RTEMS  5.1
scheduler.h
1 /* SPDX-License-Identifier: BSD-2-Clause */
2
11 /*
12  * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
13  *
14  * Redistribution and use in source and binary forms, with or without
15  * modification, are permitted provided that the following conditions
16  * are met:
17  * 1. Redistributions of source code must retain the above copyright
18  * notice, this list of conditions and the following disclaimer.
19  * 2. Redistributions in binary form must reproduce the above copyright
20  * notice, this list of conditions and the following disclaimer in the
21  * documentation and/or other materials provided with the distribution.
22  *
23  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26  * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27  * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28  * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29  * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30  * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31  * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32  * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33  * POSSIBILITY OF SUCH DAMAGE.
34  */
35
36 #ifndef _RTEMS_CONFDEFS_SCHEDULER_H
37 #define _RTEMS_CONFDEFS_SCHEDULER_H
38
39 #ifndef __CONFIGURATION_TEMPLATE_h
40 #error "Do not include this file directly, use <rtems/confdefs.h> instead"
41 #endif
42
43 #ifdef CONFIGURE_INIT
44
45 #include <rtems/confdefs/percpu.h>
46
47 #if !defined(CONFIGURE_SCHEDULER_CBS) \
48  && !defined(CONFIGURE_SCHEDULER_EDF) \
49  && !defined(CONFIGURE_SCHEDULER_EDF_SMP) \
50  && !defined(CONFIGURE_SCHEDULER_PRIORITY) \
51  && !defined(CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP) \
52  && !defined(CONFIGURE_SCHEDULER_PRIORITY_SMP) \
53  && !defined(CONFIGURE_SCHEDULER_SIMPLE) \
54  && !defined(CONFIGURE_SCHEDULER_SIMPLE_SMP) \
55  && !defined(CONFIGURE_SCHEDULER_STRONG_APA) \
56  && !defined(CONFIGURE_SCHEDULER_USER)
57  #if defined(RTEMS_SMP) && _CONFIGURE_MAXIMUM_PROCESSORS > 1
58  #define CONFIGURE_SCHEDULER_EDF_SMP
59  #else
60  #define CONFIGURE_SCHEDULER_PRIORITY
61  #endif
62 #endif
63
64 #include <rtems/scheduler.h>
65
66 #ifdef __cplusplus
67 extern "C" {
68 #endif
69
70 #ifndef CONFIGURE_MAXIMUM_PRIORITY
71  #define CONFIGURE_MAXIMUM_PRIORITY PRIORITY_DEFAULT_MAXIMUM
72 #endif
73
74 #if CONFIGURE_MAXIMUM_PRIORITY != 3 \
75  && CONFIGURE_MAXIMUM_PRIORITY != 7 \
76  && CONFIGURE_MAXIMUM_PRIORITY != 15 \
77  && CONFIGURE_MAXIMUM_PRIORITY != 31 \
78  && CONFIGURE_MAXIMUM_PRIORITY != 63 \
79  && CONFIGURE_MAXIMUM_PRIORITY != 127 \
80  && CONFIGURE_MAXIMUM_PRIORITY != 255
81  #error "CONFIGURE_MAXIMUM_PRIORITY must be one of 3, 7, 15, 31, 63, 127, and 255"
82 #endif
83
84 #if CONFIGURE_MAXIMUM_PRIORITY > PRIORITY_DEFAULT_MAXIMUM
85  #error "CONFIGURE_SCHEDULER_PRIORITY must be less than or equal to the architecture defined maximum priority"
86 #endif
87
88 #ifdef CONFIGURE_SCHEDULER_PRIORITY
