RTEMS  5.1
fsl-mpc556x.h
1 /*
2  * Modifications of the original file provided by Freescale are:
3  *
4  * Copyright (c) 2011 embedded brains GmbH. All rights reserved.
5  *
6  * embedded brains GmbH
7  * Obere Lagerstr. 30
8  * 82178 Puchheim
9  * Germany
10  * <info@embedded-brains.de>
11  *
12  * Redistribution and use in source and binary forms, with or without
13  * modification, are permitted provided that the following conditions
14  * are met:
15  * 1. Redistributions of source code must retain the above copyright
16  * notice, this list of conditions and the following disclaimer.
17  * 2. Redistributions in binary form must reproduce the above copyright
18  * notice, this list of conditions and the following disclaimer in the
19  * documentation and/or other materials provided with the distribution.
20  *
21  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
22  * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
23  * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
24  * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
25  * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
26  * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
27  * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
28  * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
29  * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
30  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
31  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
32  */
33
34 /**************************************************************************/
35 /* FILE NAME: mpc5567.h COPYRIGHT (c) Freescale 2007 */
36 /* VERSION: 1.5 All Rights Reserved */
37 /* */
38 /* DESCRIPTION: */
39 /* This file contain all of the register and bit field definitions for */
40 /* MPC5567. */
41 /*========================================================================*/
42 /* UPDATE HISTORY */
43 /* REV AUTHOR DATE DESCRIPTION OF CHANGE */
44 /* --- ----------- --------- --------------------- */
45 /* 1.0 G. Emerson 03/Jan/06 Initial version. */
46 /* 1.1 G. Emerson 27/Mar/06 Fix issue with Flexcan BCC field. */
47 /* 1.2 S. Mathieson 28/Jul/06 Change Flexcan BCC bit to MBFEN */
48 /* Add Flexcan bits WRNEN, SRXDIS, */
49 /* TWRNMSK, RWRNMSK,TWRNINT,RWRNINT */
50 /* 1.3 S. Mathieson 30/Aug/06 SPR: L1SCR0, updated bit name from DPP */
51 /* to DPB to align with documentation. */
52 /* 1.4 S. Mathieson 26/Feb/07 eDMA TCD format updated to include */
53 /* alternate configuration. */
54 /* INTC, correction to the number of PSR */
55 /* registers. */
56 /* Updates to bitfield sizes in MBSSUTR, */
57 /* MBIVEC, MBIDX & RSBIR. RSBIR, SELEC */
58 /* changed to SEL & RFRFCFR, FNUM changed */
59 /* to SEL to align with documentation. */
60 /* Various register/ bitfield updates to */
61 /* correct errors (MCR, TMODE bit removed.*/
62 /* PADR register removed. PIER1, DRDIE bit*/
63 /* removed & PIFR1, DRDIF removed. PCR1, */
64 /* Filter bypass bit removed). */
65 /* 1.5 S. Mathieson 25/Apr/07 SRAM size changed from 64K to 80K. */
66 /* */
67 /**************************************************************************/
68 /*>>>>NOTE! this file is auto-generated please do not edit it!<<<<*/
69
70 #ifndef _MPC5567_H_
71 #define _MPC5567_H_
72
73 #ifndef ASM
74
75 #include <stdint.h>
76
77 #include <mpc55xx/regs-edma.h>
78
79 #ifdef __cplusplus
80 extern "C" {
81 #endif
82
83 #ifdef __MWERKS__
84 #pragma push
85 #pragma ANSI_strict off
86 #endif
87
88 /****************************************************************************/
89 /* MODULE : PBRIDGE_A Peripheral Bridge */
90 /****************************************************************************/
91  struct PBRIDGE_A_tag {
92  union {
93  uint32_t R;
94  struct {
95  uint32_t MBW0:1;
96  uint32_t MTR0:1;
97  uint32_t MTW0:1;
98  uint32_t MPL0:1;
99  uint32_t MBW1:1;
100  uint32_t MTR1:1;
101  uint32_t MTW1:1;
102  uint32_t MPL1:1;
103  uint32_t MBW2:1;
104  uint32_t MTR2:1;
105  uint32_t MTW2:1;
106  uint32_t MPL2:1;
107  uint32_t MBW3:1;
108  uint32_t MTR3:1;
109  uint32_t MTW3:1;
110  uint32_t MPL3:1;
111
112  uint32_t MBW4:1; /* FEC */
113  uint32_t MTR4:1;
114  uint32_t MTW4:1;
115  uint32_t MPL4:1;
116
117  uint32_t:4;
118
119  uint32_t MBW6:1; /* FLEXRAY */
120  uint32_t MTR6:1;
121  uint32_t MTW6:1;
122  uint32_t MPL6:1;
123
124  uint32_t:4;
125  } B;
126  } MPCR; /* Master Privilege Control Register */
127
128  uint32_t pbridge_a_reserved2[7];
129
130  union {
131  uint32_t R;
132  struct {
133  uint32_t BW0:1;
134  uint32_t SP0:1;
135  uint32_t WP0:1;
136  uint32_t TP0:1;
137  uint32_t:28;
138  } B;
139  } PACR0;
140
141  uint32_t pbridge_a_reserved3[7];
142
143  union {
144  uint32_t R;
145  struct {
146  uint32_t BW0:1;
147  uint32_t SP0:1;
148  uint32_t WP0:1;
149  uint32_t TP0:1;
150  uint32_t BW1:1;
151  uint32_t SP1:1;
152  uint32_t WP1:1;
153  uint32_t TP1:1;
154  uint32_t BW2:1;
155  uint32_t SP2:1;
156  uint32_t WP2:1;
157  uint32_t TP2:1;
158  uint32_t:4;
159  uint32_t BW4:1;
160  uint32_t SP4:1;
161  uint32_t WP4:1;
162  uint32_t TP4:1;
163  uint32_t:12;
164  } B;
165  } OPACR0;
166
167  union {
168  uint32_t R;
169  struct {
170
171  uint32_t BW0:1; /* EMIOS */
172  uint32_t SP0:1;
173  uint32_t WP0:1;
174  uint32_t TP0:1;
175
176  uint32_t:28;
177  } B;
178  } OPACR1;
179
180  union {
181  uint32_t R;
182  struct {
183  uint32_t BW0:1;
184  uint32_t SP0:1;
185  uint32_t WP0:1;
186  uint32_t TP0:1;
187  uint32_t:4;
188  uint32_t BW2:1;
189  uint32_t SP2:1;
190  uint32_t WP2:1;
191  uint32_t TP2:1;
192  uint32_t BW3:1;
193  uint32_t SP3:1;
194  uint32_t WP3:1;
195  uint32_t TP3:1;
196  uint32_t BW4:1;
197  uint32_t SP4:1;
198  uint32_t WP4:1;
199  uint32_t TP4:1;
200  uint32_t:12;
201  } B;
202  } OPACR2;
203
204  };
205
206 /****************************************************************************/
207 /* MODULE : PBRIDGE_B Peripheral Bridge */
208 /****************************************************************************/
209  struct PBRIDGE_B_tag {
210  union {
211  uint32_t R;
212  struct {
213  uint32_t MBW0:1;
214  uint32_t MTR0:1;
215  uint32_t MTW0:1;
216  uint32_t MPL0:1;
217  uint32_t MBW1:1;
218  uint32_t MTR1:1;
219  uint32_t MTW1:1;
220  uint32_t MPL1:1;
221  uint32_t MBW2:1;
222  uint32_t MTR2:1;
223  uint32_t MTW2:1;
224  uint32_t MPL2:1;
225  uint32_t MBW3:1;
226  uint32_t MTR3:1;
227  uint32_t MTW3:1;
228  uint32_t MPL3:1;
229
230  uint32_t MBW4:1; /* FEC */
231  uint32_t MTR4:1;
232  uint32_t MTW4:1;
233  uint32_t MPL4:1;
234
235  uint32_t:4;
236
237  uint32_t MBW6:1; /* FLEXRAY */
238  uint32_t MTR6:1;
239  uint32_t MTW6:1;
240  uint32_t MPL6:1;
241
242  uint32_t:4;
243  } B;
244  } MPCR; /* Master Privilege Control Register */
245
246  uint32_t pbridge_b_reserved2[7];
247
248  union {
249  uint32_t R;
250  struct {
251  uint32_t BW0:1;
252  uint32_t SP0:1;
253  uint32_t WP0:1;
254  uint32_t TP0:1;
255  uint32_t BW1:1;
256  uint32_t SP1:1;
257  uint32_t WP1:1;
258  uint32_t TP1:1;
259  uint32_t:24;
260  } B;
261  } PACR0;
262
263  uint32_t pbridge_b_reserved3;
264
265  union {
266  uint32_t R;
267  struct {
268  uint32_t BW0:1;
269  uint32_t SP0:1;
270  uint32_t WP0:1;
271  uint32_t TP0:1;
272  uint32_t BW1:1;
273  uint32_t SP1:1;
274  uint32_t WP1:1;
275  uint32_t TP1:1;
276  uint32_t BW2:1;
277  uint32_t SP2:1;
278  uint32_t WP2:1;
279  uint32_t TP2:1;
280
281  uint32_t BW3:1; /* FEC */
282  uint32_t SP3:1;
283  uint32_t WP3:1;
284  uint32_t TP3:1;
285
286  uint32_t:16;
287
288  } B;
289  } PACR2;
290
291  uint32_t pbridge_b_reserved4[5];
292
293  union {
294  uint32_t R;
295  struct {
296  uint32_t BW0:1;
297  uint32_t SP0:1;
298  uint32_t WP0:1;
299  uint32_t TP0:1;
300  uint32_t:12;
301
302  uint32_t:4;
303
304  uint32_t BW5:1; /* DSPI_B */
305  uint32_t SP5:1;
306  uint32_t WP5:1;
307  uint32_t TP5:1;
308
309  uint32_t BW6:1;
310  uint32_t SP6:1;
311  uint32_t WP6:1;
312  uint32_t TP6:1;
313  uint32_t BW7:1;
314  uint32_t SP7:1;
315  uint32_t WP7:1;
316  uint32_t TP7:1;
317  } B;
318  } OPACR0;
319
320  union {
321  uint32_t R;
322  struct {
323  uint32_t:16;
324  uint32_t BW4:1;
325  uint32_t SP4:1;
326  uint32_t WP4:1;
327  uint32_t TP4:1;
328
329  uint32_t BW5:1; /* ESCI_B */
330  uint32_t SP5:1;
331  uint32_t WP5:1;
332  uint32_t TP5:1;
333
334  uint32_t:8;
335  } B;
336  } OPACR1;
337
338  union {
339  uint32_t R;
340  struct {
341  uint32_t BW0:1;
342  uint32_t SP0:1;
343  uint32_t WP0:1;
344  uint32_t TP0:1;
345
346  uint32_t BW1:1; /* CAN_B */
347  uint32_t SP1:1;
348  uint32_t WP1:1;
349  uint32_t TP1:1;
350
351  uint32_t BW2:1;
352  uint32_t SP2:1;
353  uint32_t WP2:1;
354  uint32_t TP2:1;
355
356  uint32_t BW3:1; /* CAN_D */
357  uint32_t SP3:1;
358  uint32_t WP3:1;
359  uint32_t TP3:1;
360
361  uint32_t BW4:1; /* CAN_E */
362  uint32_t SP4:1;
363  uint32_t WP4:1;
364  uint32_t TP4:1;
365
366  uint32_t:12;
367  } B;
368  } OPACR2;
369
370  union {
371  uint32_t R;
372  struct {
373
374  uint32_t BW0:1; /* FLEXRAY */
375  uint32_t SP0:1;
376  uint32_t WP0:1;
377  uint32_t TP0:1;
378
379  uint32_t:24;
380  uint32_t BW7:1;
381  uint32_t SP7:1;
382  uint32_t WP7:1;
383  uint32_t TP7:1;
384  } B;
385  } OPACR3;
386
387  };
388 /****************************************************************************/
389 /* MODULE : FMPLL */
390 /****************************************************************************/
391  struct FMPLL_tag {
392  union FMPLL_SYNCR_tag {
393  uint32_t R;
394  struct {
395  uint32_t:1;
396  uint32_t PREDIV:3;
397  uint32_t MFD:5;
398  uint32_t:1;
399  uint32_t RFD:3;
400  uint32_t LOCEN:1;
401  uint32_t LOLRE:1;
402  uint32_t LOCRE:1;
403  uint32_t DISCLK:1;
404  uint32_t LOLIRQ:1;
405  uint32_t LOCIRQ:1;
406  uint32_t RATE:1;
407  uint32_t DEPTH:2;
408  uint32_t EXP:10;
409  } B;
410  } SYNCR;
411
412  union FMPLL_SYNSR_tag {
413  uint32_t R;
414  struct {
415  uint32_t:22;
416  uint32_t LOLF:1;
417  uint32_t LOC:1;
418  uint32_t MODE:1;
419  uint32_t PLLSEL:1;
420  uint32_t PLLREF:1;
421  uint32_t LOCKS:1;
422  uint32_t LOCK:1;
423  uint32_t LOCF:1;
424  uint32_t CALDONE:1;
425  uint32_t CALPASS:1;
426  } B;
427  } SYNSR;
428
429  };
430 /****************************************************************************/
431 /* MODULE : External Bus Interface (EBI) */
432 /****************************************************************************/
433  struct EBI_CS_tag {
434  union { /* Base Register Bank */
435  uint32_t R;
436  struct {
437  uint32_t BA:17;
438  uint32_t:3;
439  uint32_t PS:1;
440  uint32_t:4;
441  uint32_t BL:1;
442  uint32_t WEBS:1;
443  uint32_t TBDIP:1;
444  uint32_t:2;
445  uint32_t BI:1;
446  uint32_t V:1;
447  } B;
448  } BR;
449
450  union { /* Option Register Bank */
451  uint32_t R;
452  struct {
453  uint32_t AM:17;
454  uint32_t:7;
455  uint32_t SCY:4;
456  uint32_t:1;
457  uint32_t BSCY:2;
458  uint32_t:1;
459  } B;
460  } OR;
461  };
462
463  struct EBI_CAL_CS_tag {
464  union { /* Calibration Base Register Bank */
465  uint32_t R;
466  struct {
467  uint32_t BA:17;
468  uint32_t:3;
469  uint32_t PS:1;
470  uint32_t:4;
471  uint32_t BL:1;
472  uint32_t WEBS:1;
473  uint32_t TBDIP:1;
474  uint32_t:2;
475  uint32_t BI:1;
476  uint32_t V:1;
477  } B;
478  } BR;
479
480  union { /* Calibration Option Register Bank */
481  uint32_t R;
482  struct {
483  uint32_t AM:17;
484  uint32_t:7;
485  uint32_t SCY:4;
486  uint32_t:1;
487  uint32_t BSCY:2;
488  uint32_t:1;
489  } B;
490  } OR;
491  };
492
493  struct EBI_tag {
494  union EBI_MCR_tag { /* Module Configuration Register */
495  uint32_t R;
496  struct {
497  uint32_t:5;
498  uint32_t SIZEEN:1;
499  uint32_t SIZE:2;
500  uint32_t:8;
501  uint32_t ACGE:1;
502  uint32_t EXTM:1;
503  uint32_t EARB:1;
504  uint32_t EARP:2;
505  uint32_t:4;
506  uint32_t MDIS:1;
507  uint32_t:5;
508  uint32_t DBM:1;
509  } B;
510  } MCR;
511
512  uint32_t EBI_reserved1;
513
514  union { /* Transfer Error Status Register */
515  uint32_t R;
516  struct {
517  uint32_t:30;
518  uint32_t TEAF:1;
519  uint32_t BMTF:1;
520  } B;
521  } TESR;
522
523  union { /* Bus Monitor Control Register */
524  uint32_t R;
525  struct {
526  uint32_t:16;
527  uint32_t BMT:8;
528  uint32_t BME:1;
529  uint32_t:7;
530  } B;
531  } BMCR;
532
533  struct EBI_CS_tag CS[4];
534
535 /* Calibration registers */
536  uint32_t EBI_reserved2[4];
537  struct EBI_CAL_CS_tag CAL_CS[4];
538
539  };
540 /****************************************************************************/
541 /* MODULE : FLASH */
542 /****************************************************************************/
543  struct FLASH_tag {
544  union { /* Module Configuration Register */
545  uint32_t R;
546  struct {
547  uint32_t:4;
548  uint32_t SIZE:4;
549  uint32_t:1;
550  uint32_t LAS:3;
551  uint32_t:3;
552  uint32_t MAS:1;
553  uint32_t EER:1;
554  uint32_t RWE:1;
555  uint32_t BBEPE:1;
556  uint32_t EPE:1;
557  uint32_t PEAS:1;
558  uint32_t DONE:1;
559  uint32_t PEG:1;
560
561  uint32_t:2;
562
563  uint32_t STOP:1;
564  uint32_t:1;
565  uint32_t PGM:1;
566  uint32_t PSUS:1;
567  uint32_t ERS:1;
568  uint32_t ESUS:1;
569  uint32_t EHV:1;
570  } B;
571  } MCR;
572
573  union LMLR_tag { /* LML Register */
574  uint32_t R;
575  struct {
576  uint32_t LME:1;
577  uint32_t:10;
578  uint32_t SLOCK:1;
579  uint32_t MLOCK:4;
580  uint32_t LLOCK:16;
581  } B;
582  } LMLR;
583
584  union HLR_tag { /* HL Register */
585  uint32_t R;
586  struct {
587  uint32_t HBE:1;
588  uint32_t:3;
589  uint32_t HBLOCK:28;
590  } B;
591  } HLR;
592
593  union SLMLR_tag { /* SLML Register */
594  uint32_t R;
595  struct {
596  uint32_t SLE:1;
597  uint32_t:10;
598  uint32_t SSLOCK:1;
599  uint32_t SMLOCK:4;
600  uint32_t SLLOCK:16;
601  } B;
602  } SLMLR;
603
604  union { /* LMS Register */
605  uint32_t R;
606  struct {
607  uint32_t:12;
608  uint32_t MSEL:4;
609  uint32_t LSEL:16;
610  } B;
611  } LMSR;
612
613  union {
614  uint32_t R;
615  struct {
616  uint32_t:4;
617  uint32_t HBSEL:28;
618  } B;
619  } HSR;
620
621  union {
622  uint32_t R;
623  struct {
624  uint32_t:10;
625  uint32_t ADDR:19;
626  uint32_t:3;
627  } B;
628  } AR;
629
630  union {
631  uint32_t R;
632  struct {
633
634  uint32_t:9;
635  uint32_t M6PFE:1; /* Flexray */
636  uint32_t:1;
637
638  uint32_t M4PFE:1; /* FEC */
639
640  uint32_t M3PFE:1;
641  uint32_t M2PFE:1;
642  uint32_t M1PFE:1;
643  uint32_t M0PFE:1;
644  uint32_t APC:3;
645  uint32_t WWSC:2;
646  uint32_t RWSC:3;
647
648  uint32_t DPFEN:2;
649  uint32_t IPFEN:2;
650
651  uint32_t PFLIM:3;
652  uint32_t BFEN:1;
653  } B;
654  } BIUCR;
655
656  union {
657  uint32_t R;
658  struct {
659
660  uint32_t:18;
661  uint32_t M6AP:2; /* Flexray */
662  uint32_t:2;
663
664  uint32_t M4AP:2; /* FEC */
665
666  uint32_t M3AP:2;
667  uint32_t M2AP:2;
668  uint32_t M1AP:2;
669  uint32_t M0AP:2;
670  } B;
671  } BIUAPR;
672  };
673 /****************************************************************************/
674 /* MODULE : SIU */
675 /****************************************************************************/
676  struct SIU_tag {
677  int32_t SIU_reserved0;
678
679  union { /* MCU ID Register */
680  uint32_t R;
681  struct {
682  uint32_t PARTNUM:16;
683  uint32_t MASKNUM:16;
684  } B;
685  } MIDR;
686  int32_t SIU_reserved00;
687
688  union { /* Reset Status Register */
689  uint32_t R;
690  struct {
691  uint32_t PORS:1;
692  uint32_t ERS:1;
693  uint32_t LLRS:1;
694  uint32_t LCRS:1;
695  uint32_t WDRS:1;
696  uint32_t CRS:1;
697  uint32_t:8;
698  uint32_t SSRS:1;
699  uint32_t SERF:1;
700  uint32_t WKPCFG:1;
701  uint32_t:12;
702  uint32_t BOOTCFG:2;
703  uint32_t RGF:1;
704  } B;
705  } RSR;
706
707  union { /* System Reset Control Register */
708  uint32_t R;
709  struct {
710  uint32_t SSR:1;
711  uint32_t SER:1;
712  uint32_t:14;
713  uint32_t CRE:1;
714  uint32_t:15;
715  } B;
716  } SRCR;
717
718  union SIU_EISR_tag { /* External Interrupt Status Register */
719  uint32_t R;
720  struct {
721  uint32_t:16;
722  uint32_t EIF15:1;
723  uint32_t EIF14:1;
724  uint32_t EIF13:1;
725  uint32_t EIF12:1;
726  uint32_t EIF11:1;
727  uint32_t EIF10:1;
728  uint32_t EIF9:1;
729  uint32_t EIF8:1;
730  uint32_t EIF7:1;
731  uint32_t EIF6:1;
732  uint32_t EIF5:1;
733  uint32_t EIF4:1;
734  uint32_t EIF3:1;
735  uint32_t EIF2:1;
736  uint32_t EIF1:1;
737  uint32_t EIF0:1;
738  } B;
739  } EISR;
740
741  union SIU_DIRER_tag { /* DMA/Interrupt Request Enable Register */
742  uint32_t R;
743  struct {
744  uint32_t:16;
745  uint32_t EIRE15:1;
746  uint32_t EIRE14:1;
747  uint32_t EIRE13:1;
748  uint32_t EIRE12:1;
749  uint32_t EIRE11:1;
750  uint32_t EIRE10:1;
751  uint32_t EIRE9:1;
752  uint32_t EIRE8:1;
753  uint32_t EIRE7:1;
