RTEMS  5.1
bsp.h
1
9 /*
10  * bsp.h -- contain BSP API definition.
11  */
12
13 /*
14  * Copyright (C) 1999 Eric Valette. valette@crf.canon.fr
15  *
16  * The license and distribution terms for this file may be
17  * found in the file LICENSE in this distribution or at
18  * http://www.rtems.org/license/LICENSE.
19  *
20  * S. Kate Feng 2003-2007 : Modified it to support the mvme5500 BSP.
21  *
22  * Modified for the 'beatnik' BSP by T. Straumann, 2005-2007.
23  */
24
25 #ifndef LIBBSP_BEATNIK_BSP_H
26 #define LIBBSP_BEATNIK_BSP_H
27
38 #ifndef ASM
39
40 #include <bspopts.h>
42
43 #include <rtems.h>
44 #include <libcpu/io.h>
45 #include <bsp/vectors.h>
46
47 #ifdef __cplusplus
48 extern "C" {
49 #endif
50
51 /* Board type */
52 typedef enum {
53  Unknown = 0,
54  MVME5500,
55  MVME6100
56 } BSP_BoardType;
57
58 BSP_BoardType BSP_getBoardType(void);
59
60 /* Discovery Version */
61
62 typedef enum {
63  unknown = 0,
64  GT_64260_A, /* Revision 0x10 */
65  GT_64260_B, /* Revision 0x20 */
66  MV_64360,
67 } DiscoveryVersion;
68
69 /* Determine the type of discovery chip on this board; info
70  * is cached and repeated calls just return the cached value.
71  *
72  * If a non-zero argument is passed, the routine panics
73  * (rtems_panic) if no recognized bridge is found;
74  */
75 DiscoveryVersion BSP_getDiscoveryVersion(int assertion);
76
77 /*
78  * confdefs.h overrides for this BSP:
79  * - Interrupt stack space is not minimum if defined.
80  */
81 #define BSP_INTERRUPT_STACK_SIZE (16 * 1024)
82
83 /*
84  * base address definitions for several devices
85  */
86 #define BSP_MV64x60_BASE (0xf1000000)
87 #define BSP_MV64x60_DEV1_BASE (0xf1100000)
88 #define BSP_UART_IOBASE_COM1 ((BSP_MV64x60_DEV1_BASE)+0x20000)
89 #define BSP_UART_IOBASE_COM2 ((BSP_MV64x60_DEV1_BASE)+0x21000)
90 #define BSP_UART_USE_SHARED_IRQS
91
92 #define BSP_NVRAM_BASE_ADDR (0xf1110000)
93 #define BSP_NVRAM_END_ADDR (0xf1117fff)
94 #define BSP_NVRAM_RTC_START (0xf1117ff8)
95
96 #define BSP_NVRAM_BOOTPARMS_START (0xf1111000)
97 #define BSP_NVRAM_BOOTPARMS_END (0xf1111fff)
98
99
100 /* This is only active/used during early init. It defines
101  * the hose0 base for the shared/generic pci code.
102  * Our own BSP specific pci initialization will then
103  * override the PCI configuration (see gt_pci_init.c:BSP_pci_initialize)
104  */
105
106 #define PCI_CONFIG_ADDR (BSP_MV64x60_BASE + 0xcf8)
107 #define PCI_CONFIG_DATA (BSP_MV64x60_BASE + 0xcfc)
108
109 /* our wonderful PCI initialization remaps everything to CPU addresses
110  * - before calling BSP_pci_initialize() this is NOT VALID, however
111  * and the deprecated inl()/outl() etc won't work!
112  */
113 #define _IO_BASE 0x00000000
114 /* wonderful MotLoad has the base address as seen from the
115  * CPU programmed into config space :-)
116  */
117 #define PCI_MEM_BASE 0
118 #define PCI_MEM_BASE_ADJUSTMENT 0
119 #define PCI_DRAM_OFFSET 0
120
121 extern void BSP_motload_pci_fixup(void);
122
123 /* PCI <-> local address mapping - no sophisticated windows
124  * (i.e., no support for cached regions etc. you read a BAR
125  * from config space and that's 1:1 where the CPU sees it).
