RTEMS  5.1
fdt.h
1 /* SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) */
2 #ifndef FDT_H
3 #define FDT_H
4 /*
5  * libfdt - Flat Device Tree manipulation
6  * Copyright (C) 2006 David Gibson, IBM Corporation.
7  * Copyright 2012 Kim Phillips, Freescale Semiconductor.
8  */
9
10 #ifndef __ASSEMBLY__
11
12 struct fdt_header {
13  fdt32_t magic; /* magic word FDT_MAGIC */
14  fdt32_t totalsize; /* total size of DT block */
15  fdt32_t off_dt_struct; /* offset to structure */
16  fdt32_t off_dt_strings; /* offset to strings */
17  fdt32_t off_mem_rsvmap; /* offset to memory reserve map */
18  fdt32_t version; /* format version */
19  fdt32_t last_comp_version; /* last compatible version */
20
21  /* version 2 fields below */
22  fdt32_t boot_cpuid_phys; /* Which physical CPU id we're
23  booting on */
24  /* version 3 fields below */
25  fdt32_t size_dt_strings; /* size of the strings block */
26
27  /* version 17 fields below */
28  fdt32_t size_dt_struct; /* size of the structure block */
29 };
30
32  fdt64_t address;
33  fdt64_t size;
34 };
35
37  fdt32_t tag;
38  char name[0];
39 };
40
41 struct fdt_property {
42  fdt32_t tag;
43  fdt32_t len;
44  fdt32_t nameoff;
45  char data[0];
46 };
47
48 #endif /* !__ASSEMBLY */
49
50 #define FDT_MAGIC 0xd00dfeed /* 4: version, 4: total size */
51 #define FDT_TAGSIZE sizeof(fdt32_t)
52
53 #define FDT_BEGIN_NODE 0x1 /* Start node: full name */
54 #define FDT_END_NODE 0x2 /* End node */
55 #define FDT_PROP 0x3 /* Property: name off,
56  size, content */
57 #define FDT_NOP 0x4 /* nop */
58 #define FDT_END 0x9
59
60 #define FDT_V1_SIZE (7*sizeof(fdt32_t))
61 #define FDT_V2_SIZE (FDT_V1_SIZE + sizeof(fdt32_t))
62 #define FDT_V3_SIZE (FDT_V2_SIZE + sizeof(fdt32_t))
63 #define FDT_V16_SIZE FDT_V3_SIZE
64 #define FDT_V17_SIZE (FDT_V16_SIZE + sizeof(fdt32_t))
65
66 #endif /* FDT_H */
Definition: fdt.h:12
Definition: fdt.h:31
Definition: fdt.h:36
Definition: fdt.h:41
