RTEMS  5.1
gr_rasta_adcdac.h
1 /* GR-RASTA-ADCDAC PCI Target driver.
2  *
3  * COPYRIGHT (c) 2008.
4  * Cobham Gaisler AB.
5  *
6  * Configures the GR-RASTA-ADCDAC interface PCI board.
7  * This driver provides a AMBA PnP bus by using the general part
8  * of the AMBA PnP bus driver (ambapp_bus.c).
9  *
10  * Driver resources for the AMBA PnP bus provided can be set using
11  * gr_rasta_adcdac_set_resources().
12  *
13  * The license and distribution terms for this file may be
14  * found in found in the file LICENSE in this distribution or at
15  * http://www.rtems.org/license/LICENSE.
16  */
17
18 #ifndef __GR_RASTA_ADCDAC_H__
19 #define __GR_RASTA_ADCDAC_H__
20
21 #include <drvmgr/drvmgr.h>
22
23 #ifdef __cplusplus
24 extern "C" {
25 #endif
26
27 /* An array of pointers to GR-RASTA-ADCDAC resources. The resources will be
28  * used by the drivers controlling the cores on the GR-RASTA-ADCDAC target AMBA bus.
29  *
30  * The gr_rasta_adcdac_resources is declared weak so that the user can override
31  * the default configuration. The array must be terminated with a NULL resource.
32  */
33 extern struct drvmgr_bus_res *gr_rasta_adcdac_resources[];
34
35 /* Options to gr_rasta_io_print function */
36 #define RASTA_ADCDAC_OPTIONS_AMBA 0x01 /* Print AMBA bus devices */
37 #define RASTA_ADCDAC_OPTIONS_IRQ 0x02 /* Print current IRQ setup */
38
39 /* Print information about all GR-RASTA-IO PCI boards */
40 void gr_rasta_adcdac_print(int options);
41
42 /* Print information about one GR-RASTA-IO PCI board */
43 void gr_rasta_adcdac_print_dev(struct drvmgr_dev *dev, int options);
44
45 /* Register GR-RASTA-IO driver */
46 void gr_rasta_adcdac_register_drv(void);
47
48 #ifdef __cplusplus
49 }
50 #endif
51
52 #endif
Definition: drvmgr.h:214
Definition: drvmgr.h:275
