RTEMS  5.1
frame_buffer.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
37 #ifndef _FRAME_BUFFER_
38 #define _FRAME_BUFFER_
39
40 /*----------------------------------------------------------------------------
41  * Exported functions
42  *----------------------------------------------------------------------------*/
43
44 extern void FB_SetFrameBuffer(
45  LcdColor_t *pBuffer,
46  uint8_t ucWidth,
47  uint8_t ucHeight);
48
49 extern void FB_SetColor(uint32_t color);
50
51 extern uint32_t FB_DrawLine (
52  uint32_t dwX1,
53  uint32_t dwY1,
54  uint32_t dwX2,
55  uint32_t dwY2);
56
57 extern uint32_t FB_DrawPixel(uint32_t x, uint32_t y);
58 extern uint32_t FB_DrawCircle(uint32_t x, uint32_t y, uint32_t r);
59 extern uint32_t FB_DrawFilledCircle(
60  uint32_t dwX,
61  uint32_t dwY,
62  uint32_t dwRadius);
63
64 extern uint32_t FB_DrawRectangle(
65  uint32_t dwX1,
66  uint32_t dwY1,
67  uint32_t dwX2,
68  uint32_t dwY2);
69
70 extern uint32_t FB_DrawFilledRectangle(
71  uint32_t dwX1,
72  uint32_t dwY1,
73  uint32_t dwX2,
74  uint32_t dwY2);
75
76 extern uint32_t FB_DrawPicture(
77  uint32_t dwX1,
78  uint32_t dwY1,
79  uint32_t dwX2,
80  uint32_t dwY2,
81  const void *pBuffer);
82
83 #endif /* #ifndef _FRAME_BUFFER_ */
