RTEMS
5.1
Data Structure Index
Class Hierarchy
z
z
z
z
Pages
bsps
include
grlib
grctm.h
1
/* GRCTM - CCSDS Time Manager - register driver interface.
2
3
* COPYRIGHT (c) 2009.
4
* Cobham Gaisler AB
5
6
* The license and distribution terms for this file may be
7
* found in the file LICENSE in this distribution or at
8
* http://www.rtems.org/license/LICENSE.
9
10
11
#ifndef __GRCTM_H__
12
#define __GRCTM_H__
13
14
#define DAT0_IRQ 0x1
15
#define DAT1_IRQ 0x2
16
#define DAT2_IRQ 0x4
17
#define PULSE0_IRQ 0x10
18
#define PULSE1_IRQ 0x20
19
#define PULSE2_IRQ 0x40
20
#define PULSE3_IRQ 0x80
21
#define PULSE4_IRQ 0x100
22
#define PULSE5_IRQ 0x200
23
#define PULSE6_IRQ 0x400
24
#define PULSE7_IRQ 0x800
25
26
struct
grctm_regs
27
volatile
unsigned
int
grr;
28
volatile
unsigned
int
gcr;
29
volatile
unsigned
int
gsr;
30
volatile
unsigned
int
unused[2];
31
volatile
unsigned
int
pfr;
32
volatile
unsigned
int
etcr;
33
volatile
unsigned
int
etfr;
34
volatile
unsigned
int
dcr0;
35
volatile
unsigned
int
dfr0;
36
volatile
unsigned
int
dcr1;
37
volatile
unsigned
int
dfr1;
38
volatile
unsigned
int
dcr2;
39
volatile
unsigned
int
dfr2;
40
volatile
unsigned
int
stcr;
41
volatile
unsigned
int
stfr;
42
volatile
unsigned
int
pdr[8];
43
volatile
unsigned
int
pimsr;
44
volatile
unsigned
int
pimr;
45
volatile
unsigned
int
pisr;
46
volatile
unsigned
int
pir;
47
volatile
unsigned
int
imr;
48
volatile
unsigned
int
picr;
49
volatile
unsigned
int
unused1[2];
50
volatile
unsigned
int
etir;
51
volatile
unsigned
int
fsir;
52
volatile
unsigned
int
serconf;
53
volatile
unsigned
int
unused2;
54
volatile
unsigned
int
twsc;
55
volatile
unsigned
int
twadj;
56
volatile
unsigned
int
twtx;
57
volatile
unsigned
int
twrx;
58
59
60
struct
grctm_stats
61
62
/* IRQ Stats */
63
unsigned
int
nirqs;
64
unsigned
int
pulse;
65
66
67
/* Function ISR callback prototype */
68
typedef
void (*grctm_isr_t)(
unsigned
int
pimr,
void
*data);
69
70
/* Open a GRCTM device by minor number. */
71
extern
void
*grctm_open(
int
minor);
72
73
/* Close a previously opened GRCTM device */
74
extern
void
grctm_close(
void
*spwcuc);
75
76
/* Hardware Reset of GRCTM */
77
extern
int
grctm_reset(
void
*grctm);
78
79
/* Enable Interrupts at Interrupt controller */
80
extern
void
grctm_int_enable(
void
*grctm);
81
82
/* Disable Interrupts at Interrupt controller */
83
extern
void
grctm_int_disable(
void
*grctm);
84
85
/* Clear Statistics gathered by the driver */
86
extern
void
grctm_clr_stats(
void
*grctm);
87
88
/* Get Statistics gathered by the driver */
89
extern
void
grctm_get_stats(
void
*grctm,
struct
grctm_stats
*stats);
90
91
/* Register an Interrupt handler and custom data, the function call is
92
* removed by setting func to NULL.
93
94
extern
void
grctm_int_register(
void
*grctm, grctm_isr_t func,
void
*data);
95
96
/* Enable external synchronisation (from spwcuc) */
97
extern
void
grctm_enable_ext_sync(
void
*grctm);
98
99
/* Disable external synchronisation (from spwcuc) */
100
extern
void
grctm_disable_ext_sync(
void
*grctm);
101
102
/* Enable TimeWire synchronisation */
103
extern
void
grctm_enable_tw_sync(
void
*grctm);
104
105
/* Disable TimeWire synchronisation */
106
extern
void
grctm_disable_tw_sync(
void
*grctm);
107
108
/* Disable frequency synthesizer from driving ET */
109
extern
void
grctm_disable_fs(
void
*grctm);
110
111
/* Enable frequency synthesizer to drive ET */
112
extern
void
grctm_enable_fs(
void
*grctm);
113
114
/* Return elapsed coarse time */
115
extern
unsigned
int
grctm_get_et_coarse(
void
*grctm);
116
117
/* Return elapsed fine time */
118
extern
unsigned
int
grctm_get_et_fine(
void
*grctm);
119
120
/* Return elapsed time (coarse and fine) */
121
extern
unsigned
long
long
grctm_get_et(
void
*grctm);
122
123
/* Return 1 if specified datation has been latched */
124
extern
int
grctm_is_dat_latched(
void
*grctm,
int
dat);
125
126
/* Set triggering edge of datation input */
127
extern
void
grctm_set_dat_edge(
void
*grctm,
int
dat,
int
edge);
128
129
/* Return latched datation coarse time */
130
extern
unsigned
int
grctm_get_dat_coarse(
void
*grctm,
int
dat);
131
132
/* Return latched datation fine time */
133
extern
unsigned
int
grctm_get_dat_fine(
void
*grctm,
int
dat);
134
135
/* Return latched datation ET */
136
extern
unsigned
long
long
grctm_get_dat_et(
void
*grctm,
int
dat);
137
138
/* Return current pulse configuration */
139
extern
unsigned
int
grctm_get_pulse_reg(
void
*grctm,
int
pulse);
140
141
/* Set pulse register */
142
extern
void
grctm_set_pulse_reg(
void
*grctm,
int
pulse,
unsigned
int
val);
143
144
/* Configure pulse: pp = period, pw = width, pl = level, en = enable */
145
extern
void
grctm_cfg_pulse(
void
*grctm,
int
pulse,
int
pp,
int
pw,
int
pl,
int
en);
146
147
/* Enable pulse output */
148
extern
void
grctm_enable_pulse(
void
*grctm,
int
pulse);
149
150
/* Disable pulse output */
151
extern
void
grctm_disable_pulse(
void
*grctm,
int
pulse);
152
153
/* Clear interrupts */
154
extern
void
grctm_clear_irqs(
void
*grctm,
int
irqs);
155
156
/* Enable interrupts */
157
extern
void
grctm_enable_irqs(
void
*grctm,
int
irqs);
158
159
/* Set Frequency synthesizer increment */
160
void
grctm_set_fs_incr(
void
*grctm,
int
incr);
161
162
/* Set ET increment */
163
void
grctm_set_et_incr(
void
*grctm,
int
incr);
164
165
/* Get register base address */
166
struct
grctm_regs
*grctm_get_regs(
void
*grctm);
167
168
/* Register the GRCTM driver to Driver Manager */
169
extern
void
grctm_register(
void
170
171
#endif
grctm_regs
Definition:
grctm.h:26
grctm_stats
Definition:
grctm.h:60
