RTEMS  5.1
bsp.h
1
9 /*
10  * This include file contains all MVME162fx board IO definitions.
11  */
12
13 /*
14  * COPYRIGHT (c) 1989-2014.
15  * On-Line Applications Research Corporation (OAR).
16  *
17  * The license and distribution terms for this file may be
18  * found in the file LICENSE in this distribution or at
19  * http://www.rtems.org/license/LICENSE.
20  *
21  * Modifications of respective RTEMS file: COPYRIGHT (c) 1994.
22  * EISCAT Scientific Association. M.Savitski
23  *
24  * This material is a part of the MVME162 Board Support Package
25  * for the RTEMS executive. Its licensing policies are those of the
26  * RTEMS above.
27  */
28
29 #ifndef LIBBSP_M68K_MVME162_BSP_H
30 #define LIBBSP_M68K_MVME162_BSP_H
31
42 #include <bspopts.h>
44
45 #include <rtems.h>
46
47 #include <mvme16x_hw.h>
48
49 #ifdef __cplusplus
50 extern "C" {
51 #endif
52
53 /*----------------------------------------------------------------*/
54
55 typedef volatile struct {
56
57  unsigned char chipID;
58  unsigned char chipREV;
59  unsigned char gen_control;
60  unsigned char vector_base;
61
62  unsigned long timer_cmp_1;
63  unsigned long timer_cnt_1;
64  unsigned long timer_cmp_2;
65  unsigned long timer_cnt_2;
66
67  unsigned char LSB_prescaler_count;
68  unsigned char prescaler_clock_adjust;
69  unsigned char time_ctl_2;
70  unsigned char time_ctl_1;
71
72  unsigned char time_int_ctl_4;
73  unsigned char time_int_ctl_3;
74  unsigned char time_int_ctl_2;
75  unsigned char time_int_ctl_1;
76
77  unsigned char dram_err_int_ctl;
78  unsigned char SCC_int_ctl;
79  unsigned char time_ctl_4;
80  unsigned char time_ctl_3;
81
82  unsigned short DRAM_space_base;
83  unsigned short SRAM_space_base;
84
85  unsigned char DRAM_size;
86  unsigned char DRAM_SRAM_opt;
87  unsigned char SRAM_size;
88  unsigned char reserved;
89
90  unsigned char LANC_error;
91  unsigned char reserved1;
92  unsigned char LANC_int_ctl;
93  unsigned char LANC_berr_ctl;
94
95  unsigned char SCSI_error;
96  unsigned char general_inputs;
97  unsigned char MVME_162_version;
98  unsigned char SCSI_int_ctl;
99
100  unsigned long timer_cmp_3;
101  unsigned long timer_cnt_3;
102  unsigned long timer_cmp_4;
103  unsigned long timer_cnt_4;
104
105  unsigned char bus_clk;
106  unsigned char PROM_acc_time_ctl;
107  unsigned char FLASH_acc_time_ctl;
108  unsigned char ABORT_int_ctl;
109
110  unsigned char RESET_ctl;
111  unsigned char watchdog_timer_ctl;
112  unsigned char acc_watchdog_time_base_sel;
113  unsigned char reserved2;
114
115  unsigned char DRAM_ctl;
116  unsigned char reserved4;
117  unsigned char MPU_status;
118  unsigned char reserved3;
119
120  unsigned long prescaler_count;
121
122 } mcchip_regs;
123
124 #define mcchip ((mcchip_regs * const) 0xFFF42000)
125
126 /*----------------------------------------------------------------*/
127
128 /*
129  * SCC Z8523(0) defines and macros
130  * -------------------------------
131  * Prototypes for the low-level serial io are also included here,
132  * because such stuff is bsp-specific (yet). The function bodies
133  * are in console.c
134  *
135  * NOTE from Eric Vaitl <evaitl@viasat.com>:
136  *
137  * I dropped RTEMS into a 162FX today (the MVME162-513). The 162FX has a
138  * bug in the MC2 chip (revision 1) such that the SCC data register is
139  * not accessible, it has to be accessed indirectly through the SCC
140  * control register.
141  */
142
143 enum {portB, portA};
144
145 extern bool char_ready(int port, char *ch);
146 extern char char_wait(int port);
147 extern void char_put(int port, char ch);
148
149 #define TX_BUFFER_EMPTY 0x04
150 #define RX_DATA_AVAILABLE 0x01
151 #define SCC_VECTOR 0x40
152
153 typedef volatile struct {
154  unsigned char pad1;
155  volatile unsigned char csr;
156  unsigned char pad2;
157  volatile unsigned char buf;
158 } scc_regs;
159
160 #define scc ((scc_regs * const) 0xFFF45000)
161
162 #define ZWRITE0(port, v) (scc[port].csr = (unsigned char)(v))
163 #define ZREAD0(port) (scc[port].csr)
164
165 #define ZREAD(port, n) (ZWRITE0(port, n), (scc[port].csr))
166 #define ZREADD(port) (scc[port].csr=0x08, scc[port].csr )
167
168 #define ZWRITE(port, n, v) (ZWRITE0(port, n), ZWRITE0(port, v))
169 #define ZWRITED(port, v) (scc[port].csr = 0x08, \
170  scc[port].csr = (unsigned char)(v))
171 /*----------------------------------------------------------------*/
172
173 #ifdef M162_INIT
174 #undef EXTERN
175 #define EXTERN
176 #else
177 #undef EXTERN
178 #define EXTERN extern
179 #endif
180
181 /*
182  * This value is the default address location of the 162Bug vector table
183  * and is also the default start address of the boards DRAM. This value
184  * may be different for your specific board based on a number of factors:
185  *
186  * Default DRAM address: 0x00000000
187  * Default SRAM address: 0xFFE00000
188  *
189  * o If no DRAM can be found by the 162Bug program, it will use SRAM.
190  * o The default SRAM address may be different if SRAM mezzanine boards
191  * are installed on the main board.
192  * o Both the DRAM and SRAM addresses can be modified by changing the
193  * appropriate values in NVRAM using the ENV command at the 162Bug
194  * prompt.
195  *
196  * If your board has different values than the defaults, change the value
197  * of the following define.
198  *
199  */
200 #define MOT_162BUG_VEC_ADDRESS 0x00000000
201
202 extern rtems_isr_entry M68Kvec[]; /* vector table address */
203
204 /* functions */
205
206 rtems_isr_entry set_vector(
207  rtems_isr_entry handler,
208  rtems_vector_number vector,
209  int type
210 );
211
212 /*
213  * Prototypes for methods in the BSP that cross file boundaries.
214  */
215 bool char_ready(int port, char *ch);
216
217
218 #ifdef __cplusplus
219 }
220 #endif
221
224 #endif
rtems_isr_entry set_vector(rtems_isr_entry handler, rtems_vector_number vector, int type)
Install an interrupt handler.
Definition: setvec.c:28
DEFAULT_INITIAL_EXTENSION Support.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
Definition: bsp.h:153
MVME16x IO definitions.
Definition: bsp.h:55
