RTEMS  5.1
debug.h
1 /*
2  * JFFS2 -- Journalling Flash File System, Version 2.
3  *
4  * Copyright © 2001-2007 Red Hat, Inc.
5  * Copyright © 2004-2010 David Woodhouse <dwmw2@infradead.org>
6  *
7  * Created by David Woodhouse <dwmw2@infradead.org>
8  *
9  * For licensing information, see the file 'LICENCE' in this directory.
10  *
11  */
12
13 #ifndef _JFFS2_DEBUG_H_
14 #define _JFFS2_DEBUG_H_
15
16 #include <linux/sched.h>
17
18 #ifndef CONFIG_JFFS2_FS_DEBUG
19 #define CONFIG_JFFS2_FS_DEBUG 0
20 #endif
21
22 #if CONFIG_JFFS2_FS_DEBUG > 0
23 /* Enable "paranoia" checks and dumps */
24 #define JFFS2_DBG_PARANOIA_CHECKS
25 #define JFFS2_DBG_DUMPS
26
27 /*
28  * By defining/undefining the below macros one may select debugging messages
29  * fro specific JFFS2 subsystems.
30  */
31 #define JFFS2_DBG_READINODE_MESSAGES
32 #define JFFS2_DBG_FRAGTREE_MESSAGES
33 #define JFFS2_DBG_DENTLIST_MESSAGES
34 #define JFFS2_DBG_NODEREF_MESSAGES
35 #define JFFS2_DBG_INOCACHE_MESSAGES
36 #define JFFS2_DBG_SUMMARY_MESSAGES
37 #define JFFS2_DBG_FSBUILD_MESSAGES
38 #endif
39
40 #if CONFIG_JFFS2_FS_DEBUG > 1
41 #define JFFS2_DBG_FRAGTREE2_MESSAGES
42 #define JFFS2_DBG_READINODE2_MESSAGES
43 #define JFFS2_DBG_MEMALLOC_MESSAGES
44 #endif
45
46 /* Sanity checks are supposed to be light-weight and enabled by default */
47 #define JFFS2_DBG_SANITY_CHECKS
48
49 /*
50  * Dx() are mainly used for debugging messages, they must go away and be
51  * superseded by nicer dbg_xxx() macros...
52  */
53 #if CONFIG_JFFS2_FS_DEBUG > 0
54 #define DEBUG
55 #define D1(x) x
56 #else
57 #define D1(x)
58 #endif
59
60 #if CONFIG_JFFS2_FS_DEBUG > 1
61 #define D2(x) x
62 #else
63 #define D2(x)
64 #endif
65
66 #define jffs2_dbg(level, fmt, ...) \
67 do { \
68  if (CONFIG_JFFS2_FS_DEBUG >= level) \
69  pr_debug(fmt, ##__VA_ARGS__); \
70 } while (0)
71
72 /* The prefixes of JFFS2 messages */
73 #define JFFS2_DBG KERN_DEBUG
74 #define JFFS2_DBG_PREFIX "[JFFS2 DBG]"
75 #define JFFS2_DBG_MSG_PREFIX JFFS2_DBG JFFS2_DBG_PREFIX
76
77 /* JFFS2 message macros */
78 #ifndef __rtems__
79 #define JFFS2_ERROR(fmt, ...) \
80  pr_err("error: (%d) %s: " fmt, \
81  task_pid_nr(current), __func__, ##__VA_ARGS__)
82
83 #define JFFS2_WARNING(fmt, ...) \
84  pr_warn("warning: (%d) %s: " fmt, \
85  task_pid_nr(current), __func__, ##__VA_ARGS__)
86
87 #define JFFS2_NOTICE(fmt, ...) \
88  pr_notice("notice: (%d) %s: " fmt, \
89  task_pid_nr(current), __func__, ##__VA_ARGS__)
90
91 #define JFFS2_DEBUG(fmt, ...) \
92  printk(KERN_DEBUG "[JFFS2 DBG] (%d) %s: " fmt, \
93  task_pid_nr(current), __func__, ##__VA_ARGS__)
94 #else /* __rtems__ */
95 #define JFFS2_ERROR(fmt, ...) \
96  pr_err("error: %s: " fmt, \
97  __func__, ##__VA_ARGS__)
98
99 #define JFFS2_WARNING(fmt, ...) \
100  pr_warn("warning: %s: " fmt, \
101  __func__, ##__VA_ARGS__)
102
103 #define JFFS2_NOTICE(fmt, ...) \
104  pr_notice("notice: %s: " fmt, \
105  __func__, ##__VA_ARGS__)
106
107 #define JFFS2_DEBUG(fmt, ...) \
108  printk(KERN_DEBUG "[JFFS2 DBG] %s: " fmt, \
109  __func__, ##__VA_ARGS__)
110 #endif /* __rtems__ */
111
112 /*
113  * We split our debugging messages on several parts, depending on the JFFS2
114  * subsystem the message belongs to.
