RTEMS  5.1
grslink.h
1 /*
2  * Header file for RTEMS GRSLINK SLINK master driver
3  *
4  * COPYRIGHT (c) 2009.
5  * Cobham Gaisler AB.
6  *
7  * The license and distribution terms for this file may be
8  * found in the file LICENSE in this distribution or at
9  * http://www.rtems.org/license/LICENSE.
10  */
11
12 #ifndef __GRSLINK_H__
13 #define __GRSLINK_H__
14
15 #ifdef __cplusplus
16 extern "C" {
17 #endif
18
19 /**** Configuration ****/
20 /* Collect statistics ? */
21 #define SLINK_COLLECT_STATISTICS
22
23 /* Frequency of SLINK SCLK */
24 #define SLINK_FREQ_HZ 6000000
25 /* Number of queues used in driver */
26 #define SLINK_NUMQUEUES 4
27
28 /* The four values below are only used in the demo software */
29 #define SLINK_CORE_REGBASE 0x80000600
30 #define SLINK_CORE_IRQ 6
31 #define IRQ_CNTRL_REG 0x80000200
32 #define IRQ_CNTRL_MASK_OFFSET 0x40
33
34 /*
35  * Structure returned by SLINK_statistics if SLINK_COLLECT_STATISTCS has
36  * been defined
37  */
38 typedef struct {
39  unsigned int parerr; /* Number of parity errors */
40  unsigned int recov; /* Number of receive overflows */
41  unsigned int reads; /* Number of completed READs */
42  unsigned int writes; /* Number of performed WRITES */
43  unsigned int sequences; /* Number of started SEQUENCEs */
44  unsigned int seqcomp; /* Number of completed SEQUENCEs */
45  unsigned int interrupts; /* Number of INTERRUPT transfers */
46  unsigned int lostwords; /* Number of lost words due to full queue */
47 } SLINK_stats;
48
49 /**** SLINK status codes ****/
50 #define SLINK_ABORTED 0
51 #define SLINK_QFULL 1
52 #define SLINK_ACTIVE 2
53 #define SLINK_AMBAERR 3
54 #define SLINK_COMPLETED 4
55 #define SLINK_PARERR 5
56 #define SLINK_ROV 6 /* Only used internally in driver */
57
58 /**** SLINK master register fields *****/
59 /* Control register */
60 #define SLINK_C_SLEN_POS 16
61 #define SLINK_C_SRO (1 << 8)
62 #define SLINK_C_SCN_POS 4
63 #define SLINK_C_PAR (1 << 3)
64 #define SLINK_C_AS (1 << 2)
65 #define SLINK_C_SE (1 << 1)
66 #define SLINK_C_SLE (1 << 0)
67
68 /* Status register fields */
69 #define SLINK_S_SI_POS 16
70 #define SLINK_S_PERR (1 << 7)
71 #define SLINK_S_AERR (1 << 6)
72 #define SLINK_S_ROV (1 << 5)
73 #define SLINK_S_RNE (1 << 4)
74 #define SLINK_S_TNF (1 << 3)
75 #define SLINK_S_SC (1 << 2)
76 #define SLINK_S_SA (1 << 1)
77 #define SLINK_S_SRX (1 << 0)
78
79 /* Mask register fields */
80 #define SLINK_M_PERRE (1 << 7)
81 #define SLINK_M_AERRE (1 << 6)
82 #define SLINK_M_ROVE (1 << 5)
83 #define SLINK_M_RNEE (1 << 4)
84 #define SLINK_M_TNFE (1 << 3)
85 #define SLINK_M_SCE (1 << 2)
86 #define SLINK_M_SAE (1 << 1)
87 #define SLINK_M_SRXE (1 << 0)
88
89 /**** Macros ****/
90 /* Get channel field from received SLINK word */
91 #define SLINK_WRD_CHAN(x) ((x >> 16) & 0xF)
92 /* Get IO card # from received SLINK word */
93 #define SLINK_WRD_CARDNUM(x) ((x >> 21) & 0x3)
94 /* Get data part from SLINK word */
95 #define SLINK_WRD_PAYLOAD(x) (x & 0xFFFF)
96
97 /* Checks status value to see if transmit queue has free slot */
98 #define SLINK_STS_TRANSFREE(x) (x & SLINK_S_TNF)
99 /* Get Sequence Index value */
100 #define SLINK_STS_SI(x) ((x >> 16) & 0xFF)
101
102 /**** Function declarations, driver interface ****/
103 /* Initializes the SLINK core */
104 int SLINK_init(unsigned int nullwrd, int parity, int qsize,
105  void (*interrupt_trans_handler)(int),
106  void (*sequence_callback)(int));
107
108 /* Enables the core */
109 void SLINK_start(void);
110
111 /* Disables the core */
112 void SLINK_stop(void);
113
114 /* Reads one word */
115 int SLINK_read(int data, int channel, int *reply);
116
117 /* Writes one word */
118 int SLINK_write(int data, int channel);
119
120 /* Peforms a SEQUENCE */
121 int SLINK_seqstart(int *a, int *b, int n, int channel, int reconly);
122
123 /* Aborts a SEQUENCE */
124 void SLINK_seqabort(void);
125
126 /* Status of current or last SEQUENCE */
127 int SLINK_seqstatus(void);
128
129 /* Number of words transferred in last SEQUENCE */
130 int SLINK_seqwrds(void);
131
132 /* Returns value of core's status register */
133 int SLINK_hwstatus(void);
134
135 /* Returns number of elements in queue associated with IO card */
136 int SLINK_queuestatus(int iocard);
137
138 /* Take first element from queue for IO card # 'iocard' */
139 int SLINK_dequeue(int iocard, int *elem);
140
141 /* Returns structure containing core driver statistics */
142 SLINK_stats *SLINK_statistics(void);
143
144 #ifdef __cplusplus
145 }
146 #endif
147
148 #endif /* __GRSLINK_H__ */
