RTEMS  5.1
extern-cp.h
1 /* $NetBSD: extern.h,v 1.12 2005/10/15 18:22:18 christos Exp $ */
2
3 /*-
4  * Copyright (c) 1991, 1993, 1994
5  * The Regents of the University of California. All rights reserved.
6  *
7  * Redistribution and use in source and binary forms, with or without
8  * modification, are permitted provided that the following conditions
9  * are met:
10  * 1. Redistributions of source code must retain the above copyright
11  * notice, this list of conditions and the following disclaimer.
12  * 2. Redistributions in binary form must reproduce the above copyright
13  * notice, this list of conditions and the following disclaimer in the
14  * documentation and/or other materials provided with the distribution.
15  * 3. Neither the name of the University nor the names of its contributors
16  * may be used to endorse or promote products derived from this software
17  * without specific prior written permission.
18  *
19  * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
20  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
21  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
22  * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
23  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
24  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
25  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
26  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
27  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
28  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
29  * SUCH DAMAGE.
30  *
31  * @(#)extern.h 8.2 (Berkeley) 4/1/94
32  */
33
34 #ifndef _EXTERN_CP_H_
35 #define _EXTERN_CP_H_
36
37 #define PATH_T RTEMS_SHELL_CP_PATH_T
38
39 typedef struct {
40  char *p_end; /* pointer to NULL at end of path */
41  char *target_end; /* pointer to end of target base */
42  char p_path[MAXPATHLEN + 1]; /* pointer to the start of a path */
43 } PATH_T;
44
45 #include <setjmp.h>
46 #include <rtems.h>
47
48 typedef struct {
49  PATH_T to;
50  int info;
51  uid_t myuid;
52  int fflag, iflag, lflag, nflag, pflag, vflag;
53  mode_t myumask;
54  jmp_buf exit_jmp;
56
57 #define to cp_globals->to
58 #define info cp_globals->info
59 #define myuid cp_globals->myuid
60 #define fflag cp_globals->fflag
61 #define iflag cp_globals->iflag
62 #define lflag cp_globals->lflag
63 #define nflag cp_globals->nflag
64 #define pflag cp_globals->pflag
65 #define vflag cp_globals->vflag
66 #define myumask cp_globals->myumask
67 #define exit_jump &(cp_globals->exit_jmp)
68
69 #define copy_fifo rtems_shell_cp_copy_fifo
70 #define copy_file rtems_shell_cp_copy_file
71 #define copy_link rtems_shell_cp_copy_link
72 #define copy_special rtems_shell_cp_copy_special
73 #define set_utimes rtems_shell_cp_set_utimes
74 #define setfile rtems_shell_cp_setfile
75 #define usage rtems_shell_cp_usage
76
77 #include <sys/cdefs.h>
78
79 __BEGIN_DECLS
80 int copy_fifo(rtems_shell_cp_globals* cp_globals, struct stat *, int);
81 int copy_file(rtems_shell_cp_globals* cp_globals, FTSENT *, int);
82 int copy_link(rtems_shell_cp_globals* cp_globals, FTSENT *, int);
83 int copy_special(rtems_shell_cp_globals* cp_globals, struct stat *, int);
84 int set_utimes(const char *, struct stat *);
85 int setfile(rtems_shell_cp_globals* cp_globals, struct stat *, int);
86 int preserve_dir_acls(struct stat *, char *, char *);
87 int preserve_fd_acls(int, int);
88 void usage(rtems_shell_cp_globals* cp_globals);
89
90 __END_DECLS
91
92 #endif /* !_EXTERN_H_ */
Definition: extern-cp.h:39
Definition: extern-cp.h:48
Definition: fts.h:74
