RTEMS  5.1
powerpc.h
1
5 /*
6  * This file contains definitions for the IBM/Motorola PowerPC
7  * family members.
8  *
9  * Author: Andrew Bray <andy@i-cubed.co.uk>
10  *
11  * COPYRIGHT (c) 1995 by i-cubed ltd.
12  *
13  * MPC860 support code was added by Jay Monkman <jmonkman@frasca.com>
14  * MPC8260 support added by Andy Dachs <a.dachs@sstl.co.uk>
15  * Surrey Satellite Technology Limited
16  *
17  * To anyone who acknowledges that this file is provided "AS IS"
18  * without any express or implied warranty:
19  * permission to use, copy, modify, and distribute this file
20  * for any purpose is hereby granted without fee, provided that
21  * the above copyright notice and this notice appears in all
22  * copies, and that the name of i-cubed limited not be used in
23  * advertising or publicity pertaining to distribution of the
24  * software without specific, written prior permission.
25  * i-cubed limited makes no representations about the suitability
26  * of this software for any purpose.
27  *
28  * Derived from c/src/exec/cpu/no_cpu/no_cpu.h:
29  *
30  * COPYRIGHT (c) 1989-1997.
31  * On-Line Applications Research Corporation (OAR).
32  *
33  * The license and distribution terms for this file may in
34  * the file LICENSE in this distribution or at
35  * http://www.rtems.org/license/LICENSE.
36  *
37  *
38  * Note:
39  * This file is included by both C and assembler code ( -DASM )
40  */
41
42
43 #ifndef _RTEMS_POWERPC_POWERPC_H
44 #define _RTEMS_POWERPC_POWERPC_H
45
46 #ifdef __cplusplus
47 extern "C" {
48 #endif
49
50
51 /* Till S. 2008/07/10:
52  *
53  * Using the macros/definitions which depend on a preprocessor
54  * symbol defining the CPU flavor is discouraged.
55  * I recommend to not use definitions from this file and
56  * in particular - not to add more bits and pieces.
57  *
58  * Instead, try to use run-time detection (see e.g. cpuIdent.c/cpuIdent.h)
59  * of features etc.
60  */
61
62 #include <rtems/score/powerpc.h>
63
64 /*
65  * Unfortunately it is very inefficient to use run-time detection for the cache
66  * line size, so give the BSP the opportunity to define it here.
67  */
68 #include <bspopts.h>
69
70 /*
71  * This file contains the information required to build
72  * RTEMS for a particular member of the PowerPC family. It does
73  * this by setting variables to indicate which implementation
74  * dependent features are present in a particular member
75  * of the family.
76  *
77  * The following architectural feature definitions are defaulted
78  * unless specifically set by the model definition:
79  *
80  * + PPC_INTERRUPT_MAX - 16
81  * + PPC_CACHE_ALIGNMENT
82  * + PPC_LOW_POWER_MODE - PPC_LOW_POWER_MODE_NONE
83  * + PPC_HAS_EXCEPTION_PREFIX - 1
84  * + PPC_USE_MULTIPLE - 0
85  */
86
87 /*
88  * Define the low power mode models
89  *
90  * Standard: as defined for 603e
91  * Nap Mode: nap mode only (604)
92  * XXX 403GB, 603, 603e, 604, 821
93  */
94
95 #define PPC_LOW_POWER_MODE_NONE 0
96 #define PPC_LOW_POWER_MODE_STANDARD 1
97
101 #define PPC_NO_CACHE_ALIGNMENT 4
102
107 #define PPC_NO_CACHE_ALIGNMENT_POWER 2
108
109 /*
110  * Figure out all CPU Model Feature Flags based upon compiler
111  * predefines.
112  */
113
114 /*
115  * FIXME: The ppc405 define must be checked before the ppc403 define. The
116  * ppc405 define is provided by <bspopts.h>. The ppc403 define is provided by
117  * GCC as a built-in define if no ppc* or mpc* define is set via the
118  * command line (see GCC sources "gcc/config/rs6000/rtems.h").
119  */
120 #if defined(ppc405)
121
122 #define PPC_CACHE_ALIGNMENT 32
123 #define PPC_HAS_RI 0
124 #define PPC_HAS_RFCI 1
125 #define PPC_USE_MULTIPLE 1
126 #define PPC_I_CACHE 16384
127 #define PPC_D_CACHE 16384 /* except GP/CR */
128 #define PPC_HAS_EXCEPTION_PREFIX 0
129 #define PPC_HAS_EVPR 1
130
131 #elif defined(ppc403)
132 /*
133  * IBM 403
134  *
135  * Developed for 403GA. Book checked for 403GB.
