RTEMS  5.1
cadence-i2c-regs.h
1 /*
2  * SPDX-License-Identifier: BSD-2-Clause
3  *
4  * Copyright (C) 2014 embedded brains GmbH
5  *
6  * Redistribution and use in source and binary forms, with or without
7  * modification, are permitted provided that the following conditions
8  * are met:
9  * 1. Redistributions of source code must retain the above copyright
10  * notice, this list of conditions and the following disclaimer.
11  * 2. Redistributions in binary form must reproduce the above copyright
12  * notice, this list of conditions and the following disclaimer in the
13  * documentation and/or other materials provided with the distribution.
14  *
15  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18  * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19  * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20  * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21  * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22  * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23  * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24  * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25  * POSSIBILITY OF SUCH DAMAGE.
26  */
27
28 #ifndef LIBBSP_ARM_XILINX_ZYNQ_CADENCE_I2C_REGS_H
29 #define LIBBSP_ARM_XILINX_ZYNQ_CADENCE_I2C_REGS_H
30
31 #include <bsp/utility.h>
32
33 typedef struct {
34  uint32_t control;
35 #define CADENCE_I2C_CONTROL_DIV_A(val) BSP_FLD32(val, 14, 15)
36 #define CADENCE_I2C_CONTROL_DIV_A_GET(reg) BSP_FLD32GET(reg, 14, 15)
37 #define CADENCE_I2C_CONTROL_DIV_A_SET(reg, val) BSP_FLD32SET(reg, val, 14, 15)
38 #define CADENCE_I2C_CONTROL_DIV_B(val) BSP_FLD32(val, 8, 13)
39 #define CADENCE_I2C_CONTROL_DIV_B_GET(reg) BSP_FLD32GET(reg, 8, 13)
40 #define CADENCE_I2C_CONTROL_DIV_B_SET(reg, val) BSP_FLD32SET(reg, val, 8, 13)
41 #define CADENCE_I2C_CONTROL_CLR_FIFO BSP_BIT32(6)
42 #define CADENCE_I2C_CONTROL_SLVMON BSP_BIT32(5)
43 #define CADENCE_I2C_CONTROL_HOLD BSP_BIT32(4)
44 #define CADENCE_I2C_CONTROL_ACKEN BSP_BIT32(3)
45 #define CADENCE_I2C_CONTROL_NEA BSP_BIT32(2)
46 #define CADENCE_I2C_CONTROL_MS BSP_BIT32(1)
47 #define CADENCE_I2C_CONTROL_RW BSP_BIT32(0)
48  uint32_t status;
49 #define CADENCE_I2C_STATUS_BA BSP_BIT32(8)
50 #define CADENCE_I2C_STATUS_RXOVF BSP_BIT32(7)
51 #define CADENCE_I2C_STATUS_TXDV BSP_BIT32(6)
52 #define CADENCE_I2C_STATUS_RXDV BSP_BIT32(5)
53 #define CADENCE_I2C_STATUS_RXRW BSP_BIT32(3)
54  uint32_t address;
55 #define CADENCE_I2C_ADDRESS(val) BSP_FLD32(val, 0, 9)
56 #define CADENCE_I2C_ADDRESS_GET(reg) BSP_FLD32GET(reg, 0, 9)
57 #define CADENCE_I2C_ADDRESS_SET(reg, val) BSP_FLD32SET(reg, val, 0, 9)
58  uint32_t data;
59  uint32_t irqstatus;
60 #define CADENCE_I2C_IXR_ARB_LOST BSP_BIT32(9)
61 #define CADENCE_I2C_IXR_RX_UNF BSP_BIT32(7)
62 #define CADENCE_I2C_IXR_TX_OVR BSP_BIT32(6)
63 #define CADENCE_I2C_IXR_RX_OVR BSP_BIT32(5)
64 #define CADENCE_I2C_IXR_SLV_RDY BSP_BIT32(4)
65 #define CADENCE_I2C_IXR_TO BSP_BIT32(3)
66 #define CADENCE_I2C_IXR_NACK BSP_BIT32(2)
67 #define CADENCE_I2C_IXR_DATA BSP_BIT32(1)
68 #define CADENCE_I2C_IXR_COMP BSP_BIT32(0)
69  uint32_t transfer_size;
70 #define CADENCE_I2C_TRANSFER_SIZE(val) BSP_FLD32(val, 0, 7)
71 #define CADENCE_I2C_TRANSFER_SIZE_GET(reg) BSP_FLD32GET(reg, 0, 7)
72 #define CADENCE_I2C_TRANSFER_SIZE_SET(reg, val) BSP_FLD32SET(reg, val, 0, 7)
73  uint32_t slave_mon_pause;
74 #define CADENCE_I2C_SLAVE_MON_PAUSE(val) BSP_FLD32(val, 0, 3)
75 #define CADENCE_I2C_SLAVE_MON_PAUSE_GET(reg) BSP_FLD32GET(reg, 0, 3)
76 #define CADENCE_I2C_SLAVE_MON_PAUSE_SET(reg, val) BSP_FLD32SET(reg, val, 0, 3)
77  uint32_t timeout;
78 #define CADENCE_I2C_TIMEOUT(val) BSP_FLD32(val, 0, 7)
79 #define CADENCE_I2C_TIMEOUT_GET(reg) BSP_FLD32GET(reg, 0, 7)
80 #define CADENCE_I2C_TIMEOUT_SET(reg, val) BSP_FLD32SET(reg, val, 0, 7)
81  uint32_t irqmask;
82  uint32_t irqenable;
83  uint32_t irqdisable;
84 } cadence_i2c;
85
86 #endif /* LIBBSP_ARM_XILINX_ZYNQ_CADENCE_I2C_REGS_H */
Utility macros.
Definition: cadence-i2c-regs.h:33
Definition: intercom.c:74