126  * Our memory is mapped 1:1 to PCI also.
127  */
128 #define BSP_PCI2LOCAL_ADDR(a) ((uint32_t)(a))
129 #define BSP_LOCAL2PCI_ADDR(a) ((uint32_t)(a))
130
131 #define BSP_CONFIG_NUM_PCI_CACHE_SLOTS 32
132
133 #define BSP_CONSOLE_PORT BSP_UART_COM1
134 #define BSP_UART_BAUD_BASE 115200
135
136 /* I2C Devices */
137 /* Note that the i2c addresses stated in the manual are
138  * left-shifted by one bit.
139  */
140 #define BSP_VPD_I2C_ADDR (0xA8>>1) /* the VPD EEPROM */
141 #define BSP_USR_I2C_ADDR (0xAA>>1) /* the user EEPROM */
142 #define BSP_THM_I2C_ADDR (0x90>>1) /* the DS1621 temperature sensor & thermostat */
143
144 #define BSP_I2C_BUS_DESCRIPTOR gt64260_i2c_bus_descriptor
145
146 #define BSP_I2C_BUS0_NAME "/dev/i2c0"
147
148 #define BSP_I2C_VPD_EEPROM_NAME "vpd-eeprom"
149 #define BSP_I2C_USR_EEPROM_NAME "usr-eeprom"
150 #define BSP_I2C_DS1621_NAME "ds1621"
151 #define BSP_I2C_THM_NAME BSP_I2C_DS1621_NAME
152 #define BSP_I2C_DS1621_RAW_NAME "ds1621-raw"
153
154 #define BSP_I2C_VPD_EEPROM_DEV_NAME (BSP_I2C_BUS0_NAME ", " BSP_I2C_VPD_EEPROM_NAME)
155 #define BSP_I2C_USR_EEPROM_DEV_NAME (BSP_I2C_BUS0_NAME ", " BSP_I2C_USR_EEPROM_NAME)
156 #define BSP_I2C_DS1621_DEV_NAME (BSP_I2C_BUS0_NAME ", " BSP_I2C_DS1621_NAME)
157 #define BSP_I2C_THM_DEV_NAME BSP_I2C_DS1621_DEV_NAME
158 #define BSP_I2C_DS1621_RAW_DEV_NAME (BSP_I2C_BUS0_NAME ", " BSP_I2C_DS1621_RAW_NAME)
159
160
161 /* Initialize the I2C driver and register all devices
162  * RETURNS 0 on success, -1 on error.
163  *
164  * Access to the VPD and user EEPROMS as well
165  * as the ds1621 temperature sensor is possible
166  * by means of file nodes
167  *
168  * /dev/i2c0.vpd-eeprom (read-only)
169  * /dev/i2c0.usr-eeprom (read-write)
170  * /dev/i2c0.ds1621 (read-only; one byte: board-temp in degC)
171  * /dev/i2c0.ds1621-raw (read-write; transfer bytes to/from the ds1621)
172  */
173 int BSP_i2c_initialize(void);
174
175 /* Networking; */
176 #if defined(RTEMS_NETWORKING)
177 #include <bsp/bsp_bsdnet_attach.h>
178 int rtems_em_attach(struct rtems_bsdnet_ifconfig *, int);
179 int rtems_dec21140_driver_attach(struct rtems_bsdnet_ifconfig *, int);
180 int rtems_dc_driver_attach(struct rtems_bsdnet_ifconfig *, int);
181 #endif
182
183 /* NOT FOR PUBLIC USE BELOW HERE */
184 #define BSP_PCI_HOSE0_MEM_BASE 0x80000000 /* must be aligned to size */
185 #define BSP_PCI_HOSE0_MEM_SIZE 0x20000000
186
187 #define BSP_PCI_HOSE1_MEM_BASE 0xe0000000
188
189 #define BSP_DEV_AND_PCI_IO_BASE 0xf0000000
190 #define BSP_DEV_AND_PCI_IO_SIZE 0x10000000
191
192 /* maintain coherency between CPU and GT64340 Ethernet
193  * (andpossibly other Discovery components).