136  *
137  * Does not have user mode.
138  */
139
140 #define PPC_CACHE_ALIGNMENT 16
141 #define PPC_HAS_RI 0
142 #define PPC_HAS_RFCI 1
143 #define PPC_USE_MULTIPLE 1
144 #define PPC_I_CACHE 2048
145 #define PPC_D_CACHE 1024
146
147 #define PPC_HAS_EXCEPTION_PREFIX 0
148 #define PPC_HAS_EVPR 1
149
150 #elif defined (ppc440)
151
152 #define PPC_CACHE_ALIGNMENT 32
153 #define PPC_HAS_RI 0
154 #define PPC_HAS_RFCI 1
155 #define PPC_USE_MULTIPLE 1
156 #define PPC_I_CACHE 32768
157 #define PPC_D_CACHE 32768
158 #define PPC_HAS_EXCEPTION_PREFIX 0
159 #define PPC_HAS_EVPR 1
160
161 #elif defined(mpc555)
162
163 /* Copied from mpc505 */
164 #define PPC_CACHE_ALIGNMENT PPC_NO_CACHE_ALIGNMENT
165
166 /* Added by querbach@realtime.bc.ca */
167 #define PPC_LOW_POWER_MODE PPC_LOW_POWER_MODE_STANDARD
168
169 /* Based on comments by Sergei Organov <osv@Javad.RU> */
170 #define PPC_I_CACHE 0
171 #define PPC_D_CACHE 0
172
173 #elif defined(mpc505) || defined(mpc509)
174 /*
175  * Submitted by Sergei Organov <osv@Javad.RU> as a patch against
176  * 3.6.0 long after 4.0 was released. This is just an attempt
177  * to get the setting correct.
178  */
179
180 #define CPU_MODEL_NAME "PowerPC 505/509"
181
182 #define PPC_CACHE_ALIGNMENT PPC_NO_CACHE_ALIGNMENT
183 #define PPC_I_CACHE 4096
184 #define PPC_D_CACHE 0
185
186
187 #elif defined(ppc601)
188
189 /*
190  * Submitted with original port -- book checked only.
191  */
192
193 #define PPC_USE_MULTIPLE 1
194 #define PPC_I_CACHE 0
195 #define PPC_D_CACHE 32768
196
197 #elif defined(ppc603)
198 /*
199  * Submitted with original port -- book checked only.
200  */
201
202 #define PPC_I_CACHE 8192
203 #define PPC_D_CACHE 8192
204
205 #elif defined(ppc603e)
206
207 /*
208  * Submitted with original port.
209  *
210  * Known to work on real hardware.
211  */
212
213 #define PPC_I_CACHE 16384
214 #define PPC_D_CACHE 16384
215
216 #define PPC_LOW_POWER_MODE PPC_LOW_POWER_MODE_STANDARD
217
218 #elif defined(mpc604)
219 /*
220  * Submitted with original port -- book checked only.
221  */
222
223 #define PPC_I_CACHE 16384
224 #define PPC_D_CACHE 16384
225
226 #elif defined(mpc860)
227 /*
228  * Added by Jay Monkman (jmonkman@frasca.com) 6/28/98
229  * with some changes by Darlene Stewart (Darlene.Stewart@iit.nrc.ca)
230  */
231 #define PPC_I_CACHE 4096
232 #define PPC_D_CACHE 4096
233 #define PPC_CACHE_ALIGNMENT 16
234 #define PPC_INTERRUPT_MAX 71
235 #define PPC_USE_MULTIPLE 1
236
237 #define PPC_MSR_0 0x00009000
238 #define PPC_MSR_1 0x00001000
239 #define PPC_MSR_2 0x00001000
240 #define PPC_MSR_3 0x00000000
241
242 #elif defined(mpc821)
243 /*
244  * Added by Andrew Bray <andy@chaos.org.uk> 6/April/1999
245  */
246 #define PPC_I_CACHE 4096
247 #define PPC_D_CACHE 4096
248 #define PPC_CACHE_ALIGNMENT 16
249 #define PPC_INTERRUPT_MAX 71
250
251 #define PPC_MSR_0 0x00009000
252 #define PPC_MSR_1 0x00001000
253 #define PPC_MSR_2 0x00001000
254 #define PPC_MSR_3 0x00000000
255
256 #elif defined(mpc750)
257
258 #define PPC_I_CACHE 16384
259 #define PPC_D_CACHE 16384
260
261 #elif defined(mpc7400)
262
263 #define PPC_I_CACHE 32768
264 #define PPC_D_CACHE 32768
265
266 #elif defined(mpc7455)
267 /*
268  * Added by S.K. Feng <feng1@bnl.gov> 10/03
269  */
270
271 #define PPC_CACHE_ALIGNMENT 32
272 #define PPC_I_CACHE 32768
273 #define PPC_D_CACHE 32768
274
275 #elif defined(mpc8260)
276 /*
277  * Added by Andy Dachs <a.dachs@sstl.co.uk> 23/11/2000
278  */
279 #define PPC_I_CACHE 16384
280 #define PPC_D_CACHE 16384
281 #define PPC_CACHE_ALIGNMENT 32
282 #define PPC_INTERRUPT_MAX 125
283 #define PPC_USE_MULTIPLE 1
284
285 #elif defined(__ppc_generic)
286
287 #else
288
289 #error "Unsupported CPU Model"
290
291 #endif
292
293 /*
294  * If the maximum number of exception sources has not been defined,
295  * then default it to 16.
