#define | BSP_FEATURE_IRQ_EXTENSION |
#define | BSP_SHARED_HANDLER_SUPPORT 1 |
#define | REVISION_REGISTER_ADDRESS 0x1fc00010 |
#define | PRORV_MASK 0x0000000f /* 4 bit Product Revision */ |
#define | PROID_MASK 0x000000f0 /* 4 bit Product ID */ |
#define | CORRV_MASK 0x00000300 /* 2 bit Core Board Revision */ |
#define | CORID_MASK 0x0000fc00 /* 6 bit Core Board ID */ |
#define | FPGRV_MASK 0x00ff0000 /* 8 bit CBUS FPGA Revision */ |
#define | BSP_8259_BASE_ADDRESS (0x18000000UL | 0xa0000000UL) |
#define | BSP_PCI_BASE_ADDRESS (0x1be00000UL | 0xa0000000UL) |
#define | BSP_NIC_IO_BASE (0x10000000UL | 0xa0000000UL) |
#define | PCI0_IO_BASE (0x18000000UL | 0xa0000000UL) |
#define | BSP_NIC_MEM_BASE (0x00000000UL | 0xa0000000UL) |
#define | WRITE_PROTECTED_UINT8(_addr, _value) |
#define | WRITE_PROTECTED_UINT16(_addr, _value) |
#define | WRITE_PROTECTED_UINT32(_addr, _value) |
#define | READ_PROTECTED_UINT8(_addr, _value) |
#define | READ_PROTECTED_UINT16(_addr, _value) |
#define | READ_PROTECTED_UINT32(_addr, _value) |
#define | READ_UINT8(_register_, _value_) ((_value_) = *((volatile unsigned char *)(_register_))) |
#define | WRITE_UINT8(_register_, _value_) (*((volatile unsigned char *)(_register_)) = (_value_)) |
#define | READ_UINT16(_register_, _value_) ((_value_) = *((volatile unsigned short *)(_register_))) |
#define | WRITE_UINT16(_register_, _value_) (*((volatile unsigned short *)(_register_)) = (_value_)) |
