RTEMS  5.1
gradcdac.h
1 /* ADC / DAC (GRADCDAC) interface
2  *
3  * COPYRIGHT (c) 2009.
4  * Cobham Gaisler AB.
5  *
6  * The license and distribution terms for this file may be
7  * found in the file LICENSE in this distribution or at
8  * http://www.rtems.org/license/LICENSE.
9  */
10
11 #ifndef __GRADCDAC_H__
12 #define __GRADCDAC_H__
13
14 #ifdef __cplusplus
15 extern "C" {
16 #endif
17
18 struct gradcdac_regs {
19  volatile unsigned int config; /* 0x00 Configuration Register */
20  volatile unsigned int status; /* 0x04 Status Register */
21  int unused0[2];
22  volatile unsigned int adc_din; /* 0x10 ADC Data Input Register */
23  volatile unsigned int dac_dout; /* 0x14 DAC Data Output Register */
24  int unused1[2];
25  volatile unsigned int adrin; /* 0x20 Address Input Register */
26  volatile unsigned int adrout; /* 0x24 Address Output Register */
27  volatile unsigned int adrdir; /* 0x28 Address Direction Register */
28  int unused2[1];
29  volatile unsigned int data_in; /* 0x30 Data Input Register */
30  volatile unsigned int data_out; /* 0x34 Data Output Register */
31  volatile unsigned int data_dir; /* 0x38 Data Direction Register */
32 };
33
34 #define GRADCDAC_CFG_DACWS 0x00f80000
35 #define GRADCDAC_CFG_WRPOL 0x00040000
36 #define GRADCDAC_CFG_DACDW 0x00030000
37 #define GRADCDAC_CFG_ADCWS 0x0000f800
38 #define GRADCDAC_CFG_RCPOL 0x00000400
39 #define GRADCDAC_CFG_CSMODE 0x00000300
40 #define GRADCDAC_CFG_CSPOL 0x00000080
41 #define GRADCDAC_CFG_RDYMODE 0x00000040
42 #define GRADCDAC_CFG_RDYPOL 0x00000020
43 #define GRADCDAC_CFG_TRIGPOL 0x00000010
44 #define GRADCDAC_CFG_TRIGMODE 0x0000000c
45 #define GRADCDAC_CFG_ADCDW 0x00000003
46
47 #define GRADCDAC_CFG_DACWS_BIT 19
48 #define GRADCDAC_CFG_WRPOL_BIT 18
49 #define GRADCDAC_CFG_DACDW_BIT 16
50 #define GRADCDAC_CFG_ADCWS_BIT 11
51 #define GRADCDAC_CFG_RCPOL_BIT 10
52 #define GRADCDAC_CFG_CSMODE_BIT 8
53 #define GRADCDAC_CFG_CSPOL_BIT 7
54 #define GRADCDAC_CFG_RDYMODE_BIT 6
55 #define GRADCDAC_CFG_RDYPOL_BIT 5
56 #define GRADCDAC_CFG_TRIGPOL_BIT 4
57 #define GRADCDAC_CFG_TRIGMODE_BIT 2
58 #define GRADCDAC_CFG_ADCDW_BIT 0
59
60 #define GRADCDAC_STATUS_DACNO 0x40
61 #define GRADCDAC_STATUS_DACRDY 0x20
62 #define GRADCDAC_STATUS_DACON 0x10
63 #define GRADCDAC_STATUS_ADCTO 0x08
64 #define GRADCDAC_STATUS_ADCNO 0x04
65 #define GRADCDAC_STATUS_ADCRDY 0x02
66 #define GRADCDAC_STATUS_ADCON 0x01
67
68 #define GRADCDAC_STATUS_DACNO_BIT 6
69 #define GRADCDAC_STATUS_DACRDY_BIT 5
70 #define GRADCDAC_STATUS_DACON_BIT 4
71 #define GRADCDAC_STATUS_ADCTO_BIT 3
72 #define GRADCDAC_STATUS_ADCNO_BIT 2
73 #define GRADCDAC_STATUS_ADCRDY_BIT 1
74 #define GRADCDAC_STATUS_ADCON_BIT 0
75
76 #define GRADCDAC_IRQ_DAC 1
77 #define GRADCDAC_IRQ_ADC 0
78
80  unsigned char dac_ws;
81  char wr_pol;
82  unsigned char dac_dw;
83  unsigned char adc_ws;
84  char rc_pol;
85  unsigned char cs_mode;
86  char cs_pol;
87  char ready_mode;
88  char ready_pol;
89  char trigg_pol;
90  unsigned char trigg_mode;
91  unsigned char adc_dw;
92 };
93
94 extern void *gradcdac_open(char *devname);
95
96 extern void gradcdac_set_config(void *cookie, struct gradcdac_config *cfg);
97
98 extern void gradcdac_get_config(void *cookie, struct gradcdac_config *cfg);
99
100 extern void gradcdac_set_cfg(void *cookie, unsigned int config);
101
102 extern unsigned int gradcdac_get_cfg(void *cookie);
103
104 extern unsigned int gradcdac_get_status(void *cookie);
105
106 static int __inline__ gradcdac_DAC_ReqRej(unsigned int status)
107 {
108  return (status & GRADCDAC_STATUS_DACNO);
109 }
110
111 static int __inline__ gradcdac_DAC_isCompleted(unsigned int status)
112 {
113  return (status & GRADCDAC_STATUS_DACRDY);
114 }
115
116 static int __inline__ gradcdac_DAC_isOngoing(unsigned int status)
117 {
118  return (status & GRADCDAC_STATUS_DACON);
119 }
120
121 static int __inline__ gradcdac_ADC_isTimeouted(unsigned int status)
122 {
123  return (status & GRADCDAC_STATUS_ADCTO);
124 }
125
126 static int __inline__ gradcdac_ADC_ReqRej(unsigned int status)
127 {
128  return (status & GRADCDAC_STATUS_ADCNO);
129 }
130
131 static int __inline__ gradcdac_ADC_isCompleted(unsigned int status)
132 {
133  return (status & GRADCDAC_STATUS_ADCRDY);
134 }
135
136 static int __inline__ gradcdac_ADC_isOngoing(unsigned int status)
137 {
138  return (status & GRADCDAC_STATUS_ADCON);
139 }
140
141 #define GRADCDAC_ISR_BOTH 3
142 #define GRADCDAC_ISR_DAC 2
143 #define GRADCDAC_ISR_ADC 1
144
145 /* Install IRQ handler for ADC and/or DAC interrupt.
