RTEMS  5.1
fsl-mpc555x.h
1 /*
2  * Modifications of the original file provided by Freescale are:
3  *
4  * Copyright (c) 2011 embedded brains GmbH. All rights reserved.
5  *
6  * embedded brains GmbH
7  * Obere Lagerstr. 30
8  * 82178 Puchheim
9  * Germany
10  * <info@embedded-brains.de>
11  *
12  * Redistribution and use in source and binary forms, with or without
13  * modification, are permitted provided that the following conditions
14  * are met:
15  * 1. Redistributions of source code must retain the above copyright
16  * notice, this list of conditions and the following disclaimer.
17  * 2. Redistributions in binary form must reproduce the above copyright
18  * notice, this list of conditions and the following disclaimer in the
19  * documentation and/or other materials provided with the distribution.
20  *
21  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
22  * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
23  * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
24  * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
25  * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
26  * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
27  * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
28  * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
29  * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
30  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
31  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
32  */
33
34 /**************************************************************************/
35 /* FILE NAME: mpc5554.h COPYRIGHT (c) Freescale 2007 */
36 /* VERSION: 1.7 All Rights Reserved */
37 /* */
38 /* DESCRIPTION: */
39 /* This file contain all of the register and bit field definitions for */
40 /* MPC5554. */
41 /*========================================================================*/
42 /* UPDATE HISTORY */
43 /* REV AUTHOR DATE DESCRIPTION OF CHANGE */
44 /* --- ----------- --------- --------------------- */
45 /* 0.01 J. Loeliger 03/Mar/03 Initial version of file for MPC5554. */
46 /* Based on SoC version 0.7. */
47 /* 0.02 J. Loeliger 05/Mar/03 All registers and bit fields now */
48 /* defined. */
49 /* 0.03 J. Loeliger 05/May/03 Updated to current spec., fixed several*/
50 /* bugs and naming/formating issues. */
51 /* 0.04 J. Loeliger 16/May/03 More fixes and naming/formating issues.*/
52 /* 0.05 J. Loeliger 19/Aug/03 Updated for latest documentation. */
53 /* 0.06 J. Loeliger 03/Sep/03 Changed to include motint.h */
54 /* Updated many register names. */
55 /* 0.07 J. Loeliger 04/Nov/03 Changed to include typedefs.h and more */
56 /* register name updates. */
57 /* 0.08 J. Loeliger 25/Feb/04 Added MetroWerks #pragmas. */
58 /* Updated for user manual 1.0 */
59 /* 0.09 J. Loeliger 27/Feb/04 Updated eDMA tcd section and some more */
60 /* bit field names to match user's man. */
61 /* 0.10 J. Loeliger 01/Apr/04 Fixed register spacing in ADC and eTPU */
62 /* 0.11 J. Loeliger 16/Jun/04 Many fixes and updated to user's */
63 /* manual, also some testing done. */
64 /* 0.12 J. Loeliger 25/Jun/04 Fixed problems in edma and eTPU. */
65 /* 0.13 J. Loeliger 16/Jul/04 Fixed mistake in FlexCAN TIMER size and*/
66 /* changed eTPU memory defs to start with*/
67 /* ETPU_ */
68 /* 0.14 J. Loeliger 17/Nov/04 Added ETPU_CODE_RAM definition. */
69 /* All code moved to CVS repository. */
70 /* Updated copyright to Freescale. */
71 /* Added new SCMOFFDATAR register to eTPU*/
72 /* Fixed REDCR_A&B bit fields in eTPU. */
73 /* Added new DBR bit in CTAR for DSPI. */
74 /* 0.15 J. Loeliger 29/Nov/04 Added support for new eTPU util funcs. */
75 /* Added bit fields for FlexCAN buffer ID*/
76 /* 0.16 J. Loeliger 01/Dec/04 Corrected comments in release 0.16. */
77 /* 0.17 J. Loeliger 02/Dec/04 Moved eTPU variable definitions to a */
78 /* seperate new file. */
79 /* Removed SIU variable the GPIO */
80 /* routines do not need it. */
81 /* 1.0 G.Emerson 22/Feb/05 No real changes to this file. */
82 /* Joint generation with mpc5553.h */
83 /* 1.1 G. Emerson 6/Jun/05 Changes to SIU to allow for upward */
84 /* expansion of PCR/GPDI/GPDO */
85 /* Added #defines for memory sizes etc */
86 /* 1.2 G. Emerson 21/Sep/05 PBRIDGES fixes */
87 /* 1.3 G. Emerson 03/Jan/06 Pbridge MPCR/PACR/OPACR now generic */
88 /* XBAR MPR now generic */
89 /* ECSM has FSBMCR on all integrations */
90 /* 1.4 G. Emerson 24/Jan/06 Make Pbridges, XBAR, Flash BIU */
91 /* integration specific */
92 /* 1.5 S. Mathieson 28/Jul/06 Split out unused bit to support build */
93 /* process. No real change. */
94 /* 1.6 S. Mathieson 30/Aug/06 SPR: L1SCR0, updated bit name from DPP */
95 /* to DPB to align with documentation. */
96 /* 1.7 S. Mathieson 26/Feb/07 eDMA TCD format updated to include */
97 /* alternate configuration. INTC, */
98 /* correction to the number of PSR */
99 /* registers. */
100 /**************************************************************************/
101 /*>>>>NOTE! this file is auto-generated please do not edit it!<<<<*/
102
103 #ifndef _MPC5554_H_
104 #define _MPC5554_H_
105
106 #ifndef ASM
107
108 #include <stdint.h>
109
110 #include <mpc55xx/regs-edma.h>
111
112 #ifdef __cplusplus
113 extern "C" {
114 #endif
115
116 #ifdef __MWERKS__
117 #pragma push
118 #pragma ANSI_strict off
119 #endif
120
121 /****************************************************************************/
122 /* MODULE : PBRIDGE_A Peripheral Bridge */
123 /****************************************************************************/
124  struct PBRIDGE_A_tag {
125  union {
126  uint32_t R;
127  struct {
128  uint32_t MBW0:1;
129  uint32_t MTR0:1;
130  uint32_t MTW0:1;
131  uint32_t MPL0:1;
132  uint32_t MBW1:1;
133  uint32_t MTR1:1;
134  uint32_t MTW1:1;
135  uint32_t MPL1:1;
136  uint32_t MBW2:1;
137  uint32_t MTR2:1;
138  uint32_t MTW2:1;
139  uint32_t MPL2:1;
140  uint32_t MBW3:1;
141  uint32_t MTR3:1;
142  uint32_t MTW3:1;
143  uint32_t MPL3:1;
144
145  uint32_t:4;
146
147  uint32_t:4;
148
149  uint32_t:4;
150
151  uint32_t:4;
152  } B;
153  } MPCR; /* Master Privilege Control Register */
154
155  uint32_t pbridge_a_reserved2[7];
156
157  union {
158  uint32_t R;
159  struct {
160  uint32_t BW0:1;
161  uint32_t SP0:1;
162  uint32_t WP0:1;
163  uint32_t TP0:1;
164  uint32_t:28;
165  } B;
166  } PACR0;
167
168  uint32_t pbridge_a_reserved3[7];
169
170  union {
171  uint32_t R;
172  struct {
173  uint32_t BW0:1;
174  uint32_t SP0:1;
175  uint32_t WP0:1;
176  uint32_t TP0:1;
177  uint32_t BW1:1;
178  uint32_t SP1:1;
179  uint32_t WP1:1;
180  uint32_t TP1:1;
181  uint32_t BW2:1;
182  uint32_t SP2:1;
183  uint32_t WP2:1;
184  uint32_t TP2:1;
185  uint32_t:4;
186  uint32_t BW4:1;
187  uint32_t SP4:1;
188  uint32_t WP4:1;
189  uint32_t TP4:1;
190  uint32_t:12;
191  } B;
192  } OPACR0;
193
194  union {
195  uint32_t R;
196  struct {
197
198  uint32_t BW0:1; /* EMIOS */
199  uint32_t SP0:1;
200  uint32_t WP0:1;
201  uint32_t TP0:1;
202
203  uint32_t:28;
204  } B;
205  } OPACR1;
206
207  union {
208  uint32_t R;
209  struct {
210  uint32_t BW0:1;
211  uint32_t SP0:1;
212  uint32_t WP0:1;
213  uint32_t TP0:1;
214  uint32_t:4;
215  uint32_t BW2:1;
216  uint32_t SP2:1;
217  uint32_t WP2:1;
218  uint32_t TP2:1;
219  uint32_t BW3:1;
220  uint32_t SP3:1;
221  uint32_t WP3:1;
222  uint32_t TP3:1;
223  uint32_t BW4:1;
224  uint32_t SP4:1;
225  uint32_t WP4:1;
226  uint32_t TP4:1;
227  uint32_t:12;
228  } B;
229  } OPACR2;
230
231  };
232
233 /****************************************************************************/
234 /* MODULE : PBRIDGE_B Peripheral Bridge */
235 /****************************************************************************/
236  struct PBRIDGE_B_tag {
237  union {
238  uint32_t R;
239  struct {
240  uint32_t MBW0:1;
241  uint32_t MTR0:1;
242  uint32_t MTW0:1;
243  uint32_t MPL0:1;
244  uint32_t MBW1:1;
245  uint32_t MTR1:1;
246  uint32_t MTW1:1;
247  uint32_t MPL1:1;
248  uint32_t MBW2:1;
249  uint32_t MTR2:1;
250  uint32_t MTW2:1;
251  uint32_t MPL2:1;
252  uint32_t MBW3:1;
253  uint32_t MTR3:1;
254  uint32_t MTW3:1;
255  uint32_t MPL3:1;
256
257  uint32_t:4;
258
259  uint32_t:4;
260
261  uint32_t:4;
262
263  uint32_t:4;
264  } B;
265  } MPCR; /* Master Privilege Control Register */
266
267  uint32_t pbridge_b_reserved2[7];
268
269  union {
270  uint32_t R;
271  struct {
272  uint32_t BW0:1;
273  uint32_t SP0:1;
274  uint32_t WP0:1;
275  uint32_t TP0:1;
276  uint32_t BW1:1;
277  uint32_t SP1:1;
278  uint32_t WP1:1;
279  uint32_t TP1:1;
280  uint32_t:24;
281  } B;
282  } PACR0;
283
284  uint32_t pbridge_b_reserved3;
285
286  union {
287  uint32_t R;
288  struct {
289  uint32_t BW0:1;
290  uint32_t SP0:1;
291  uint32_t WP0:1;
292  uint32_t TP0:1;
293  uint32_t BW1:1;
294  uint32_t SP1:1;
295  uint32_t WP1:1;
296  uint32_t TP1:1;
297  uint32_t BW2:1;
298  uint32_t SP2:1;
299  uint32_t WP2:1;
300  uint32_t TP2:1;
301
302  uint32_t:4;
303
304  uint32_t:16;
305
306  } B;
307  } PACR2;
308
309  uint32_t pbridge_b_reserved4[5];
310
311  union {
312  uint32_t R;
313  struct {
314  uint32_t BW0:1;
315  uint32_t SP0:1;
316  uint32_t WP0:1;
317  uint32_t TP0:1;
318  uint32_t:12;
319
320  uint32_t BW4:1; /* DSPI_A */
321  uint32_t SP4:1;
322  uint32_t WP4:1;
323  uint32_t TP4:1;
324
325  uint32_t BW5:1; /* DSPI_B */
326  uint32_t SP5:1;
327  uint32_t WP5:1;
328  uint32_t TP5:1;
329
330  uint32_t BW6:1;
331  uint32_t SP6:1;
332  uint32_t WP6:1;
333  uint32_t TP6:1;
334  uint32_t BW7:1;
335  uint32_t SP7:1;
336  uint32_t WP7:1;
337  uint32_t TP7:1;
338  } B;
339  } OPACR0;
340
341  union {
342  uint32_t R;
343  struct {
344  uint32_t:16;
345  uint32_t BW4:1;
346  uint32_t SP4:1;
347  uint32_t WP4:1;
348  uint32_t TP4:1;
349
350  uint32_t BW5:1; /* ESCI_B */
351  uint32_t SP5:1;
352  uint32_t WP5:1;
353  uint32_t TP5:1;
354
355  uint32_t:8;
356  } B;
357  } OPACR1;
358
359  union {
360  uint32_t R;
361  struct {
362  uint32_t BW0:1;
363  uint32_t SP0:1;
364  uint32_t WP0:1;
365  uint32_t TP0:1;
366
367  uint32_t BW1:1; /* CAN_B */
368  uint32_t SP1:1;
369  uint32_t WP1:1;
370  uint32_t TP1:1;
371
372  uint32_t BW2:1;
373  uint32_t SP2:1;
374  uint32_t WP2:1;
375  uint32_t TP2:1;
376
377  uint32_t:4;
378
379  uint32_t:4;
380
381  uint32_t:12;
382  } B;
383  } OPACR2;
384
385  union {
386  uint32_t R;
387  struct {
388
389  uint32_t:4;
390
391  uint32_t:24;
392  uint32_t BW7:1;
393  uint32_t SP7:1;
394  uint32_t WP7:1;
395  uint32_t TP7:1;
396  } B;
397  } OPACR3;
398
399  };
400 /****************************************************************************/
401 /* MODULE : FMPLL */
402 /****************************************************************************/
403  struct FMPLL_tag {
405  uint32_t R;
406  struct {
407  uint32_t:1;
408  uint32_t PREDIV:3;
409  uint32_t MFD:5;
410  uint32_t:1;
411  uint32_t RFD:3;
412  uint32_t LOCEN:1;
413  uint32_t LOLRE:1;
414  uint32_t LOCRE:1;
415  uint32_t DISCLK:1;
416  uint32_t LOLIRQ:1;
417  uint32_t LOCIRQ:1;
418  uint32_t RATE:1;
419  uint32_t DEPTH:2;
420  uint32_t EXP:10;
421  } B;
422  } SYNCR;
423
424  union FMPLL_SYNSR_tag {
425  uint32_t R;
426  struct {
427  uint32_t:22;
428  uint32_t LOLF:1;
429  uint32_t LOC:1;
430  uint32_t MODE:1;
431  uint32_t PLLSEL:1;
432  uint32_t PLLREF:1;
433  uint32_t LOCKS:1;
434  uint32_t LOCK:1;
435  uint32_t LOCF:1;
436  uint32_t CALDONE:1;
437  uint32_t CALPASS:1;
438  } B;
439  } SYNSR;
440
441  };
442 /****************************************************************************/
443 /* MODULE : External Bus Interface (EBI) */
444 /****************************************************************************/
445  struct EBI_CS_tag {
446  union { /* Base Register Bank */
447  uint32_t R;
448  struct {
449  uint32_t BA:17;
450  uint32_t:3;
451  uint32_t PS:1;
452  uint32_t:4;
453  uint32_t BL:1;
454  uint32_t WEBS:1;
455  uint32_t TBDIP:1;
456  uint32_t:2;
457  uint32_t BI:1;
458  uint32_t V:1;
459  } B;
460  } BR;
461
462  union { /* Option Register Bank */
463  uint32_t R;
464  struct {
465  uint32_t AM:17;
466  uint32_t:7;
467  uint32_t SCY:4;
468  uint32_t:1;
469  uint32_t BSCY:2;
470  uint32_t:1;
471  } B;
472  } OR;
473  };
474
475  struct EBI_CAL_CS_tag {
476  uint32_t ebi_cal_cs_reserved [2];
477  };
478
479  struct EBI_tag {
480  union EBI_MCR_tag { /* Module Configuration Register */
481  uint32_t R;
482  struct {
483  uint32_t:5;
484  uint32_t SIZEEN:1;
485  uint32_t SIZE:2;
486  uint32_t:8;
487  uint32_t ACGE:1;
488  uint32_t EXTM:1;
489  uint32_t EARB:1;
490  uint32_t EARP:2;
491  uint32_t:4;
