RTEMS  5.1
deflate.h
1 /* deflate.h -- internal compression state
2  * Copyright (C) 1995-2010 Jean-loup Gailly
3  * For conditions of distribution and use, see copyright notice in zlib.h
4  */
5
6 /* WARNING: this file should *not* be used by applications. It is
7  part of the implementation of the compression library and is
8  subject to change. Applications should only use zlib.h.
9  */
10
11 #ifndef DEFLATE_H
12 #define DEFLATE_H
13
14 #include "zutil.h"
15
16 /* define NO_GZIP when compiling if you want to disable gzip header and
17  trailer creation by deflate(). NO_GZIP would be used to avoid linking in
18  the crc code when it is not needed. For shared libraries, gzip encoding
19  should be left enabled. */
20 #ifndef NO_GZIP
21 # define GZIP
22 #endif
23
24 /* ===========================================================================
25  * Internal compression state.
26  */
27
28 #define LENGTH_CODES 29
29 /* number of length codes, not counting the special END_BLOCK code */
30
31 #define LITERALS 256
32 /* number of literal bytes 0..255 */
33
34 #define L_CODES (LITERALS+1+LENGTH_CODES)
35 /* number of Literal or Length codes, including the END_BLOCK code */
36
37 #define D_CODES 30
38 /* number of distance codes */
39
40 #define BL_CODES 19
41 /* number of codes used to transfer the bit lengths */
42
43 #define HEAP_SIZE (2*L_CODES+1)
44 /* maximum heap size */
45
46 #define MAX_BITS 15
47 /* All codes must not exceed MAX_BITS bits */
48
49 #define INIT_STATE 42
50 #define EXTRA_STATE 69
51 #define NAME_STATE 73
52 #define COMMENT_STATE 91
53 #define HCRC_STATE 103
54 #define BUSY_STATE 113
55 #define FINISH_STATE 666
56 /* Stream status */
57
58
59 /* Data structure describing a single value and its code string. */
60 typedef struct ct_data_s {
61  union {
62  ush freq; /* frequency count */
63  ush code; /* bit string */
64  } fc;
65  union {
66  ush dad; /* father node in Huffman tree */
67  ush len; /* length of bit string */
68  } dl;
69 } FAR ct_data;
70
71 #define Freq fc.freq
72 #define Code fc.code
73 #define Dad dl.dad
74 #define Len dl.len
75
77
78 typedef struct tree_desc_s {
79  ct_data *dyn_tree; /* the dynamic tree */
80  int max_code; /* largest code with non zero frequency */
81  static_tree_desc *stat_desc; /* the corresponding static tree */
82 } FAR tree_desc;
83
84 typedef ush Pos;
85 typedef Pos FAR Posf;
86 typedef unsigned IPos;
87
88 /* A Pos is an index in the character window. We use short instead of int to
89  * save space in the various tables. IPos is used only for parameter passing.
90  */
91
92 typedef struct internal_state {
93  z_streamp strm; /* pointer back to this zlib stream */
94  int status; /* as the name implies */
95  Bytef *pending_buf; /* output still pending */
96  ulg pending_buf_size; /* size of pending_buf */
97  Bytef *pending_out; /* next pending byte to output to the stream */
98  uInt pending; /* nb of bytes in the pending buffer */
99  int wrap; /* bit 0 true for zlib, bit 1 true for gzip */
100  gz_headerp gzhead; /* gzip header information to write */
101  uInt gzindex; /* where in extra, name, or comment */
102  Byte method; /* STORED (for zip only) or DEFLATED */
103  int last_flush; /* value of flush param for previous deflate call */
104
105  /* used by deflate.c: */
106
107  uInt w_size; /* LZ77 window size (32K by default) */
108  uInt w_bits; /* log2(w_size) (8..16) */
109  uInt w_mask; /* w_size - 1 */
110
111  Bytef *window;
112  /* Sliding window. Input bytes are read into the second half of the window,
113  * and move to the first half later to keep a dictionary of at least wSize
114  * bytes. With this organization, matches are limited to a distance of
115  * wSize-MAX_MATCH bytes, but this ensures that IO is always
116  * performed with a length multiple of the block size. Also, it limits
117  * the window size to 64K, which is quite useful on MSDOS.
118  * To do: use the user input buffer as sliding window.
119  */
120
121  ulg window_size;
122  /* Actual size of window: 2*wSize, except when the user input buffer
123  * is directly used as sliding window.
124  */
125
126  Posf *prev;
127  /* Link to older string with same hash index. To limit the size of this
128  * array to 64K, this link is maintained only for the last 32K strings.