146  * The installed IRQ handler(ISR) must read the status
147  * register to clear the pending interrupt avoiding multiple
148  * entries to the ISR caused by the same IRQ.
149  *
150  * \param adc 1=ADC interrupt, 2=ADC interrupt, 3=ADC and DAC interrupt
151  * \param isr Interrupt service routine called when IRQ is fired
152  * \param arg custom argument passed to ISR when called.
153  */
154 extern int gradcdac_install_irq_handler
155  (void *cookie, int adc, void (*isr)(void *cookie, void *arg), void *arg);
156
157 extern void gradcdac_uninstall_irq_handler(void *cookie, int adc);
158
159 /* Make the ADC circuitry initialize a analogue to digital
160  * conversion. The result can be read out by gradcdac_adc_convert_try
161  * or gradcdac_adc_convert.
162  */
163 extern void gradcdac_adc_convert_start(void *cookie);
164
165 /* Tries to read the conversion result. If the circuitry is busy
166  * converting the function return a non-zero value, if the conversion
167  * has successfully finished the function return zero.
168  *
169  * \param digital_value the resulting converted value is placed here
170  * \return zero = ADC conversion complete, digital_value contain current conversion result
171  * positive = ADC busy, digital_value contain previous conversion result
172  * negative = Conversion request failed.
173  */
174 extern int gradcdac_adc_convert_try(void *cookie, unsigned short *digital_value);
175
176 /* Waits until the ADC circuity has finished a digital to analogue
177  * conversion. The Waiting is implemented as a busy loop utilizing
178  * 100% CPU load.
179  *
180  * \return zero = Conversion ok
181  * negative = Conversion request failed.
182  */
183 extern int gradcdac_adc_convert(void *cookie, unsigned short *digital_value);
184
185 /* Try to make the DAC circuitry initialize a digital to analogue
186  * conversion. If the circuitry is busy by a previous conversion
187  * the function return a non-zero value, if the conversion is
188  * successfully initialized the function return zero.
189  */
190 extern int gradcdac_dac_convert_try(void *cookie, unsigned short digital_value);
191
192 /* Initializes a digital to analogue conversion by waiting until
193  * previous conversions is finished before procceding with the
194  * conversion. The Waiting is implemented as a busy loop utilizing
195  * 100% CPU load.
196  */
197 extern void gradcdac_dac_convert(void *cookie, unsigned short digital_value);
198
199 extern unsigned int gradcdac_get_adrinput(void *cookie);
200 extern void gradcdac_set_adrinput(void *cookie, unsigned int input);
201
202 extern unsigned int gradcdac_get_adroutput(void *cookie);
203 extern void gradcdac_set_adroutput(void *cookie, unsigned int output);
204
205 extern unsigned int gradcdac_get_adrdir(void *cookie);
206 extern void gradcdac_set_adrdir(void *cookie, unsigned int dir);
207
208 extern unsigned int gradcdac_get_datainput(void *cookie);
209 extern void gradcdac_set_datainput(void *cookie, unsigned int input);
210
211 extern unsigned int gradcdac_get_dataoutput(void *cookie);
212 extern void gradcdac_set_dataoutput(void *cookie, unsigned int output);
213
214 extern unsigned int gradcdac_get_datadir(void *cookie);
215 extern void gradcdac_set_datadir(void *cookie, unsigned int dir);
216
217 /* Show one or all GRADCDAC cores. If cookie is NULL all GRADCDAC's are shown */
218 extern void grAdcDacShow(void *cookie);
219
220 /* Register Driver routine */
221 extern void gradcdac_register_drv (void);
222
223 #ifdef __cplusplus
224 }
225 #endif
226
227 #endif
Definition: deflate.c:115
Definition: gradcdac.h:18
Definition: gradcdac.h:79