754  uint32_t EIRE6:1;
755  uint32_t EIRE5:1;
756  uint32_t EIRE4:1;
757  uint32_t EIRE3:1;
758  uint32_t EIRE2:1;
759  uint32_t EIRE1:1;
760  uint32_t EIRE0:1;
761  } B;
762  } DIRER;
763
764  union SIU_DIRSR_tag { /* DMA/Interrupt Select Register */
765  uint32_t R;
766  struct {
767  uint32_t:28;
768  uint32_t DIRS3:1;
769  uint32_t DIRS2:1;
770  uint32_t DIRS1:1;
771  uint32_t DIRS0:1;
772  } B;
773  } DIRSR;
774
775  union { /* Overrun Status Register */
776  uint32_t R;
777  struct {
778  uint32_t:16;
779  uint32_t OVF15:1;
780  uint32_t OVF14:1;
781  uint32_t OVF13:1;
782  uint32_t OVF12:1;
783  uint32_t OVF11:1;
784  uint32_t OVF10:1;
785  uint32_t OVF9:1;
786  uint32_t OVF8:1;
787  uint32_t OVF7:1;
788  uint32_t OVF6:1;
789  uint32_t OVF5:1;
790  uint32_t OVF4:1;
791  uint32_t OVF3:1;
792  uint32_t OVF2:1;
793  uint32_t OVF1:1;
794  uint32_t OVF0:1;
795  } B;
796  } OSR;
797
798  union SIU_ORER_tag { /* Overrun Request Enable Register */
799  uint32_t R;
800  struct {
801  uint32_t:16;
802  uint32_t ORE15:1;
803  uint32_t ORE14:1;
804  uint32_t ORE13:1;
805  uint32_t ORE12:1;
806  uint32_t ORE11:1;
807  uint32_t ORE10:1;
808  uint32_t ORE9:1;
809  uint32_t ORE8:1;
810  uint32_t ORE7:1;
811  uint32_t ORE6:1;
812  uint32_t ORE5:1;
813  uint32_t ORE4:1;
814  uint32_t ORE3:1;
815  uint32_t ORE2:1;
816  uint32_t ORE1:1;
817  uint32_t ORE0:1;
818  } B;
819  } ORER;
820
821  union SIU_IREER_tag { /* External IRQ Rising-Edge Event Enable Register */
822  uint32_t R;
823  struct {
824  uint32_t:16;
825  uint32_t IREE15:1;
826  uint32_t IREE14:1;
827  uint32_t IREE13:1;
828  uint32_t IREE12:1;
829  uint32_t IREE11:1;
830  uint32_t IREE10:1;
831  uint32_t IREE9:1;
832  uint32_t IREE8:1;
833  uint32_t IREE7:1;
834  uint32_t IREE6:1;
835  uint32_t IREE5:1;
836  uint32_t IREE4:1;
837  uint32_t IREE3:1;
838  uint32_t IREE2:1;
839  uint32_t IREE1:1;
840  uint32_t IREE0:1;
841  } B;
842  } IREER;
843
844  union SIU_IFEER_tag { /* External IRQ Falling-Edge Event Enable Register */
845  uint32_t R;
846  struct {
847  uint32_t:16;
848  uint32_t IFEE15:1;
849  uint32_t IFEE14:1;
850  uint32_t IFEE13:1;
851  uint32_t IFEE12:1;
852  uint32_t IFEE11:1;
853  uint32_t IFEE10:1;
854  uint32_t IFEE9:1;
855  uint32_t IFEE8:1;
856  uint32_t IFEE7:1;
857  uint32_t IFEE6:1;
858  uint32_t IFEE5:1;
859  uint32_t IFEE4:1;
860  uint32_t IFEE3:1;
861  uint32_t IFEE2:1;
862  uint32_t IFEE1:1;
863  uint32_t IFEE0:1;
864  } B;
865  } IFEER;
866
867  union SIU_IDFR_tag { /* External IRQ Digital Filter Register */
868  uint32_t R;
869  struct {
870  uint32_t:28;
871  uint32_t DFL:4;
872  } B;
873  } IDFR;
874
875  int32_t SIU_reserved1[3];
876
877  union SIU_PCR_tag { /* Pad Configuration Registers */
878  uint16_t R;
879  struct {
880  uint16_t:3;
881  uint16_t PA:3;
882  uint16_t OBE:1;
883  uint16_t IBE:1;
884  uint16_t DSC:2;
885  uint16_t ODE:1;
886  uint16_t HYS:1;
887  uint16_t SRC:2;
888  uint16_t WPE:1;
889  uint16_t WPS:1;
890  } B;
891  } PCR[512];
892
893  int16_t SIU_reserved_0[224];
894
895  union { /* GPIO Pin Data Output Registers */
896  uint8_t R;
897  struct {
898  uint8_t:7;
899  uint8_t PDO:1;
900  } B;
901  } GPDO[256];
902
903  int32_t SIU_reserved_3[64];
904
905  union { /* GPIO Pin Data Input Registers */
906  uint8_t R;
907  struct {
908  uint8_t:7;
909  uint8_t PDI:1;
910  } B;
911  } GPDI[256];
912
913  union { /* IMUX Register */
914  uint32_t R;
915  struct {
916  uint32_t TSEL5:2;
917  uint32_t TSEL4:2;
918  uint32_t TSEL3:2;
919  uint32_t TSEL2:2;
920  uint32_t TSEL1:2;
921  uint32_t TSEL0:2;
922  uint32_t:20;
923  } B;
924  } ETISR;
925
926  union { /* IMUX Register */
927  uint32_t R;
928  struct {
929  uint32_t ESEL15:2;
930  uint32_t ESEL14:2;
931  uint32_t ESEL13:2;
932  uint32_t ESEL12:2;
933  uint32_t ESEL11:2;
934  uint32_t ESEL10:2;
935  uint32_t ESEL9:2;
936  uint32_t ESEL8:2;
937  uint32_t ESEL7:2;
938  uint32_t ESEL6:2;
939  uint32_t ESEL5:2;
940  uint32_t ESEL4:2;
941  uint32_t ESEL3:2;
942  uint32_t ESEL2:2;
943  uint32_t ESEL1:2;
944  uint32_t ESEL0:2;
945  } B;
946  } EIISR;
947
948  union { /* IMUX Register */
949  uint32_t R;
950  struct {
951  uint32_t SINSELA:2;
952  uint32_t SSSELA:2;
953  uint32_t SCKSELA:2;
954  uint32_t TRIGSELA:2;
955  uint32_t SINSELB:2;
956  uint32_t SSSELB:2;
957  uint32_t SCKSELB:2;
958  uint32_t TRIGSELB:2;
959  uint32_t SINSELC:2;
960  uint32_t SSSELC:2;
961  uint32_t SCKSELC:2;
962  uint32_t TRIGSELC:2;
963  uint32_t SINSELD:2;
964  uint32_t SSSELD:2;
965  uint32_t SCKSELD:2;
966  uint32_t TRIGSELD:2;
967  } B;
968  } DISR;
969
970  int32_t SIU_reserved2[29];
971
972  union { /* Chip Configuration Register Register */
973  uint32_t R;
974  struct {
975  uint32_t:14;
976  uint32_t MATCH:1;
977  uint32_t DISNEX:1;
978  uint32_t:16;
979  } B;
980  } CCR;
981
982  union { /* External Clock Configuration Register Register */
983  uint32_t R;
984  struct {
985  uint32_t:18;
986  uint32_t ENGDIV:6;
987  uint32_t:4;
988  uint32_t EBTS:1;
989  uint32_t:1;
990  uint32_t EBDF:2;
991  } B;
992  } ECCR;
993
994  union {
995  uint32_t R;
996  } CARH;
997
998  union {
999  uint32_t R;
1000  } CARL;
1001
1002  union {
1003  uint32_t R;
1004  } CBRH;
1005
1006  union {
1007  uint32_t R;
1008  } CBRL;
1009
1010  };
1011 /****************************************************************************/
1012 /* MODULE : EMIOS */
1013 /****************************************************************************/
1014  struct EMIOS_tag {
1015  union EMIOS_MCR_tag {
1016  uint32_t R;
1017  struct {
1018  uint32_t:1;
1019  uint32_t MDIS:1;
1020  uint32_t FRZ:1;
1021  uint32_t GTBE:1;
1022  uint32_t ETB:1;
1023  uint32_t GPREN:1;
1024  uint32_t:6;
1025  uint32_t SRV:4;
1026  uint32_t GPRE:8;
1027  uint32_t:8;
1028  } B;
1029  } MCR; /* Module Configuration Register */
1030
1031  union {
1032  uint32_t R;
1033  struct {
1034  uint32_t:8;
1035  uint32_t F23:1;
1036  uint32_t F22:1;
1037  uint32_t F21:1;
1038  uint32_t F20:1;
1039  uint32_t F19:1;
1040  uint32_t F18:1;
1041  uint32_t F17:1;
1042  uint32_t F16:1;
1043  uint32_t F15:1;
1044  uint32_t F14:1;
1045  uint32_t F13:1;
1046  uint32_t F12:1;
1047  uint32_t F11:1;
1048  uint32_t F10:1;
1049  uint32_t F9:1;
1050  uint32_t F8:1;
1051  uint32_t F7:1;
1052  uint32_t F6:1;
1053  uint32_t F5:1;
1054  uint32_t F4:1;
1055  uint32_t F3:1;
1056  uint32_t F2:1;
1057  uint32_t F1:1;
1058  uint32_t F0:1;
1059  } B;
1060  } GFR; /* Global FLAG Register */
1061
1062  union {
1063  uint32_t R;
1064  struct {
1065  uint32_t:8;
1066  uint32_t OU23:1;
1067  uint32_t OU22:1;
1068  uint32_t OU21:1;
1069  uint32_t OU20:1;
1070  uint32_t OU19:1;
1071  uint32_t OU18:1;
1072  uint32_t OU17:1;
1073  uint32_t OU16:1;
1074  uint32_t OU15:1;
1075  uint32_t OU14:1;
1076  uint32_t OU13:1;
1077  uint32_t OU12:1;
1078  uint32_t OU11:1;
1079  uint32_t OU10:1;
1080  uint32_t OU9:1;
1081  uint32_t OU8:1;
1082  uint32_t OU7:1;
1083  uint32_t OU6:1;
1084  uint32_t OU5:1;
1085  uint32_t OU4:1;
1086  uint32_t OU3:1;
1087  uint32_t OU2:1;
1088  uint32_t OU1:1;
1089  uint32_t OU0:1;
1090  } B;
1091  } OUDR; /* Output Update Disable Register */
1092
1093  uint32_t emios_reserved[5];
1094
1095  struct EMIOS_CH_tag {
1096  union {
1097  uint32_t R; /* Channel A Data Register */
1098  } CADR;
1099
1100  union {
1101  uint32_t R; /* Channel B Data Register */
1102  } CBDR;
1103
1104  union {
1105  uint32_t R; /* Channel Counter Register */
1106  } CCNTR;
1107
1108  union EMIOS_CCR_tag {
1109  uint32_t R;
1110  struct {
1111  uint32_t FREN:1;
1112  uint32_t ODIS:1;
1113  uint32_t ODISSL:2;
1114  uint32_t UCPRE:2;
1115  uint32_t UCPREN:1;
1116  uint32_t DMA:1;
1117  uint32_t:1;
1118  uint32_t IF:4;
1119  uint32_t FCK:1;
1120  uint32_t FEN:1;
1121  uint32_t:3;
1122  uint32_t FORCMA:1;
1123  uint32_t FORCMB:1;
1124  uint32_t:1;
1125  uint32_t BSL:2;
1126  uint32_t EDSEL:1;
1127  uint32_t EDPOL:1;
1128  uint32_t MODE:7;
1129  } B;
1130  } CCR; /* Channel Control Register */
1131
1132  union EMIOS_CSR_tag {
1133  uint32_t R;
1134  struct {
1135  uint32_t OVR:1;
1136  uint32_t:15;
1137  uint32_t OVFL:1;
1138  uint32_t:12;
1139  uint32_t UCIN:1;
1140  uint32_t UCOUT:1;
1141  uint32_t FLAG:1;
1142  } B;
1143  } CSR; /* Channel Status Register */
1144
1145  union {
1146  uint32_t R; /* Alternate Channel A Data Register */
1147  } ALTCADR;
1148
1149  uint32_t emios_channel_reserved[2];
1150
1151  } CH[24];
1152
1153  };
1154 /****************************************************************************/
1155 /* MODULE :ETPU */
1156 /****************************************************************************/
1157
1158 /***************************Configuration Registers**************************/
1159
1160  struct ETPU_tag {
1161  union { /* MODULE CONFIGURATION REGISTER */
1162  uint32_t R;
1163  struct {
1164  uint32_t GEC:1; /* Global Exception Clear */
1165  uint32_t:3;
1166  uint32_t MGE1:1; /* Microcode Global Exception-ETPU_A */
1167
1168  uint32_t:1; /* For single ETPU implementations */
1169
1170  uint32_t ILF1:1; /* Illegal Instruction Flag-ETPU_A */
1171
1172  uint32_t:1; /* For single ETPU implementations */
1173
1174  uint32_t:3;
1175  uint32_t SCMSIZE:5; /* Shared Code Memory size */
1176  uint32_t:5;
1177  uint32_t SCMMISF:1; /* SCM MISC Flag */
1178  uint32_t SCMMISEN:1; /* SCM MISC Enable */
1179  uint32_t:2;
1180  uint32_t VIS:1; /* SCM Visability */
1181  uint32_t:5;
1182  uint32_t GTBE:1; /* Global Time Base Enable */
1183  } B;
1184  } MCR;
1185
1186  union { /* COHERENT DUAL-PARAMETER CONTROL */
1187  uint32_t R;
1188  struct {
1189  uint32_t STS:1; /* Start Status bit */
1190  uint32_t CTBASE:5; /* Channel Transfer Base */
1191  uint32_t PBASE:10; /* Parameter Buffer Base Address */
1192  uint32_t PWIDTH:1; /* Parameter Width */
1193  uint32_t PARAM0:7; /* Channel Parameter 0 */
1194  uint32_t WR:1;
1195  uint32_t PARAM1:7; /* Channel Parameter 1 */
1196  } B;
1197  } CDCR;
1198
1199  uint32_t etpu_reserved1;
1200
1201  union { /* MISC Compare Register */
1202  uint32_t R;
1203  } MISCCMPR;
1204
1205  union { /* SCM off-range Date Register */
1206  uint32_t R;
1207  } SCMOFFDATAR;
1208
1209  union { /* ETPU_A Configuration Register */
1210  uint32_t R;
1211  struct {
1212  uint32_t FEND:1; /* Force END */
1213  uint32_t MDIS:1; /* Low power Stop */
1214  uint32_t:1;
1215  uint32_t STF:1; /* Stop Flag */
1216  uint32_t:4;
1217  uint32_t HLTF:1; /* Halt Mode Flag */
1218  uint32_t:4;
1219  uint32_t FPSCK:3; /* Filter Prescaler Clock Control */
1220  uint32_t CDFC:2;
1221  uint32_t:9;
1222  uint32_t ETB:5; /* Entry Table Base */
1223  } B;
1224  } ECR_A;
1225  uint32_t etpu_reserved3; /* For single ETPU implementations */
1226
1227  uint32_t etpu_reserved4;
1228
1229  union { /* ETPU_A Timebase Configuration Register */
1230  uint32_t R;
1231  struct {
1232  uint32_t TCR2CTL:3; /* TCR2 Clock/Gate Control */
1233  uint32_t TCRCF:2; /* TCRCLK Signal Filter Control */
1234  uint32_t:1;
1235  uint32_t AM:1; /* Angle Mode */
1236  uint32_t:3;
1237  uint32_t TCR2P:6; /* TCR2 Prescaler Control */
1238  uint32_t TCR1CTL:2; /* TCR1 Clock/Gate Control */
1239  uint32_t:6;
1240  uint32_t TCR1P:8; /* TCR1 Prescaler Control */
1241  } B;
1242  } TBCR_A;
1243
1244  union { /* ETPU_A TCR1 Visibility Register */
1245  uint32_t R;
1246  } TB1R_A;
1247
1248  union { /* ETPU_A TCR2 Visibility Register */
1249  uint32_t R;
1250  } TB2R_A;
1251
1252  union { /* ETPU_A STAC Configuration Register */
1253  uint32_t R;
1254  struct {
1255  uint32_t REN1:1; /* Resource Enable TCR1 */
1256  uint32_t RSC1:1; /* Resource Control TCR1 */
1257  uint32_t:2;
1258  uint32_t SERVER_ID1:4;
1259  uint32_t:4;
1260  uint32_t SRV1:4; /* Resource Server Slot */
1261  uint32_t REN2:1; /* Resource Enable TCR2 */
1262  uint32_t RSC2:1; /* Resource Control TCR2 */
1263  uint32_t:2;
1264  uint32_t SERVER_ID2:4;
1265  uint32_t:4;
1266  uint32_t SRV2:4; /* Resource Server Slot */
1267  } B;
1268  } REDCR_A;
1269
1270  uint32_t etpu_reserved5[4];
1271  uint32_t etpu_reserved6[4]; /* For single ETPU implementations */
1272
1273  uint32_t etpu_reserved7[108];
1274
1275 /*****************************Status and Control Registers**************************/
1276
1277  union { /* ETPU_A Channel Interrut Status */
1278  uint32_t R;
1279  struct {
1280  uint32_t CIS31:1; /* Channel 31 Interrut Status */
1281  uint32_t CIS30:1; /* Channel 30 Interrut Status */
1282  uint32_t CIS29:1; /* Channel 29 Interrut Status */
1283  uint32_t CIS28:1; /* Channel 28 Interrut Status */
1284  uint32_t CIS27:1; /* Channel 27 Interrut Status */
1285  uint32_t CIS26:1; /* Channel 26 Interrut Status */
1286  uint32_t CIS25:1; /* Channel 25 Interrut Status */
1287  uint32_t CIS24:1; /* Channel 24 Interrut Status */
1288  uint32_t CIS23:1; /* Channel 23 Interrut Status */
1289  uint32_t CIS22:1; /* Channel 22 Interrut Status */
1290  uint32_t CIS21:1; /* Channel 21 Interrut Status */
1291  uint32_t CIS20:1; /* Channel 20 Interrut Status */
1292  uint32_t CIS19:1; /* Channel 19 Interrut Status */
1293  uint32_t CIS18:1; /* Channel 18 Interrut Status */
1294  uint32_t CIS17:1; /* Channel 17 Interrut Status */
1295  uint32_t CIS16:1; /* Channel 16 Interrut Status */
1296  uint32_t CIS15:1; /* Channel 15 Interrut Status */
1297  uint32_t CIS14:1; /* Channel 14 Interrut Status */
1298  uint32_t CIS13:1; /* Channel 13 Interrut Status */
1299  uint32_t CIS12:1; /* Channel 12 Interrut Status */
1300  uint32_t CIS11:1; /* Channel 11 Interrut Status */
1301  uint32_t CIS10:1; /* Channel 10 Interrut Status */
1302  uint32_t CIS9:1; /* Channel 9 Interrut Status */
1303  uint32_t CIS8:1; /* Channel 8 Interrut Status */
1304  uint32_t CIS7:1; /* Channel 7 Interrut Status */
1305  uint32_t CIS6:1; /* Channel 6 Interrut Status */
1306  uint32_t CIS5:1; /* Channel 5 Interrut Status */
1307  uint32_t CIS4:1; /* Channel 4 Interrut Status */
1308  uint32_t CIS3:1; /* Channel 3 Interrut Status */
1309  uint32_t CIS2:1; /* Channel 2 Interrut Status */
1310  uint32_t CIS1:1; /* Channel 1 Interrut Status */
1311  uint32_t CIS0:1; /* Channel 0 Interrut Status */
1312  } B;
1313  } CISR_A;
1314  uint32_t etpu_reserved8; /* For single ETPU implementations */
1315
1316  uint32_t etpu_reserved9[2];
1317
1318  union { /* ETPU_A Data Transfer Request Status */
1319  uint32_t R;
1320  struct {
1321  uint32_t DTRS31:1; /* Channel 31 Data Transfer Request Status */
1322  uint32_t DTRS30:1; /* Channel 30 Data Transfer Request Status */
1323  uint32_t DTRS29:1; /* Channel 29 Data Transfer Request Status */
1324  uint32_t DTRS28:1; /* Channel 28 Data Transfer Request Status */
1325  uint32_t DTRS27:1; /* Channel 27 Data Transfer Request Status */
1326  uint32_t DTRS26:1; /* Channel 26 Data Transfer Request Status */
1327  uint32_t DTRS25:1; /* Channel 25 Data Transfer Request Status */
1328  uint32_t DTRS24:1; /* Channel 24 Data Transfer Request Status */
1329  uint32_t DTRS23:1; /* Channel 23 Data Transfer Request Status */
1330  uint32_t DTRS22:1; /* Channel 22 Data Transfer Request Status */
1331  uint32_t DTRS21:1; /* Channel 21 Data Transfer Request Status */
1332  uint32_t DTRS20:1; /* Channel 20 Data Transfer Request Status */
1333  uint32_t DTRS19:1; /* Channel 19 Data Transfer Request Status */
1334  uint32_t DTRS18:1; /* Channel 18 Data Transfer Request Status */
1335  uint32_t DTRS17:1; /* Channel 17 Data Transfer Request Status */
1336  uint32_t DTRS16:1; /* Channel 16 Data Transfer Request Status */
1337  uint32_t DTRS15:1; /* Channel 15 Data Transfer Request Status */
1338  uint32_t DTRS14:1; /* Channel 14 Data Transfer Request Status */
1339  uint32_t DTRS13:1; /* Channel 13 Data Transfer Request Status */
1340  uint32_t DTRS12:1; /* Channel 12 Data Transfer Request Status */
1341  uint32_t DTRS11:1; /* Channel 11 Data Transfer Request Status */
1342  uint32_t DTRS10:1; /* Channel 10 Data Transfer Request Status */
1343  uint32_t DTRS9:1; /* Channel 9 Data Transfer Request Status */
1344  uint32_t DTRS8:1; /* Channel 8 Data Transfer Request Status */
1345  uint32_t DTRS7:1; /* Channel 7 Data Transfer Request Status */
1346  uint32_t DTRS6:1; /* Channel 6 Data Transfer Request Status */
1347  uint32_t DTRS5:1; /* Channel 5 Data Transfer Request Status */
1348  uint32_t DTRS4:1; /* Channel 4 Data Transfer Request Status */
1349  uint32_t DTRS3:1; /* Channel 3 Data Transfer Request Status */
1350  uint32_t DTRS2:1; /* Channel 2 Data Transfer Request Status */
1351  uint32_t DTRS1:1; /* Channel 1 Data Transfer Request Status */
1352  uint32_t DTRS0:1; /* Channel 0 Data Transfer Request Status */
1353  } B;
1354  } CDTRSR_A;
1355  uint32_t etpu_reserved10; /* For single ETPU implementations */
