RTEMS  5.1
gpio.h
1
9 /*
10  * Copyright (c) 2014-2015 Andre Marques <andre.lousa.marques at gmail.com>
11  *
12  * The license and distribution terms for this file may be
13  * found in the file LICENSE in this distribution or at
14  * http://www.rtems.org/license/LICENSE.
15  */
16
17 #ifndef LIBBSP_SHARED_GPIO_H
18 #define LIBBSP_SHARED_GPIO_H
19
20 #include <bsp.h>
21 #include <rtems.h>
22
23 #ifdef __cplusplus
24 extern "C" {
25 #endif /* __cplusplus */
26
27 #if !defined(BSP_GPIO_PIN_COUNT) || !defined(BSP_GPIO_PINS_PER_BANK)
28  #error "BSP_GPIO_PIN_COUNT or BSP_GPIO_PINS_PER_BANK is not defined."
29 #endif
30
31 #if BSP_GPIO_PIN_COUNT <= 0 || BSP_GPIO_PINS_PER_BANK <= 0
32  #error "Invalid BSP_GPIO_PIN_COUNT or BSP_GPIO_PINS_PER_BANK."
33 #endif
34
35 #if BSP_GPIO_PINS_PER_BANK > 32
36  #error "Invalid BSP_GPIO_PINS_PER_BANK. Must be in the range of 1 to 32."
37 #endif
38
39 #define GPIO_LAST_BANK_PINS BSP_GPIO_PIN_COUNT % BSP_GPIO_PINS_PER_BANK
40
41 #if GPIO_LAST_BANK_PINS > 0
42  #define GPIO_BANK_COUNT (BSP_GPIO_PIN_COUNT / BSP_GPIO_PINS_PER_BANK) + 1
43 #else
44  #define GPIO_BANK_COUNT BSP_GPIO_PIN_COUNT / BSP_GPIO_PINS_PER_BANK
45  #undef GPIO_LAST_BANK_PINS
46  #define GPIO_LAST_BANK_PINS BSP_GPIO_PINS_PER_BANK
47 #endif
48
49 #if defined(BSP_GPIO_PINS_PER_SELECT_BANK) && BSP_GPIO_PINS_PER_SELECT_BANK > 32
50  #error "Invalid BSP_GPIO_PINS_PER_SELECT_BANK. Must under and including 32."
51 #elif defined(BSP_GPIO_PINS_PER_SELECT_BANK) <= 32
52  #define GPIO_SELECT_BANK_COUNT \
53  BSP_GPIO_PINS_PER_BANK / BSP_GPIO_PINS_PER_SELECT_BANK
54 #endif
55
56 #define INTERRUPT_SERVER_PRIORITY 1
57 #define INTERRUPT_SERVER_STACK_SIZE 2 * RTEMS_MINIMUM_STACK_SIZE
58 #define INTERRUPT_SERVER_MODES RTEMS_TIMESLICE | RTEMS_PREEMPT
59 #define INTERRUPT_SERVER_ATTRIBUTES RTEMS_DEFAULT_ATTRIBUTES
60
61 #define GPIO_INPUT_ERROR ~0
62
75 typedef enum
76 {
77  PULL_UP = 1,
78  PULL_DOWN,
79  NO_PULL_RESISTOR
81
87 typedef enum
88 {
89  DIGITAL_INPUT = 0,
91  BSP_SPECIFIC,
92  NOT_USED
94
100 typedef enum
101 {
102  FALLING_EDGE = 0,
103  RISING_EDGE,
104  LOW_LEVEL,
105  HIGH_LEVEL,
106  BOTH_EDGES,
107  BOTH_LEVELS,
108  NONE
110
117 typedef enum
118 {
119  IRQ_HANDLED,
120  IRQ_NONE
122
129 typedef enum
130 {
131  SHARED_HANDLER,
132  UNIQUE_HANDLER
134
141 typedef struct
142 {
143  /* The BSP defined function code. */
144  uint32_t io_function;
145
146  void *pin_data;
148
153 typedef struct
154 {
155  rtems_gpio_interrupt active_interrupt;
156
157  rtems_gpio_handler_flag handler_flag;
158
159  bool threaded_interrupts;
160
161  /* Interrupt handler function. */
162  rtems_gpio_irq_state (*handler) (void *arg);
163
164  /* Interrupt handler function arguments. */
165  void *arg;
166
167  /* Software switch debounce settings. It should contain the amount of clock
168  * ticks that must pass between interrupts to ensure that the interrupt
169  * was not caused by a switch bounce.