115  */
116 /* Read inode debugging messages */
117 #ifdef JFFS2_DBG_READINODE_MESSAGES
118 #define dbg_readinode(fmt, ...) JFFS2_DEBUG(fmt, ##__VA_ARGS__)
119 #else
120 #define dbg_readinode(fmt, ...)
121 #endif
122 #ifdef JFFS2_DBG_READINODE2_MESSAGES
123 #define dbg_readinode2(fmt, ...) JFFS2_DEBUG(fmt, ##__VA_ARGS__)
124 #else
125 #define dbg_readinode2(fmt, ...)
126 #endif
127
128 /* Fragtree build debugging messages */
129 #ifdef JFFS2_DBG_FRAGTREE_MESSAGES
130 #define dbg_fragtree(fmt, ...) JFFS2_DEBUG(fmt, ##__VA_ARGS__)
131 #else
132 #define dbg_fragtree(fmt, ...)
133 #endif
134 #ifdef JFFS2_DBG_FRAGTREE2_MESSAGES
135 #define dbg_fragtree2(fmt, ...) JFFS2_DEBUG(fmt, ##__VA_ARGS__)
136 #else
137 #define dbg_fragtree2(fmt, ...)
138 #endif
139
140 /* Directory entry list manilulation debugging messages */
141 #ifdef JFFS2_DBG_DENTLIST_MESSAGES
142 #define dbg_dentlist(fmt, ...) JFFS2_DEBUG(fmt, ##__VA_ARGS__)
143 #else
144 #define dbg_dentlist(fmt, ...)
145 #endif
146
147 /* Print the messages about manipulating node_refs */
148 #ifdef JFFS2_DBG_NODEREF_MESSAGES
149 #define dbg_noderef(fmt, ...) JFFS2_DEBUG(fmt, ##__VA_ARGS__)
150 #else
151 #define dbg_noderef(fmt, ...)
152 #endif
153
154 /* Manipulations with the list of inodes (JFFS2 inocache) */
155 #ifdef JFFS2_DBG_INOCACHE_MESSAGES
156 #define dbg_inocache(fmt, ...) JFFS2_DEBUG(fmt, ##__VA_ARGS__)
157 #else
158 #define dbg_inocache(fmt, ...)
159 #endif
160
161 /* Summary debugging messages */
162 #ifdef JFFS2_DBG_SUMMARY_MESSAGES
163 #define dbg_summary(fmt, ...) JFFS2_DEBUG(fmt, ##__VA_ARGS__)
164 #else
165 #define dbg_summary(fmt, ...)
166 #endif
167
168 /* File system build messages */
169 #ifdef JFFS2_DBG_FSBUILD_MESSAGES
170 #define dbg_fsbuild(fmt, ...) JFFS2_DEBUG(fmt, ##__VA_ARGS__)
171 #else
172 #define dbg_fsbuild(fmt, ...)
173 #endif
174
175 /* Watch the object allocations */
176 #ifdef JFFS2_DBG_MEMALLOC_MESSAGES
177 #define dbg_memalloc(fmt, ...) JFFS2_DEBUG(fmt, ##__VA_ARGS__)
178 #else
179 #define dbg_memalloc(fmt, ...)
180 #endif
181
182 /* Watch the XATTR subsystem */
183 #ifdef JFFS2_DBG_XATTR_MESSAGES
184 #define dbg_xattr(fmt, ...) JFFS2_DEBUG(fmt, ##__VA_ARGS__)
185 #else
186 #define dbg_xattr(fmt, ...)
