RTEMS  5.1
efc.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
51 #ifndef _EEFC_
52 #define _EEFC_
53
54 /*----------------------------------------------------------------------------
55  * Headers
56  *----------------------------------------------------------------------------*/
57 #include "chip.h"
58
59 #include <stdint.h>
60
61 /*----------------------------------------------------------------------------
62  * Definitions
63  *----------------------------------------------------------------------------*/
64 /* TODO: Temporary definition for missing symbol in header file */
65 #define IFLASH_SECTOR_SIZE 65536u
66
67
68 /* EFC command */
69 #define EFC_FCMD_GETD 0x00 /* Get Flash Descriptor */
70 #define EFC_FCMD_WP 0x01 /* Write page */
71 #define EFC_FCMD_WPL 0x02 /* Write page and lock */
72 #define EFC_FCMD_EWP 0x03 /* Erase page and write page */
73 #define EFC_FCMD_EWPL 0x04 /* Erase page and write page then lock */
74 #define EFC_FCMD_EA 0x05 /* Erase all */
75 #define EFC_FCMD_EPA 0x07 /* Erase pages */
76 #define EFC_FCMD_SLB 0x08 /* Set Lock Bit */
77 #define EFC_FCMD_CLB 0x09 /* Clear Lock Bit */
78 #define EFC_FCMD_GLB 0x0A /* Get Lock Bit */
79 #define EFC_FCMD_SFB 0x0B /* Set GPNVM Bit */
80 #define EFC_FCMD_CFB 0x0C /* Clear GPNVM Bit */
81 #define EFC_FCMD_GFB 0x0D /* Get GPNVM Bit */
82 #define EFC_FCMD_STUI 0x0E /* Start unique ID */
83 #define EFC_FCMD_SPUI 0x0F /* Stop unique ID */
84 #define EFC_FCMD_GCALB 0x10 /* Get CALIB Bit */
85 #define EFC_FCMD_ES 0x11 /* Erase Sector */
86 #define EFC_FCMD_WUS 0x12 /* Write User Signature */
87 #define EFC_FCMD_EUS 0x13 /* Erase User Signature */
88 #define EFC_FCMD_STUS 0x14 /* Start Read User Signature */
89 #define EFC_FCMD_SPUS 0x15 /* Stop Read User Signature */
90
91 /* The IAP function entry address */
92 #define CHIP_FLASH_IAP_ADDRESS (0x00800008)
93
94 #ifdef __cplusplus
95 extern "C" {
96 #endif
97
98 /*----------------------------------------------------------------------------
99  * Exported functions
100  *----------------------------------------------------------------------------*/
101
102 extern void EFC_EnableFrdyIt(Efc *efc);
103
104 extern void EFC_DisableFrdyIt(Efc *efc);
105
106 extern void EFC_SetWaitState(Efc *efc, uint8_t cycles);
107
108 extern void EFC_TranslateAddress(Efc **pEfc, uint32_t dwAddress,
109  uint16_t *pwPage, uint16_t *pwOffset);
110
111 extern void EFC_ComputeAddress(Efc *efc, uint16_t wPage, uint16_t wOffset,
112  uint32_t *pdwAddress);
113
114 extern uint32_t EFC_PerformCommand(Efc *efc, uint32_t dwCommand,
115  uint32_t dwArgument, uint32_t dwUseIAP);
116
117 extern uint32_t EFC_GetStatus(Efc *efc);
118
119 extern uint32_t EFC_GetResult(Efc *efc);
120
121 extern void EFC_SetFlashAccessMode(Efc *efc, uint32_t dwMode);
122
123 #ifdef __cplusplus
124 }
125 #endif
126
127 #endif /* #ifndef _EEFC_ */
128
Disables the flash ready interrupt source on the EEFC peripheral.
Definition: efc.c:124
Returns the result of the last executed command.
Definition: efc.c:167
Efc hardware registers.
Definition: component_efc.h:41
void EFC_ComputeAddress(Efc *efc, uint16_t wPage, uint16_t wOffset, uint32_t *pdwAddress)
Computes the address of a flash access given the page and offset.
Definition: efc.c:210
Returns the current status of the EEFC.
Definition: efc.c:157
Enables the flash ready interrupt source on the EEFC peripheral.
Definition: efc.c:111
Set flash access mode.
Definition: efc.c:273
uint32_t EFC_PerformCommand(Efc *efc, uint32_t dwCommand, uint32_t dwArgument, uint32_t dwUseIAP)
Performs the given command and wait until its completion (or an error).
Definition: efc.c:238
Set read/write wait state on the EEFC peripheral.
Definition: efc.c:139
void EFC_TranslateAddress(Efc **pEfc, uint32_t dwAddress, uint16_t *pwPage, uint16_t *pwOffset)
Translates the given address page and offset values.
Definition: efc.c:182