1356
1357  uint32_t etpu_reserved11[2];
1358
1359  union { /* ETPU_A Interruput Overflow Status */
1360  uint32_t R;
1361  struct {
1362  uint32_t CIOS31:1; /* Channel 31 Interruput Overflow Status */
1363  uint32_t CIOS30:1; /* Channel 30 Interruput Overflow Status */
1364  uint32_t CIOS29:1; /* Channel 29 Interruput Overflow Status */
1365  uint32_t CIOS28:1; /* Channel 28 Interruput Overflow Status */
1366  uint32_t CIOS27:1; /* Channel 27 Interruput Overflow Status */
1367  uint32_t CIOS26:1; /* Channel 26 Interruput Overflow Status */
1368  uint32_t CIOS25:1; /* Channel 25 Interruput Overflow Status */
1369  uint32_t CIOS24:1; /* Channel 24 Interruput Overflow Status */
1370  uint32_t CIOS23:1; /* Channel 23 Interruput Overflow Status */
1371  uint32_t CIOS22:1; /* Channel 22 Interruput Overflow Status */
1372  uint32_t CIOS21:1; /* Channel 21 Interruput Overflow Status */
1373  uint32_t CIOS20:1; /* Channel 20 Interruput Overflow Status */
1374  uint32_t CIOS19:1; /* Channel 19 Interruput Overflow Status */
1375  uint32_t CIOS18:1; /* Channel 18 Interruput Overflow Status */
1376  uint32_t CIOS17:1; /* Channel 17 Interruput Overflow Status */
1377  uint32_t CIOS16:1; /* Channel 16 Interruput Overflow Status */
1378  uint32_t CIOS15:1; /* Channel 15 Interruput Overflow Status */
1379  uint32_t CIOS14:1; /* Channel 14 Interruput Overflow Status */
1380  uint32_t CIOS13:1; /* Channel 13 Interruput Overflow Status */
1381  uint32_t CIOS12:1; /* Channel 12 Interruput Overflow Status */
1382  uint32_t CIOS11:1; /* Channel 11 Interruput Overflow Status */
1383  uint32_t CIOS10:1; /* Channel 10 Interruput Overflow Status */
1384  uint32_t CIOS9:1; /* Channel 9 Interruput Overflow Status */
1385  uint32_t CIOS8:1; /* Channel 8 Interruput Overflow Status */
1386  uint32_t CIOS7:1; /* Channel 7 Interruput Overflow Status */
1387  uint32_t CIOS6:1; /* Channel 6 Interruput Overflow Status */
1388  uint32_t CIOS5:1; /* Channel 5 Interruput Overflow Status */
1389  uint32_t CIOS4:1; /* Channel 4 Interruput Overflow Status */
1390  uint32_t CIOS3:1; /* Channel 3 Interruput Overflow Status */
1391  uint32_t CIOS2:1; /* Channel 2 Interruput Overflow Status */
1392  uint32_t CIOS1:1; /* Channel 1 Interruput Overflow Status */
1393  uint32_t CIOS0:1; /* Channel 0 Interruput Overflow Status */
1394  } B;
1395  } CIOSR_A;
1396  uint32_t etpu_reserved12; /* For single ETPU implementations */
1397
1398  uint32_t etpu_reserved13[2];
1399
1400  union { /* ETPU_A Data Transfer Overflow Status */
1401  uint32_t R;
1402  struct {
1403  uint32_t DTROS31:1; /* Channel 31 Data Transfer Overflow Status */
1404  uint32_t DTROS30:1; /* Channel 30 Data Transfer Overflow Status */
1405  uint32_t DTROS29:1; /* Channel 29 Data Transfer Overflow Status */
1406  uint32_t DTROS28:1; /* Channel 28 Data Transfer Overflow Status */
1407  uint32_t DTROS27:1; /* Channel 27 Data Transfer Overflow Status */
1408  uint32_t DTROS26:1; /* Channel 26 Data Transfer Overflow Status */
1409  uint32_t DTROS25:1; /* Channel 25 Data Transfer Overflow Status */
1410  uint32_t DTROS24:1; /* Channel 24 Data Transfer Overflow Status */
1411  uint32_t DTROS23:1; /* Channel 23 Data Transfer Overflow Status */
1412  uint32_t DTROS22:1; /* Channel 22 Data Transfer Overflow Status */
1413  uint32_t DTROS21:1; /* Channel 21 Data Transfer Overflow Status */
1414  uint32_t DTROS20:1; /* Channel 20 Data Transfer Overflow Status */
1415  uint32_t DTROS19:1; /* Channel 19 Data Transfer Overflow Status */
1416  uint32_t DTROS18:1; /* Channel 18 Data Transfer Overflow Status */
1417  uint32_t DTROS17:1; /* Channel 17 Data Transfer Overflow Status */
1418  uint32_t DTROS16:1; /* Channel 16 Data Transfer Overflow Status */
1419  uint32_t DTROS15:1; /* Channel 15 Data Transfer Overflow Status */
1420  uint32_t DTROS14:1; /* Channel 14 Data Transfer Overflow Status */
1421  uint32_t DTROS13:1; /* Channel 13 Data Transfer Overflow Status */
1422  uint32_t DTROS12:1; /* Channel 12 Data Transfer Overflow Status */
1423  uint32_t DTROS11:1; /* Channel 11 Data Transfer Overflow Status */
1424  uint32_t DTROS10:1; /* Channel 10 Data Transfer Overflow Status */
1425  uint32_t DTROS9:1; /* Channel 9 Data Transfer Overflow Status */
1426  uint32_t DTROS8:1; /* Channel 8 Data Transfer Overflow Status */
1427  uint32_t DTROS7:1; /* Channel 7 Data Transfer Overflow Status */
1428  uint32_t DTROS6:1; /* Channel 6 Data Transfer Overflow Status */
1429  uint32_t DTROS5:1; /* Channel 5 Data Transfer Overflow Status */
1430  uint32_t DTROS4:1; /* Channel 4 Data Transfer Overflow Status */
1431  uint32_t DTROS3:1; /* Channel 3 Data Transfer Overflow Status */
1432  uint32_t DTROS2:1; /* Channel 2 Data Transfer Overflow Status */
1433  uint32_t DTROS1:1; /* Channel 1 Data Transfer Overflow Status */
1434  uint32_t DTROS0:1; /* Channel 0 Data Transfer Overflow Status */
1435  } B;
1436  } CDTROSR_A;
1437  uint32_t etpu_reserved14; /* For single ETPU implementations */
1438
1439  uint32_t etpu_reserved15[2];
1440
1441  union { /* ETPU_A Channel Interruput Enable */
1442  uint32_t R;
1443  struct {
1444  uint32_t CIE31:1; /* Channel 31 Interruput Enable */
1445  uint32_t CIE30:1; /* Channel 30 Interruput Enable */
1446  uint32_t CIE29:1; /* Channel 29 Interruput Enable */
1447  uint32_t CIE28:1; /* Channel 28 Interruput Enable */
1448  uint32_t CIE27:1; /* Channel 27 Interruput Enable */
1449  uint32_t CIE26:1; /* Channel 26 Interruput Enable */
1450  uint32_t CIE25:1; /* Channel 25 Interruput Enable */
1451  uint32_t CIE24:1; /* Channel 24 Interruput Enable */
1452  uint32_t CIE23:1; /* Channel 23 Interruput Enable */
1453  uint32_t CIE22:1; /* Channel 22 Interruput Enable */
1454  uint32_t CIE21:1; /* Channel 21 Interruput Enable */
1455  uint32_t CIE20:1; /* Channel 20 Interruput Enable */
1456  uint32_t CIE19:1; /* Channel 19 Interruput Enable */
1457  uint32_t CIE18:1; /* Channel 18 Interruput Enable */
1458  uint32_t CIE17:1; /* Channel 17 Interruput Enable */
1459  uint32_t CIE16:1; /* Channel 16 Interruput Enable */
1460  uint32_t CIE15:1; /* Channel 15 Interruput Enable */
1461  uint32_t CIE14:1; /* Channel 14 Interruput Enable */
1462  uint32_t CIE13:1; /* Channel 13 Interruput Enable */
1463  uint32_t CIE12:1; /* Channel 12 Interruput Enable */
1464  uint32_t CIE11:1; /* Channel 11 Interruput Enable */
1465  uint32_t CIE10:1; /* Channel 10 Interruput Enable */
1466  uint32_t CIE9:1; /* Channel 9 Interruput Enable */
1467  uint32_t CIE8:1; /* Channel 8 Interruput Enable */
1468  uint32_t CIE7:1; /* Channel 7 Interruput Enable */
1469  uint32_t CIE6:1; /* Channel 6 Interruput Enable */
1470  uint32_t CIE5:1; /* Channel 5 Interruput Enable */
1471  uint32_t CIE4:1; /* Channel 4 Interruput Enable */
1472  uint32_t CIE3:1; /* Channel 3 Interruput Enable */
1473  uint32_t CIE2:1; /* Channel 2 Interruput Enable */
1474  uint32_t CIE1:1; /* Channel 1 Interruput Enable */
1475  uint32_t CIE0:1; /* Channel 0 Interruput Enable */
1476  } B;
1477  } CIER_A;
1478  uint32_t etpu_reserved16; /* For single ETPU implementations */
1479
1480  uint32_t etpu_reserved17[2];
1481
1482  union { /* ETPU_A Channel Data Transfer Request Enable */
1483  uint32_t R;
1484  struct {
1485  uint32_t DTRE31:1; /* Channel 31 Data Transfer Request Enable */
1486  uint32_t DTRE30:1; /* Channel 30 Data Transfer Request Enable */
1487  uint32_t DTRE29:1; /* Channel 29 Data Transfer Request Enable */
1488  uint32_t DTRE28:1; /* Channel 28 Data Transfer Request Enable */
1489  uint32_t DTRE27:1; /* Channel 27 Data Transfer Request Enable */
1490  uint32_t DTRE26:1; /* Channel 26 Data Transfer Request Enable */
1491  uint32_t DTRE25:1; /* Channel 25 Data Transfer Request Enable */
1492  uint32_t DTRE24:1; /* Channel 24 Data Transfer Request Enable */
1493  uint32_t DTRE23:1; /* Channel 23 Data Transfer Request Enable */
1494  uint32_t DTRE22:1; /* Channel 22 Data Transfer Request Enable */
1495  uint32_t DTRE21:1; /* Channel 21 Data Transfer Request Enable */
1496  uint32_t DTRE20:1; /* Channel 20 Data Transfer Request Enable */
1497  uint32_t DTRE19:1; /* Channel 19 Data Transfer Request Enable */
1498  uint32_t DTRE18:1; /* Channel 18 Data Transfer Request Enable */
1499  uint32_t DTRE17:1; /* Channel 17 Data Transfer Request Enable */
1500  uint32_t DTRE16:1; /* Channel 16 Data Transfer Request Enable */
1501  uint32_t DTRE15:1; /* Channel 15 Data Transfer Request Enable */
1502  uint32_t DTRE14:1; /* Channel 14 Data Transfer Request Enable */
1503  uint32_t DTRE13:1; /* Channel 13 Data Transfer Request Enable */
1504  uint32_t DTRE12:1; /* Channel 12 Data Transfer Request Enable */
1505  uint32_t DTRE11:1; /* Channel 11 Data Transfer Request Enable */
1506  uint32_t DTRE10:1; /* Channel 10 Data Transfer Request Enable */
1507  uint32_t DTRE9:1; /* Channel 9 Data Transfer Request Enable */
1508  uint32_t DTRE8:1; /* Channel 8 Data Transfer Request Enable */
1509  uint32_t DTRE7:1; /* Channel 7 Data Transfer Request Enable */
1510  uint32_t DTRE6:1; /* Channel 6 Data Transfer Request Enable */
1511  uint32_t DTRE5:1; /* Channel 5 Data Transfer Request Enable */
1512  uint32_t DTRE4:1; /* Channel 4 Data Transfer Request Enable */
1513  uint32_t DTRE3:1; /* Channel 3 Data Transfer Request Enable */
1514  uint32_t DTRE2:1; /* Channel 2 Data Transfer Request Enable */
1515  uint32_t DTRE1:1; /* Channel 1 Data Transfer Request Enable */
1516  uint32_t DTRE0:1; /* Channel 0 Data Transfer Request Enable */
1517  } B;
1518  } CDTRER_A;
1519  uint32_t etpu_reserved19; /* For single ETPU implementations */
1520
1521  uint32_t etpu_reserved20[10];
1522  union { /* ETPU_A Channel Pending Service Status */
1523  uint32_t R;
1524  struct {
1525  uint32_t SR31:1; /* Channel 31 Pending Service Status */
1526  uint32_t SR30:1; /* Channel 30 Pending Service Status */
1527  uint32_t SR29:1; /* Channel 29 Pending Service Status */
1528  uint32_t SR28:1; /* Channel 28 Pending Service Status */
1529  uint32_t SR27:1; /* Channel 27 Pending Service Status */
1530  uint32_t SR26:1; /* Channel 26 Pending Service Status */
1531  uint32_t SR25:1; /* Channel 25 Pending Service Status */
1532  uint32_t SR24:1; /* Channel 24 Pending Service Status */
1533  uint32_t SR23:1; /* Channel 23 Pending Service Status */
1534  uint32_t SR22:1; /* Channel 22 Pending Service Status */
1535  uint32_t SR21:1; /* Channel 21 Pending Service Status */
1536  uint32_t SR20:1; /* Channel 20 Pending Service Status */
1537  uint32_t SR19:1; /* Channel 19 Pending Service Status */
1538  uint32_t SR18:1; /* Channel 18 Pending Service Status */
1539  uint32_t SR17:1; /* Channel 17 Pending Service Status */
1540  uint32_t SR16:1; /* Channel 16 Pending Service Status */
1541  uint32_t SR15:1; /* Channel 15 Pending Service Status */
1542  uint32_t SR14:1; /* Channel 14 Pending Service Status */
1543  uint32_t SR13:1; /* Channel 13 Pending Service Status */
1544  uint32_t SR12:1; /* Channel 12 Pending Service Status */
1545  uint32_t SR11:1; /* Channel 11 Pending Service Status */
1546  uint32_t SR10:1; /* Channel 10 Pending Service Status */
1547  uint32_t SR9:1; /* Channel 9 Pending Service Status */
1548  uint32_t SR8:1; /* Channel 8 Pending Service Status */
1549  uint32_t SR7:1; /* Channel 7 Pending Service Status */
1550  uint32_t SR6:1; /* Channel 6 Pending Service Status */
1551  uint32_t SR5:1; /* Channel 5 Pending Service Status */
1552  uint32_t SR4:1; /* Channel 4 Pending Service Status */
1553  uint32_t SR3:1; /* Channel 3 Pending Service Status */
1554  uint32_t SR2:1; /* Channel 2 Pending Service Status */
1555  uint32_t SR1:1; /* Channel 1 Pending Service Status */
1556  uint32_t SR0:1; /* Channel 0 Pending Service Status */
1557  } B;
1558  } CPSSR_A;
1559  uint32_t etpu_reserved22; /* For single ETPU implementations */
1560
1561  uint32_t etpu_reserved20a[2];
1562
1563  union { /* ETPU_A Channel Service Status */
1564  uint32_t R;
1565  struct {
1566  uint32_t SS31:1; /* Channel 31 Service Status */
1567  uint32_t SS30:1; /* Channel 30 Service Status */
1568  uint32_t SS29:1; /* Channel 29 Service Status */
1569  uint32_t SS28:1; /* Channel 28 Service Status */
1570  uint32_t SS27:1; /* Channel 27 Service Status */
1571  uint32_t SS26:1; /* Channel 26 Service Status */
1572  uint32_t SS25:1; /* Channel 25 Service Status */
1573  uint32_t SS24:1; /* Channel 24 Service Status */
1574  uint32_t SS23:1; /* Channel 23 Service Status */
1575  uint32_t SS22:1; /* Channel 22 Service Status */
1576  uint32_t SS21:1; /* Channel 21 Service Status */
1577  uint32_t SS20:1; /* Channel 20 Service Status */
1578  uint32_t SS19:1; /* Channel 19 Service Status */
1579  uint32_t SS18:1; /* Channel 18 Service Status */
1580  uint32_t SS17:1; /* Channel 17 Service Status */
1581  uint32_t SS16:1; /* Channel 16 Service Status */
1582  uint32_t SS15:1; /* Channel 15 Service Status */
1583  uint32_t SS14:1; /* Channel 14 Service Status */
1584  uint32_t SS13:1; /* Channel 13 Service Status */
1585  uint32_t SS12:1; /* Channel 12 Service Status */
1586  uint32_t SS11:1; /* Channel 11 Service Status */
1587  uint32_t SS10:1; /* Channel 10 Service Status */
1588  uint32_t SS9:1; /* Channel 9 Service Status */
1589  uint32_t SS8:1; /* Channel 8 Service Status */
1590  uint32_t SS7:1; /* Channel 7 Service Status */
1591  uint32_t SS6:1; /* Channel 6 Service Status */
1592  uint32_t SS5:1; /* Channel 5 Service Status */
1593  uint32_t SS4:1; /* Channel 4 Service Status */
1594  uint32_t SS3:1; /* Channel 3 Service Status */
1595  uint32_t SS2:1; /* Channel 2 Service Status */
1596  uint32_t SS1:1; /* Channel 1 Service Status */
1597  uint32_t SS0:1; /* Channel 0 Service Status */
1598  } B;
1599  } CSSR_A;
1600  uint32_t etpu_reserved22a; /* For single ETPU implementations */
1601
1602  uint32_t etpu_reserved23[90];
1603
1604 /*****************************Channels********************************/
1605
1606  struct {
1607  union {
1608  uint32_t R; /* Channel Configuration Register */
1609  struct {
1610  uint32_t CIE:1; /* Channel Interruput Enable */
1611  uint32_t DTRE:1; /* Data Transfer Request Enable */
1612  uint32_t CPR:2; /* Channel Priority */
1613  uint32_t:3;
1614  uint32_t ETCS:1; /* Entry Table Condition Select */
1615  uint32_t:3;
1616  uint32_t CFS:5; /* Channel Function Select */
1617  uint32_t ODIS:1; /* Output disable */
1618  uint32_t OPOL:1; /* output polarity */
1619  uint32_t:3;
1620  uint32_t CPBA:11; /* Channel Parameter Base Address */
1621  } B;
1622  } CR;
1623  union {
1624  uint32_t R; /* Channel Status Control Register */
1625  struct {
1626  uint32_t CIS:1; /* Channel Interruput Status */
1627  uint32_t CIOS:1; /* Channel Interruput Overflow Status */
1628  uint32_t:6;
1629  uint32_t DTRS:1; /* Data Transfer Status */
1630  uint32_t DTROS:1; /* Data Transfer Overflow Status */
1631  uint32_t:6;
1632  uint32_t IPS:1; /* Input Pin State */
1633  uint32_t OPS:1; /* Output Pin State */
1634  uint32_t OBE:1; /* Output Buffer Enable */
1635  uint32_t:11;
1636  uint32_t FM1:1; /* Function mode */
1637  uint32_t FM0:1; /* Function mode */
1638  } B;
1639  } SCR;
1640  union {
1641  uint32_t R; /* Channel Host Service Request Register */
1642  struct {
1643  uint32_t:29; /* Host Service Request */
1644  uint32_t HSR:3;
1645  } B;
1646  } HSRR;
1647  uint32_t etpu_reserved23;
1648  } CHAN[127];
1649
1650  };
1651 /****************************************************************************/
1652 /* MODULE : XBAR CrossBar */
1653 /****************************************************************************/
1654  struct XBAR_tag {
1655  union {
1656  uint32_t R;
1657  struct {
1658  uint32_t:4;
1659
1660  uint32_t:1;
1661  uint32_t MSTR6:3; /* FLEXRAY */
1662
1663  uint32_t:4;
1664
1665  uint32_t:4;
1666
1667  uint32_t:1;
1668  uint32_t MSTR3:3; /* FEC */
1669
1670  uint32_t:1;
1671  uint32_t MSTR2:3;
1672  uint32_t:1;
1673  uint32_t MSTR1:3;
1674  uint32_t:1;
1675  uint32_t MSTR0:3;
1676  } B;
1677  } MPR0; /* Master Priority Register for Slave Port 0 */
1678
1679  uint32_t xbar_reserved1[3];
1680
1681  union {
1682  uint32_t R;
1683  struct {
1684  uint32_t RO:1;
1685  uint32_t:21;
1686  uint32_t ARB:2;
1687  uint32_t:2;
1688  uint32_t PCTL:2;
1689  uint32_t:1;
1690  uint32_t PARK:3;
1691  } B;
1692  } SGPCR0; /* General Purpose Control Register for Slave Port 0 */
1693
1694  uint32_t xbar_reserved2[59];
1695
1696  union {
1697  uint32_t R;
1698  struct {
1699  uint32_t:4;
1700
1701  uint32_t:1;
1702  uint32_t MSTR6:3; /* FLEXRAY */
1703
1704  uint32_t:4;
1705
1706  uint32_t:4;
1707
1708  uint32_t:1;
1709  uint32_t MSTR3:3; /* FEC */
1710
1711  uint32_t:1;
1712  uint32_t MSTR2:3;
1713  uint32_t:1;
