RTEMS
5.1
bsps
sparc64
niagara
include
bsp.h
1
9
/* bsp.h
10
11
* This include file contains all SPARC64 simulator definitions.
12
13
* COPYRIGHT (c) 1989-1998. On-Line Applications Research Corporation (OAR).
14
15
* The license and distribution terms for this file may be
16
* found in the file LICENSE in this distribution or at
17
* http://www.rtems.org/license/LICENSE.
18
19
20
#ifndef LIBBSP_SPARC64_NIAGARA_BSP_H
21
#define LIBBSP_SPARC64_NIAGARA_BSP_H
22
33
#include <bspopts.h>
34
bsp/default-initial-extension.h
35
36
rtems.h
37
38
#ifdef __cplusplus
39
extern
"C"
40
#endif
41
42
/* support for simulated clock tick */
43
44
void *clock_driver_sim_idle_body(uintptr_t);
45
#define BSP_IDLE_TASK_BODY clock_driver_sim_idle_body
46
47
48
/* this should be defined somewhere */
49
rtems_isr_entry
set_vector
/* returns old vector */
50
rtems_isr_entry handler,
/* isr routine */
51
rtems_vector_number
vector,
/* vector number */
52
int
type
/* RTEMS or RAW intr */
53
54
55
#ifdef __cplusplus
56
57
#endif
58
61
#endif
set_vector
rtems_isr_entry set_vector(rtems_isr_entry handler, rtems_vector_number vector, int type)
Install an interrupt handler.
Definition:
setvec.c:28
DEFAULT_INITIAL_EXTENSION Support.
rtems_vector_number
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition:
intr.h:47
rtems.h
