RTEMS  5.1
irq.h
1
9 /*
10  * COPYRIGHT (c) 1989-2012.
11  * On-Line Applications Research Corporation (OAR).
12  *
13  * The license and distribution terms for this file may be
14  * found in the file LICENSE in this distribution or at
15  * http://www.rtems.org/license/LICENSE.
16  */
17
18 #ifndef LIBBSP_MIPS_MALTA_IRQ_H
19 #define LIBBSP_MIPS_MALTA_IRQ_H
20
21 #ifndef ASM
22  #include <rtems.h>
23  #include <rtems/irq.h>
24  #include <rtems/irq-extension.h>
25  #include <rtems/score/mips.h>
26 #endif
27
34 #define BSP_INTERRUPT_VECTOR_MIN 0
35
36 /*
37  * Interrupt Vector Numbers
38  *
39  * NOTE: Numbers 0-15 directly map to levels on the IRC.
40  * Number 16 is "1xxxx" per p. 164 of the TX3904 manual.
41  */
42 #define MALTA_CPU_INT_START MIPS_INTERRUPT_BASE+0
43 #define MALTA_CPU_INT_SW0 MALTA_CPU_INT_START+0
44 #define MALTA_CPU_INT_SW2 MALTA_CPU_INT_START+1
45 #define MALTA_CPU_INT0 MALTA_CPU_INT_START+2
46 #define MALTA_CPU_INT1 MALTA_CPU_INT_START+3
47 #define MALTA_CPU_INT2 MALTA_CPU_INT_START+4
48 #define MALTA_CPU_INT3 MALTA_CPU_INT_START+5
49 #define MALTA_CPU_INT4 MALTA_CPU_INT_START+6
50 #define MALTA_CPU_INT5 MALTA_CPU_INT_START+7
51 #define MALTA_CPU_INT_LAST MALTA_CPU_INT5
52
53 #define MALTA_SB_IRQ_START MALTA_CPU_INT_LAST+1
54 #define MALTA_SB_IRQ_0 MALTA_SB_IRQ_START+0
55 #define MALTA_SB_IRQ_1 MALTA_SB_IRQ_START+1
56 #define MALTA_SB_IRQ_2 MALTA_SB_IRQ_START+2
57 #define MALTA_SB_IRQ_3 MALTA_SB_IRQ_START+3
58 #define MALTA_SB_IRQ_4 MALTA_SB_IRQ_START+4
59 #define MALTA_SB_IRQ_5 MALTA_SB_IRQ_START+5
60 #define MALTA_SB_IRQ_6 MALTA_SB_IRQ_START+6
61 #define MALTA_SB_IRQ_7 MALTA_SB_IRQ_START+7
62 #define MALTA_SB_IRQ_8 MALTA_SB_IRQ_START+8
63 #define MALTA_SB_IRQ_9 MALTA_SB_IRQ_START+9
64 #define MALTA_SB_IRQ_10 MALTA_SB_IRQ_START+10
65 #define MALTA_SB_IRQ_11 MALTA_SB_IRQ_START+11
66 #define MALTA_SB_IRQ_12 MALTA_SB_IRQ_START+12
67 #define MALTA_SB_IRQ_13 MALTA_SB_IRQ_START+13
68 #define MALTA_SB_IRQ_14 MALTA_SB_IRQ_START+14
69 #define MALTA_SB_IRQ_15 MALTA_SB_IRQ_START+15
70 #define MALTA_SB_IRQ_LAST MALTA_SB_IRQ_15
71
72 #define MALTA_PCI_ADP_START MALTA_SB_IRQ_LAST+1
73 #define MALTA_PCI_ADP20 MALTA_PCI_ADP_START+0
74 #define MALTA_PCI_ADP21 MALTA_PCI_ADP_START+1
75 #define MALTA_PCI_ADP22 MALTA_PCI_ADP_START+2
76 #define MALTA_PCI_ADP27 MALTA_PCI_ADP_START+3
77 #define MALTA_PCI_ADP28 MALTA_PCI_ADP_START+4
78 #define MALTA_PCI_ADP29 MALTA_PCI_ADP_START+5
79 #define MALTA_PCI_ADP30 MALTA_PCI_ADP_START+6
80 #define MALTA_PCI_ADP31 MALTA_PCI_ADP_START+7
81 #define MALTA_PCI_ADP_LAST MALTA_PCI_ADP31
82 #
83
84 #define BSP_INTERRUPT_VECTOR_MAX MALTA_PCI_ADP_LAST
85
86 /*
87  * Redefine interrupts with more descriptive names.
