RTEMS  5.1
irq.h
1
9 /*
10  * COPYRIGHT (c) 1989-2012.
11  * On-Line Applications Research Corporation (OAR).
12  *
13  * The license and distribution terms for this file may be
14  * found in the file LICENSE in this distribution or at
15  * http://www.rtems.org/license/LICENSE.
16  */
17
18 #ifndef LIBBSP_MIPS_JMR3904_IRQ_H
19 #define LIBBSP_MIPS_JMR3904_IRQ_H
20
21 #ifndef ASM
22  #include <rtems.h>
23  #include <rtems/irq.h>
24  #include <rtems/irq-extension.h>
25  #include <rtems/score/mips.h>
26 #endif
27
34 #define BSP_INTERRUPT_VECTOR_MIN 0
35
36 /*
37  * Interrupt Vector Numbers
38  *
39  * NOTE: Numbers 0-15 directly map to levels on the IRC.
40  * Number 16 is "1xxxx" per p. 164 of the TX3904 manual.
41  */
42
43  #define TX3904_IRQ_INT1 MIPS_INTERRUPT_BASE+0
44  #define TX3904_IRQ_INT2 MIPS_INTERRUPT_BASE+1
45  #define TX3904_IRQ_INT3 MIPS_INTERRUPT_BASE+2
46  #define TX3904_IRQ_INT4 MIPS_INTERRUPT_BASE+3
47  #define TX3904_IRQ_INT5 MIPS_INTERRUPT_BASE+4
48  #define TX3904_IRQ_INT6 MIPS_INTERRUPT_BASE+5
49  #define TX3904_IRQ_INT7 MIPS_INTERRUPT_BASE+6
50  #define TX3904_IRQ_DMAC3 MIPS_INTERRUPT_BASE+7
51  #define TX3904_IRQ_DMAC2 MIPS_INTERRUPT_BASE+8
52  #define TX3904_IRQ_DMAC1 MIPS_INTERRUPT_BASE+9
53  #define TX3904_IRQ_DMAC0 MIPS_INTERRUPT_BASE+10
54  #define TX3904_IRQ_SIO0 MIPS_INTERRUPT_BASE+11
55  #define TX3904_IRQ_SIO1 MIPS_INTERRUPT_BASE+12
56  #define TX3904_IRQ_TMR0 MIPS_INTERRUPT_BASE+13
57  #define TX3904_IRQ_TMR1 MIPS_INTERRUPT_BASE+14
58  #define TX3904_IRQ_TMR2 MIPS_INTERRUPT_BASE+15
59  #define TX3904_IRQ_INT0 MIPS_INTERRUPT_BASE+16
60  #define TX3904_IRQ_SOFTWARE_1 MIPS_INTERRUPT_BASE+17
61  #define TX3904_IRQ_SOFTWARE_2 MIPS_INTERRUPT_BASE+18
62  #define TX3904_MAXIMUM_VECTORS MIPS_INTERRUPT_BASE+19
63
64 #define BSP_INTERRUPT_VECTOR_MAX TX3904_MAXIMUM_VECTORS
65
68 #endif /* LIBBSP_MIPS_JMR3904_IRQ_H */
Header file for the Interrupt Manager Extension.
Information to build RTEMS for a "no cpu" while in protected mode.
