
317 #define PSTS_ME_BIT 17
318 #define PSTS_TF_BIT 16
319 #define PSTS_RE_BIT 15
320 #define PSTS_LS_BIT 12
321 #define PSTS_IP_BIT 7
322 #define PSTS_PR_BIT 6
323 #define PSTS_PB_BIT 5
324 #define PSTS_IA_BIT 4
325 #define PSTS_CE_BIT 3
326 #define PSTS_ER_BIT 2
327 #define PSTS_DE_BIT 1
328 #define PSTS_PE_BIT 0
329
330 /* Check Port Status register and clear errors if there are */
331 extern int router_port_status(void *d, int port, uint32_t *sts, uint32_t clrmsk);
332
333 #define ROUTER_LINK_STATUS_ERROR_RESET 0
334 #define ROUTER_LINK_STATUS_ERROR_WAIT 1
335 #define ROUTER_LINK_STATUS_READY 2
336 #define ROUTER_LINK_STATUS_STARTED 3
337 #define ROUTER_LINK_STATUS_CONNECTING 4
338 #define ROUTER_LINK_STATUS_RUN_STATE 5
339 /* Get Link status */
340 extern int router_port_link_status(void *d, int port);
341 /* Operate a Link */
342 extern int router_port_enable(void *d, int port);
343 extern int router_port_disable(void *d, int port);
344 extern int router_port_link_stop(void *d, int port);
345 extern int router_port_link_start(void *d, int port);
346 extern int router_port_link_receive_spill(void *d, int port);
347 extern int router_port_link_transmit_reset(void *d, int port);
348
349 /* Get port credit counter register */
350 extern int router_port_cred_get(void *d, int port, uint32_t *cred);
351
352 /*
353  * ROUTER RTACTRL register fields
354  */
355 #define RTACTRL_SR (0x1 << RTACTRL_SR_BIT)
356 #define RTACTRL_EN (0x1 << RTACTRL_EN_BIT)
357 #define RTACTRL_PR (0x1 << RTACTRL_PR_BIT)
358 #define RTACTRL_HD (0x1 << RTACTRL_HD_BIT)
359
360 #define RTACTRL_SR_BIT 3
361 #define RTACTRL_EN_BIT 2
362 #define RTACTRL_PR_BIT 1
363 #define RTACTRL_HD_BIT 0
364
365 /* Individual route modification */
366 #define ROUTER_ROUTE_PACKETDISTRIBUTION_ENABLE (0x1 << 16)
367 #define ROUTER_ROUTE_PACKETDISTRIBUTION_DISABLE (0x0 << 16)
368 #define ROUTER_ROUTE_SPILLIFNOTREADY_ENABLE RTACTRL_SR
369 #define ROUTER_ROUTE_SPILLIFNOTREADY_DISABLE 0
370 #define ROUTER_ROUTE_ENABLE RTACTRL_EN
371 #define ROUTER_ROUTE_DISABLE 0
372 #define ROUTER_ROUTE_PRIORITY_HIGH RTACTRL_PR
373 #define ROUTER_ROUTE_PRIORITY_LOW 0
374 #define ROUTER_ROUTE_HEADERDELETION_ENABLE RTACTRL_HD
375 #define ROUTER_ROUTE_HEADERDELETION_DISABLE 0
376 struct router_route {
377  uint8_t from_address;
378  uint8_t to_port[32];
379  int count;
380  int options;
381 };
382 extern int router_route_set(void *d, struct router_route *route);
383 extern int router_route_get(void *d, struct router_route *route);
384
385 /* Router configuration port write enable */
386 extern int router_write_enable(void *d);
387 extern int router_write_disable(void *d);
388
389 /* Router reset */
390 extern int router_reset(void *d);
391
392 /* Set Instance ID */
393 extern int router_instance_set(void *d, uint8_t iid);
394 /* Get Instance ID */
395 extern int router_instance_get(void *d, uint8_t *iid);
396
397 /* Set SpaceWire Link Initialization Clock Divisor */
398 extern int router_idiv_set(void *d, uint8_t idiv);
399 /* Get SpaceWire Link Initialization Clock Divisor */
400 extern int router_idiv_get(void *d, uint8_t *idiv);
401
402 /* Set Timer Prescaler */
403 extern int router_tpresc_set(void *d, uint32_t prescaler);
404 /* Get Timer Prescaler */
405 extern int router_tpresc_get(void *d, uint32_t *prescaler);
406
407 /* Set/get Router configuration */
408 extern int router_cfgsts_set(void *d, uint32_t cfgsts);
409 extern int router_cfgsts_get(void *d, uint32_t *cfgsts);
410
411 /* Router timecode */
412 extern int router_tc_enable(void *d);
413 extern int router_tc_disable(void *d);
414 extern int router_tc_reset(void *d);
