RTEMS  5.1
bsp.h
1
9 /*
10  * This include file contains all board IO definitions.
11  */
12
23 /*
24  * COPYRIGHT (c) 1989-2014.
25  * On-Line Applications Research Corporation (OAR).
26  *
27  * The license and distribution terms for this file may be
28  * found in the file LICENSE in this distribution or at
29  * http://www.rtems.org/license/LICENSE.
30  */
31
32 #ifndef LIBBSP_POWERPC_MPC8260ADS_BSP_H
33 #define LIBBSP_POWERPC_MPC8260ADS_BSP_H
34
35 #include <bspopts.h>
37
38 #include <rtems.h>
39 #include <mpc8260.h>
40 #include <mpc8260/cpm.h>
41 #include <mpc8260/mmu.h>
42 #include <mpc8260/console.h>
43 #include <bsp/irq.h>
44 #include <bsp/vectors.h>
45
46 #ifdef __cplusplus
47 extern "C" {
48 #endif
49
50 /*
51  * Board configuration registers
52  */
53
54 typedef struct bcsr
55
56 {
57  uint32_t bcsr0; /* Board Control and Status Register */
58  uint32_t bcsr1;
59  uint32_t bcsr2;
60  uint32_t bcsr3;
61
62 } BCSR;
63
64 /*
65  * Network driver configuration
66  */
67 struct rtems_bsdnet_ifconfig;
68 extern int rtems_enet_driver_attach (struct rtems_bsdnet_ifconfig *config, int attaching);
69 #define RTEMS_BSP_NETWORK_DRIVER_NAME "eth1"
70 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_enet_driver_attach
71
72 /* miscellaneous stuff assumed to exist */
73
74 /*
75  * We need to decide how much memory will be non-cacheable. This
76  * will mainly be memory that will be used in DMA (network and serial
77  * buffers).
78  */
79 /*
80 #define NOCACHE_MEM_SIZE 512*1024
81 */
82
83 /* functions */
84
85 #if 0
86 void M8260ExecuteRISC( uint32_t command );
87 void *M8260AllocateBufferDescriptors( int count );
88 void *M8260AllocateRiscTimers( int count );
89 extern char M8260DefaultWatchdogFeeder;
90 #endif
91
92 /*
93  * Prototypes for items shared across file boundaries in the BSP
94  */
95 extern uint32_t bsp_serial_per_sec;
96 void *bsp_idle_thread( uintptr_t ignored );
97 void cpu_init(void);
98 int mbx8xx_console_get_configuration(void);
99
100 #ifdef __cplusplus
101 }
102 #endif
103
106 #endif
Definition: deflate.c:115
Definition: bsp.h:54
DEFAULT_INITIAL_EXTENSION Support.
PowerPC Exceptions API.
void * bsp_idle_thread(uintptr_t ignored)
Optimized idle task.
Definition: bspidle.c:26