296  */
297
298 #ifndef PPC_INTERRUPT_MAX
299 #define PPC_INTERRUPT_MAX 16
300 #endif
301
302 #ifndef PPC_CACHE_ALIGNMENT
303 #define PPC_CACHE_ALIGNMENT PPC_DEFAULT_CACHE_LINE_SIZE
304 #endif
305
306 #if (PPC_CACHE_ALIGNMENT == 16)
307 #define PPC_CACHE_ALIGN_POWER 4
308 #elif (PPC_CACHE_ALIGNMENT == 32)
309 #define PPC_CACHE_ALIGN_POWER 5
310 #elif (PPC_CACHE_ALIGNMENT == 64)
311 #define PPC_CACHE_ALIGN_POWER 6
312 #elif (PPC_CACHE_ALIGNMENT == PPC_NO_CACHE_ALIGNMENT)
313 #define PPC_CACHE_ALIGN_POWER PPC_NO_CACHE_ALIGNMENT_POWER
314 #else
315 #error "Undefined power of 2 for PPC_CACHE_ALIGNMENT"
316 #endif
317
318 /*
319  * Unless otherwise specified, assume the model has an IP/EP bit to
320  * set the exception address prefix.
321  */
322
323 #ifndef PPC_HAS_EXCEPTION_PREFIX
324 #define PPC_HAS_EXCEPTION_PREFIX 1
325 #endif
326 /*
327  * Unless otherwise specified, assume the model has an RI bit to
328  * identify non-recoverable interrupts
329  */
330
331 #ifndef PPC_HAS_RI
332 #define PPC_HAS_RI 1
333 #endif
334
335 /*
336  * Unless otherwise specified, assume the model does NOT have
337  * 403 style EVPR register to set the exception address prefix.
338  */
339
340 #ifndef PPC_HAS_EVPR
341 #define PPC_HAS_EVPR 0
342 #endif
343
344 /*
345  * If no low power mode model was specified, then assume there is none.
346  */
347
348 #ifndef PPC_LOW_POWER_MODE
349 #define PPC_LOW_POWER_MODE PPC_LOW_POWER_MODE_NONE
350 #endif
351
352 /*
353  * Unless specified above, then assume the model does NOT have critical
354  * interrupt support.
355  */
356
357 #ifndef PPC_HAS_RFCI
358 #define PPC_HAS_RFCI 0
359 #endif
360
361 /*
362  * Unless specified above, do not use the load/store multiple instructions
363  * in a context switch.
364  */
365
366 #ifndef PPC_USE_MULTIPLE
367 #define PPC_USE_MULTIPLE 0
368 #endif
369
370 /*
371  * The following exceptions are not maskable, and are not
372  * necessarily predictable, so cannot be offered to RTEMS:
373  * Alignment exception - handled by the CPU module
374  * Data exceptions.
375  * Instruction exceptions.
376  */
377
378 /*
379  * Base Interrupt vectors supported on all models.