492  uint32_t MDIS:1;
493  uint32_t:5;
494  uint32_t DBM:1;
495  } B;
496  } MCR;
497
498  uint32_t EBI_reserved1;
499
500  union { /* Transfer Error Status Register */
501  uint32_t R;
502  struct {
503  uint32_t:30;
504  uint32_t TEAF:1;
505  uint32_t BMTF:1;
506  } B;
507  } TESR;
508
509  union { /* Bus Monitor Control Register */
510  uint32_t R;
511  struct {
512  uint32_t:16;
513  uint32_t BMT:8;
514  uint32_t BME:1;
515  uint32_t:7;
516  } B;
517  } BMCR;
518
519  struct EBI_CS_tag CS[4];
520
521  uint32_t EBI_reserved2[4];
522
523  struct EBI_CAL_CS_tag CAL_CS[4];
524  };
525 /****************************************************************************/
526 /* MODULE : FLASH */
527 /****************************************************************************/
528  struct FLASH_tag {
529  union { /* Module Configuration Register */
530  uint32_t R;
531  struct {
532  uint32_t:4;
533  uint32_t SIZE:4;
534  uint32_t:1;
535  uint32_t LAS:3;
536  uint32_t:3;
537  uint32_t MAS:1;
538  uint32_t EER:1;
539  uint32_t RWE:1;
540  uint32_t BBEPE:1;
541  uint32_t EPE:1;
542  uint32_t PEAS:1;
543  uint32_t DONE:1;
544  uint32_t PEG:1;
545
546  uint32_t:2;
547
548  uint32_t STOP:1;
549  uint32_t:1;
550  uint32_t PGM:1;
551  uint32_t PSUS:1;
552  uint32_t ERS:1;
553  uint32_t ESUS:1;
554  uint32_t EHV:1;
555  } B;
556  } MCR;
557
558  union LMLR_tag { /* LML Register */
559  uint32_t R;
560  struct {
561  uint32_t LME:1;
562  uint32_t:10;
563  uint32_t SLOCK:1;
564  uint32_t MLOCK:4;
565  uint32_t LLOCK:16;
566  } B;
567  } LMLR;
568
569  union HLR_tag { /* HL Register */
570  uint32_t R;
571  struct {
572  uint32_t HBE:1;
573  uint32_t:3;
574  uint32_t HBLOCK:28;
575  } B;
576  } HLR;
577
578  union SLMLR_tag { /* SLML Register */
579  uint32_t R;
580  struct {
581  uint32_t SLE:1;
582  uint32_t:10;
583  uint32_t SSLOCK:1;
584  uint32_t SMLOCK:4;
585  uint32_t SLLOCK:16;
586  } B;
587  } SLMLR;
588
589  union { /* LMS Register */
590  uint32_t R;
591  struct {
592  uint32_t:12;
593  uint32_t MSEL:4;
594  uint32_t LSEL:16;
595  } B;
596  } LMSR;
597
598  union {
599  uint32_t R;
600  struct {
601  uint32_t:4;
602  uint32_t HBSEL:28;
603  } B;
604  } HSR;
605
606  union {
607  uint32_t R;
608  struct {
609  uint32_t:10;
610  uint32_t ADDR:19;
611  uint32_t:3;
612  } B;
613  } AR;
614
615  union {
616  uint32_t R;
617  struct {
618
619  uint32_t:11;
620
621  uint32_t:1;
622
623  uint32_t M3PFE:1;
624  uint32_t M2PFE:1;
625  uint32_t M1PFE:1;
626  uint32_t M0PFE:1;
627  uint32_t APC:3;
628  uint32_t WWSC:2;
629  uint32_t RWSC:3;
630
631  uint32_t DPFEN:2;
632  uint32_t IPFEN:2;
633
634  uint32_t PFLIM:3;
635  uint32_t BFEN:1;
636  } B;
637  } BIUCR;
638
639  union {
640  uint32_t R;
641  struct {
642
643  uint32_t:22;
644
645  uint32_t:2;
646
647  uint32_t M3AP:2;
648  uint32_t M2AP:2;
649  uint32_t M1AP:2;
650  uint32_t M0AP:2;
651  } B;
652  } BIUAPR;
653  };
654 /****************************************************************************/
655 /* MODULE : SIU */
656 /****************************************************************************/
657  struct SIU_tag {
658  int32_t SIU_reserved0;
659
660  union { /* MCU ID Register */
661  uint32_t R;
662  struct {
663  uint32_t PARTNUM:16;
664  uint32_t MASKNUM:16;
665  } B;
666  } MIDR;
667  int32_t SIU_reserved00;
668
669  union { /* Reset Status Register */
670  uint32_t R;
671  struct {
672  uint32_t PORS:1;
673  uint32_t ERS:1;
674  uint32_t LLRS:1;
675  uint32_t LCRS:1;
676  uint32_t WDRS:1;
677  uint32_t CRS:1;
678  uint32_t:8;
679  uint32_t SSRS:1;
680  uint32_t SERF:1;
681  uint32_t WKPCFG:1;
682  uint32_t:12;
683  uint32_t BOOTCFG:2;
684  uint32_t RGF:1;
685  } B;
686  } RSR;
687
688  union { /* System Reset Control Register */
689  uint32_t R;
690  struct {
691  uint32_t SSR:1;
692  uint32_t SER:1;
693  uint32_t:14;
694  uint32_t CRE:1;
695  uint32_t:15;
696  } B;
697  } SRCR;
698
699  union SIU_EISR_tag { /* External Interrupt Status Register */
700  uint32_t R;
701  struct {
702  uint32_t:16;
703  uint32_t EIF15:1;
704  uint32_t EIF14:1;
705  uint32_t EIF13:1;
706  uint32_t EIF12:1;
707  uint32_t EIF11:1;
708  uint32_t EIF10:1;
709  uint32_t EIF9:1;
710  uint32_t EIF8:1;
711  uint32_t EIF7:1;
712  uint32_t EIF6:1;
713  uint32_t EIF5:1;
714  uint32_t EIF4:1;
715  uint32_t EIF3:1;
716  uint32_t EIF2:1;
717  uint32_t EIF1:1;
718  uint32_t EIF0:1;
719  } B;
720  } EISR;
721
722  union SIU_DIRER_tag { /* DMA/Interrupt Request Enable Register */
723  uint32_t R;
724  struct {
725  uint32_t:16;
726  uint32_t EIRE15:1;
727  uint32_t EIRE14:1;
728  uint32_t EIRE13:1;
729  uint32_t EIRE12:1;
730  uint32_t EIRE11:1;
731  uint32_t EIRE10:1;
732  uint32_t EIRE9:1;
733  uint32_t EIRE8:1;
734  uint32_t EIRE7:1;
735  uint32_t EIRE6:1;
736  uint32_t EIRE5:1;
737  uint32_t EIRE4:1;
738  uint32_t EIRE3:1;
739  uint32_t EIRE2:1;
740  uint32_t EIRE1:1;
741  uint32_t EIRE0:1;
742  } B;
743  } DIRER;
744
745  union SIU_DIRSR_tag { /* DMA/Interrupt Select Register */
746  uint32_t R;
747  struct {
748  uint32_t:28;
749  uint32_t DIRS3:1;
750  uint32_t DIRS2:1;
751  uint32_t DIRS1:1;
752  uint32_t DIRS0:1;
753  } B;
754  } DIRSR;
755
756  union { /* Overrun Status Register */
757  uint32_t R;
758  struct {
759  uint32_t:16;
760  uint32_t OVF15:1;
761  uint32_t OVF14:1;
762  uint32_t OVF13:1;
763  uint32_t OVF12:1;
764  uint32_t OVF11:1;
765  uint32_t OVF10:1;
766  uint32_t OVF9:1;
767  uint32_t OVF8:1;
768  uint32_t OVF7:1;
769  uint32_t OVF6:1;
770  uint32_t OVF5:1;
771  uint32_t OVF4:1;
772  uint32_t OVF3:1;
773  uint32_t OVF2:1;
774  uint32_t OVF1:1;
775  uint32_t OVF0:1;
776  } B;
777  } OSR;
778
779  union SIU_ORER_tag { /* Overrun Request Enable Register */
780  uint32_t R;
781  struct {
782  uint32_t:16;
783  uint32_t ORE15:1;
784  uint32_t ORE14:1;
785  uint32_t ORE13:1;
786  uint32_t ORE12:1;
787  uint32_t ORE11:1;
788  uint32_t ORE10:1;
789  uint32_t ORE9:1;
790  uint32_t ORE8:1;
791  uint32_t ORE7:1;
792  uint32_t ORE6:1;
793  uint32_t ORE5:1;
794  uint32_t ORE4:1;
795  uint32_t ORE3:1;
796  uint32_t ORE2:1;
797  uint32_t ORE1:1;
798  uint32_t ORE0:1;
799  } B;
800  } ORER;
801
802  union SIU_IREER_tag { /* External IRQ Rising-Edge Event Enable Register */
803  uint32_t R;
804  struct {
805  uint32_t:16;
806  uint32_t IREE15:1;
807  uint32_t IREE14:1;
808  uint32_t IREE13:1;
809  uint32_t IREE12:1;
810  uint32_t IREE11:1;
811  uint32_t IREE10:1;
812  uint32_t IREE9:1;
813  uint32_t IREE8:1;
814  uint32_t IREE7:1;
815  uint32_t IREE6:1;
816  uint32_t IREE5:1;
817  uint32_t IREE4:1;
818  uint32_t IREE3:1;
819  uint32_t IREE2:1;
820  uint32_t IREE1:1;
821  uint32_t IREE0:1;
822  } B;
823  } IREER;
824
825  union SIU_IFEER_tag { /* External IRQ Falling-Edge Event Enable Register */
826  uint32_t R;
827  struct {
828  uint32_t:16;
829  uint32_t IFEE15:1;
830  uint32_t IFEE14:1;
831  uint32_t IFEE13:1;
832  uint32_t IFEE12:1;
833  uint32_t IFEE11:1;
834  uint32_t IFEE10:1;
835  uint32_t IFEE9:1;
836  uint32_t IFEE8:1;
837  uint32_t IFEE7:1;
838  uint32_t IFEE6:1;
839  uint32_t IFEE5:1;
840  uint32_t IFEE4:1;
841  uint32_t IFEE3:1;
842  uint32_t IFEE2:1;
843  uint32_t IFEE1:1;
844  uint32_t IFEE0:1;
845  } B;
846  } IFEER;
847
848  union SIU_IDFR_tag { /* External IRQ Digital Filter Register */
849  uint32_t R;
850  struct {
851  uint32_t:28;
852  uint32_t DFL:4;
853  } B;
854  } IDFR;
855
856  int32_t SIU_reserved1[3];
857
858  union SIU_PCR_tag { /* Pad Configuration Registers */
859  uint16_t R;
860  struct {
861  uint16_t:3;
862  uint16_t PA:3;
863  uint16_t OBE:1;
864  uint16_t IBE:1;
865  uint16_t DSC:2;
866  uint16_t ODE:1;
867  uint16_t HYS:1;
868  uint16_t SRC:2;
869  uint16_t WPE:1;
870  uint16_t WPS:1;
871  } B;
872  } PCR[512];
873
874  int16_t SIU_reserved_0[224];
875
876  union { /* GPIO Pin Data Output Registers */
877  uint8_t R;
878  struct {
879  uint8_t:7;
880  uint8_t PDO:1;
881  } B;
882  } GPDO[256];
883
884  int32_t SIU_reserved_3[64];
885
886  union { /* GPIO Pin Data Input Registers */
887  uint8_t R;
888  struct {
889  uint8_t:7;
890  uint8_t PDI:1;
891  } B;
892  } GPDI[256];
893
894  union { /* IMUX Register */
895  uint32_t R;
896  struct {
897  uint32_t TSEL5:2;
898  uint32_t TSEL4:2;
899  uint32_t TSEL3:2;
900  uint32_t TSEL2:2;
901  uint32_t TSEL1:2;
902  uint32_t TSEL0:2;
903  uint32_t:20;
904  } B;
905  } ETISR;
906
907  union { /* IMUX Register */
908  uint32_t R;
909  struct {
910  uint32_t ESEL15:2;
911  uint32_t ESEL14:2;
912  uint32_t ESEL13:2;
913  uint32_t ESEL12:2;
914  uint32_t ESEL11:2;
915  uint32_t ESEL10:2;
916  uint32_t ESEL9:2;
917  uint32_t ESEL8:2;
918  uint32_t ESEL7:2;
919  uint32_t ESEL6:2;
920  uint32_t ESEL5:2;
921  uint32_t ESEL4:2;
922  uint32_t ESEL3:2;
923  uint32_t ESEL2:2;
924  uint32_t ESEL1:2;
925  uint32_t ESEL0:2;
926  } B;
927  } EIISR;
928
929  union { /* IMUX Register */
930  uint32_t R;
931  struct {
932  uint32_t SINSELA:2;
933  uint32_t SSSELA:2;
934  uint32_t SCKSELA:2;
935  uint32_t TRIGSELA:2;
936  uint32_t SINSELB:2;
937  uint32_t SSSELB:2;
938  uint32_t SCKSELB:2;
939  uint32_t TRIGSELB:2;
940  uint32_t SINSELC:2;
941  uint32_t SSSELC:2;
942  uint32_t SCKSELC:2;
943  uint32_t TRIGSELC:2;
944  uint32_t SINSELD:2;
945  uint32_t SSSELD:2;
946  uint32_t SCKSELD:2;
947  uint32_t TRIGSELD:2;
948  } B;
949  } DISR;
950
951  int32_t SIU_reserved2[29];
952
953  union { /* Chip Configuration Register Register */
954  uint32_t R;
955  struct {
956  uint32_t:14;
957  uint32_t MATCH:1;
958  uint32_t DISNEX:1;
959  uint32_t:16;
960  } B;
961  } CCR;
962
963  union { /* External Clock Configuration Register Register */
964  uint32_t R;
965  struct {
966  uint32_t:18;
967  uint32_t ENGDIV:6;
968  uint32_t:4;
969  uint32_t EBTS:1;
970  uint32_t:1;
971  uint32_t EBDF:2;
972  } B;
973  } ECCR;
974
975  union {
976  uint32_t R;
977  } CARH;
978
979  union {
980  uint32_t R;
981  } CARL;
982
983  union {
984  uint32_t R;
985  } CBRH;
986
987  union {
988  uint32_t R;
989  } CBRL;
990
991  };
992 /****************************************************************************/
993 /* MODULE : EMIOS */
994 /****************************************************************************/
995  struct EMIOS_tag {
996  union EMIOS_MCR_tag {
997  uint32_t R;
998  struct {
999  uint32_t:1;
1000  uint32_t MDIS:1;
1001  uint32_t FRZ:1;
1002  uint32_t GTBE:1;
1003  uint32_t ETB:1;
1004  uint32_t GPREN:1;
1005  uint32_t:6;
1006  uint32_t SRV:4;
1007  uint32_t GPRE:8;
1008  uint32_t:8;
1009  } B;
1010  } MCR; /* Module Configuration Register */
1011
1012  union {
1013  uint32_t R;
1014  struct {
1015  uint32_t:8;
1016  uint32_t F23:1;
1017  uint32_t F22:1;
1018  uint32_t F21:1;
1019  uint32_t F20:1;
1020  uint32_t F19:1;
1021  uint32_t F18:1;
1022  uint32_t F17:1;
1023  uint32_t F16:1;
1024  uint32_t F15:1;
1025  uint32_t F14:1;
1026  uint32_t F13:1;
1027  uint32_t F12:1;
1028  uint32_t F11:1;
1029  uint32_t F10:1;
1030  uint32_t F9:1;
1031  uint32_t F8:1;
1032  uint32_t F7:1;
1033  uint32_t F6:1;
1034  uint32_t F5:1;
1035  uint32_t F4:1;
1036  uint32_t F3:1;
1037  uint32_t F2:1;
1038  uint32_t F1:1;
1039  uint32_t F0:1;
1040  } B;
1041  } GFR; /* Global FLAG Register */
1042
1043  union {
1044  uint32_t R;
1045  struct {
1046  uint32_t:8;
1047  uint32_t OU23:1;
1048  uint32_t OU22:1;
1049  uint32_t OU21:1;
1050  uint32_t OU20:1;
1051  uint32_t OU19:1;
1052  uint32_t OU18:1;
1053  uint32_t OU17:1;
1054  uint32_t OU16:1;
1055  uint32_t OU15:1;
1056  uint32_t OU14:1;
1057  uint32_t OU13:1;
1058  uint32_t OU12:1;
1059  uint32_t OU11:1;
1060  uint32_t OU10:1;
1061  uint32_t OU9:1;
1062  uint32_t OU8:1;
1063  uint32_t OU7:1;
1064  uint32_t OU6:1;
1065  uint32_t OU5:1;
1066  uint32_t OU4:1;
1067  uint32_t OU3:1;
1068  uint32_t OU2:1;
1069  uint32_t OU1:1;
1070  uint32_t OU0:1;
1071  } B;
1072  } OUDR; /* Output Update Disable Register */
1073
1074  uint32_t emios_reserved[5];
1075
1076  struct EMIOS_CH_tag {
1077  union {
1078  uint32_t R; /* Channel A Data Register */
1079  } CADR;
1080
1081  union {
1082  uint32_t R; /* Channel B Data Register */
1083  } CBDR;
1084
1085  union {
1086  uint32_t R; /* Channel Counter Register */
1087  } CCNTR;
1088
1089  union EMIOS_CCR_tag {
1090  uint32_t R;
1091  struct {
1092  uint32_t FREN:1;
1093  uint32_t ODIS:1;
1094  uint32_t ODISSL:2;
1095  uint32_t UCPRE:2;
1096  uint32_t UCPREN:1;
1097  uint32_t DMA:1;
1098  uint32_t:1;
1099  uint32_t IF:4;
1100  uint32_t FCK:1;
1101  uint32_t FEN:1;
1102  uint32_t:3;
1103  uint32_t FORCMA:1;
1104  uint32_t FORCMB:1;