170  * If set to 0 this feature is disabled . */
171  uint32_t debounce_clock_tick_interval;
173
178 typedef struct
179 {
180  /* Processor pin number. */
181  uint32_t pin_number;
182  rtems_gpio_function function;
183
184  /* Pull resistor setting. */
185  rtems_gpio_pull_mode pull_mode;
186
187  /* If digital out pin, set to TRUE to set the pin to logical high,
188  * or FALSE for logical low. If not a digital out then this
189  * is ignored. */
190  bool output_enabled;
191
192  /* If true inverts digital in/out applicational logic. */
193  bool logic_invert;
194
195  /* Pin interrupt configuration. Should be NULL if not used. */
197
198  /* Structure with BSP specific data, to use during the pin request.
199  * If function == BSP_SPECIFIC this should have a pointer to
200  * a rtems_gpio_specific_data structure.
201  *
202  * If not this field may be NULL. This is passed to the BSP function
203  * so any BSP specific data can be passed to it through this pointer. */
204  void *bsp_specific;
206
212 typedef struct
213 {
214  /* Global GPIO pin number. */
215  uint32_t pin_number;
216
217  /* RTEMS GPIO pin function code. */
218  rtems_gpio_function function;
219
220  /* BSP specific function code. Only used if function == BSP_SPECIFIC */
221  uint32_t io_function;
222
223  /* BSP specific data. */
224  void *bsp_specific;
226
231 typedef struct
232 {
233  const rtems_gpio_pin_conf *digital_inputs;
234  uint32_t input_count;
235
236  const rtems_gpio_pin_conf *digital_outputs;
237  uint32_t output_count;
238
239  const rtems_gpio_pin_conf *bsp_specifics;
240  uint32_t bsp_specific_pin_count;
242
247
263
271
287 extern rtems_status_code rtems_gpio_define_pin_group(
288  const rtems_gpio_group_definition *group_definition,
289  rtems_gpio_group *group
290 );
291
304  uint32_t data,
305  rtems_gpio_group *group
306 );
307
318 extern uint32_t rtems_gpio_read_group(rtems_gpio_group *group);
319
334  rtems_gpio_group *group,
335  void *arg
336 );
337
348  const rtems_gpio_pin_conf *conf
349 );
350
363  const rtems_gpio_pin_conf *conf
364 );
365
379  uint32_t *pin_numbers,
380  uint32_t pin_count
381 );
382
396  uint32_t *pin_numbers,
397  uint32_t pin_count
398 );
399
410 extern uint32_t rtems_gpio_multi_read(
411  uint32_t *pin_numbers,
412  uint32_t pin_count
413 );
414
426 extern rtems_status_code rtems_gpio_set(uint32_t pin_number);
427
439 extern rtems_status_code rtems_gpio_clear(uint32_t pin_number);
440
450 extern int rtems_gpio_get_value(uint32_t pin_number);
451
470 extern rtems_status_code rtems_gpio_multi_select(
471  const rtems_gpio_pin_conf *pins,
472  uint8_t pin_count
473 );
474
494 extern rtems_status_code rtems_gpio_request_pin(
495  uint32_t pin_number,
496  rtems_gpio_function function,
497  bool output_enable,
498  bool logic_invert,
499  void *bsp_specific
500 );
501
513  uint32_t pin_number,
515 );
516
527 extern rtems_status_code rtems_gpio_release_pin(uint32_t pin_number);
528
539  const rtems_gpio_pin_conf *conf
540 );
541
552 extern rtems_status_code rtems_gpio_release_multiple_pins(
553  const rtems_gpio_pin_conf *pins,
554  uint32_t pin_count
555 );
556
568  rtems_gpio_group *group
569 );
570
590  uint32_t pin_number,
591  int ticks
592 );
593
614  uint32_t pin_number,
615  rtems_gpio_irq_state (*handler) (void *arg),
616  void *arg
617 );
618
646 extern rtems_status_code rtems_gpio_enable_interrupt(
647  uint32_t pin_number,
648  rtems_gpio_interrupt interrupt,
650  bool threaded_handling,
651  rtems_gpio_irq_state (*handler) (void *arg),
652  void *arg
653 );
654
670  uint32_t pin_number,
671  rtems_gpio_irq_state (*handler) (void *arg),
672  void *arg
673 );
674
689 extern rtems_status_code rtems_gpio_disable_interrupt(uint32_t pin_number);
690
702  uint32_t bank,
703  uint32_t bitmask
704 );
705
717  uint32_t bank,
