RTEMS
5.1
30 #ifndef _SYS_CDEFS_ELF_H_ 31 #define _SYS_CDEFS_ELF_H_ 33 #ifdef __LEADING_UNDERSCORE 34 #define _C_LABEL(x) __CONCAT(_,x) 35 #define _C_LABEL_STRING(x) "_"x 38 #define _C_LABEL_STRING(x) x 42 #define ___RENAME(x) __asm__(___STRING(_C_LABEL(x))) 44 #ifdef __LEADING_UNDERSCORE 45 #define ___RENAME(x) ____RENAME(_x) 46 #define ____RENAME(x) __asm__(___STRING(x)) 48 #define ___RENAME(x) __asm__(___STRING(x)) 52 #define __indr_reference(sym,alias) 55 #define __strong_alias(alias,sym) \ 56 __asm__(".global " _C_LABEL_STRING(#alias) "\n" \ 57 _C_LABEL_STRING(#alias) " = " _C_LABEL_STRING(#sym)); 59 #define __weak_alias(alias,sym) \ 60 __asm__(".weak " _C_LABEL_STRING(#alias) "\n" \ 61 _C_LABEL_STRING(#alias) " = " _C_LABEL_STRING(#sym)); 62 #define __weak_extern(sym) \ 63 __asm__(".weak " _C_LABEL_STRING(#sym)); 64 #define __warn_references(sym,msg) \ 65 __asm__(".section .gnu.warning." #sym "\n\t.ascii \"" msg "\"\n\t.text"); 69 #ifdef __LEADING_UNDERSCORE 70 #define __weak_alias(alias,sym) ___weak_alias(_alias,_sym) 71 #define ___weak_alias(alias,sym) \ 72 __asm__(".weak alias\nalias = sym"); 74 #define __weak_alias(alias,sym) \ 75 __asm__(".weak alias\nalias = sym"); 77 #ifdef __LEADING_UNDERSCORE 78 #define __weak_extern(sym) ___weak_extern(_sym) 79 #define ___weak_extern(sym) \ 82 #define __weak_extern(sym) \ 85 #define __warn_references(sym,msg) \ 86 __asm__(".section .gnu.warning.sym\n\t.ascii msg ; .text"); 91 #define __SECTIONSTRING(_sec, _str) \ 92 __asm__(".section " #_sec "\n\t.asciz \"" _str "\"\n\t.previous") 94 #define __SECTIONSTRING(_sec, _str) \ 95 __asm__(".section _sec\n\t.asciz _str\n\t.previous") 98 #define __IDSTRING(_n,_s) __SECTIONSTRING(.ident,_s) 100 #define __RCSID(_s) __IDSTRING(rcsid,_s) 102 #define __SCCSID2(_s) 104 #define __COPYRIGHT(_s) __SECTIONSTRING(.copyright,_s) 106 #define __COPYRIGHT(_s) \ 107 static const char copyright[] \ 108 __attribute__((__unused__,__section__(".copyright"))) = _s 111 #define __KERNEL_RCSID(_n, _s) __RCSID(_s) 112 #define __KERNEL_SCCSID(_n, _s) 114 #define __KERNEL_COPYRIGHT(_n, _s) __COPYRIGHT(_s) 116 #define __KERNEL_COPYRIGHT(_n, _s) __SECTIONSTRING(.copyright, _s) 120 #define __link_set_make_entry(set, sym) \ 121 static void const * const __link_set_##set##_sym_##sym \ 122 __section("link_set_" #set) __used = &sym 123 #define __link_set_make_entry2(set, sym, n) \ 124 static void const * const __link_set_##set##_sym_##sym##_##n \ 125 __section("link_set_" #set) __used = &sym[n] 127 #define __link_set_make_entry(set, sym) \ 128 extern void const * const __link_set_##set##_sym_##sym 129 #define __link_set_make_entry2(set, sym, n) \ 130 extern void const * const __link_set_##set##_sym_##sym##_##n 133 #define __link_set_add_text(set, sym) __link_set_make_entry(set, sym) 134 #define __link_set_add_rodata(set, sym) __link_set_make_entry(set, sym) 135 #define __link_set_add_data(set, sym) __link_set_make_entry(set, sym) 136 #define __link_set_add_bss(set, sym) __link_set_make_entry(set, sym) 137 #define __link_set_add_text2(set, sym, n) __link_set_make_entry2(set, sym, n) 138 #define __link_set_add_rodata2(set, sym, n) __link_set_make_entry2(set, sym, n) 139 #define __link_set_add_data2(set, sym, n) __link_set_make_entry2(set, sym, n) 140 #define __link_set_add_bss2(set, sym, n) __link_set_make_entry2(set, sym, n) 142 #define __link_set_decl(set, ptype) \ 143 extern ptype * const __start_link_set_##set[]; \ 144 extern ptype * const __stop_link_set_##set[] \ 146 #define __link_set_start(set) (__start_link_set_##set) 147 #define __link_set_end(set) (__stop_link_set_##set) 149 #define __link_set_count(set) \ 150 (__link_set_end(set) - __link_set_start(set))