380  */
381 #define PPC_IRQ_SYSTEM_RESET 0 /* 0x00100 - System reset. */
382 #define PPC_IRQ_MCHECK 1 /* 0x00200 - Machine check */
383 #define PPC_IRQ_PROTECT 2 /* 0x00300 - Protection violation */
384 #define PPC_IRQ_ISI 3 /* 0x00400 - Instruction Fetch error */
385 #define PPC_IRQ_EXTERNAL 4 /* 0x00500 - External interrupt */
386 #define PPC_IRQ_ALIGNMENT 5 /* 0X00600 - Alignment exception */
387 #define PPC_IRQ_PROGRAM 6 /* 0x00700 - Program exception */
388 #define PPC_IRQ_NOFP 7 /* 0x00800 - Floating point unavailable */
389 #define PPC_IRQ_DECREMENTER 8 /* 0x00900 - Decrementer interrupt */
390 #define PPC_IRQ_RESERVED_A 9 /* 0x00a00 - Implementation Reserved */
391 #define PPC_IRQ_RESERVED_B 10 /* 0x00b00 - Implementation Reserved */
392 #define PPC_IRQ_SCALL 11 /* 0x00c00 - System call */
393 #define PPC_IRQ_TRACE 12 /* 0x00d00 - Trace Exception */
394 #define PPC_IRQ_FP_ASST 13 /* ox00e00 - Floating point assist */
395 #define PPC_STD_IRQ_LAST PPC_IRQ_FP_ASST
396
397 #define PPC_IRQ_FIRST PPC_IRQ_SYSTEM_RESET
398
399 #if defined(ppc403) || defined(ppc405) || defined(ppc440)
400
401 #define PPC_IRQ_CRIT PPC_IRQ_SYSTEM_RESET /*0x00100- Critical int. pin */
402 #define PPC_IRQ_PIT (PPC_STD_IRQ_LAST+1) /*0x01000- Pgm interval timer*/
403 #define PPC_IRQ_FIT (PPC_STD_IRQ_LAST+2) /*0x01010- Fixed int. timer */
404 #define PPC_IRQ_WATCHDOG (PPC_STD_IRQ_LAST+3) /*0x01020- Watchdog timer */
405 #define PPC_IRQ_DEBUG (PPC_STD_IRQ_LAST+4) /*0x02000- Debug exceptions */
406 #define PPC_IRQ_LAST PPC_IRQ_DEBUG
407
408 #elif defined(mpc505) || defined(mpc509)
409 #define PPC_IRQ_SOFTEMU (PPC_STD_IRQ_LAST+1) /* Software emulation. */
410 #define PPC_IRQ_DATA_BP (PPC_STD_IRQ_LAST+ 2)
411 #define PPC_IRQ_INST_BP (PPC_STD_IRQ_LAST+ 3)
412 #define PPC_IRQ_MEXT_BP (PPC_STD_IRQ_LAST+ 4)
413 #define PPC_IRQ_NMEXT_BP (PPC_STD_IRQ_LAST+ 5)
414
415 #elif defined(mpc555)
416 #define PPC_IRQ_SOFTEMU (PPC_STD_IRQ_LAST+1) /* Software emulation. */
417 #define PPC_IRQ_INST_PE (PPC_STD_IRQ_LAST+2) /* Insn protection error */
418 #define PPC_IRQ_DATA_PE (PPC_STD_IRQ_LAST+3) /* Data protection error */
419 #define PPC_IRQ_DATA_BP (PPC_STD_IRQ_LAST+4) /* Data breakpoint */
420 #define PPC_IRQ_INST_BP (PPC_STD_IRQ_LAST+5) /* Insn breakpoint */
421 #define PPC_IRQ_MEXT_BP (PPC_STD_IRQ_LAST+6) /* Maskable ext bkpt */
422 #define PPC_IRQ_NMEXT_BP (PPC_STD_IRQ_LAST+7) /* Non-maskable ext bkpt */
423 #define PPC_IRQ_LAST PPC_IRQ_NMEXT_BP
424
425 #elif defined(ppc601)
426 #undef PPC_IRQ_TRACE
427 #define PPC_IRQ_TRACE (PPC_STD_IRQ_LAST+1) /*0x02000-Run/Trace Exception*/