1105  uint32_t:1;
1106  uint32_t BSL:2;
1107  uint32_t EDSEL:1;
1108  uint32_t EDPOL:1;
1109  uint32_t MODE:7;
1110  } B;
1111  } CCR; /* Channel Control Register */
1112
1113  union EMIOS_CSR_tag {
1114  uint32_t R;
1115  struct {
1116  uint32_t OVR:1;
1117  uint32_t:15;
1118  uint32_t OVFL:1;
1119  uint32_t:12;
1120  uint32_t UCIN:1;
1121  uint32_t UCOUT:1;
1122  uint32_t FLAG:1;
1123  } B;
1124  } CSR; /* Channel Status Register */
1125  uint32_t emios_channel_reserved[3];
1126
1127  } CH[24];
1128
1129  };
1130 /****************************************************************************/
1131 /* MODULE :ETPU */
1132 /****************************************************************************/
1133
1134 /***************************Configuration Registers**************************/
1135
1136  struct ETPU_tag {
1137  union { /* MODULE CONFIGURATION REGISTER */
1138  uint32_t R;
1139  struct {
1140  uint32_t GEC:1; /* Global Exception Clear */
1141  uint32_t:3;
1142  uint32_t MGE1:1; /* Microcode Global Exception-ETPU_A */
1143
1144  uint32_t MGE2:1; /* Microcode Global Exception-ETPU_B */
1145
1146  uint32_t ILF1:1; /* Illegal Instruction Flag-ETPU_A */
1147
1148  uint32_t ILF2:1; /* Illegal Instruction Flag-ETPU_B */
1149
1150  uint32_t:3;
1151  uint32_t SCMSIZE:5; /* Shared Code Memory size */
1152  uint32_t:5;
1153  uint32_t SCMMISF:1; /* SCM MISC Flag */
1154  uint32_t SCMMISEN:1; /* SCM MISC Enable */
1155  uint32_t:2;
1156  uint32_t VIS:1; /* SCM Visability */
1157  uint32_t:5;
1158  uint32_t GTBE:1; /* Global Time Base Enable */
1159  } B;
1160  } MCR;
1161
1162  union { /* COHERENT DUAL-PARAMETER CONTROL */
1163  uint32_t R;
1164  struct {
1165  uint32_t STS:1; /* Start Status bit */
1166  uint32_t CTBASE:5; /* Channel Transfer Base */
1167  uint32_t PBASE:10; /* Parameter Buffer Base Address */
1168  uint32_t PWIDTH:1; /* Parameter Width */
1169  uint32_t PARAM0:7; /* Channel Parameter 0 */
1170  uint32_t WR:1;
1171  uint32_t PARAM1:7; /* Channel Parameter 1 */
1172  } B;
1173  } CDCR;
1174
1175  uint32_t etpu_reserved1;
1176
1177  union { /* MISC Compare Register */
1178  uint32_t R;
1179  } MISCCMPR;
1180
1181  union { /* SCM off-range Date Register */
1182  uint32_t R;
1183  } SCMOFFDATAR;
1184
1185  union { /* ETPU_A Configuration Register */
1186  uint32_t R;
1187  struct {
1188  uint32_t FEND:1; /* Force END */
1189  uint32_t MDIS:1; /* Low power Stop */
1190  uint32_t:1;
1191  uint32_t STF:1; /* Stop Flag */
1192  uint32_t:4;
1193  uint32_t HLTF:1; /* Halt Mode Flag */
1194  uint32_t:4;
1195  uint32_t FPSCK:3; /* Filter Prescaler Clock Control */
1196  uint32_t CDFC:2;
1197  uint32_t:9;
1198  uint32_t ETB:5; /* Entry Table Base */
1199  } B;
1200  } ECR_A;
1201
1202  union { /* ETPU_B Configuration Register */
1203  uint32_t R;
1204  struct {
1205  uint32_t FEND:1; /* Force END */
1206  uint32_t MDIS:1; /* Low power Stop */
1207  uint32_t:1;
1208  uint32_t STF:1; /* Stop Flag */
1209  uint32_t:4;
1210  uint32_t HLTF:1; /* Halt Mode Flag */
1211  uint32_t:4;
1212  uint32_t FPSCK:3; /* Filter Prescaler Clock Control */
1213  uint32_t CDFC:2;
1214  uint32_t:9;
1215  uint32_t ETB:5; /* Entry Table Base */
1216  } B;
1217  } ECR_B;
1218
1219  uint32_t etpu_reserved4;
1220
1221  union { /* ETPU_A Timebase Configuration Register */
1222  uint32_t R;
1223  struct {
1224  uint32_t TCR2CTL:3; /* TCR2 Clock/Gate Control */
1225  uint32_t TCRCF:2; /* TCRCLK Signal Filter Control */
1226  uint32_t:1;
1227  uint32_t AM:1; /* Angle Mode */
1228  uint32_t:3;
1229  uint32_t TCR2P:6; /* TCR2 Prescaler Control */
1230  uint32_t TCR1CTL:2; /* TCR1 Clock/Gate Control */
1231  uint32_t:6;
1232  uint32_t TCR1P:8; /* TCR1 Prescaler Control */
1233  } B;
1234  } TBCR_A;
1235
1236  union { /* ETPU_A TCR1 Visibility Register */
1237  uint32_t R;
1238  } TB1R_A;
1239
1240  union { /* ETPU_A TCR2 Visibility Register */
1241  uint32_t R;
1242  } TB2R_A;
1243
1244  union { /* ETPU_A STAC Configuration Register */
1245  uint32_t R;
1246  struct {
1247  uint32_t REN1:1; /* Resource Enable TCR1 */
1248  uint32_t RSC1:1; /* Resource Control TCR1 */
1249  uint32_t:2;
1250  uint32_t SERVER_ID1:4;
1251  uint32_t:4;
1252  uint32_t SRV1:4; /* Resource Server Slot */
1253  uint32_t REN2:1; /* Resource Enable TCR2 */
1254  uint32_t RSC2:1; /* Resource Control TCR2 */
1255  uint32_t:2;
1256  uint32_t SERVER_ID2:4;
1257  uint32_t:4;
1258  uint32_t SRV2:4; /* Resource Server Slot */
1259  } B;
1260  } REDCR_A;
1261
1262  uint32_t etpu_reserved5[4];
1263
1264  union { /* ETPU_B Timebase Configuration Register */
1265  uint32_t R;
1266  struct {
1267  uint32_t TCR2CTL:3; /* TCR2 Clock/Gate Control */
1268  uint32_t TCRCF:2; /* TCRCLK Signal Filter Control */
1269  uint32_t:1;
1270  uint32_t AM:1; /* Angle Mode */
1271  uint32_t:3;
1272  uint32_t TCR2P:6; /* TCR2 Prescaler Control */
1273  uint32_t TCR1CTL:2; /* TCR1 Clock/Gate Control */
1274  uint32_t:6;
1275  uint32_t TCR1P:8; /* TCR1 Prescaler Control */
1276  } B;
1277  } TBCR_B;
1278
1279  union { /* ETPU_B TCR1 Visibility Register */
1280  uint32_t R;
1281  } TB1R_B;
1282
1283  union { /* ETPU_B TCR2 Visibility Register */
1284  uint32_t R;
1285  } TB2R_B;
1286
1287  union { /* ETPU_B STAC Configuration Register */
1288  uint32_t R;
1289  struct {
1290  uint32_t REN1:1; /* Resource Enable TCR1 */
1291  uint32_t RSC1:1; /* Resource Control TCR1 */
1292  uint32_t:2;
1293  uint32_t SERVER_ID1:4;
1294  uint32_t:4;
1295  uint32_t SRV1:4; /* Resource Server Slot */
1296  uint32_t REN2:1; /* Resource Enable TCR2 */
1297  uint32_t RSC2:1; /* Resource Control TCR2 */
1298  uint32_t:2;
1299  uint32_t SERVER_ID2:4;
1300  uint32_t:4;
1301  uint32_t SRV2:4; /* Resource Server Slot */
1302  } B;
1303  } REDCR_B;
1304
1305  uint32_t etpu_reserved7[108];
1306
1307 /*****************************Status and Control Registers**************************/
1308
1309  union { /* ETPU_A Channel Interrut Status */
1310  uint32_t R;
1311  struct {
1312  uint32_t CIS31:1; /* Channel 31 Interrut Status */
1313  uint32_t CIS30:1; /* Channel 30 Interrut Status */
1314  uint32_t CIS29:1; /* Channel 29 Interrut Status */
1315  uint32_t CIS28:1; /* Channel 28 Interrut Status */
1316  uint32_t CIS27:1; /* Channel 27 Interrut Status */
1317  uint32_t CIS26:1; /* Channel 26 Interrut Status */
1318  uint32_t CIS25:1; /* Channel 25 Interrut Status */
1319  uint32_t CIS24:1; /* Channel 24 Interrut Status */
1320  uint32_t CIS23:1; /* Channel 23 Interrut Status */
1321  uint32_t CIS22:1; /* Channel 22 Interrut Status */
1322  uint32_t CIS21:1; /* Channel 21 Interrut Status */
1323  uint32_t CIS20:1; /* Channel 20 Interrut Status */
1324  uint32_t CIS19:1; /* Channel 19 Interrut Status */
1325  uint32_t CIS18:1; /* Channel 18 Interrut Status */
1326  uint32_t CIS17:1; /* Channel 17 Interrut Status */
1327  uint32_t CIS16:1; /* Channel 16 Interrut Status */
1328  uint32_t CIS15:1; /* Channel 15 Interrut Status */
1329  uint32_t CIS14:1; /* Channel 14 Interrut Status */
1330  uint32_t CIS13:1; /* Channel 13 Interrut Status */
1331  uint32_t CIS12:1; /* Channel 12 Interrut Status */
1332  uint32_t CIS11:1; /* Channel 11 Interrut Status */
1333  uint32_t CIS10:1; /* Channel 10 Interrut Status */
1334  uint32_t CIS9:1; /* Channel 9 Interrut Status */
1335  uint32_t CIS8:1; /* Channel 8 Interrut Status */
1336  uint32_t CIS7:1; /* Channel 7 Interrut Status */
1337  uint32_t CIS6:1; /* Channel 6 Interrut Status */
1338  uint32_t CIS5:1; /* Channel 5 Interrut Status */
1339  uint32_t CIS4:1; /* Channel 4 Interrut Status */
1340  uint32_t CIS3:1; /* Channel 3 Interrut Status */
1341  uint32_t CIS2:1; /* Channel 2 Interrut Status */
1342  uint32_t CIS1:1; /* Channel 1 Interrut Status */
1343  uint32_t CIS0:1; /* Channel 0 Interrut Status */
1344  } B;
1345  } CISR_A;
1346
1347  union { /* ETPU_B Channel Interruput Status */
1348  uint32_t R;
1349  struct {
1350  uint32_t CIS31:1; /* Channel 31 Interrut Status */
1351  uint32_t CIS30:1; /* Channel 30 Interrut Status */
1352  uint32_t CIS29:1; /* Channel 29 Interrut Status */
1353  uint32_t CIS28:1; /* Channel 28 Interrut Status */
1354  uint32_t CIS27:1; /* Channel 27 Interrut Status */
1355  uint32_t CIS26:1; /* Channel 26 Interrut Status */
1356  uint32_t CIS25:1; /* Channel 25 Interrut Status */
1357  uint32_t CIS24:1; /* Channel 24 Interrut Status */
1358  uint32_t CIS23:1; /* Channel 23 Interrut Status */
1359  uint32_t CIS22:1; /* Channel 22 Interrut Status */
1360  uint32_t CIS21:1; /* Channel 21 Interrut Status */
1361  uint32_t CIS20:1; /* Channel 20 Interrut Status */
1362  uint32_t CIS19:1; /* Channel 19 Interrut Status */
1363  uint32_t CIS18:1; /* Channel 18 Interrut Status */
1364  uint32_t CIS17:1; /* Channel 17 Interrut Status */
1365  uint32_t CIS16:1; /* Channel 16 Interrut Status */
1366  uint32_t CIS15:1; /* Channel 15 Interrut Status */
1367  uint32_t CIS14:1; /* Channel 14 Interrut Status */
1368  uint32_t CIS13:1; /* Channel 13 Interrut Status */
1369  uint32_t CIS12:1; /* Channel 12 Interrut Status */
1370  uint32_t CIS11:1; /* Channel 11 Interrut Status */
1371  uint32_t CIS10:1; /* Channel 10 Interrut Status */
1372  uint32_t CIS9:1; /* Channel 9 Interrut Status */
1373  uint32_t CIS8:1; /* Channel 8 Interrut Status */
1374  uint32_t CIS7:1; /* Channel 7 Interrut Status */
1375  uint32_t CIS6:1; /* Channel 6 Interrut Status */
1376  uint32_t CIS5:1; /* Channel 5 Interrut Status */
1377  uint32_t CIS4:1; /* Channel 4 Interrut Status */
1378  uint32_t CIS3:1; /* Channel 3 Interrut Status */
1379  uint32_t CIS2:1; /* Channel 2 Interrut Status */
1380  uint32_t CIS1:1; /* Channel 1 Interrupt Status */
1381  uint32_t CIS0:1; /* Channel 0 Interrupt Status */
1382  } B;
1383  } CISR_B;
1384
1385  uint32_t etpu_reserved9[2];
1386
1387  union { /* ETPU_A Data Transfer Request Status */
1388  uint32_t R;
1389  struct {
1390  uint32_t DTRS31:1; /* Channel 31 Data Transfer Request Status */
1391  uint32_t DTRS30:1; /* Channel 30 Data Transfer Request Status */
1392  uint32_t DTRS29:1; /* Channel 29 Data Transfer Request Status */
1393  uint32_t DTRS28:1; /* Channel 28 Data Transfer Request Status */
1394  uint32_t DTRS27:1; /* Channel 27 Data Transfer Request Status */
1395  uint32_t DTRS26:1; /* Channel 26 Data Transfer Request Status */
1396  uint32_t DTRS25:1; /* Channel 25 Data Transfer Request Status */
1397  uint32_t DTRS24:1; /* Channel 24 Data Transfer Request Status */
1398  uint32_t DTRS23:1; /* Channel 23 Data Transfer Request Status */
1399  uint32_t DTRS22:1; /* Channel 22 Data Transfer Request Status */
1400  uint32_t DTRS21:1; /* Channel 21 Data Transfer Request Status */
1401  uint32_t DTRS20:1; /* Channel 20 Data Transfer Request Status */
1402  uint32_t DTRS19:1; /* Channel 19 Data Transfer Request Status */
1403  uint32_t DTRS18:1; /* Channel 18 Data Transfer Request Status */
1404  uint32_t DTRS17:1; /* Channel 17 Data Transfer Request Status */
1405  uint32_t DTRS16:1; /* Channel 16 Data Transfer Request Status */
1406  uint32_t DTRS15:1; /* Channel 15 Data Transfer Request Status */
1407  uint32_t DTRS14:1; /* Channel 14 Data Transfer Request Status */
1408  uint32_t DTRS13:1; /* Channel 13 Data Transfer Request Status */
1409  uint32_t DTRS12:1; /* Channel 12 Data Transfer Request Status */
1410  uint32_t DTRS11:1; /* Channel 11 Data Transfer Request Status */
1411  uint32_t DTRS10:1; /* Channel 10 Data Transfer Request Status */
1412  uint32_t DTRS9:1; /* Channel 9 Data Transfer Request Status */
1413  uint32_t DTRS8:1; /* Channel 8 Data Transfer Request Status */
1414  uint32_t DTRS7:1; /* Channel 7 Data Transfer Request Status */
1415  uint32_t DTRS6:1; /* Channel 6 Data Transfer Request Status */
1416  uint32_t DTRS5:1; /* Channel 5 Data Transfer Request Status */
1417  uint32_t DTRS4:1; /* Channel 4 Data Transfer Request Status */
1418  uint32_t DTRS3:1; /* Channel 3 Data Transfer Request Status */
1419  uint32_t DTRS2:1; /* Channel 2 Data Transfer Request Status */
1420  uint32_t DTRS1:1; /* Channel 1 Data Transfer Request Status */
1421  uint32_t DTRS0:1; /* Channel 0 Data Transfer Request Status */
1422  } B;
1423  } CDTRSR_A;
1424
1425  union { /* ETPU_B Data Transfer Request Status */
1426  uint32_t R;
1427  struct {
1428  uint32_t DTRS31:1; /* Channel 31 Data Transfer Request Status */
1429  uint32_t DTRS30:1; /* Channel 30 Data Transfer Request Status */
1430  uint32_t DTRS29:1; /* Channel 29 Data Transfer Request Status */
1431  uint32_t DTRS28:1; /* Channel 28 Data Transfer Request Status */