88  * The Generic ones above match the hardware name,
89  * where these match the device name.
90  */
91 #define MALTA_INT_SOUTHBRIDGE_INTR MALTA_CPU_INT0
92 #define MALTA_INT_SOUTHBRIDGE_SMI MALTA_CPU_INT1
93 #define MALTA_INT_TTY2 MALTA_CPU_INT2
94 #define MALTA_INT_COREHI MALTA_CPU_INT3
95 #define MALTA_INT_CORELO MALTA_CPU_INT4
96 #define MALTA_INT_TICKER MALTA_CPU_INT5
97
98 #define MALTA_IRQ_TIMER_SOUTH_BRIDGE MALTA_SB_IRQ_0
99 #define MALTA_IRQ_KEYBOARD_SUPERIO MALTA_SB_IRQ_1
100 #define MALTA_IRQ_RESERVED1_SOUTH_BRIDGE MALTA_SB_IRQ_2
101 #define MALTA_IRQ_TTY1 MALTA_SB_IRQ_3
102 #define MALTA_IRQ_TTY0 MALTA_SB_IRQ_4
103 #define MALTA_IRQ_NOT_USED MALTA_SB_IRQ_5
104 #define MALTA_IRQ_FLOPPY_SUPERIO MALTA_SB_IRQ_6
105 #define MALTA_IRQ_PARALLEL_PORT_SUPERIO MALTA_SB_IRQ_7
106 #define MALTA_IRQ_REALTIME_CLOCK_SOUTH_BRIDGE MALTA_SB_IRQ_8
107 #define MALTA_IRQ_I2C_SOUTH_BRIDGE MALTA_SB_IRQ_9
108 /* PCI A, PCI B (including Ethernet) PCI slot 1..4, Ethernet */
109 #define MALTA_IRQ_PCI_A_B MALTA_SB_IRQ_10
110 /* PCI slot 1..4 (audio, USB) */
111 #define MALTA_IRQ_PCI_C_D MALTA_SB_IRQ_11
112 #define MALTA_IRQ_MOUSE_SUPERIO MALTA_SB_IRQ_12
113 #define MALTA_IRQ_RESERVED2_SOUTH_BRIDGE MALTA_SB_IRQ_13
114 #define MALTA_IRQ_PRIMARY_IDE MALTA_SB_IRQ_14
115 #define MALTA_IRQ_SECONDARY_IDE MALTA_SB_IRQ_15
116 #define MALTA_IRQ_SOUTH_BRIDGE MALTA_PCI_ADP20
117 #define MALTA_IRQ_ETHERNET MALTA_IRQ_PCI_A_B
118 #define MALTA_IRQ_AUDIO MALTA_PCI_ADP22
119 #define MALTA_IRQ_CORE_CARD MALTA_PCI_ADP27
120 #define MALTA_IRQ_PCI_CONNECTOR_1 MALTA_PCI_ADP28
121 #define MALTA_IRQ_PCI_CONNECTOR_2 MALTA_PCI_ADP29
122 #define MALTA_IRQ_PCI_CONNECTOR_3 MALTA_PCI_ADP30
123 #define MALTA_IRQ_PCI_CONNECTOR_4 MALTA_PCI_ADP31
124
125 #ifndef ASM
126
127 #endif /* ASM */
128
131 #endif /* LIBBSP_MIPS_MALTA_IRQ_H */
Header file for the Interrupt Manager Extension.
Information to build RTEMS for a "no cpu" while in protected mode.