428 #define PPC_IRQ_LAST PPC_IRQ_TRACE
429
430 #elif defined(ppc602)
431 #define PPC_IRQ_LAST (PPC_STD_IRQ_LAST)
432
433 #elif defined(ppc603) || defined(ppc603e)
434 #define PPC_IRQ_TRANS_MISS (PPC_STD_IRQ_LAST+1) /*0x1000-Ins Translation Miss*/
435 #define PPC_IRQ_DATA_LOAD (PPC_STD_IRQ_LAST+2) /*0x1100-Data Load Trans Miss*/
436 #define PPC_IRQ_DATA_STORE (PPC_STD_IRQ_LAST+3) /*0x1200-Data Store Miss */
437 #define PPC_IRQ_ADDR_BRK (PPC_STD_IRQ_LAST+4) /*0x1300-Instruction Bkpoint */
438 #define PPC_IRQ_SYS_MGT (PPC_STD_IRQ_LAST+5) /*0x1400-System Management */
439 #define PPC_IRQ_LAST PPC_IRQ_SYS_MGT
440
441 #elif defined(mpc604)
442 #define PPC_IRQ_ADDR_BRK (PPC_STD_IRQ_LAST+1) /*0x1300- Inst. addr break */
443 #define PPC_IRQ_SYS_MGT (PPC_STD_IRQ_LAST+2) /*0x1400- System Management */
444 #define PPC_IRQ_LAST PPC_IRQ_SYS_MGT
445
446 #elif defined(mpc860) || defined(mpc821)
447 #define PPC_IRQ_EMULATE (PPC_STD_IRQ_LAST+1) /*0x1000-Software emulation */
448 #define PPC_IRQ_INST_MISS (PPC_STD_IRQ_LAST+2) /*0x1100-Instruction TLB miss*/
449 #define PPC_IRQ_DATA_MISS (PPC_STD_IRQ_LAST+3) /*0x1200-Data TLB miss */
450 #define PPC_IRQ_INST_ERR (PPC_STD_IRQ_LAST+4) /*0x1300-Instruction TLB err */
451 #define PPC_IRQ_DATA_ERR (PPC_STD_IRQ_LAST+5) /*0x1400-Data TLB error */
452 #define PPC_IRQ_DATA_BPNT (PPC_STD_IRQ_LAST+6) /*0x1C00-Data breakpoint */
453 #define PPC_IRQ_INST_BPNT (PPC_STD_IRQ_LAST+7) /*0x1D00-Inst breakpoint */
454 #define PPC_IRQ_IO_BPNT (PPC_STD_IRQ_LAST+8) /*0x1E00-Peripheral breakpnt */
455 #define PPC_IRQ_DEV_PORT (PPC_STD_IRQ_LAST+9) /*0x1F00-Development port */
456 #define PPC_IRQ_IRQ0 (PPC_STD_IRQ_LAST + 10)
457 #define PPC_IRQ_LVL0 (PPC_STD_IRQ_LAST + 11)
458 #define PPC_IRQ_IRQ1 (PPC_STD_IRQ_LAST + 12)
459 #define PPC_IRQ_LVL1 (PPC_STD_IRQ_LAST + 13)
460 #define PPC_IRQ_IRQ2 (PPC_STD_IRQ_LAST + 14)
461 #define PPC_IRQ_LVL2 (PPC_STD_IRQ_LAST + 15)
462 #define PPC_IRQ_IRQ3 (PPC_STD_IRQ_LAST + 16)
463 #define PPC_IRQ_LVL3 (PPC_STD_IRQ_LAST + 17)
464 #define PPC_IRQ_IRQ4 (PPC_STD_IRQ_LAST + 18)
465 #define PPC_IRQ_LVL4 (PPC_STD_IRQ_LAST + 19)
466 #define PPC_IRQ_IRQ5 (PPC_STD_IRQ_LAST + 20)
467 #define PPC_IRQ_LVL5 (PPC_STD_IRQ_LAST + 21)
468 #define PPC_IRQ_IRQ6 (PPC_STD_IRQ_LAST + 22)
469 #define PPC_IRQ_LVL6 (PPC_STD_IRQ_LAST + 23)
470 #define PPC_IRQ_IRQ7 (PPC_STD_IRQ_LAST + 24)
471 #define PPC_IRQ_LVL7 (PPC_STD_IRQ_LAST + 25)
472 #define PPC_IRQ_CPM_ERROR (PPC_STD_IRQ_LAST + 26)
473 #define PPC_IRQ_CPM_PC4 (PPC_STD_IRQ_LAST + 27)
474 #define PPC_IRQ_CPM_PC5 (PPC_STD_IRQ_LAST + 28)