1714  uint32_t MSTR1:3;
1715  uint32_t:1;
1716  uint32_t MSTR0:3;
1717  } B;
1718  } MPR1; /* Master Priority Register for Slave Port 1 */
1719
1720  uint32_t xbar_reserved3[3];
1721
1722  union {
1723  uint32_t R;
1724  struct {
1725  uint32_t RO:1;
1726  uint32_t:21;
1727  uint32_t ARB:2;
1728  uint32_t:2;
1729  uint32_t PCTL:2;
1730  uint32_t:1;
1731  uint32_t PARK:3;
1732  } B;
1733  } SGPCR1; /* General Purpose Control Register for Slave Port 1 */
1734
1735  uint32_t xbar_reserved4[123];
1736
1737  union {
1738  uint32_t R;
1739  struct {
1740  uint32_t:4;
1741
1742  uint32_t:1;
1743  uint32_t MSTR6:3; /* FLEXRAY */
1744
1745  uint32_t:4;
1746
1747  uint32_t:4;
1748
1749  uint32_t:1;
1750  uint32_t MSTR3:3; /* FEC */
1751
1752  uint32_t:1;
1753  uint32_t MSTR2:3;
1754  uint32_t:1;
1755  uint32_t MSTR1:3;
1756  uint32_t:1;
1757  uint32_t MSTR0:3;
1758  } B;
1759  } MPR3; /* Master Priority Register for Slave Port 3 */
1760
1761  uint32_t xbar_reserved5[3];
1762
1763  union {
1764  uint32_t R;
1765  struct {
1766  uint32_t RO:1;
1767  uint32_t:21;
1768  uint32_t ARB:2;
1769  uint32_t:2;
1770  uint32_t PCTL:2;
1771  uint32_t:1;
1772  uint32_t PARK:3;
1773  } B;
1774  } SGPCR3; /* General Purpose Control Register for Slave Port 3 */
1775  uint32_t xbar_reserved6[187];
1776
1777  union {
1778  uint32_t R;
1779  struct {
1780  uint32_t:4;
1781
1782  uint32_t:1;
1783  uint32_t MSTR6:3; /* FLEXRAY */
1784
1785  uint32_t:4;
1786
1787  uint32_t:4;
1788
1789  uint32_t:1;
1790  uint32_t MSTR3:3; /* FEC */
1791
1792  uint32_t:1;
1793  uint32_t MSTR2:3;
1794  uint32_t:1;
1795  uint32_t MSTR1:3;
1796  uint32_t:1;
1797  uint32_t MSTR0:3;
1798  } B;
1799  } MPR6; /* Master Priority Register for Slave Port 6 */
1800
1801  uint32_t xbar_reserved7[3];
1802
1803  union {
1804  uint32_t R;
1805  struct {
1806  uint32_t RO:1;
1807  uint32_t:21;
1808  uint32_t ARB:2;
1809  uint32_t:2;
1810  uint32_t PCTL:2;
1811  uint32_t:1;
1812  uint32_t PARK:3;
1813  } B;
1814  } SGPCR6; /* General Purpose Control Register for Slave Port 6 */
1815
1816  uint32_t xbar_reserved8[59];
1817
1818  union {
1819  uint32_t R;
1820  struct {
1821  uint32_t:4;
1822
1823  uint32_t:1;
1824  uint32_t MSTR6:3; /* FLEXRAY */
1825
1826  uint32_t:4;
1827
1828  uint32_t:4;
1829
1830  uint32_t:1;
1831  uint32_t MSTR3:3; /* FEC */
1832
1833  uint32_t:1;
1834  uint32_t MSTR2:3;
1835  uint32_t:1;
1836  uint32_t MSTR1:3;
1837  uint32_t:1;
1838  uint32_t MSTR0:3;
1839  } B;
1840  } MPR7; /* Master Priority Register for Slave Port 7 */
1841
1842  uint32_t xbar_reserved9[3];
1843
1844  union {
1845  uint32_t R;
1846  struct {
1847  uint32_t RO:1;
1848  uint32_t:21;
1849  uint32_t ARB:2;
1850  uint32_t:2;
1851  uint32_t PCTL:2;
1852  uint32_t:1;
1853  uint32_t PARK:3;
1854  } B;
1855  } SGPCR7; /* General Purpose Control Register for Slave Port 7 */
1856
1857  };
1858 /****************************************************************************/
1859 /* MODULE : ECSM */
1860 /****************************************************************************/
1861  struct ECSM_tag {
1862
1863  uint32_t ecsm_reserved1[5];
1864
1865  uint16_t ecsm_reserved2;
1866
1867  union {
1868  uint16_t R;
1869  } SWTCR; //Software Watchdog Timer Control
1870
1871  uint8_t ecsm_reserved3[3];
1872
1873  union {
1874  uint8_t R;
1875  } SWTSR; //SWT Service Register
1876
1877  uint8_t ecsm_reserved4[3];
1878
1879  union {
1880  uint8_t R;
1881  } SWTIR; //SWT Interrupt Register
1882
1883  uint32_t ecsm_reserved5a[1];
1884
1885  union {
1886  uint32_t R;
1887  struct {
1888  uint32_t FSBCR0:1;
1889  uint32_t FSBCR1:1;
1890  uint32_t FSBCR2:1;
1891  uint32_t FSBCR3:1;
1892  uint32_t FSBCR4:1;
1893  uint32_t FSBCR5:1;
1894  uint32_t FSBCR6:1;
1895  uint32_t FSBCR7:1;
1896  uint32_t RBEN:1;
1897  uint32_t WBEN:1;
1898  uint32_t ACCERR:1;
1899  uint32_t:21;
1900  } B;
1901  } FSBMCR; /* FEC System Bus Master Control Register */
1902
1903  uint32_t ecsm_reserved5c[6];
1904
1905  uint8_t ecsm_reserved6[3];
1906
1907  union {
1908  uint8_t R;
1909  struct {
1910  uint8_t:6;
1911  uint8_t ERNCR:1;
1912  uint8_t EFNCR:1;
1913  } B;
1914  } ECR; //ECC Configuration Register
1915
1916  uint8_t mcm_reserved8[3];
1917
1918  union {
1919  uint8_t R;
1920  struct {
1921  uint8_t:6;
1922  uint8_t RNCE:1;
1923  uint8_t FNCE:1;
1924  } B;
1925  } ESR; //ECC Status Register
1926
1927  uint16_t ecsm_reserved9;
1928
1929  union {
1930  uint16_t R;
1931  struct {
1932  uint16_t:6;
1933  uint16_t FRCNCI:1;
1934  uint16_t FR1NCI:1;
1935  uint16_t:1;
1936  uint16_t ERRBIT:7;
1937  } B;
1938  } EEGR; //ECC Error Generation Register
1939
1940  uint32_t ecsm_reserved10;
1941
1942  union {
1943  uint32_t R;
1944  struct {
1945  uint32_t FEAR:32;
1946  } B;
1947  } FEAR; //Flash ECC Address Register
1948
1949  uint16_t ecsm_reserved11;
1950
1951  union {
1952  uint8_t R;
1953  struct {
1954  uint8_t:4;
1955  uint8_t FEMR:4;
1956  } B;
1957  } FEMR; //Flash ECC Master Register
1958
1959  union {
1960  uint8_t R;
1961  struct {
1962  uint8_t WRITE:1;
1963  uint8_t SIZE:3;
1964  uint8_t PROT0:1;
1965  uint8_t PROT1:1;
1966  uint8_t PROT2:1;
1967  uint8_t PROT3:1;
1968  } B;
1969  } FEAT; //Flash ECC Attributes Register
1970
1971  union {
1972  uint32_t R;
1973  struct {
1974  uint32_t FEDH:32;
1975  } B;
1976  } FEDRH; //Flash ECC Data High Register
1977
1978  union {
1979  uint32_t R;
1980  struct {
1981  uint32_t FEDL:32;
1982  } B;
1983  } FEDRL; //Flash ECC Data Low Register
1984
1985  union {
1986  uint32_t R;
1987  struct {
1988  uint32_t REAR:32;
1989  } B;
1990  } REAR; //RAM ECC Address
1991
1992  uint8_t ecsm_reserved12[2];
1993
1994  union {
1995  uint8_t R;
1996  struct {
1997  uint8_t:4;
1998  uint8_t REMR:4;
1999  } B;
2000  } REMR; //RAM ECC Master
2001
2002  union {
2003  uint8_t R;
2004  struct {
2005  uint8_t WRITE:1;
2006  uint8_t SIZE:3;
2007  uint8_t PROT0:1;
2008  uint8_t PROT1:1;
2009  uint8_t PROT2:1;
2010  uint8_t PROT3:1;
2011  } B;
2012  } REAT; // RAM ECC Attributes Register
2013
2014  union {
2015  uint32_t R;
2016  struct {
2017  uint32_t REDH:32;
2018  } B;
2019  } REDRH; //RAM ECC Data High Register
2020
2021  union {
2022  uint32_t R;
2023  struct {
2024  uint32_t REDL:32;
2025  } B;
2026  } REDRL; //RAMECC Data Low Register
2027
2028  };
2029 /****************************************************************************/
2030 /* MODULE : INTC */
2031 /****************************************************************************/
2032  struct INTC_tag {
2033  union {
2034  uint32_t R;
2035  struct {
2036  uint32_t:26;
2037  uint32_t VTES:1;
2038  uint32_t:4;
2039  uint32_t HVEN:1;
2040  } B;
2041  } MCR; /* Module Configuration Register */
2042
2043  int32_t INTC_reserved00;
2044
2045  union {
2046  uint32_t R;
2047  struct {
2048  uint32_t:28;
2049  uint32_t PRI:4;
2050  } B;
2051  } CPR; /* Current Priority Register */
2052
2053  uint32_t intc_reserved1;
2054
2055  union {
2056  uint32_t R;
2057  struct {
2058  uint32_t VTBA:21;
2059  uint32_t INTVEC:9;
2060  uint32_t:2;
2061  } B;
2062  } IACKR; /* Interrupt Acknowledge Register */
2063
2064  uint32_t intc_reserved2;
2065
2066  union {
2067  uint32_t R;
2068  struct {
2069  uint32_t:32;
2070  } B;
2071  } EOIR; /* End of Interrupt Register */
2072
2073  uint32_t intc_reserved3;
2074
2075  union {
2076  uint8_t R;
2077  struct {
2078  uint8_t:6;
2079  uint8_t SET:1;
2080  uint8_t CLR:1;
2081  } B;
2082  } SSCIR[8]; /* Software Set/Clear Interruput Register */
2083
2084  uint32_t intc_reserved4[6];
2085
2086  union {
2087  uint8_t R;
2088  struct {
2089  uint8_t:4;
2090  uint8_t PRI:4;
2091  } B;
2092  } PSR[358]; /* Software Set/Clear Interrupt Register */
2093
2094  };
2095 /****************************************************************************/
2096 /* MODULE : EQADC */
2097 /****************************************************************************/
2098  struct EQADC_tag {
2099  union {
2100  uint32_t R;
2101  struct {
2102  uint32_t:27;
2103  uint32_t ESSIE:2;
2104  uint32_t:1;
2105  uint32_t DBG:2;
2106  } B;
2107  } MCR; /* Module Configuration Register */
2108
2109  int32_t EQADC_reserved00;
2110
2111  union {
2112  uint32_t R;
2113  struct {
2114  uint32_t:6;
2115  uint32_t NMF:26;
2116  } B;
2117  } NMSFR; /* Null Message Send Format Register */
2118
2119  union {
2120  uint32_t R;
2121  struct {
2122  uint32_t:28;
2123  uint32_t DFL:4;
2124  } B;
2125  } ETDFR; /* External Trigger Digital Filter Register */
2126
2127  union {
2128  uint32_t R;
2129  struct {
2130  uint32_t CFPUSH:32;
2131  } B;
2132  } CFPR[6]; /* CFIFO Push Registers */
2133
2134  uint32_t eqadc_reserved1;
2135
2136  uint32_t eqadc_reserved2;
2137
2138  union {
2139  uint32_t R;
2140  struct {
2141  uint32_t:16;
2142  uint32_t RFPOP:16;
2143  } B;
2144  } RFPR[6]; /* Result FIFO Pop Registers */
2145
2146  uint32_t eqadc_reserved3;
2147
2148  uint32_t eqadc_reserved4;
2149
2150  union {
2151  uint16_t R;
2152  struct {
2153  uint16_t:5;
2154  uint16_t SSE:1;
2155  uint16_t CFINV:1;
2156  uint16_t:1;
2157  uint16_t MODE:4;
2158  uint16_t:4;
2159  } B;
2160  } CFCR[6]; /* CFIFO Control Registers */
2161
2162  uint32_t eqadc_reserved5;
2163
2164  union {
2165  uint16_t R;
2166  struct {
2167  uint16_t NCIE:1;
2168  uint16_t TORIE:1;
2169  uint16_t PIE:1;
2170  uint16_t EOQIE:1;
2171  uint16_t CFUIE:1;
2172  uint16_t:1;
2173  uint16_t CFFE:1;
2174  uint16_t CFFS:1;
2175  uint16_t:4;
2176  uint16_t RFOIE:1;
2177  uint16_t:1;
2178  uint16_t RFDE:1;
2179  uint16_t RFDS:1;
2180  } B;
2181  } IDCR[6]; /* Interrupt and DMA Control Registers */
2182
2183  uint32_t eqadc_reserved6;
2184
2185  union {
2186  uint32_t R;
2187  struct {
2188  uint32_t NCF:1;
2189  uint32_t TORF:1;
2190  uint32_t PF:1;
2191  uint32_t EOQF:1;
2192  uint32_t CFUF:1;
2193  uint32_t SSS:1;
2194  uint32_t CFFF:1;
2195  uint32_t:5;
2196  uint32_t RFOF:1;
2197  uint32_t:1;
2198  uint32_t RFDF:1;
2199  uint32_t:1;
2200  uint32_t CFCTR:4;
2201  uint32_t TNXTPTR:4;
2202  uint32_t RFCTR:4;
2203  uint32_t POPNXTPTR:4;
2204  } B;
2205  } FISR[6]; /* FIFO and Interrupt Status Registers */
2206
2207  uint32_t eqadc_reserved7;
2208
2209  uint32_t eqadc_reserved8;
2210
2211  union {
2212  uint16_t R;
2213  struct {
2214  uint16_t:5;
2215  uint16_t TCCF:11;
2216  } B;
2217  } CFTCR[6]; /* CFIFO Transfer Counter Registers */
2218
2219  uint32_t eqadc_reserved9;
2220
2221  union {
2222  uint32_t R;
2223  struct {
2224  uint32_t CFS0:2;
2225  uint32_t CFS1:2;
2226  uint32_t CFS2:2;
2227  uint32_t CFS3:2;
2228  uint32_t CFS4:2;
2229  uint32_t CFS5:2;
2230  uint32_t:5;
2231  uint32_t LCFTCB0:4;
2232  uint32_t TC_LCFTCB0:11;
2233  } B;
2234  } CFSSR0; /* CFIFO Status Register 0 */
2235
2236  union {
2237  uint32_t R;
2238  struct {
2239  uint32_t CFS0:2;
2240  uint32_t CFS1:2;
2241  uint32_t CFS2:2;
2242  uint32_t CFS3:2;
2243  uint32_t CFS4:2;
2244  uint32_t CFS5:2;
2245  uint32_t:5;
2246  uint32_t LCFTCB1:4;
2247  uint32_t TC_LCFTCB1:11;
2248  } B;
2249  } CFSSR1; /* CFIFO Status Register 1 */
2250
2251  union {
2252  uint32_t R;
2253  struct {
2254  uint32_t CFS0:2;
2255  uint32_t CFS1:2;
2256  uint32_t CFS2:2;
2257  uint32_t CFS3:2;
2258  uint32_t CFS4:2;
2259  uint32_t CFS5:2;
2260  uint32_t:4;
2261  uint32_t ECBNI:1;
2262  uint32_t LCFTSSI:4;
2263  uint32_t TC_LCFTSSI:11;
2264  } B;
2265  } CFSSR2; /* CFIFO Status Register 2 */
2266
2267  union {
2268  uint32_t R;
2269  struct {
2270  uint32_t CFS0:2;
2271  uint32_t CFS1:2;
2272  uint32_t CFS2:2;
2273  uint32_t CFS3:2;
2274  uint32_t CFS4:2;
2275  uint32_t CFS5:2;
2276  uint32_t:20;
2277  } B;
2278  } CFSR;
2279
2280  uint32_t eqadc_reserved11;
2281
2282  union {
2283  uint32_t R;
2284  struct {
2285  uint32_t:21;
2286  uint32_t MDT:3;
2287  uint32_t:4;
2288  uint32_t BR:4;
2289  } B;
2290  } SSICR; /* SSI Control Register */
2291
2292  union {
2293  uint32_t R;
2294  struct {
2295  uint32_t RDV:1;
2296  uint32_t:5;
2297  uint32_t RDATA:26;
2298  } B;
2299  } SSIRDR; /* SSI Recieve Data Register */
2300
2301  uint32_t eqadc_reserved12[17];
2302
2303  struct {
2304  union {
2305  uint32_t R;
2306  struct {
2307  uint32_t:32;
2308  } B;
2309  } R[4];
2310
2311  uint32_t eqadc_reserved13[12];
2312
2313  } CF[6];
2314
2315  uint32_t eqadc_reserved14[32];
2316
2317  struct {
2318  union {
2319  uint32_t R;
2320  struct {
2321  uint32_t:32;
2322  } B;
2323  } R[4];
2324
2325  uint32_t eqadc_reserved15[12];
2326
2327  } RF[6];
2328
2329  };
2330 /****************************************************************************/
2331 /* MODULE : DSPI */
2332 /****************************************************************************/
2333  struct DSPI_tag {
2334  union DSPI_MCR_tag {
2335  uint32_t R;
2336  struct {
2337  uint32_t MSTR:1;
2338  uint32_t CONT_SCKE:1;
2339  uint32_t DCONF:2;
2340  uint32_t FRZ:1;
2341  uint32_t MTFE:1;
2342  uint32_t PCSSE:1;
2343  uint32_t ROOE:1;
2344  uint32_t:2;
2345  uint32_t PCSIS5:1;
2346  uint32_t PCSIS4:1;
2347  uint32_t PCSIS3:1;
2348  uint32_t PCSIS2:1;
2349  uint32_t PCSIS1:1;
2350  uint32_t PCSIS0:1;
2351  uint32_t DOZE:1;
2352  uint32_t MDIS:1;
2353  uint32_t DIS_TXF:1;
2354  uint32_t DIS_RXF:1;
2355  uint32_t CLR_TXF:1;
2356  uint32_t CLR_RXF:1;
2357  uint32_t SMPL_PT:2;
2358  uint32_t:7;
2359  uint32_t HALT:1;
2360  } B;
2361  } MCR; /* Module Configuration Register */
2362
2363  uint32_t dspi_reserved1;
2364
2365  union {
2366  uint32_t R;
2367  struct {
2368  uint32_t TCNT:16;
2369  uint32_t:16;
2370  } B;
2371  } TCR;
2372
2373  union DSPI_CTAR_tag {
2374  uint32_t R;
2375  struct {
2376  uint32_t DBR:1;
2377  uint32_t FMSZ:4;
2378  uint32_t CPOL:1;
2379  uint32_t CPHA:1;
2380  uint32_t LSBFE:1;
2381  uint32_t PCSSCK:2;
2382  uint32_t PASC:2;
2383  uint32_t PDT:2;
2384  uint32_t PBR:2;
2385  uint32_t CSSCK:4;
2386  uint32_t ASC:4;
2387  uint32_t DT:4;
2388  uint32_t BR:4;
2389  } B;
2390  } CTAR[8]; /* Clock and Transfer Attributes Registers */
2391
2392  union DSPI_SR_tag {
2393  uint32_t R;
2394  struct {
2395  uint32_t TCF:1;
2396  uint32_t TXRXS:1;
2397  uint32_t:1;
2398  uint32_t EOQF:1;
2399  uint32_t TFUF:1;
2400  uint32_t:1;
2401  uint32_t TFFF:1;
2402  uint32_t:5;
2403  uint32_t RFOF:1;
2404  uint32_t:1;
2405  uint32_t RFDF:1;
2406  uint32_t:1;
2407  uint32_t TXCTR:4;
2408  uint32_t TXNXTPTR:4;
2409  uint32_t RXCTR:4;
2410  uint32_t POPNXTPTR:4;
2411  } B;
2412  } SR; /* Status Register */
2413
2414  union DSPI_RSER_tag {
2415  uint32_t R;
2416  struct {
2417  uint32_t TCFRE:1;
2418  uint32_t:2;
2419  uint32_t EOQFRE:1;
2420  uint32_t TFUFRE:1;
2421  uint32_t:1;
2422  uint32_t TFFFRE:1;
2423  uint32_t TFFFDIRS:1;
2424  uint32_t:4;
2425  uint32_t RFOFRE:1;
2426  uint32_t:1;
2427  uint32_t RFDFRE:1;
2428  uint32_t RFDFDIRS:1;
2429  uint32_t:16;
2430  } B;
2431  } RSER; /* DMA/Interrupt Request Select and Enable Register */
2432
2433  union DSPI_PUSHR_tag {
2434  uint32_t R;
2435  struct {
2436  uint32_t CONT:1;
2437  uint32_t CTAS:3;
2438  uint32_t EOQ:1;
2439  uint32_t CTCNT:1;
2440  uint32_t:4;
2441  uint32_t PCS5:1;
2442  uint32_t PCS4:1;
2443  uint32_t PCS3:1;
2444  uint32_t PCS2:1;
2445  uint32_t PCS1:1;
2446  uint32_t PCS0:1;
2447  uint32_t TXDATA:16;
2448  } B;
2449  } PUSHR; /* PUSH TX FIFO Register */
2450
2451  union DSPI_POPR_tag {
2452  uint32_t R;
2453  struct {
2454  uint32_t:16;
2455  uint32_t RXDATA:16;
2456  } B;
2457  } POPR; /* POP RX FIFO Register */
2458
2459  union {
2460  uint32_t R;
2461  struct {
2462  uint32_t TXCMD:16;
2463  uint32_t TXDATA:16;
2464  } B;
2465  } TXFR[4]; /* Transmit FIFO Registers */
2466
2467  uint32_t DSPI_reserved_txf[12];
2468
2469  union {
2470  uint32_t R;
2471  struct {
2472  uint32_t:16;
2473  uint32_t RXDATA:16;
2474  } B;
2475  } RXFR[4]; /* Transmit FIFO Registers */
2476
2477  uint32_t DSPI_reserved_rxf[12];
2478
2479  union {
2480  uint32_t R;
2481  struct {
2482  uint32_t MTOE:1;
2483  uint32_t:1;
2484  uint32_t MTOCNT:6;
2485  uint32_t:4;
2486  uint32_t TXSS:1;
2487  uint32_t TPOL:1;
2488  uint32_t TRRE:1;
2489  uint32_t CID:1;
2490  uint32_t DCONT:1;
2491  uint32_t DSICTAS:3;
2492  uint32_t:6;
2493  uint32_t DPCS5:1;
2494  uint32_t DPCS4:1;
2495  uint32_t DPCS3:1;
2496  uint32_t DPCS2:1;
2497  uint32_t DPCS1:1;
2498  uint32_t DPCS0:1;
2499  } B;
2500  } DSICR; /* DSI Configuration Register */
2501
2502  union {
2503  uint32_t R;
2504  struct {
2505  uint32_t:16;
2506  uint32_t SER_DATA:16;
2507  } B;
2508  } SDR; /* DSI Serialization Data Register */
2509
2510  union {
2511  uint32_t R;
2512  struct {
2513  uint32_t:16;
2514  uint32_t ASER_DATA:16;
2515  } B;
2516  } ASDR; /* DSI Alternate Serialization Data Register */
2517
2518  union {
2519  uint32_t R;
