RTEMS  5.1
cli.h
1
9 /* Based upon code from MicroMonitor 1.17 from http://www.umonfw.com/
10  * which includes this notice:
11  *
12  **************************************************************************
13  * General notice:
14  * This code is part of a boot-monitor package developed as a generic base
15  * platform for embedded system designs. As such, it is likely to be
16  * distributed to various projects beyond the control of the original
17  * author. Please notify the author of any enhancements made or bugs found
18  * so that all may benefit from the changes. In addition, notification back
19  * to the author will allow the new user to pick up changes that may have
20  * been made by other users after this version of the code was distributed.
21  *
22  * Note1: the majority of this code was edited with 4-space tabs.
23  * Note2: as more and more contributions are accepted, the term "author"
24  * is becoming a mis-representation of credit.
25  *
26  * Original author: Ed Sutter
27  * Email: esutter@alcatel-lucent.com
28  * Phone: 908-582-2351
29  **************************************************************************
30  *
31  * Ed Sutter has been informed that this code is being used in RTEMS.
32  *
33  * This code was reformatted by Joel Sherrill from OAR Corporation and
34  * Fernando Nicodemos <fgnicodemos@terra.com.br> from NCB - Sistemas
35  * Embarcados Ltda. (Brazil) to be more compliant with RTEMS coding
36  * standards and to eliminate C++ style comments.
37  */
38
39 #ifndef _cli_h
40 #define _cli_h
41
42 #ifdef __cplusplus
43 extern "C" {
44 #endif
45
54 struct monCommand {
55  char *name; /* Name of command seen by user. */
56  int (*func)(int,char **); /* Called when command is invoked. */
57  char **helptxt; /* Help text (see notes below). */
58  long flags; /* Single-bit flags for various uses */
59  /* (see the CMDFLAG_XXX macros). */
60 };
61
62 #ifdef __cplusplus
63 }
64 #endif
65
66 /* Bits currently assigned to command flags used in the monCommand
67  * structure...
68  */
69 #define CMDFLAG_NOMONRC 1
70
71 /* Maximum size of a command line:
72  */
73 #ifndef CMDLINESIZE
74 #define CMDLINESIZE 128
75 #endif
76
77 /* Maximum number of arguments in a command line:
78  */
79 #define ARGCNT 24
80
81 /* Definitions for docommand() return values:
82  *
83  * Note that the CMD_SUCCESS, CMD_FAILURE and CMD_PARAM_ERROR are return
84  * values used by the local command code also. The remaining errors
85  * (CMD_LINE_ERROR, CMD_ULVL_DENIED and CMD_NOT_FOUND) are used only by
86  # the docommand() function.
87  *
88  * CMD_SUCCESS:
89  * Everything worked ok.
90  * CMD_FAILURE:
91  * Command parameters were valid, but command itself failed for some other
92  * reason. The docommand() function does not print a message here, it
93  * is assumed that the error message was printed by the local function.
94  * CMD_PARAM_ERROR:
95  * Command line did not parse properly. Control was passed to a
96  * local command function, but argument syntax caused it to choke.
97  * In this case docommand() will print out the generic CLI syntax error
98  * message.
99  * CMD_LINE_ERROR:
100  * Command line itself was invalid. Too many args, invalid shell var
101  * syntax, etc.. Somekind of command line error prior to checking for
102  * the command name-to-function match.
103  * CMD_ULVL_DENIED:
104  * Command's user level is higher than current user level, so access
105  * is denied.
106  * CMD_NOT_FOUND:
107  * Since these same return values are used for each command function
108  * plus the docommand() function, this error indicates that docommand()
109  * could not even find the command in the command table.
110  * CMD_MONRC_DENIED:
111  * The command cannot execute because it is considered illegal
112  * when run from within the monrc file.
113  */
114 #define CMD_SUCCESS 0
115 #define CMD_FAILURE -1
116 #define CMD_PARAM_ERROR -2
117 #define CMD_LINE_ERROR -3
118 #define CMD_ULVL_DENIED -4
119 #define CMD_NOT_FOUND -5
120 #define CMD_MONRC_DENIED -6
121
122 /* Notes on help text array:
123  * The monitor's CLI processor assumes that every command's help text
124  * array abides by a few basic rules...
125  * First of all, it assumes that every array has AT LEAST two strings.
126  * The first string in the array of strings is assumed to be a one-line
127  * abstract describing the command.
128  * The second string in the array of strings is assumed to be a usage
129  * message that describes the syntax of the arguments needed by the command.
130  * If this second string is an empty string (""), the docommand() prints out
131  * a generic usage string indicating that there are no options or arguements
132  * to apply to the command.
133  * All remaining lines are formatted based on the needs of the individual
134  * command and the final string is a null pointer to let the CLI processor
135  * know where the end is.
136  * Following is an example help text array...
137  *
138  * char *HelpHelp[] = {
139  * "Display command set",
140  * "-[d] [commandname]",
141  * "Options:",
142  * " -d list commands and descriptions",
143  * 0,
144  * };
145  *
146  */
147 #endif
Definition: cli.h:54