129  * An index in this array is thus a window index modulo 32K.
130  */
131
132  Posf *head; /* Heads of the hash chains or NIL. */
133
134  uInt ins_h; /* hash index of string to be inserted */
135  uInt hash_size; /* number of elements in hash table */
136  uInt hash_bits; /* log2(hash_size) */
137  uInt hash_mask; /* hash_size-1 */
138
139  uInt hash_shift;
140  /* Number of bits by which ins_h must be shifted at each input
141  * step. It must be such that after MIN_MATCH steps, the oldest
142  * byte no longer takes part in the hash key, that is:
143  * hash_shift * MIN_MATCH >= hash_bits
144  */
145
146  long block_start;
147  /* Window position at the beginning of the current output block. Gets
148  * negative when the window is moved backwards.
149  */
150
151  uInt match_length; /* length of best match */
152  IPos prev_match; /* previous match */
153  int match_available; /* set if previous match exists */
154  uInt strstart; /* start of string to insert */
155  uInt match_start; /* start of matching string */
156  uInt lookahead; /* number of valid bytes ahead in window */
157
158  uInt prev_length;
159  /* Length of the best match at previous step. Matches not greater than this
160  * are discarded. This is used in the lazy match evaluation.
161  */
162
163  uInt max_chain_length;
164  /* To speed up deflation, hash chains are never searched beyond this
165  * length. A higher limit improves compression ratio but degrades the
166  * speed.
167  */
168
169  uInt max_lazy_match;
170  /* Attempt to find a better match only when the current match is strictly
171  * smaller than this value. This mechanism is used only for compression
172  * levels >= 4.
173  */
174 # define max_insert_length max_lazy_match
175  /* Insert new strings in the hash table only if the match length is not
176  * greater than this length. This saves time but degrades compression.
177  * max_insert_length is used only for compression levels <= 3.
178  */
179
180  int level; /* compression level (1..9) */
181  int strategy; /* favor or force Huffman coding*/
182
183  uInt good_match;
184  /* Use a faster search when the previous match is longer than this */
185
186  int nice_match; /* Stop searching when current match exceeds this */
187
188  /* used by trees.c: */
189  /* Didn't use ct_data typedef below to supress compiler warning */
190  struct ct_data_s dyn_ltree[HEAP_SIZE]; /* literal and length tree */
191  struct ct_data_s dyn_dtree[2*D_CODES+1]; /* distance tree */
192  struct ct_data_s bl_tree[2*BL_CODES+1]; /* Huffman tree for bit lengths */
193
194  struct tree_desc_s l_desc; /* desc. for literal tree */
195  struct tree_desc_s d_desc; /* desc. for distance tree */
196  struct tree_desc_s bl_desc; /* desc. for bit length tree */
197
198  ush bl_count[MAX_BITS+1];
199  /* number of codes at each bit length for an optimal tree */
200
201  int heap[2*L_CODES+1]; /* heap used to build the Huffman trees */
202  int heap_len; /* number of elements in the heap */
203  int heap_max; /* element of largest frequency */
204  /* The sons of heap[n] are heap[2*n] and heap[2*n+1]. heap[0] is not used.
205  * The same heap array is used to build all trees.
206  */
207
208  uch depth[2*L_CODES+1];
209  /* Depth of each subtree used as tie breaker for trees of equal frequency
210  */
211
212  uchf *l_buf; /* buffer for literals or lengths */
213
214  uInt lit_bufsize;
215  /* Size of match buffer for literals/lengths. There are 4 reasons for
216  * limiting lit_bufsize to 64K:
217  * - frequencies can be kept in 16 bit counters
218  * - if compression is not successful for the first block, all input
219  * data is still in the window so we can still emit a stored block even
220  * when input comes from standard input. (This can also be done for
221  * all blocks if lit_bufsize is not greater than 32K.)
222  * - if compression is not successful for a file smaller than 64K, we can
223  * even emit a stored file instead of a stored block (saving 5 bytes).
224  * This is applicable only for zip (not gzip or zlib).
225  * - creating new Huffman trees less frequently may not provide fast
226  * adaptation to changes in the input data statistics. (Take for
227  * example a binary file with poorly compressible code followed by
228  * a highly compressible string table.) Smaller buffer sizes give
229  * fast adaptation but have of course the overhead of transmitting
230  * trees more frequently.
231  * - I can't count above 4
232  */
233
234  uInt last_lit; /* running index in l_buf */
235
236  ushf *d_buf;
237  /* Buffer for distances. To simplify the code, d_buf and l_buf have
238  * the same number of elements. To use different lengths, an extra flag
239  * array would be necessary.