2520  struct {
2521  uint32_t:16;
2522  uint32_t COMP_DATA:16;
2523  } B;
2524  } COMPR; /* DSI Transmit Comparison Register */
2525
2526  union {
2527  uint32_t R;
2528  struct {
2529  uint32_t:16;
2530  uint32_t DESER_DATA:16;
2531  } B;
2532  } DDR; /* DSI deserialization Data Register */
2533
2534  };
2535 /****************************************************************************/
2536 /* MODULE : eSCI */
2537 /****************************************************************************/
2538  struct ESCI_tag {
2539  union ESCI_CR1_tag {
2540  uint32_t R;
2541  struct {
2542  uint32_t:3;
2543  uint32_t SBR:13;
2544  uint32_t LOOPS:1;
2545  uint32_t SCISDOZ:1;
2546  uint32_t RSRC:1;
2547  uint32_t M:1;
2548  uint32_t WAKE:1;
2549  uint32_t ILT:1;
2550  uint32_t PE:1;
2551  uint32_t PT:1;
2552  uint32_t TIE:1;
2553  uint32_t TCIE:1;
2554  uint32_t RIE:1;
2555  uint32_t ILIE:1;
2556  uint32_t TE:1;
2557  uint32_t RE:1;
2558  uint32_t RWU:1;
2559  uint32_t SBK:1;
2560  } B;
2561  } CR1; /* Control Register 1 */
2562
2563  union ESCI_CR2_tag {
2564  uint16_t R;
2565  struct {
2566  uint16_t MDIS:1;
2567  uint16_t FBR:1;
2568  uint16_t BSTP:1;
2569  uint16_t IEBERR:1;
2570  uint16_t RXDMA:1;
2571  uint16_t TXDMA:1;
2572  uint16_t BRK13:1;
2573  uint16_t:1;
2574  uint16_t BESM13:1;
2575  uint16_t SBSTP:1;
2576  uint16_t:2;
2577  uint16_t ORIE:1;
2578  uint16_t NFIE:1;
2579  uint16_t FEIE:1;
2580  uint16_t PFIE:1;
2581  } B;
2582  } CR2; /* Control Register 2 */
2583
2584  union ESCI_DR_tag {
2585  uint16_t R;
2586  struct {
2587  uint16_t R8:1;
2588  uint16_t T8:1;
2589  uint16_t:6;
2590  uint8_t D;
2591  } B;
2592  } DR; /* Data Register */
2593
2594  union ESCI_SR_tag {
2595  uint32_t R;
2596  struct {
2597  uint32_t TDRE:1;
2598  uint32_t TC:1;
2599  uint32_t RDRF:1;
2600  uint32_t IDLE:1;
2601  uint32_t OR:1;
2602  uint32_t NF:1;
2603  uint32_t FE:1;
2604  uint32_t PF:1;
2605  uint32_t:3;
2606  uint32_t BERR:1;
2607  uint32_t:3;
2608  uint32_t RAF:1;
2609  uint32_t RXRDY:1;
2610  uint32_t TXRDY:1;
2611  uint32_t LWAKE:1;
2612  uint32_t STO:1;
2613  uint32_t PBERR:1;
2614  uint32_t CERR:1;
2615  uint32_t CKERR:1;
2616  uint32_t FRC:1;
2617  uint32_t:7;
2618  uint32_t OVFL:1;
2619  } B;
2620  } SR; /* Status Register */
2621
2622  union {
2623  uint32_t R;
2624  struct {
2625  uint32_t LRES:1;
2626  uint32_t WU:1;
2627  uint32_t WUD0:1;
2628  uint32_t WUD1:1;
2629  uint32_t LDBG:1;
2630  uint32_t DSF:1;
2631  uint32_t PRTY:1;
2632  uint32_t LIN:1;
2633  uint32_t RXIE:1;
2634  uint32_t TXIE:1;
2635  uint32_t WUIE:1;
2636  uint32_t STIE:1;
2637  uint32_t PBIE:1;
2638  uint32_t CIE:1;
2639  uint32_t CKIE:1;
2640  uint32_t FCIE:1;
2641  uint32_t:7;
2642  uint32_t OFIE:1;
2643  uint32_t:8;
2644  } B;
2645  } LCR; /* LIN Control Register */
2646
2647  union {
2648  uint32_t R;
2649  } LTR; /* LIN Transmit Register */
2650
2651  union {
2652  uint32_t R;
2653  } LRR; /* LIN Recieve Register */
2654
2655  union {
2656  uint32_t R;
2657  } LPR; /* LIN CRC Polynom Register */
2658
2659  };
2660 /****************************************************************************/
2661 /* MODULE : FlexCAN */
2662 /****************************************************************************/
2663  struct FLEXCAN2_tag {
2664  union {
2665  uint32_t R;
2666  struct {
2667  uint32_t MDIS:1;
2668  uint32_t FRZ:1;
2669  uint32_t:1;
2670  uint32_t HALT:1;
2671  uint32_t NOTRDY:1;
2672  uint32_t:1;
2673  uint32_t SOFTRST:1;
2674  uint32_t FRZACK:1;
2675  uint32_t:1;
2676  uint32_t:1;
2677
2678  uint32_t WRNEN:1;
2679
2680  uint32_t MDISACK:1;
2681  uint32_t:1;
2682  uint32_t:1;
2683
2684  uint32_t SRXDIS:1;
2685  uint32_t MBFEN:1;
2686  uint32_t:10;
2687
2688  uint32_t MAXMB:6;
2689  } B;
2690  } MCR; /* Module Configuration Register */
2691
2692  union {
2693  uint32_t R;
2694  struct {
2695  uint32_t PRESDIV:8;
2696  uint32_t RJW:2;
2697  uint32_t PSEG1:3;
2698  uint32_t PSEG2:3;
2699  uint32_t BOFFMSK:1;
2700  uint32_t ERRMSK:1;
2701  uint32_t CLKSRC:1;
2702  uint32_t LPB:1;
2703
2704  uint32_t TWRNMSK:1;
2705  uint32_t RWRNMSK:1;
2706  uint32_t:2;
2707
2708  uint32_t SMP:1;
2709  uint32_t BOFFREC:1;
2710  uint32_t TSYN:1;
2711  uint32_t LBUF:1;
2712  uint32_t LOM:1;
2713  uint32_t PROPSEG:3;
2714  } B;
2715  } CR; /* Control Register */
2716
2717  union {
2718  uint32_t R;
2719  } TIMER; /* Free Running Timer */
2720  int32_t FLEXCAN_reserved00;
2721
2722  union {
2723  uint32_t R;
2724  struct {
2725  uint32_t:3;
2726  uint32_t MI:29;
2727  } B;
2728  } RXGMASK; /* RX Global Mask */
2729
2730  union {
2731  uint32_t R;
2732  struct {
2733  uint32_t:3;
2734  uint32_t MI:29;
2735  } B;
2736  } RX14MASK; /* RX 14 Mask */
2737
2738  union {
2739  uint32_t R;
2740  struct {
2741  uint32_t:3;
2742  uint32_t MI:29;
2743  } B;
2744  } RX15MASK; /* RX 15 Mask */
2745
2746  union {
2747  uint32_t R;
2748  struct {
2749  uint32_t:16;
2750  uint32_t RXECNT:8;
2751  uint32_t TXECNT:8;
2752  } B;
2753  } ECR; /* Error Counter Register */
2754
2755  union {
2756  uint32_t R;
2757  struct {
2758  uint32_t:14;
2759
2760  uint32_t TWRNINT:1;
2761  uint32_t RWRNINT:1;
2762
2763  uint32_t BIT1ERR:1;
2764  uint32_t BIT0ERR:1;
2765  uint32_t ACKERR:1;
2766  uint32_t CRCERR:1;
2767  uint32_t FRMERR:1;
2768  uint32_t STFERR:1;
2769  uint32_t TXWRN:1;
2770  uint32_t RXWRN:1;
2771  uint32_t IDLE:1;
2772  uint32_t TXRX:1;
2773  uint32_t FLTCONF:2;
2774  uint32_t:1;
2775  uint32_t BOFFINT:1;
2776  uint32_t ERRINT:1;
2777  uint32_t:1;
2778  } B;
2779  } ESR; /* Error and Status Register */
2780
2781  union {
2782  uint32_t R;
2783  struct {
2784  uint32_t BUF63M:1;
2785  uint32_t BUF62M:1;
2786  uint32_t BUF61M:1;
2787  uint32_t BUF60M:1;
2788  uint32_t BUF59M:1;
2789  uint32_t BUF58M:1;
2790  uint32_t BUF57M:1;
2791  uint32_t BUF56M:1;
2792  uint32_t BUF55M:1;
2793  uint32_t BUF54M:1;
2794  uint32_t BUF53M:1;
2795  uint32_t BUF52M:1;
2796  uint32_t BUF51M:1;
2797  uint32_t BUF50M:1;
2798  uint32_t BUF49M:1;
2799  uint32_t BUF48M:1;
2800  uint32_t BUF47M:1;
2801  uint32_t BUF46M:1;
2802  uint32_t BUF45M:1;
2803  uint32_t BUF44M:1;
2804  uint32_t BUF43M:1;
2805  uint32_t BUF42M:1;
2806  uint32_t BUF41M:1;
2807  uint32_t BUF40M:1;
2808  uint32_t BUF39M:1;
2809  uint32_t BUF38M:1;
2810  uint32_t BUF37M:1;
2811  uint32_t BUF36M:1;
2812  uint32_t BUF35M:1;
2813  uint32_t BUF34M:1;
2814  uint32_t BUF33M:1;
2815  uint32_t BUF32M:1;
2816  } B;
2817  } IMRH; /* Interruput Masks Register */
2818
2819  union {
2820  uint32_t R;
2821  struct {
2822  uint32_t BUF31M:1;
2823  uint32_t BUF30M:1;
2824  uint32_t BUF29M:1;
2825  uint32_t BUF28M:1;
2826  uint32_t BUF27M:1;
2827  uint32_t BUF26M:1;
2828  uint32_t BUF25M:1;
2829  uint32_t BUF24M:1;
2830  uint32_t BUF23M:1;
2831  uint32_t BUF22M:1;
2832  uint32_t BUF21M:1;
2833  uint32_t BUF20M:1;
2834  uint32_t BUF19M:1;
2835  uint32_t BUF18M:1;
2836  uint32_t BUF17M:1;
2837  uint32_t BUF16M:1;
2838  uint32_t BUF15M:1;
2839  uint32_t BUF14M:1;
2840  uint32_t BUF13M:1;
2841  uint32_t BUF12M:1;
2842  uint32_t BUF11M:1;
2843  uint32_t BUF10M:1;
2844  uint32_t BUF09M:1;
2845  uint32_t BUF08M:1;
2846  uint32_t BUF07M:1;
2847  uint32_t BUF06M:1;
2848  uint32_t BUF05M:1;
2849  uint32_t BUF04M:1;
2850  uint32_t BUF03M:1;
2851  uint32_t BUF02M:1;
2852  uint32_t BUF01M:1;
2853  uint32_t BUF00M:1;
2854  } B;
2855  } IMRL; /* Interruput Masks Register */
2856
2857  union {
2858  uint32_t R;
2859  struct {
2860  uint32_t BUF63I:1;
2861  uint32_t BUF62I:1;
2862  uint32_t BUF61I:1;
2863  uint32_t BUF60I:1;
2864  uint32_t BUF59I:1;
2865  uint32_t BUF58I:1;
2866  uint32_t BUF57I:1;
2867  uint32_t BUF56I:1;
2868  uint32_t BUF55I:1;
2869  uint32_t BUF54I:1;
2870  uint32_t BUF53I:1;
2871  uint32_t BUF52I:1;
2872  uint32_t BUF51I:1;
2873  uint32_t BUF50I:1;
2874  uint32_t BUF49I:1;
2875  uint32_t BUF48I:1;
2876  uint32_t BUF47I:1;
2877  uint32_t BUF46I:1;
2878  uint32_t BUF45I:1;
2879  uint32_t BUF44I:1;
2880  uint32_t BUF43I:1;
2881  uint32_t BUF42I:1;
2882  uint32_t BUF41I:1;
2883  uint32_t BUF40I:1;
2884  uint32_t BUF39I:1;
2885  uint32_t BUF38I:1;
2886  uint32_t BUF37I:1;
2887  uint32_t BUF36I:1;
2888  uint32_t BUF35I:1;
2889  uint32_t BUF34I:1;
2890  uint32_t BUF33I:1;
2891  uint32_t BUF32I:1;
2892  } B;
2893  } IFRH; /* Interruput Flag Register */
2894
2895  union {
2896  uint32_t R;
2897  struct {
2898  uint32_t BUF31I:1;
2899  uint32_t BUF30I:1;
2900  uint32_t BUF29I:1;
2901  uint32_t BUF28I:1;
2902  uint32_t BUF27I:1;
2903  uint32_t BUF26I:1;
2904  uint32_t BUF25I:1;
2905  uint32_t BUF24I:1;
2906  uint32_t BUF23I:1;
2907  uint32_t BUF22I:1;
2908  uint32_t BUF21I:1;
2909  uint32_t BUF20I:1;
2910  uint32_t BUF19I:1;
2911  uint32_t BUF18I:1;
2912  uint32_t BUF17I:1;
2913  uint32_t BUF16I:1;
2914  uint32_t BUF15I:1;
2915  uint32_t BUF14I:1;
2916  uint32_t BUF13I:1;
2917  uint32_t BUF12I:1;
2918  uint32_t BUF11I:1;
2919  uint32_t BUF10I:1;
2920  uint32_t BUF09I:1;
2921  uint32_t BUF08I:1;
2922  uint32_t BUF07I:1;
2923  uint32_t BUF06I:1;
2924  uint32_t BUF05I:1;
2925  uint32_t BUF04I:1;
2926  uint32_t BUF03I:1;
2927  uint32_t BUF02I:1;
2928  uint32_t BUF01I:1;
2929  uint32_t BUF00I:1;
2930  } B;
2931  } IFRL; /* Interruput Flag Register */
2932
2933  uint32_t flexcan2_reserved2[19];
2934
2935  struct canbuf_t {
2936  union {
2937  uint32_t R;
2938  struct {
2939  uint32_t:4;
2940  uint32_t CODE:4;
2941  uint32_t:1;
2942  uint32_t SRR:1;
2943  uint32_t IDE:1;
2944  uint32_t RTR:1;
2945  uint32_t LENGTH:4;
2946  uint32_t TIMESTAMP:16;
2947  } B;
2948  } CS;
2949
2950  union {
2951  uint32_t R;
2952  struct {
2953  uint32_t:3;
2954  uint32_t STD_ID:11;
2955  uint32_t EXT_ID:18;
2956  } B;
2957  } ID;
2958
2959  union {
2960  uint8_t B[8]; /* Data buffer in Bytes (8 bits) */
2961  uint16_t H[4]; /* Data buffer in Half-words (16 bits) */
2962  uint32_t W[2]; /* Data buffer in words (32 bits) */
2963  uint32_t R[2]; /* Data buffer in words (32 bits) */
2964  } DATA;
2965
2966  } BUF[64];
2967
2968  uint32_t flexcan2_reserved3[256];
2969
2970  union {
2971  uint32_t R;
2972  struct {
2973  uint32_t:3;
2974  uint32_t MI:29;
2975  } B;
2976  } RXIMR[64]; /* RX Individual Mask Registers */
2977
2978  };
2979 /****************************************************************************/
2980 /* MODULE : FEC */
2981 /****************************************************************************/
2982  struct FEC_tag {
2983
2984  uint32_t fec_reserved_start[0x1];
2985
2986  union {
2987  uint32_t R;
2988  struct {
2989  uint32_t HBERR:1;
2990  uint32_t BABR:1;
2991  uint32_t BABT:1;
2992  uint32_t GRA:1;
2993  uint32_t TXF:1;
2994  uint32_t TXB:1;
2995  uint32_t RXF:1;
2996  uint32_t RXB:1;
2997  uint32_t MII:1;
2998  uint32_t EBERR:1;
2999  uint32_t LC:1;
3000  uint32_t RL:1;
3001  uint32_t UN:1;
3002  uint32_t:19;
3003  } B;
3004  } EIR; /* Interrupt Event Register */
3005
3006  union {
3007  uint32_t R;
3008  struct {
3009  uint32_t HBERRM:1;
3010  uint32_t BABRM:1;
3011  uint32_t BABTM:1;
3012  uint32_t GRAM:1;
3013  uint32_t TXFM:1;
3014  uint32_t TXBM:1;
3015  uint32_t RXFM:1;
3016  uint32_t RXBM:1;
3017  uint32_t MIIM:1;
3018  uint32_t EBERRM:1;
3019  uint32_t LCM:1;
3020  uint32_t RLM:1;
3021  uint32_t UNM:1;
3022  uint32_t:19;
3023  } B;
3024  } EIMR; /* Interrupt Mask Register */
3025
3026  uint32_t fec_reserved_eimr;
3027
3028  union {
3029  uint32_t R;
3030  struct {
3031  uint32_t:7;
3032  uint32_t R_DES_ACTIVE:1;
3033  uint32_t:24;
3034  } B;
3035  } RDAR; /* Receive Descriptor Active Register */
3036
3037  union {
3038  uint32_t R;
3039  struct {
3040  uint32_t:7;
3041  uint32_t X_DES_ACTIVE:1;
3042  uint32_t:24;
3043  } B;
3044  } TDAR; /* Transmit Descriptor Active Register */
3045
3046  uint32_t fec_reserved_tdar[3];
3047
3048  union {
3049  uint32_t R;
3050  struct {
3051  uint32_t:30;
3052  uint32_t ETHER_EN:1;
3053  uint32_t RESET:1;
3054  } B;
3055  } ECR; /* Ethernet Control Register */
3056
3057  uint32_t fec_reserved_ecr[6];
3058
3059  union {
3060  uint32_t R;
3061  struct {
3062  uint32_t ST:2;
3063  uint32_t CP:2;
3064  uint32_t PA:5;
3065  uint32_t RA:5;
3066  uint32_t TA:2;
3067  uint32_t DATA:16;
3068  } B;
3069  } MDATA; /* MII Data Register */
3070
3071  union {
3072  uint32_t R;
3073  struct {
3074  uint32_t:24;
3075  uint32_t DIS_PREAMBLE:1;
3076  uint32_t MII_SPEED:6;
3077  uint32_t:1;
3078  } B;
3079  } MSCR; /* MII Speed Control Register */
3080
3081  uint32_t fec_reserved_mscr[7];
3082
3083  union {
3084  uint32_t R;
3085  struct {
3086  uint32_t MIB_DISABLE:1;
3087  uint32_t MIB_IDLE:1;
3088  uint32_t:30;
3089  } B;
3090  } MIBC; /* MIB Control Register */
3091
3092  uint32_t fec_reserved_mibc[7];
3093
3094  union {
3095  uint32_t R;
3096  struct {
3097  uint32_t:5;
3098  uint32_t MAX_FL:11;
3099  uint32_t:10;
3100  uint32_t FCE:1;
3101  uint32_t BC_REJ:1;
3102  uint32_t PROM:1;
3103  uint32_t MII_MODE:1;
3104  uint32_t DRT:1;
3105  uint32_t LOOP:1;
3106  } B;
3107  } RCR; /* Receive Control Register */
3108
3109  uint32_t fec_reserved_rcr[15];
3110
3111  union {
3112  uint32_t R;
3113  struct {
3114  uint32_t:27;
3115  uint32_t RFC_PAUSE:1;
3116  uint32_t TFC_PAUSE:1;
3117  uint32_t FDEN:1;
3118  uint32_t HBC:1;
3119  uint32_t GTS:1;
3120  } B;
3121  } TCR; /* Transmit Control Register */
3122
3123  uint32_t fec_reserved_tcr[7];
3124
3125  union {
3126  uint32_t R;
3127  struct {
3128  uint32_t PADDR1:32;
3129  } B;
3130  } PALR; /* Physical Address Low Register */
3131
3132  union {
3133  uint32_t R;
3134  struct {
3135  uint32_t PADDR2:16;
3136  uint32_t TYPE:16;
3137  } B;
3138  } PAUR; /* Physical Address High + Type Register */
3139
3140  union {
3141  uint32_t R;
3142  struct {
3143  uint32_t OPCODE:16;
3144  uint32_t PAUSE_DUR:16;
3145  } B;
3146  } OPD; /* Opcode/Pause Duration Register */
3147
3148  uint32_t fec_reserved_opd[10];
3149
3150  union {
3151  uint32_t R;
3152  struct {
3153  uint32_t IADDR1:32;
3154  } B;
3155  } IAUR; /* Descriptor Individual Upper Address Register */
3156
3157  union {
3158  uint32_t R;
3159  struct {
3160  uint32_t IADDR2:32;
3161  } B;
3162  } IALR; /* Descriptor Individual Lower Address Register */
3163
3164  union {
3165  uint32_t R;
3166  struct {
3167  uint32_t GADDR1:32;
3168  } B;
3169  } GAUR; /* Descriptor Group Upper Address Register */
3170
3171  union {
3172  uint32_t R;
3173  struct {
3174  uint32_t GADDR2:32;
3175  } B;
3176  } GALR; /* Descriptor Group Lower Address Register */
3177
3178  uint32_t fec_reserved_galr[7];
3179
3180  union {
3181  uint32_t R;
3182  struct {
3183  uint32_t:30;
3184  uint32_t X_WMRK:2;
3185  } B;
3186  } TFWR; /* FIFO Transmit FIFO Watermark Register */
3187
3188  uint32_t fec_reserved_tfwr;
3189
3190  union {
3191  uint32_t R;
3192  struct {
3193  uint32_t:22;
3194  uint32_t R_BOUND:8;
3195  uint32_t:2;
3196  } B;
3197  } FRBR; /* FIFO Receive Bound Register */
3198
3199  union {
3200  uint32_t R;
3201  struct {
3202  uint32_t:22;
3203  uint32_t R_FSTART:8;
3204  uint32_t:2;
3205  } B;
3206  } FRSR; /* FIFO Receive Start Register */
3207
3208  uint32_t fec_reserved_frsr[11];
3209
3210  union {
3211  uint32_t R;
3212  struct {
3213  uint32_t R_DES_START:30;
3214  uint32_t:2;
3215  } B;
3216  } ERDSR; /* Receive Descriptor Ring Start Register */
3217
3218  union {
3219  uint32_t R;
3220  struct {
3221  uint32_t X_DES_START:30;
3222  uint32_t:2;
3223  } B;
3224  } ETDSR; /* Transmit Descriptor Ring Start Register */
3225
3226  union {
3227  uint32_t R;
3228  struct {
3229  uint32_t:21;
3230  uint32_t R_BUF_SIZE:7;
3231  uint32_t:4;
3232  } B;
3233  } EMRBR; /* Receive Buffer Size Register */
3234
3235  uint32_t fec_reserved_emrbr[29];
3236
3237  union {
3238  uint32_t R;
3239  } RMON_T_DROP; /* Count of frames not counted correctly */
3240
3241  union {
3242  uint32_t R;
3243  } RMON_T_PACKETS; /* RMON Tx packet count */
3244
3245  union {
3246  uint32_t R;
3247  } RMON_T_BC_PKT; /* RMON Tx Broadcast Packets */
3248
3249  union {
3250  uint32_t R;
3251  } RMON_T_MC_PKT; /* RMON Tx Multicast Packets */
3252
3253  union {
3254  uint32_t R;
3255  } RMON_T_CRC_ALIGN; /* RMON Tx Packets w CRC/Align error */
3256
3257  union {
3258  uint32_t R;
3259  } RMON_T_UNDERSIZE; /* RMON Tx Packets < 64 bytes, good crc */
3260
3261  union {
3262  uint32_t R;
3263  } RMON_T_OVERSIZE; /* RMON Tx Packets > MAX_FL bytes, good crc */
3264
3265  union {
3266  uint32_t R;
3267  } RMON_T_FRAG; /* RMON Tx Packets < 64 bytes, bad crc */
3268
3269  union {
3270  uint32_t R;
3271  } RMON_T_JAB; /* RMON Tx Packets > MAX_FL bytes, bad crc */
3272
3273  union {
3274  uint32_t R;
3275  } RMON_T_COL; /* RMON Tx collision count */
3276
3277  union {
3278  uint32_t R;
