RTEMS  5.1
dosfs.h
1
9 /*
10  * Copyright (C) 2001 OKTET Ltd., St.-Petersburg, Russia
11  * Author: Eugeny S. Mints <Eugeny.Mints@oktet.ru>
12  *
13  * Modifications to support UTF-8 in the file system are
14  * Copyright (c) 2013 embedded brains GmbH.
15  *
16  * The license and distribution terms for this file may be
17  * found in the file LICENSE in this distribution or at
18  * http://www.rtems.org/license/LICENSE.
19  */
20
21 #ifndef _RTEMS_DOSFS_H
22 #define _RTEMS_DOSFS_H
23
24 #include <rtems.h>
25 #include <rtems/libio.h>
26
27 #ifdef __cplusplus
28 extern "C" {
29 #endif
30
32
49  const uint8_t *src,
50  size_t src_size,
51  char *dst,
52  size_t *dst_size
53 );
54
71  const char *src,
72  size_t src_size,
73  uint8_t *dst,
74  size_t *dst_size
75 );
76
93  const uint8_t *src,
94  size_t src_size,
95  uint16_t *dst,
96  size_t *dst_size
97 );
98
115  const uint16_t *src,
116  size_t src_size,
117  uint8_t *dst,
118  size_t *dst_size
119 );
120
143  const uint8_t *src,
144  size_t src_size,
145  uint8_t *dst,
146  size_t *dst_size
147 );
148
156 );
157
161 typedef struct {
162  rtems_dosfs_utf8_to_codepage utf8_to_codepage;
163  rtems_dosfs_codepage_to_utf8 codepage_to_utf8;
164  rtems_dosfs_utf8_to_utf16 utf8_to_utf16;
165  rtems_dosfs_utf16_to_utf8 utf16_to_utf8;
166  rtems_dosfs_utf8_normalize_and_fold utf8_normalize_and_fold;
169
170 typedef struct {
171  void *data;
172  size_t size;
174
183  const rtems_dosfs_convert_handler *handler;
184  rtems_dosfs_buffer buffer;
185 };
186
208 #define RTEMS_DOSFS_SEMAPHORES_PER_INSTANCE 1
209
213 typedef struct {
298
315
342  const char *codepage
343 );
344
345 #define MSDOS_FMT_INFO_LEVEL_NONE (0)
346 #define MSDOS_FMT_INFO_LEVEL_INFO (1)
347 #define MSDOS_FMT_INFO_LEVEL_DETAIL (2)
348 #define MSDOS_FMT_INFO_LEVEL_DEBUG (3)
349
353 typedef struct {
357  const char *OEMName;
358
362  const char *VolLabel;
363
370
376  uint32_t fat_num;
377
384
390  uint8_t media;
391
398
404
409
415
426 int msdos_format (
427  const char *devname,
428  const msdos_format_request_param_t *rqdata
429 );
430
433 int rtems_dosfs_initialize(rtems_filesystem_mount_table_entry_t *mt_entry,
434  const void *data);
435
436 #ifdef __cplusplus
437 }
438 #endif
439
440 #endif
Basic IO API.
const char * OEMName
OEM name string or NULL.
Definition: dosfs.h:357
int info_level
The amount of info to output.
Definition: dosfs.h:413
bool sync_device
Synchronize device after write operations.
Definition: dosfs.h:408
int(* rtems_dosfs_utf8_to_utf16)(rtems_dosfs_convert_control *self, const uint8_t *src, size_t src_size, uint16_t *dst, size_t *dst_size)
Converts from UTF-8 to UTF-16.
Definition: dosfs.h:91
uint32_t sectors_per_cluster
Sectors per cluster hint.
Definition: dosfs.h:369
void(* rtems_dosfs_convert_destroy)(rtems_dosfs_convert_control *self)
Destroys a convert control structure.
Definition: dosfs.h:154
rtems_dosfs_convert_control * converter
Converter implementation for new file system instance.
Definition: dosfs.h:296
FAT filesystem convert handler.
Definition: dosfs.h:161
FAT filesystem convert control.
Definition: dosfs.h:182
FAT file system format request parameters.
Definition: dosfs.h:353
uint8_t media
Media code.
Definition: dosfs.h:390
bool quick_format
Quick format.
Definition: dosfs.h:397
uint32_t fat_num
Number of FATs hint.
Definition: dosfs.h:376
FAT filesystem mount options.
Definition: dosfs.h:213
int(* rtems_dosfs_utf8_normalize_and_fold)(rtems_dosfs_convert_control *self, const uint8_t *src, size_t src_size, uint8_t *dst, size_t *dst_size)
Converts from UTF-8 to Normalized Form Canonical Decomposition.
Definition: dosfs.h:141
bool skip_alignment
Do not align FAT, data cluster, and root directory to a cluster boundary.
Definition: dosfs.h:403
Mount table entry.
Definition: libio.h:1604
rtems_dosfs_convert_control * rtems_dosfs_create_default_converter(void)
Allocates and initializes a default converter.
Definition: msdos_conv_default.c:176
int msdos_format(const char *devname, const msdos_format_request_param_t *rqdata)
Formats a block device with a FAT file system.
Definition: msdos_format.c:991
int(* rtems_dosfs_utf16_to_utf8)(rtems_dosfs_convert_control *self, const uint16_t *src, size_t src_size, uint8_t *dst, size_t *dst_size)
Converts from UTF-16 to UTF-8.
Definition: dosfs.h:113
rtems_dosfs_convert_control * rtems_dosfs_create_utf8_converter(const char *codepage)
Allocates and initializes a UTF-8 converter.
Definition: msdos_conv_utf8.c:289
const char * VolLabel
Volume label string or NULL.
Definition: dosfs.h:362
uint32_t files_per_root_dir
Minimum files in root directory for FAT12 and FAT16.
Definition: dosfs.h:383
unsigned size
Definition: tte.h:74
int(* rtems_dosfs_utf8_to_codepage)(rtems_dosfs_convert_control *self, const uint8_t *src, size_t src_size, char *dst, size_t *dst_size)
Converts from UTF-8 into a specific code page.
Definition: dosfs.h:47
int(* rtems_dosfs_codepage_to_utf8)(rtems_dosfs_convert_control *self, const char *src, size_t src_size, uint8_t *dst, size_t *dst_size)
Converts from a specific code page into UTF-8.
Definition: dosfs.h:69
Definition: dosfs.h:170
