RTEMS  5.1
fts.h
1 /* $NetBSD: fts.h,v 1.14 2005/09/13 01:44:32 christos Exp $ */
2
3 /*
4  * Copyright (c) 1989, 1993
5  * The Regents of the University of California. All rights reserved.
6  *
7  * Redistribution and use in source and binary forms, with or without
8  * modification, are permitted provided that the following conditions
9  * are met:
10  * 1. Redistributions of source code must retain the above copyright
11  * notice, this list of conditions and the following disclaimer.
12  * 2. Redistributions in binary form must reproduce the above copyright
13  * notice, this list of conditions and the following disclaimer in the
14  * documentation and/or other materials provided with the distribution.
15  * 3. Neither the name of the University nor the names of its contributors
16  * may be used to endorse or promote products derived from this software
17  * without specific prior written permission.
18  *
19  * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
20  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
21  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
22  * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
23  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
24  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
25  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
26  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
27  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
28  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
29  * SUCH DAMAGE.
30  *
31  * @(#)fts.h 8.3 (Berkeley) 8/14/94
32  */
33
34 #ifndef _FTS_H_
35 #define _FTS_H_
36
37 #ifndef __fts_stat_t
38 #define __fts_stat_t struct stat
39 #endif
40 #ifndef __fts_nlink_t
41 #define __fts_nlink_t nlink_t
42 #endif
43 #ifndef __fts_ino_t
44 #define __fts_ino_t ino_t
45 #endif
46
47 typedef struct {
48  struct _ftsent *fts_cur; /* current node */
49  struct _ftsent *fts_child; /* linked list of children */
50  struct _ftsent **fts_array; /* sort array */
51  dev_t fts_dev; /* starting device # */
52  char *fts_path; /* path for this descent */
53  int fts_rfd; /* fd for root */
54  u_int fts_pathlen; /* sizeof(path) */
55  u_int fts_nitems; /* elements in the sort array */
56  int (*fts_compar) /* compare function */
57  (const struct _ftsent **, const struct _ftsent **);
58
59 #define FTS_COMFOLLOW 0x001 /* follow command line symlinks */
60 #define FTS_LOGICAL 0x002 /* logical walk */
61 #define FTS_NOCHDIR 0x004 /* don't change directories */
62 #define FTS_NOSTAT 0x008 /* don't get stat info */
63 #define FTS_PHYSICAL 0x010 /* physical walk */
64 #define FTS_SEEDOT 0x020 /* return dot and dot-dot */
65 #define FTS_XDEV 0x040 /* don't cross devices */
66 #define FTS_WHITEOUT 0x080 /* return whiteout information */
67 #define FTS_OPTIONMASK 0x0ff /* valid user option mask */
68
69 #define FTS_NAMEONLY 0x100 /* (private) child names only */
70 #define FTS_STOP 0x200 /* (private) unrecoverable error */
71  int fts_options; /* fts_open options, global flags */
72 } FTS;
73
74 typedef struct _ftsent {
75  struct _ftsent *fts_cycle; /* cycle node */
76  struct _ftsent *fts_parent; /* parent directory */
77  struct _ftsent *fts_link; /* next file in directory */
78  long fts_number; /* local numeric value */
79  void *fts_pointer; /* local address value */
80  char *fts_accpath; /* access path */
81  char *fts_path; /* root path */
82  int fts_errno; /* errno for this node */
83  int fts_symfd; /* fd for symlink */
84  u_short fts_pathlen; /* strlen(fts_path) */
85  u_short fts_namelen; /* strlen(fts_name) */
86
87  __fts_ino_t fts_ino; /* inode */
88  dev_t fts_dev; /* device */
89  __fts_nlink_t fts_nlink; /* link count */
90
91 #define FTS_ROOTPARENTLEVEL -1
92 #define FTS_ROOTLEVEL 0
93  short fts_level; /* depth (-1 to N) */
94
95 #define FTS_D 1 /* preorder directory */
96 #define FTS_DC 2 /* directory that causes cycles */
97 #define FTS_DEFAULT 3 /* none of the above */
98 #define FTS_DNR 4 /* unreadable directory */
99 #define FTS_DOT 5 /* dot or dot-dot */
100 #define FTS_DP 6 /* postorder directory */
101 #define FTS_ERR 7 /* error; errno is set */
102 #define FTS_F 8 /* regular file */
103 #define FTS_INIT 9 /* initialized only */
104 #define FTS_NS 10 /* stat(2) failed */
105 #define FTS_NSOK 11 /* no stat(2) requested */
106 #define FTS_SL 12 /* symbolic link */
107 #define FTS_SLNONE 13 /* symbolic link without target */
108 #define FTS_W 14 /* whiteout object */
109  u_short fts_info; /* user flags for FTSENT structure */
110
111 #define FTS_DONTCHDIR 0x01 /* don't chdir .. to the parent */
112 #define FTS_SYMFOLLOW 0x02 /* followed a symlink to get here */
113 #define FTS_ISW 0x04 /* this is a whiteout object */
114  u_short fts_flags; /* private flags for FTSENT structure */
115
116 #define FTS_AGAIN 1 /* read node again */
117 #define FTS_FOLLOW 2 /* follow symbolic link */
118 #define FTS_NOINSTR 3 /* no instructions */
119 #define FTS_SKIP 4 /* discard node */
120  u_short fts_instr; /* fts_set() instructions */
121
122  __fts_stat_t *fts_statp; /* stat(2) information */
123  char fts_name[1]; /* file name */
124 } FTSENT;
125
126 #include <sys/cdefs.h>
127
128 #define __RENAME(n)
129 #define fts_children rtems_shell_fts_children
130 #define fts_close rtems_shell_fts_close
131 #define fts_open rtems_shell_fts_open
132 #define fts_read rtems_shell_fts_read
133 #define fts_set rtems_shell_fts_set
134
135 __BEGIN_DECLS
136 #ifndef __LIBC12_SOURCE__
137 FTSENT *fts_children(FTS *, int) __RENAME(__fts_children30);
138 int fts_close(FTS *) __RENAME(__fts_close30);
139 FTS *fts_open(char * const *, int,
140  int (*)(const FTSENT **, const FTSENT **)) __RENAME(__fts_open30);
141 FTSENT *fts_read(FTS *) __RENAME(__fts_read30);
142 int fts_set(FTS *, FTSENT *, int) __RENAME(__fts_set30);
143 #endif
144 __END_DECLS
145
146 #endif /* !_FTS_H_ */
Definition: fts.h:47
Definition: fts.h:74