3279  } RMON_T_P64; /* RMON Tx 64 byte packets */
3280
3281  union {
3282  uint32_t R;
3283  } RMON_T_P65TO127; /* RMON Tx 65 to 127 byte packets */
3284
3285  union {
3286  uint32_t R;
3287  } RMON_T_P128TO255; /* RMON Tx 128 to 255 byte packets */
3288
3289  union {
3290  uint32_t R;
3291  } RMON_T_P256TO511; /* RMON Tx 256 to 511 byte packets */
3292
3293  union {
3294  uint32_t R;
3295  } RMON_T_P512TO1023; /* RMON Tx 512 to 1023 byte packets */
3296
3297  union {
3298  uint32_t R;
3299  } RMON_T_P1024TO2047; /* RMON Tx 1024 to 2047 byte packets */
3300
3301  union {
3302  uint32_t R;
3303  } RMON_T_P_GTE2048; /* RMON Tx packets w > 2048 bytes */
3304
3305  union {
3306  uint32_t R;
3307  } RMON_T_OCTETS; /* RMON Tx Octets */
3308
3309  union {
3310  uint32_t R;
3311  } IEEE_T_DROP; /* Count of frames not counted correctly */
3312
3313  union {
3314  uint32_t R;
3315  } IEEE_T_FRAME_OK; /* Frames Transmitted OK */
3316
3317  union {
3318  uint32_t R;
3319  } IEEE_T_1COL; /* Frames Transmitted with Single Collision */
3320
3321  union {
3322  uint32_t R;
3323  } IEEE_T_MCOL; /* Frames Transmitted with Multiple Collisions */
3324
3325  union {
3326  uint32_t R;
3327  } IEEE_T_DEF; /* Frames Transmitted after Deferral Delay */
3328
3329  union {
3330  uint32_t R;
3331  } IEEE_T_LCOL; /* Frames Transmitted with Late Collision */
3332
3333  union {
3334  uint32_t R;
3335  } IEEE_T_EXCOL; /* Frames Transmitted with Excessive Collisions */
3336
3337  union {
3338  uint32_t R;
3339  } IEEE_T_MACERR; /* Frames Transmitted with Tx FIFO Underrun */
3340
3341  union {
3342  uint32_t R;
3343  } IEEE_T_CSERR; /* Frames Transmitted with Carrier Sense Error */
3344
3345  union {
3346  uint32_t R;
3347  } IEEE_T_SQE; /* Frames Transmitted with SQE Error */
3348
3349  union {
3350  uint32_t R;
3351  } IEEE_T_FDXFC; /* Flow Control Pause frames transmitted */
3352
3353  union {
3354  uint32_t R;
3355  } IEEE_T_OCTETS_OK; /* Octet count for Frames Transmitted w/o Error */
3356
3357  uint32_t fec_reserved_rmon_t_octets_ok[2];
3358
3359  union {
3360  uint32_t R;
3361  } RMON_R_DROP; /* Count of frames not counted correctly */
3362
3363  union {
3364  uint32_t R;
3365  } RMON_R_PACKETS; /* RMON Rx packet count */
3366
3367  union {
3368  uint32_t R;
3369  } RMON_R_BC_PKT; /* RMON Rx Broadcast Packets */
3370
3371  union {
3372  uint32_t R;
3373  } RMON_R_MC_PKT; /* RMON Rx Multicast Packets */
3374
3375  union {
3376  uint32_t R;
3377  } RMON_R_CRC_ALIGN; /* RMON Rx Packets w CRC/Align error */
3378
3379  union {
3380  uint32_t R;
3381  } RMON_R_UNDERSIZE; /* RMON Rx Packets < 64 bytes, good crc */
3382
3383  union {
3384  uint32_t R;
3385  } RMON_R_OVERSIZE; /* RMON Rx Packets > MAX_FL bytes, good crc */
3386
3387  union {
3388  uint32_t R;
3389  } RMON_R_FRAG; /* RMON Rx Packets < 64 bytes, bad crc */
3390
3391  union {
3392  uint32_t R;
3393  } RMON_R_JAB; /* RMON Rx Packets > MAX_FL bytes, bad crc */
3394
3395  uint32_t fec_reserved_rmon_r_jab;
3396
3397  union {
3398  uint32_t R;
3399  } RMON_R_P64; /* RMON Rx 64 byte packets */
3400
3401  union {
3402  uint32_t R;
3403  } RMON_R_P65TO127; /* RMON Rx 65 to 127 byte packets */
3404
3405  union {
3406  uint32_t R;
3407  } RMON_R_P128TO255; /* RMON Rx 128 to 255 byte packets */
3408
3409  union {
3410  uint32_t R;
3411  } RMON_R_P256TO511; /* RMON Rx 256 to 511 byte packets */
3412
3413  union {
3414  uint32_t R;
3415  } RMON_R_P512TO1023; /* RMON Rx 512 to 1023 byte packets */
3416
3417  union {
3418  uint32_t R;
3419  } RMON_R_P1024TO2047; /* RMON Rx 1024 to 2047 byte packets */
3420
3421  union {
3422  uint32_t R;
3423  } RMON_R_P_GTE2048; /* RMON Rx packets w > 2048 bytes */
3424
3425  union {
3426  uint32_t R;
3427  } RMON_R_OCTETS; /* RMON Rx Octets */
3428
3429  union {
3430  uint32_t R;
3431  } IEEE_R_DROP; /* Count of frames not counted correctly */
3432
3433  union {
3434  uint32_t R;
3435  } IEEE_R_FRAME_OK; /* Frames Received OK */
3436
3437  union {
3438  uint32_t R;
3439  } IEEE_R_CRC; /* Frames Received with CRC Error */
3440
3441  union {
3442  uint32_t R;
3443  } IEEE_R_ALIGN; /* Frames Received with Alignment Error */
3444
3445  union {
3446  uint32_t R;
3447  } IEEE_R_MACERR; /* Receive Fifo Overflow count */
3448
3449  union {
3450  uint32_t R;
3451  } IEEE_R_FDXFC; /* Flow Control Pause frames received */
3452
3453  union {
3454  uint32_t R;
3455  } IEEE_R_OCTETS_OK; /* Octet count for Frames Rcvd w/o Error */
3456
3457  };
3458 /****************************************************************************/
3459 /* MODULE : FlexRay */
3460 /****************************************************************************/
3461
3462  typedef union uMVR {
3463  uint16_t R;
3464  struct {
3465  uint16_t CHIVER:8; /* CHI Version Number */
3466  uint16_t PEVER:8; /* PE Version Number */
3467  } B;
3468  } MVR_t;
3469
3470  typedef union uMCR {
3471  uint16_t R;
3472  struct {
3473  uint16_t MEN:1; /* module enable */
3474  uint16_t:1;
3475  uint16_t SCMD:1; /* single channel mode */
3476  uint16_t CHB:1; /* channel B enable */
3477  uint16_t CHA:1; /* channel A enable */
3478  uint16_t SFFE:1; /* synchronization frame filter enable */
3479  uint16_t:5;
3480  uint16_t CLKSEL:1; /* protocol engine clock source select */
3481  uint16_t PRESCALE:3; /* protocol engine clock prescaler */
3482  uint16_t:1;
3483  } B;
3484  } MCR_t;
3485  typedef union uSTBSCR {
3486  uint16_t R;
3487  struct {
3488  uint16_t WMD:1; /* write mode */
3489  uint16_t STBSSEL:7; /* strobe signal select */
3490  uint16_t:3;
3491  uint16_t ENB:1; /* strobe signal enable */
3492  uint16_t:2;
3493  uint16_t STBPSEL:2; /* strobe port select */
3494  } B;
3495  } STBSCR_t;
3496  typedef union uSTBPCR {
3497  uint16_t R;
3498  struct {
3499  uint16_t:12;
3500  uint16_t STB3EN:1; /* strobe port enable */
3501  uint16_t STB2EN:1; /* strobe port enable */
3502  uint16_t STB1EN:1; /* strobe port enable */
3503  uint16_t STB0EN:1; /* strobe port enable */
3504  } B;
3505  } STBPCR_t;
3506
3507  typedef union uMBDSR {
3508  uint16_t R;
3509  struct {
3510  uint16_t:1;
3511  uint16_t MBSEG2DS:7; /* message buffer segment 2 data size */
3512  uint16_t:1;
3513  uint16_t MBSEG1DS:7; /* message buffer segment 1 data size */
3514  } B;
3515  } MBDSR_t;
3516  typedef union uMBSSUTR {
3517  uint16_t R;
3518  struct {
3519
3520  uint16_t:1;
3521  uint16_t LAST_MB_SEG1:7; /* last message buffer control register for message buffer segment 1 */
3522  uint16_t:1;
3523  uint16_t LAST_MB_UTIL:7; /* last message buffer utilized */
3524  } B;
3525  } MBSSUTR_t;
3526
3527  typedef union uPOCR {
3528  uint16_t R;
3529  uint8_t byte[2];
3530  struct {
3531  uint16_t WME:1; /* write mode external correction command */
3532  uint16_t:3;
3533  uint16_t EOC_AP:2; /* external offset correction application */
3534  uint16_t ERC_AP:2; /* external rate correction application */
3535  uint16_t BSY:1; /* command write busy / write mode command */
3536  uint16_t:3;
3537  uint16_t POCCMD:4; /* protocol command */
3538  } B;
3539  } POCR_t;
3540 /* protocol commands */
3541  typedef union uGIFER {
3542  uint16_t R;
3543  struct {
3544  uint16_t MIF:1; /* module interrupt flag */
3545  uint16_t PRIF:1; /* protocol interrupt flag */
3546  uint16_t CHIF:1; /* CHI interrupt flag */
3547  uint16_t WKUPIF:1; /* wakeup interrupt flag */
3548  uint16_t FNEBIF:1; /* receive FIFO channel B not empty interrupt flag */
3549  uint16_t FNEAIF:1; /* receive FIFO channel A not empty interrupt flag */
3550  uint16_t RBIF:1; /* receive message buffer interrupt flag */
3551  uint16_t TBIF:1; /* transmit buffer interrupt flag */
3552  uint16_t MIE:1; /* module interrupt enable */
3553  uint16_t PRIE:1; /* protocol interrupt enable */
3554  uint16_t CHIE:1; /* CHI interrupt enable */
3555  uint16_t WKUPIE:1; /* wakeup interrupt enable */
3556  uint16_t FNEBIE:1; /* receive FIFO channel B not empty interrupt enable */
3557  uint16_t FNEAIE:1; /* receive FIFO channel A not empty interrupt enable */
3558  uint16_t RBIE:1; /* receive message buffer interrupt enable */
3559  uint16_t TBIE:1; /* transmit buffer interrupt enable */
3560  } B;
3561  } GIFER_t;
3562  typedef union uPIFR0 {
3563  uint16_t R;
3564  struct {
3565  uint16_t FATLIF:1; /* fatal protocol error interrupt flag */
3566  uint16_t INTLIF:1; /* internal protocol error interrupt flag */
3567  uint16_t ILCFIF:1; /* illegal protocol configuration flag */
3568  uint16_t CSAIF:1; /* cold start abort interrupt flag */
3569  uint16_t MRCIF:1; /* missing rate correctio interrupt flag */
3570  uint16_t MOCIF:1; /* missing offset correctio interrupt flag */
3571  uint16_t CCLIF:1; /* clock correction limit reached interrupt flag */
3572  uint16_t MXSIF:1; /* max sync frames detected interrupt flag */
3573  uint16_t MTXIF:1; /* media access test symbol received flag */
3574  uint16_t LTXBIF:1; /* pdLatestTx violation on channel B interrupt flag */
3575  uint16_t LTXAIF:1; /* pdLatestTx violation on channel A interrupt flag */
3576  uint16_t TBVBIF:1; /* Transmission across boundary on channel B Interrupt Flag */
3577  uint16_t TBVAIF:1; /* Transmission across boundary on channel A Interrupt Flag */
3578  uint16_t TI2IF:1; /* timer 2 expired interrupt flag */
3579  uint16_t TI1IF:1; /* timer 1 expired interrupt flag */
3580  uint16_t CYSIF:1; /* cycle start interrupt flag */
3581  } B;
3582  } PIFR0_t;
3583  typedef union uPIFR1 {
3584  uint16_t R;
3585  struct {
3586  uint16_t EMCIF:1; /* error mode changed interrupt flag */
3587  uint16_t IPCIF:1; /* illegal protocol command interrupt flag */
3588  uint16_t PECFIF:1; /* protocol engine communication failure interrupt flag */
3589  uint16_t PSCIF:1; /* Protocol State Changed Interrupt Flag */
3590  uint16_t SSI3IF:1; /* slot status counter incremented interrupt flag */
3591  uint16_t SSI2IF:1; /* slot status counter incremented interrupt flag */
3592  uint16_t SSI1IF:1; /* slot status counter incremented interrupt flag */
3593  uint16_t SSI0IF:1; /* slot status counter incremented interrupt flag */
3594  uint16_t:2;
3595  uint16_t EVTIF:1; /* even cycle table written interrupt flag */
3596  uint16_t ODTIF:1; /* odd cycle table written interrupt flag */
3597  uint16_t:4;
3598  } B;
3599  } PIFR1_t;
3600  typedef union uPIER0 {
3601  uint16_t R;
3602  struct {
3603  uint16_t FATLIE:1; /* fatal protocol error interrupt enable */
3604  uint16_t INTLIE:1; /* internal protocol error interrupt interrupt enable */
3605  uint16_t ILCFIE:1; /* illegal protocol configuration interrupt enable */
3606  uint16_t CSAIE:1; /* cold start abort interrupt enable */
3607  uint16_t MRCIE:1; /* missing rate correctio interrupt enable */
3608  uint16_t MOCIE:1; /* missing offset correctio interrupt enable */
3609  uint16_t CCLIE:1; /* clock correction limit reached interrupt enable */
3610  uint16_t MXSIE:1; /* max sync frames detected interrupt enable */
3611  uint16_t MTXIE:1; /* media access test symbol received interrupt enable */
3612  uint16_t LTXBIE:1; /* pdLatestTx violation on channel B interrupt enable */
3613  uint16_t LTXAIE:1; /* pdLatestTx violation on channel A interrupt enable */
3614  uint16_t TBVBIE:1; /* Transmission across boundary on channel B Interrupt enable */
3615  uint16_t TBVAIE:1; /* Transmission across boundary on channel A Interrupt enable */
3616  uint16_t TI2IE:1; /* timer 2 expired interrupt enable */
3617  uint16_t TI1IE:1; /* timer 1 expired interrupt enable */
3618  uint16_t CYSIE:1; /* cycle start interrupt enable */
3619  } B;
3620  } PIER0_t;
3621  typedef union uPIER1 {
3622  uint16_t R;
3623  struct {
3624  uint16_t EMCIE:1; /* error mode changed interrupt enable */
3625  uint16_t IPCIE:1; /* illegal protocol command interrupt enable */
3626  uint16_t PECFIE:1; /* protocol engine communication failure interrupt enable */
3627  uint16_t PSCIE:1; /* Protocol State Changed Interrupt enable */
3628  uint16_t SSI3IE:1; /* slot status counter incremented interrupt enable */
3629  uint16_t SSI2IE:1; /* slot status counter incremented interrupt enable */
3630  uint16_t SSI1IE:1; /* slot status counter incremented interrupt enable */
3631  uint16_t SSI0IE:1; /* slot status counter incremented interrupt enable */
3632  uint16_t:2;
3633  uint16_t EVTIE:1; /* even cycle table written interrupt enable */
3634  uint16_t ODTIE:1; /* odd cycle table written interrupt enable */
3635  uint16_t:4;
3636  } B;
3637  } PIER1_t;
3638  typedef union uCHIERFR {
3639  uint16_t R;
3640  struct {
3641  uint16_t FRLBEF:1; /* flame lost channel B error flag */
3642  uint16_t FRLAEF:1; /* frame lost channel A error flag */
3643  uint16_t PCMIEF:1; /* command ignored error flag */
3644  uint16_t FOVBEF:1; /* receive FIFO overrun channel B error flag */
3645  uint16_t FOVAEF:1; /* receive FIFO overrun channel A error flag */
3646  uint16_t MSBEF:1; /* message buffer search error flag */
3647  uint16_t MBUEF:1; /* message buffer utilization error flag */
3648  uint16_t LCKEF:1; /* lock error flag */
3649  uint16_t DBLEF:1; /* double transmit message buffer lock error flag */
3650  uint16_t SBCFEF:1; /* system bus communication failure error flag */
3651  uint16_t FIDEF:1; /* frame ID error flag */
3652  uint16_t DPLEF:1; /* dynamic payload length error flag */
3653  uint16_t SPLEF:1; /* static payload length error flag */
3654  uint16_t NMLEF:1; /* network management length error flag */
3655  uint16_t NMFEF:1; /* network management frame error flag */
3656  uint16_t ILSAEF:1; /* illegal access error flag */
3657  } B;
3658  } CHIERFR_t;
3659  typedef union uMBIVEC {
3660  uint16_t R;
3661  struct {
3662
3663  uint16_t:1;
3664  uint16_t TBIVEC:7; /* transmit buffer interrupt vector */
3665  uint16_t:1;
3666  uint16_t RBIVEC:7; /* receive buffer interrupt vector */
3667  } B;
3668  } MBIVEC_t;
3669
3670  typedef union uPSR0 {
3671  uint16_t R;
3672  struct {
3673  uint16_t ERRMODE:2; /* error mode */
3674  uint16_t SLOTMODE:2; /* slot mode */
3675  uint16_t:1;
3676  uint16_t PROTSTATE:3; /* protocol state */
3677  uint16_t SUBSTATE:4; /* protocol sub state */
3678  uint16_t:1;
3679  uint16_t WAKEUPSTATUS:3; /* wakeup status */
3680  } B;
3681  } PSR0_t;
3682
3683 /* protocol states */
3684 /* protocol sub-states */
3685 /* wakeup status */
3686  typedef union uPSR1 {
3687  uint16_t R;
3688  struct {
3689  uint16_t CSAA:1; /* cold start attempt abort flag */
3690  uint16_t SCP:1; /* cold start path */
3691  uint16_t:1;
3692  uint16_t REMCSAT:5; /* remanining coldstart attempts */
3693  uint16_t CPN:1; /* cold start noise path */
3694  uint16_t HHR:1; /* host halt request pending */
3695  uint16_t FRZ:1; /* freeze occured */
3696  uint16_t APTAC:5; /* allow passive to active counter */
3697  } B;
3698  } PSR1_t;
3699  typedef union uPSR2 {
3700  uint16_t R;
3701  struct {
3702  uint16_t NBVB:1; /* NIT boundary violation on channel B */
3703  uint16_t NSEB:1; /* NIT syntax error on channel B */
3704  uint16_t STCB:1; /* symbol window transmit conflict on channel B */
3705  uint16_t SBVB:1; /* symbol window boundary violation on channel B */
3706  uint16_t SSEB:1; /* symbol window syntax error on channel B */
3707  uint16_t MTB:1; /* media access test symbol MTS received on channel B */
3708  uint16_t NBVA:1; /* NIT boundary violation on channel A */
3709  uint16_t NSEA:1; /* NIT syntax error on channel A */
3710  uint16_t STCA:1; /* symbol window transmit conflict on channel A */
3711  uint16_t SBVA:1; /* symbol window boundary violation on channel A */
3712  uint16_t SSEA:1; /* symbol window syntax error on channel A */
3713  uint16_t MTA:1; /* media access test symbol MTS received on channel A */
3714  uint16_t CLKCORRFAILCNT:4; /* clock correction failed counter */
3715  } B;
3716  } PSR2_t;
3717  typedef union uPSR3 {
3718  uint16_t R;
3719  struct {
3720  uint16_t:2;
3721  uint16_t WUB:1; /* wakeup symbol received on channel B */
3722  uint16_t ABVB:1; /* aggregated boundary violation on channel B */
3723  uint16_t AACB:1; /* aggregated additional communication on channel B */
3724  uint16_t ACEB:1; /* aggregated content error on channel B */
3725  uint16_t ASEB:1; /* aggregated syntax error on channel B */
3726  uint16_t AVFB:1; /* aggregated valid frame on channel B */
3727  uint16_t:2;
3728  uint16_t WUA:1; /* wakeup symbol received on channel A */
3729  uint16_t ABVA:1; /* aggregated boundary violation on channel A */
3730  uint16_t AACA:1; /* aggregated additional communication on channel A */
3731  uint16_t ACEA:1; /* aggregated content error on channel A */
3732  uint16_t ASEA:1; /* aggregated syntax error on channel A */
3733  uint16_t AVFA:1; /* aggregated valid frame on channel A */
