RTEMS  5.1
generic_or1k.h
1
9 /*
10  * COPYRIGHT (c) 2014-2015 Hesham ALMatary <heshamelmatary@gmail.com>
11  *
12  * The license and distribution terms for this file may be
13  * found in the file LICENSE in this distribution or at
14  * http://www.rtems.org/license/LICENSE
15  */
16
17 #ifndef LIBBSP_GENERIC_OR1K_H
18 #define LIBBSP_GENERIC_OR1K_H
19
20 #include <stdint.h>
21
38  #define OR1K_REG(x) (*((volatile unsigned char *) (x)))
39  #define OR1K_BIT(n) (1 << (n))
40
48 #define OR1K_BSP_CLOCK_FREQ 50000000UL
49 #define OR1K_BSP_UART_BASE 0x90000000
50
51 #define OR1K_BSP_UART_REG_TX (OR1K_BSP_UART_BASE+0)
52 #define OR1K_BSP_UART_REG_RX (OR1K_BSP_UART_BASE+0)
53 #define OR1K_BSP_UART_REG_DEV_LATCH_LOW (OR1K_BSP_UART_BASE+0)
54 #define OR1K_BSP_UART_REG_DEV_LATCH_HIGH (OR1K_BSP_UART_BASE+1)
55 #define OR1K_BSP_UART_REG_INT_ENABLE (OR1K_BSP_UART_BASE+1)
56 #define OR1K_BSP_UART_REG_INT_ID (OR1K_BSP_UART_BASE+2)
57 #define OR1K_BSP_UART_REG_FIFO_CTRL (OR1K_BSP_UART_BASE+2)
58 #define OR1K_BSP_UART_REG_LINE_CTRL (OR1K_BSP_UART_BASE+3)
59 #define OR1K_BSP_UART_REG_MODEM_CTRL (OR1K_BSP_UART_BASE+4)
60 #define OR1K_BSP_UART_REG_LINE_STATUS (OR1K_BSP_UART_BASE+5)
61 #define OR1K_BSP_UART_REG_MODEM_STATUS (OR1K_BSP_UART_BASE+6)
62 #define OR1K_BSP_UART_REG_SCRATCH (OR1K_BSP_UART_BASE+7)
63
64 /* FIFO Control Register */
65 #define OR1K_BSP_UART_REG_FIFO_CTRL_TRIGGER_1 (0x00)
66 #define OR1K_BSP_UART_REG_FIFO_CTRL_ENABLE_FIFO (0x01)
67 #define OR1K_BSP_UART_REG_FIFO_CTRL_CLEAR_RCVR (0x02)
68 #define OR1K_BSP_UART_REG_FIFO_CTRL_CLEAR_XMIT (0x03)
69 #define OR1K_BSP_UART_REG_FIFO_CTRL_DMA_SELECT (0x08)
70 #define OR1K_BSP_UART_REG_FIFO_CTRL_TRIGGER_4 (0x40)
71 #define OR1K_BSP_UART_REG_FIFO_CTRL_TRIGGER_8 (0x80)
72 #define OR1K_BSP_UART_REG_FIFO_CTRL_TRIGGER_14 (0xC0)
73 #define OR1K_BSP_UART_REG_FIFO_CTRL_TRIGGER_MASK (0xC0)
74
75 /* Line Control Register */
76 #define OR1K_BSP_UART_REG_LINE_CTRL_WLEN5 (0x00)
77 #define OR1K_BSP_UART_REG_LINE_CTRL_WLEN6 (0x01)
78 #define OR1K_BSP_UART_REG_LINE_CTRL_WLEN7 (0x02)
79 #define OR1K_BSP_UART_REG_LINE_CTRL_WLEN8 (0x03)
80 #define OR1K_BSP_UART_REG_LINE_CTRL_STOP (0x04)
81 #define OR1K_BSP_UART_REG_LINE_CTRL_PARITY (0x08)
82 #define OR1K_BSP_UART_REG_LINE_CTRL_EPAR (0x10)
83 #define OR1K_BSP_UART_REG_LINE_CTRL_SPAR (0x20)
84 #define OR1K_BSP_UART_REG_LINE_CTRL_SBC (0x40)
85 #define OR1K_BSP_UART_REG_LINE_CTRL_DLAB (0x80)
86
87 /* Line Status Register */
88 #define OR1K_BSP_UART_REG_LINE_STATUS_DR (0x01)
89 #define OR1K_BSP_UART_REG_LINE_STATUS_OE (0x02)
90 #define OR1K_BSP_UART_REG_LINE_STATUS_PE (0x04)
91 #define OR1K_BSP_UART_REG_LINE_STATUS_FE (0x08)
92 #define OR1K_BSP_UART_REG_LINE_STATUS_BI (0x10)
93 #define OR1K_BSP_UART_REG_LINE_STATUS_THRE (0x20)
94 #define OR1K_BSP_UART_REG_LINE_STATUS_TEMT (0x40)
95
96 /* Modem Control Register */
97 #define OR1K_BSP_UART_REG_MODEM_CTRL_DTR (0x01)
98 #define OR1K_BSP_UART_REG_MODEM_CTRL_RTS (0x02)
99 #define OR1K_BSP_UART_REG_MODEM_CTRL_OUT1 (0x04)
100 #define OR1K_BSP_UART_REG_MODEM_CTRL_OUT2 (0x08)
101 #define OR1K_BSP_UART_REG_MODEM_CTRL_LOOP (0x10)
102
103 /* Modem Status Register */
104 #define OR1K_BSP_UART_REG_MODEM_STATUS_DCTS (0x01)
105 #define OR1K_BSP_UART_REG_MODEM_STATUS_DDSR (0x02)
106 #define OR1K_BSP_UART_REG_MODEM_STATUS_TERI (0x04)
107 #define OR1K_BSP_UART_REG_MODEM_STATUS_DDCD (0x08)
108 #define OR1K_BSP_UART_REG_MODEM_STATUS_CTS (0x10)
109 #define OR1K_BSP_UART_REG_MODEM_STATUS_DSR (0x20)
110 #define OR1K_BSP_UART_REG_MODEM_STATUS_RI (0x40)
111 #define OR1K_BSP_UART_REG_MODEM_STATUS_DCD (0x80)
112 #define OR1K_BSP_UART_REG_MODEM_STATUS_ANY_DELTA (0x0F)
113
118 #endif /* LIBBSP_GENERIC_OR1K_H */
