RTEMS  5.1
gpiolib.h
1 /* GPIO Library interface
2  *
3  * COPYRIGHT (c) 2009.
4  * Cobham Gaisler AB.
5  *
6  * The license and distribution terms for this file may be
7  * found in the file LICENSE in this distribution or at
8  * http://www.rtems.org/license/LICENSE.
9  */
10
11 #ifndef __GPIOLIB_H__
12 #define __GPIOLIB_H__
13
14 #ifdef __cplusplus
15 extern "C" {
16 #endif
17
18 /* GPIO Config of one GPIO port */
20  char mask; /* 0=Masked/1=Unmasked IRQ */
21  char irq_level; /* Edge or Level triggered IRQ */
22  char irq_polarity; /* Polarity of IRQ */
23 };
24
25 #define GPIOLIB_IRQ_EDGE 0
26 #define GPIOLIB_IRQ_LEVEL 1
27
28 #define GPIOLIB_IRQ_POL_LOW 0
29 #define GPIOLIB_IRQ_POL_HIGH 1
30
31 /* Libarary initialize function must be called befor any other */
32 extern int gpiolib_initialize(void);
33
34 /*** User Interface ***/
35
36 extern void *gpiolib_open(int port);
37 extern void *gpiolib_open_by_name(char *devName);
38 extern void gpiolib_close(void *handle);
39
40 /* Show the current status one or all GPIO ports in the system.
41  * Int port is port nunber, if port = -1 selects all ports.
42  *
43  * If port != -1, handle is used to get port.
44  * If port != -1, handle == NULL, then port is used as port number
45  */
46 extern void gpiolib_show(int port, void *handle);
47
48 extern int gpiolib_set_config(void *handle, struct gpiolib_config *cfg);
49 extern int gpiolib_set(void *handle, int dir, int val);
50 extern int gpiolib_get(void *handle, int *inval);
51 extern int gpiolib_irq_clear(void *handle);
52 extern int gpiolib_irq_enable(void *handle);
53 extern int gpiolib_irq_disable(void *handle);
54 extern int gpiolib_irq_mask(void *handle);
55 extern int gpiolib_irq_unmask(void *handle);
56 extern int gpiolib_irq_force(void *handle);
57 extern int gpiolib_irq_register(void *handle, void *func, void *arg);
58
59 /*** Driver Interface ***/
60
61 struct gpiolib_info {
62  char devName[64];
63 };
64
66  int (*config)(void *handle, struct gpiolib_config *cfg);
67  int (*get)(void *handle, int *val);
68  int (*irq_opts)(void *handle, unsigned int options);
69  int (*irq_register)(void *handle, void *func, void *arg);
70  int (*open)(void *handle);
71  int (*set)(void *handle, int dir, int outval);
72  int (*show)(void *handle);
73  int (*get_info)(void *handle, struct gpiolib_info *pinfo);
74 };
75
76 #define GPIOLIB_IRQ_ENABLE 0x01
77 #define GPIOLIB_IRQ_DISABLE 0x02
78 #define GPIOLIB_IRQ_CLEAR 0x04
79 #define GPIOLIB_IRQ_FORCE 0x08
80 #define GPIOLIB_IRQ_MASK 0x10
81 #define GPIOLIB_IRQ_UNMASK 0x20
82
83 struct gpiolib_drv {
84  struct gpiolib_drv_ops *ops;
85 };
86
87 /* Register a GPIO port */
88 extern int gpiolib_drv_register(struct gpiolib_drv *drv, void *handle);
89
90 #ifdef __cplusplus
91 }
92 #endif
93
94 #endif
Definition: deflate.c:115
Definition: gpiolib.h:83
Definition: gpiolib.h:65
Definition: gpiolib.h:19
int open(const char *path, int oflag,...)
Definition: open.c:149
Definition: gpiolib.h:61