3734  } B;
3735  } PSR3_t;
3736  typedef union uCIFRR {
3737  uint16_t R;
3738  struct {
3739  uint16_t:8;
3740  uint16_t MIFR:1; /* module interrupt flag */
3741  uint16_t PRIFR:1; /* protocol interrupt flag */
3742  uint16_t CHIFR:1; /* CHI interrupt flag */
3743  uint16_t WUPIFR:1; /* wakeup interrupt flag */
3744  uint16_t FNEBIFR:1; /* receive fifo channel B no empty interrupt flag */
3745  uint16_t FNEAIFR:1; /* receive fifo channel A no empty interrupt flag */
3746  uint16_t RBIFR:1; /* receive message buffer interrupt flag */
3747  uint16_t TBIFR:1; /* transmit buffer interrupt flag */
3748  } B;
3749  } CIFRR_t;
3750  typedef union uSFCNTR {
3751  uint16_t R;
3752  struct {
3753  uint16_t SFEVB:4; /* sync frames channel B, even cycle */
3754  uint16_t SFEVA:4; /* sync frames channel A, even cycle */
3755  uint16_t SFODB:4; /* sync frames channel B, odd cycle */
3756  uint16_t SFODA:4; /* sync frames channel A, odd cycle */
3757  } B;
3758  } SFCNTR_t;
3759
3760  typedef union uSFTCCSR {
3761  uint16_t R;
3762  struct {
3763  uint16_t ELKT:1; /* even cycle tables lock and unlock trigger */
3764  uint16_t OLKT:1; /* odd cycle tables lock and unlock trigger */
3765  uint16_t CYCNUM:6; /* cycle number */
3766  uint16_t ELKS:1; /* even cycle tables lock status */
3767  uint16_t OLKS:1; /* odd cycle tables lock status */
3768  uint16_t EVAL:1; /* even cycle tables valid */
3769  uint16_t OVAL:1; /* odd cycle tables valid */
3770  uint16_t:1;
3771  uint16_t OPT:1; /*one pair trigger */
3772  uint16_t SDVEN:1; /* sync frame deviation table enable */
3773  uint16_t SIDEN:1; /* sync frame ID table enable */
3774  } B;
3775  } SFTCCSR_t;
3776  typedef union uSFIDRFR {
3777  uint16_t R;
3778  struct {
3779  uint16_t:6;
3780  uint16_t SYNFRID:10; /* sync frame rejection ID */
3781  } B;
3782  } SFIDRFR_t;
3783
3784  typedef union uTICCR {
3785  uint16_t R;
3786  struct {
3787  uint16_t:2;
3788  uint16_t T2CFG:1; /* timer 2 configuration */
3789  uint16_t T2REP:1; /* timer 2 repetitive mode */
3790  uint16_t:1;
3791  uint16_t T2SP:1; /* timer 2 stop */
3792  uint16_t T2TR:1; /* timer 2 trigger */
3793  uint16_t T2ST:1; /* timer 2 state */
3794  uint16_t:3;
3795  uint16_t T1REP:1; /* timer 1 repetitive mode */
3796  uint16_t:1;
3797  uint16_t T1SP:1; /* timer 1 stop */
3798  uint16_t T1TR:1; /* timer 1 trigger */
3799  uint16_t T1ST:1; /* timer 1 state */
3800
3801  } B;
3802  } TICCR_t;
3803  typedef union uTI1CYSR {
3804  uint16_t R;
3805  struct {
3806  uint16_t:2;
3807  uint16_t TI1CYCVAL:6; /* timer 1 cycle filter value */
3808  uint16_t:2;
3809  uint16_t TI1CYCMSK:6; /* timer 1 cycle filter mask */
3810
3811  } B;
3812  } TI1CYSR_t;
3813
3814  typedef union uSSSR {
3815  uint16_t R;
3816  struct {
3817  uint16_t WMD:1; /* write mode */
3818  uint16_t:1;
3819  uint16_t SEL:2; /* static slot number */
3820  uint16_t:1;
3821  uint16_t SLOTNUMBER:11; /* selector */
3822  } B;
3823  } SSSR_t;
3824
3825  typedef union uSSCCR {
3826  uint16_t R;
3827  struct {
3828  uint16_t WMD:1; /* write mode */
3829  uint16_t:1;
3830  uint16_t SEL:2; /* selector */
3831  uint16_t:1;
3832  uint16_t CNTCFG:2; /* counter configuration */
3833  uint16_t MCY:1; /* multi cycle selection */
3834  uint16_t VFR:1; /* valid frame selection */
3835  uint16_t SYF:1; /* sync frame selection */
3836  uint16_t NUF:1; /* null frame selection */
3837  uint16_t SUF:1; /* startup frame selection */
3838  uint16_t STATUSMASK:4; /* slot status mask */
3839  } B;
3840  } SSCCR_t;
3841  typedef union uSSR {
3842  uint16_t R;
3843  struct {
3844  uint16_t VFB:1; /* valid frame on channel B */
3845  uint16_t SYB:1; /* valid sync frame on channel B */
3846  uint16_t NFB:1; /* valid null frame on channel B */
3847  uint16_t SUB:1; /* valid startup frame on channel B */
3848  uint16_t SEB:1; /* syntax error on channel B */
3849  uint16_t CEB:1; /* content error on channel B */
3850  uint16_t BVB:1; /* boundary violation on channel B */
3851  uint16_t TCB:1; /* tx conflict on channel B */
3852  uint16_t VFA:1; /* valid frame on channel A */
3853  uint16_t SYA:1; /* valid sync frame on channel A */
3854  uint16_t NFA:1; /* valid null frame on channel A */
3855  uint16_t SUA:1; /* valid startup frame on channel A */
3856  uint16_t SEA:1; /* syntax error on channel A */
3857  uint16_t CEA:1; /* content error on channel A */
3858  uint16_t BVA:1; /* boundary violation on channel A */
3859  uint16_t TCA:1; /* tx conflict on channel A */
3860  } B;
3861  } SSR_t;
3862  typedef union uMTSCFR {
3863  uint16_t R;
3864  struct {
3865  uint16_t MTE:1; /* media access test symbol transmission enable */
3866  uint16_t:1;
3867  uint16_t CYCCNTMSK:6; /* cycle counter mask */
3868  uint16_t:2;
3869  uint16_t CYCCNTVAL:6; /* cycle counter value */
3870  } B;
3871  } MTSCFR_t;
3872  typedef union uRSBIR {
3873  uint16_t R;
3874  struct {
3875  uint16_t WMD:1; /* write mode */
3876  uint16_t:1;
3877  uint16_t SEL:2; /* selector */
3878  uint16_t:4;
3879  uint16_t RSBIDX:8; /* receive shadow buffer index */
3880  } B;
3881  } RSBIR_t;
3882  typedef union uRFDSR {
3883  uint16_t R;
3884  struct {
3885  uint16_t FIFODEPTH:8; /* fifo depth */
3886  uint16_t:1;
3887  uint16_t ENTRYSIZE:7; /* entry size */
3888  } B;
3889  } RFDSR_t;
3890
3891  typedef union uRFRFCFR {
3892  uint16_t R;
3893  struct {
3894  uint16_t WMD:1; /* write mode */
3895  uint16_t IBD:1; /* interval boundary */
3896  uint16_t SEL:2; /* filter number */
3897  uint16_t:1;
3898  uint16_t SID:11; /* slot ID */
3899  } B;
3900  } RFRFCFR_t;
3901
3902  typedef union uRFRFCTR {
3903  uint16_t R;
3904  struct {
3905  uint16_t:4;
3906  uint16_t F3MD:1; /* filter mode */
3907  uint16_t F2MD:1; /* filter mode */
3908  uint16_t F1MD:1; /* filter mode */
3909  uint16_t F0MD:1; /* filter mode */
3910  uint16_t:4;
3911  uint16_t F3EN:1; /* filter enable */
3912  uint16_t F2EN:1; /* filter enable */
3913  uint16_t F1EN:1; /* filter enable */
3914  uint16_t F0EN:1; /* filter enable */
3915  } B;
3916  } RFRFCTR_t;
3917  typedef union uPCR0 {
3918  uint16_t R;
3919  struct {
3920  uint16_t ACTION_POINT_OFFSET:6;
3921  uint16_t STATIC_SLOT_LENGTH:10;
3922  } B;
3923  } PCR0_t;
3924
3925  typedef union uPCR1 {
3926  uint16_t R;
3927  struct {
3928  uint16_t:2;
3929  uint16_t MACRO_AFTER_FIRST_STATIC_SLOT:14;
3930  } B;
3931  } PCR1_t;
3932
3933  typedef union uPCR2 {
3934  uint16_t R;
3935  struct {
3936  uint16_t MINISLOT_AFTER_ACTION_POINT:6;
3937  uint16_t NUMBER_OF_STATIC_SLOTS:10;
3938  } B;
3939  } PCR2_t;
3940
3941  typedef union uPCR3 {
3942  uint16_t R;
3943  struct {
3944  uint16_t WAKEUP_SYMBOL_RX_LOW:6;
3945  uint16_t MINISLOT_ACTION_POINT_OFFSET:5;
3946  uint16_t COLDSTART_ATTEMPTS:5;
3947  } B;
3948  } PCR3_t;
3949
3950  typedef union uPCR4 {
3951  uint16_t R;
3952  struct {
3953  uint16_t CAS_RX_LOW_MAX:7;
3954  uint16_t WAKEUP_SYMBOL_RX_WINDOW:9;
3955  } B;
3956  } PCR4_t;
3957
3958  typedef union uPCR5 {
3959  uint16_t R;
3960  struct {
3961  uint16_t TSS_TRANSMITTER:4;
3962  uint16_t WAKEUP_SYMBOL_TX_LOW:6;
3963  uint16_t WAKEUP_SYMBOL_RX_IDLE:6;
3964  } B;
3965  } PCR5_t;
3966
3967  typedef union uPCR6 {
3968  uint16_t R;
3969  struct {
3970  uint16_t:1;
3971  uint16_t SYMBOL_WINDOW_AFTER_ACTION_POINT:8;
3972  uint16_t MACRO_INITIAL_OFFSET_A:7;
3973  } B;
3974  } PCR6_t;
3975
3976  typedef union uPCR7 {
3977  uint16_t R;
3978  struct {
3979  uint16_t DECODING_CORRECTION_B:9;
3980  uint16_t MICRO_PER_MACRO_NOM_HALF:7;
3981  } B;
3982  } PCR7_t;
3983
3984  typedef union uPCR8 {
3985  uint16_t R;
3986  struct {
3987  uint16_t MAX_WITHOUT_CLOCK_CORRECTION_FATAL:4;
3988  uint16_t MAX_WITHOUT_CLOCK_CORRECTION_PASSIVE:4;
3989  uint16_t WAKEUP_SYMBOL_TX_IDLE:8;
3990  } B;
3991  } PCR8_t;
3992
3993  typedef union uPCR9 {
3994  uint16_t R;
3995  struct {
3996  uint16_t MINISLOT_EXISTS:1;
3997  uint16_t SYMBOL_WINDOW_EXISTS:1;
3998  uint16_t OFFSET_CORRECTION_OUT:14;
3999  } B;
4000  } PCR9_t;
4001
4002  typedef union uPCR10 {
4003  uint16_t R;
4004  struct {
4005  uint16_t SINGLE_SLOT_ENABLED:1;
4006  uint16_t WAKEUP_CHANNEL:1;
4007  uint16_t MACRO_PER_CYCLE:14;
4008  } B;
4009  } PCR10_t;
4010
4011  typedef union uPCR11 {
4012  uint16_t R;
4013  struct {
4014  uint16_t KEY_SLOT_USED_FOR_STARTUP:1;
4015  uint16_t KEY_SLOT_USED_FOR_SYNC:1;
4016  uint16_t OFFSET_CORRECTION_START:14;
4017  } B;
4018  } PCR11_t;
4019
4020  typedef union uPCR12 {
4021  uint16_t R;
4022  struct {
4023  uint16_t ALLOW_PASSIVE_TO_ACTIVE:5;
4024  uint16_t KEY_SLOT_HEADER_CRC:11;
4025  } B;
4026  } PCR12_t;
4027
4028  typedef union uPCR13 {
4029  uint16_t R;
4030  struct {
4031  uint16_t FIRST_MINISLOT_ACTION_POINT_OFFSET:6;
4032  uint16_t STATIC_SLOT_AFTER_ACTION_POINT:10;
4033  } B;
4034  } PCR13_t;
4035
4036  typedef union uPCR14 {
4037  uint16_t R;
4038  struct {
4039  uint16_t RATE_CORRECTION_OUT:11;
4040  uint16_t LISTEN_TIMEOUT_H:5;
4041  } B;
4042  } PCR14_t;
4043
4044  typedef union uPCR15 {
4045  uint16_t R;
4046  struct {
4047  uint16_t LISTEN_TIMEOUT_L:16;
4048  } B;
4049  } PCR15_t;
4050
4051  typedef union uPCR16 {
4052  uint16_t R;
4053  struct {
4054  uint16_t MACRO_INITIAL_OFFSET_B:7;
4055  uint16_t NOISE_LISTEN_TIMEOUT_H:9;
4056  } B;
4057  } PCR16_t;
4058
4059  typedef union uPCR17 {
4060  uint16_t R;
4061  struct {
4062  uint16_t NOISE_LISTEN_TIMEOUT_L:16;
4063  } B;
4064  } PCR17_t;
4065
4066  typedef union uPCR18 {
4067  uint16_t R;
4068  struct {
4069  uint16_t WAKEUP_PATTERN:6;
4070  uint16_t KEY_SLOT_ID:10;
4071  } B;
4072  } PCR18_t;
4073
4074  typedef union uPCR19 {
4075  uint16_t R;
4076  struct {
4077  uint16_t DECODING_CORRECTION_A:9;
4078  uint16_t PAYLOAD_LENGTH_STATIC:7;
4079  } B;
4080  } PCR19_t;
4081
4082  typedef union uPCR20 {
4083  uint16_t R;
4084  struct {
4085  uint16_t MICRO_INITIAL_OFFSET_B:8;
4086  uint16_t MICRO_INITIAL_OFFSET_A:8;
4087  } B;
4088  } PCR20_t;
4089
4090  typedef union uPCR21 {
4091  uint16_t R;
4092  struct {
4093  uint16_t EXTERN_RATE_CORRECTION:3;
4094  uint16_t LATEST_TX:13;
4095  } B;
4096  } PCR21_t;
4097
4098  typedef union uPCR22 {
4099  uint16_t R;
4100  struct {
4101  uint16_t:1;
4102  uint16_t COMP_ACCEPTED_STARTUP_RANGE_A:11;
4103  uint16_t MICRO_PER_CYCLE_H:4;
4104  } B;
4105  } PCR22_t;
4106
4107  typedef union uPCR23 {
4108  uint16_t R;
4109  struct {
4110  uint16_t micro_per_cycle_l:16;
4111  } B;
4112  } PCR23_t;
4113
4114  typedef union uPCR24 {
4115  uint16_t R;
4116  struct {
4117  uint16_t CLUSTER_DRIFT_DAMPING:5;
4118  uint16_t MAX_PAYLOAD_LENGTH_DYNAMIC:7;
4119  uint16_t MICRO_PER_CYCLE_MIN_H:4;
4120  } B;
4121  } PCR24_t;
4122
4123  typedef union uPCR25 {
4124  uint16_t R;
4125  struct {
4126  uint16_t MICRO_PER_CYCLE_MIN_L:16;
4127  } B;
4128  } PCR25_t;
4129
4130  typedef union uPCR26 {
4131  uint16_t R;
4132  struct {
4133  uint16_t ALLOW_HALT_DUE_TO_CLOCK:1;
4134  uint16_t COMP_ACCEPTED_STARTUP_RANGE_B:11;
4135  uint16_t MICRO_PER_CYCLE_MAX_H:4;
4136  } B;
4137  } PCR26_t;
4138
4139  typedef union uPCR27 {
4140  uint16_t R;
4141  struct {
4142  uint16_t MICRO_PER_CYCLE_MAX_L:16;
4143  } B;
4144  } PCR27_t;
4145
4146  typedef union uPCR28 {
4147  uint16_t R;
4148  struct {
4149  uint16_t DYNAMIC_SLOT_IDLE_PHASE:2;
4150  uint16_t MACRO_AFTER_OFFSET_CORRECTION:14;
4151  } B;
4152  } PCR28_t;
4153
4154  typedef union uPCR29 {
4155  uint16_t R;
4156  struct {
4157  uint16_t EXTERN_OFFSET_CORRECTION:3;
4158  uint16_t MINISLOTS_MAX:13;
4159  } B;
4160  } PCR29_t;
4161
4162  typedef union uPCR30 {
4163  uint16_t R;
4164  struct {
4165  uint16_t:12;
4166  uint16_t SYNC_NODE_MAX:4;
4167  } B;
4168  } PCR30_t;
4169
4170  typedef struct uMSG_BUFF_CCS {
4171  union {
4172  uint16_t R;
4173  struct {
4174  uint16_t:1;
4175  uint16_t MCM:1; /* message buffer commit mode */
4176  uint16_t MBT:1; /* message buffer type */
4177  uint16_t MTD:1; /* message buffer direction */
4178  uint16_t CMT:1; /* commit for transmission */
4179  uint16_t EDT:1; /* enable / disable trigger */
4180  uint16_t LCKT:1; /* lock request trigger */
4181  uint16_t MBIE:1; /* message buffer interrupt enable */
4182  uint16_t:3;
4183  uint16_t DUP:1; /* data updated */
4184  uint16_t DVAL:1; /* data valid */
4185  uint16_t EDS:1; /* lock status */
4186  uint16_t LCKS:1; /* enable / disable status */
4187  uint16_t MBIF:1; /* message buffer interrupt flag */
4188  } B;
4189  } MBCCSR;
4190  union {
4191  uint16_t R;
4192  struct {
4193  uint16_t MTM:1; /* message buffer transmission mode */
4194  uint16_t CHNLA:1; /* channel assignement */
4195  uint16_t CHNLB:1; /* channel assignement */
4196  uint16_t CCFE:1; /* cycle counter filter enable */
4197  uint16_t CCFMSK:6; /* cycle counter filter mask */
4198  uint16_t CCFVAL:6; /* cycle counter filter value */
4199  } B;
4200  } MBCCFR;
4201  union {
4202  uint16_t R;
4203  struct {
4204  uint16_t:5;
4205  uint16_t FID:11; /* frame ID */
4206  } B;
4207  } MBFIDR;
4208  union {
4209  uint16_t R;
4210  struct {
4211  uint16_t:8;
4212  uint16_t MBIDX:8; /* message buffer index */
4213  } B;
4214  } MBIDXR;
4215  } MSG_BUFF_CCS_t;
4216  typedef union uSYSBADHR {
4217  uint16_t R;
4218  } SYSBADHR_t;
4219  typedef union uSYSBADLR {
4220  uint16_t R;
4221  } SYSBADLR_t;
4222  typedef union uPDAR {
4223  uint16_t R;
4224  } PDAR_t;
4225  typedef union uCASERCR {
4226  uint16_t R;
4227  } CASERCR_t;
4228  typedef union uCBSERCR {
4229  uint16_t R;
4230  } CBSERCR_t;
4231  typedef union uCYCTR {
4232  uint16_t R;
4233  } CYCTR_t;
4234  typedef union uMTCTR {
4235  uint16_t R;
4236  } MTCTR_t;
4237  typedef union uSLTCTAR {
4238  uint16_t R;
4239  } SLTCTAR_t;
4240  typedef union uSLTCTBR {
4241  uint16_t R;
4242  } SLTCTBR_t;
4243  typedef union uRTCORVR {
4244  uint16_t R;
4245  } RTCORVR_t;
4246  typedef union uOFCORVR {
4247  uint16_t R;
4248  } OFCORVR_t;
4249  typedef union uSFTOR {
4250  uint16_t R;
4251  } SFTOR_t;
4252  typedef union uSFIDAFVR {
4253  uint16_t R;
4254  } SFIDAFVR_t;
4255  typedef union uSFIDAFMR {
4256  uint16_t R;
4257  } SFIDAFMR_t;
4258  typedef union uNMVR {
4259  uint16_t R;
4260  } NMVR_t;
4261  typedef union uNMVLR {
4262  uint16_t R;
4263  } NMVLR_t;
4264  typedef union uT1MTOR {
4265  uint16_t R;
4266  } T1MTOR_t;
4267  typedef union uTI2CR0 {
4268  uint16_t R;
4269  } TI2CR0_t;
4270  typedef union uTI2CR1 {
4271  uint16_t R;
4272  } TI2CR1_t;
4273  typedef union uSSCR {
4274  uint16_t R;
4275  } SSCR_t;
4276  typedef union uRFSR {
4277  uint16_t R;
4278  } RFSR_t;
4279  typedef union uRFSIR {
4280  uint16_t R;
4281  } RFSIR_t;
4282  typedef union uRFARIR {
4283  uint16_t R;
4284  } RFARIR_t;
4285  typedef union uRFBRIR {
4286  uint16_t R;
4287  } RFBRIR_t;
4288  typedef union uRFMIDAFVR {
4289  uint16_t R;
4290  } RFMIDAFVR_t;
4291  typedef union uRFMIAFMR {
4292  uint16_t R;
4293  } RFMIAFMR_t;
4294  typedef union uRFFIDRFVR {
4295  uint16_t R;
4296  } RFFIDRFVR_t;
4297  typedef union uRFFIDRFMR {
4298  uint16_t R;
4299  } RFFIDRFMR_t;
4300  typedef union uLDTXSLAR {
4301  uint16_t R;
4302  } LDTXSLAR_t;
4303  typedef union uLDTXSLBR {
4304  uint16_t R;
4305  } LDTXSLBR_t;
4306
4307  typedef struct FR_tag {
4308  volatile MVR_t MVR; /*module version register *//*0 */
4309  volatile MCR_t MCR; /*module configuration register *//*2 */
4310  volatile SYSBADHR_t SYSBADHR; /*system memory base address high register *//*4 */
4311  volatile SYSBADLR_t SYSBADLR; /*system memory base address low register *//*6 */
4312  volatile STBSCR_t STBSCR; /*strobe signal control register *//*8 */
4313  volatile STBPCR_t STBPCR; /*strobe port control register *//*A */
4314  volatile MBDSR_t MBDSR; /*message buffer data size register *//*C */
4315  volatile MBSSUTR_t MBSSUTR; /*message buffer segment size and utilization register *//*E */
4316  uint16_t reserved3a[1]; /*10 */
4317  volatile PDAR_t PDAR; /*PE data register *//*12 */
4318  volatile POCR_t POCR; /*Protocol operation control register *//*14 */
4319  volatile GIFER_t GIFER; /*global interrupt flag and enable register *//*16 */
4320  volatile PIFR0_t PIFR0; /*protocol interrupt flag register 0 *//*18 */
4321  volatile PIFR1_t PIFR1; /*protocol interrupt flag register 1 *//*1A */
4322  volatile PIER0_t PIER0; /*protocol interrupt enable register 0 *//*1C */
4323  volatile PIER1_t PIER1; /*protocol interrupt enable register 1 *//*1E */
4324  volatile CHIERFR_t CHIERFR; /*CHI error flag register *//*20 */
4325  volatile MBIVEC_t MBIVEC; /*message buffer interrupt vector register *//*22 */
4326  volatile CASERCR_t CASERCR; /*channel A status error counter register *//*24 */
4327  volatile CBSERCR_t CBSERCR; /*channel B status error counter register *//*26 */
4328  volatile PSR0_t PSR0; /*protocol status register 0 *//*28 */