1432  uint32_t DTRS27:1; /* Channel 27 Data Transfer Request Status */
1433  uint32_t DTRS26:1; /* Channel 26 Data Transfer Request Status */
1434  uint32_t DTRS25:1; /* Channel 25 Data Transfer Request Status */
1435  uint32_t DTRS24:1; /* Channel 24 Data Transfer Request Status */
1436  uint32_t DTRS23:1; /* Channel 23 Data Transfer Request Status */
1437  uint32_t DTRS22:1; /* Channel 22 Data Transfer Request Status */
1438  uint32_t DTRS21:1; /* Channel 21 Data Transfer Request Status */
1439  uint32_t DTRS20:1; /* Channel 20 Data Transfer Request Status */
1440  uint32_t DTRS19:1; /* Channel 19 Data Transfer Request Status */
1441  uint32_t DTRS18:1; /* Channel 18 Data Transfer Request Status */
1442  uint32_t DTRS17:1; /* Channel 17 Data Transfer Request Status */
1443  uint32_t DTRS16:1; /* Channel 16 Data Transfer Request Status */
1444  uint32_t DTRS15:1; /* Channel 15 Data Transfer Request Status */
1445  uint32_t DTRS14:1; /* Channel 14 Data Transfer Request Status */
1446  uint32_t DTRS13:1; /* Channel 13 Data Transfer Request Status */
1447  uint32_t DTRS12:1; /* Channel 12 Data Transfer Request Status */
1448  uint32_t DTRS11:1; /* Channel 11 Data Transfer Request Status */
1449  uint32_t DTRS10:1; /* Channel 10 Data Transfer Request Status */
1450  uint32_t DTRS9:1; /* Channel 9 Data Transfer Request Status */
1451  uint32_t DTRS8:1; /* Channel 8 Data Transfer Request Status */
1452  uint32_t DTRS7:1; /* Channel 7 Data Transfer Request Status */
1453  uint32_t DTRS6:1; /* Channel 6 Data Transfer Request Status */
1454  uint32_t DTRS5:1; /* Channel 5 Data Transfer Request Status */
1455  uint32_t DTRS4:1; /* Channel 4 Data Transfer Request Status */
1456  uint32_t DTRS3:1; /* Channel 3 Data Transfer Request Status */
1457  uint32_t DTRS2:1; /* Channel 2 Data Transfer Request Status */
1458  uint32_t DTRS1:1; /* Channel 1 Data Transfer Request Status */
1459  uint32_t DTRS0:1; /* Channel 0 Data Transfer Request Status */
1460  } B;
1461  } CDTRSR_B;
1462
1463  uint32_t etpu_reserved11[2];
1464
1465  union { /* ETPU_A Interruput Overflow Status */
1466  uint32_t R;
1467  struct {
1468  uint32_t CIOS31:1; /* Channel 31 Interruput Overflow Status */
1469  uint32_t CIOS30:1; /* Channel 30 Interruput Overflow Status */
1470  uint32_t CIOS29:1; /* Channel 29 Interruput Overflow Status */
1471  uint32_t CIOS28:1; /* Channel 28 Interruput Overflow Status */
1472  uint32_t CIOS27:1; /* Channel 27 Interruput Overflow Status */
1473  uint32_t CIOS26:1; /* Channel 26 Interruput Overflow Status */
1474  uint32_t CIOS25:1; /* Channel 25 Interruput Overflow Status */
1475  uint32_t CIOS24:1; /* Channel 24 Interruput Overflow Status */
1476  uint32_t CIOS23:1; /* Channel 23 Interruput Overflow Status */
1477  uint32_t CIOS22:1; /* Channel 22 Interruput Overflow Status */
1478  uint32_t CIOS21:1; /* Channel 21 Interruput Overflow Status */
1479  uint32_t CIOS20:1; /* Channel 20 Interruput Overflow Status */
1480  uint32_t CIOS19:1; /* Channel 19 Interruput Overflow Status */
1481  uint32_t CIOS18:1; /* Channel 18 Interruput Overflow Status */
1482  uint32_t CIOS17:1; /* Channel 17 Interruput Overflow Status */
1483  uint32_t CIOS16:1; /* Channel 16 Interruput Overflow Status */
1484  uint32_t CIOS15:1; /* Channel 15 Interruput Overflow Status */
1485  uint32_t CIOS14:1; /* Channel 14 Interruput Overflow Status */
1486  uint32_t CIOS13:1; /* Channel 13 Interruput Overflow Status */
1487  uint32_t CIOS12:1; /* Channel 12 Interruput Overflow Status */
1488  uint32_t CIOS11:1; /* Channel 11 Interruput Overflow Status */
1489  uint32_t CIOS10:1; /* Channel 10 Interruput Overflow Status */
1490  uint32_t CIOS9:1; /* Channel 9 Interruput Overflow Status */
1491  uint32_t CIOS8:1; /* Channel 8 Interruput Overflow Status */
1492  uint32_t CIOS7:1; /* Channel 7 Interruput Overflow Status */
1493  uint32_t CIOS6:1; /* Channel 6 Interruput Overflow Status */
1494  uint32_t CIOS5:1; /* Channel 5 Interruput Overflow Status */
1495  uint32_t CIOS4:1; /* Channel 4 Interruput Overflow Status */
1496  uint32_t CIOS3:1; /* Channel 3 Interruput Overflow Status */
1497  uint32_t CIOS2:1; /* Channel 2 Interruput Overflow Status */
1498  uint32_t CIOS1:1; /* Channel 1 Interruput Overflow Status */
1499  uint32_t CIOS0:1; /* Channel 0 Interruput Overflow Status */
1500  } B;
1501  } CIOSR_A;
1502
1503  union { /* ETPU_B Interruput Overflow Status */
1504  uint32_t R;
1505  struct {
1506  uint32_t CIOS31:1; /* Channel 31 Interruput Overflow Status */
1507  uint32_t CIOS30:1; /* Channel 30 Interruput Overflow Status */
1508  uint32_t CIOS29:1; /* Channel 29 Interruput Overflow Status */
1509  uint32_t CIOS28:1; /* Channel 28 Interruput Overflow Status */
1510  uint32_t CIOS27:1; /* Channel 27 Interruput Overflow Status */
1511  uint32_t CIOS26:1; /* Channel 26 Interruput Overflow Status */
1512  uint32_t CIOS25:1; /* Channel 25 Interruput Overflow Status */
1513  uint32_t CIOS24:1; /* Channel 24 Interruput Overflow Status */
1514  uint32_t CIOS23:1; /* Channel 23 Interruput Overflow Status */
1515  uint32_t CIOS22:1; /* Channel 22 Interruput Overflow Status */
1516  uint32_t CIOS21:1; /* Channel 21 Interruput Overflow Status */
1517  uint32_t CIOS20:1; /* Channel 20 Interruput Overflow Status */
1518  uint32_t CIOS19:1; /* Channel 19 Interruput Overflow Status */
1519  uint32_t CIOS18:1; /* Channel 18 Interruput Overflow Status */
1520  uint32_t CIOS17:1; /* Channel 17 Interruput Overflow Status */
1521  uint32_t CIOS16:1; /* Channel 16 Interruput Overflow Status */
1522  uint32_t CIOS15:1; /* Channel 15 Interruput Overflow Status */
1523  uint32_t CIOS14:1; /* Channel 14 Interruput Overflow Status */
1524  uint32_t CIOS13:1; /* Channel 13 Interruput Overflow Status */
1525  uint32_t CIOS12:1; /* Channel 12 Interruput Overflow Status */
1526  uint32_t CIOS11:1; /* Channel 11 Interruput Overflow Status */
1527  uint32_t CIOS10:1; /* Channel 10 Interruput Overflow Status */
1528  uint32_t CIOS9:1; /* Channel 9 Interruput Overflow Status */
1529  uint32_t CIOS8:1; /* Channel 8 Interruput Overflow Status */
1530  uint32_t CIOS7:1; /* Channel 7 Interruput Overflow Status */
1531  uint32_t CIOS6:1; /* Channel 6 Interruput Overflow Status */
1532  uint32_t CIOS5:1; /* Channel 5 Interruput Overflow Status */
1533  uint32_t CIOS4:1; /* Channel 4 Interruput Overflow Status */
1534  uint32_t CIOS3:1; /* Channel 3 Interruput Overflow Status */
1535  uint32_t CIOS2:1; /* Channel 2 Interruput Overflow Status */
1536  uint32_t CIOS1:1; /* Channel 1 Interruput Overflow Status */
1537  uint32_t CIOS0:1; /* Channel 0 Interruput Overflow Status */
1538  } B;
1539  } CIOSR_B;
1540
1541  uint32_t etpu_reserved13[2];
1542
1543  union { /* ETPU_A Data Transfer Overflow Status */
1544  uint32_t R;
1545  struct {
1546  uint32_t DTROS31:1; /* Channel 31 Data Transfer Overflow Status */
1547  uint32_t DTROS30:1; /* Channel 30 Data Transfer Overflow Status */
1548  uint32_t DTROS29:1; /* Channel 29 Data Transfer Overflow Status */
1549  uint32_t DTROS28:1; /* Channel 28 Data Transfer Overflow Status */
1550  uint32_t DTROS27:1; /* Channel 27 Data Transfer Overflow Status */
1551  uint32_t DTROS26:1; /* Channel 26 Data Transfer Overflow Status */
1552  uint32_t DTROS25:1; /* Channel 25 Data Transfer Overflow Status */
1553  uint32_t DTROS24:1; /* Channel 24 Data Transfer Overflow Status */
1554  uint32_t DTROS23:1; /* Channel 23 Data Transfer Overflow Status */
1555  uint32_t DTROS22:1; /* Channel 22 Data Transfer Overflow Status */
1556  uint32_t DTROS21:1; /* Channel 21 Data Transfer Overflow Status */
1557  uint32_t DTROS20:1; /* Channel 20 Data Transfer Overflow Status */
1558  uint32_t DTROS19:1; /* Channel 19 Data Transfer Overflow Status */
1559  uint32_t DTROS18:1; /* Channel 18 Data Transfer Overflow Status */
1560  uint32_t DTROS17:1; /* Channel 17 Data Transfer Overflow Status */
1561  uint32_t DTROS16:1; /* Channel 16 Data Transfer Overflow Status */
1562  uint32_t DTROS15:1; /* Channel 15 Data Transfer Overflow Status */
1563  uint32_t DTROS14:1; /* Channel 14 Data Transfer Overflow Status */
1564  uint32_t DTROS13:1; /* Channel 13 Data Transfer Overflow Status */
1565  uint32_t DTROS12:1; /* Channel 12 Data Transfer Overflow Status */
1566  uint32_t DTROS11:1; /* Channel 11 Data Transfer Overflow Status */
1567  uint32_t DTROS10:1; /* Channel 10 Data Transfer Overflow Status */
1568  uint32_t DTROS9:1; /* Channel 9 Data Transfer Overflow Status */
1569  uint32_t DTROS8:1; /* Channel 8 Data Transfer Overflow Status */
1570  uint32_t DTROS7:1; /* Channel 7 Data Transfer Overflow Status */
1571  uint32_t DTROS6:1; /* Channel 6 Data Transfer Overflow Status */
1572  uint32_t DTROS5:1; /* Channel 5 Data Transfer Overflow Status */
1573  uint32_t DTROS4:1; /* Channel 4 Data Transfer Overflow Status */
1574  uint32_t DTROS3:1; /* Channel 3 Data Transfer Overflow Status */
1575  uint32_t DTROS2:1; /* Channel 2 Data Transfer Overflow Status */
1576  uint32_t DTROS1:1; /* Channel 1 Data Transfer Overflow Status */
1577  uint32_t DTROS0:1; /* Channel 0 Data Transfer Overflow Status */
1578  } B;
1579  } CDTROSR_A;
1580
1581  union { /* ETPU_B Data Transfer Overflow Status */
1582  uint32_t R;
1583  struct {
1584  uint32_t DTROS31:1; /* Channel 31 Data Transfer Overflow Status */
1585  uint32_t DTROS30:1; /* Channel 30 Data Transfer Overflow Status */
1586  uint32_t DTROS29:1; /* Channel 29 Data Transfer Overflow Status */
1587  uint32_t DTROS28:1; /* Channel 28 Data Transfer Overflow Status */
1588  uint32_t DTROS27:1; /* Channel 27 Data Transfer Overflow Status */
1589  uint32_t DTROS26:1; /* Channel 26 Data Transfer Overflow Status */
1590  uint32_t DTROS25:1; /* Channel 25 Data Transfer Overflow Status */
1591  uint32_t DTROS24:1; /* Channel 24 Data Transfer Overflow Status */
1592  uint32_t DTROS23:1; /* Channel 23 Data Transfer Overflow Status */
1593  uint32_t DTROS22:1; /* Channel 22 Data Transfer Overflow Status */
1594  uint32_t DTROS21:1; /* Channel 21 Data Transfer Overflow Status */
1595  uint32_t DTROS20:1; /* Channel 20 Data Transfer Overflow Status */
1596  uint32_t DTROS19:1; /* Channel 19 Data Transfer Overflow Status */
1597  uint32_t DTROS18:1; /* Channel 18 Data Transfer Overflow Status */
1598  uint32_t DTROS17:1; /* Channel 17 Data Transfer Overflow Status */
1599  uint32_t DTROS16:1; /* Channel 16 Data Transfer Overflow Status */
1600  uint32_t DTROS15:1; /* Channel 15 Data Transfer Overflow Status */
1601  uint32_t DTROS14:1; /* Channel 14 Data Transfer Overflow Status */
1602  uint32_t DTROS13:1; /* Channel 13 Data Transfer Overflow Status */
1603  uint32_t DTROS12:1; /* Channel 12 Data Transfer Overflow Status */
1604  uint32_t DTROS11:1; /* Channel 11 Data Transfer Overflow Status */
1605  uint32_t DTROS10:1; /* Channel 10 Data Transfer Overflow Status */
1606  uint32_t DTROS9:1; /* Channel 9 Data Transfer Overflow Status */
1607  uint32_t DTROS8:1; /* Channel 8 Data Transfer Overflow Status */
1608  uint32_t DTROS7:1; /* Channel 7 Data Transfer Overflow Status */
1609  uint32_t DTROS6:1; /* Channel 6 Data Transfer Overflow Status */
1610  uint32_t DTROS5:1; /* Channel 5 Data Transfer Overflow Status */
1611  uint32_t DTROS4:1; /* Channel 4 Data Transfer Overflow Status */
1612  uint32_t DTROS3:1; /* Channel 3 Data Transfer Overflow Status */
1613  uint32_t DTROS2:1; /* Channel 2 Data Transfer Overflow Status */
1614  uint32_t DTROS1:1; /* Channel 1 Data Transfer Overflow Status */
1615  uint32_t DTROS0:1; /* Channel 0 Data Transfer Overflow Status */
1616  } B;
1617  } CDTROSR_B;
1618
1619  uint32_t etpu_reserved15[2];
1620
1621  union { /* ETPU_A Channel Interruput Enable */
1622  uint32_t R;
1623  struct {
1624  uint32_t CIE31:1; /* Channel 31 Interruput Enable */
1625  uint32_t CIE30:1; /* Channel 30 Interruput Enable */
1626  uint32_t CIE29:1; /* Channel 29 Interruput Enable */
1627  uint32_t CIE28:1; /* Channel 28 Interruput Enable */
1628  uint32_t CIE27:1; /* Channel 27 Interruput Enable */
1629  uint32_t CIE26:1; /* Channel 26 Interruput Enable */
1630  uint32_t CIE25:1; /* Channel 25 Interruput Enable */
1631  uint32_t CIE24:1; /* Channel 24 Interruput Enable */
1632  uint32_t CIE23:1; /* Channel 23 Interruput Enable */
1633  uint32_t CIE22:1; /* Channel 22 Interruput Enable */
1634  uint32_t CIE21:1; /* Channel 21 Interruput Enable */
1635  uint32_t CIE20:1; /* Channel 20 Interruput Enable */
1636  uint32_t CIE19:1; /* Channel 19 Interruput Enable */