718  uint32_t bitmask
719 );
720
732 extern uint32_t rtems_gpio_bsp_multi_read(uint32_t bank, uint32_t bitmask);
733
751 extern rtems_status_code rtems_gpio_bsp_specific_group_operation(
752  uint32_t bank,
753  uint32_t *pins,
754  uint32_t pin_count,
755  void *arg
756 );
757
775 extern rtems_status_code rtems_gpio_bsp_multi_select(
777  uint32_t pin_count,
778  uint32_t select_bank
779 );
780
791 extern rtems_status_code rtems_gpio_bsp_set(uint32_t bank, uint32_t pin);
792
803 extern rtems_status_code rtems_gpio_bsp_clear(uint32_t bank, uint32_t pin);
804
816 extern uint32_t rtems_gpio_bsp_get_value(uint32_t bank, uint32_t pin);
817
831  uint32_t bank,
832  uint32_t pin,
833  void *bsp_specific
834 );
835
849  uint32_t bank,
850  uint32_t pin,
851  void *bsp_specific
852 );
853
868  uint32_t bank,
869  uint32_t pin,
870  uint32_t function,
871  void *pin_data
872 );
873
886  uint32_t bank,
887  uint32_t pin,
889 );
890
903 extern uint32_t rtems_gpio_bsp_interrupt_line(rtems_vector_number vector);
904
913 extern rtems_vector_number rtems_gpio_bsp_get_vector(uint32_t bank);
914
927  uint32_t bank,
928  uint32_t pin,
929  rtems_gpio_interrupt interrupt
930 );
931
944  uint32_t bank,
945  uint32_t pin,
946  rtems_gpio_interrupt interrupt
947 );
948
951 #ifdef __cplusplus
952 }
953 #endif /* __cplusplus */
954
955 #endif /* LIBBSP_SHARED_GPIO_H */
uint32_t rtems_gpio_multi_read(uint32_t *pin_numbers, uint32_t pin_count)
Returns the value (level) of multiple GPIO input pins.
Definition: gpio-support.c:1149
Reads the value/level of the group's digital inputs. The pins order is as defined in the group defini...
Definition: gpio-support.c:905
rtems_status_code rtems_gpio_bsp_enable_interrupt(uint32_t bank, uint32_t pin, rtems_gpio_interrupt interrupt)
Enables interrupts to be generated on a given GPIO pin. This must be implemented by each BSP.
Definition: rpi-gpio.c:192
rtems_status_code rtems_gpio_group_bsp_specific_operation(rtems_gpio_group *group, void *arg)
Performs a BSP specific operation on a group of pins. The pins order is as defined in the group defin...
Definition: gpio-support.c:941
Reads and returns a vector/bank interrupt event line. The bitmask should indicate with a 1 if the cor...
Definition: rpi-gpio.c:179
The set of possible handled states an user-defined interrupt handler can return.
Definition: gpio.h:117
rtems_status_code rtems_gpio_bsp_select_specific_io(uint32_t bank, uint32_t pin, uint32_t function, void *pin_data)
Assigns a BSP specific function to the given pin. This must be implemented by each BSP.
Definition: rpi-gpio.c:128
rtems_status_code rtems_gpio_update_configuration(const rtems_gpio_pin_conf *conf)
Updates the current configuration of a GPIO pin .
Definition: gpio-support.c:1008
rtems_status_code rtems_gpio_bsp_multi_clear(uint32_t bank, uint32_t bitmask)
Sets multiple output GPIO pins with the logical low. This must be implemented by each BSP.
Definition: rpi-gpio.c:81
rtems_status_code rtems_gpio_bsp_select_input(uint32_t bank, uint32_t pin, void *bsp_specific)
Assigns the digital input function to the given pin. This must be implemented by each BSP.
Definition: rpi-gpio.c:112
Object containing configuration information regarding interrupts.
Definition: gpio.h:153
rtems_status_code rtems_gpio_release_pin_group(rtems_gpio_group *group)
Releases a GPIO pin group, making the pins used available to be repurposed.
Definition: gpio-support.c:1498
rtems_status_code rtems_gpio_bsp_set_resistor_mode(uint32_t bank, uint32_t pin, rtems_gpio_pull_mode mode)
Configures a single GPIO pin pull resistor. This must be implemented by each BSP.
Definition: rpi-gpio.c:137
rtems_status_code rtems_gpio_resistor_mode(uint32_t pin_number, rtems_gpio_pull_mode mode)
Definition: gpio-support.c:1383
Returns the value (level) of a GPIO input pin.