4329  volatile PSR1_t PSR1; /*protocol status register 1 *//*2A */
4330  volatile PSR2_t PSR2; /*protocol status register 2 *//*2C */
4331  volatile PSR3_t PSR3; /*protocol status register 3 *//*2E */
4332  volatile MTCTR_t MTCTR; /*macrotick counter register *//*30 */
4333  volatile CYCTR_t CYCTR; /*cycle counter register *//*32 */
4334  volatile SLTCTAR_t SLTCTAR; /*slot counter channel A register *//*34 */
4335  volatile SLTCTBR_t SLTCTBR; /*slot counter channel B register *//*36 */
4336  volatile RTCORVR_t RTCORVR; /*rate correction value register *//*38 */
4337  volatile OFCORVR_t OFCORVR; /*offset correction value register *//*3A */
4338  volatile CIFRR_t CIFRR; /*combined interrupt flag register *//*3C */
4339  uint16_t reserved3[1]; /*3E */
4340  volatile SFCNTR_t SFCNTR; /*sync frame counter register *//*40 */
4341  volatile SFTOR_t SFTOR; /*sync frame table offset register *//*42 */
4342  volatile SFTCCSR_t SFTCCSR; /*sync frame table configuration, control, status register *//*44 */
4343  volatile SFIDRFR_t SFIDRFR; /*sync frame ID rejection filter register *//*46 */
4344  volatile SFIDAFVR_t SFIDAFVR; /*sync frame ID acceptance filter value regiater *//*48 */
4345  volatile SFIDAFMR_t SFIDAFMR; /*sync frame ID acceptance filter mask register *//*4A */
4346  volatile NMVR_t NMVR[6]; /*network management vector registers (12 bytes) *//*4C */
4347  volatile NMVLR_t NMVLR; /*network management vector length register *//*58 */
4348  volatile TICCR_t TICCR; /*timer configuration and control register *//*5A */
4349  volatile TI1CYSR_t TI1CYSR; /*timer 1 cycle set register *//*5C */
4350  volatile T1MTOR_t T1MTOR; /*timer 1 macrotick offset register *//*5E */
4351  volatile TI2CR0_t TI2CR0; /*timer 2 configuration register 0 *//*60 */
4352  volatile TI2CR1_t TI2CR1; /*timer 2 configuration register 1 *//*62 */
4353  volatile SSSR_t SSSR; /*slot status selection register *//*64 */
4354  volatile SSCCR_t SSCCR; /*slot status counter condition register *//*66 */
4355  volatile SSR_t SSR[8]; /*slot status registers 0-7 *//*68 */
4356  volatile SSCR_t SSCR[4]; /*slot status counter registers 0-3 *//*78 */
4357  volatile MTSCFR_t MTSACFR; /*mts a config register *//*80 */
4358  volatile MTSCFR_t MTSBCFR; /*mts b config register *//*82 */
4359  volatile RSBIR_t RSBIR; /*receive shadow buffer index register *//*84 */
4360  volatile RFSR_t RFSR; /*receive fifo selection register *//*86 */
4361  volatile RFSIR_t RFSIR; /*receive fifo start index register *//*88 */
4362  volatile RFDSR_t RFDSR; /*receive fifo depth and size register *//*8A */
4363  volatile RFARIR_t RFARIR; /*receive fifo a read index register *//*8C */
4364  volatile RFBRIR_t RFBRIR; /*receive fifo b read index register *//*8E */
4365  volatile RFMIDAFVR_t RFMIDAFVR; /*receive fifo message ID acceptance filter value register *//*90 */
4366  volatile RFMIAFMR_t RFMIAFMR; /*receive fifo message ID acceptance filter mask register *//*92 */
4367  volatile RFFIDRFVR_t RFFIDRFVR; /*receive fifo frame ID rejection filter value register *//*94 */
4368  volatile RFFIDRFMR_t RFFIDRFMR; /*receive fifo frame ID rejection filter mask register *//*96 */
4369  volatile RFRFCFR_t RFRFCFR; /*receive fifo range filter configuration register *//*98 */
4370  volatile RFRFCTR_t RFRFCTR; /*receive fifo range filter control register *//*9A */
4371  volatile LDTXSLAR_t LDTXSLAR; /*last dynamic transmit slot channel A register *//*9C */
4372  volatile LDTXSLBR_t LDTXSLBR; /*last dynamic transmit slot channel B register *//*9E */
4373  volatile PCR0_t PCR0; /*protocol configuration register 0 *//*A0 */
4374  volatile PCR1_t PCR1; /*protocol configuration register 1 *//*A2 */
4375  volatile PCR2_t PCR2; /*protocol configuration register 2 *//*A4 */
4376  volatile PCR3_t PCR3; /*protocol configuration register 3 *//*A6 */
4377  volatile PCR4_t PCR4; /*protocol configuration register 4 *//*A8 */
4378  volatile PCR5_t PCR5; /*protocol configuration register 5 *//*AA */
4379  volatile PCR6_t PCR6; /*protocol configuration register 6 *//*AC */
4380  volatile PCR7_t PCR7; /*protocol configuration register 7 *//*AE */
4381  volatile PCR8_t PCR8; /*protocol configuration register 8 *//*B0 */
4382  volatile PCR9_t PCR9; /*protocol configuration register 9 *//*B2 */
4383  volatile PCR10_t PCR10; /*protocol configuration register 10 *//*B4 */
4384  volatile PCR11_t PCR11; /*protocol configuration register 11 *//*B6 */
4385  volatile PCR12_t PCR12; /*protocol configuration register 12 *//*B8 */
4386  volatile PCR13_t PCR13; /*protocol configuration register 13 *//*BA */
4387  volatile PCR14_t PCR14; /*protocol configuration register 14 *//*BC */
4388  volatile PCR15_t PCR15; /*protocol configuration register 15 *//*BE */
4389  volatile PCR16_t PCR16; /*protocol configuration register 16 *//*C0 */
4390  volatile PCR17_t PCR17; /*protocol configuration register 17 *//*C2 */
4391  volatile PCR18_t PCR18; /*protocol configuration register 18 *//*C4 */
4392  volatile PCR19_t PCR19; /*protocol configuration register 19 *//*C6 */
4393  volatile PCR20_t PCR20; /*protocol configuration register 20 *//*C8 */
4394  volatile PCR21_t PCR21; /*protocol configuration register 21 *//*CA */
4395  volatile PCR22_t PCR22; /*protocol configuration register 22 *//*CC */
4396  volatile PCR23_t PCR23; /*protocol configuration register 23 *//*CE */
4397  volatile PCR24_t PCR24; /*protocol configuration register 24 *//*D0 */
4398  volatile PCR25_t PCR25; /*protocol configuration register 25 *//*D2 */
4399  volatile PCR26_t PCR26; /*protocol configuration register 26 *//*D4 */
4400  volatile PCR27_t PCR27; /*protocol configuration register 27 *//*D6 */
4401  volatile PCR28_t PCR28; /*protocol configuration register 28 *//*D8 */
4402  volatile PCR29_t PCR29; /*protocol configuration register 29 *//*DA */
4403  volatile PCR30_t PCR30; /*protocol configuration register 30 *//*DC */
4404  uint16_t reserved2[17];
4405  volatile MSG_BUFF_CCS_t MBCCS[128]; /* message buffer configuration, control & status registers 0-31 *//*100 */
4406  } FR_tag_t;
4407
4408  typedef union uF_HEADER /* frame header */
4409  {
4410  struct {
4411  uint16_t:5;
4412  uint16_t HDCRC:11; /* Header CRC */
4413  uint16_t:2;
4414  uint16_t CYCCNT:6; /* Cycle Count */
4415  uint16_t:1;
4416  uint16_t PLDLEN:7; /* Payload Length */
4417  uint16_t:1;
4418  uint16_t PPI:1; /* Payload Preamble Indicator */
4419  uint16_t NUF:1; /* Null Frame Indicator */
4420  uint16_t SYF:1; /* Sync Frame Indicator */
4421  uint16_t SUF:1; /* Startup Frame Indicator */
4422  uint16_t FID:11; /* Frame ID */
4423  } B;
4424  uint16_t WORDS[3];
4425  } F_HEADER_t;
4426  typedef union uS_STSTUS /* slot status */
4427  {
4428  struct {
4429  uint16_t VFB:1; /* Valid Frame on channel B */
4430  uint16_t SYB:1; /* Sync Frame Indicator channel B */
4431  uint16_t NFB:1; /* Null Frame Indicator channel B */
4432  uint16_t SUB:1; /* Startup Frame Indicator channel B */
4433  uint16_t SEB:1; /* Syntax Error on channel B */
4434  uint16_t CEB:1; /* Content Error on channel B */
4435  uint16_t BVB:1; /* Boundary Violation on channel B */
4436  uint16_t CH:1; /* Channel */
4437  uint16_t VFA:1; /* Valid Frame on channel A */
4438  uint16_t SYA:1; /* Sync Frame Indicator channel A */
4439  uint16_t NFA:1; /* Null Frame Indicator channel A */
4440  uint16_t SUA:1; /* Startup Frame Indicator channel A */
4441  uint16_t SEA:1; /* Syntax Error on channel A */
4442  uint16_t CEA:1; /* Content Error on channel A */
4443  uint16_t BVA:1; /* Boundary Violation on channel A */
4444  uint16_t:1;
4445  } RX;
4446  struct {
4447  uint16_t VFB:1; /* Valid Frame on channel B */
4448  uint16_t SYB:1; /* Sync Frame Indicator channel B */
4449  uint16_t NFB:1; /* Null Frame Indicator channel B */
4450  uint16_t SUB:1; /* Startup Frame Indicator channel B */
4451  uint16_t SEB:1; /* Syntax Error on channel B */
4452  uint16_t CEB:1; /* Content Error on channel B */
4453  uint16_t BVB:1; /* Boundary Violation on channel B */
4454  uint16_t TCB:1; /* Tx Conflict on channel B */
4455  uint16_t VFA:1; /* Valid Frame on channel A */
4456  uint16_t SYA:1; /* Sync Frame Indicator channel A */
4457  uint16_t NFA:1; /* Null Frame Indicator channel A */
4458  uint16_t SUA:1; /* Startup Frame Indicator channel A */
4459  uint16_t SEA:1; /* Syntax Error on channel A */
4460  uint16_t CEA:1; /* Content Error on channel A */
4461  uint16_t BVA:1; /* Boundary Violation on channel A */
4462  uint16_t TCA:1; /* Tx Conflict on channel A */
4463  } TX;
4464  uint16_t R;
4465  } S_STATUS_t;
4466
4467  typedef struct uMB_HEADER /* message buffer header */
4468  {
4469  F_HEADER_t FRAME_HEADER;
4470  uint16_t DATA_OFFSET;
4471  S_STATUS_t SLOT_STATUS;
4472  } MB_HEADER_t;
4473
4474 /* Define memories */
4475
4476 #define SRAM_START 0x40000000
4477 #define SRAM_SIZE 0x14000
4478 #define SRAM_END 0x40013FFF
4479
4480 #define FLASH_START 0x0
4481 #define FLASH_SIZE 0x200000
4482 #define FLASH_END 0x1FFFFF
4483
4484 /* Define instances of modules */
4485 #define PBRIDGE_A (*(volatile struct PBRIDGE_A_tag *) 0xC3F00000)
4486 #define FMPLL (*(volatile struct FMPLL_tag *) 0xC3F80000)
4487 #define EBI (*(volatile struct EBI_tag *) 0xC3F84000)
4488 #define FLASH (*(volatile struct FLASH_tag *) 0xC3F88000)
4489 #define SIU (*(volatile struct SIU_tag *) 0xC3F90000)
4490
4491 #define EMIOS (*(volatile struct EMIOS_tag *) 0xC3FA0000)
4492 #define ETPU (*(volatile struct ETPU_tag *) 0xC3FC0000)
4493 #define ETPU_DATA_RAM (*( uint32_t *) 0xC3FC8000)
4494 #define ETPU_DATA_RAM_EXT (*( uint32_t *) 0xC3FCC000)
4495 #define ETPU_DATA_RAM_END 0xC3FC89FC
4496 #define CODE_RAM (*( uint32_t *) 0xC3FD0000)
4497 #define ETPU_CODE_RAM (*( uint32_t *) 0xC3FD0000)
4498
4499 #define PBRIDGE_B (*(volatile struct PBRIDGE_B_tag *) 0xFFF00000)
4500 #define XBAR (*(volatile struct XBAR_tag *) 0xFFF04000)
4501 #define ECSM (*(volatile struct ECSM_tag *) 0xFFF40000)
4502 #define EDMA (*(volatile struct EDMA_tag *) 0xFFF44000)
4503 #define INTC (*(volatile struct INTC_tag *) 0xFFF48000)
4504
4505 #define EQADC (*(volatile struct EQADC_tag *) 0xFFF80000)
4506
4507 #define DSPI_A (*(volatile struct DSPI_tag *) 0xFFF90000)
4508 #define DSPI_B (*(volatile struct DSPI_tag *) 0xFFF94000)
4509 #define DSPI_C (*(volatile struct DSPI_tag *) 0xFFF98000)
4510 #define DSPI_D (*(volatile struct DSPI_tag *) 0xFFF9C000)
4511
4512 #define ESCI_A (*(volatile struct ESCI_tag *) 0xFFFB0000)
4513 #define ESCI_B (*(volatile struct ESCI_tag *) 0xFFFB4000)
4514
4515 #define CAN_A (*(volatile struct FLEXCAN2_tag *) 0xFFFC0000)
4516 #define CAN_B (*(volatile struct FLEXCAN2_tag *) 0xFFFC4000)
4517 #define CAN_C (*(volatile struct FLEXCAN2_tag *) 0xFFFC8000)
4518 #define CAN_D (*(volatile struct FLEXCAN2_tag *) 0xFFFCC000)
4519 #define CAN_E (*(volatile struct FLEXCAN2_tag *) 0xFFFD0000)
4520
4521 #define FEC (*(volatile struct FEC_tag *) 0xFFF4C000)
4522
4523 #define FR (*(volatile struct FR_tag *) 0xFFFE0000)
4524
4525 #ifdef __MWERKS__
4526 #pragma pop
4527 #endif
4528
4529 #ifdef __cplusplus
4530 }
4531 #endif
4532 #endif /* ASM */
4533 #endif /* ifdef _MPC5567_H */
4534 /*********************************************************************
4535  *
4536  * Copyright:
4537  * Freescale Semiconductor, INC. All Rights Reserved.
4538  * You are hereby granted a copyright license to use, modify, and
4539  * distribute the SOFTWARE so long as this entire notice is
4540  * retained without alteration in any modified and/or redistributed
4541  * versions, and that such modified versions are clearly identified
4542  * as such. No licenses are granted by implication, estoppel or
4543  * otherwise under any patents or trademarks of Freescale
4544  * Semiconductor, Inc. This software is provided on an "AS IS"
4545  * basis and without warranty.
4546  *
4547  * To the maximum extent permitted by applicable law, Freescale
4548  * Semiconductor DISCLAIMS ALL WARRANTIES WHETHER EXPRESS OR IMPLIED,
4549  * INCLUDING IMPLIED WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A
4550  * PARTICULAR PURPOSE AND ANY WARRANTY AGAINST INFRINGEMENT WITH
4551  * REGARD TO THE SOFTWARE (INCLUDING ANY MODIFIED VERSIONS THEREOF)
4552  * AND ANY ACCOMPANYING WRITTEN MATERIALS.
4553  *
4554  * To the maximum extent permitted by applicable law, IN NO EVENT
4555  * SHALL Freescale Semiconductor BE LIABLE FOR ANY DAMAGES WHATSOEVER
4556  * (INCLUDING WITHOUT LIMITATION, DAMAGES FOR LOSS OF BUSINESS PROFITS,
4557  * BUSINESS INTERRUPTION, LOSS OF BUSINESS INFORMATION, OR OTHER
4558  * PECUNIARY LOSS) ARISING OF THE USE OR INABILITY TO USE THE SOFTWARE.
4559  *
4560  * Freescale Semiconductor assumes no responsibility for the
4561  * maintenance and support of this software
4562  *
4563  ********************************************************************/
Definition: fsl-mpc551x.h:3093
Definition: fsl-mpc551x.h:3552
Definition: fsl-mpc551x.h:3182
Definition: fsl-mpc551x.h:3576
Definition: fsl-mpc551x.h:3295
Definition: fsl-mpc551x.h:3612
Definition: fsl-mpc551x.h:3570
Definition: fsl-mpc551x.h:3418
Definition: fsl-mpc551x.h:3213
Definition: fsl-mpc551x.h:3603
Definition: fsl-mpc555x.h:1982
Definition: fsl-mpc551x.h:3355
Definition: fsl-mpc551x.h:2884
Definition: fsl-mpc551x.h:2922
Definition: fsl-mpc551x.h:3609
Definition: fsl-mpc551x.h:899
Definition: fsl-mpc551x.h:3567
Definition: fsl-mpc551x.h:3134
Definition: fsl-mpc551x.h:3588
Definition: fsl-mpc551x.h:3069
Definition: fsl-mpc551x.h:3202
Definition: fsl-mpc551x.h:3457
Definition: fsl-mpc551x.h:3123
Definition: fsl-mpc564xL.h:16627
Definition: fsl-mpc555x.h:124
Definition: fsl-mpc551x.h:3261
Definition: fsl-mpc551x.h:3546
Definition: fsl-mpc556x.h:2982
Definition: fsl-mpc551x.h:3244
Definition: fsl-mpc551x.h:3597
Definition: fsl-mpc551x.h:3540
Definition: fsl-mpc551x.h:447
Definition: fsl-mpc551x.h:1484
Definition: fsl-mpc551x.h:3000
Definition: fsl-mpc551x.h:3401
Definition: fsl-mpc551x.h:3600
Definition: fsl-mpc551x.h:3473
Definition: fsl-mpc564xL.h:16586
Definition: fsl-mpc551x.h:3741
Definition: fsl-mpc551x.h:3287
Definition: fsl-mpc564xL.h:966
Definition: fsl-mpc551x.h:2960
Definition: fsl-mpc551x.h:3594
Definition: fsl-mpc551x.h:3425
Definition: fsl-mpc551x.h:2781
Definition: fsl-mpc551x.h:3362
Definition: fsl-mpc551x.h:2842
Definition: fsl-mpc551x.h:3606
Definition: fsl-mpc555x.h:2999
Definition: fsl-mpc551x.h:3313
Definition: fsl-mpc551x.h:3150
Definition: fsl-mpc551x.h:3171
Definition: fsl-mpc551x.h:3622
Definition: fsl-mpc551x.h:3615
Definition: fsl-mpc551x.h:3370
Definition: fsl-mpc551x.h:3582
Definition: fsl-mpc551x.h:3252
Definition: fsl-mpc564xL.h:16678
Definition: fsl-mpc551x.h:716
Definition: fsl-mpc551x.h:3236
Definition: fsl-mpc551x.h:3018
Definition: fsl-mpc551x.h:3555
Definition: fsl-mpc551x.h:3531
Definition: fsl-mpc551x.h:2987
Definition: fsl-mpc551x.h:3409
Definition: fsl-mpc556x.h:3496
Definition: fsl-mpc551x.h:2796
Definition: fsl-mpc555x.h:1136
Definition: fsl-mpc551x.h:2939
Definition: fsl-mpc564xL.h:16605
Definition: fsl-mpc551x.h:244
Definition: fsl-mpc551x.h:3465
Definition: fsl-mpc551x.h:3481
Definition: fsl-mpc551x.h:3339
Definition: fsl-mpc551x.h:2807
Definition: fsl-mpc551x.h:3564
Definition: fsl-mpc551x.h:3377
Definition: fsl-mpc564xL.h:16698
Definition: fsl-mpc551x.h:3193
Definition: fsl-mpc551x.h:3278
Definition: fsl-mpc551x.h:2221
Definition: fsl-mpc551x.h:3528
Definition: fsl-mpc551x.h:3434
Definition: fsl-mpc551x.h:3037
Definition: fsl-mpc551x.h:483
Definition: fsl-mpc555x.h:2179
Definition: fsl-mpc551x.h:3549
Definition: fsl-mpc551x.h:3112
Definition: fsl-mpc551x.h:3322
Definition: fsl-mpc551x.h:3304
Definition: fsl-mpc551x.h:3573
Definition: fsl-mpc551x.h:3347
Definition: fsl-mpc551x.h:3585
Definition: fsl-mpc551x.h:2817
Definition: fsl-mpc551x.h:3537
Definition: fsl-mpc551x.h:2863
Definition: fsl-mpc551x.h:2901
Definition: fsl-mpc551x.h:3543
Definition: fsl-mpc551x.h:3228
Definition: fsl-mpc551x.h:3591
Definition: fsl-mpc551x.h:2971
Definition: fsl-mpc551x.h:3723
Definition: fsl-mpc551x.h:3561
Definition: fsl-mpc551x.h:3579
Definition: fsl-mpc555x.h:236
Definition: fsl-mpc551x.h:1603
Definition: fsl-mpc551x.h:3269
Definition: fsl-mpc551x.h:2773
Definition: fsl-mpc551x.h:3441
Definition: fsl-mpc551x.h:2828
Definition: fsl-mpc551x.h:1027
Definition: fsl-mpc551x.h:3393
Definition: fsl-mpc551x.h:3331
Definition: fsl-mpc564xL.h:16541
Definition: fsl-mpc551x.h:479
Definition: fsl-mpc551x.h:3618
Definition: fsl-mpc551x.h:3085
Definition: fsl-mpc551x.h:3782
Definition: fsl-mpc551x.h:3450
Definition: fsl-mpc551x.h:3558
Definition: fsl-mpc551x.h:3059
Definition: fsl-mpc551x.h:3385
Definition: fsl-mpc551x.h:531