475 #define PPC_IRQ_CPM_SMC2 (PPC_STD_IRQ_LAST + 29)
476 #define PPC_IRQ_CPM_SMC1 (PPC_STD_IRQ_LAST + 30)
477 #define PPC_IRQ_CPM_SPI (PPC_STD_IRQ_LAST + 31)
478 #define PPC_IRQ_CPM_PC6 (PPC_STD_IRQ_LAST + 32)
479 #define PPC_IRQ_CPM_TIMER4 (PPC_STD_IRQ_LAST + 33)
480 #define PPC_IRQ_CPM_RESERVED_8 (PPC_STD_IRQ_LAST + 34)
481 #define PPC_IRQ_CPM_PC7 (PPC_STD_IRQ_LAST + 35)
482 #define PPC_IRQ_CPM_PC8 (PPC_STD_IRQ_LAST + 36)
483 #define PPC_IRQ_CPM_PC9 (PPC_STD_IRQ_LAST + 37)
484 #define PPC_IRQ_CPM_TIMER3 (PPC_STD_IRQ_LAST + 38)
485 #define PPC_IRQ_CPM_RESERVED_D (PPC_STD_IRQ_LAST + 39)
486 #define PPC_IRQ_CPM_PC10 (PPC_STD_IRQ_LAST + 40)
487 #define PPC_IRQ_CPM_PC11 (PPC_STD_IRQ_LAST + 41)
488 #define PPC_IRQ_CPM_I2C (PPC_STD_IRQ_LAST + 42)
489 #define PPC_IRQ_CPM_RISC_TIMER (PPC_STD_IRQ_LAST + 43)
490 #define PPC_IRQ_CPM_TIMER2 (PPC_STD_IRQ_LAST + 44)
491 #define PPC_IRQ_CPM_RESERVED_13 (PPC_STD_IRQ_LAST + 45)
492 #define PPC_IRQ_CPM_IDMA2 (PPC_STD_IRQ_LAST + 46)
493 #define PPC_IRQ_CPM_IDMA1 (PPC_STD_IRQ_LAST + 47)
494 #define PPC_IRQ_CPM_SDMA_ERROR (PPC_STD_IRQ_LAST + 48)
495 #define PPC_IRQ_CPM_PC12 (PPC_STD_IRQ_LAST + 49)
496 #define PPC_IRQ_CPM_PC13 (PPC_STD_IRQ_LAST + 50)
497 #define PPC_IRQ_CPM_TIMER1 (PPC_STD_IRQ_LAST + 51)
498 #define PPC_IRQ_CPM_PC14 (PPC_STD_IRQ_LAST + 52)
499 #define PPC_IRQ_CPM_SCC4 (PPC_STD_IRQ_LAST + 53)
500 #define PPC_IRQ_CPM_SCC3 (PPC_STD_IRQ_LAST + 54)
501 #define PPC_IRQ_CPM_SCC2 (PPC_STD_IRQ_LAST + 55)
502 #define PPC_IRQ_CPM_SCC1 (PPC_STD_IRQ_LAST + 56)
503 #define PPC_IRQ_CPM_PC15 (PPC_STD_IRQ_LAST + 57)
504
505 #define PPC_IRQ_LAST PPC_IRQ_CPM_PC15
506
507 #elif defined(mpc8260)
508
509 #define PPC_IRQ_INST_MISS (PPC_STD_IRQ_LAST+1) /*0x1000-Instruction TLB miss*/
510 #define PPC_IRQ_DATA_MISS (PPC_STD_IRQ_LAST+2) /*0x1100-Data TLB miss */
511 #define PPC_IRQ_DATA_L_MISS (PPC_STD_IRQ_LAST+3) /*0x1200-Data TLB load miss */
512 #define PPC_IRQ_DATA_S_MISS (PPC_STD_IRQ_LAST+4) /*0x1300-Data TLB store miss */
513 #define PPC_IRQ_INST_BPNT (PPC_STD_IRQ_LAST+5) /*0x1400-Inst address breakpoint */
514 #define PPC_IRQ_SYS_MGT (PPC_STD_IRQ_LAST+6) /*0x1500-System Management */
515 /* 0x1600 - 0x2F00 reserved */
516 #define PPC_IRQ_CPM_NONE (PPC_STD_IRQ_LAST + 50)
517 #define PPC_IRQ_CPM_I2C (PPC_STD_IRQ_LAST + 51)
518 #define PPC_IRQ_CPM_SPI (PPC_STD_IRQ_LAST + 52)
519 #define PPC_IRQ_CPM_RISC_TIMER (PPC_STD_IRQ_LAST + 53)
520 #define PPC_IRQ_CPM_SMC1 (PPC_STD_IRQ_LAST + 54)
521 #define PPC_IRQ_CPM_SMC2 (PPC_STD_IRQ_LAST + 55)
522 #define PPC_IRQ_CPM_IDMA1 (PPC_STD_IRQ_LAST + 56)