1637  uint32_t CIE18:1; /* Channel 18 Interruput Enable */
1638  uint32_t CIE17:1; /* Channel 17 Interruput Enable */
1639  uint32_t CIE16:1; /* Channel 16 Interruput Enable */
1640  uint32_t CIE15:1; /* Channel 15 Interruput Enable */
1641  uint32_t CIE14:1; /* Channel 14 Interruput Enable */
1642  uint32_t CIE13:1; /* Channel 13 Interruput Enable */
1643  uint32_t CIE12:1; /* Channel 12 Interruput Enable */
1644  uint32_t CIE11:1; /* Channel 11 Interruput Enable */
1645  uint32_t CIE10:1; /* Channel 10 Interruput Enable */
1646  uint32_t CIE9:1; /* Channel 9 Interruput Enable */
1647  uint32_t CIE8:1; /* Channel 8 Interruput Enable */
1648  uint32_t CIE7:1; /* Channel 7 Interruput Enable */
1649  uint32_t CIE6:1; /* Channel 6 Interruput Enable */
1650  uint32_t CIE5:1; /* Channel 5 Interruput Enable */
1651  uint32_t CIE4:1; /* Channel 4 Interruput Enable */
1652  uint32_t CIE3:1; /* Channel 3 Interruput Enable */
1653  uint32_t CIE2:1; /* Channel 2 Interruput Enable */
1654  uint32_t CIE1:1; /* Channel 1 Interruput Enable */
1655  uint32_t CIE0:1; /* Channel 0 Interruput Enable */
1656  } B;
1657  } CIER_A;
1658
1659  union { /* ETPU_B Channel Interruput Enable */
1660  uint32_t R;
1661  struct {
1662  uint32_t CIE31:1; /* Channel 31 Interruput Enable */
1663  uint32_t CIE30:1; /* Channel 30 Interruput Enable */
1664  uint32_t CIE29:1; /* Channel 29 Interruput Enable */
1665  uint32_t CIE28:1; /* Channel 28 Interruput Enable */
1666  uint32_t CIE27:1; /* Channel 27 Interruput Enable */
1667  uint32_t CIE26:1; /* Channel 26 Interruput Enable */
1668  uint32_t CIE25:1; /* Channel 25 Interruput Enable */
1669  uint32_t CIE24:1; /* Channel 24 Interruput Enable */
1670  uint32_t CIE23:1; /* Channel 23 Interruput Enable */
1671  uint32_t CIE22:1; /* Channel 22 Interruput Enable */
1672  uint32_t CIE21:1; /* Channel 21 Interruput Enable */
1673  uint32_t CIE20:1; /* Channel 20 Interruput Enable */
1674  uint32_t CIE19:1; /* Channel 19 Interruput Enable */
1675  uint32_t CIE18:1; /* Channel 18 Interruput Enable */
1676  uint32_t CIE17:1; /* Channel 17 Interruput Enable */
1677  uint32_t CIE16:1; /* Channel 16 Interruput Enable */
1678  uint32_t CIE15:1; /* Channel 15 Interruput Enable */
1679  uint32_t CIE14:1; /* Channel 14 Interruput Enable */
1680  uint32_t CIE13:1; /* Channel 13 Interruput Enable */
1681  uint32_t CIE12:1; /* Channel 12 Interruput Enable */
1682  uint32_t CIE11:1; /* Channel 11 Interruput Enable */
1683  uint32_t CIE10:1; /* Channel 10 Interruput Enable */
1684  uint32_t CIE9:1; /* Channel 9 Interruput Enable */
1685  uint32_t CIE8:1; /* Channel 8 Interruput Enable */
1686  uint32_t CIE7:1; /* Channel 7 Interruput Enable */
1687  uint32_t CIE6:1; /* Channel 6 Interruput Enable */
1688  uint32_t CIE5:1; /* Channel 5 Interruput Enable */
1689  uint32_t CIE4:1; /* Channel 4 Interruput Enable */
1690  uint32_t CIE3:1; /* Channel 3 Interruput Enable */
1691  uint32_t CIE2:1; /* Channel 2 Interruput Enable */
1692  uint32_t CIE1:1; /* Channel 1 Interruput Enable */
1693  uint32_t CIE0:1; /* Channel 0 Interruput Enable */
1694  } B;
1695  } CIER_B;
1696
1697  uint32_t etpu_reserved17[2];
1698
1699  union { /* ETPU_A Channel Data Transfer Request Enable */
1700  uint32_t R;
1701  struct {
1702  uint32_t DTRE31:1; /* Channel 31 Data Transfer Request Enable */
1703  uint32_t DTRE30:1; /* Channel 30 Data Transfer Request Enable */
1704  uint32_t DTRE29:1; /* Channel 29 Data Transfer Request Enable */
1705  uint32_t DTRE28:1; /* Channel 28 Data Transfer Request Enable */
1706  uint32_t DTRE27:1; /* Channel 27 Data Transfer Request Enable */
1707  uint32_t DTRE26:1; /* Channel 26 Data Transfer Request Enable */
1708  uint32_t DTRE25:1; /* Channel 25 Data Transfer Request Enable */
1709  uint32_t DTRE24:1; /* Channel 24 Data Transfer Request Enable */
1710  uint32_t DTRE23:1; /* Channel 23 Data Transfer Request Enable */
1711  uint32_t DTRE22:1; /* Channel 22 Data Transfer Request Enable */
1712  uint32_t DTRE21:1; /* Channel 21 Data Transfer Request Enable */
1713  uint32_t DTRE20:1; /* Channel 20 Data Transfer Request Enable */
1714  uint32_t DTRE19:1; /* Channel 19 Data Transfer Request Enable */
1715  uint32_t DTRE18:1; /* Channel 18 Data Transfer Request Enable */
1716  uint32_t DTRE17:1; /* Channel 17 Data Transfer Request Enable */
1717  uint32_t DTRE16:1; /* Channel 16 Data Transfer Request Enable */
1718  uint32_t DTRE15:1; /* Channel 15 Data Transfer Request Enable */
1719  uint32_t DTRE14:1; /* Channel 14 Data Transfer Request Enable */
1720  uint32_t DTRE13:1; /* Channel 13 Data Transfer Request Enable */
1721  uint32_t DTRE12:1; /* Channel 12 Data Transfer Request Enable */
1722  uint32_t DTRE11:1; /* Channel 11 Data Transfer Request Enable */
1723  uint32_t DTRE10:1; /* Channel 10 Data Transfer Request Enable */
1724  uint32_t DTRE9:1; /* Channel 9 Data Transfer Request Enable */
1725  uint32_t DTRE8:1; /* Channel 8 Data Transfer Request Enable */
1726  uint32_t DTRE7:1; /* Channel 7 Data Transfer Request Enable */
1727  uint32_t DTRE6:1; /* Channel 6 Data Transfer Request Enable */
1728  uint32_t DTRE5:1; /* Channel 5 Data Transfer Request Enable */
1729  uint32_t DTRE4:1; /* Channel 4 Data Transfer Request Enable */
1730  uint32_t DTRE3:1; /* Channel 3 Data Transfer Request Enable */
1731  uint32_t DTRE2:1; /* Channel 2 Data Transfer Request Enable */
1732  uint32_t DTRE1:1; /* Channel 1 Data Transfer Request Enable */
1733  uint32_t DTRE0:1; /* Channel 0 Data Transfer Request Enable */
1734  } B;
1735  } CDTRER_A;
1736
1737  union { /* ETPU_B Channel Data Transfer Request Enable */
1738  uint32_t R;
1739  struct {
1740  uint32_t DTRE31:1; /* Channel 31 Data Transfer Request Enable */
1741  uint32_t DTRE30:1; /* Channel 30 Data Transfer Request Enable */
1742  uint32_t DTRE29:1; /* Channel 29 Data Transfer Request Enable */
1743  uint32_t DTRE28:1; /* Channel 28 Data Transfer Request Enable */
1744  uint32_t DTRE27:1; /* Channel 27 Data Transfer Request Enable */
1745  uint32_t DTRE26:1; /* Channel 26 Data Transfer Request Enable */
1746  uint32_t DTRE25:1; /* Channel 25 Data Transfer Request Enable */
1747  uint32_t DTRE24:1; /* Channel 24 Data Transfer Request Enable */
1748  uint32_t DTRE23:1; /* Channel 23 Data Transfer Request Enable */
1749  uint32_t DTRE22:1; /* Channel 22 Data Transfer Request Enable */
1750  uint32_t DTRE21:1; /* Channel 21 Data Transfer Request Enable */
1751  uint32_t DTRE20:1; /* Channel 20 Data Transfer Request Enable */
1752  uint32_t DTRE19:1; /* Channel 19 Data Transfer Request Enable */
1753  uint32_t DTRE18:1; /* Channel 18 Data Transfer Request Enable */
1754  uint32_t DTRE17:1; /* Channel 17 Data Transfer Request Enable */
1755  uint32_t DTRE16:1; /* Channel 16 Data Transfer Request Enable */
1756  uint32_t DTRE15:1; /* Channel 15 Data Transfer Request Enable */
1757  uint32_t DTRE14:1; /* Channel 14 Data Transfer Request Enable */
1758  uint32_t DTRE13:1; /* Channel 13 Data Transfer Request Enable */
1759  uint32_t DTRE12:1; /* Channel 12 Data Transfer Request Enable */
1760  uint32_t DTRE11:1; /* Channel 11 Data Transfer Request Enable */
1761  uint32_t DTRE10:1; /* Channel 10 Data Transfer Request Enable */
1762  uint32_t DTRE9:1; /* Channel 9 Data Transfer Request Enable */
1763  uint32_t DTRE8:1; /* Channel 8 Data Transfer Request Enable */
1764  uint32_t DTRE7:1; /* Channel 7 Data Transfer Request Enable */
1765  uint32_t DTRE6:1; /* Channel 6 Data Transfer Request Enable */
1766  uint32_t DTRE5:1; /* Channel 5 Data Transfer Request Enable */
1767  uint32_t DTRE4:1; /* Channel 4 Data Transfer Request Enable */
1768  uint32_t DTRE3:1; /* Channel 3 Data Transfer Request Enable */
1769  uint32_t DTRE2:1; /* Channel 2 Data Transfer Request Enable */
1770  uint32_t DTRE1:1; /* Channel 1 Data Transfer Request Enable */
1771  uint32_t DTRE0:1; /* Channel 0 Data Transfer Request Enable */
1772  } B;
1773  } CDTRER_B;
1774
1775  uint32_t etpu_reserved20[10];
1776  union { /* ETPU_A Channel Pending Service Status */
1777  uint32_t R;
1778  struct {
1779  uint32_t SR31:1; /* Channel 31 Pending Service Status */
1780  uint32_t SR30:1; /* Channel 30 Pending Service Status */
1781  uint32_t SR29:1; /* Channel 29 Pending Service Status */
1782  uint32_t SR28:1; /* Channel 28 Pending Service Status */
1783  uint32_t SR27:1; /* Channel 27 Pending Service Status */
1784  uint32_t SR26:1; /* Channel 26 Pending Service Status */
1785  uint32_t SR25:1; /* Channel 25 Pending Service Status */
1786  uint32_t SR24:1; /* Channel 24 Pending Service Status */
1787  uint32_t SR23:1; /* Channel 23 Pending Service Status */
1788  uint32_t SR22:1; /* Channel 22 Pending Service Status */
1789  uint32_t SR21:1; /* Channel 21 Pending Service Status */
1790  uint32_t SR20:1; /* Channel 20 Pending Service Status */
1791  uint32_t SR19:1; /* Channel 19 Pending Service Status */
1792  uint32_t SR18:1; /* Channel 18 Pending Service Status */
1793  uint32_t SR17:1; /* Channel 17 Pending Service Status */
1794  uint32_t SR16:1; /* Channel 16 Pending Service Status */
1795  uint32_t SR15:1; /* Channel 15 Pending Service Status */
1796  uint32_t SR14:1; /* Channel 14 Pending Service Status */
1797  uint32_t SR13:1; /* Channel 13 Pending Service Status */
1798  uint32_t SR12:1; /* Channel 12 Pending Service Status */
1799  uint32_t SR11:1; /* Channel 11 Pending Service Status */
1800  uint32_t SR10:1; /* Channel 10 Pending Service Status */
1801  uint32_t SR9:1; /* Channel 9 Pending Service Status */
1802  uint32_t SR8:1; /* Channel 8 Pending Service Status */
1803  uint32_t SR7:1; /* Channel 7 Pending Service Status */
1804  uint32_t SR6:1; /* Channel 6 Pending Service Status */
1805  uint32_t SR5:1; /* Channel 5 Pending Service Status */
1806  uint32_t SR4:1; /* Channel 4 Pending Service Status */
1807  uint32_t SR3:1; /* Channel 3 Pending Service Status */
1808  uint32_t SR2:1; /* Channel 2 Pending Service Status */
1809  uint32_t SR1:1; /* Channel 1 Pending Service Status */
1810  uint32_t SR0:1; /* Channel 0 Pending Service Status */
1811  } B;
1812  } CPSSR_A;
1813
1814  union { /* ETPU_B Channel Pending Service Status */
1815  uint32_t R;
1816  struct {
1817  uint32_t SR31:1; /* Channel 31 Pending Service Status */
1818  uint32_t SR30:1; /* Channel 30 Pending Service Status */
1819  uint32_t SR29:1; /* Channel 29 Pending Service Status */
1820  uint32_t SR28:1; /* Channel 28 Pending Service Status */
1821  uint32_t SR27:1; /* Channel 27 Pending Service Status */
1822  uint32_t SR26:1; /* Channel 26 Pending Service Status */
1823  uint32_t SR25:1; /* Channel 25 Pending Service Status */
1824  uint32_t SR24:1; /* Channel 24 Pending Service Status */
1825  uint32_t SR23:1; /* Channel 23 Pending Service Status */
1826  uint32_t SR22:1; /* Channel 22 Pending Service Status */
1827  uint32_t SR21:1; /* Channel 21 Pending Service Status */
1828  uint32_t SR20:1; /* Channel 20 Pending Service Status */
1829  uint32_t SR19:1; /* Channel 19 Pending Service Status */
1830  uint32_t SR18:1; /* Channel 18 Pending Service Status */
1831  uint32_t SR17:1; /* Channel 17 Pending Service Status */
1832  uint32_t SR16:1; /* Channel 16 Pending Service Status */
1833  uint32_t SR15:1; /* Channel 15 Pending Service Status */
1834  uint32_t SR14:1; /* Channel 14 Pending Service Status */
1835  uint32_t SR13:1; /* Channel 13 Pending Service Status */
1836  uint32_t SR12:1; /* Channel 12 Pending Service Status */
1837  uint32_t SR11:1; /* Channel 11 Pending Service Status */
1838  uint32_t SR10:1; /* Channel 10 Pending Service Status */
1839  uint32_t SR9:1; /* Channel 9 Pending Service Status */
1840  uint32_t SR8:1; /* Channel 8 Pending Service Status */
1841  uint32_t SR7:1; /* Channel 7 Pending Service Status */
1842  uint32_t SR6:1; /* Channel 6 Pending Service Status */
1843  uint32_t SR5:1; /* Channel 5 Pending Service Status */
1844  uint32_t SR4:1; /* Channel 4 Pending Service Status */
1845  uint32_t SR3:1; /* Channel 3 Pending Service Status */
1846  uint32_t SR2:1; /* Channel 2 Pending Service Status */
1847  uint32_t SR1:1; /* Channel 1 Pending Service Status */
1848  uint32_t SR0:1; /* Channel 0 Pending Service Status */
1849  } B;
1850  } CPSSR_B;
1851
1852  uint32_t etpu_reserved20a[2];
1853
1854  union { /* ETPU_A Channel Service Status */
1855  uint32_t R;
1856  struct {
1857  uint32_t SS31:1; /* Channel 31 Service Status */
1858  uint32_t SS30:1; /* Channel 30 Service Status */
1859  uint32_t SS29:1; /* Channel 29 Service Status */