194  */
195 #define BSP_RW_PAGE_ATTRIBUTES TRIV121_ATTR_M
196
197 extern unsigned BSP_pci_hose1_bus_base;
198
199 void BSP_pci_initialize(void);
200
201 /* Exception Handling */
202
203 /* Use a task notepad to attach user exception handler info;
204  * may be changed by application startup code (EPICS uses 11)
205  */
206 #define BSP_EXCEPTION_NOTEPAD 14
207
208 #ifndef ASM
209
210 #define outport_byte(port,value) outb(value,port)
211 #define outport_word(port,value) outw(value,port)
212 #define outport_long(port,value) outl(value,port)
213
214 #define inport_byte(port,value) (value = inb(port))
215 #define inport_word(port,value) (value = inw(port))
216 #define inport_long(port,value) (value = inl(port))
217 /*
218  * Vital Board data Start using DATA RESIDUAL
219  */
220 /*
221  * Total memory using RESIDUAL DATA
222  */
223 extern unsigned int BSP_mem_size;
224 /*
225  * Start of the heap
226  */
227 extern unsigned int BSP_heap_start;
228 /*
229  * PCI Bus Frequency
230  */
231 extern unsigned int BSP_bus_frequency;
232 /*
233  * processor clock frequency
234  */
235 extern unsigned int BSP_processor_frequency;
236 /*
237  * Time base divisior (how many tick for 1 second).
238  */
239 extern unsigned int BSP_time_base_divisor;
240
241 extern char BSP_productIdent[20];
242 extern char BSP_serialNumber[20];
243
244 extern char BSP_enetAddr0[7];
245 extern char BSP_enetAddr1[7];
246
247 /*
248  * The commandline as passed from the bootloader.
249  */
250 extern char *BSP_commandline_string;
251
252
253 #define BSP_Convert_decrementer( _value ) \
254  ((unsigned long long) ((((unsigned long long)BSP_time_base_divisor) * 1000000ULL) /((unsigned long long) BSP_bus_frequency)) * ((unsigned long long) (_value)))
255
256 extern void bsp_reset(void);
257 extern int BSP_disconnect_clock_handler (void);
258 extern int BSP_connect_clock_handler (void);
259
260 /* clear hostbridge errors
261  *
262  * enableMCP: whether to enable MCP checkstop / machine check interrupts
263  * on the hostbridge and in HID0.
264  *
265  * NOTE: The 5500 and 6100 boards have NO PHYSICAL CONNECTION
266  * to MCP so 'enableMCP' will always fail!
267  *
268  * quiet : be silent
269  *
270  * RETURNS : PCI status (hose 0 in byte 0, host 1 in byte 1) and
271  * VME bridge status (upper 16 bits).
272  * Zero if no errors were found.
273  */
274 extern unsigned long _BSP_clear_hostbridge_errors(int enableMCP, int quiet);
275
276 /* clear vme bridge errors and return (bridge-dependent) 16-bit status
277  *
278  * quiet : be silent
279  *
280  * RETURNS : 0 if there were no errors, non-zero, bridge-dependent
281  * 16-bit error status on error.
282  *
283  */
284 extern unsigned short (*_BSP_clear_vmebridge_errors)(int);
285
286 /*
287  * Prototypes for debug helpers
288  */
289 void discovery_pic_set_debug_irq(int on);
290 void discovery_pic_install_debug_irq(void);
291
292 /*
293  * Prototypes for methods called only from .S for dependency tracking
294  */
295 char *save_boot_params(
296  void *r3,
297  void *r4,
298  void *r5,
299  char *cmdline_start,
300  char *cmdline_end
301 );
302 void zero_bss(void);
303
304 /*
305  * Prototypes for methods in the BSP that cross file boundaries
306  */
307 uint32_t probeMemoryEnd(void);
308
309 #endif
310
311 #ifdef __cplusplus
312 }
313 #endif
314
315 #endif /* !ASM */
316
319 #endif
DEFAULT_INITIAL_EXTENSION Support.
PowerPC Exceptions API.
int BSP_connect_clock_handler(void)
Clock Tick Device Driver.
Definition: p_clock.c:37