89  #ifndef CONFIGURE_SCHEDULER_NAME
90  #define CONFIGURE_SCHEDULER_NAME rtems_build_name( 'U', 'P', 'D', ' ' )
91  #endif
92
93  #ifndef CONFIGURE_SCHEDULER_TABLE_ENTRIES
94  #define CONFIGURE_SCHEDULER \
95  RTEMS_SCHEDULER_PRIORITY( \
96  dflt, \
97  CONFIGURE_MAXIMUM_PRIORITY + 1 \
98  )
99
100  #define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
101  RTEMS_SCHEDULER_TABLE_PRIORITY( dflt, CONFIGURE_SCHEDULER_NAME )
102  #endif
103 #endif
104
105 #ifdef CONFIGURE_SCHEDULER_PRIORITY_SMP
106  #ifndef CONFIGURE_SCHEDULER_NAME
107  #define CONFIGURE_SCHEDULER_NAME rtems_build_name( 'M', 'P', 'D', ' ' )
108  #endif
109
110  #ifndef CONFIGURE_SCHEDULER_TABLE_ENTRIES
111  #define CONFIGURE_SCHEDULER \
112  RTEMS_SCHEDULER_PRIORITY_SMP( \
113  dflt, \
114  CONFIGURE_MAXIMUM_PRIORITY + 1 \
115  )
116
117  #define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
118  RTEMS_SCHEDULER_TABLE_PRIORITY_SMP( dflt, CONFIGURE_SCHEDULER_NAME )
119  #endif
120 #endif
121
122 #ifdef CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
123  #ifndef CONFIGURE_SCHEDULER_NAME
124  #define CONFIGURE_SCHEDULER_NAME rtems_build_name( 'M', 'P', 'A', ' ' )
125  #endif
126
127  #ifndef CONFIGURE_SCHEDULER_TABLE_ENTRIES
128  #define CONFIGURE_SCHEDULER \
129  RTEMS_SCHEDULER_PRIORITY_AFFINITY_SMP( \
130  dflt, \
131  CONFIGURE_MAXIMUM_PRIORITY + 1 \
132  )
133
134  #define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
135  RTEMS_SCHEDULER_TABLE_PRIORITY_AFFINITY_SMP( \
136  dflt, \
137  CONFIGURE_SCHEDULER_NAME \
138  )
139  #endif
140 #endif
141
142 #ifdef CONFIGURE_SCHEDULER_STRONG_APA
143  #ifndef CONFIGURE_SCHEDULER_NAME
144  #define CONFIGURE_SCHEDULER_NAME rtems_build_name( 'M', 'A', 'P', 'A' )
145  #endif
146
147  #ifndef CONFIGURE_SCHEDULER_TABLE_ENTRIES
148  #define CONFIGURE_SCHEDULER \
149  RTEMS_SCHEDULER_STRONG_APA( \
150  dflt, \
151  CONFIGURE_MAXIMUM_PRIORITY + 1 \
152  )
153
154  #define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
155  RTEMS_SCHEDULER_TABLE_STRONG_APA( dflt, CONFIGURE_SCHEDULER_NAME )
156  #endif
157 #endif
158
159 #ifdef CONFIGURE_SCHEDULER_SIMPLE
160  #ifndef CONFIGURE_SCHEDULER_NAME
161  #define CONFIGURE_SCHEDULER_NAME rtems_build_name( 'U', 'P', 'S', ' ' )
162  #endif
163
164  #ifndef CONFIGURE_SCHEDULER_TABLE_ENTRIES
165  #define CONFIGURE_SCHEDULER RTEMS_SCHEDULER_SIMPLE( dflt )
166
167  #define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
168  RTEMS_SCHEDULER_TABLE_SIMPLE( dflt, CONFIGURE_SCHEDULER_NAME )
169  #endif
170 #endif
171
172 #ifdef CONFIGURE_SCHEDULER_SIMPLE_SMP
173  #ifndef CONFIGURE_SCHEDULER_NAME
174  #define CONFIGURE_SCHEDULER_NAME rtems_build_name( 'M', 'P', 'S', ' ' )
175  #endif
176
177  #ifndef CONFIGURE_SCHEDULER_TABLE_ENTRIES
178  #define CONFIGURE_SCHEDULER \
179  RTEMS_SCHEDULER_SIMPLE_SMP( dflt )
180
181  #define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
182  RTEMS_SCHEDULER_TABLE_SIMPLE_SMP( dflt, CONFIGURE_SCHEDULER_NAME )