240  */
241
242  ulg opt_len; /* bit length of current block with optimal trees */
243  ulg static_len; /* bit length of current block with static trees */
244  uInt matches; /* number of string matches in current block */
245  int last_eob_len; /* bit length of EOB code for last block */
246
247 #ifdef DEBUG
248  ulg compressed_len; /* total bit length of compressed file mod 2^32 */
249  ulg bits_sent; /* bit length of compressed data sent mod 2^32 */
250 #endif
251
252  ush bi_buf;
253  /* Output buffer. bits are inserted starting at the bottom (least
254  * significant bits).
255  */
256  int bi_valid;
257  /* Number of valid bits in bi_buf. All bits above the last valid bit
258  * are always zero.
259  */
260
261  ulg high_water;
262  /* High water mark offset in window for initialized bytes -- bytes above
263  * this are set to zero in order to avoid memory check warnings when
264  * longest match routines access bytes past the input. This is then
265  * updated to the new high water mark.
266  */
267
268 } FAR deflate_state;
269
270 /* Output a byte on the stream.
271  * IN assertion: there is enough room in pending_buf.
272  */
273 #define put_byte(s, c) {s->pending_buf[s->pending++] = (c);}
274
275
276 #define MIN_LOOKAHEAD (MAX_MATCH+MIN_MATCH+1)
277 /* Minimum amount of lookahead, except at the end of the input file.
278  * See deflate.c for comments about the MIN_MATCH+1.
279  */
280
281 #define MAX_DIST(s) ((s)->w_size-MIN_LOOKAHEAD)
282 /* In order to simplify the code, particularly on 16 bit machines, match
283  * distances are limited to MAX_DIST instead of WSIZE.
284  */
285
286 #define WIN_INIT MAX_MATCH
287 /* Number of bytes after end of data in window to initialize in order to avoid
288  memory checker errors from longest match routines */
289
290  /* in trees.c */
291 void ZLIB_INTERNAL _tr_init OF((deflate_state *s));
292 int ZLIB_INTERNAL _tr_tally OF((deflate_state *s, unsigned dist, unsigned lc));
293 void ZLIB_INTERNAL _tr_flush_block OF((deflate_state *s, charf *buf,
294  ulg stored_len, int last));
295 void ZLIB_INTERNAL _tr_align OF((deflate_state *s));
296 void ZLIB_INTERNAL _tr_stored_block OF((deflate_state *s, charf *buf,
297  ulg stored_len, int last));
298
299 #define d_code(dist) \
300  ((dist) < 256 ? _dist_code[dist] : _dist_code[256+((dist)>>7)])
301 /* Mapping from a distance to a distance code. dist is the distance - 1 and
302  * must not have side effects. _dist_code[256] and _dist_code[257] are never
303  * used.
304  */
305
306 #ifndef DEBUG
307 /* Inline versions of _tr_tally for speed: */
308
309 #if defined(GEN_TREES_H) || !defined(STDC)
310  extern uch ZLIB_INTERNAL _length_code[];
311  extern uch ZLIB_INTERNAL _dist_code[];
312 #else
313  extern const uch ZLIB_INTERNAL _length_code[];
314  extern const uch ZLIB_INTERNAL _dist_code[];
315 #endif
316
317 # define _tr_tally_lit(s, c, flush) \
318  { uch cc = (c); \
319  s->d_buf[s->last_lit] = 0; \
320  s->l_buf[s->last_lit++] = cc; \
321  s->dyn_ltree[cc].Freq++; \
322  flush = (s->last_lit == s->lit_bufsize-1); \
323  }
324 # define _tr_tally_dist(s, distance, length, flush) \
325  { uch len = (length); \
326  ush dist = (distance); \
327  s->d_buf[s->last_lit] = dist; \
328  s->l_buf[s->last_lit++] = len; \
329  dist--; \
330  s->dyn_ltree[_length_code[len]+LITERALS+1].Freq++; \
331  s->dyn_dtree[d_code(dist)].Freq++; \
332  flush = (s->last_lit == s->lit_bufsize-1); \
333  }
334 #else
335 # define _tr_tally_lit(s, c, flush) flush = _tr_tally(s, 0, c)
336 # define _tr_tally_dist(s, distance, length, flush) \
337  flush = _tr_tally(s, distance, length)
338 #endif
339
340 #endif /* DEFLATE_H */
Definition: deflate.c:153
Definition: deflate.h:78
Definition: inftrees.h:24
Definition: zlib.c:264
Definition: deflate.h:60
Definition: clnt_tcp.c:94