187 #endif
188
189 /* "Sanity" checks */
190 void
191 __jffs2_dbg_acct_sanity_check_nolock(struct jffs2_sb_info *c,
192  struct jffs2_eraseblock *jeb);
193 void
194 __jffs2_dbg_acct_sanity_check(struct jffs2_sb_info *c,
195  struct jffs2_eraseblock *jeb);
196
197 /* "Paranoia" checks */
198 void
199 __jffs2_dbg_fragtree_paranoia_check(struct jffs2_inode_info *f);
200 void
201 __jffs2_dbg_fragtree_paranoia_check_nolock(struct jffs2_inode_info *f);
202 void
203 __jffs2_dbg_acct_paranoia_check(struct jffs2_sb_info *c,
204  struct jffs2_eraseblock *jeb);
205 void
206 __jffs2_dbg_acct_paranoia_check_nolock(struct jffs2_sb_info *c,
207  struct jffs2_eraseblock *jeb);
208 void
209 __jffs2_dbg_prewrite_paranoia_check(struct jffs2_sb_info *c,
210  uint32_t ofs, int len);
211
212 /* "Dump" functions */
213 void
214 __jffs2_dbg_dump_jeb(struct jffs2_sb_info *c, struct jffs2_eraseblock *jeb);
215 void
216 __jffs2_dbg_dump_jeb_nolock(struct jffs2_eraseblock *jeb);
217 void
218 __jffs2_dbg_dump_block_lists(struct jffs2_sb_info *c);
219 void
220 __jffs2_dbg_dump_block_lists_nolock(struct jffs2_sb_info *c);
221 void
222 __jffs2_dbg_dump_node_refs(struct jffs2_sb_info *c,
223  struct jffs2_eraseblock *jeb);
224 void
225 __jffs2_dbg_dump_node_refs_nolock(struct jffs2_sb_info *c,
226  struct jffs2_eraseblock *jeb);
227 void
228 __jffs2_dbg_dump_fragtree(struct jffs2_inode_info *f);
229 void
230 __jffs2_dbg_dump_fragtree_nolock(struct jffs2_inode_info *f);
231 void
232 __jffs2_dbg_dump_buffer(unsigned char *buf, int len, uint32_t offs);
233 void
234 __jffs2_dbg_dump_node(struct jffs2_sb_info *c, uint32_t ofs);
235
236 #ifdef JFFS2_DBG_PARANOIA_CHECKS
237 #define jffs2_dbg_fragtree_paranoia_check(f) \
238  __jffs2_dbg_fragtree_paranoia_check(f)
239 #define jffs2_dbg_fragtree_paranoia_check_nolock(f) \
240  __jffs2_dbg_fragtree_paranoia_check_nolock(f)
241 #define jffs2_dbg_acct_paranoia_check(c, jeb) \
242  __jffs2_dbg_acct_paranoia_check(c,jeb)
243 #define jffs2_dbg_acct_paranoia_check_nolock(c, jeb) \
244  __jffs2_dbg_acct_paranoia_check_nolock(c,jeb)
245 #define jffs2_dbg_prewrite_paranoia_check(c, ofs, len) \
246  __jffs2_dbg_prewrite_paranoia_check(c, ofs, len)
247 #else
248 #define jffs2_dbg_fragtree_paranoia_check(f)
249 #define jffs2_dbg_fragtree_paranoia_check_nolock(f)
250 #define jffs2_dbg_acct_paranoia_check(c, jeb)
251 #define jffs2_dbg_acct_paranoia_check_nolock(c, jeb)
252 #define jffs2_dbg_prewrite_paranoia_check(c, ofs, len)
253 #endif /* !JFFS2_PARANOIA_CHECKS */
254
255 #ifdef JFFS2_DBG_DUMPS
256 #define jffs2_dbg_dump_jeb(c, jeb) \
257  __jffs2_dbg_dump_jeb(c, jeb);
258 #define jffs2_dbg_dump_jeb_nolock(jeb) \
259  __jffs2_dbg_dump_jeb_nolock(jeb);
260 #define jffs2_dbg_dump_block_lists(c) \
261  __jffs2_dbg_dump_block_lists(c)
262 #define jffs2_dbg_dump_block_lists_nolock(c) \
263  __jffs2_dbg_dump_block_lists_nolock(c)
264 #define jffs2_dbg_dump_fragtree(f) \
265  __jffs2_dbg_dump_fragtree(f);
266 #define jffs2_dbg_dump_fragtree_nolock(f) \
267  __jffs2_dbg_dump_fragtree_nolock(f);
268 #define jffs2_dbg_dump_buffer(buf, len, offs) \
269  __jffs2_dbg_dump_buffer(*buf, len, offs);
270 #define jffs2_dbg_dump_node(c, ofs) \
271  __jffs2_dbg_dump_node(c, ofs);
272 #else
273 #define jffs2_dbg_dump_jeb(c, jeb)
274 #define jffs2_dbg_dump_jeb_nolock(jeb)
275 #define jffs2_dbg_dump_block_lists(c)
276 #define jffs2_dbg_dump_block_lists_nolock(c)
277 #define jffs2_dbg_dump_fragtree(f)
278 #define jffs2_dbg_dump_fragtree_nolock(f)
279 #define jffs2_dbg_dump_buffer(buf, len, offs)
280 #define jffs2_dbg_dump_node(c, ofs)
281 #endif /* !JFFS2_DBG_DUMPS */
282
283 #ifdef JFFS2_DBG_SANITY_CHECKS
284 #define jffs2_dbg_acct_sanity_check(c, jeb) \
285  __jffs2_dbg_acct_sanity_check(c, jeb)
286 #define jffs2_dbg_acct_sanity_check_nolock(c, jeb) \
287  __jffs2_dbg_acct_sanity_check_nolock(c, jeb)
288 #else
289 #define jffs2_dbg_acct_sanity_check(c, jeb)
290 #define jffs2_dbg_acct_sanity_check_nolock(c, jeb)
291 #endif /* !JFFS2_DBG_SANITY_CHECKS */
292
293 #endif /* _JFFS2_DEBUG_H_ */
Definition: nodelist.h:277
Definition: jffs2_fs_sb.h:48
Definition: jffs2_fs_i.h:20
