RTEMS  5.1
ofw_tree.h
1 /*
2  * Copyright (c) 2006 Jakub Jermar
3  * All rights reserved.
4  *
5  * Redistribution and use in source and binary forms, with or without
6  * modification, are permitted provided that the following conditions
7  * are met:
8  *
9  * - Redistributions of source code must retain the above copyright
10  * notice, this list of conditions and the following disclaimer.
11  * - Redistributions in binary form must reproduce the above copyright
12  * notice, this list of conditions and the following disclaimer in the
13  * documentation and/or other materials provided with the distribution.
14  * - The name of the author may not be used to endorse or promote products
15  * derived from this software without specific prior written permission.
16  *
17  * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
18  * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
19  * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
20  * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
21  * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
22  * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
23  * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
24  * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
25  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
26  * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
27  */
28
29 #ifndef KERN_OFW_TREE_H_
30 #define KERN_OFW_TREE_H_
31
32 #include <arch/types.h>
33 #include <typedefs.h>
34
35 #define OFW_TREE_PROPERTY_MAX_NAMELEN 32
36
38 typedef struct {
39  char name[OFW_TREE_PROPERTY_MAX_NAMELEN];
40  size_t size;
41  void *value;
43
45 typedef struct ofw_tree_node {
46  struct ofw_tree_node *parent;
47  struct ofw_tree_node *peer;
48  struct ofw_tree_node *child;
49
50  uint32_t node_handle;
52  char *da_name;
54  unsigned int properties;
55  ofw_tree_property_t *property;
56
61  void *device;
63
64 /* Walker for visiting OpenFirmware device tree nodes. */
65 typedef bool (* ofw_tree_walker_t)(ofw_tree_node_t *, void *);
66
67 extern void ofw_tree_init(ofw_tree_node_t *);
68 extern void ofw_tree_print(void);
69
70 extern const char *ofw_tree_node_name(const ofw_tree_node_t *);
71 extern ofw_tree_node_t *ofw_tree_lookup(const char *);
72 extern ofw_tree_property_t *ofw_tree_getprop(const ofw_tree_node_t *,
73  const char *);
74 extern void ofw_tree_walk_by_device_type(const char *, ofw_tree_walker_t,
75  void *);
76
77 extern ofw_tree_node_t *ofw_tree_find_child(ofw_tree_node_t *, const char *);
78 extern ofw_tree_node_t *ofw_tree_find_child_by_device_type(ofw_tree_node_t *,
79  const char *);
80
81 extern ofw_tree_node_t *ofw_tree_find_peer_by_device_type(ofw_tree_node_t *,
82  const char *);
83 extern ofw_tree_node_t *ofw_tree_find_peer_by_name(ofw_tree_node_t *,
84  const char *);
85 extern ofw_tree_node_t *ofw_tree_find_node_by_handle(ofw_tree_node_t *,
86  uint32_t);
87
88 #endif
Definition: ofw_tree.h:44
Definition: ofw_tree.h:53
char * da_name
Definition: ofw_tree.h:51
Definition: ofw_tree.h:37
void * device
Definition: ofw_tree.h:56
Definition: ofw_tree.h:49
unsigned size
Definition: tte.h:74
