RTEMS  5.1
cadence-i2c.h
1 /*
2  * SPDX-License-Identifier: BSD-2-Clause
3  *
4  * Copyright (C) 2014 embedded brains GmbH
5  *
6  * Redistribution and use in source and binary forms, with or without
7  * modification, are permitted provided that the following conditions
8  * are met:
9  * 1. Redistributions of source code must retain the above copyright
10  * notice, this list of conditions and the following disclaimer.
11  * 2. Redistributions in binary form must reproduce the above copyright
12  * notice, this list of conditions and the following disclaimer in the
13  * documentation and/or other materials provided with the distribution.
14  *
15  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18  * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19  * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20  * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21  * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22  * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23  * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24  * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25  * POSSIBILITY OF SUCH DAMAGE.
26  */
27
28 #ifndef LIBBSP_ARM_XILINX_ZYNQ_CADENCE_I2C_H
29 #define LIBBSP_ARM_XILINX_ZYNQ_CADENCE_I2C_H
30
31 #include <rtems.h>
32
33 #ifdef __cplusplus
34 extern "C" {
35 #endif /* __cplusplus */
36
37 int i2c_bus_register_cadence(
38  const char *bus_path,
39  uintptr_t register_base,
40  uint32_t input_clock,
42 );
43
44 #ifdef __cplusplus
45 }
46 #endif /* __cplusplus */
47
48 #endif /* LIBBSP_ARM_XILINX_ZYNQ_CADENCE_I2C_H */
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