415 extern int router_tc_get(void *d);
416
417 /* Router Interrupts */
418 /*
419  * ROUTER IMASK register fields
420  */
421 #define IMASK_PE (0x1 << IMASK_PE_BIT)
422 #define IMASK_SR (0x1 << IMASK_SR_BIT)
423 #define IMASK_RS (0x1 << IMASK_RS_BIT)
424 #define IMASK_TT (0x1 << IMASK_TT_BIT)
425 #define IMASK_PL (0x1 << IMASK_PL_BIT)
426 #define IMASK_TS (0x1 << IMASK_TS_BIT)
427 #define IMASK_AC (0x1 << IMASK_AC_BIT)
428 #define IMASK_RE (0x1 << IMASK_RE_BIT)
429 #define IMASK_IA (0x1 << IMASK_IA_BIT)
430 #define IMASK_LE (0x1 << IMASK_LE_BIT)
431 #define IMASK_ME (0x1 << IMASK_ME_BIT)
432 #define IMASK_ALL ( IMASK_PE | IMASK_SR | IMASK_RS | IMASK_TT \
433  IMASK_PL | IMASK_TS | IMASK_AC | IMASK_RE | IMASK_IA \
434  IMASK_LE | IMASK_ME)
435
436 #define IMASK_PE_BIT 10
437 #define IMASK_SR_BIT 9
438 #define IMASK_RS_BIT 8
439 #define IMASK_TT_BIT 7
440 #define IMASK_PL_BIT 6
441 #define IMASK_TS_BIT 5
442 #define IMASK_AC_BIT 4
443 #define IMASK_RE_BIT 3
444 #define IMASK_IA_BIT 2
445 #define IMASK_LE_BIT 1
446 #define IMASK_ME_BIT 0
447
448 #define ROUTER_INTERRUPT_ALL IMASK_ALL
449 #define ROUTER_INTERRUPT_SPWPNP_ERROR IMASK_PE
450 #define ROUTER_INTERRUPT_SPILLED IMASK_SR
451 #define ROUTER_INTERRUPT_RUNSTATE IMASK_RS
452 #define ROUTER_INTERRUPT_TC_TRUNCATION IMASK_TT
453 #define ROUTER_INTERRUPT_PACKET_TRUNCATION IMASK_PL
454 #define ROUTER_INTERRUPT_TIMEOUT IMASK_TS
455 #define ROUTER_INTERRUPT_CFGPORT IMASK_AC
456 #define ROUTER_INTERRUPT_RMAP_ERROR IMASK_RE
457 #define ROUTER_INTERRUPT_INVALID_ADDRESS IMASK_IA
458 #define ROUTER_INTERRUPT_LINK_ERROR IMASK_LE
459 #define ROUTER_INTERRUPT_MEMORY_ERROR IMASK_ME
460 extern int router_port_interrupt_unmask(void *d, int port);
461 extern int router_port_interrupt_mask(void *d, int port);
462 extern int router_interrupt_unmask(void *d, int options);
463 extern int router_interrupt_mask(void *d, int options);
464
465 /* Router Interrupt code generation */
466 /*
467  * ROUTER ICODEGEN register fields
468  */
469 #define ICODEGEN_UA (0x1 << ICODEGEN_UA_BIT)
470 #define ICODEGEN_AH (0x1 << ICODEGEN_AH_BIT)
471 #define ICODEGEN_IT (0x1 << ICODEGEN_IT_BIT)
472 #define ICODEGEN_TE (0x1 << ICODEGEN_TE_BIT)
473 #define ICODEGEN_EN (0x1 << ICODEGEN_EN_BIT)
474 #define ICODEGEN_IN (0x1f << ICODEGEN_IN_BIT)
475
476 #define ICODEGEN_UA_BIT 20
477 #define ICODEGEN_AH_BIT 19
478 #define ICODEGEN_IT_BIT 18
479 #define ICODEGEN_TE_BIT 17
480 #define ICODEGEN_EN_BIT 16
481 #define ICODEGEN_IN_BIT 0
482
483 #define ROUTER_ICODEGEN_ITYPE_EDGE ICODEGEN_IT
484 #define ROUTER_ICODEGEN_ITYPE_LEVEL 0
485 #define ROUTER_ICODEGEN_AUTOUNACK_ENABLE ICODEGEN_UA
486 #define ROUTER_ICODEGEN_AUTOUNACK_DISABLE 0
487 #define ROUTER_ICODEGEN_AUTOACK_ENABLE ICODEGEN_AH
488 #define ROUTER_ICODEGEN_AUTOACK_DISABLE 0
489 extern int router_icodegen_enable(void *d, uint8_t intn, uint32_t aitimer,
490  int options);
491 extern int router_icodegen_disable(void *d);
492
493 /* Router interrupt change timers */
494 extern int router_isrctimer_set(void *d, uint32_t reloadvalue);
495 extern int router_isrctimer_get(void *d, uint32_t *reloadvalue);
496
497 /* Router interrupt timers */
498 extern int router_isrtimer_set(void *d, uint32_t reloadvalue);
499 extern int router_isrtimer_get(void *d, uint32_t *reloadvalue);
500
501 #ifdef __cplusplus
502 }
503 #endif
504
505 #endif
Definition: deflate.c:115
Definition: grspw_router.h:112
Definition: grspw_router.h:376
Definition: grspw_router.h:29
Definition: grspw_router.h:79
Definition: grspw_router.h:85
Definition: grspw_router.h:62
Definition: intercom.c:74
Definition: grspw_router.h:94
