RTEMS  5.1
Typedefs | Functions
extension.h File Reference
User Extensions API. More...
#include <rtems/score/userext.h>
typedef User_extensions_routine rtems_extension RTEMS_DEPRECATED
typedef User_extensions_thread_create_extension rtems_task_create_extension
typedef User_extensions_thread_delete_extension rtems_task_delete_extension
typedef User_extensions_thread_start_extension rtems_task_start_extension
typedef User_extensions_thread_restart_extension rtems_task_restart_extension
typedef User_extensions_thread_switch_extension rtems_task_switch_extension
typedef User_extensions_thread_begin_extension rtems_task_begin_extension
typedef User_extensions_thread_exitted_extension rtems_task_exitted_extension
typedef User_extensions_fatal_extension rtems_fatal_extension
typedef User_extensions_thread_terminate_extension rtems_task_terminate_extension
typedef User_extensions_Table rtems_extensions_table
typedef Internal_errors_Source rtems_fatal_source
typedef Internal_errors_t rtems_fatal_code
rtems_status_code rtems_extension_create (rtems_name name, const rtems_extensions_table *extension_table, rtems_id *id)
 Creates an extension set object. More...
rtems_status_code rtems_extension_ident (rtems_name name, rtems_id *id)
 Identifies an extension set object by a name. More...
rtems_status_code rtems_extension_delete (rtems_id id)
 Deletes an extension set object specified by the identifier id. More...
