RTEMS  5.1
bsp.h
1
9 /*
10  * uC5282 BSP header file
11  *
12  * Author: W. Eric Norum <norume@aps.anl.gov>
13  *
14  * COPYRIGHT (c) 2005.
15  * On-Line Applications Research Corporation (OAR).
16  *
17  * The license and distribution terms for this file may be
18  * found in the file LICENSE in this distribution or at
19  * http://www.rtems.org/license/LICENSE.
20  */
21
22 #ifndef LIBBSP_M68K_UC5282_BSP_H
23 #define LIBBSP_M68K_UC5282_BSP_H
24
35 #include <bspopts.h>
37
38 #include <rtems.h>
39 #include <rtems/bspIo.h>
40
41 #ifdef __cplusplus
42 extern "C" {
43 #endif
44
45 /***************************************************************************/
47 /*
48  * Uncomment to use instruction/data cache
49  * Leave commented to use instruction-only cache
50  */
51 #define RTEMS_MCF5282_BSP_ENABLE_DATA_CACHE
52
53 /***************************************************************************/
55 #include <mcf5282/mcf5282.h> /* internal MCF5282 modules */
56
57 /***************************************************************************/
59 struct rtems_bsdnet_ifconfig;
60 extern int rtems_fec_driver_attach (struct rtems_bsdnet_ifconfig *config, int attaching );
61 #define RTEMS_BSP_NETWORK_DRIVER_NAME "fs1"
62 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_fec_driver_attach
63
64 /***************************************************************************/
67 /* define which port the console should use - all other ports are then defined as general purpose */
68 #define CONSOLE_PORT 0
69
70 /* functions */
71
72 typedef struct {
73  unsigned int l;
74  void *v;
75 } bsp_mnode_t;
76
77 #define RTEMS_BSP_PGM_ERASE_FIRST 0x1
78 #define RTEMS_BSP_PGM_RESET_AFTER 0x2
79 #define RTEMS_BSP_PGM_EXEC_AFTER 0x4
80 #define RTEMS_BSP_PGM_HALT_AFTER 0x8
81
82 uint32_t bsp_get_CPU_clock_speed(void);
83 rtems_status_code bsp_allocate_interrupt(int level, int priority);
84 int bsp_sysReset(int flags);
85 int bsp_program(bsp_mnode_t *chain, int flags);
86 unsigned const char *bsp_gethwaddr(int a);
87 const char *bsp_getbenv(const char *a);
88 int bsp_flash_erase_range(volatile unsigned short *flashptr, int start, int end);
89 int bsp_flash_write_range(volatile unsigned short *flashptr, bsp_mnode_t *chain, int offset);
90
91 rtems_isr_entry set_vector(
92  rtems_isr_entry handler,
93  rtems_vector_number vector,
94  int type
95 );
96
97 /*
98  * Interrupt assignments
99  * Highest-priority listed first
100  */
101 #define FEC_IRQ_LEVEL 4
102 #define FEC_IRQ_RX_PRIORITY 7
103 #define FEC_IRQ_TX_PRIORITY 6
104
105 #define PIT3_IRQ_LEVEL 4
106 #define PIT3_IRQ_PRIORITY 0
107
108 #define UART0_IRQ_LEVEL 3
109 #define UART0_IRQ_PRIORITY 7
110 #define UART1_IRQ_LEVEL 3
111 #define UART1_IRQ_PRIORITY 6
112 #define UART2_IRQ_LEVEL 3
113 #define UART2_IRQ_PRIORITY 5
114
115 /*
116  * Fake VME support
117  * This makes it easier to use EPICS driver support on this BSP.
118  */
119 #define VME_AM_STD_SUP_ASCENDING 0x3f
120 #define VME_AM_STD_SUP_PGM 0x3e
121 #define VME_AM_STD_USR_ASCENDING 0x3b
122 #define VME_AM_STD_USR_PGM 0x3a
123 #define VME_AM_STD_SUP_DATA 0x3d
124 #define VME_AM_STD_USR_DATA 0x39
125 #define VME_AM_EXT_SUP_ASCENDING 0x0f
126 #define VME_AM_EXT_SUP_PGM 0x0e
127 #define VME_AM_EXT_USR_ASCENDING 0x0b
128 #define VME_AM_EXT_USR_PGM 0x0a
129 #define VME_AM_EXT_SUP_DATA 0x0d
130 #define VME_AM_EXT_USR_DATA 0x09
131 #define VME_AM_SUP_SHORT_IO 0x2d
132 #define VME_AM_USR_SHORT_IO 0x29
133
134 /*
135  * 'Extended' BSP support
136  */
137 rtems_status_code bspExtInit(void);
138 typedef void (*BSP_VME_ISR_t)(void *usrArg, unsigned long vector);
139 BSP_VME_ISR_t BSP_getVME_isr(unsigned long vector, void **parg);
140 int BSP_installVME_isr(unsigned long vector, BSP_VME_ISR_t handler, void *usrArg);
141 int BSP_removeVME_isr(unsigned long vector, BSP_VME_ISR_t handler, void *usrArg);
142 int BSP_enableVME_int_lvl(unsigned int level);
143 int BSP_disableVME_int_lvl(unsigned int level);
144 int BSP_vme2local_adrs(unsigned am, unsigned long vmeaddr, unsigned long *plocaladdr);
145
146 /*
147  * This BSP provides its own IDLE task to override the RTEMS one.
148  * So we prototype it and define the constant confdefs.h expects
149  * to configure a BSP specific one.
150  */
151 void *bsp_idle_thread( uintptr_t ignored );
152 #define BSP_IDLE_TASK_BODY bsp_idle_thread
153
154 /*
155  * The custom IDLE task keeps some idle statistics.
156  */
157 int bsp_cpu_load_percentage(void);
158
159 /*
160  * This is a helper method to determine the cause of a reset.
161  */
162 void bsp_reset_cause(char *buf, size_t capacity);
163
164 /*
165  * SRAM. The BSP uses SRAM for maintaining some clock-driver data
166  * and for ethernet descriptors (and the initial stack during
167  * early boot).
168  */
169
170 typedef struct mcf5282BufferDescriptor_ {
171  volatile uint16_t status;
172  uint16_t length;
173  volatile void *buffer;
175
176 extern struct {
177  uint32_t idle_counter;
178  uint32_t filtered_idle;
179  uint32_t max_idle_count;
180  uint32_t pitc_per_tick;
181  uint32_t nsec_per_pitc;
182  uint32_t pad[3]; /* align to 16-bytes for descriptors */
183  mcf5282BufferDescriptor_t fec_descriptors[];
184  /* buffer descriptors are allocated from here */
185
186  /* initial stack is at top of SRAM (start.S) */
187 } __SRAMBASE;
188
189 #ifdef __cplusplus
190 }
191 #endif
192
195 #endif
Definition: deflate.c:115
rtems_isr_entry set_vector(rtems_isr_entry handler, rtems_vector_number vector, int type)
Install an interrupt handler.
Definition: setvec.c:28
Definition: network.c:75
DEFAULT_INITIAL_EXTENSION Support.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
rtems_status_code
Classic API Status.
Definition: status.h:43
Interface to Kernel Print Methods.
void * bsp_idle_thread(uintptr_t ignored)
Optimized idle task.
Definition: bspidle.c:26
Definition: bsp.h:72
unsigned l
Definition: tte.h:86
unsigned v
Definition: tte.h:73
