RTEMS  5.1
cfg_auto.h
1 /* PCI Auto Configuration Library
2  *
3  * COPYRIGHT (c) 2010 Cobham Gaisler AB.
4  *
5  * The license and distribution terms for this file may be
6  * found in the file LICENSE in this distribution or at
7  * http://www.rtems.org/license/LICENSE.
8  */
9
10 #ifndef __PCI_CFG_AUTO_H__
11 #define __PCI_CFG_AUTO_H__
12
13 #define CFGOPT_NOSETUP_IRQ 0x1 /* Skip IRQ setup */
14
15 /* PCI Memory Layout setup, used by the auto-config library in order to
16  * determine the addresses of PCI BARs and Buses.
17  *
18  * All addresses are in PCI address space, the actual address the CPU access
19  * may be different, and taken care of elsewhere.
20  */
22  int options;
23
24  /* PCI prefetchable Memory space (OPTIONAL) */
25  uint32_t mem_start;
26  uint32_t mem_size; /* 0 = Use MEMIO space for prefetchable mem BARs */
27
28  /* PCI non-prefetchable Memory */
29  uint32_t memio_start;
30  uint32_t memio_size;
31
32  /* PCI I/O space (OPTIONAL) */
33  uint32_t io_start;
34  uint32_t io_size; /* 0 = No I/O space */
35
36  /* Get System IRQ connected to a PCI line of a PCI device on bus0.
37  * The return IRQ value zero equals no IRQ (IRQ disabled).
38  */
39  uint8_t (*irq_map)(pci_dev_t dev, int irq_pin);
40
41  /* IRQ Bridge routing. Returns the interrupt pin (0..3 = A..D) that
42  * a device is connected to on parent bus.
43  */
44  int (*irq_route)(pci_dev_t dev, int irq_pin);
45 };
46
47 /* Do PCI initialization: Enumrate buses, scan buses for devices, assign
48  * I/O MEM and MEMIO resources, assign IRQ and so on.
49  */
50 extern int pci_config_auto(void);
51
52 /* Register a configuration for the auto library (struct pci_auto_setup *) */
53 extern void pci_config_auto_register(void *config);
54
55 /* PCI memory map */
56 extern struct pci_auto_setup pci_auto_cfg;
57
58 #endif
Definition: deflate.c:115
Definition: cfg_auto.h:21