183  #endif
184 #endif
185
186 #ifdef CONFIGURE_SCHEDULER_EDF
187  #ifndef CONFIGURE_SCHEDULER_NAME
188  #define CONFIGURE_SCHEDULER_NAME rtems_build_name( 'U', 'E', 'D', 'F' )
189  #endif
190
191  #ifndef CONFIGURE_SCHEDULER_TABLE_ENTRIES
192  #define CONFIGURE_SCHEDULER RTEMS_SCHEDULER_EDF( dflt )
193
194  #define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
195  RTEMS_SCHEDULER_TABLE_EDF( dflt, CONFIGURE_SCHEDULER_NAME )
196  #endif
197 #endif
198
199 #ifdef CONFIGURE_SCHEDULER_EDF_SMP
200  #ifndef CONFIGURE_SCHEDULER_NAME
201  #define CONFIGURE_SCHEDULER_NAME rtems_build_name( 'M', 'E', 'D', 'F' )
202  #endif
203
204  #ifndef CONFIGURE_SCHEDULER_TABLE_ENTRIES
205  #define CONFIGURE_SCHEDULER RTEMS_SCHEDULER_EDF_SMP( dflt )
206
207  #define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
208  RTEMS_SCHEDULER_TABLE_EDF_SMP( dflt, CONFIGURE_SCHEDULER_NAME )
209  #endif
210 #endif
211
212 #ifdef CONFIGURE_SCHEDULER_CBS
213  #ifndef CONFIGURE_SCHEDULER_NAME
214  #define CONFIGURE_SCHEDULER_NAME rtems_build_name( 'U', 'C', 'B', 'S' )
215  #endif
216
217  #ifndef CONFIGURE_SCHEDULER_TABLE_ENTRIES
218  #define CONFIGURE_SCHEDULER RTEMS_SCHEDULER_CBS( dflt )
219
220  #define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
221  RTEMS_SCHEDULER_TABLE_CBS( dflt, CONFIGURE_SCHEDULER_NAME )
222  #endif
223
224  #ifndef CONFIGURE_CBS_MAXIMUM_SERVERS
225  #define CONFIGURE_CBS_MAXIMUM_SERVERS CONFIGURE_MAXIMUM_TASKS
226  #endif
227
228  const uint32_t _Scheduler_CBS_Maximum_servers =
229  CONFIGURE_CBS_MAXIMUM_SERVERS;
230
232  _Scheduler_CBS_Server_list[ CONFIGURE_CBS_MAXIMUM_SERVERS ];
233 #endif
234
235 #ifdef CONFIGURE_SCHEDULER
236  CONFIGURE_SCHEDULER;
237 #endif
238
240  CONFIGURE_SCHEDULER_TABLE_ENTRIES
241 };
242
243 #define _CONFIGURE_SCHEDULER_COUNT RTEMS_ARRAY_SIZE( _Scheduler_Table )
244
245 #ifdef RTEMS_SMP
246
247 const size_t _Scheduler_Count = _CONFIGURE_SCHEDULER_COUNT;
248
249 const Scheduler_Assignment _Scheduler_Initial_assignments[] = {
250  #ifdef CONFIGURE_SCHEDULER_ASSIGNMENTS
251  CONFIGURE_SCHEDULER_ASSIGNMENTS
252  #else
253  #define _CONFIGURE_SCHEDULER_ASSIGN \
254  RTEMS_SCHEDULER_ASSIGN( \
255  0, \
256  RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL \
257  )
258  _CONFIGURE_SCHEDULER_ASSIGN
259  #if _CONFIGURE_MAXIMUM_PROCESSORS >= 2
260  , _CONFIGURE_SCHEDULER_ASSIGN
261  #endif
262  #if _CONFIGURE_MAXIMUM_PROCESSORS >= 3
263  , _CONFIGURE_SCHEDULER_ASSIGN
264  #endif
265  #if _CONFIGURE_MAXIMUM_PROCESSORS >= 4
266  , _CONFIGURE_SCHEDULER_ASSIGN
267  #endif
268  #if _CONFIGURE_MAXIMUM_PROCESSORS >= 5
269  , _CONFIGURE_SCHEDULER_ASSIGN
270  #endif
271  #if _CONFIGURE_MAXIMUM_PROCESSORS >= 6
272  , _CONFIGURE_SCHEDULER_ASSIGN
273  #endif
274  #if _CONFIGURE_MAXIMUM_PROCESSORS >= 7
275  , _CONFIGURE_SCHEDULER_ASSIGN
276  #endif
277  #if _CONFIGURE_MAXIMUM_PROCESSORS >= 8
278  , _CONFIGURE_SCHEDULER_ASSIGN
279  #endif