1860  uint32_t SS28:1; /* Channel 28 Service Status */
1861  uint32_t SS27:1; /* Channel 27 Service Status */
1862  uint32_t SS26:1; /* Channel 26 Service Status */
1863  uint32_t SS25:1; /* Channel 25 Service Status */
1864  uint32_t SS24:1; /* Channel 24 Service Status */
1865  uint32_t SS23:1; /* Channel 23 Service Status */
1866  uint32_t SS22:1; /* Channel 22 Service Status */
1867  uint32_t SS21:1; /* Channel 21 Service Status */
1868  uint32_t SS20:1; /* Channel 20 Service Status */
1869  uint32_t SS19:1; /* Channel 19 Service Status */
1870  uint32_t SS18:1; /* Channel 18 Service Status */
1871  uint32_t SS17:1; /* Channel 17 Service Status */
1872  uint32_t SS16:1; /* Channel 16 Service Status */
1873  uint32_t SS15:1; /* Channel 15 Service Status */
1874  uint32_t SS14:1; /* Channel 14 Service Status */
1875  uint32_t SS13:1; /* Channel 13 Service Status */
1876  uint32_t SS12:1; /* Channel 12 Service Status */
1877  uint32_t SS11:1; /* Channel 11 Service Status */
1878  uint32_t SS10:1; /* Channel 10 Service Status */
1879  uint32_t SS9:1; /* Channel 9 Service Status */
1880  uint32_t SS8:1; /* Channel 8 Service Status */
1881  uint32_t SS7:1; /* Channel 7 Service Status */
1882  uint32_t SS6:1; /* Channel 6 Service Status */
1883  uint32_t SS5:1; /* Channel 5 Service Status */
1884  uint32_t SS4:1; /* Channel 4 Service Status */
1885  uint32_t SS3:1; /* Channel 3 Service Status */
1886  uint32_t SS2:1; /* Channel 2 Service Status */
1887  uint32_t SS1:1; /* Channel 1 Service Status */
1888  uint32_t SS0:1; /* Channel 0 Service Status */
1889  } B;
1890  } CSSR_A;
1891
1892  union { /* ETPU_B Channel Service Status */
1893  uint32_t R;
1894  struct {
1895  uint32_t SS31:1; /* Channel 31 Service Status */
1896  uint32_t SS30:1; /* Channel 30 Service Status */
1897  uint32_t SS29:1; /* Channel 29 Service Status */
1898  uint32_t SS28:1; /* Channel 28 Service Status */
1899  uint32_t SS27:1; /* Channel 27 Service Status */
1900  uint32_t SS26:1; /* Channel 26 Service Status */
1901  uint32_t SS25:1; /* Channel 25 Service Status */
1902  uint32_t SS24:1; /* Channel 24 Service Status */
1903  uint32_t SS23:1; /* Channel 23 Service Status */
1904  uint32_t SS22:1; /* Channel 22 Service Status */
1905  uint32_t SS21:1; /* Channel 21 Service Status */
1906  uint32_t SS20:1; /* Channel 20 Service Status */
1907  uint32_t SS19:1; /* Channel 19 Service Status */
1908  uint32_t SS18:1; /* Channel 18 Service Status */
1909  uint32_t SS17:1; /* Channel 17 Service Status */
1910  uint32_t SS16:1; /* Channel 16 Service Status */
1911  uint32_t SS15:1; /* Channel 15 Service Status */
1912  uint32_t SS14:1; /* Channel 14 Service Status */
1913  uint32_t SS13:1; /* Channel 13 Service Status */
1914  uint32_t SS12:1; /* Channel 12 Service Status */
1915  uint32_t SS11:1; /* Channel 11 Service Status */
1916  uint32_t SS10:1; /* Channel 10 Service Status */
1917  uint32_t SS9:1; /* Channel 9 Service Status */
1918  uint32_t SS8:1; /* Channel 8 Service Status */
1919  uint32_t SS7:1; /* Channel 7 Service Status */
1920  uint32_t SS6:1; /* Channel 6 Service Status */
1921  uint32_t SS5:1; /* Channel 5 Service Status */
1922  uint32_t SS4:1; /* Channel 4 Service Status */
1923  uint32_t SS3:1; /* Channel 3 Service Status */
1924  uint32_t SS2:1; /* Channel 2 Service Status */
1925  uint32_t SS1:1; /* Channel 1 Service Status */
1926  uint32_t SS0:1; /* Channel 0 Service Status */
1927  } B;
1928  } CSSR_B;
1929
1930  uint32_t etpu_reserved23[90];
1931
1932 /*****************************Channels********************************/
1933
1934  struct {
1935  union {
1936  uint32_t R; /* Channel Configuration Register */
1937  struct {
1938  uint32_t CIE:1; /* Channel Interruput Enable */
1939  uint32_t DTRE:1; /* Data Transfer Request Enable */
1940  uint32_t CPR:2; /* Channel Priority */
1941  uint32_t:3;
1942  uint32_t ETCS:1; /* Entry Table Condition Select */
1943  uint32_t:3;
1944  uint32_t CFS:5; /* Channel Function Select */
1945  uint32_t ODIS:1; /* Output disable */
1946  uint32_t OPOL:1; /* output polarity */
1947  uint32_t:3;
1948  uint32_t CPBA:11; /* Channel Parameter Base Address */
1949  } B;
1950  } CR;
1951  union {
1952  uint32_t R; /* Channel Status Control Register */
1953  struct {
1954  uint32_t CIS:1; /* Channel Interruput Status */
1955  uint32_t CIOS:1; /* Channel Interruput Overflow Status */
1956  uint32_t:6;
1957  uint32_t DTRS:1; /* Data Transfer Status */
1958  uint32_t DTROS:1; /* Data Transfer Overflow Status */
1959  uint32_t:6;
1960  uint32_t IPS:1; /* Input Pin State */
1961  uint32_t OPS:1; /* Output Pin State */
1962  uint32_t OBE:1; /* Output Buffer Enable */
1963  uint32_t:11;
1964  uint32_t FM1:1; /* Function mode */
1965  uint32_t FM0:1; /* Function mode */
1966  } B;
1967  } SCR;
1968  union {
1969  uint32_t R; /* Channel Host Service Request Register */
1970  struct {
1971  uint32_t:29; /* Host Service Request */
1972  uint32_t HSR:3;
1973  } B;
1974  } HSRR;
1975  uint32_t etpu_reserved23;
1976  } CHAN[127];
1977
1978  };
1979 /****************************************************************************/
1980 /* MODULE : XBAR CrossBar */
1981 /****************************************************************************/
1982  struct XBAR_tag {
1983  union {
1984  uint32_t R;
1985  struct {
1986  uint32_t:4;
1987
1988  uint32_t:4;
1989
1990  uint32_t:4;
1991
1992  uint32_t:4;
1993
1994  uint32_t:4;
1995
1996  uint32_t:1;
1997  uint32_t MSTR2:3;
1998  uint32_t:1;
1999  uint32_t MSTR1:3;
2000  uint32_t:1;
2001  uint32_t MSTR0:3;
2002  } B;
2003  } MPR0; /* Master Priority Register for Slave Port 0 */
2004
2005  uint32_t xbar_reserved1[3];
2006
2007  union {
2008  uint32_t R;
2009  struct {
2010  uint32_t RO:1;
2011  uint32_t:21;
2012  uint32_t ARB:2;
2013  uint32_t:2;
2014  uint32_t PCTL:2;
2015  uint32_t:1;
2016  uint32_t PARK:3;
2017  } B;
2018  } SGPCR0; /* General Purpose Control Register for Slave Port 0 */
2019
2020  uint32_t xbar_reserved2[59];
2021
2022  union {
2023  uint32_t R;
2024  struct {
2025  uint32_t:4;
2026
2027  uint32_t:4;
2028
2029  uint32_t:4;
2030
2031  uint32_t:4;
2032
2033  uint32_t:4;
2034
2035  uint32_t:1;
2036  uint32_t MSTR2:3;
2037  uint32_t:1;
2038  uint32_t MSTR1:3;
2039  uint32_t:1;
2040  uint32_t MSTR0:3;
2041  } B;
2042  } MPR1; /* Master Priority Register for Slave Port 1 */
2043
2044  uint32_t xbar_reserved3[3];
2045
2046  union {
2047  uint32_t R;
2048  struct {
2049  uint32_t RO:1;
2050  uint32_t:21;
2051  uint32_t ARB:2;
2052  uint32_t:2;
2053  uint32_t PCTL:2;
2054  uint32_t:1;
2055  uint32_t PARK:3;
2056  } B;
2057  } SGPCR1; /* General Purpose Control Register for Slave Port 1 */
2058
2059  uint32_t xbar_reserved4[123];
2060
2061  union {
2062  uint32_t R;
2063  struct {
2064  uint32_t:4;
2065
2066  uint32_t:4;
2067
2068  uint32_t:4;
2069
2070  uint32_t:4;
2071
2072  uint32_t:4;
2073
2074  uint32_t:1;
2075  uint32_t MSTR2:3;
2076  uint32_t:1;
2077  uint32_t MSTR1:3;
2078  uint32_t:1;
2079  uint32_t MSTR0:3;
2080  } B;
2081  } MPR3; /* Master Priority Register for Slave Port 3 */
2082
2083  uint32_t xbar_reserved5[3];
2084
2085  union {
2086  uint32_t R;
2087  struct {
2088  uint32_t RO:1;
2089  uint32_t:21;
2090  uint32_t ARB:2;
2091  uint32_t:2;
2092  uint32_t PCTL:2;
2093  uint32_t:1;
2094  uint32_t PARK:3;
2095  } B;
2096  } SGPCR3; /* General Purpose Control Register for Slave Port 3 */
2097  uint32_t xbar_reserved6[187];
2098
2099  union {
2100  uint32_t R;
2101  struct {
2102  uint32_t:4;
2103
2104  uint32_t:4;
2105
2106  uint32_t:4;
2107
2108  uint32_t:4;
2109
2110  uint32_t:4;
2111
2112  uint32_t:1;
2113  uint32_t MSTR2:3;
2114  uint32_t:1;
2115  uint32_t MSTR1:3;
2116  uint32_t:1;
2117  uint32_t MSTR0:3;
2118  } B;
2119  } MPR6; /* Master Priority Register for Slave Port 6 */
2120
2121  uint32_t xbar_reserved7[3];
2122
2123  union {
2124  uint32_t R;
2125  struct {
2126  uint32_t RO:1;
2127  uint32_t:21;
2128  uint32_t ARB:2;
2129  uint32_t:2;
2130  uint32_t PCTL:2;
2131  uint32_t:1;
2132  uint32_t PARK:3;
2133  } B;
2134  } SGPCR6; /* General Purpose Control Register for Slave Port 6 */
2135
2136  uint32_t xbar_reserved8[59];
2137
2138  union {
2139  uint32_t R;
2140  struct {
2141  uint32_t:4;
2142
2143  uint32_t:4;
2144
2145  uint32_t:4;
2146
2147  uint32_t:4;
2148
2149  uint32_t:4;
2150
2151  uint32_t:1;
2152  uint32_t MSTR2:3;
2153  uint32_t:1;
2154  uint32_t MSTR1:3;
2155  uint32_t:1;
2156  uint32_t MSTR0:3;
2157  } B;
2158  } MPR7; /* Master Priority Register for Slave Port 7 */
2159
2160  uint32_t xbar_reserved9[3];
2161
2162  union {
2163  uint32_t R;
2164  struct {
2165  uint32_t RO:1;
2166  uint32_t:21;
2167  uint32_t ARB:2;
2168  uint32_t:2;
2169  uint32_t PCTL:2;
2170  uint32_t:1;
2171  uint32_t PARK:3;
2172  } B;
2173  } SGPCR7; /* General Purpose Control Register for Slave Port 7 */
2174
2175  };
2176 /****************************************************************************/
2177 /* MODULE : ECSM */
2178 /****************************************************************************/
2179  struct ECSM_tag {
2180
2181  uint32_t ecsm_reserved1[5];
2182
2183  uint16_t ecsm_reserved2;
2184
2185  union {
2186  uint16_t R;
2187  } SWTCR; //Software Watchdog Timer Control
2188
2189  uint8_t ecsm_reserved3[3];
2190
2191  union {
2192  uint8_t R;
2193  } SWTSR; //SWT Service Register
2194
2195  uint8_t ecsm_reserved4[3];
2196
2197  union {
2198  uint8_t R;
2199  } SWTIR; //SWT Interrupt Register
2200
2201  uint32_t ecsm_reserved5a[1];
2202  uint32_t ecsm_reserved5b[1];
2203
2204  uint32_t ecsm_reserved5c[6];
2205
2206  uint8_t ecsm_reserved6[3];
2207
2208  union {
2209  uint8_t R;
2210  struct {
2211  uint8_t:6;
2212  uint8_t ERNCR:1;
2213  uint8_t EFNCR:1;
2214  } B;
2215  } ECR; //ECC Configuration Register
2216
2217  uint8_t mcm_reserved8[3];
2218
2219  union {
2220  uint8_t R;
2221  struct {
2222  uint8_t:6;
2223  uint8_t RNCE:1;
2224  uint8_t FNCE:1;
2225  } B;
2226  } ESR; //ECC Status Register
2227
2228  uint16_t ecsm_reserved9;
2229
2230  union {
2231  uint16_t R;
2232  struct {
2233  uint16_t:6;
2234  uint16_t FRCNCI:1;
2235  uint16_t FR1NCI:1;
2236  uint16_t:1;
2237  uint16_t ERRBIT:7;
2238  } B;
2239  } EEGR; //ECC Error Generation Register
2240
2241  uint32_t ecsm_reserved10;
2242
2243  union {
2244  uint32_t R;
2245  struct {
2246  uint32_t FEAR:32;
2247  } B;
2248  } FEAR; //Flash ECC Address Register
2249
2250  uint16_t ecsm_reserved11;
2251
2252  union {
2253  uint8_t R;
2254  struct {
2255  uint8_t:4;
2256  uint8_t FEMR:4;
2257  } B;
2258  } FEMR; //Flash ECC Master Register
2259
2260  union {
2261  uint8_t R;
2262  struct {
2263  uint8_t WRITE:1;
2264  uint8_t SIZE:3;
2265  uint8_t PROT0:1;
2266  uint8_t PROT1:1;
2267  uint8_t PROT2:1;
2268  uint8_t PROT3:1;
2269  } B;
2270  } FEAT; //Flash ECC Attributes Register
2271
2272  union {
2273  uint32_t R;
2274  struct {
2275  uint32_t FEDH:32;
2276  } B;
2277  } FEDRH; //Flash ECC Data High Register
2278
2279  union {
2280  uint32_t R;
2281  struct {
2282  uint32_t FEDL:32;
2283  } B;
2284  } FEDRL; //Flash ECC Data Low Register
2285
2286  union {
2287  uint32_t R;
2288  struct {
2289  uint32_t REAR:32;
2290  } B;
2291  } REAR; //RAM ECC Address
2292
2293  uint8_t ecsm_reserved12[2];
2294
2295  union {
2296  uint8_t R;
2297  struct {
2298  uint8_t:4;
2299  uint8_t REMR:4;
2300  } B;
2301  } REMR; //RAM ECC Master
2302
2303  union {
2304  uint8_t R;
2305  struct {
2306  uint8_t WRITE:1;
2307  uint8_t SIZE:3;
2308  uint8_t PROT0:1;
2309  uint8_t PROT1:1;
2310  uint8_t PROT2:1;
2311  uint8_t PROT3:1;
2312  } B;
2313  } REAT; // RAM ECC Attributes Register
2314
2315  union {
2316  uint32_t R;
2317  struct {
2318  uint32_t REDH:32;
2319  } B;
2320  } REDRH; //RAM ECC Data High Register
2321
2322  union {
2323  uint32_t R;
2324  struct {
2325  uint32_t REDL:32;
2326  } B;
2327  } REDRL; //RAMECC Data Low Register
2328
2329  };
2330 /****************************************************************************/
2331 /* MODULE : INTC */
2332 /****************************************************************************/
2333  struct INTC_tag {
2334  union {
2335  uint32_t R;
2336  struct {
2337  uint32_t:26;
2338  uint32_t VTES:1;
2339  uint32_t:4;
2340  uint32_t HVEN:1;
2341  } B;
2342  } MCR; /* Module Configuration Register */
2343
2344  int32_t INTC_reserved00;
2345
2346  union {
2347  uint32_t R;
2348  struct {
2349  uint32_t:28;
2350  uint32_t PRI:4;
2351  } B;
2352  } CPR; /* Current Priority Register */
2353
2354  uint32_t intc_reserved1;