523 #define PPC_IRQ_CPM_IDMA2 (PPC_STD_IRQ_LAST + 57)
524 #define PPC_IRQ_CPM_IDMA3 (PPC_STD_IRQ_LAST + 58)
525 #define PPC_IRQ_CPM_IDMA4 (PPC_STD_IRQ_LAST + 59)
526 #define PPC_IRQ_CPM_SDMA (PPC_STD_IRQ_LAST + 60)
527 #define PPC_IRQ_CPM_RES_A (PPC_STD_IRQ_LAST + 61)
528 #define PPC_IRQ_CPM_TIMER1 (PPC_STD_IRQ_LAST + 62)
529 #define PPC_IRQ_CPM_TIMER2 (PPC_STD_IRQ_LAST + 63)
530 #define PPC_IRQ_CPM_TIMER3 (PPC_STD_IRQ_LAST + 64)
531 #define PPC_IRQ_CPM_TIMER4 (PPC_STD_IRQ_LAST + 65)
532 #define PPC_IRQ_CPM_TMCNT (PPC_STD_IRQ_LAST + 66)
533 #define PPC_IRQ_CPM_PIT (PPC_STD_IRQ_LAST + 67)
534 #define PPC_IRQ_CPM_RES_B (PPC_STD_IRQ_LAST + 68)
535 #define PPC_IRQ_CPM_IRQ1 (PPC_STD_IRQ_LAST + 69)
536 #define PPC_IRQ_CPM_IRQ2 (PPC_STD_IRQ_LAST + 70)
537 #define PPC_IRQ_CPM_IRQ3 (PPC_STD_IRQ_LAST + 71)
538 #define PPC_IRQ_CPM_IRQ4 (PPC_STD_IRQ_LAST + 72)
539 #define PPC_IRQ_CPM_IRQ5 (PPC_STD_IRQ_LAST + 73)
540 #define PPC_IRQ_CPM_IRQ6 (PPC_STD_IRQ_LAST + 74)
541 #define PPC_IRQ_CPM_IRQ7 (PPC_STD_IRQ_LAST + 75)
542 #define PPC_IRQ_CPM_RES_C (PPC_STD_IRQ_LAST + 76)
543 #define PPC_IRQ_CPM_RES_D (PPC_STD_IRQ_LAST + 77)
544 #define PPC_IRQ_CPM_RES_E (PPC_STD_IRQ_LAST + 78)
545 #define PPC_IRQ_CPM_RES_F (PPC_STD_IRQ_LAST + 79)
546 #define PPC_IRQ_CPM_RES_G (PPC_STD_IRQ_LAST + 80)
547 #define PPC_IRQ_CPM_RES_H (PPC_STD_IRQ_LAST + 81)
548 #define PPC_IRQ_CPM_FCC1 (PPC_STD_IRQ_LAST + 82)
549 #define PPC_IRQ_CPM_FCC2 (PPC_STD_IRQ_LAST + 83)
550 #define PPC_IRQ_CPM_FCC3 (PPC_STD_IRQ_LAST + 84)
551 #define PPC_IRQ_CPM_RES_I (PPC_STD_IRQ_LAST + 85)
552 #define PPC_IRQ_CPM_MCC1 (PPC_STD_IRQ_LAST + 86)
553 #define PPC_IRQ_CPM_MCC2 (PPC_STD_IRQ_LAST + 87)
554 #define PPC_IRQ_CPM_RES_J (PPC_STD_IRQ_LAST + 88)
555 #define PPC_IRQ_CPM_RES_K (PPC_STD_IRQ_LAST + 89)
556 #define PPC_IRQ_CPM_SCC1 (PPC_STD_IRQ_LAST + 90)
557 #define PPC_IRQ_CPM_SCC2 (PPC_STD_IRQ_LAST + 91)
558 #define PPC_IRQ_CPM_SCC3 (PPC_STD_IRQ_LAST + 92)
559 #define PPC_IRQ_CPM_SCC4 (PPC_STD_IRQ_LAST + 93)
560 #define PPC_IRQ_CPM_RES_L (PPC_STD_IRQ_LAST + 94)
561 #define PPC_IRQ_CPM_RES_M (PPC_STD_IRQ_LAST + 95)
562 #define PPC_IRQ_CPM_RES_N (PPC_STD_IRQ_LAST + 96)
563 #define PPC_IRQ_CPM_RES_O (PPC_STD_IRQ_LAST + 97)
564 #define PPC_IRQ_CPM_PC15 (PPC_STD_IRQ_LAST + 98)
565 #define PPC_IRQ_CPM_PC14 (PPC_STD_IRQ_LAST + 99)
566 #define PPC_IRQ_CPM_PC13 (PPC_STD_IRQ_LAST + 100)
567 #define PPC_IRQ_CPM_PC12 (PPC_STD_IRQ_LAST + 101)
568 #define PPC_IRQ_CPM_PC11 (PPC_STD_IRQ_LAST + 102)
569 #define PPC_IRQ_CPM_PC10 (PPC_STD_IRQ_LAST + 103)
570 #define PPC_IRQ_CPM_PC9 (PPC_STD_IRQ_LAST + 104)
