RTEMS  5.1
fb_vesa.h
1
9 /*
10  * Copyright (C) 2014 Jan Doležal (dolezj21@fel.cvut.cz)
11  * CTU in Prague.
12  *
13  * The license and distribution terms for this file may be
14  * found in the file LICENSE in this distribution or at
15  * http://www.rtems.org/license/LICENSE.
16  */
17
18 #include <bsp/vbe3.h>
19 #include <edid.h>
20
21 #ifndef _FB_VESA_H
22 #define _FB_VESA_H
23
24 #ifndef ASM /* ASM */
25
26 #include <stdint.h>
27
28 #ifdef __cplusplus
29 extern "C" {
30 #endif /* __cplusplus */
31
32
33 /* ----- Prototypes ----- */
34
48  VBE_vbe_info_block *info_block,
49  uint16_t queried_VBE_Version
50 );
51
62 uint32_t VBE_mode_information (
63  VBE_mode_info_block *info_block,
64  uint16_t mode_number
65 );
66
76 uint32_t VBE_set_mode (
77  uint16_t mode_number,
78  VBE_CRTC_info_block *info_block
79 );
80
88 uint32_t VBE_current_mode (
89  uint16_t *mode_number
90 );
91
105  uint16_t controller_unit_number,
106  uint8_t *seconds_to_transfer_EDID_block,
107  uint8_t *DDC_level_supported
108 );
109
120 uint32_t VBE_read_EDID (
121  uint16_t controller_unit_number,
122  uint16_t EDID_block_number,
123  EDID_edid1 *buffer
124 );
125
126 #ifdef __cplusplus
127 }
128 #endif /* __cplusplus */
129
130 #endif /* ASM */
131
132 #endif /* _FB_VESA_H */
uint32_t VBE_mode_information(VBE_mode_info_block *info_block, uint16_t mode_number)
Fills structure info_block with informations about selected mode in mode_number variable.
Definition: fb_vesa_rm.c:133
VESA EDID definitions.
uint32_t VBE_set_mode(uint16_t mode_number, VBE_CRTC_info_block *info_block)
Sets graphics mode selected. If mode has refreshRateCtrl bit set, than the info_block must be filled ...
Definition: fb_vesa_rm.c:156
uint32_t VBE_controller_information(VBE_vbe_info_block *info_block, uint16_t queried_VBE_Version)
Returns information about graphic's controller in the info_block structure.
Definition: fb_vesa_rm.c:102
VESA Bios Extension definitions.
uint32_t VBE_report_DDC_capabilities(uint16_t controller_unit_number, uint8_t *seconds_to_transfer_EDID_block, uint8_t *DDC_level_supported)
Gets information about display data channel implemented in the graphic's controller.
Definition: fb_vesa_rm.c:186
uint32_t VBE_current_mode(uint16_t *mode_number)
Get currently set mode number.
Definition: fb_vesa_rm.c:176
uint32_t VBE_read_EDID(uint16_t controller_unit_number, uint16_t EDID_block_number, EDID_edid1 *buffer)
Reads selected EDID block from display attached to controller's interface.
Definition: fb_vesa_rm.c:203