2355
2356  union {
2357  uint32_t R;
2358  struct {
2359  uint32_t VTBA:21;
2360  uint32_t INTVEC:9;
2361  uint32_t:2;
2362  } B;
2363  } IACKR; /* Interrupt Acknowledge Register */
2364
2365  uint32_t intc_reserved2;
2366
2367  union {
2368  uint32_t R;
2369  struct {
2370  uint32_t:32;
2371  } B;
2372  } EOIR; /* End of Interrupt Register */
2373
2374  uint32_t intc_reserved3;
2375
2376  union {
2377  uint8_t R;
2378  struct {
2379  uint8_t:6;
2380  uint8_t SET:1;
2381  uint8_t CLR:1;
2382  } B;
2383  } SSCIR[8]; /* Software Set/Clear Interruput Register */
2384
2385  uint32_t intc_reserved4[6];
2386
2387  union {
2388  uint8_t R;
2389  struct {
2390  uint8_t:4;
2391  uint8_t PRI:4;
2392  } B;
2393  } PSR[358]; /* Software Set/Clear Interrupt Register */
2394
2395  };
2396 /****************************************************************************/
2397 /* MODULE : EQADC */
2398 /****************************************************************************/
2399  struct EQADC_tag {
2400  union {
2401  uint32_t R;
2402  struct {
2403  uint32_t:27;
2404  uint32_t ESSIE:2;
2405  uint32_t:1;
2406  uint32_t DBG:2;
2407  } B;
2408  } MCR; /* Module Configuration Register */
2409
2410  int32_t EQADC_reserved00;
2411
2412  union {
2413  uint32_t R;
2414  struct {
2415  uint32_t:6;
2416  uint32_t NMF:26;
2417  } B;
2418  } NMSFR; /* Null Message Send Format Register */
2419
2420  union {
2421  uint32_t R;
2422  struct {
2423  uint32_t:28;
2424  uint32_t DFL:4;
2425  } B;
2426  } ETDFR; /* External Trigger Digital Filter Register */
2427
2428  union {
2429  uint32_t R;
2430  struct {
2431  uint32_t CFPUSH:32;
2432  } B;
2433  } CFPR[6]; /* CFIFO Push Registers */
2434
2435  uint32_t eqadc_reserved1;
2436
2437  uint32_t eqadc_reserved2;
2438
2439  union {
2440  uint32_t R;
2441  struct {
2442  uint32_t:16;
2443  uint32_t RFPOP:16;
2444  } B;
2445  } RFPR[6]; /* Result FIFO Pop Registers */
2446
2447  uint32_t eqadc_reserved3;
2448
2449  uint32_t eqadc_reserved4;
2450
2452  uint16_t R;
2453  struct {
2454  uint16_t:5;
2455  uint16_t SSE:1;
2456  uint16_t CFINV:1;
2457  uint16_t:1;
2458  uint16_t MODE:4;
2459  uint16_t:4;
2460  } B;
2461  } CFCR[6]; /* CFIFO Control Registers */
2462
2463  uint32_t eqadc_reserved5;
2464
2466  uint16_t R;
2467  struct {
2468  uint16_t NCIE:1;
2469  uint16_t TORIE:1;
2470  uint16_t PIE:1;
2471  uint16_t EOQIE:1;
2472  uint16_t CFUIE:1;
2473  uint16_t:1;
2474  uint16_t CFFE:1;
2475  uint16_t CFFS:1;
2476  uint16_t:4;
2477  uint16_t RFOIE:1;
2478  uint16_t:1;
2479  uint16_t RFDE:1;
2480  uint16_t RFDS:1;
2481  } B;
2482  } IDCR[6]; /* Interrupt and DMA Control Registers */
2483
2484  uint32_t eqadc_reserved6;
2485
2487  uint32_t R;
2488  struct {
2489  uint32_t NCF:1;
2490  uint32_t TORF:1;
2491  uint32_t PF:1;
2492  uint32_t EOQF:1;
2493  uint32_t CFUF:1;
2494  uint32_t SSS:1;
2495  uint32_t CFFF:1;
2496  uint32_t:5;
2497  uint32_t RFOF:1;
2498  uint32_t:1;
2499  uint32_t RFDF:1;
2500  uint32_t:1;
2501  uint32_t CFCTR:4;
2502  uint32_t TNXTPTR:4;
2503  uint32_t RFCTR:4;
2504  uint32_t POPNXTPTR:4;
2505  } B;
2506  } FISR[6]; /* FIFO and Interrupt Status Registers */
2507
2508  uint32_t eqadc_reserved7;
2509
2510  uint32_t eqadc_reserved8;
2511
2512  union {
2513  uint16_t R;
2514  struct {
2515  uint16_t:5;
2516  uint16_t TCCF:11;
2517  } B;
2518  } CFTCR[6]; /* CFIFO Transfer Counter Registers */
2519
2520  uint32_t eqadc_reserved9;
2521
2522  union {
2523  uint32_t R;
2524  struct {
2525  uint32_t CFS0:2;
2526  uint32_t CFS1:2;
2527  uint32_t CFS2:2;
2528  uint32_t CFS3:2;
2529  uint32_t CFS4:2;
2530  uint32_t CFS5:2;
2531  uint32_t:5;
2532  uint32_t LCFTCB0:4;
2533  uint32_t TC_LCFTCB0:11;
2534  } B;
2535  } CFSSR0; /* CFIFO Status Register 0 */
2536
2537  union {
2538  uint32_t R;
2539  struct {
2540  uint32_t CFS0:2;
2541  uint32_t CFS1:2;
2542  uint32_t CFS2:2;
2543  uint32_t CFS3:2;
2544  uint32_t CFS4:2;
2545  uint32_t CFS5:2;
2546  uint32_t:5;
2547  uint32_t LCFTCB1:4;
2548  uint32_t TC_LCFTCB1:11;
2549  } B;
2550  } CFSSR1; /* CFIFO Status Register 1 */
2551
2552  union {
2553  uint32_t R;
2554  struct {
2555  uint32_t CFS0:2;
2556  uint32_t CFS1:2;
2557  uint32_t CFS2:2;
2558  uint32_t CFS3:2;
2559  uint32_t CFS4:2;
2560  uint32_t CFS5:2;
2561  uint32_t:4;
2562  uint32_t ECBNI:1;
2563  uint32_t LCFTSSI:4;
2564  uint32_t TC_LCFTSSI:11;
2565  } B;
2566  } CFSSR2; /* CFIFO Status Register 2 */
2567
2568  union {
2569  uint32_t R;
2570  struct {
2571  uint32_t CFS0:2;
2572  uint32_t CFS1:2;
2573  uint32_t CFS2:2;
2574  uint32_t CFS3:2;
2575  uint32_t CFS4:2;
2576  uint32_t CFS5:2;
2577  uint32_t:20;
2578  } B;
2579  } CFSR;
2580
2581  uint32_t eqadc_reserved11;
2582
2583  union {
2584  uint32_t R;
2585  struct {
2586  uint32_t:21;
2587  uint32_t MDT:3;
2588  uint32_t:4;
2589  uint32_t BR:4;
2590  } B;
2591  } SSICR; /* SSI Control Register */
2592
2593  union {
2594  uint32_t R;
2595  struct {
2596  uint32_t RDV:1;
2597  uint32_t:5;
2598  uint32_t RDATA:26;
2599  } B;
2600  } SSIRDR; /* SSI Recieve Data Register */
2601
2602  uint32_t eqadc_reserved12[17];
2603
2604  struct {
2605  union {
2606  uint32_t R;
2607  struct {
2608  uint32_t:32;
2609  } B;
2610  } R[4];
2611
2612  uint32_t eqadc_reserved13[12];
2613
2614  } CF[6];
2615
2616  uint32_t eqadc_reserved14[32];
2617
2618  struct {
2619  union {
2620  uint32_t R;
2621  struct {
2622  uint32_t:32;
2623  } B;
2624  } R[4];
2625
2626  uint32_t eqadc_reserved15[12];
2627
2628  } RF[6];
2629
2630  };
2631
2632 /* Message Formats for On-Chip ADC Operation
2633  */
2635  uint32_t R;
2636  struct {
2637  uint32_t EOQ:1;
2638  uint32_t PAUSE:1;
2639  uint32_t:3;
2640  uint32_t EB:1;
2641  uint32_t BN:1;
2642  uint32_t CAL:1;
2643  uint32_t MESSAGE_TAG:4;
2644  uint32_t LST:2;
2645  uint32_t TSR:1;
2646  uint32_t FMT:1;
2647  uint32_t CHANNEL_NUMBER:8;
2648  uint32_t:8;
2649  } B;
2650 }; /* Conversion command */
2651
2653  uint32_t R;
2654  struct {
2655  uint32_t EOQ:1;
2656  uint32_t PAUSE:1;
2657  uint32_t:3;
2658  uint32_t EB:1;
2659  uint32_t BN:1;
2660  uint32_t RW:1;
2661  uint32_t VALUE:16;
2662  uint32_t ADDR:8;
2663  } B;
2664 }; /* Write configuration command */
2665
2666 /****************************************************************************/
2667 /* MODULE : DSPI */
2668 /****************************************************************************/
2669  struct DSPI_tag {
2670  union DSPI_MCR_tag {
2671  uint32_t R;
2672  struct {
2673  uint32_t MSTR:1;
2674  uint32_t CONT_SCKE:1;
2675  uint32_t DCONF:2;
2676  uint32_t FRZ:1;
2677  uint32_t MTFE:1;
2678  uint32_t PCSSE:1;
2679  uint32_t ROOE:1;
2680  uint32_t:2;
2681  uint32_t PCSIS5:1;
2682  uint32_t PCSIS4:1;
2683  uint32_t PCSIS3:1;
2684  uint32_t PCSIS2:1;
2685  uint32_t PCSIS1:1;
2686  uint32_t PCSIS0:1;
2687  uint32_t DOZE:1;
2688  uint32_t MDIS:1;
2689  uint32_t DIS_TXF:1;
2690  uint32_t DIS_RXF:1;
2691  uint32_t CLR_TXF:1;
2692  uint32_t CLR_RXF:1;
2693  uint32_t SMPL_PT:2;
2694  uint32_t:7;
2695  uint32_t HALT:1;
2696  } B;
2697  } MCR; /* Module Configuration Register */
2698
2699  uint32_t dspi_reserved1;
2700
2701  union {
2702  uint32_t R;
2703  struct {
2704  uint32_t TCNT:16;
2705  uint32_t:16;
2706  } B;
2707  } TCR;
2708
2709  union DSPI_CTAR_tag {
2710  uint32_t R;
2711  struct {
2712  uint32_t DBR:1;
2713  uint32_t FMSZ:4;
2714  uint32_t CPOL:1;
2715  uint32_t CPHA:1;
2716  uint32_t LSBFE:1;
2717  uint32_t PCSSCK:2;
2718  uint32_t PASC:2;
2719  uint32_t PDT:2;
2720  uint32_t PBR:2;
2721  uint32_t CSSCK:4;
2722  uint32_t ASC:4;
2723  uint32_t DT:4;
2724  uint32_t BR:4;
2725  } B;
2726  } CTAR[8]; /* Clock and Transfer Attributes Registers */
2727
2728  union DSPI_SR_tag {
2729  uint32_t R;
2730  struct {
2731  uint32_t TCF:1;
2732  uint32_t TXRXS:1;
2733  uint32_t:1;
2734  uint32_t EOQF:1;
2735  uint32_t TFUF:1;
2736  uint32_t:1;
2737  uint32_t TFFF:1;
2738  uint32_t:5;
2739  uint32_t RFOF:1;
2740  uint32_t:1;
2741  uint32_t RFDF:1;
2742  uint32_t:1;
2743  uint32_t TXCTR:4;
2744  uint32_t TXNXTPTR:4;
2745  uint32_t RXCTR:4;
2746  uint32_t POPNXTPTR:4;
2747  } B;
2748  } SR; /* Status Register */
2749
2750  union DSPI_RSER_tag {
2751  uint32_t R;
2752  struct {
2753  uint32_t TCFRE:1;
2754  uint32_t:2;
2755  uint32_t EOQFRE:1;
2756  uint32_t TFUFRE:1;
2757  uint32_t:1;
2758  uint32_t TFFFRE:1;
2759  uint32_t TFFFDIRS:1;
2760  uint32_t:4;
2761  uint32_t RFOFRE:1;
2762  uint32_t:1;
2763  uint32_t RFDFRE:1;
2764  uint32_t RFDFDIRS:1;
2765  uint32_t:16;
2766  } B;
2767  } RSER; /* DMA/Interrupt Request Select and Enable Register */
2768
2769  union DSPI_PUSHR_tag {
2770  uint32_t R;
2771  struct {
2772  uint32_t CONT:1;
2773  uint32_t CTAS:3;
2774  uint32_t EOQ:1;
2775  uint32_t CTCNT:1;
2776  uint32_t:4;
2777  uint32_t PCS5:1;
2778  uint32_t PCS4:1;
2779  uint32_t PCS3:1;
2780  uint32_t PCS2:1;
2781  uint32_t PCS1:1;
2782  uint32_t PCS0:1;
2783  uint32_t TXDATA:16;
2784  } B;
2785  } PUSHR; /* PUSH TX FIFO Register */
2786
2787  union DSPI_POPR_tag {
2788  uint32_t R;
2789  struct {
2790  uint32_t:16;
2791  uint32_t RXDATA:16;
2792  } B;
2793  } POPR; /* POP RX FIFO Register */
2794
2795  union {
2796  uint32_t R;
2797  struct {
2798  uint32_t TXCMD:16;
2799  uint32_t TXDATA:16;
2800  } B;
2801  } TXFR[4]; /* Transmit FIFO Registers */
2802
2803  uint32_t DSPI_reserved_txf[12];
2804
2805  union {
2806  uint32_t R;
2807  struct {
2808  uint32_t:16;
2809  uint32_t RXDATA:16;
2810  } B;
2811  } RXFR[4]; /* Transmit FIFO Registers */
2812
2813  uint32_t DSPI_reserved_rxf[12];
2814
2815  union {
2816  uint32_t R;
2817  struct {
2818  uint32_t MTOE:1;
2819  uint32_t:1;
2820  uint32_t MTOCNT:6;
2821  uint32_t:4;
2822  uint32_t TXSS:1;
2823  uint32_t TPOL:1;
2824  uint32_t TRRE:1;
2825  uint32_t CID:1;
2826  uint32_t DCONT:1;
2827  uint32_t DSICTAS:3;
2828  uint32_t:6;
2829  uint32_t DPCS5:1;
2830  uint32_t DPCS4:1;
2831  uint32_t DPCS3:1;
2832  uint32_t DPCS2:1;
2833  uint32_t DPCS1:1;
2834  uint32_t DPCS0:1;
2835  } B;
2836  } DSICR; /* DSI Configuration Register */
2837
2838  union {
2839  uint32_t R;
2840  struct {
2841  uint32_t:16;
2842  uint32_t SER_DATA:16;
2843  } B;
2844  } SDR; /* DSI Serialization Data Register */
2845
2846  union {
2847  uint32_t R;
2848  struct {
2849  uint32_t:16;
2850  uint32_t ASER_DATA:16;
2851  } B;
2852  } ASDR; /* DSI Alternate Serialization Data Register */
2853
2854  union {
2855  uint32_t R;
2856  struct {
2857  uint32_t:16;
2858  uint32_t COMP_DATA:16;
2859  } B;
2860  } COMPR; /* DSI Transmit Comparison Register */
2861
2862  union {
2863  uint32_t R;
2864  struct {
2865  uint32_t:16;
2866  uint32_t DESER_DATA:16;
2867  } B;
2868  } DDR; /* DSI deserialization Data Register */
2869
2870  };
2871 /****************************************************************************/
2872 /* MODULE : eSCI */
2873 /****************************************************************************/
2874  struct ESCI_tag {
2875  union ESCI_CR1_tag {
2876  uint32_t R;
2877  struct {
2878  uint32_t:3;
2879  uint32_t SBR:13;
2880  uint32_t LOOPS:1;
2881  uint32_t SCISDOZ:1;
2882  uint32_t RSRC:1;
2883  uint32_t M:1;
2884  uint32_t WAKE:1;
2885  uint32_t ILT:1;
2886  uint32_t PE:1;
2887  uint32_t PT:1;
2888  uint32_t TIE:1;
2889  uint32_t TCIE:1;
2890  uint32_t RIE:1;
2891  uint32_t ILIE:1;
2892  uint32_t TE:1;
2893  uint32_t RE:1;
2894  uint32_t RWU:1;
2895  uint32_t SBK:1;
2896  } B;
2897  } CR1; /* Control Register 1 */
2898
2899  union ESCI_CR2_tag {
2900  uint16_t R;
2901  struct {
2902  uint16_t MDIS:1;
2903  uint16_t FBR:1;
2904  uint16_t BSTP:1;
2905  uint16_t IEBERR:1;
2906  uint16_t RXDMA:1;
2907  uint16_t TXDMA:1;
2908  uint16_t BRK13:1;
2909  uint16_t:1;
2910  uint16_t BESM13:1;
2911  uint16_t SBSTP:1;
2912  uint16_t:2;
2913  uint16_t ORIE:1;
2914  uint16_t NFIE:1;
2915  uint16_t FEIE:1;
2916  uint16_t PFIE:1;
2917  } B;
2918  } CR2; /* Control Register 2 */
2919
2920  union ESCI_DR_tag {
2921  uint16_t R;
2922  struct {
2923  uint16_t R8:1;
2924  uint16_t T8:1;
2925  uint16_t:6;
2926  uint8_t D;
2927  } B;
2928  } DR; /* Data Register */
2929
2930  union ESCI_SR_tag {
2931  uint32_t R;
2932  struct {
2933  uint32_t TDRE:1;
2934  uint32_t TC:1;
2935  uint32_t RDRF:1;
2936  uint32_t IDLE:1;
2937  uint32_t OR:1;
2938  uint32_t NF:1;
2939  uint32_t FE:1;
2940  uint32_t PF:1;
2941  uint32_t:3;
2942  uint32_t BERR:1;
2943  uint32_t:3;
2944  uint32_t RAF:1;
2945  uint32_t RXRDY:1;
2946  uint32_t TXRDY:1;
2947  uint32_t LWAKE:1;
2948  uint32_t STO:1;
2949  uint32_t PBERR:1;