571 #define PPC_IRQ_CPM_PC8 (PPC_STD_IRQ_LAST + 105)
572 #define PPC_IRQ_CPM_PC7 (PPC_STD_IRQ_LAST + 106)
573 #define PPC_IRQ_CPM_PC6 (PPC_STD_IRQ_LAST + 107)
574 #define PPC_IRQ_CPM_PC5 (PPC_STD_IRQ_LAST + 108)
575 #define PPC_IRQ_CPM_PC4 (PPC_STD_IRQ_LAST + 109)
576 #define PPC_IRQ_CPM_PC3 (PPC_STD_IRQ_LAST + 110)
577 #define PPC_IRQ_CPM_PC2 (PPC_STD_IRQ_LAST + 111)
578 #define PPC_IRQ_CPM_PC1 (PPC_STD_IRQ_LAST + 112)
579 #define PPC_IRQ_CPM_PC0 (PPC_STD_IRQ_LAST + 113)
580
581 #define PPC_IRQ_LAST PPC_IRQ_CPM_PC0
582
583 #endif
584
585
586 /*
587  * If the maximum number of exception sources is too low,
588  * then fix it
589  */
590
591 #if PPC_INTERRUPT_MAX <= PPC_IRQ_LAST
592 #undef PPC_INTERRUPT_MAX
593 #define PPC_INTERRUPT_MAX ((PPC_IRQ_LAST) + 1)
594 #endif
595
596 /*
597  * Machine Status Register (MSR) Constants Used by RTEMS
598  */
599
600 #if PPC_HAS_RI
601 #define PPC_MSR_RI 0x000000002 /* bit 30 - recoverable exception */
602 #endif
603
604 #define PPC_MSR_DR 0x000000010 /* bit 27 - data address translation */
605 #define PPC_MSR_IR 0x000000020 /* bit 26 - instruction addr translation*/
606
607 /*
608  * Some PPC model manuals refer to the Exception Prefix (EP) bit as
609  * IP for no apparent reason.
610  */
611 #if (PPC_HAS_EXCEPTION_PREFIX)
612 #define PPC_MSR_EP 0x000000040 /* bit 25 - exception prefix */
613 #else
614 #define PPC_MSR_EP 0x000000000 /* bit 25 - exception prefix */
615 #endif
616
617 #if (PPC_HAS_FPU)
618 #define PPC_MSR_FP 0x000002000 /* bit 18 - floating point enable */
619 #else
620 #define PPC_MSR_FP 0x000000000 /* bit 18 - floating point enable */
621 #endif
622
623 #if (PPC_LOW_POWER_MODE == PPC_LOW_POWER_MODE_NONE)
624 #define PPC_MSR_POW 0x000000000 /* bit 13 - power management enable */
625 #else
626 #define PPC_MSR_POW 0x000040000 /* bit 13 - power management enable */
627 #endif
628
629 #define PPC_MSR_ME 0x000001000 /* bit 19 - machine check enable */
630 #define PPC_MSR_EE 0x000008000 /* bit 16 - external interrupt enable */
631
632 #if (PPC_HAS_RFCI)
633 #define PPC_MSR_CE 0x000020000 /* bit 14 - critical interrupt enable */
634 #else
635 #define PPC_MSR_CE 0x000000000 /* bit 14 - critical interrupt enable */
636 #endif
637
638 #define PPC_MSR_DISABLE_MASK (PPC_MSR_ME|PPC_MSR_EE|PPC_MSR_CE)
639
640 #if defined(__powerpc64__)
641 #define PPC_MINIMUM_STACK_FRAME_SIZE 32
642 #else
643 #define PPC_MINIMUM_STACK_FRAME_SIZE PPC_STACK_ALIGNMENT
644 #endif
645
646 #ifdef __cplusplus
647 }
648 #endif
649
650 #endif /* _RTEMS_POWERPC_POWERPC_H */
IBM/Motorola PowerPC Definitions.