280  #if _CONFIGURE_MAXIMUM_PROCESSORS >= 9
281  , _CONFIGURE_SCHEDULER_ASSIGN
282  #endif
283  #if _CONFIGURE_MAXIMUM_PROCESSORS >= 10
284  , _CONFIGURE_SCHEDULER_ASSIGN
285  #endif
286  #if _CONFIGURE_MAXIMUM_PROCESSORS >= 11
287  , _CONFIGURE_SCHEDULER_ASSIGN
288  #endif
289  #if _CONFIGURE_MAXIMUM_PROCESSORS >= 12
290  , _CONFIGURE_SCHEDULER_ASSIGN
291  #endif
292  #if _CONFIGURE_MAXIMUM_PROCESSORS >= 13
293  , _CONFIGURE_SCHEDULER_ASSIGN
294  #endif
295  #if _CONFIGURE_MAXIMUM_PROCESSORS >= 14
296  , _CONFIGURE_SCHEDULER_ASSIGN
297  #endif
298  #if _CONFIGURE_MAXIMUM_PROCESSORS >= 15
299  , _CONFIGURE_SCHEDULER_ASSIGN
300  #endif
301  #if _CONFIGURE_MAXIMUM_PROCESSORS >= 16
302  , _CONFIGURE_SCHEDULER_ASSIGN
303  #endif
304  #if _CONFIGURE_MAXIMUM_PROCESSORS >= 17
305  , _CONFIGURE_SCHEDULER_ASSIGN
306  #endif
307  #if _CONFIGURE_MAXIMUM_PROCESSORS >= 18
308  , _CONFIGURE_SCHEDULER_ASSIGN
309  #endif
310  #if _CONFIGURE_MAXIMUM_PROCESSORS >= 19
311  , _CONFIGURE_SCHEDULER_ASSIGN
312  #endif
313  #if _CONFIGURE_MAXIMUM_PROCESSORS >= 20
314  , _CONFIGURE_SCHEDULER_ASSIGN
315  #endif
316  #if _CONFIGURE_MAXIMUM_PROCESSORS >= 21
317  , _CONFIGURE_SCHEDULER_ASSIGN
318  #endif
319  #if _CONFIGURE_MAXIMUM_PROCESSORS >= 22
320  , _CONFIGURE_SCHEDULER_ASSIGN
321  #endif
322  #if _CONFIGURE_MAXIMUM_PROCESSORS >= 23
323  , _CONFIGURE_SCHEDULER_ASSIGN
324  #endif
325  #if _CONFIGURE_MAXIMUM_PROCESSORS >= 24
326  , _CONFIGURE_SCHEDULER_ASSIGN
327  #endif
328  #if _CONFIGURE_MAXIMUM_PROCESSORS >= 25
329  , _CONFIGURE_SCHEDULER_ASSIGN
330  #endif
331  #if _CONFIGURE_MAXIMUM_PROCESSORS >= 26
332  , _CONFIGURE_SCHEDULER_ASSIGN
333  #endif
334  #if _CONFIGURE_MAXIMUM_PROCESSORS >= 27
335  , _CONFIGURE_SCHEDULER_ASSIGN
336  #endif
337  #if _CONFIGURE_MAXIMUM_PROCESSORS >= 28
338  , _CONFIGURE_SCHEDULER_ASSIGN
339  #endif
340  #if _CONFIGURE_MAXIMUM_PROCESSORS >= 29
341  , _CONFIGURE_SCHEDULER_ASSIGN
342  #endif
343  #if _CONFIGURE_MAXIMUM_PROCESSORS >= 30
344  , _CONFIGURE_SCHEDULER_ASSIGN
345  #endif
346  #if _CONFIGURE_MAXIMUM_PROCESSORS >= 31
347  , _CONFIGURE_SCHEDULER_ASSIGN
348  #endif
349  #if _CONFIGURE_MAXIMUM_PROCESSORS >= 32
350  , _CONFIGURE_SCHEDULER_ASSIGN
351  #endif
352  #undef _CONFIGURE_SCHEDULER_ASSIGN
353  #endif
354 };
355
356 RTEMS_STATIC_ASSERT(
357  _CONFIGURE_MAXIMUM_PROCESSORS
358  == RTEMS_ARRAY_SIZE( _Scheduler_Initial_assignments ),
359  _Scheduler_Initial_assignments
360 );
361
362 #endif /* RTEMS_SMP */
363
364 #ifdef __cplusplus
365 }
366 #endif
367
368 #endif /* CONFIGURE_INIT */
369
370 #endif /* _RTEMS_CONFDEFS_SCHEDULER_H */
Evaluate Per-CPU Configuration Options.
Scheduler Configuration API.
#define _Scheduler_Count
Count of registered schedulers.
Definition: scheduler.h:325
Scheduler_CBS_Server _Scheduler_CBS_Server_list[]
const Scheduler_Control _Scheduler_Table[]
Registered schedulers.
Definition: schedulercbs.h:115
Scheduler control.
Definition: scheduler.h:269