2950  uint32_t CERR:1;
2951  uint32_t CKERR:1;
2952  uint32_t FRC:1;
2953  uint32_t:7;
2954  uint32_t OVFL:1;
2955  } B;
2956  } SR; /* Status Register */
2957
2958  union {
2959  uint32_t R;
2960  struct {
2961  uint32_t LRES:1;
2962  uint32_t WU:1;
2963  uint32_t WUD0:1;
2964  uint32_t WUD1:1;
2965  uint32_t LDBG:1;
2966  uint32_t DSF:1;
2967  uint32_t PRTY:1;
2968  uint32_t LIN:1;
2969  uint32_t RXIE:1;
2970  uint32_t TXIE:1;
2971  uint32_t WUIE:1;
2972  uint32_t STIE:1;
2973  uint32_t PBIE:1;
2974  uint32_t CIE:1;
2975  uint32_t CKIE:1;
2976  uint32_t FCIE:1;
2977  uint32_t:7;
2978  uint32_t OFIE:1;
2979  uint32_t:8;
2980  } B;
2981  } LCR; /* LIN Control Register */
2982
2983  union {
2984  uint32_t R;
2985  } LTR; /* LIN Transmit Register */
2986
2987  union {
2988  uint32_t R;
2989  } LRR; /* LIN Recieve Register */
2990
2991  union {
2992  uint32_t R;
2993  } LPR; /* LIN CRC Polynom Register */
2994
2995  };
2996 /****************************************************************************/
2997 /* MODULE : FlexCAN */
2998 /****************************************************************************/
2999  struct FLEXCAN2_tag {
3000  union {
3001  uint32_t R;
3002  struct {
3003  uint32_t MDIS:1;
3004  uint32_t FRZ:1;
3005  uint32_t:1;
3006  uint32_t HALT:1;
3007  uint32_t NOTRDY:1;
3008  uint32_t:1;
3009  uint32_t SOFTRST:1;
3010  uint32_t FRZACK:1;
3011  uint32_t:1;
3012  uint32_t:1;
3013
3014  uint32_t:1;
3015
3016  uint32_t MDISACK:1;
3017  uint32_t:1;
3018  uint32_t:1;
3019
3020  uint32_t:12;
3021
3022  uint32_t MAXMB:6;
3023  } B;
3024  } MCR; /* Module Configuration Register */
3025
3026  union {
3027  uint32_t R;
3028  struct {
3029  uint32_t PRESDIV:8;
3030  uint32_t RJW:2;
3031  uint32_t PSEG1:3;
3032  uint32_t PSEG2:3;
3033  uint32_t BOFFMSK:1;
3034  uint32_t ERRMSK:1;
3035  uint32_t CLKSRC:1;
3036  uint32_t LPB:1;
3037
3038  uint32_t:4;
3039
3040  uint32_t SMP:1;
3041  uint32_t BOFFREC:1;
3042  uint32_t TSYN:1;
3043  uint32_t LBUF:1;
3044  uint32_t LOM:1;
3045  uint32_t PROPSEG:3;
3046  } B;
3047  } CR; /* Control Register */
3048
3049  union {
3050  uint32_t R;
3051  } TIMER; /* Free Running Timer */
3052  int32_t FLEXCAN_reserved00;
3053
3054  union {
3055  uint32_t R;
3056  struct {
3057  uint32_t:3;
3058  uint32_t MI:29;
3059  } B;
3060  } RXGMASK; /* RX Global Mask */
3061
3062  union {
3063  uint32_t R;
3064  struct {
3065  uint32_t:3;
3066  uint32_t MI:29;
3067  } B;
3068  } RX14MASK; /* RX 14 Mask */
3069
3070  union {
3071  uint32_t R;
3072  struct {
3073  uint32_t:3;
3074  uint32_t MI:29;
3075  } B;
3076  } RX15MASK; /* RX 15 Mask */
3077
3078  union {
3079  uint32_t R;
3080  struct {
3081  uint32_t:16;
3082  uint32_t RXECNT:8;
3083  uint32_t TXECNT:8;
3084  } B;
3085  } ECR; /* Error Counter Register */
3086
3087  union {
3088  uint32_t R;
3089  struct {
3090  uint32_t:14;
3091
3092  uint32_t:2;
3093
3094  uint32_t BIT1ERR:1;
3095  uint32_t BIT0ERR:1;
3096  uint32_t ACKERR:1;
3097  uint32_t CRCERR:1;
3098  uint32_t FRMERR:1;
3099  uint32_t STFERR:1;
3100  uint32_t TXWRN:1;
3101  uint32_t RXWRN:1;
3102  uint32_t IDLE:1;
3103  uint32_t TXRX:1;
3104  uint32_t FLTCONF:2;
3105  uint32_t:1;
3106  uint32_t BOFFINT:1;
3107  uint32_t ERRINT:1;
3108  uint32_t:1;
3109  } B;
3110  } ESR; /* Error and Status Register */
3111
3112  union {
3113  uint32_t R;
3114  struct {
3115  uint32_t BUF63M:1;
3116  uint32_t BUF62M:1;
3117  uint32_t BUF61M:1;
3118  uint32_t BUF60M:1;
3119  uint32_t BUF59M:1;
3120  uint32_t BUF58M:1;
3121  uint32_t BUF57M:1;
3122  uint32_t BUF56M:1;
3123  uint32_t BUF55M:1;
3124  uint32_t BUF54M:1;
3125  uint32_t BUF53M:1;
3126  uint32_t BUF52M:1;
3127  uint32_t BUF51M:1;
3128  uint32_t BUF50M:1;
3129  uint32_t BUF49M:1;
3130  uint32_t BUF48M:1;
3131  uint32_t BUF47M:1;
3132  uint32_t BUF46M:1;
3133  uint32_t BUF45M:1;
3134  uint32_t BUF44M:1;
3135  uint32_t BUF43M:1;
3136  uint32_t BUF42M:1;
3137  uint32_t BUF41M:1;
3138  uint32_t BUF40M:1;
3139  uint32_t BUF39M:1;
3140  uint32_t BUF38M:1;
3141  uint32_t BUF37M:1;
3142  uint32_t BUF36M:1;
3143  uint32_t BUF35M:1;
3144  uint32_t BUF34M:1;
3145  uint32_t BUF33M:1;
3146  uint32_t BUF32M:1;
3147  } B;
3148  } IMRH; /* Interruput Masks Register */
3149
3150  union {
3151  uint32_t R;
3152  struct {
3153  uint32_t BUF31M:1;
3154  uint32_t BUF30M:1;
3155  uint32_t BUF29M:1;
3156  uint32_t BUF28M:1;
3157  uint32_t BUF27M:1;
3158  uint32_t BUF26M:1;
3159  uint32_t BUF25M:1;
3160  uint32_t BUF24M:1;
3161  uint32_t BUF23M:1;
3162  uint32_t BUF22M:1;
3163  uint32_t BUF21M:1;
3164  uint32_t BUF20M:1;
3165  uint32_t BUF19M:1;
3166  uint32_t BUF18M:1;
3167  uint32_t BUF17M:1;
3168  uint32_t BUF16M:1;
3169  uint32_t BUF15M:1;
3170  uint32_t BUF14M:1;
3171  uint32_t BUF13M:1;
3172  uint32_t BUF12M:1;
3173  uint32_t BUF11M:1;
3174  uint32_t BUF10M:1;
3175  uint32_t BUF09M:1;
3176  uint32_t BUF08M:1;
3177  uint32_t BUF07M:1;
3178  uint32_t BUF06M:1;
3179  uint32_t BUF05M:1;
3180  uint32_t BUF04M:1;
3181  uint32_t BUF03M:1;
3182  uint32_t BUF02M:1;
3183  uint32_t BUF01M:1;
3184  uint32_t BUF00M:1;
3185  } B;
3186  } IMRL; /* Interruput Masks Register */
3187
3188  union {
3189  uint32_t R;
3190  struct {
3191  uint32_t BUF63I:1;
3192  uint32_t BUF62I:1;
3193  uint32_t BUF61I:1;
3194  uint32_t BUF60I:1;
3195  uint32_t BUF59I:1;
3196  uint32_t BUF58I:1;
3197  uint32_t BUF57I:1;
3198  uint32_t BUF56I:1;
3199  uint32_t BUF55I:1;
3200  uint32_t BUF54I:1;
3201  uint32_t BUF53I:1;
3202  uint32_t BUF52I:1;
3203  uint32_t BUF51I:1;
3204  uint32_t BUF50I:1;
3205  uint32_t BUF49I:1;
3206  uint32_t BUF48I:1;
3207  uint32_t BUF47I:1;
3208  uint32_t BUF46I:1;
3209  uint32_t BUF45I:1;
3210  uint32_t BUF44I:1;
3211  uint32_t BUF43I:1;
3212  uint32_t BUF42I:1;
3213  uint32_t BUF41I:1;
3214  uint32_t BUF40I:1;
3215  uint32_t BUF39I:1;
3216  uint32_t BUF38I:1;
3217  uint32_t BUF37I:1;
3218  uint32_t BUF36I:1;
3219  uint32_t BUF35I:1;
3220  uint32_t BUF34I:1;
3221  uint32_t BUF33I:1;
3222  uint32_t BUF32I:1;
3223  } B;
3224  } IFRH; /* Interruput Flag Register */
3225
3226  union {
3227  uint32_t R;
3228  struct {
3229  uint32_t BUF31I:1;
3230  uint32_t BUF30I:1;
3231  uint32_t BUF29I:1;
3232  uint32_t BUF28I:1;
3233  uint32_t BUF27I:1;
3234  uint32_t BUF26I:1;
3235  uint32_t BUF25I:1;
3236  uint32_t BUF24I:1;
3237  uint32_t BUF23I:1;
3238  uint32_t BUF22I:1;
3239  uint32_t BUF21I:1;
3240  uint32_t BUF20I:1;
3241  uint32_t BUF19I:1;
3242  uint32_t BUF18I:1;
3243  uint32_t BUF17I:1;
3244  uint32_t BUF16I:1;
3245  uint32_t BUF15I:1;
3246  uint32_t BUF14I:1;
3247  uint32_t BUF13I:1;
3248  uint32_t BUF12I:1;
3249  uint32_t BUF11I:1;
3250  uint32_t BUF10I:1;
3251  uint32_t BUF09I:1;
3252  uint32_t BUF08I:1;
3253  uint32_t BUF07I:1;
3254  uint32_t BUF06I:1;
3255  uint32_t BUF05I:1;
3256  uint32_t BUF04I:1;
3257  uint32_t BUF03I:1;
3258  uint32_t BUF02I:1;
3259  uint32_t BUF01I:1;
3260  uint32_t BUF00I:1;
3261  } B;
3262  } IFRL; /* Interruput Flag Register */
3263
3264  uint32_t flexcan2_reserved2[19];
3265
3266  struct canbuf_t {
3267  union {
3268  uint32_t R;
3269  struct {
3270  uint32_t:4;
3271  uint32_t CODE:4;
3272  uint32_t:1;
3273  uint32_t SRR:1;
3274  uint32_t IDE:1;
3275  uint32_t RTR:1;
3276  uint32_t LENGTH:4;
3277  uint32_t TIMESTAMP:16;
3278  } B;
3279  } CS;
3280
3281  union {
3282  uint32_t R;
3283  struct {
3284  uint32_t:3;
3285  uint32_t STD_ID:11;
3286  uint32_t EXT_ID:18;
3287  } B;
3288  } ID;
3289
3290  union {
3291  uint8_t B[8]; /* Data buffer in Bytes (8 bits) */
3292  uint16_t H[4]; /* Data buffer in Half-words (16 bits) */
3293  uint32_t W[2]; /* Data buffer in words (32 bits) */
3294  uint32_t R[2]; /* Data buffer in words (32 bits) */
3295  } DATA;
3296
3297  } BUF[64];
3298  };
3299
3300 /* Define memories */
3301
3302 #define SRAM_START 0x40000000
3303 #define SRAM_SIZE 0x10000
3304 #define SRAM_END 0x4000FFFF
3305
3306 #define FLASH_START 0x0
3307 #define FLASH_SIZE 0x200000
3308 #define FLASH_END 0x1FFFFF
3309
3310 /* Define instances of modules */
3311 #define PBRIDGE_A (*(volatile struct PBRIDGE_A_tag *) 0xC3F00000)
3312 #define FMPLL (*(volatile struct FMPLL_tag *) 0xC3F80000)
3313 #define EBI (*(volatile struct EBI_tag *) 0xC3F84000)
3314 #define FLASH (*(volatile struct FLASH_tag *) 0xC3F88000)
3315 #define SIU (*(volatile struct SIU_tag *) 0xC3F90000)
3316
3317 #define EMIOS (*(volatile struct EMIOS_tag *) 0xC3FA0000)
3318 #define ETPU (*(volatile struct ETPU_tag *) 0xC3FC0000)
3319 #define ETPU_DATA_RAM (*( uint32_t *) 0xC3FC8000)
3320 #define ETPU_DATA_RAM_EXT (*( uint32_t *) 0xC3FCC000)
3321 #define ETPU_DATA_RAM_END 0xC3FC8BFC
3322 #define CODE_RAM (*( uint32_t *) 0xC3FD0000)
3323 #define ETPU_CODE_RAM (*( uint32_t *) 0xC3FD0000)
3324
3325 #define PBRIDGE_B (*(volatile struct PBRIDGE_B_tag *) 0xFFF00000)
3326 #define XBAR (*(volatile struct XBAR_tag *) 0xFFF04000)
3327 #define ECSM (*(volatile struct ECSM_tag *) 0xFFF40000)
3328 #define EDMA (*(volatile struct EDMA_tag *) 0xFFF44000)
3329 #define INTC (*(volatile struct INTC_tag *) 0xFFF48000)
3330
3331 #define EQADC (*(volatile struct EQADC_tag *) 0xFFF80000)
3332
3333 #define DSPI_A (*(volatile struct DSPI_tag *) 0xFFF90000)
3334 #define DSPI_B (*(volatile struct DSPI_tag *) 0xFFF94000)
3335 #define DSPI_C (*(volatile struct DSPI_tag *) 0xFFF98000)
3336 #define DSPI_D (*(volatile struct DSPI_tag *) 0xFFF9C000)
3337
3338 #define ESCI_A (*(volatile struct ESCI_tag *) 0xFFFB0000)
3339 #define ESCI_B (*(volatile struct ESCI_tag *) 0xFFFB4000)
3340
3341 #define CAN_A (*(volatile struct FLEXCAN2_tag *) 0xFFFC0000)
3342 #define CAN_B (*(volatile struct FLEXCAN2_tag *) 0xFFFC4000)
3343 #define CAN_C (*(volatile struct FLEXCAN2_tag *) 0xFFFC8000)
3344
3345 #ifdef __MWERKS__
3346 #pragma pop
3347 #endif
3348
3349 #ifdef __cplusplus
3350 }
3351 #endif
3352 #endif /* ASM */
3353 #endif /* ifdef _MPC5554_H */
3354 /*********************************************************************
3355  *
3356  * Copyright:
3357  * Freescale Semiconductor, INC. All Rights Reserved.
3358  * You are hereby granted a copyright license to use, modify, and
3359  * distribute the SOFTWARE so long as this entire notice is
3360  * retained without alteration in any modified and/or redistributed
3361  * versions, and that such modified versions are clearly identified
3362  * as such. No licenses are granted by implication, estoppel or
3363  * otherwise under any patents or trademarks of Freescale
3364  * Semiconductor, Inc. This software is provided on an "AS IS"
3365  * basis and without warranty.
3366  *
3367  * To the maximum extent permitted by applicable law, Freescale
3368  * Semiconductor DISCLAIMS ALL WARRANTIES WHETHER EXPRESS OR IMPLIED,
3369  * INCLUDING IMPLIED WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A
3370  * PARTICULAR PURPOSE AND ANY WARRANTY AGAINST INFRINGEMENT WITH
3371  * REGARD TO THE SOFTWARE (INCLUDING ANY MODIFIED VERSIONS THEREOF)
3372  * AND ANY ACCOMPANYING WRITTEN MATERIALS.
3373  *
3374  * To the maximum extent permitted by applicable law, IN NO EVENT
3375  * SHALL Freescale Semiconductor BE LIABLE FOR ANY DAMAGES WHATSOEVER
3376  * (INCLUDING WITHOUT LIMITATION, DAMAGES FOR LOSS OF BUSINESS PROFITS,
3377  * BUSINESS INTERRUPTION, LOSS OF BUSINESS INFORMATION, OR OTHER
3378  * PECUNIARY LOSS) ARISING OF THE USE OR INABILITY TO USE THE SOFTWARE.
3379  *
3380  * Freescale Semiconductor assumes no responsibility for the
3381  * maintenance and support of this software
3382  *
3383  ********************************************************************/
Definition: fsl-mpc551x.h:1488
Definition: fsl-mpc555x.h:1982
Definition: fsl-mpc555x.h:2451
Definition: fsl-mpc551x.h:899
Definition: fsl-mpc555x.h:3266
Definition: fsl-mpc555x.h:2465
Definition: fsl-mpc564xL.h:16627
Definition: fsl-mpc555x.h:124
Definition: fsl-mpc551x.h:447
Definition: fsl-mpc551x.h:1484
Definition: fsl-mpc564xL.h:16586
Definition: fsl-mpc564xL.h:966
Definition: fsl-mpc555x.h:2999
Definition: fsl-mpc564xL.h:16678
Definition: fsl-mpc551x.h:716
Definition: fsl-mpc555x.h:1136
Definition: fsl-mpc555x.h:404
Definition: fsl-mpc564xL.h:16605
Definition: fsl-mpc551x.h:244
Definition: fsl-mpc564xL.h:16698
Definition: fsl-mpc551x.h:2221
Definition: fsl-mpc551x.h:483
Definition: fsl-mpc555x.h:2179
Definition: fsl-mpc555x.h:2652
Definition: fsl-mpc555x.h:236
Definition: fsl-mpc551x.h:1603
Definition: fsl-mpc551x.h:1027
Definition: fsl-mpc555x.h:2486
Definition: fsl-mpc564xL.h:16541
Definition: fsl-mpc551x.h:479
Definition: fsl-mpc555x.h:2634
Definition: fsl-mpc551x.h:531