Definition: gpio-support.c:1253
rtems_gpio_group * rtems_gpio_create_pin_group(void)
Instantiates a GPIO pin group. To define the group.
Definition: gpio-support.c:680
Releases a GPIO pin, making it available to be used again.
Definition: gpio-support.c:1428
Sets an output GPIO pin with the logical high.
Definition: gpio-support.c:1173
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
Object containing configuration information to request/update a GPIO pin.
Definition: gpio.h:178
Sets an output GPIO pin with the logical high. This must be implemented by each BSP.
Definition: rpi-gpio.c:93
rtems_status_code
Classic API Status.
Definition: status.h:43
Object containing configuration information to assign GPIO functions to multiple pins at the same tim...
Definition: gpio.h:212
Sets an output GPIO pin with the logical low. This must be implemented by each BSP.
Definition: rpi-gpio.c:100
rtems_status_code rtems_gpio_interrupt_handler_install(uint32_t pin_number, rtems_gpio_irq_state(*handler)(void *arg), void *arg)
Connects a new user-defined interrupt handler to a given pin.
Definition: gpio-support.c:1602
rtems_gpio_function
The set of possible functions a pin can have.
Definition: gpio.h:87
Object containing relevant information for assigning a BSP specific function to a pin.
Definition: gpio.h:141
The set of possible interrupts a GPIO pin can generate.
Definition: gpio.h:100
The set of possible configurations for a GPIO pull-up resistor.
Definition: gpio.h:75
Calculates a vector number for a given GPIO bank. This must be implemented by each BSP.
Definition: rpi-gpio.c:174
rtems_status_code rtems_gpio_bsp_disable_interrupt(uint32_t bank, uint32_t pin, rtems_gpio_interrupt interrupt)
Stops interrupts from being generated on a given GPIO pin. This must be implemented by each BSP.
Definition: rpi-gpio.c:236
Assigns a certain function to a GPIO pin.
Definition: gpio.h:90
Object containing relevant information about a GPIO group.
Definition: gpio-support.c:55
rtems_status_code rtems_gpio_initialize(void)
Initializes the GPIO API.
Definition: gpio-support.c:640
Definition: gpio-support.c:1213
Returns the value (level) of a GPIO input pin. This must be implemented by each BSP.
Definition: rpi-gpio.c:107
Stops interrupts from being generated on a given GPIO pin and removes the corresponding handler.
Definition: gpio-support.c:1888
Returns the value (level) of multiple GPIO input pins. This must be implemented by each BSP.
Definition: rpi-gpio.c:88
rtems_status_code rtems_gpio_bsp_multi_set(uint32_t bank, uint32_t bitmask)
Sets multiple output GPIO pins with the logical high. This must be implemented by each BSP.
Definition: rpi-gpio.c:74
rtems_status_code rtems_gpio_bsp_select_output(uint32_t bank, uint32_t pin, void *bsp_specific)
Assigns the digital output function to the given pin. This must be implemented by each BSP.
Definition: rpi-gpio.c:120
rtems_status_code rtems_gpio_write_group(uint32_t data, rtems_gpio_group *group)
Writes a value to the group's digital outputs. The pins order is as defined in the group definition.
Definition: gpio-support.c:840
rtems_status_code rtems_gpio_interrupt_handler_remove(uint32_t pin_number, rtems_gpio_irq_state(*handler)(void *arg), void *arg)
Disconnects an user-defined interrupt handler from the given pin. If in the end there are no more use...
Definition: gpio-support.c:1826
rtems_status_code rtems_gpio_multi_set(uint32_t *pin_numbers, uint32_t pin_count)
Definition: gpio-support.c:1103
The set of flags to specify an user-defined interrupt handler uniqueness on a GPIO pin.
Definition: gpio.h:129
rtems_status_code rtems_gpio_request_configuration(const rtems_gpio_pin_conf *conf)
Requests a GPIO pin configuration.
Definition: gpio-support.c:980
Object containing configuration information to request a GPIO pin group.
Definition: gpio.h:231
rtems_status_code rtems_gpio_debounce_switch(uint32_t pin_number, int ticks)
Attaches a debouncing function to a given pin/switch. Debouncing is done by requiring a certain numbe...
Definition: gpio-support.c:1567
rtems_status_code rtems_gpio_release_configuration(const rtems_gpio_pin_conf *conf)
Definition: gpio-support.c:1466
rtems_status_code rtems_gpio_multi_clear(uint32_t *pin_numbers, uint32_t pin_count)
Definition: gpio-support.c:1126
